The folding project is such a noble cause.
I am new at this and having a problem for which I need advice.
This workstation is no longer able to get assignment. Unfortunately I am only using cpu slots.
Everthing has been fine until this morning. There are two other identical machines here that are folding normally.
I have reinstalled the client and control packages, and verified settings and config.xml to identical with the other two installations.
Also entering the server urls do direct the browser to the assignment server.
*********************** Log Started 2017-04-28T18:33:41Z ***********************
18:33:41:************************* Folding@home Client *************************
18:33:41: Website: http://folding.stanford.edu/
18:33:41: Copyright: (c) 2009-2014 Stanford University
18:33:41: Author: Joseph Coffland <joseph@cauldrondevelopment.com>
18:33:41: Args:
18:33:41: Config: /home/uno/config.xml
18:33:41:******************************** Build ********************************
18:33:41: Version: 7.4.4
18:33:41: Date: Mar 4 2014
18:33:41: Time: 12:02:38
18:33:41: SVN Rev: 4130
18:33:41: Branch: fah/trunk/client
18:33:41: Compiler: GNU 4.4.7
18:33:41: Options: -std=gnu++98 -O3 -funroll-loops -mfpmath=sse -ffast-math
18:33:41: -fno-unsafe-math-optimizations -msse2
18:33:41: Platform: linux2 3.2.0-1-amd64
18:33:41: Bits: 64
18:33:41: Mode: Release
18:33:41:******************************* System ********************************
18:33:41: CPU: Intel(R) Xeon(R) CPU W3530 @ 2.80GHz
18:33:41: CPU ID: GenuineIntel Family 6 Model 26 Stepping 5
18:33:41: CPUs: 8
18:33:41: Memory: 11.73GiB
18:33:41:Free Memory: 10.85GiB
18:33:41: Threads: POSIX_THREADS
18:33:41: OS Version: 4.4
18:33:41:Has Battery: false
18:33:41: On Battery: false
18:33:41: UTC Offset: -5
18:33:41: PID: 11276
18:33:41: CWD: /home/uno
18:33:41: OS: Linux 4.4.0-72-generic x86_64
18:33:41: OS Arch: AMD64
18:33:41: GPUs: 1
18:33:41: GPU 0: UNSUPPORTED: GT218 [GeForce 210]
18:33:41: CUDA: Not detected
18:33:41:***********************************************************************
18:33:41:<config>
18:33:41: <!-- Network -->
18:33:41: <proxy v=':8080'/>
18:33:41:
18:33:41: <!-- Slot Control -->
18:33:41: <pause-on-battery v='false'/>
18:33:41:
18:33:41: <!-- User Information -->
18:33:41: <passkey v='********************************'/>
18:33:41: <team v='76140'/>
18:33:41: <user v='4mint'/>
18:33:41:
18:33:41: <!-- Folding Slots -->
18:33:41: <slot id='0' type='CPU'/>
18:33:41:</config>
18:33:41:Trying to access database...
18:33:41:Successfully acquired database lock
18:33:41:Enabled folding slot 00: READY cpu:7
18:33:41:WU00:FS00:Connecting to 171.67.108.45:8080
18:33:43:WARNING:WU00:FS00:Failed to get assignment from '171.67.108.45:8080': Empty work server assignment
18:33:43:WU00:FS00:Connecting to 171.64.65.35:80
18:33:45:WARNING:WU00:FS00:Failed to get assignment from '171.64.65.35:80': Empty work server assignment
18:33:45:ERROR:WU00:FS00:Exception: Could not get an assignment
18:33:45:WU00:FS00:Connecting to 171.67.108.45:8080
18:33:46:WARNING:WU00:FS00:Failed to get assignment from '171.67.108.45:8080': Empty work server assignment
18:33:46:WU00:FS00:Connecting to 171.64.65.35:80
18:33:47:WARNING:WU00:FS00:Failed to get assignment from '171.64.65.35:80': Empty work server assignment
18:33:47:ERROR:WU00:FS00:Exception: Could not get an assignment
18:34:45:WU00:FS00:Connecting to 171.67.108.45:8080
18:34:47:WARNING:WU00:FS00:Failed to get assignment from '171.67.108.45:8080': Empty work server assignment
18:34:47:WU00:FS00:Connecting to 171.64.65.35:80
18:34:48:WARNING:WU00:FS00:Failed to get assignment from '171.64.65.35:80': Empty work server assignment
18:34:48:ERROR:WU00:FS00:Exception: Could not get an assignment
18:36:12:FS00:Finishing
18:36:22:WU00:FS00:Connecting to 171.67.108.45:8080
18:36:24:WARNING:WU00:FS00:Failed to get assignment from '171.67.108.45:8080': Empty work server assignment
18:36:24:WU00:FS00:Connecting to 171.64.65.35:80
18:36:25:WARNING:WU00:FS00:Failed to get assignment from '171.64.65.35:80': Empty work server assignment
18:36:25:ERROR:WU00:FS00:Exception: Could not get an assignment
18:38:59:WU00:FS00:Connecting to 171.67.108.45:8080
18:39:01:WARNING:WU00:FS00:Failed to get assignment from '171.67.108.45:8080': Empty work server assignment
18:39:01:WU00:FS00:Connecting to 171.64.65.35:80
18:39:03:WARNING:WU00:FS00:Failed to get assignment from '171.64.65.35:80': Empty work server assignment
18:39:03:ERROR:WU00:FS00:Exception: Could not get an assignment
18:43:14:WU00:FS00:Connecting to 171.67.108.45:8080
18:43:15:WARNING:WU00:FS00:Failed to get assignment from '171.67.108.45:8080': Empty work server assignment
18:43:15:WU00:FS00:Connecting to 171.64.65.35:80
18:43:16:WARNING:WU00:FS00:Failed to get assignment from '171.64.65.35:80': Empty work server assignment
18:43:16:ERROR:WU00:FS00:Exception: Could not get an assignment
18:50:05:WU00:FS00:Connecting to 171.67.108.45:8080
18:50:07:WARNING:WU00:FS00:Failed to get assignment from '171.67.108.45:8080': Empty work server assignment
18:50:07:WU00:FS00:Connecting to 171.64.65.35:80
18:50:09:WARNING:WU00:FS00:Failed to get assignment from '171.64.65.35:80': Empty work server assignment
18:50:09:ERROR:WU00:FS00:Exception: Could not get an assignment
