CPU not running at full
overwatch_fan
Post by overwatch_fan »
I am trying to run folding@home on the full setting but my CPU is only running at 50%? I have no clue how to fix this!
Re: CPU not running at full
We do not know much about your setup, can you post the configuration portion of your log?
viewtopic.php?f=24&t=26036
overwatch_fan
*********************** Log Started 2017-06-11T19:32:33Z ***********************
19:32:33:************************* Folding@home Client *************************
19:32:33: Website: http://folding.stanford.edu/
19:32:33: Copyright: (c) 2009-2014 Stanford University
19:32:33: Author: Joseph Coffland <joseph@cauldrondevelopment.com>
19:32:33: Args: --open-web-control
19:32:33: Config: <none>
19:32:33:******************************** Build ********************************
19:32:33: Version: 7.4.4
19:32:33: Date: Mar 4 2014
19:32:33: Time: 20:26:54
19:32:33: SVN Rev: 4130
19:32:33: Branch: fah/trunk/client
19:32:33: Compiler: Intel(R) C++ MSVC 1500 mode 1200
19:32:33: Options: /TP /nologo /EHa /Qdiag-disable:4297,4103,1786,279 /Ox -arch:SSE
19:32:33: /QaxSSE2,SSE3,SSSE3,SSE4.1,SSE4.2 /Qopenmp /Qrestrict /MT /Qmkl
19:32:33: Platform: win32 XP
19:32:33: Bits: 32
19:32:33: Mode: Release
19:32:33:******************************* System ********************************
19:32:33: CPU: Intel(R) Pentium(R) 4 CPU 3.06GHz
19:32:33: CPU ID: GenuineIntel Family 15 Model 4 Stepping 9
19:32:33: CPUs: 2
19:32:33: Memory: 1.99GiB
19:32:33: Free Memory: 1.62GiB
19:32:33: Threads: WINDOWS_THREADS
19:32:33: OS Version: 5.1
19:32:33: Has Battery: false
19:32:33: On Battery: false
19:32:33: UTC Offset: -5
19:32:33: PID: 3928
19:32:33: CWD: C:/Documents and Settings/Fisher/Application Data/FAHClient
19:32:33: OS: Microsoft Windows XP Service Pack 2
19:32:33: OS Arch: X86
19:32:33: GPUs: 0
19:32:33: CUDA: Not detected
19:32:33:Win32 Service: false
19:32:33:***********************************************************************
If this is your first WU, there is an installer bug that shows up sometimes causing the first WU requested to be for a single CPU thread. That will not be able to change to using both cores. On Full, later WU's should use both.
Also, please confirm the Power Slider was set to FULL at the time the last assignment was downloaded.
overwatch_fan
Ok thanks at running at full now must have been the first wu!
