AMD RX Vega
boristsybin
Hardware configuration: 4x1080Ti + 2x1050Ti
AMD RX Vega
Post by boristsybin »
mod note - multiple topics from here and FAH Hardware merged
AMD RX Vega available for preoder. Tech specs are known.
Is any way to predict/pre-calculate vega`s productivity for folding?
Re: AMD RX Vega
Post by foldy »
You can compare RX Vega to Amd Fury X. They both have 4096 shaders but clock of RX Vega 1500Mhz is 50% higher than Fury X with 1050 Mhz, due to reduced structure of 14nm to 28nm. That also matches the Tflops where RX Vega has 13 Tflops and is 50% faster than Fury X with 8,6 Tflops.
As Fury X make 425k PPD the RX Vega will make 850k PPD like a gtx 1080.
But the RX Vega uses upto 300 watts while gtx 1080 uses 200 watts.
The 16nm process used by nvidia is still more efficient than the 14nm used by AMD.
Re: AMD RX Vega
Post by foldy »
AMD RX Vega was presented yesterday and will be released on August 14th.
boristsybin
Re: AMD RX Vega
chemist_slime reports: vega fe folds at ~600k peak ~850k
https://hardforum.com/threads/amd-vega- ... 1043115511
but by chemist_slime graph on last weeks
http://folding.extremeoverclocking.com/ ... =&u=165190
there were hits to 1,110,392 points on 07.23.17 and to 1,019,003 on 07.29.17
was them produced by vega only or by any additional hardware - don`t know
Re: AMD RX Vega
Post by foldy »
AMD RX Vega 64 should match Vega FE Frontier Edition and get up to 850k PPD at 300 watts for $500
AMD RX Vega 56 has less shaders so get up to 700k PPD at 200 watts for $400
So this is an alternative to the Nvidia GPUs GTX 1070 and 1080.
B.A.T
Hardware configuration: 1: AMD FX 8150, 8 GB 1333MHZ, 256 GB Samsung evo 850, Radeon 280X
2: Intel i3 4170, 8GB ram, 120GB SSDNow V300, 2X KFA2 gtx 1080
3: AMD Phenom II x6 1100T, 8GB 1600MHZ, Radeon 280X
4: AMD FX 4300, 8GB 1600MHz, Crucial C300 128GB, 2X Radeon 290X
Re: AMD RX Vega
Post by B.A.T »
The norwegian tech site TEK.no tested FAHBench 2.2.5 on the AMD RX Vega 64. I haven't seen other tech sites test the Vega 64 with folding.
In «Single Precision» OpenCL it scored 110.9
https://www.tek.no/artikler/den-kanskje ... ake/350956
Senture
AMD RX Vega
Post by Senture »
Any chance of having RX Vega added to the white list please?
lspci output from the client:
0x8086:0x0ec3:Intel Corporation:Intel(R) Xeon(R) E7 v2/Xeon(R) E5 v2/Core i7 Power Control Unit 3 - 0EC3
0x8086:0x1d3e:Intel Corporation:Intel(R) C600/X79 series chipset PCI Express Virtual Switch Port - 1D3E
0x8086:0x0eaa:Intel Corporation:Intel(R) Xeon(R) E7 v2/Xeon(R) E5 v2/Core i7 Integrated Memory Controller 0 Channel Target Address Decoder Registers - 0EAA
0x1b21:0x1042:ASMedia Technology Inc.:ASMedia USB3.0 eXtensible Host Controller
0x8086:0x0ec2:Intel Corporation:Intel(R) Xeon(R) E7 v2/Xeon(R) E5 v2/Core i7 Power Control Unit 2 - 0EC2
0x8086:0x0e30:Intel Corporation:Intel(R) Xeon(R) E7 v2/Xeon(R) E5 v2/Core i7 Home Agent 0 - 0E30
0x8086:0x0ec1:Intel Corporation:Intel(R) Xeon(R) E7 v2/Xeon(R) E5 v2/Core i7 Power Control Unit 1 - 0EC1
0x8086:0x1d20:Intel Corporation:High Definition Audio Controller
0x8086:0x1d26:Intel Corporation:Intel(R) C600/X79 series chipset USB2 Enhanced Host Controller #1 - 1D26
0x8086:0x0ec0:Intel Corporation:Intel(R) Xeon(R) E7 v2/Xeon(R) E5 v2/Core i7 Power Control Unit 0 - 0EC0
0x8086:0x0ee5:Intel Corporation:Intel(R) Xeon(R) E7 v2/Xeon(R) E5 v2/Core i7 Unicast Registers - 0EE5
0x8086:0x0eb7:Intel Corporation:Intel(R) Xeon(R) E7 v2/Xeon(R) E5 v2/Core i7 Integrated Memory Controller 1 Channel 0 - 3 ERROR Registers 3 - 0EB7
0x8086:0x0e81:Intel Corporation:Intel(R) Xeon(R) E7 v2/Xeon(R) E5 v2/Core i7 QPI Ring Registers - 0E81
0x8086:0x1d3a:Intel Corporation:Intel(R) Management Engine Interface
0x8086:0x0e02:Intel Corporation:Intel(R) Xeon(R) E7 v2/Xeon(R) E5 v2/Core i7 PCI Express Root Port 1a - 0E02
0x8086:0x0ee4:Intel Corporation:Intel(R) Xeon(R) E7 v2/Xeon(R) E5 v2/Core i7 Unicast Registers - 0EE4
0x8086:0x0eb6:Intel Corporation:Intel(R) Xeon(R) E7 v2/Xeon(R) E5 v2/Core i7 Integrated Memory Controller 1 Channel 0 - 3 ERROR Registers 2 - 0EB6
0x8086:0x0e80:Intel Corporation:Intel(R) Xeon(R) E7 v2/Xeon(R) E5 v2/Core i7 QPI Link 0 - 0E80
0x1022:0x1471:Advanced Micro Devices, Inc. [AMD]:PCI-to-PCI Bridge
0x8086:0x0ee3:Intel Corporation:Intel(R) Xeon(R) E7 v2/Xeon(R) E5 v2/Core i7 Unicast Registers - 0EE3
0x8086:0x0eb5:Intel Corporation:Intel(R) Xeon(R) E7 v2/Xeon(R) E5 v2/Core i7 Integrated Memory Controller 1 Channel 0 - 3 Thermal Control 3 - 0EB5
0x8086:0x0eca:Intel Corporation:Intel(R) Xeon(R) E7 v2/Xeon(R) E5 v2/Core i7 Broadcast Registers - 0ECA
0x8086:0x0ee2:Intel Corporation:Intel(R) Xeon(R) E7 v2/Xeon(R) E5 v2/Core i7 Unicast Registers - 0EE2
0x8086:0x0eb4:Intel Corporation:Intel(R) Xeon(R) E7 v2/Xeon(R) E5 v2/Core i7 Integrated Memory Controller 1 Channel 0 - 3 Thermal Control 2 - 0EB4
0x8086:0x1d16:Intel Corporation:Intel(R) C600/X79 series chipset PCI Express Root Port 4 - 1D16
0x8086:0x0ee1:Intel Corporation:Intel(R) Xeon(R) E7 v2/Xeon(R) E5 v2/Core i7 Unicast Registers - 0EE1
0x8086:0x244e:Intel Corporation:PCI-to-PCI Bridge
0x8086:0x0eb3:Intel Corporation:Intel(R) Xeon(R) E7 v2/Xeon(R) E5 v2/Core i7 Integrated Memory Controller 1 Channel 0 - 3 ERROR Registers 1 - 0EB3
0x8086:0x0ee0:Intel Corporation:Intel(R) Xeon(R) E7 v2/Xeon(R) E5 v2/Core i7 Unicast Registers - 0EE0
0x8086:0x0eb2:Intel Corporation:Intel(R) Xeon(R) E7 v2/Xeon(R) E5 v2/Core i7 Integrated Memory Controller 1 Channel 0 - 3 ERROR Registers 0 - 0EB2
0x8086:0x0e04:Intel Corporation:Intel(R) Xeon(R) E7 v2/Xeon(R) E5 v2/Core i7 PCI Express Root Port 2a - 0E04
0x8086:0x0e2a:Intel Corporation:Intel(R) Xeon(R) E7 v2/Xeon(R) E5 v2/Core i7 IIO RAS - 0E2A
0x8086:0x0eb1:Intel Corporation:Intel(R) Xeon(R) E7 v2/Xeon(R) E5 v2/Core i7 Integrated Memory Controller 1 Channel 0 - 3 Thermal Control 1 - 0EB1
0x8086:0x0ea8:Intel Corporation:Intel(R) Xeon(R) E7 v2/Xeon(R) E5 v2/Core i7 Integrated Memory Controller 0 Target Address/Thermal Registers - 0EA8
0x1022:0x1470:Advanced Micro Devices, Inc. [AMD]:PCI-to-PCI Bridge
0x8086:0x0eb0:Intel Corporation:Intel(R) Xeon(R) E7 v2/Xeon(R) E5 v2/Core i7 Integrated Memory Controller 1 Channel 0 - 3 Thermal Control 0 - 0EB0
0x8086:0x0e71:Intel Corporation:Intel(R) Xeon(R) E7 v2/Xeon(R) E5 v2/Core i7 Integrated Memory Controller 0 RAS Registers - 0E71
[b]0x1002:0x687f:Advanced Micro Devices, Inc. [AMD/ATI]:Radeon(TM) RX Vega[/b]
0x8086:0x1d10:Intel Corporation:Intel(R) C600/X79 series chipset PCI Express Root Port 1 - 1D10
0x8086:0x1d18:Intel Corporation:Intel(R) C600/X79 series chipset PCI Express Root Port 5 - 1D18
0x8086:0x1d22:Intel Corporation:SM Bus Controller
0x8086:0x0e1f:Intel Corporation:Intel(R) Xeon(R) E7 v2/Xeon(R) E5 v2/Core i7 UBOX Registers - 0E1F
0x8086:0x0ec9:Intel Corporation:Intel(R) Xeon(R) E7 v2/Xeon(R) E5 v2/Core i7 Broadcast Registers - 0EC9
0x1b21:0x0612:ASMedia Technology Inc.:Standard SATA AHCI Controller
0x8086:0x0e2c:Intel Corporation:Intel(R) Xeon(R) E7 v2/Xeon(R) E5 v2/Core i7 IOAPIC - 0E2C
0x8086:0x0e1e:Intel Corporation:Intel(R) Xeon(R) E7 v2/Xeon(R) E5 v2/Core i7 UBOX Registers - 0E1E
0x1102:0x0012:Creative Labs:Sound Blaster Audio Controller
0x8086:0x0ec8:Intel Corporation:Intel(R) Xeon(R) E7 v2/Xeon(R) E5 v2/Core i7 System Address Decoder - 0EC8
0x8086:0x0e36:Intel Corporation:Intel(R) Xeon(R) E7 v2/Xeon(R) E5 v2/Core i7 QPI Ring Performance Ring Monitoring - 0E36
0x8086:0x2822:Intel Corporation:Intel Chipset SATA RAID Controller
0x8086:0x0e1d:Intel Corporation:Intel(R) Xeon(R) E7 v2/Xeon(R) E5 v2/Core i7 R2PCIe - 0E1D
0x8086:0x0e28:Intel Corporation:Intel(R) Xeon(R) E7 v2/Xeon(R) E5 v2/Core i7 VTd/Memory Map/Misc - 0E28
0x8086:0x1d1e:Intel Corporation:Intel(R) C600/X79 series chipset PCI Express Root Port 8 - 1D1E
0x8086:0x1d41:Intel Corporation:LPC Controller
0x8086:0x1d12:Intel Corporation:Intel(R) C600/X79 series chipset PCI Express Root Port 2 - 1D12
0x8086:0x0e90:Intel Corporation:Intel(R) Xeon(R) E7 v2/Xeon(R) E5 v2/Core i7 QPI Link 1 - 0E90
0x8086:0x0ead:Intel Corporation:Intel(R) Xeon(R) E7 v2/Xeon(R) E5 v2/Core i7 Integrated Memory Controller 0 Channel Target Address Decoder Registers - 0EAD
0x1002:0xaaf8:Advanced Micro Devices, Inc. [AMD/ATI]:High Definition Audio Bus
0x8086:0x0e34:Intel Corporation:Intel(R) Xeon(R) E7 v2/Xeon(R) E5 v2/Core i7 R2PCIe - 0E34
0x8086:0x1503:Intel Corporation:Intel(R) 82579V Gigabit Network Connection
0x8086:0x0ea0:Intel Corporation:Intel(R) Xeon(R) E7 v2/Xeon(R) E5 v2/Core i7 Home Agent 0 - 0EA0
0x8086:0x0eac:Intel Corporation:Intel(R) Xeon(R) E7 v2/Xeon(R) E5 v2/Core i7 Integrated Memory Controller 0 Channel Target Address Decoder Registers - 0EAC
0x8086:0x0e00:Intel Corporation:Intel(R) Xeon(R) E7 v2/Xeon(R) E5 v2/Core i7 DMI2 - 0E00
0x8086:0x0eab:Intel Corporation:Intel(R) Xeon(R) E7 v2/Xeon(R) E5 v2/Core i7 Integrated Memory Controller 0 Channel Target Address Decoder Registers - 0EAB
0x8086:0x1d2d:Intel Corporation:Intel(R) C600/X79 series chipset USB2 Enhanced Host Controller #2 - 1D2D
0x8086:0x0e08:Intel Corporation:Intel(R) Xeon(R) E7 v2/Xeon(R) E5 v2/Core i7 PCI Express Root Port 3a - 0E08
Re: AMD RX Vega
Post by foldy »
monkeyclaw
Hardware configuration: R9 280x and a 4770K
Re: AMD RX Vega
Post by monkeyclaw »
Anyone out there with a Vega 64 / Vega 64 liquid cooled and test it with a lot of different WUs yet? I'm looking to replace my Fury X (mainly to have something I can sit on with more than 4GB of memory for a few years) and right now, Vega is looking to just barely meet expectations. Folding@Home performance will probably be the kicker, and I want to see if AMD can take back the folding crown with this compute-heavy architecture they have come up with.
Let us know!
Re: AMD RX Vega
No one is folding on one yet, the cards' ID has not even been added to the GPUs.txt file yet - viewtopic.php?f=83&t=30221#p297047. Monday was the release date for the two cards.
monkeyclaw
Re: AMD RX Vega
Ah, I forgot about the GPU whitelist file. And yeah... it is a bit early to be hoping for PPD numbers already with the cards releasing barely 48 hrs ago, on top of stock issues that always come with anticipated releases.
Thanks for the info about the GPUs.txt though, I'll be waiting with high hopes for those numbers to start to roll in!
Re: AMD RX Vega
Post by foldy »
I heard AMD Vega supports half precision FP16 with double speed than normal FP32. Maybe next FahCore could support that or is it no benefit for folding?
Re: AMD RX Vega
I doubt that half-precision will be accurate enough, but somebody at PG will need to say one way or another.
In fact, the current FAHCore_21 runs in mixed precision, using primarily single precision but using a limited number of double precision operations when needed.
Then, too, it would take a re-do of FAHCore_2x.
QuintLeo
Re: AMD RX Vega
Post by QuintLeo »
Half precision AFAIK is not used by FAH at all as it's NOT accurate enough.
Based on the FoldingBench tests, the Vega 64 looks like it's going to fall in the 650k balllpark range on average, between the 600k of the GTX 1070 and the 700k of the GTX 1080 (again, those are BALLPARK figures, specific model of card will change that quite a bit due to "OEM factory overclocking" and higher TDP on many OEM cards).
Given the MUCH higher power usage of the VEGA cards, I'd say "don't bother getting them to fold on, but use them if you have other reasons to get one" - kinda like the GTX 980ti by current standards.
BTW - did anyone else notice that "chart" claiming that the GTX 950 is capable of almost 700k PPD?
Makes me TOTALLY disinclined to trust that chart when they can mess up that data point SO BADLY (the GTX 950 struggles to hit 150k in actual usage).
Re: AMD RX Vega
Post by foldy »
Hope it is not my chart... I check it. No it says 115k PPD for gtx 950 but that may not be perfect accurate either.
https://docs.google.com/spreadsheets/d/ ... edit#gid=0
