One-Click Uninstall & Install-Routine for FAHclient
foldinghomealone2
Post by foldinghomealone2 »
Hi there,
As I have the problem that I need to reinstall the client after each reboot, - viewtopic.php?f=61&t=30181#p296796 - I wanted to ask if there is a possibility to uninstall and install the client w/o any manual operation?
I would like to uninstall and reinstall the client with autostart but I have to manually operate the uninstall and installation programs.
Is there the possibility for command line uninstallation/installation where I can set command line options?
Or can s.o. think about another way of automated reinstallation like with macros or sth. similar?
Thanks
