Assigned WU that won't run on 10 cores
Adam_Ford
Post by Adam_Ford »
20:02:40:WU02:FS00:Connecting to 171.67.108.45:8080
20:02:40:WU02:FS00:Assigned to work server 155.247.166.219
20:02:40:WU02:FS00:Requesting new work unit for slot 00: RUNNING cpu:10 from 155.247.166.219
20:02:40:WU02:FS00:Connecting to 155.247.166.219:8080
20:02:41:WU02:FS00:Downloading 672.89KiB
20:02:42:WU02:FS00:Download complete
20:02:42:WU02:FS00:Received Unit: id:02 state:DOWNLOAD error:NO_ERROR project:13712 run:0 clone:2 gen:0 core:0xa7 unit:0x000000010002894b58d577f5456cc3b6
20:02:45:WU02:FS00:Starting
20:02:45:WU02:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\Adam\AppData\Roaming\FAHClient\cores/fahwebx.stanford.edu/cores/Win32/AMD64/AVX/beta/Core_a7.fah/FahCore_a7.exe -dir 02 -suffix 01 -version 704 -lifeline 13240 -checkpoint 30 -np 10
20:02:45:WU02:FS00:Started FahCore on PID 12732
20:02:46:WU02:FS00:Core PID:8412
20:02:46:WU02:FS00:FahCore 0xa7 started
20:02:46:WU02:FS00:0xa7:*********************** Log Started 2017-07-05T20:02:46Z ***********************
20:02:46:WU02:FS00:0xa7:************************** Gromacs Folding@home Core ***************************
20:02:46:WU02:FS00:0xa7:       Type: 0xa7
20:02:46:WU02:FS00:0xa7:       Core: Gromacs
20:02:46:WU02:FS00:0xa7:    Website: http://folding.stanford.edu/
20:02:46:WU02:FS00:0xa7:  Copyright: (c) 2009-2016 Stanford University
20:02:46:WU02:FS00:0xa7:     Author: Joseph Coffland <joseph@cauldrondevelopment.com>
20:02:46:WU02:FS00:0xa7:       Args: -dir 02 -suffix 01 -version 704 -lifeline 12732 -checkpoint 30 -np
20:02:46:WU02:FS00:0xa7:             10
20:02:46:WU02:FS00:0xa7:     Config: <none>
20:02:46:WU02:FS00:0xa7:************************************ Build *************************************
20:02:46:WU02:FS00:0xa7:    Version: 0.0.13
20:02:46:WU02:FS00:0xa7:       Date: Mar 26 2017
20:02:46:WU02:FS00:0xa7:       Time: 16:55:32
20:02:46:WU02:FS00:0xa7: Repository: Git
20:02:46:WU02:FS00:0xa7:   Revision: a56232226285339aea9d39205933fb63e3b288f4
20:02:46:WU02:FS00:0xa7:     Branch: master
20:02:46:WU02:FS00:0xa7:   Compiler: Visual C++ 2008
20:02:46:WU02:FS00:0xa7:    Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
20:02:46:WU02:FS00:0xa7:   Platform: win32 10
20:02:46:WU02:FS00:0xa7:       Bits: 64
20:02:46:WU02:FS00:0xa7:       Mode: Release
20:02:46:WU02:FS00:0xa7:       SIMD: avx_256
20:02:46:WU02:FS00:0xa7:************************************ System ************************************
20:02:46:WU02:FS00:0xa7:        CPU: Unknown
20:02:46:WU02:FS00:0xa7:     CPU ID:
20:02:46:WU02:FS00:0xa7:       CPUs: 12
20:02:46:WU02:FS00:0xa7:     Memory: 15.91GiB
20:02:46:WU02:FS00:0xa7:Free Memory: 11.70GiB
20:02:46:WU02:FS00:0xa7:    Threads: WINDOWS_THREADS
20:02:46:WU02:FS00:0xa7: OS Version: 6.2
20:02:46:WU02:FS00:0xa7:Has Battery: false
20:02:46:WU02:FS00:0xa7: On Battery: false
20:02:46:WU02:FS00:0xa7: UTC Offset: -5
20:02:46:WU02:FS00:0xa7:        PID: 8412
20:02:46:WU02:FS00:0xa7:        CWD: C:\Users\Adam\AppData\Roaming\FAHClient\work
20:02:46:WU02:FS00:0xa7:         OS: Windows 10 Home
20:02:46:WU02:FS00:0xa7:    OS Arch: AMD64
20:02:46:WU02:FS00:0xa7:********************************************************************************
20:02:46:WU02:FS00:0xa7:Project: 13712 (Run 0, Clone 2, Gen 0)
20:02:46:WU02:FS00:0xa7:Unit: 0x000000010002894b58d577f5456cc3b6
20:02:46:WU02:FS00:0xa7:Reading tar file core.xml
20:02:46:WU02:FS00:0xa7:Reading tar file frame0.tpr
20:02:46:WU02:FS00:0xa7:Digital signatures verified
20:02:46:WU02:FS00:0xa7:Calling: mdrun -s frame0.tpr -o frame0.trr -cpt 30 -nt 10
20:02:46:WU02:FS00:0xa7:Steps: first=0 total=2500000
20:02:46:WU02:FS00:0xa7:ERROR:
20:02:46:WU02:FS00:0xa7:ERROR:-------------------------------------------------------
20:02:46:WU02:FS00:0xa7:ERROR:Program GROMACS, VERSION 5.0.4-20161122-4846b12ba-unknown
20:02:46:WU02:FS00:0xa7:ERROR:Source code file: C:\build\fah\core-a7-avx-release\windows-10-64bit-core-a7-avx-release\gromacs-core\build\gromacs\src\gromacs\mdlib\domdec.c, line: 6902
20:02:46:WU02:FS00:0xa7:ERROR:Fatal error:
20:02:46:WU02:FS00:0xa7:ERROR:There is no domain decomposition for 10 ranks that is compatible with the given box and a minimum cell size of 2.04143 nm
20:02:46:WU02:FS00:0xa7:ERROR:Change the number of ranks or mdrun option -rdd or -dds
20:02:46:WU02:FS00:0xa7:ERROR:Look in the log file for details on the domain decomposition
20:02:46:WU02:FS00:0xa7:ERROR:For more information and tips for troubleshooting, please check the GROMACS
20:02:46:WU02:FS00:0xa7:ERROR:website at http://www.gromacs.org/Documentation/Errors
20:02:51:WU02:FS00:0xa7:WARNING:Unexpected exit() call
20:02:51:WU02:FS00:0xa7:WARNING:Unexpected exit from science code
20:02:51:WU02:FS00:0xa7:Saving result file ..\logfile_01.txt
20:02:51:WU02:FS00:0xa7:Saving result file md.log
20:02:51:WU02:FS00:0xa7:Saving result file science.log
20:02:51:WU02:FS00:0xa7:WARNING:While cleaning up: Failed to remove directory '01': boost::filesystem::remove: The process cannot access the file because it is being used by another process: "01\md.log"
20:02:51:WU02:FS00:0xa7:Folding@home Core Shutdown: BAD_WORK_UNIT
20:02:52:WARNING:WU02:FS00:FahCore returned: BAD_WORK_UNIT (114 = 0x72)
20:02:52:WU02:FS00:Sending unit results: id:02 state:SEND error:FAULTY project:13712 run:0 clone:2 gen:0 core:0xa7 unit:0x000000010002894b58d577f5456cc3b6
20:02:52:WU02:FS00:Uploading 6.14KiB to 155.247.166.219
20:02:52:WU02:FS00:Connecting to 155.247.166.219:8080
20:02:52:WU02:FS00:Upload complete
20:02:52:WU02:FS00:Server responded WORK_ACK (400)
20:02:52:WU02:FS00:Cleaning up
20:02:52:WU02:FS00:Connecting to 171.67.108.45:8080
20:02:52:WU02:FS00:Assigned to work server 155.247.166.219
20:02:52:WU02:FS00:Requesting new work unit for slot 00: READY cpu:10 from 155.247.166.219
20:02:53:WU02:FS00:Downloading 675.13KiB
20:02:54:WU02:FS00:Download complete
20:02:54:WU02:FS00:Received Unit: id:02 state:DOWNLOAD error:NO_ERROR project:13715 run:1 clone:2 gen:0 core:0xa7 unit:0x000000030002894b58d576e93addb7ea
20:02:54:WU02:FS00:Starting
20:02:54:WU02:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\Adam\AppData\Roaming\FAHClient\cores/fahwebx.stanford.edu/cores/Win32/AMD64/AVX/beta/Core_a7.fah/FahCore_a7.exe -dir 02 -suffix 01 -version 704 -lifeline 13240 -checkpoint 30 -np 10
20:02:54:WU02:FS00:Started FahCore on PID 3560
20:02:54:WU02:FS00:Core PID:1064
20:02:54:WU02:FS00:FahCore 0xa7 started
20:02:54:WU02:FS00:0xa7:*********************** Log Started 2017-07-05T20:02:54Z ***********************
20:02:54:WU02:FS00:0xa7:************************** Gromacs Folding@home Core ***************************
20:02:54:WU02:FS00:0xa7:       Type: 0xa7
20:02:54:WU02:FS00:0xa7:       Core: Gromacs
20:02:54:WU02:FS00:0xa7:    Website: http://folding.stanford.edu/
20:02:54:WU02:FS00:0xa7:  Copyright: (c) 2009-2016 Stanford University
20:02:54:WU02:FS00:0xa7:     Author: Joseph Coffland <joseph@cauldrondevelopment.com>
20:02:54:WU02:FS00:0xa7:       Args: -dir 02 -suffix 01 -version 704 -lifeline 3560 -checkpoint 30 -np
20:02:54:WU02:FS00:0xa7:             10
20:02:54:WU02:FS00:0xa7:     Config: <none>
20:02:54:WU02:FS00:0xa7:************************************ Build *************************************
20:02:54:WU02:FS00:0xa7:    Version: 0.0.13
20:02:54:WU02:FS00:0xa7:       Date: Mar 26 2017
20:02:54:WU02:FS00:0xa7:       Time: 16:55:32
20:02:54:WU02:FS00:0xa7: Repository: Git
20:02:54:WU02:FS00:0xa7:   Revision: a56232226285339aea9d39205933fb63e3b288f4
20:02:54:WU02:FS00:0xa7:     Branch: master
20:02:54:WU02:FS00:0xa7:   Compiler: Visual C++ 2008
20:02:54:WU02:FS00:0xa7:    Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
20:02:54:WU02:FS00:0xa7:   Platform: win32 10
20:02:54:WU02:FS00:0xa7:       Bits: 64
20:02:54:WU02:FS00:0xa7:       Mode: Release
20:02:54:WU02:FS00:0xa7:       SIMD: avx_256
20:02:54:WU02:FS00:0xa7:************************************ System ************************************
20:02:54:WU02:FS00:0xa7:        CPU: Unknown
20:02:54:WU02:FS00:0xa7:     CPU ID:
20:02:54:WU02:FS00:0xa7:       CPUs: 12
20:02:54:WU02:FS00:0xa7:     Memory: 15.91GiB
20:02:54:WU02:FS00:0xa7:Free Memory: 11.72GiB
20:02:54:WU02:FS00:0xa7:    Threads: WINDOWS_THREADS
20:02:54:WU02:FS00:0xa7: OS Version: 6.2
20:02:54:WU02:FS00:0xa7:Has Battery: false
20:02:54:WU02:FS00:0xa7: On Battery: false
20:02:54:WU02:FS00:0xa7: UTC Offset: -5
20:02:54:WU02:FS00:0xa7:        PID: 1064
20:02:54:WU02:FS00:0xa7:        CWD: C:\Users\Adam\AppData\Roaming\FAHClient\work
20:02:54:WU02:FS00:0xa7:         OS: Windows 10 Home
20:02:54:WU02:FS00:0xa7:    OS Arch: AMD64
20:02:54:WU02:FS00:0xa7:********************************************************************************
20:02:54:WU02:FS00:0xa7:Project: 13715 (Run 1, Clone 2, Gen 0)
20:02:54:WU02:FS00:0xa7:Unit: 0x000000030002894b58d576e93addb7ea
20:02:54:WU02:FS00:0xa7:Reading tar file core.xml
20:02:54:WU02:FS00:0xa7:Reading tar file frame0.tpr
20:02:54:WU02:FS00:0xa7:Digital signatures verified
20:02:54:WU02:FS00:0xa7:Calling: mdrun -s frame0.tpr -o frame0.trr -cpt 30 -nt 10
20:02:54:WU02:FS00:0xa7:Steps: first=0 total=2500000
20:02:54:WU02:FS00:0xa7:ERROR:
20:02:54:WU02:FS00:0xa7:ERROR:-------------------------------------------------------
20:02:54:WU02:FS00:0xa7:ERROR:Program GROMACS, VERSION 5.0.4-20161122-4846b12ba-unknown
20:02:54:WU02:FS00:0xa7:ERROR:Source code file: C:\build\fah\core-a7-avx-release\windows-10-64bit-core-a7-avx-release\gromacs-core\build\gromacs\src\gromacs\mdlib\domdec.c, line: 6902
20:02:54:WU02:FS00:0xa7:ERROR:Fatal error:
20:02:54:WU02:FS00:0xa7:ERROR:There is no domain decomposition for 10 ranks that is compatible with the given box and a minimum cell size of 2.0203 nm
20:02:54:WU02:FS00:0xa7:ERROR:Change the number of ranks or mdrun option -rdd or -dds
20:02:54:WU02:FS00:0xa7:ERROR:Look in the log file for details on the domain decomposition
20:02:54:WU02:FS00:0xa7:ERROR:For more information and tips for troubleshooting, please check the GROMACS
20:02:54:WU02:FS00:0xa7:ERROR:website at http://www.gromacs.org/Documentation/Errors
20:02:59:WU02:FS00:0xa7:WARNING:Unexpected exit() call
20:02:59:WU02:FS00:0xa7:WARNING:Unexpected exit from science code
20:02:59:WU02:FS00:0xa7:Saving result file ..\logfile_01.txt
20:02:59:WU02:FS00:0xa7:Saving result file md.log
20:02:59:WU02:FS00:0xa7:Saving result file science.log
20:02:59:WU02:FS00:0xa7:WARNING:While cleaning up: Failed to remove directory '01': boost::filesystem::remove: The process cannot access the file because it is being used by another process: "01\md.log"
20:02:59:WU02:FS00:0xa7:Folding@home Core Shutdown: BAD_WORK_UNIT
20:03:00:WARNING:WU02:FS00:FahCore returned: BAD_WORK_UNIT (114 = 0x72)
20:03:00:WU02:FS00:Sending unit results: id:02 state:SEND error:FAULTY project:13715 run:1 clone:2 gen:0 core:0xa7 unit:0x000000030002894b58d576e93addb7ea
20:03:00:WU02:FS00:Uploading 6.13KiB to 155.247.166.219
20:03:00:WU02:FS00:Connecting to 155.247.166.219:8080
20:03:00:WU02:FS00:Upload complete
20:03:00:WU02:FS00:Server responded WORK_ACK (400)
20:03:00:WU02:FS00:Cleaning up
20:03:00:WU03:FS00:Connecting to 171.67.108.45:8080
20:03:00:WU03:FS00:Assigned to work server 155.247.166.219
20:03:00:WU03:FS00:Requesting new work unit for slot 00: READY cpu:10 from 155.247.166.219
20:03:00:WU03:FS00:Connecting to 155.247.166.219:8080
20:03:01:WU03:FS00:Downloading 843.64KiB
20:03:02:WU03:FS00:Download complete
20:03:02:WU03:FS00:Received Unit: id:03 state:DOWNLOAD error:NO_ERROR project:13707 run:19 clone:0 gen:1 core:0xa7 unit:0x000000020002894b58d5797362b062fd
20:03:02:WU03:FS00:Starting
20:03:02:WU03:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\Adam\AppData\Roaming\FAHClient\cores/fahwebx.stanford.edu/cores/Win32/AMD64/AVX/beta/Core_a7.fah/FahCore_a7.exe -dir 03 -suffix 01 -version 704 -lifeline 13240 -checkpoint 30 -np 10
20:03:02:WU03:FS00:Started FahCore on PID 3428
20:03:02:WU03:FS00:Core PID:420
20:03:02:WU03:FS00:FahCore 0xa7 started
20:03:03:WU03:FS00:0xa7:*********************** Log Started 2017-07-05T20:03:02Z ***********************
20:03:03:WU03:FS00:0xa7:************************** Gromacs Folding@home Core ***************************
20:03:03:WU03:FS00:0xa7:       Type: 0xa7
20:03:03:WU03:FS00:0xa7:       Core: Gromacs
20:03:03:WU03:FS00:0xa7:    Website: http://folding.stanford.edu/
20:03:03:WU03:FS00:0xa7:  Copyright: (c) 2009-2016 Stanford University
20:03:03:WU03:FS00:0xa7:     Author: Joseph Coffland <joseph@cauldrondevelopment.com>
20:03:03:WU03:FS00:0xa7:       Args: -dir 03 -suffix 01 -version 704 -lifeline 3428 -checkpoint 30 -np
20:03:03:WU03:FS00:0xa7:             10
20:03:03:WU03:FS00:0xa7:     Config: <none>
20:03:03:WU03:FS00:0xa7:************************************ Build *************************************
20:03:03:WU03:FS00:0xa7:    Version: 0.0.13
20:03:03:WU03:FS00:0xa7:       Date: Mar 26 2017
20:03:03:WU03:FS00:0xa7:       Time: 16:55:32
20:03:03:WU03:FS00:0xa7: Repository: Git
20:03:03:WU03:FS00:0xa7:   Revision: a56232226285339aea9d39205933fb63e3b288f4
20:03:03:WU03:FS00:0xa7:     Branch: master
20:03:03:WU03:FS00:0xa7:   Compiler: Visual C++ 2008
20:03:03:WU03:FS00:0xa7:    Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox /MT
20:03:03:WU03:FS00:0xa7:   Platform: win32 10
20:03:03:WU03:FS00:0xa7:       Bits: 64
20:03:03:WU03:FS00:0xa7:       Mode: Release
20:03:03:WU03:FS00:0xa7:       SIMD: avx_256
20:03:03:WU03:FS00:0xa7:************************************ System ************************************
20:03:03:WU03:FS00:0xa7:        CPU: Unknown
20:03:03:WU03:FS00:0xa7:     CPU ID:
20:03:03:WU03:FS00:0xa7:       CPUs: 12
20:03:03:WU03:FS00:0xa7:     Memory: 15.91GiB
20:03:03:WU03:FS00:0xa7:Free Memory: 11.73GiB
20:03:03:WU03:FS00:0xa7:    Threads: WINDOWS_THREADS
20:03:03:WU03:FS00:0xa7: OS Version: 6.2
20:03:03:WU03:FS00:0xa7:Has Battery: false
20:03:03:WU03:FS00:0xa7: On Battery: false
20:03:03:WU03:FS00:0xa7: UTC Offset: -5
20:03:03:WU03:FS00:0xa7:        PID: 420
20:03:03:WU03:FS00:0xa7:        CWD: C:\Users\Adam\AppData\Roaming\FAHClient\work
20:03:03:WU03:FS00:0xa7:         OS: Windows 10 Home
20:03:03:WU03:FS00:0xa7:    OS Arch: AMD64
20:03:03:WU03:FS00:0xa7:********************************************************************************
20:03:03:WU03:FS00:0xa7:Project: 13707 (Run 19, Clone 0, Gen 1)
20:03:03:WU03:FS00:0xa7:Unit: 0x000000020002894b58d5797362b062fd
20:03:03:WU03:FS00:0xa7:Reading tar file core.xml
20:03:03:WU03:FS00:0xa7:Reading tar file frame1.tpr
20:03:03:WU03:FS00:0xa7:Digital signatures verified
20:03:03:WU03:FS00:0xa7:Calling: mdrun -s frame1.tpr -o frame1.trr -cpt 30 -nt 10
20:03:03:WU03:FS00:0xa7:Steps: first=2500000 total=2500000
20:03:03:WU03:FS00:0xa7:ERROR:
20:03:03:WU03:FS00:0xa7:ERROR:-------------------------------------------------------
20:03:03:WU03:FS00:0xa7:ERROR:Program GROMACS, VERSION 5.0.4-20161122-4846b12ba-unknown
20:03:03:WU03:FS00:0xa7:ERROR:Source code file: C:\build\fah\core-a7-avx-release\windows-10-64bit-core-a7-avx-release\gromacs-core\build\gromacs\src\gromacs\mdlib\domdec.c, line: 6902
20:03:03:WU03:FS00:0xa7:ERROR:Fatal error:
20:03:03:WU03:FS00:0xa7:ERROR:There is no domain decomposition for 10 ranks that is compatible with the given box and a minimum cell size of 2.09648 nm
20:03:03:WU03:FS00:0xa7:ERROR:Change the number of ranks or mdrun option -rdd or -dds
20:03:03:WU03:FS00:0xa7:ERROR:Look in the log file for details on the domain decomposition
20:03:03:WU03:FS00:0xa7:ERROR:For more information and tips for troubleshooting, please check the GROMACS
20:03:03:WU03:FS00:0xa7:ERROR:website at http://www.gromacs.org/Documentation/Errors
20:03:05:FS00:Finishing
20:03:07:WU03:FS00:0xa7:WARNING:Unexpected exit() call
20:03:07:WU03:FS00:0xa7:WARNING:Unexpected exit from science code
20:03:07:WU03:FS00:0xa7:Saving result file ..\logfile_01.txt
20:03:07:WU03:FS00:0xa7:Saving result file md.log
20:03:07:WU03:FS00:0xa7:Saving result file science.log
20:03:07:WU03:FS00:0xa7:WARNING:While cleaning up: Failed to remove directory '01': boost::filesystem::remove: The process cannot access the file because it is being used by another process: "01\md.log"
20:03:07:WU03:FS00:0xa7:Folding@home Core Shutdown: BAD_WORK_UNIT
20:03:08:WARNING:WU03:FS00:FahCore returned: BAD_WORK_UNIT (114 = 0x72)
20:03:08:WU03:FS00:Sending unit results: id:03 state:SEND error:FAULTY project:13707 run:19 clone:0 gen:1 core:0xa7 unit:0x000000020002894b58d5797362b062fd
20:03:08:WU03:FS00:Uploading 6.15KiB to 155.247.166.219
20:03:08:WU03:FS00:Connecting to 155.247.166.219:8080
20:03:08:WU03:FS00:Upload complete
20:03:08:WU03:FS00:Server responded WORK_ACK (400)
20:03:08:WU03:FS00:Cleaning up
*********************** Log Started 2017-07-05T20:52:04Z ***********************
20:52:04:************************* Folding@home Client *************************
20:52:04:        Website: http://folding.stanford.edu/
20:52:04:      Copyright: (c) 2009-2016 Stanford University
20:52:04:         Author: Joseph Coffland <joseph@cauldrondevelopment.com>
20:52:04:           Args: --open-web-control
20:52:04:         Config: C:\Users\Adam\AppData\Roaming\FAHClient\config.xml
20:52:04:******************************** Build ********************************
20:52:04:        Version: 7.4.16
20:52:04:           Date: Jan 6 2017
20:52:04:           Time: 00:25:14
20:52:04:     Repository: Git
20:52:04:       Revision: a9e9e27dc2ee6ff01398c439677bc27f6cb74032
20:52:04:         Branch: master
20:52:04:       Compiler: Visual C++ 2008
20:52:04:        Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox -arch:SSE /MT
20:52:04:       Platform: win32 10
20:52:04:           Bits: 32
20:52:04:           Mode: Release
20:52:04:******************************* System ********************************
20:52:04:            CPU: Intel(R) Core(TM) i7-5820K CPU @ 3.30GHz
20:52:04:         CPU ID: GenuineIntel Family 6 Model 63 Stepping 2
20:52:04:           CPUs: 12
20:52:04:         Memory: 15.91GiB
20:52:04:    Free Memory: 12.16GiB
20:52:04:        Threads: WINDOWS_THREADS
20:52:04:     OS Version: 6.2
20:52:04:    Has Battery: false
20:52:04:     On Battery: false
20:52:04:     UTC Offset: -5
20:52:04:            PID: 9132
20:52:04:            CWD: C:\Users\Adam\AppData\Roaming\FAHClient
20:52:04:             OS: Windows 10 Home
20:52:04:        OS Arch: AMD64
20:52:04:           GPUs: 1
20:52:04:          GPU 0: Bus:1 Slot:0 Func:0 NVIDIA:7 GP104 [GeForce GTX 1080] 8873
20:52:04:  CUDA Device 0: Platform:0 Device:0 Bus:1 Slot:0 Compute:6.1 Driver:8.0
20:52:04:OpenCL Device 0: Platform:0 Device:0 Bus:1 Slot:0 Compute:1.2 Driver:373.6
20:52:04:  Win32 Service: false
20:52:04:***********************************************************************
20:52:04:<config>
20:52:04:  <!-- Folding Core -->
20:52:04:  <checkpoint v='30'/>
20:52:04:
20:52:04:  <!-- HTTP Server -->
20:52:04:  <allow v='127.0.0.1 192.168.1.0/24'/>
20:52:04:
20:52:04:  <!-- Network -->
20:52:04:  <proxy v=':8080'/>
20:52:04:
20:52:04:  <!-- Remote Command Server -->
20:52:04:  <command-allow-no-pass v='127.0.0.1 192.168.1.0/24'/>
20:52:04:
20:52:04:  <!-- Slot Control -->
20:52:04:  <pause-on-battery v='false'/>
20:52:04:  <pause-on-start v='true'/>
20:52:04:  <power v='full'/>
20:52:04:
20:52:04:  <!-- User Information -->
20:52:04:  <passkey v='********************************'/>
20:52:04:  <user v='Adam_Ford'/>
20:52:04:
20:52:04:  <!-- Work Unit Control -->
20:52:04:  <next-unit-percentage v='100'/>
20:52:04:
20:52:04:  <!-- Folding Slots -->
20:52:04:  <slot id='0' type='CPU'>
20:52:04:    <client-type v='beta'/>
20:52:04:    <cpus v='10'/>
20:52:04:  </slot>
20:52:04:  <slot id='1' type='GPU'>
20:52:04:    <max-packet-size v='big'/>
20:52:04:  </slot>
20:52:04:</config>
20:52:04:Trying to access database...
20:52:04:Successfully acquired database lock
20:52:04:Enabled folding slot 00: PAUSED cpu:10 (by user)
20:52:04:Enabled folding slot 01: PAUSED gpu:0:GP104 [GeForce GTX 1080] 8873 (by user)
Re: Assigned WU that won't run on 10 cores
The domain needs to be divided into prisms using factors of the number of threads. That will be 5x2x1 in XYZ. Apparently dividing it by 5 in one direction makes the slices too thin. I expect it will work fine with 8 = 2*2*2.
The Project Scientist sets the minimum cell size but it also depends on the initial geometry of the protein. A protein covering a smaller volume (such as the same protein after it is partially folded) will probably work. Hopefully you'll either change the number of CPUs or you'll get another project that fits withing the constraints.
