uploading project 9179 failed then dumped [9178 actually]
Glennmas
Post by Glennmas »
08:23:01:WU02:FS01:FahCore returned: FINISHED_UNIT (100 = 0x64)
08:23:01:WU02:FS01:Sending unit results: id:02 state:SEND error:NO_ERROR project:9178 run:10 clone:11 gen:362 core:0x21 unit:0x00000216ab436c6957b24c2ad58c3cc3
08:23:01:WU02:FS01:Uploading 14.09MiB to 171.67.108.105
08:23:01:WU01:FS01:Starting
08:23:01:WU02:FS01:Connecting to 171.67.108.105:8080
08:23:01:WU01:FS01:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:/Users/Gebruiker/AppData/Roaming/FAHClient/cores/fahwebx.stanford.edu/cores/Win32/AMD64/NVIDIA/Fermi/Core_21.fah/FahCore_21.exe -dir 01 -suffix 01 -version 704 -lifeline 1632 -checkpoint 15 -gpu 0 -gpu-vendor nvidia
08:23:01:WU01:FS01:Started FahCore on PID 2864
08:23:01:WU01:FS01:Core PID:8880
08:23:01:WU01:FS01:FahCore 0x21 started
08:23:02:WU01:FS01:0x21:*********************** Log Started 2017-07-24T08:23:01Z ***********************
08:23:02:WU01:FS01:0x21:Project: 9179 (Run 14, Clone 0, Gen 392)
08:23:02:WU01:FS01:0x21:Unit: 0x0000023dab436c9f57bdce046e3d4c1f
08:23:02:WU01:FS01:0x21:CPU: 0x00000000000000000000000000000000
08:23:02:WU01:FS01:0x21:Machine: 1
08:23:02:WU01:FS01:0x21:Reading tar file core.xml
08:23:02:WU01:FS01:0x21:Reading tar file integrator.xml
08:23:02:WU01:FS01:0x21:Reading tar file state.xml
08:23:02:WU01:FS01:0x21:Reading tar file system.xml
08:23:02:WU01:FS01:0x21:Digital signatures verified
08:23:02:WU01:FS01:0x21:Folding@home GPU Core21 Folding@home Core
08:23:02:WU01:FS01:0x21:Version 0.0.18
08:23:10:WU01:FS01:0x21:Completed 0 out of 2500000 steps (0%)
08:23:10:WU01:FS01:0x21:Temperature control disabled. Requirements: single Nvidia GPU, tmax must be < 110 and twait >= 900
08:23:35:WU02:FS01:Upload 0.89%
08:23:35:WARNING:WU02:FS01:Exception: Failed to send results to work server: Transfer failed
08:23:35:WU02:FS01:Trying to send results to collection server
08:23:35:WU02:FS01:Uploading 14.09MiB to 171.67.108.46
08:23:35:WU02:FS01:Connecting to 171.67.108.46:8080
08:23:41:WU02:FS01:Upload 33.71%
08:23:47:WU02:FS01:Upload complete
08:23:47:WU02:FS01:Server responded WORK_QUIT (404)
08:23:47:WARNING:WU02:FS01:Server did not like results, dumping
08:23:47:WU02:FS01:Cleaning up
First uploaded to the first server failed 2nd server didnt like the wu is there a fix for this?
Mod edit: added Code tags
Glennmas
Re: uploading project 9179 failed then dumped
Post by Glennmas »
Got the exact same wu uploaded without a problem this time
The upload that failed was for a WU from Project 9178, not 9179, so it was not the exact same WU. Project: 9178 (Run 10, Clone 11, Gen 362) was first attempted to be uploaded at 08:23:01, and was dumped as bad at 08:23:47. There is one failure report in the database from another person.
Project: 9179 (Run 14, Clone 0, Gen 392) started after the 9178 WU was completed processing and was turned in successfully by you.
Glennmas
Re: uploading project 9179 failed then dumped [9178 actually
Post by Glennmas »
Oh oke thanks for the info. lets hope it doesnt happen again
Server 171.67.108.105 is reportedly down so my guess is that msultan is working on it.
Projects 9178 and 9179 happen to be on different servers.
