I recently installed FAH for the first time, setup an identity, obtained a passkey, chose a cause, and waited. I have two Windows PCs containing three powerful GPUs waiting to fold, but after several days of waiting the FAH client has never once downloaded any work units. I see many cryptic error messages in the log such as:
08:47:47:WARNING:WU00:FS00:Failed to get ID from '171.64.65.35:80': Failed to connect to 171.64.65.35:80: A connection attempt failed because....
08:47:47:ERROR:WU00:FS00:Exception: Could not get an assignment ID
08:53:35:Connecting to assign-GPU2.stanford.edu:80
08:53:56:WARNING:Attempting to update GPUs.txt from assign-GPU2.stanford.edu:80: Failed to connect to assign-GPU2.stanford.edu:80: A connection attempt failed because...
After jumping through all the initial hoops, is the average person really supposed to spend their time trying to solve software bugs, or should they simply uninstall FAH and tell all their friends and colleagues not to bother with FAH, since it doesn't work?
WU's Not Being Assigned [new install]
Re: WU's Not Being Assigned [new install]
I have split your post off the topic you added it to, the problem is not a software bug or server problem. Something on your system or local network is preventing the client software from contacting the servers for the Folding@home project. The FAHClient process needs the same access for downloading and uploading as a web browser, anti-malware and firewalls may need an exception entered.
Most of their friends and relatives are going to have a straight forward home network. Tell us about yours. (Router, firewall, antivirus, etc)NAtWork wrote:simply uninstall FAH and tell all their friends and colleagues not to bother with FAH, since it doesn't work?
i use Windows 7 a great deal and it asks me if F@H can be approved to go through the Windows firewall for the current network and all public networks.
In WIndows 10, Microsoft has decided to suppress that question even though FAH is not on their built-in list of approved browsers. I'm not sure of the best way to get that information out to new donors who don't find their way to foldingforum to ask the question.JimboPalmer wrote:[i use Windows 7 a great deal and it asks me if F@H can be approved to go through the Windows firewall for the current network and all public networks.
Welcome to foldingforum.org, NAtWork.
Thanks for your help; of course you are correct, and apologies for my rant. I tried installing FAH on another PC here at work (with two TITAN Black GPUs), and when Windows 7 notified me about giving (local) firewall access I checked all three boxes to give FAH full freedom. Unfortunately that still wasn't enough, so the corporate network stuff higher up the chain must be blocking FAH. Instead, I'm now using the instant web-interface FAH, and it's now happily roasting two CPUs. I'll try FAH on my home PC next, which has two GTX1060 GPUs ready to earn their keep. Keep up the good work!
If you are folding using company resources, (PCs, electricity, time) be sure you have written permission to do so.
Best of luck with the corporate firewall. Mostly F@H only needs port 8080 open.
Many firewalls block port 8080 or us it for its own purposes. If FAH has trouble with port 8080, it acts like a browser and expects to be able to use port 80.JimboPalmer wrote:Best of luck with the corporate firewall. Mostly F@H only needs port 8080 open.
Posting a log of failed download attempts will give us a chance to make better recommendations.
I second the recommendation that you get written permission from your employer before using company resources for projects that are not related to corporate goals. You might prepare yourself to make a presentation about how donating to medical research can benefit the company's public image.
Yes, perhaps it is better to leave my work PCs using only the CPU browser-based FAH, rather than installing the application! My work PCs are frequently left rendering 3D animations over the weekends, so the electricity/time for FAH would have been irrelevant, or at least unnoticeable
. The installed FAH has worked perfectly on my home PC, detecting CPU and 2x GPUs. Thanks for your help and advice.
