WU's Not Being Assigned
noob_for_life
Post by noob_for_life »
I have restarted and I'm still not receiving work units. The Chrome page works fine. But, FAH Control just shows lots of
07:02:17:ERROR:WU00:FS00:Exception: Could not get an assignment
07:20:14:WU00:FS00:Connecting to 171.67.108.45:8080
07:20:14:WARNING:WU00:FS00:Failed to get assignment from '171.67.108.45:8080': Empty work server assignment
07:20:14:WU00:FS00:Connecting to 171.64.65.35:80
07:20:15:WARNING:WU00:FS00:Failed to get assignment from '171.64.65.35:80': Empty work server assignment
07:20:15:ERROR:WU00:FS00:Exception: Could not get an assignment
In the log
Ricky
Hardware configuration: 1. 2 each E5-2630 V3 processors, 64 GB RAM, GTX980SC GPU, and GTX980 GPU running on windows 8.1 operating system.
2. I7-6950X V3 processor, 32 GB RAM, 1 GTX980tiFTW, and 2 each GTX1080FTW GPUs running on windows 8.1 operating system.
Re: WU's Not Being Assigned by 171.67.108.102/171.67.108.105
Post by Ricky »
noob_for_life,
Do you have 7 threads for your CPU that you are trying to fold in slot 00? If so, it is hard to get assignments that work with primes larger than 5. If this is your issue, you can try the 7.4.16 client that will automatically reduce the slot setting for work units that are available, or you can manually reduce the slot setting in the 7.4.4 client to a value that has no prime factor larger than 5.
@noob_for_life
I have split this off from where you posted, your problem is unrelated to that topic. The two Assignment Servers your system have been connecting to are not able to match your configuration with available work on Work Servers, that is the meaning of the "Empty work server" message. The topic you posted in was about specific Work Servers not assigning work after the AS had connected the client to them. Ricky has given you the same information as Bruce gave to you in response to your previous post with the same problem - viewtopic.php?f=96&t=30040&p=295841#p295841.
A quick way of determining if this is your problem is to pause the CPU folding slot, change the setting of the slider and then resume. If the slider is set at Full, move it to Medium or Light. The log should show the client requesting a WU for a CPU thread count that is a multiple of 2, 3 and/or 5. Multiples of primes larger than that will not get assigned WU's using the 7.4.4 client, the newer beta client 7.4.16 has code to negotiate with the AS for a WU with a CPU thread setting that is as high as possible up to the number set in the request.
Or you can post the first 100 or so line of your log to show your system info and configuration. We can make suggestions based on the information that shows.
