gpu keeps crashing during crunching?
djspacewhale
Post by djspacewhale »
Fedora Rawhide 64-bit; latest FAH tools from the Stanford website. whenever I try to fold using my RX 480, it works slowly for a bit, then crashes out. I've set gpu=true to get it to detect, than idle=true to make sure it doesn't take up other gpu time, but whenever it starts it goes really incredibly slowly for just a bit then gives a failed message. the card should be fine, as it works fine under 1080p ultra settings on Middle Earth: Shadow of Mordor, but doesn't cooperate here. thoughts? any error consoles I could report?
Re: gpu keeps crashing during crunching?
Yes, post the console output by following the link in the signature block of this post.
Which drivers have you installed and from what source?
djspacewhale
*********************** Log Started 2017-07-07T20:27:22Z ***********************
20:27:22:************************* Folding@home Client *************************
20:27:22:    Website: http://folding.stanford.edu/
20:27:22:  Copyright: (c) 2009-2014 Stanford University
20:27:22:     Author: Joseph Coffland <joseph@cauldrondevelopment.com>
20:27:22:       Args: --child --lifeline 1739 /etc/fahclient/config.xml --run-as
20:27:22:             fahclient --pid-file=/var/run/fahclient.pid --daemon
20:27:22:     Config: /etc/fahclient/config.xml
20:27:22:******************************** Build ********************************
20:27:22:    Version: 7.4.4
20:27:22:       Date: Mar 4 2014
20:27:22:       Time: 12:01:17
20:27:22:    SVN Rev: 4130
20:27:22:     Branch: fah/trunk/client
20:27:22:   Compiler: GNU 4.1.2 20080704 (Red Hat 4.1.2-46)
20:27:22:    Options: -std=gnu++98 -O3 -funroll-loops -mfpmath=sse -ffast-math
20:27:22:             -fno-unsafe-math-optimizations -msse2
20:27:22:   Platform: linux2 2.6.18-164.11.1.el5
20:27:22:       Bits: 64
20:27:22:       Mode: Release
20:27:22:******************************* System ********************************
20:27:22:        CPU: Intel(R) Core(TM) i5-6600K CPU @ 3.50GHz
20:27:22:     CPU ID: GenuineIntel Family 6 Model 94 Stepping 3
20:27:22:       CPUs: 4
20:27:22:     Memory: 15.52GiB
20:27:22:Free Memory: 14.64GiB
20:27:22:    Threads: POSIX_THREADS
20:27:22: OS Version: 4.12
20:27:22:Has Battery: false
20:27:22: On Battery: false
20:27:22: UTC Offset: -6
20:27:22:        PID: 1741
20:27:22:        CWD: /var/lib/fahclient
20:27:22:         OS: Linux 4.12.0-0.rc7.git2.1.fc27.x86_64 x86_64
20:27:22:    OS Arch: AMD64
20:27:22:       GPUs: 1
20:27:22:      GPU 0: ATI:5 Ellesmere XT [Radeon RX 470/480/570/580]
20:27:22:       CUDA: Not detected
20:27:22:***********************************************************************
20:27:22:<config>
20:27:22:  <!-- Folding Slot Configuration -->
20:27:22:  <extra-core-args v='idle=true'/>
20:27:22:
20:27:22:  <!-- Network -->
20:27:22:  <proxy v=':8080'/>
20:27:22:
20:27:22:  <!-- Slot Control -->
20:27:22:  <power v='MEDIUM'/>
20:27:22:
20:27:22:  <!-- User Information -->
20:27:22:  <passkey v='********************************'/>
20:27:22:  <team v='224497'/>
20:27:22:  <user v='djspacewhale'/>
20:27:22:
20:27:22:  <!-- Folding Slots -->
20:27:22:  <slot id='1' type='CPU'/>
20:27:22:  <slot id='0' type='GPU'/>
20:27:22:</config>
20:27:22:Switching to user fahclient
20:27:22:Trying to access database...
20:27:22:Successfully acquired database lock
20:27:22:Enabled folding slot 01: READY cpu:2
20:27:22:Enabled folding slot 00: READY gpu:0:Ellesmere XT [Radeon RX 470/480/570/580]
20:27:22:WU01:FS01:Starting
20:27:22:WU01:FS01:Running FahCore: /usr/bin/FAHCoreWrapper /var/lib/fahclient/cores/fahwebx.stanford.edu/cores/Linux/AMD64/AVX/Core_a7.fah/FahCore_a7 -dir 01 -suffix 01 -version 704 -lifeline 1741 -checkpoint 15 -np 2 idle=true
20:27:22:WU01:FS01:Started FahCore on PID 1764
20:27:22:WU01:FS01:Core PID:1769
20:27:22:WU01:FS01:FahCore 0xa7 started
20:27:23:WU01:FS01:0xa7:*********************** Log Started 2017-07-07T20:27:22Z ***********************
20:27:23:WU01:FS01:0xa7:************************** Gromacs Folding@home Core ***************************
20:27:23:WU01:FS01:0xa7:       Type: 0xa7
20:27:23:WU01:FS01:0xa7:       Core: Gromacs
20:27:23:WU01:FS01:0xa7:    Website: http://folding.stanford.edu/
20:27:23:WU01:FS01:0xa7:  Copyright: (c) 2009-2016 Stanford University
20:27:23:WU01:FS01:0xa7:     Author: Joseph Coffland <joseph@cauldrondevelopment.com>
20:27:23:WU01:FS01:0xa7:       Args: -dir 01 -suffix 01 -version 704 -lifeline 1764 -checkpoint 15 -np 2
20:27:23:WU01:FS01:0xa7:             idle=true
20:27:23:WU01:FS01:0xa7:     Config: <none>
20:27:23:WU01:FS01:0xa7:************************************ Build *************************************
20:27:23:WU01:FS01:0xa7:    Version: 0.0.11
20:27:23:WU01:FS01:0xa7:       Date: Sep 20 2016
20:27:23:WU01:FS01:0xa7:       Time: 06:40:11
20:27:23:WU01:FS01:0xa7: Repository: Git
20:27:23:WU01:FS01:0xa7:   Revision: 957bd90e68d95ddcf1594dc15ff6c64cc4555146
20:27:23:WU01:FS01:0xa7:     Branch: master
20:27:23:WU01:FS01:0xa7:   Compiler: GNU 4.8.5
20:27:23:WU01:FS01:0xa7:    Options: -std=gnu++98 -O3 -funroll-loops -ffast-math -mfpmath=sse
20:27:23:WU01:FS01:0xa7:             -fno-unsafe-math-optimizations -msse2
20:27:23:WU01:FS01:0xa7:   Platform: linux2 4.6.0-1-amd64
20:27:23:WU01:FS01:0xa7:       Bits: 64
20:27:23:WU01:FS01:0xa7:       Mode: Release
20:27:23:WU01:FS01:0xa7:       SIMD: avx_256
20:27:23:WU01:FS01:0xa7:************************************ System ************************************
20:27:23:WU01:FS01:0xa7:        CPU: Intel(R) Core(TM) i5-6600K CPU @ 3.50GHz
20:27:23:WU01:FS01:0xa7:     CPU ID: GenuineIntel Family 6 Model 94 Stepping 3
20:27:23:WU01:FS01:0xa7:       CPUs: 4
20:27:23:WU01:FS01:0xa7:     Memory: 15.52GiB
20:27:23:WU01:FS01:0xa7:Free Memory: 14.62GiB
20:27:23:WU01:FS01:0xa7:    Threads: POSIX_THREADS
20:27:23:WU01:FS01:0xa7: OS Version: 4.12
20:27:23:WU01:FS01:0xa7:Has Battery: false
20:27:23:WU01:FS01:0xa7: On Battery: false
20:27:23:WU01:FS01:0xa7: UTC Offset: -6
20:27:23:WU01:FS01:0xa7:        PID: 1769
20:27:23:WU01:FS01:0xa7:        CWD: /var/lib/fahclient/work
20:27:23:WU01:FS01:0xa7:         OS: Linux 4.12.0-0.rc7.git2.1.fc27.x86_64 x86_64
20:27:23:WU01:FS01:0xa7:    OS Arch: AMD64
20:27:23:WU01:FS01:0xa7:********************************************************************************
20:27:23:WU01:FS01:0xa7:Project: 13720 (Run 76, Clone 3, Gen 10)
20:27:23:WU01:FS01:0xa7:Unit: 0x0000000b0002894b58fd953ca11b15b0
20:27:23:WU01:FS01:0xa7:Digital signatures verified
20:27:23:WU01:FS01:0xa7:Calling: mdrun -s frame10.tpr -o frame10.trr -cpi state.cpt -cpt 15 -nt 2
20:27:24:WU01:FS01:0xa7:Steps: first=25000000 total=2500000
20:27:24:WU00:FS00:Connecting to 171.67.108.45:80
20:27:24:WU01:FS01:0xa7:Completed 1014391 out of 2500000 steps (40%)
20:27:25:WU00:FS00:Assigned to work server 171.67.108.157
20:27:25:WU00:FS00:Requesting new work unit for slot 00: READY gpu:0:Ellesmere XT [Radeon RX 470/480/570/580] from 171.67.108.157
20:27:25:WU00:FS00:Connecting to 171.67.108.157:8080
20:27:26:WU00:FS00:Downloading 8.85MiB
20:27:27:WU00:FS00:Download complete
20:27:27:WU00:FS00:Received Unit: id:00 state:DOWNLOAD error:NO_ERROR project:9431 run:687 clone:0 gen:289 core:0x21 unit:0x00000150ab436c9d586fdd39e0ea2fcb
20:27:27:WU00:FS00:Starting
20:27:27:WU00:FS00:Running FahCore: /usr/bin/FAHCoreWrapper /var/lib/fahclient/cores/fahwebx.stanford.edu/cores/Linux/AMD64/ATI/R600/Core_21.fah/FahCore_21 -dir 00 -suffix 01 -version 704 -lifeline 1741 -checkpoint 15 -gpu 0 -gpu-vendor ati idle=true
20:27:27:WU00:FS00:Started FahCore on PID 2199
20:27:27:WU00:FS00:Core PID:2203
20:27:27:WU00:FS00:FahCore 0x21 started
20:27:28:WARNING:WU00:FS00:FahCore returned: BAD_WORK_UNIT (114 = 0x72)
20:27:28:WU00:FS00:Sending unit results: id:00 state:SEND error:FAULTY project:9431 run:687 clone:0 gen:289 core:0x21 unit:0x00000150ab436c9d586fdd39e0ea2fcb
20:27:28:WU00:FS00:Uploading 6.50KiB to 171.67.108.157
20:27:28:WU00:FS00:Connecting to 171.67.108.157:8080
20:27:28:WU00:FS00:Upload complete
20:27:28:WU02:FS00:Connecting to 171.67.108.45:80
20:27:28:WU00:FS00:Server responded WORK_ACK (400)
20:27:28:WU00:FS00:Cleaning up
20:27:29:WU02:FS00:Assigned to work server 171.67.108.160
20:27:29:WU02:FS00:Requesting new work unit for slot 00: READY gpu:0:Ellesmere XT [Radeon RX 470/480/570/580] from 171.67.108.160
20:27:29:WU02:FS00:Connecting to 171.67.108.160:8080
20:27:31:WU02:FS00:Downloading 2.02MiB
20:27:32:WU02:FS00:Download complete
20:27:32:WU02:FS00:Received Unit: id:02 state:DOWNLOAD error:NO_ERROR project:9839 run:0 clone:55 gen:190 core:0x21 unit:0x000000e1ab436ca05890cac620ddd11b
20:27:32:WU02:FS00:Starting
20:27:32:WU02:FS00:Running FahCore: /usr/bin/FAHCoreWrapper /var/lib/fahclient/cores/fahwebx.stanford.edu/cores/Linux/AMD64/ATI/R600/Core_21.fah/FahCore_21 -dir 02 -suffix 01 -version 704 -lifeline 1741 -checkpoint 15 -gpu 0 -gpu-vendor ati idle=true
20:27:32:WU02:FS00:Started FahCore on PID 2426
20:27:32:WU02:FS00:Core PID:2431
20:27:32:WU02:FS00:FahCore 0x21 started
20:27:32:WU02:FS00:0x21:*********************** Log Started 2017-07-07T20:27:32Z ***********************
20:27:32:WU02:FS00:0x21:Project: 9839 (Run 0, Clone 55, Gen 190)
20:27:32:WU02:FS00:0x21:Unit: 0x000000e1ab436ca05890cac620ddd11b
20:27:32:WU02:FS00:0x21:CPU: 0x00000000000000000000000000000000
20:27:32:WU02:FS00:0x21:Machine: 0
20:27:32:WU02:FS00:0x21:Reading tar file core.xml
20:27:32:WU02:FS00:0x21:Reading tar file integrator.xml
20:27:32:WU02:FS00:0x21:Reading tar file state.xml
20:27:33:WU02:FS00:0x21:Reading tar file system.xml
20:27:33:WU02:FS00:0x21:Digital signatures verified
20:27:33:WU02:FS00:0x21:Folding@home GPU Core21 Folding@home Core
20:27:33:WU02:FS00:0x21:Version 0.0.18
20:27:33:WU02:FS00:0x21:ERROR:126: Bad platformId size.
20:27:33:WU02:FS00:0x21:Saving result file logfile_01.txt
20:27:33:WU02:FS00:0x21:Saving result file log.txt
20:27:33:WU02:FS00:0x21:Folding@home Core Shutdown: BAD_WORK_UNIT
20:27:33:WARNING:WU02:FS00:FahCore returned: BAD_WORK_UNIT (114 = 0x72)
20:27:33:WU02:FS00:Sending unit results: id:02 state:SEND error:FAULTY project:9839 run:0 clone:55 gen:190 core:0x21 unit:0x000000e1ab436ca05890cac620ddd11b
20:27:33:WU02:FS00:Uploading 2.32KiB to 171.67.108.160
20:27:33:WU02:FS00:Connecting to 171.67.108.160:8080
20:27:33:WU02:FS00:Upload complete
20:27:33:WU00:FS00:Connecting to 171.67.108.45:80
20:27:33:WU02:FS00:Server responded WORK_ACK (400)
20:27:33:WU02:FS00:Cleaning up
20:27:34:WU00:FS00:Assigned to work server 171.67.108.157
20:27:34:WU00:FS00:Requesting new work unit for slot 00: READY gpu:0:Ellesmere XT [Radeon RX 470/480/570/580] from 171.67.108.157
20:27:34:WU00:FS00:Connecting to 171.67.108.157:8080
20:27:35:WU00:FS00:Downloading 5.15MiB
20:27:35:WU00:FS00:Download complete
20:27:35:WU00:FS00:Received Unit: id:00 state:DOWNLOAD error:NO_ERROR project:9415 run:441 clone:0 gen:454 core:0x21 unit:0x00000209ab436c9d585e06ccc553e294
20:27:35:WU00:FS00:Starting
20:27:35:WU00:FS00:Running FahCore: /usr/bin/FAHCoreWrapper /var/lib/fahclient/cores/fahwebx.stanford.edu/cores/Linux/AMD64/ATI/R600/Core_21.fah/FahCore_21 -dir 00 -suffix 01 -version 704 -lifeline 1741 -checkpoint 15 -gpu 0 -gpu-vendor ati idle=true
20:27:35:WU00:FS00:Started FahCore on PID 2465
20:27:35:WU00:FS00:Core PID:2469
20:27:35:WU00:FS00:FahCore 0x21 started
20:27:36:WARNING:WU00:FS00:FahCore returned: BAD_WORK_UNIT (114 = 0x72)
20:27:36:WU00:FS00:Sending unit results: id:00 state:SEND error:FAULTY project:9415 run:441 clone:0 gen:454 core:0x21 unit:0x00000209ab436c9d585e06ccc553e294
20:27:36:WU00:FS00:Uploading 6.50KiB to 171.67.108.157
20:27:36:WU00:FS00:Connecting to 171.67.108.157:8080
20:27:36:WU00:FS00:Upload complete
20:27:36:WU02:FS00:Connecting to 171.67.108.45:80
20:27:36:WU00:FS00:Server responded WORK_ACK (400)
20:27:36:WU00:FS00:Cleaning up
20:27:37:WU02:FS00:Assigned to work server 140.163.4.245
20:27:37:WU02:FS00:Requesting new work unit for slot 00: READY gpu:0:Ellesmere XT [Radeon RX 470/480/570/580] from 140.163.4.245
20:27:37:WU02:FS00:Connecting to 140.163.4.245:8080
20:27:37:WU02:FS00:Downloading 14.48MiB
20:27:39:WU02:FS00:Download complete
20:27:39:WU02:FS00:Received Unit: id:02 state:DOWNLOAD error:NO_ERROR project:10496 run:113 clone:43 gen:30 core:0x21 unit:0x000000288ca304f55889750fc5151210
20:27:39:WU02:FS00:Starting
20:27:39:WU02:FS00:Running FahCore: /usr/bin/FAHCoreWrapper /var/lib/fahclient/cores/fahwebx.stanford.edu/cores/Linux/AMD64/ATI/R600/Core_21.fah/FahCore_21 -dir 02 -suffix 01 -version 704 -lifeline 1741 -checkpoint 15 -gpu 0 -gpu-vendor ati idle=true
20:27:39:WU02:FS00:Started FahCore on PID 2490
20:27:39:WU02:FS00:Core PID:2494
20:27:39:WU02:FS00:FahCore 0x21 started
20:27:40:WU02:FS00:0x21:*********************** Log Started 2017-07-07T20:27:39Z ***********************
20:27:40:WU02:FS00:0x21:Project: 10496 (Run 113, Clone 43, Gen 30)
20:27:40:WU02:FS00:0x21:Unit: 0x000000288ca304f55889750fc5151210
20:27:40:WU02:FS00:0x21:CPU: 0x00000000000000000000000000000000
20:27:40:WU02:FS00:0x21:Machine: 0
20:27:40:WU02:FS00:0x21:Reading tar file core.xml
20:27:40:WU02:FS00:0x21:Reading tar file system.xml
20:27:40:WU02:FS00:0x21:Reading tar file integrator.xml
20:27:40:WU02:FS00:0x21:Reading tar file state.xml
20:27:42:WU02:FS00:0x21:Digital signatures verified
20:27:42:WU02:FS00:0x21:Folding@home GPU Core21 Folding@home Core
20:27:42:WU02:FS00:0x21:Version 0.0.18
20:27:42:WU02:FS00:0x21:ERROR:126: Bad platformId size.
20:27:42:WU02:FS00:0x21:Saving result file logfile_01.txt
20:27:42:WU02:FS00:0x21:Saving result file log.txt
20:27:42:WU02:FS00:0x21:Folding@home Core Shutdown: BAD_WORK_UNIT
20:27:42:WARNING:WU02:FS00:FahCore returned: BAD_WORK_UNIT (114 = 0x72)
20:27:42:WU02:FS00:Sending unit results: id:02 state:SEND error:FAULTY project:10496 run:113 clone:43 gen:30 core:0x21 unit:0x000000288ca304f55889750fc5151210
20:27:42:WU02:FS00:Uploading 2.31KiB to 140.163.4.245
20:27:42:WU02:FS00:Connecting to 140.163.4.245:8080
20:27:43:WU02:FS00:Upload complete
20:27:43:WU02:FS00:Server responded WORK_ACK (400)
20:27:43:WU00:FS00:Connecting to 171.67.108.45:80
20:27:43:WU02:FS00:Cleaning up
20:27:44:WU00:FS00:Assigned to work server 171.67.108.157
20:27:44:WU00:FS00:Requesting new work unit for slot 00: READY gpu:0:Ellesmere XT [Radeon RX 470/480/570/580] from 171.67.108.157
20:27:44:WU00:FS00:Connecting to 171.67.108.157:8080
20:27:45:WU00:FS00:Downloading 8.88MiB
20:27:45:WU00:FS00:Download complete
20:27:46:WU00:FS00:Received Unit: id:00 state:DOWNLOAD error:NO_ERROR project:9431 run:664 clone:0 gen:324 core:0x21 unit:0x00000183ab436c9d586fdd39460637d9
20:27:46:WU00:FS00:Starting
20:27:46:WU00:FS00:Running FahCore: /usr/bin/FAHCoreWrapper /var/lib/fahclient/cores/fahwebx.stanford.edu/cores/Linux/AMD64/ATI/R600/Core_21.fah/FahCore_21 -dir 00 -suffix 01 -version 704 -lifeline 1741 -checkpoint 15 -gpu 0 -gpu-vendor ati idle=true
20:27:46:WU00:FS00:Started FahCore on PID 2548
20:27:46:WU00:FS00:Core PID:2554
20:27:46:WU00:FS00:FahCore 0x21 started
20:27:47:WARNING:WU00:FS00:FahCore returned: BAD_WORK_UNIT (114 = 0x72)
20:27:47:WU00:FS00:Sending unit results: id:00 state:SEND error:FAULTY project:9431 run:664 clone:0 gen:324 core:0x21 unit:0x00000183ab436c9d586fdd39460637d9
20:27:47:WU00:FS00:Uploading 6.50KiB to 171.67.108.157
20:27:47:WU00:FS00:Connecting to 171.67.108.157:8080
20:27:47:WU00:FS00:Upload complete
20:27:47:WU02:FS00:Connecting to 171.67.108.45:80
20:27:48:WU00:FS00:Server responded WORK_ACK (400)
20:27:48:WU00:FS00:Cleaning up
20:27:48:WU02:FS00:Assigned to work server 171.67.108.160
20:27:48:WU02:FS00:Requesting new work unit for slot 00: READY gpu:0:Ellesmere XT [Radeon RX 470/480/570/580] from 171.67.108.160
20:27:48:WU02:FS00:Connecting to 171.67.108.160:8080
20:27:51:WU02:FS00:Downloading 2.02MiB
20:27:51:WU02:FS00:Download complete
20:27:51:WU02:FS00:Received Unit: id:02 state:DOWNLOAD error:NO_ERROR project:9839 run:0 clone:74 gen:177 core:0x21 unit:0x000000deab436ca05890cac631653e80
20:27:52:WU02:FS00:Starting
20:27:52:WU02:FS00:Running FahCore: /usr/bin/FAHCoreWrapper /var/lib/fahclient/cores/fahwebx.stanford.edu/cores/Linux/AMD64/ATI/R600/Core_21.fah/FahCore_21 -dir 02 -suffix 01 -version 704 -lifeline 1741 -checkpoint 15 -gpu 0 -gpu-vendor ati idle=true
20:27:52:WU02:FS00:Started FahCore on PID 2741
20:27:52:WU02:FS00:Core PID:2745
20:27:52:WU02:FS00:FahCore 0x21 started
20:27:52:WU02:FS00:0x21:*********************** Log Started 2017-07-07T20:27:52Z ***********************
20:27:52:WU02:FS00:0x21:Project: 9839 (Run 0, Clone 74, Gen 177)
20:27:52:WU02:FS00:0x21:Unit: 0x000000deab436ca05890cac631653e80
20:27:52:WU02:FS00:0x21:CPU: 0x00000000000000000000000000000000
20:27:52:WU02:FS00:0x21:Machine: 0
20:27:52:WU02:FS00:0x21:Reading tar file core.xml
20:27:52:WU02:FS00:0x21:Reading tar file integrator.xml
20:27:52:WU02:FS00:0x21:Reading tar file state.xml
20:27:52:WU02:FS00:0x21:Reading tar file system.xml
20:27:52:WU02:FS00:0x21:Digital signatures verified
20:27:52:WU02:FS00:0x21:Folding@home GPU Core21 Folding@home Core
20:27:52:WU02:FS00:0x21:Version 0.0.18
20:27:52:WU02:FS00:0x21:ERROR:126: Bad platformId size.
20:27:52:WU02:FS00:0x21:Saving result file logfile_01.txt
20:27:52:WU02:FS00:0x21:Saving result file log.txt
20:27:52:WU02:FS00:0x21:Folding@home Core Shutdown: BAD_WORK_UNIT
20:27:53:WARNING:WU02:FS00:FahCore returned: BAD_WORK_UNIT (114 = 0x72)
20:27:53:WU02:FS00:Sending unit results: id:02 state:SEND error:FAULTY project:9839 run:0 clone:74 gen:177 core:0x21 unit:0x000000deab436ca05890cac631653e80
20:27:53:WU02:FS00:Uploading 2.31KiB to 171.67.108.160
20:27:53:WU02:FS00:Connecting to 171.67.108.160:8080
20:27:53:WU02:FS00:Upload complete
20:27:53:WU02:FS00:Server responded WORK_ACK (400)
20:27:53:WU00:FS00:Connecting to 171.67.108.45:80
20:27:53:WU02:FS00:Cleaning up
20:27:53:WU00:FS00:Assigned to work server 171.67.108.160
20:27:53:WU00:FS00:Requesting new work unit for slot 00: READY gpu:0:Ellesmere XT [Radeon RX 470/480/570/580] from 171.67.108.160
20:27:53:WU00:FS00:Connecting to 171.67.108.160:8080
20:27:56:WU00:FS00:Downloading 2.02MiB
20:27:56:WU00:FS00:Download complete
20:27:56:WU00:FS00:Received Unit: id:00 state:DOWNLOAD error:NO_ERROR project:9839 run:1 clone:84 gen:175 core:0x21 unit:0x000000d5ab436ca05890cac6912e38fe
20:27:57:WU00:FS00:Starting
20:27:57:WU00:FS00:Running FahCore: /usr/bin/FAHCoreWrapper /var/lib/fahclient/cores/fahwebx.stanford.edu/cores/Linux/AMD64/ATI/R600/Core_21.fah/FahCore_21 -dir 00 -suffix 01 -version 704 -lifeline 1741 -checkpoint 15 -gpu 0 -gpu-vendor ati idle=true
20:27:57:WU00:FS00:Started FahCore on PID 3112
20:27:57:WU00:FS00:Core PID:3116
20:27:57:WU00:FS00:FahCore 0x21 started
20:27:57:WU00:FS00:0x21:*********************** Log Started 2017-07-07T20:27:57Z ***********************
20:27:57:WU00:FS00:0x21:Project: 9839 (Run 1, Clone 84, Gen 175)
20:27:57:WU00:FS00:0x21:Unit: 0x000000d5ab436ca05890cac6912e38fe
20:27:57:WU00:FS00:0x21:CPU: 0x00000000000000000000000000000000
20:27:57:WU00:FS00:0x21:Machine: 0
20:27:57:WU00:FS00:0x21:Reading tar file core.xml
20:27:57:WU00:FS00:0x21:Reading tar file integrator.xml
20:27:57:WU00:FS00:0x21:Reading tar file state.xml
20:27:57:WU00:FS00:0x21:Reading tar file system.xml
20:27:57:WU00:FS00:0x21:Digital signatures verified
20:27:57:WU00:FS00:0x21:Folding@home GPU Core21 Folding@home Core
20:27:57:WU00:FS00:0x21:Version 0.0.18
20:27:57:WU00:FS00:0x21:ERROR:126: Bad platformId size.
20:27:57:WU00:FS00:0x21:Saving result file logfile_01.txt
20:27:57:WU00:FS00:0x21:Saving result file log.txt
20:27:57:WU00:FS00:0x21:Folding@home Core Shutdown: BAD_WORK_UNIT
20:27:57:WARNING:WU00:FS00:FahCore returned: BAD_WORK_UNIT (114 = 0x72)
20:27:58:WU00:FS00:Sending unit results: id:00 state:SEND error:FAULTY project:9839 run:1 clone:84 gen:175 core:0x21 unit:0x000000d5ab436ca05890cac6912e38fe
20:27:58:WU00:FS00:Uploading 2.32KiB to 171.67.108.160
20:27:58:WU00:FS00:Connecting to 171.67.108.160:8080
20:27:58:WU00:FS00:Upload complete
20:27:58:WU02:FS00:Connecting to 171.67.108.45:80
20:27:59:WU00:FS00:Server responded WORK_ACK (400)
20:27:59:WU00:FS00:Cleaning up
20:28:00:WU02:FS00:Assigned to work server 140.163.4.245
20:28:00:WU02:FS00:Requesting new work unit for slot 00: READY gpu:0:Ellesmere XT [Radeon RX 470/480/570/580] from 140.163.4.245
20:28:00:WU02:FS00:Connecting to 140.163.4.245:8080
20:28:01:WU02:FS00:Downloading 14.50MiB
20:28:03:WU02:FS00:Download complete
20:28:04:WU02:FS00:Received Unit: id:02 state:DOWNLOAD error:NO_ERROR project:10496 run:32 clone:27 gen:68 core:0x21 unit:0x000000568ca304f558895f23b75c8f02
20:28:05:WU02:FS00:Starting
20:28:05:WU02:FS00:Running FahCore: /usr/bin/FAHCoreWrapper /var/lib/fahclient/cores/fahwebx.stanford.edu/cores/Linux/AMD64/ATI/R600/Core_21.fah/FahCore_21 -dir 02 -suffix 01 -version 704 -lifeline 1741 -checkpoint 15 -gpu 0 -gpu-vendor ati idle=true
20:28:05:WU02:FS00:Started FahCore on PID 3437
20:28:05:WU02:FS00:Core PID:3441
20:28:05:WU02:FS00:FahCore 0x21 started
20:28:06:WU02:FS00:0x21:*********************** Log Started 2017-07-07T20:28:05Z ***********************
20:28:06:WU02:FS00:0x21:Project: 10496 (Run 32, Clone 27, Gen 68)
20:28:06:WU02:FS00:0x21:Unit: 0x000000568ca304f558895f23b75c8f02
20:28:06:WU02:FS00:0x21:CPU: 0x00000000000000000000000000000000
20:28:06:WU02:FS00:0x21:Machine: 0
20:28:06:WU02:FS00:0x21:Reading tar file core.xml
20:28:06:WU02:FS00:0x21:Reading tar file system.xml
20:28:06:WU02:FS00:0x21:Reading tar file integrator.xml
20:28:06:WU02:FS00:0x21:Reading tar file state.xml
20:28:07:WU02:FS00:0x21:Digital signatures verified
20:28:07:WU02:FS00:0x21:Folding@home GPU Core21 Folding@home Core
20:28:07:WU02:FS00:0x21:Version 0.0.18
20:28:07:WU02:FS00:0x21:ERROR:126: Bad platformId size.
20:28:07:WU02:FS00:0x21:Saving result file logfile_01.txt
20:28:07:WU02:FS00:0x21:Saving result file log.txt
20:28:07:WU02:FS00:0x21:Folding@home Core Shutdown: BAD_WORK_UNIT
20:28:24:WU01:FS01:0xa7:Completed 1025000 out of 2500000 steps (41%)
20:28:24:WARNING:WU02:FS00:FahCore returned: BAD_WORK_UNIT (114 = 0x72)
20:28:26:WU02:FS00:Sending unit results: id:02 state:SEND error:FAULTY project:10496 run:32 clone:27 gen:68 core:0x21 unit:0x000000568ca304f558895f23b75c8f02
20:28:27:WU02:FS00:Uploading 2.33KiB to 140.163.4.245
20:28:27:WU02:FS00:Connecting to 140.163.4.245:8080
20:28:27:WU00:FS00:Connecting to 171.67.108.45:80
20:28:27:WU02:FS00:Upload complete
20:28:28:WU02:FS00:Server responded WORK_ACK (400)
20:28:28:WU02:FS00:Cleaning up
20:28:29:WU00:FS00:Assigned to work server 171.67.108.157
20:28:29:WU00:FS00:Requesting new work unit for slot 00: READY gpu:0:Ellesmere XT [Radeon RX 470/480/570/580] from 171.67.108.157
20:28:29:WU00:FS00:Connecting to 171.67.108.157:8080
20:28:31:WU00:FS00:Downloading 5.18MiB
20:28:31:WU00:FS00:Download complete
20:28:32:WU00:FS00:Received Unit: id:00 state:DOWNLOAD error:NO_ERROR project:9414 run:28 clone:0 gen:545 core:0x21 unit:0x00000267ab436c9d585e069069243b6a
20:28:32:WU00:FS00:Starting
20:28:32:WU00:FS00:Running FahCore: /usr/bin/FAHCoreWrapper /var/lib/fahclient/cores/fahwebx.stanford.edu/cores/Linux/AMD64/ATI/R600/Core_21.fah/FahCore_21 -dir 00 -suffix 01 -version 704 -lifeline 1741 -checkpoint 15 -gpu 0 -gpu-vendor ati idle=true
20:28:32:WU00:FS00:Started FahCore on PID 3718
20:28:32:WU00:FS00:Core PID:3722
20:28:32:WU00:FS00:FahCore 0x21 started
20:28:32:WARNING:WU00:FS00:FahCore returned: BAD_WORK_UNIT (114 = 0x72)
20:28:33:WU00:FS00:Sending unit results: id:00 state:SEND error:FAULTY project:9414 run:28 clone:0 gen:545 core:0x21 unit:0x00000267ab436c9d585e069069243b6a
20:28:33:WU00:FS00:Uploading 6.50KiB to 171.67.108.157
20:28:33:WU00:FS00:Connecting to 171.67.108.157:8080
20:28:33:WU02:FS00:Connecting to 171.67.108.45:80
20:28:33:WU00:FS00:Upload complete
20:28:34:WU00:FS00:Server responded WORK_ACK (400)
20:28:34:WU00:FS00:Cleaning up
20:28:35:WU02:FS00:Assigned to work server 140.163.4.245
20:28:35:WU02:FS00:Requesting new work unit for slot 00: READY gpu:0:Ellesmere XT [Radeon RX 470/480/570/580] from 140.163.4.245
20:28:35:WU02:FS00:Connecting to 140.163.4.245:8080
20:28:36:WU02:FS00:Downloading 14.49MiB
20:28:38:WU02:FS00:Download complete
20:28:39:WU02:FS00:Received Unit: id:02 state:DOWNLOAD error:NO_ERROR project:10496 run:66 clone:73 gen:66 core:0x21 unit:0x000000528ca304f558896885c7051119
20:28:39:WU02:FS00:Starting
20:28:39:WU02:FS00:Running FahCore: /usr/bin/FAHCoreWrapper /var/lib/fahclient/cores/fahwebx.stanford.edu/cores/Linux/AMD64/ATI/R600/Core_21.fah/FahCore_21 -dir 02 -suffix 01 -version 704 -lifeline 1741 -checkpoint 15 -gpu 0 -gpu-vendor ati idle=true
20:28:39:WU02:FS00:Started FahCore on PID 3878
20:28:39:WU02:FS00:Core PID:3882
20:28:39:WU02:FS00:FahCore 0x21 started
20:28:39:WU02:FS00:0x21:*********************** Log Started 2017-07-07T20:28:39Z ***********************
20:28:39:WU02:FS00:0x21:Project: 10496 (Run 66, Clone 73, Gen 66)
20:28:39:WU02:FS00:0x21:Unit: 0x000000528ca304f558896885c7051119
20:28:39:WU02:FS00:0x21:CPU: 0x00000000000000000000000000000000
20:28:39:WU02:FS00:0x21:Machine: 0
20:28:39:WU02:FS00:0x21:Reading tar file core.xml
20:28:39:WU02:FS00:0x21:Reading tar file system.xml
20:28:40:WU02:FS00:0x21:Reading tar file integrator.xml
20:28:40:WU02:FS00:0x21:Reading tar file state.xml
20:28:41:WU02:FS00:0x21:Digital signatures verified
20:28:41:WU02:FS00:0x21:Folding@home GPU Core21 Folding@home Core
20:28:41:WU02:FS00:0x21:Version 0.0.18
20:28:42:WU02:FS00:0x21:ERROR:126: Bad platformId size.
20:28:42:WU02:FS00:0x21:Saving result file logfile_01.txt
20:28:42:WU02:FS00:0x21:Saving result file log.txt
20:28:42:WU02:FS00:0x21:Folding@home Core Shutdown: BAD_WORK_UNIT
20:28:42:WARNING:WU02:FS00:FahCore returned: BAD_WORK_UNIT (114 = 0x72)
20:28:42:WU02:FS00:Sending unit results: id:02 state:SEND error:FAULTY project:10496 run:66 clone:73 gen:66 core:0x21 unit:0x000000528ca304f558896885c7051119
20:28:42:WU02:FS00:Uploading 2.33KiB to 140.163.4.245
20:28:42:WU02:FS00:Connecting to 140.163.4.245:8080
20:28:43:WU02:FS00:Upload complete
20:28:43:WU02:FS00:Server responded WORK_ACK (400)
20:28:43:WU02:FS00:Cleaning up
20:30:46:WU01:FS01:0xa7:Completed 1050000 out of 2500000 steps (42%)
20:32:57:WU01:FS01:0xa7:Completed 1075000 out of 2500000 steps (43%)
20:35:02:WU01:FS01:0xa7:Completed 1100000 out of 2500000 steps (44%)
20:37:07:WU01:FS01:0xa7:Completed 1125000 out of 2500000 steps (45%)
20:39:14:WU01:FS01:0xa7:Completed 1150000 out of 2500000 steps (46%)
20:41:18:WU01:FS01:0xa7:Completed 1175000 out of 2500000 steps (47%)
20:43:29:WU01:FS01:0xa7:Completed 1200000 out of 2500000 steps (48%)
20:45:46:WU01:FS01:0xa7:Completed 1225000 out of 2500000 steps (49%)
20:48:23:WU01:FS01:0xa7:Completed 1250000 out of 2500000 steps (50%)
20:50:51:WU01:FS01:0xa7:Completed 1275000 out of 2500000 steps (51%)
20:53:32:WU01:FS01:0xa7:Completed 1300000 out of 2500000 steps (52%)
20:56:07:WU01:FS01:0xa7:Completed 1325000 out of 2500000 steps (53%)
20:58:46:WU01:FS01:0xa7:Completed 1350000 out of 2500000 steps (54%)
21:01:14:WU01:FS01:0xa7:Completed 1375000 out of 2500000 steps (55%)
21:03:23:WU01:FS01:0xa7:Completed 1400000 out of 2500000 steps (56%)
21:05:51:WU01:FS01:0xa7:Completed 1425000 out of 2500000 steps (57%)
21:08:00:WU01:FS01:0xa7:Completed 1450000 out of 2500000 steps (58%)
21:10:13:WU01:FS01:0xa7:Completed 1475000 out of 2500000 steps (59%)
21:12:39:WU01:FS01:0xa7:Completed 1500000 out of 2500000 steps (60%)
I'm just running the latest mesa drivers from the fedora repos
You should be using the AMD proprietary drivers including support for OpenCL processing. The open source drivers have been reported to not work.
djspacewhale
my distro doesn't support the AMD closed-source drivers - is there work being done to support mesa?
Mesa does not support OpenCL yet from what I understand, it has concentrated on supporting OpenGL ("G" not "C") for 3D video processing. Reportedly, Gallium is working on an OpenCL implementation to use with the Mesa drivers, but the most recent information I have seen is that is a "work in process".
So the answer is that PG is not able to do any work on supporting use of F@H with the Mesa drivers, they currently are missing an important element needed for processing on the GPU core. If at some point in time the open source drivers include usable OpenCL support, then they should be usable for folding.
