project:13729 run:57 clone:1 gen:5
davidcoton
Post by davidcoton »
*********************** Log Started 2017-05-23T07:40:58Z ***********************
07:47:12:WU01:FS00:Connecting to 171.67.108.45:8080
07:47:13:WU01:FS00:Assigned to work server 155.247.166.219
07:47:13:WU01:FS00:Requesting new work unit for slot 00: RUNNING cpu:3 from 155.247.166.219
07:47:13:WU01:FS00:Connecting to 155.247.166.219:8080
07:47:15:WU01:FS00:Downloading 338.64KiB
07:47:16:WU01:FS00:Download complete
07:47:16:WU01:FS00:Received Unit: id:01 state:DOWNLOAD error:NO_ERROR project:13729 run:57 clone:1 gen:5 core:0xa7 unit:0x000000050002894b58fd72f51f19a26b
07:53:50:WU01:FS00:Starting
07:53:50:WU01:FS00:Running FahCore: "C:\Program Files\FAHClient/FAHCoreWrapper.exe" C:\Users\David\AppData\Roaming\FAHClient\cores/fahwebx.stanford.edu/cores/Win32/x86/beta/Core_a7.fah/FahCore_a7.exe -dir 01 -suffix 01 -version 704 -lifeline 5420 -checkpoint 5 -np 3
07:53:50:WU01:FS00:Started FahCore on PID 6872
07:53:51:WU01:FS00:Core PID:7644
07:53:51:WU01:FS00:FahCore 0xa7 started
******************************* Date: 2017-05-23 *******************************
16:30:42:WARNING:WU01:FS00:FahCore returned an unknown error code which probably indicates that it crashed
16:30:42:WARNING:WU01:FS00:FahCore returned: UNKNOWN_ENUM (-1073740966 = 0xc000035a)
16:30:42:WU01:FS00:Starting
16:30:42:WU01:FS00:Running FahCore: "C:\Program Files\FAHClient/FAHCoreWrapper.exe" C:\Users\David\AppData\Roaming\FAHClient\cores/fahwebx.stanford.edu/cores/Win32/x86/beta/Core_a7.fah/FahCore_a7.exe -dir 01 -suffix 01 -version 704 -lifeline 5420 -checkpoint 5 -np 3
16:30:42:WU01:FS00:Started FahCore on PID 5948
16:30:42:WU01:FS00:Core PID:6500
16:30:42:WU01:FS00:FahCore 0xa7 started
16:31:37:WU01:FS00:FahCore returned: INTERRUPTED (102 = 0x66)
07:40:58:************************* Folding@home Client *************************
07:40:58:        Website: http://folding.stanford.edu/
07:40:58:      Copyright: (c) 2009-2016 Stanford University
07:40:58:         Author: Joseph Coffland <joseph@cauldrondevelopment.com>
07:40:58:           Args:
07:40:58:         Config: C:\Users\David\AppData\Roaming\FAHClient\config.xml
07:40:58:******************************** Build ********************************
07:40:58:        Version: 7.4.16
07:40:58:           Date: Jan 6 2017
07:40:58:           Time: 00:25:14
07:40:58:     Repository: Git
07:40:58:       Revision: a9e9e27dc2ee6ff01398c439677bc27f6cb74032
07:40:58:         Branch: master
07:40:58:       Compiler: Visual C++ 2008
07:40:58:        Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox -arch:SSE /MT
07:40:58:       Platform: win32 10
07:40:58:           Bits: 32
07:40:58:           Mode: Release
07:40:58:******************************* System ********************************
07:40:58:            CPU: AMD Athlon(tm) II X4 640 Processor
07:40:58:         CPU ID: AuthenticAMD Family 16 Model 5 Stepping 3
07:40:58:           CPUs: 4
07:40:58:         Memory: 3.12GiB
07:40:58:    Free Memory: 1.60GiB
07:40:58:        Threads: WINDOWS_THREADS
07:40:58:     OS Version: 6.0
07:40:58:    Has Battery: false
07:40:58:     On Battery: false
07:40:58:     UTC Offset: 1
07:40:58:            PID: 5420
07:40:58:            CWD: C:\Users\David\AppData\Roaming\FAHClient
07:40:58:             OS: Windows Vista (TM) Home Premium Service Pack 2
07:40:58:        OS Arch: X86
07:40:58:           GPUs: 1
07:40:58:          GPU 0: Bus:1 Slot:0 Func:0 NVIDIA:5 GM204 [GeForce GTX 980] 4612
07:40:58:  CUDA Device 0: Platform:0 Device:0 Bus:1 Slot:0 Compute:5.2 Driver:8.0
07:40:58:OpenCL Device 0: Platform:0 Device:0 Bus:1 Slot:0 Compute:1.2 Driver:365.19
07:40:58:  Win32 Service: false
07:40:58:***********************************************************************
07:40:58:<config>
07:40:58:  <!-- Folding Core -->
07:40:58:  <checkpoint v='5'/>
07:40:58:
07:40:58:  <!-- HTTP Server -->
07:40:58:  <allow v='127.0.0.1 192.168.1.0/24'/>
07:40:58:  <deny v='0.0.0.0/0'/>
07:40:58:  <http-addresses v='127.0.0.1:7396 david-ubuntu:7396'/>
07:40:58:
07:40:58:  <!-- Network -->
07:40:58:  <proxy v=':8080'/>
07:40:58:
07:40:58:  <!-- Remote Command Server -->
07:40:58:  <password v='*******'/>
07:40:58:
07:40:58:  <!-- Slot Control -->
07:40:58:  <power v='full'/>
07:40:58:
07:40:58:  <!-- User Information -->
07:40:58:  <passkey v='********************************'/>
07:40:58:  <user v='davidcoton'/>
07:40:58:
07:40:58:  <!-- Web Server -->
07:40:58:  <web-allow v='127.0.0.1 168.192.1.0/24'/>
07:40:58:
07:40:58:  <!-- Folding Slots -->
07:40:58:  <slot id='0' type='CPU'>
07:40:58:    <client-type v='beta'/>
07:40:58:    <cpus v='3'/>
07:40:58:  </slot>
07:40:58:  <slot id='1' type='GPU'>
07:40:58:  </slot>
07:40:58:</config>
The log stalls after the core starts. No error. At the (normally remote) machine itself, Windows complains about ilbfftw3f-3.dll (Bad Image). Once that is cleared the log gives more info.
Had this a couple of days ago on Project13802 (0,824,69)
Will preserve log and delete work directory to clear, but any suggestions to avoid recurrence welcome.
Re: project:13729 run:57 clone:1 gen:5
If you are a participating member of the beta test team, reeport in the topic for that group of projects - viewtopic.php?f=66&t=29935. Otherwise the best I can suggest is removing the beta setting for client-type.
The version of the A7 core used by beta projects is also in beta test.
davidcoton
Previous report in beta got no response. This project is apparently not in beta, although the version of Core_A7 may be.
Gen 4 was completed on 22nd, but no sign of success for Gen 5 ... I guess something is wrong with this WU :(
I reported it.
