Nvidia Quadro M1200
aBigRedBear
Nvidia Quadro M1200
Post by aBigRedBear »
fahclient --lspci output:
0x8086:0xa12f:Intel Corporation:USB xHCI Compliant Host Controller
0x8086:0x24fd:Intel Corporation:Intel(R) Dual Band Wireless-AC 8265
0x8086:0xa123:Intel Corporation:Synaptics SMBus Driver
0x8086:0xa13d:Intel Corporation:Intel(R) Active Management Technology - SOL
0x8086:0xa131:Intel Corporation:Intel(R) 100 Series/C230 Series Chipset Family Thermal subsystem - A131
0x8086:0x5910:Intel Corporation:PCI standard host CPU bridge
0x8086:0xa13a:Intel Corporation:Intel(R) Management Engine Interface
0x8086:0xa11c:Intel Corporation:PCI-to-PCI Bridge
0x8086:0xa110:Intel Corporation:PCI-to-PCI Bridge
0x8086:0xa118:Intel Corporation:PCI-to-PCI Bridge
0x8086:0x15e3:Intel Corporation:Intel(R) Ethernet Connection (5) I219-LM
0x8086:0x1911:Intel Corporation:Intel(R) Xeon(R) E3 - 1200/1500 v5/6th Gen Intel(R) Core(TM) Gaussian Mixture Model - 1911
0x10ec:0x525a:Realtek Semiconductor Co., Ltd.:Realtek PCIE CardReader
0x8086:0xa102:Intel Corporation:Intel(R) 100 Series/C230 Chipset Family SATA AHCI Controller
0x8086:0xa112:Intel Corporation:PCI-to-PCI Bridge
0x8086:0x1901:Intel Corporation:PCI-to-PCI Bridge
0x144d:0xa804:Samsung Electronics Co Ltd:Standard NVM Express Controller
0x8086:0xa121:Intel Corporation:Intel(R) 100 Series/C230 Series Chipset Family PMC - A121
0x8086:0xa160:Intel Corporation:Intel(R) Serial IO I2C Host Controller - A160
0x8086:0xa171:Intel Corporation:High Definition Audio Controller
0x8086:0xa114:Intel Corporation:PCI-to-PCI Bridge
0x10de:0x13b6:NVIDIA Corporation:NVIDIA Quadro M1200
0x8086:0xa154:Intel Corporation:PCI standard ISA bridge
fahclient log output:
*********************** Log Started 2017-06-20T15:02:44Z ***********************
15:02:44:************************* Folding@home Client *************************
15:02:44:      Website: http://folding.stanford.edu/
15:02:44:    Copyright: (c) 2009-2014 Stanford University
15:02:44:       Author: Joseph Coffland <joseph@cauldrondevelopment.com>
15:02:44:         Args:
15:02:44:       Config: C:/Users/GeorgeHWBush/AppData/Roaming/FAHClient/config.xml
15:02:44:******************************** Build ********************************
15:02:44:      Version: 7.4.4
15:02:44:         Date: Mar 4 2014
15:02:44:         Time: 20:26:54
15:02:44:      SVN Rev: 4130
15:02:44:       Branch: fah/trunk/client
15:02:44:     Compiler: Intel(R) C++ MSVC 1500 mode 1200
15:02:44:      Options: /TP /nologo /EHa /Qdiag-disable:4297,4103,1786,279 /Ox -arch:SSE
15:02:44:               /QaxSSE2,SSE3,SSSE3,SSE4.1,SSE4.2 /Qopenmp /Qrestrict /MT /Qmkl
15:02:44:     Platform: win32 XP
15:02:44:         Bits: 32
15:02:44:         Mode: Release
15:02:44:******************************* System ********************************
15:02:44:          CPU: Intel(R) Core(TM) i7-7820HQ CPU @ 2.90GHz
15:02:44:       CPU ID: GenuineIntel Family 6 Model 158 Stepping 9
15:02:44:         CPUs: 8
15:02:44:       Memory: 31.88GiB
15:02:44:  Free Memory: 29.35GiB
15:02:44:      Threads: WINDOWS_THREADS
15:02:44:   OS Version: 6.2
15:02:44:  Has Battery: true
15:02:44:   On Battery: false
15:02:44:   UTC Offset: -4
15:02:44:          PID: 13564
15:02:44:          CWD: C:/Users/WilliamClinton/AppData/Roaming/FAHClient
15:02:44:           OS: Windows 10 Pro
15:02:44:      OS Arch: AMD64
15:02:44:         GPUs: 0
15:02:44:         CUDA: 5.0
15:02:44:  CUDA Driver: 8000
15:02:44:Win32 Service: false
15:02:44:***********************************************************************
15:02:44:<config>
15:02:44:  <!-- Folding Slot Configuration -->
15:02:44:  <cause v='PARKINSONS'/>
15:02:44:
15:02:44:  <!-- Network -->
15:02:44:  <proxy v=':8080'/>
15:02:44:
15:02:44:  <!-- Slot Control -->
15:02:44:  <power v='full'/>
15:02:44:
15:02:44:  <!-- User Information -->
15:02:44:  <passkey v='********************************'/>
15:02:44:  <team v='37726'/>
15:02:44:  <user v='BigRedBear'/>
15:02:44:
15:02:44:  <!-- Folding Slots -->
15:02:44:  <slot id='0' type='CPU'>
15:02:44:    <cpus v='4'/>
15:02:44:  </slot>
15:02:44:</config>
15:02:44:Trying to access database...
15:02:44:Successfully acquired database lock
15:02:44:Enabled folding slot 00: READY cpu:4
15:02:44:WU01:FS00:Starting
15:02:44:WU01:FS00:Running FahCore: B:\ExtraAppInstalls\FAHClient/FAHCoreWrapper.exe C:/Users/BarrackObama/AppData/Roaming/FAHClient/cores/fahwebx.stanford.edu/cores/Win32/AMD64/Core_a4.fah/FahCore_a4.exe -dir 01 -suffix 01 -version 704 -lifeline 13564 -checkpoint 15 -np 4
15:02:44:WU01:FS00:Started FahCore on PID 13932
15:02:44:WU01:FS00:Core PID:13956
15:02:44:WU01:FS00:FahCore 0xa4 started
15:02:44:WU01:FS00:0xa4:
15:02:44:WU01:FS00:0xa4:*------------------------------*
15:02:44:WU01:FS00:0xa4:Folding@Home Gromacs GB Core
15:02:44:WU01:FS00:0xa4:Version 2.27 (Dec. 15, 2010)
15:02:44:WU01:FS00:0xa4:Preparing to commence simulation
15:02:44:WU01:FS00:0xa4:- Looking at optimizations...
15:02:44:WU01:FS00:0xa4:- Files status OK
15:02:44:WU01:FS00:0xa4:- Expanded 825715 -> 1401112 (decompressed 169.6 percent)
15:02:44:WU01:FS00:0xa4:Called DecompressByteArray: compressed_data_size=825715 data_size=1401112, decompressed_data_size=1401112 diff=0
15:02:44:WU01:FS00:0xa4:- Digital signature verified
15:02:44:WU01:FS00:0xa4:Project: 9034 (Run 203, Clone 1, Gen 1181)
15:02:44:WU01:FS00:0xa4:Assembly optimizations on if available.
15:02:44:WU01:FS00:0xa4:Entering M.D.
15:02:50:WU01:FS00:0xa4:Using Gromacs checkpoints
15:02:50:WU01:FS00:0xa4:Mapping NT from 4 to 4
15:02:50:WU01:FS00:0xa4:Resuming from checkpoint
15:02:50:WU01:FS00:0xa4:Verified 01/wudata_01.log
15:02:50:WU01:FS00:0xa4:Verified 01/wudata_01.trr
15:02:50:WU01:FS00:0xa4:Verified 01/wudata_01.xtc
15:02:50:WU01:FS00:0xa4:Verified 01/wudata_01.edr
15:02:50:WU01:FS00:0xa4:Completed 46580 out of 250000 steps  (18%)
Re: Nvidia Quadro M1200
Welcome to foldingforum.org, aBigRedBear.
You're the first Donor who has asked to fold with a Quadro M1200. I'll get it added to GPUs.txt so it's approved for folding.
aBigRedBear
Thanks Bruce, that'd be great. Will you notify me when the list is updated so that I can download the latest version, or will it update automatically?
edit: I just came to understand that the client automatically updates the gpus.txt file every 30 days. There's no need to answer my first question, but if you could post when it's updated so that I can pull a fresh version I'd appreciate it.
tictoc
Hardware configuration: AMD Threadripper 7960X
1x AMD Radeon 7900XTX
1x AMD Radeon 6900XT
1x AMD Radeon VII
AMD Threadripper 3960X
2x AMD Radeon VII
AMD Threadripper 2970WX
2x AMD Radeon VII
AMD Ryzen 7 5800X
2x NVIDIA RTX 3090
Post by tictoc »
Not sure if you have tried folding on your laptop again, but the M1200 has been added to the GPUs.txt file.
