Hopefully the log is ok this time: (the failed WU is in the second part of the log (next post)
*********************** Log Started 2017-04-21T06:54:30Z ***********************
06:54:30:************************* Folding@home Client *************************
06:54:30: Website: http://folding.stanford.edu/
06:54:30: Copyright: (c) 2009-2014 Stanford University
06:54:30: Author: Joseph Coffland <joseph@cauldrondevelopment.com>
06:54:30: Args:
06:54:30: Config: C:/Users/*garbled*/AppData/Roaming/FAHClient/config.xml
06:54:30:******************************** Build ********************************
06:54:30: Version: 7.4.4
06:54:30: Date: Mar 4 2014
06:54:30: Time: 20:26:54
06:54:30: SVN Rev: 4130
06:54:30: Branch: fah/trunk/client
06:54:30: Compiler: Intel(R) C++ MSVC 1500 mode 1200
06:54:30: Options: /TP /nologo /EHa /Qdiag-disable:4297,4103,1786,279 /Ox -arch:SSE
06:54:30: /QaxSSE2,SSE3,SSSE3,SSE4.1,SSE4.2 /Qopenmp /Qrestrict /MT /Qmkl
06:54:30: Platform: win32 XP
06:54:30: Bits: 32
06:54:30: Mode: Release
06:54:30:******************************* System ********************************
06:54:30: CPU: Intel(R) Core(TM) i5-2500 CPU @ 3.30GHz
06:54:30: CPU ID: GenuineIntel Family 6 Model 42 Stepping 7
06:54:30: CPUs: 4
06:54:30: Memory: 3.96GiB
06:54:30: Free Memory: 2.63GiB
06:54:30: Threads: WINDOWS_THREADS
06:54:30: OS Version: 6.2
06:54:30: Has Battery: false
06:54:30: On Battery: false
06:54:30: UTC Offset: 2
06:54:30: PID: 5852
06:54:30: CWD: C:/Users/*garbled*/AppData/Roaming/FAHClient
06:54:30: OS: Windows 10 Enterprise
06:54:30: OS Arch: AMD64
06:54:30: GPUs: 1
06:54:30: GPU 0: ATI:4 Cedar PRO [Radeon HD 5400/6300/7350/8350]
06:54:30: CUDA: Not detected
06:54:30:Win32 Service: false
06:54:30:***********************************************************************
06:54:30:<config>
06:54:30: <!-- Network -->
06:54:30: <proxy v=':8080'/>
06:54:30:
06:54:30: <!-- Slot Control -->
06:54:30: <power v='FULL'/>
06:54:30:
06:54:30: <!-- User Information -->
06:54:30: <passkey v='********************************'/>
06:54:30: <team v='223518'/>
06:54:30: <user v='--'/>
06:54:30:
06:54:30: <!-- Folding Slots -->
06:54:30: <slot id='0' type='CPU'/>
06:54:30:</config>
06:54:30:Trying to access database...
06:54:34:Successfully acquired database lock
06:54:34:Enabled folding slot 00: READY cpu:4
06:54:36:WU00:FS00:Connecting to 171.67.108.45:8080
06:54:37:WU00:FS00:Assigned to work server 128.252.203.4
06:54:37:WU00:FS00:Requesting new work unit for slot 00: READY cpu:4 from 128.252.203.4
06:54:37:WU00:FS00:Connecting to 128.252.203.4:8080
06:54:38:WU00:FS00:Downloading 1.98MiB
06:54:41:WU00:FS00:Download complete
06:54:41:WU00:FS00:Received Unit: id:00 state:DOWNLOAD error:NO_ERROR project:13803 run:0 clone:717 gen:88 core:0xa7 unit:0x0000006280fccb0458b9a2640915f994
06:54:42:WU00:FS00:Starting
06:54:42:WU00:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:/Users/*garbled*/AppData/Roaming/FAHClient/cores/fahwebx.stanford.edu/cores/Win32/AMD64/AVX/Core_a7.fah/FahCore_a7.exe -dir 00 -suffix 01 -version 704 -lifeline 5852 -checkpoint 15 -np 4
06:54:42:WU00:FS00:Started FahCore on PID 4672
06:54:42:WU00:FS00:Core PID:7424
06:54:42:WU00:FS00:FahCore 0xa7 started
06:54:43:WU00:FS00:0xa7:*********************** Log Started 2017-04-21T06:54:43Z ***********************
06:54:43:WU00:FS00:0xa7:************************** Gromacs Folding@home Core ***************************
06:54:43:WU00:FS00:0xa7: Type: 0xa7
06:54:43:WU00:FS00:0xa7: Core: Gromacs
06:54:43:WU00:FS00:0xa7: Website: http://folding.stanford.edu/
06:54:43:WU00:FS00:0xa7: Copyright: (c) 2009-2016 Stanford University
06:54:43:WU00:FS00:0xa7: Author: Joseph Coffland <joseph@cauldrondevelopment.com>
06:54:43:WU00:FS00:0xa7: Args: -dir 00 -suffix 01 -version 704 -lifeline 4672 -checkpoint 15 -np 4
06:54:43:WU00:FS00:0xa7: Config: <none>
06:54:43:WU00:FS00:0xa7:************************************ Build *************************************
06:54:43:WU00:FS00:0xa7: Version: 0.0.11
06:54:43:WU00:FS00:0xa7: Date: Sep 21 2016
06:54:43:WU00:FS00:0xa7: Time: 01:43:48
06:54:43:WU00:FS00:0xa7: Repository: Git
06:54:43:WU00:FS00:0xa7: Revision: 957bd90e68d95ddcf1594dc15ff6c64cc4555146
06:54:43:WU00:FS00:0xa7: Branch: master
06:54:43:WU00:FS00:0xa7: Compiler: GNU 4.2.1 Compatible Clang 3.9.0 (trunk 274080)
06:54:44:WU00:FS00:0xa7: Options: -std=gnu++98 -O3 -funroll-loops -ffast-math -mfpmath=sse
06:54:44:WU00:FS00:0xa7: -fno-unsafe-math-optimizations -msse2 -I/mingw64/include
06:54:44:WU00:FS00:0xa7: -Wno-inconsistent-dllimport -Wno-parentheses-equality
06:54:44:WU00:FS00:0xa7: -Wno-deprecated-register -Wno-unused-local-typedef
06:54:44:WU00:FS00:0xa7: Platform: linux2 4.6.0-1-amd64
06:54:44:WU00:FS00:0xa7: Bits: 64
06:54:44:WU00:FS00:0xa7: Mode: Release
06:54:44:WU00:FS00:0xa7: SIMD: avx_256
06:54:44:WU00:FS00:0xa7:************************************ System ************************************
06:54:44:WU00:FS00:0xa7: CPU: Intel(R) Core(TM) i5-2500 CPU @ 3.30GHz
06:54:44:WU00:FS00:0xa7: CPU ID: GenuineIntel Family 6 Model 42 Stepping 7
06:54:44:WU00:FS00:0xa7: CPUs: 4
06:54:44:WU00:FS00:0xa7: Memory: 3.96GiB
06:54:44:WU00:FS00:0xa7:Free Memory: 2.56GiB
06:54:44:WU00:FS00:0xa7: Threads: WINDOWS_THREADS
06:54:44:WU00:FS00:0xa7: OS Version: 6.2
06:54:44:WU00:FS00:0xa7:Has Battery: false
06:54:44:WU00:FS00:0xa7: On Battery: false
06:54:44:WU00:FS00:0xa7: UTC Offset: 2
06:54:44:WU00:FS00:0xa7: PID: 7424
06:54:44:WU00:FS00:0xa7: CWD: C:\Users\*garbled*\AppData\Roaming\FAHClient\work
06:54:44:WU00:FS00:0xa7: OS: Windows 10 Enterprise
06:54:44:WU00:FS00:0xa7: OS Arch: AMD64
06:54:44:WU00:FS00:0xa7:********************************************************************************
06:54:44:WU00:FS00:0xa7:Project: 13803 (Run 0, Clone 717, Gen 88)
06:54:44:WU00:FS00:0xa7:Unit: 0x0000006280fccb0458b9a2640915f994
06:54:44:WU00:FS00:0xa7:Reading tar file core.xml
06:54:44:WU00:FS00:0xa7:Reading tar file frame88.tpr
06:54:44:WU00:FS00:0xa7:Digital signatures verified
06:54:44:WU00:FS00:0xa7:Calling: mdrun -s frame88.tpr -o frame88.trr -x frame88.xtc -cpt 15 -nt 4
06:54:44:WU00:FS00:0xa7:Steps: first=22000000 total=250000
06:54:44:WU00:FS00:0xa7:Completed 1 out of 250000 steps (0%)
06:56:06:WU00:FS00:0xa7:Completed 2500 out of 250000 steps (1%)
06:57:25:WU00:FS00:0xa7:Completed 5000 out of 250000 steps (2%)
08:53:33:WU00:FS00:0xa7:Completed 247500 out of 250000 steps (99%)
08:53:34:WU01:FS00:Connecting to 171.67.108.45:8080
08:53:35:WU01:FS00:Assigned to work server 155.247.166.220
08:53:35:WU01:FS00:Requesting new work unit for slot 00: RUNNING cpu:4 from 155.247.166.220
08:53:35:WU01:FS00:Connecting to 155.247.166.220:8080
08:53:36:WU01:FS00:Downloading 333.93KiB
08:53:36:WU01:FS00:Download complete
08:53:36:WU01:FS00:Received Unit: id:01 state:DOWNLOAD error:NO_ERROR project:8656 run:677 clone:0 gen:8 core:0xa4 unit:0x000000080002894c57f133218d02ca18
08:54:44:WU00:FS00:0xa7:Completed 250000 out of 250000 steps (100%)
08:54:45:WU00:FS00:0xa7:Saving result file ..\logfile_01.txt
08:54:45:WU00:FS00:0xa7:Saving result file frame88.trr
08:54:45:WU00:FS00:0xa7:Saving result file frame88.xtc
08:54:45:WU00:FS00:0xa7:Saving result file md.log
08:54:45:WU00:FS00:0xa7:Saving result file science.log
08:54:45:WU00:FS00:0xa7:Folding@home Core Shutdown: FINISHED_UNIT
08:54:45:WU00:FS00:FahCore returned: FINISHED_UNIT (100 = 0x64)
08:54:45:WU00:FS00:Sending unit results: id:00 state:SEND error:NO_ERROR project:13803 run:0 clone:717 gen:88 core:0xa7 unit:0x0000006280fccb0458b9a2640915f994
08:54:45:WU00:FS00:Uploading 2.43MiB to 128.252.203.4
08:54:45:WU01:FS00:Starting
08:54:45:WU00:FS00:Connecting to 128.252.203.4:8080
08:54:45:WU01:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:/Users/*garbled*/AppData/Roaming/FAHClient/cores/fahwebx.stanford.edu/cores/Win32/AMD64/Core_a4.fah/FahCore_a4.exe -dir 01 -suffix 01 -version 704 -lifeline 5852 -checkpoint 15 -np 4
08:54:45:WU01:FS00:Started FahCore on PID 4320
08:54:45:WU01:FS00:Core PID:3528
08:54:45:WU01:FS00:FahCore 0xa4 started
08:54:46:WU01:FS00:0xa4:
08:54:46:WU01:FS00:0xa4:*------------------------------*
08:54:46:WU01:FS00:0xa4:Folding@Home Gromacs GB Core
08:54:46:WU01:FS00:0xa4:Version 2.27 (Dec. 15, 2010)
08:54:46:WU01:FS00:0xa4:Preparing to commence simulation
08:54:46:WU01:FS00:0xa4:- Looking at optimizations...
08:54:46:WU01:FS00:0xa4:- Created dyn
08:54:46:WU01:FS00:0xa4:- Files status OK
08:54:46:WU01:FS00:0xa4:- Expanded 341432 -> 535948 (decompressed 156.9 percent)
08:54:46:WU01:FS00:0xa4:Called DecompressByteArray: compressed_data_size=341432 data_size=535948, decompressed_data_size=535948 diff=0
08:54:46:WU01:FS00:0xa4:- Digital signature verified
08:54:46:WU01:FS00:0xa4:Project: 8656 (Run 677, Clone 0, Gen 8)
08:54:46:WU01:FS00:0xa4:Assembly optimizations on if available.
08:54:46:WU01:FS00:0xa4:Entering M.D.
08:54:47:WU00:FS00:Upload complete
08:54:47:WU00:FS00:Server responded WORK_ACK (400)
08:54:47:WU00:FS00:Final credit estimate, 2776.00 points
08:54:47:WU00:FS00:Cleaning up
08:54:52:WU01:FS00:0xa4:Mapping NT from 4 to 4
08:54:52:WU01:FS00:0xa4:Completed 0 out of 2500000 steps (0%)
08:57:41:WU01:FS00:0xa4:Completed 25000 out of 2500000 steps (1%)
09:00:33:WU01:FS00:0xa4:Completed 50000 out of 2500000 steps (2%)
13:24:25:WU01:FS00:0xa4:Completed 2475000 out of 2500000 steps (99%)
13:24:25:WU00:FS00:Connecting to 171.67.108.45:8080
13:24:26:WU00:FS00:Assigned to work server 155.247.166.219
13:24:26:WU00:FS00:Requesting new work unit for slot 00: RUNNING cpu:4 from 155.247.166.219
13:24:26:WU00:FS00:Connecting to 155.247.166.219:8080
13:24:27:WU00:FS00:Downloading 374.59KiB
13:24:27:WU00:FS00:Download complete
13:24:27:WU00:FS00:Received Unit: id:00 state:DOWNLOAD error:NO_ERROR project:8682 run:80 clone:1 gen:81 core:0xa7 unit:0x0000005a0002894b5826ab496e605273
13:27:07:WU01:FS00:0xa4:Completed 2500000 out of 2500000 steps (100%)
13:27:07:WU01:FS00:0xa4:DynamicWrapper: Finished Work Unit: sleep=10000
13:27:17:WU01:FS00:0xa4:
13:27:17:WU01:FS00:0xa4:Finished Work Unit:
13:27:17:WU01:FS00:0xa4:- Reading up to 1953936 from "01/wudata_01.trr": Read 1953936
13:27:17:WU01:FS00:0xa4:trr file hash check passed.
13:27:17:WU01:FS00:0xa4:- Reading up to 2463484 from "01/wudata_01.xtc": Read 2463484
13:27:17:WU01:FS00:0xa4:xtc file hash check passed.
13:27:17:WU01:FS00:0xa4:edr file hash check passed.
13:27:17:WU01:FS00:0xa4:logfile size: 56363
13:27:17:WU01:FS00:0xa4:Leaving Run
13:27:22:WU01:FS00:0xa4:- Writing 4504343 bytes of core data to disk...
13:27:23:WU01:FS00:0xa4:Done: 4503831 -> 4361605 (compressed to 96.8 percent)
13:27:23:WU01:FS00:0xa4: ... Done.
13:27:23:WU01:FS00:0xa4:- Shutting down core
13:27:23:WU01:FS00:0xa4:Folding@home Core Shutdown: FINISHED_UNIT
13:27:23:WU01:FS00:FahCore returned: FINISHED_UNIT (100 = 0x64)
13:27:24:WU01:FS00:Sending unit results: id:01 state:SEND error:NO_ERROR project:8656 run:677 clone:0 gen:8 core:0xa4 unit:0x000000080002894c57f133218d02ca18
13:27:24:WU01:FS00:Uploading 4.16MiB to 155.247.166.220
13:27:24:WU00:FS00:Starting
13:27:24:WU01:FS00:Connecting to 155.247.166.220:8080
13:27:24:WU00:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:/Users/*garbled*/AppData/Roaming/FAHClient/cores/fahwebx.stanford.edu/cores/Win32/AMD64/AVX/Core_a7.fah/FahCore_a7.exe -dir 00 -suffix 01 -version 704 -lifeline 5852 -checkpoint 15 -np 4
13:27:24:WU00:FS00:Started FahCore on PID 7616
13:27:24:WU00:FS00:Core PID:3908
13:27:24:WU00:FS00:FahCore 0xa7 started
13:27:24:WU00:FS00:0xa7:*********************** Log Started 2017-04-21T13:27:24Z ***********************
13:27:24:WU00:FS00:0xa7:************************** Gromacs Folding@home Core ***************************
13:27:24:WU00:FS00:0xa7: Type: 0xa7
13:27:24:WU00:FS00:0xa7: Core: Gromacs
13:27:24:WU00:FS00:0xa7: Website: http://folding.stanford.edu/
13:27:24:WU00:FS00:0xa7: Copyright: (c) 2009-2016 Stanford University
13:27:24:WU00:FS00:0xa7: Author: Joseph Coffland <joseph@cauldrondevelopment.com>
13:27:24:WU00:FS00:0xa7: Args: -dir 00 -suffix 01 -version 704 -lifeline 7616 -checkpoint 15 -np 4
13:27:24:WU00:FS00:0xa7: Config: <none>
13:27:24:WU00:FS00:0xa7:************************************ Build *************************************
13:27:24:WU00:FS00:0xa7: Version: 0.0.11
13:27:24:WU00:FS00:0xa7: Date: Sep 21 2016
13:27:24:WU00:FS00:0xa7: Time: 01:43:48
13:27:24:WU00:FS00:0xa7: Repository: Git
13:27:24:WU00:FS00:0xa7: Revision: 957bd90e68d95ddcf1594dc15ff6c64cc4555146
13:27:24:WU00:FS00:0xa7: Branch: master
13:27:24:WU00:FS00:0xa7: Compiler: GNU 4.2.1 Compatible Clang 3.9.0 (trunk 274080)
13:27:24:WU00:FS00:0xa7: Options: -std=gnu++98 -O3 -funroll-loops -ffast-math -mfpmath=sse
13:27:24:WU00:FS00:0xa7: -fno-unsafe-math-optimizations -msse2 -I/mingw64/include
13:27:24:WU00:FS00:0xa7: -Wno-inconsistent-dllimport -Wno-parentheses-equality
13:27:24:WU00:FS00:0xa7: -Wno-deprecated-register -Wno-unused-local-typedef
13:27:24:WU00:FS00:0xa7: Platform: linux2 4.6.0-1-amd64
13:27:24:WU00:FS00:0xa7: Bits: 64
13:27:24:WU00:FS00:0xa7: Mode: Release
13:27:24:WU00:FS00:0xa7: SIMD: avx_256
13:27:24:WU00:FS00:0xa7:************************************ System ************************************
13:27:24:WU00:FS00:0xa7: CPU: Intel(R) Core(TM) i5-2500 CPU @ 3.30GHz
13:27:24:WU00:FS00:0xa7: CPU ID: GenuineIntel Family 6 Model 42 Stepping 7
13:27:24:WU00:FS00:0xa7: CPUs: 4
13:27:24:WU00:FS00:0xa7: Memory: 3.96GiB
13:27:24:WU00:FS00:0xa7:Free Memory: 1.58GiB
13:27:24:WU00:FS00:0xa7: Threads: WINDOWS_THREADS
13:27:24:WU00:FS00:0xa7: OS Version: 6.2
13:27:24:WU00:FS00:0xa7:Has Battery: false
13:27:24:WU00:FS00:0xa7: On Battery: false
13:27:24:WU00:FS00:0xa7: UTC Offset: 2
13:27:24:WU00:FS00:0xa7: PID: 3908
13:27:24:WU00:FS00:0xa7: CWD: C:\Users\*garbled*\AppData\Roaming\FAHClient\work
13:27:24:WU00:FS00:0xa7: OS: Windows 10 Enterprise
13:27:24:WU00:FS00:0xa7: OS Arch: AMD64
13:27:24:WU00:FS00:0xa7:********************************************************************************
13:27:24:WU00:FS00:0xa7:Project: 8682 (Run 80, Clone 1, Gen 81)
13:27:24:WU00:FS00:0xa7:Unit: 0x0000005a0002894b5826ab496e605273
13:27:24:WU00:FS00:0xa7:Reading tar file core.xml
13:27:24:WU00:FS00:0xa7:Reading tar file frame81.tpr
13:27:24:WU00:FS00:0xa7:Digital signatures verified
13:27:24:WU00:FS00:0xa7:Calling: mdrun -s frame81.tpr -o frame81.trr -cpt 15 -nt 4
13:27:24:WU00:FS00:0xa7:Steps: first=202500000 total=2500000
13:27:24:WU00:FS00:0xa7:Completed 1 out of 2500000 steps (0%)
13:27:32:WU01:FS00:Upload 4.51%
13:27:33:WU01:FS00:Upload complete
13:27:33:WU01:FS00:Server responded WORK_ACK (400)
13:27:33:WU01:FS00:Final credit estimate, 3153.00 points
13:27:33:WU01:FS00:Cleaning up
13:30:23:WU00:FS00:0xa7:Completed 25000 out of 2500000 steps (1%)
13:33:20:WU00:FS00:0xa7:Completed 50000 out of 2500000 steps (2%)
18:17:12:WU00:FS00:0xa7:Completed 2475000 out of 2500000 steps (99%)
18:17:13:WU01:FS00:Connecting to 171.67.108.45:8080
18:17:14:WU01:FS00:Assigned to work server 128.252.203.4
18:17:14:WU01:FS00:Requesting new work unit for slot 00: RUNNING cpu:4 from 128.252.203.4
18:17:14:WU01:FS00:Connecting to 128.252.203.4:8080
18:17:14:WU01:FS00:Downloading 1.98MiB
18:17:15:WU01:FS00:Download complete
18:17:15:WU01:FS00:Received Unit: id:01 state:DOWNLOAD error:NO_ERROR project:13803 run:0 clone:580 gen:40 core:0xa7 unit:0x0000003080fccb0458b9a267c9b68e04
18:20:09:WU00:FS00:0xa7:Completed 2500000 out of 2500000 steps (100%)
18:20:10:WU00:FS00:0xa7:Saving result file ..\logfile_01.txt
18:20:10:WU00:FS00:0xa7:Saving result file frame81.trr
18:20:10:WU00:FS00:0xa7:Saving result file md.log
18:20:10:WU00:FS00:0xa7:Saving result file science.log
18:20:10:WU00:FS00:0xa7:Saving result file traj_comp.xtc
18:20:10:WU00:FS00:0xa7:Folding@home Core Shutdown: FINISHED_UNIT
18:20:11:WU00:FS00:FahCore returned: FINISHED_UNIT (100 = 0x64)
18:20:11:WU00:FS00:Sending unit results: id:00 state:SEND error:NO_ERROR project:8682 run:80 clone:1 gen:81 core:0xa7 unit:0x0000005a0002894b5826ab496e605273
18:20:11:WU00:FS00:Uploading 4.26MiB to 155.247.166.219
18:20:11:WU00:FS00:Connecting to 155.247.166.219:8080
18:20:11:WU01:FS00:Starting
18:20:11:WU01:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:/Users/*garbled*/AppData/Roaming/FAHClient/cores/fahwebx.stanford.edu/cores/Win32/AMD64/AVX/Core_a7.fah/FahCore_a7.exe -dir 01 -suffix 01 -version 704 -lifeline 5852 -checkpoint 15 -np 4
18:20:11:WU01:FS00:Started FahCore on PID 4528
18:20:11:WU01:FS00:Core PID:7372
18:20:11:WU01:FS00:FahCore 0xa7 started
18:20:12:WU01:FS00:0xa7:*********************** Log Started 2017-04-21T18:20:11Z ***********************
18:20:12:WU01:FS00:0xa7:************************** Gromacs Folding@home Core ***************************
18:20:12:WU01:FS00:0xa7: Type: 0xa7
18:20:12:WU01:FS00:0xa7: Core: Gromacs
18:20:12:WU01:FS00:0xa7: Website: http://folding.stanford.edu/
18:20:12:WU01:FS00:0xa7: Copyright: (c) 2009-2016 Stanford University
18:20:12:WU01:FS00:0xa7: Author: Joseph Coffland <joseph@cauldrondevelopment.com>
18:20:12:WU01:FS00:0xa7: Args: -dir 01 -suffix 01 -version 704 -lifeline 4528 -checkpoint 15 -np 4
18:20:12:WU01:FS00:0xa7: Config: <none>
18:20:12:WU01:FS00:0xa7:************************************ Build *************************************
18:20:12:WU01:FS00:0xa7: Version: 0.0.11
18:20:12:WU01:FS00:0xa7: Date: Sep 21 2016
18:20:12:WU01:FS00:0xa7: Time: 01:43:48
18:20:12:WU01:FS00:0xa7: Repository: Git
18:20:12:WU01:FS00:0xa7: Revision: 957bd90e68d95ddcf1594dc15ff6c64cc4555146
18:20:12:WU01:FS00:0xa7: Branch: master
18:20:12:WU01:FS00:0xa7: Compiler: GNU 4.2.1 Compatible Clang 3.9.0 (trunk 274080)
18:20:12:WU01:FS00:0xa7: Options: -std=gnu++98 -O3 -funroll-loops -ffast-math -mfpmath=sse
18:20:12:WU01:FS00:0xa7: -fno-unsafe-math-optimizations -msse2 -I/mingw64/include
18:20:12:WU01:FS00:0xa7: -Wno-inconsistent-dllimport -Wno-parentheses-equality
18:20:12:WU01:FS00:0xa7: -Wno-deprecated-register -Wno-unused-local-typedef
18:20:12:WU01:FS00:0xa7: Platform: linux2 4.6.0-1-amd64
18:20:12:WU01:FS00:0xa7: Bits: 64
18:20:12:WU01:FS00:0xa7: Mode: Release
18:20:12:WU01:FS00:0xa7: SIMD: avx_256
18:20:12:WU01:FS00:0xa7:************************************ System ************************************
18:20:12:WU01:FS00:0xa7: CPU: Intel(R) Core(TM) i5-2500 CPU @ 3.30GHz
18:20:12:WU01:FS00:0xa7: CPU ID: GenuineIntel Family 6 Model 42 Stepping 7
18:20:12:WU01:FS00:0xa7: CPUs: 4
18:20:12:WU01:FS00:0xa7: Memory: 3.96GiB
18:20:12:WU01:FS00:0xa7:Free Memory: 2.22GiB
18:20:12:WU01:FS00:0xa7: Threads: WINDOWS_THREADS
18:20:12:WU01:FS00:0xa7: OS Version: 6.2
18:20:12:WU01:FS00:0xa7:Has Battery: false
18:20:12:WU01:FS00:0xa7: On Battery: false
18:20:12:WU01:FS00:0xa7: UTC Offset: 2
18:20:12:WU01:FS00:0xa7: PID: 7372
18:20:12:WU01:FS00:0xa7: CWD: C:\Users\*garbled*\AppData\Roaming\FAHClient\work
18:20:12:WU01:FS00:0xa7: OS: Windows 10 Enterprise
18:20:12:WU01:FS00:0xa7: OS Arch: AMD64
18:20:12:WU01:FS00:0xa7:********************************************************************************
18:20:12:WU01:FS00:0xa7:Project: 13803 (Run 0, Clone 580, Gen 40)
18:20:12:WU01:FS00:0xa7:Unit: 0x0000003080fccb0458b9a267c9b68e04
18:20:12:WU01:FS00:0xa7:Reading tar file core.xml
18:20:12:WU01:FS00:0xa7:Reading tar file frame40.tpr
18:20:12:WU01:FS00:0xa7:Digital signatures verified
18:20:12:WU01:FS00:0xa7:Calling: mdrun -s frame40.tpr -o frame40.trr -x frame40.xtc -cpt 15 -nt 4
18:20:12:WU01:FS00:0xa7:Steps: first=10000000 total=250000
18:20:12:WU01:FS00:0xa7:Completed 1 out of 250000 steps (0%)
18:20:13:WU00:FS00:Upload complete
18:20:13:WU00:FS00:Server responded WORK_ACK (400)
18:20:13:WU00:FS00:Final credit estimate, 3035.00 points
18:20:13:WU00:FS00:Cleaning up
18:21:23:WU01:FS00:0xa7:Completed 2500 out of 250000 steps (1%)
18:22:34:WU01:FS00:0xa7:Completed 5000 out of 250000 steps (2%)
20:16:31:WU01:FS00:0xa7:Completed 247500 out of 250000 steps (99%)
20:16:32:WU00:FS00:Connecting to 171.67.108.45:8080
20:16:33:WU00:FS00:Assigned to work server 128.252.203.4
20:16:33:WU00:FS00:Requesting new work unit for slot 00: RUNNING cpu:4 from 128.252.203.4
20:16:33:WU00:FS00:Connecting to 128.252.203.4:8080
20:16:34:WU00:FS00:Downloading 1.98MiB
20:16:36:WU00:FS00:Download complete
20:16:36:WU00:FS00:Received Unit: id:00 state:DOWNLOAD error:NO_ERROR project:13803 run:0 clone:1867 gen:39 core:0xa7 unit:0x0000002f80fccb0458b9a24af638fdd5
20:17:42:WU01:FS00:0xa7:Completed 250000 out of 250000 steps (100%)
20:17:43:WU01:FS00:0xa7:Saving result file ..\logfile_01.txt
20:17:43:WU01:FS00:0xa7:Saving result file frame40.trr
20:17:43:WU01:FS00:0xa7:Saving result file frame40.xtc
20:17:43:WU01:FS00:0xa7:Saving result file md.log
20:17:43:WU01:FS00:0xa7:Saving result file science.log
20:17:43:WU01:FS00:0xa7:Folding@home Core Shutdown: FINISHED_UNIT
20:17:43:WU01:FS00:FahCore returned: FINISHED_UNIT (100 = 0x64)
20:17:43:WU01:FS00:Sending unit results: id:01 state:SEND error:NO_ERROR project:13803 run:0 clone:580 gen:40 core:0xa7 unit:0x0000003080fccb0458b9a267c9b68e04
20:17:43:WU01:FS00:Uploading 2.42MiB to 128.252.203.4
20:17:43:WU01:FS00:Connecting to 128.252.203.4:8080
20:17:43:WU00:FS00:Starting
20:17:43:WU00:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:/Users/*garbled*/AppData/Roaming/FAHClient/cores/fahwebx.stanford.edu/cores/Win32/AMD64/AVX/Core_a7.fah/FahCore_a7.exe -dir 00 -suffix 01 -version 704 -lifeline 5852 -checkpoint 15 -np 4
20:17:43:WU00:FS00:Started FahCore on PID 1976
20:17:43:WU00:FS00:Core PID:1260
20:17:43:WU00:FS00:FahCore 0xa7 started
20:17:44:WU00:FS00:0xa7:*********************** Log Started 2017-04-21T20:17:43Z ***********************
20:17:44:WU00:FS00:0xa7:************************** Gromacs Folding@home Core ***************************
20:17:44:WU00:FS00:0xa7: Type: 0xa7
20:17:44:WU00:FS00:0xa7: Core: Gromacs
20:17:44:WU00:FS00:0xa7: Website: http://folding.stanford.edu/
20:17:44:WU00:FS00:0xa7: Copyright: (c) 2009-2016 Stanford University
20:17:44:WU00:FS00:0xa7: Author: Joseph Coffland <joseph@cauldrondevelopment.com>
20:17:44:WU00:FS00:0xa7: Args: -dir 00 -suffix 01 -version 704 -lifeline 1976 -checkpoint 15 -np 4
20:17:44:WU00:FS00:0xa7: Config: <none>
20:17:44:WU00:FS00:0xa7:************************************ Build *************************************
20:17:44:WU00:FS00:0xa7: Version: 0.0.11
20:17:44:WU00:FS00:0xa7: Date: Sep 21 2016
20:17:44:WU00:FS00:0xa7: Time: 01:43:48
20:17:44:WU00:FS00:0xa7: Repository: Git
20:17:44:WU00:FS00:0xa7: Revision: 957bd90e68d95ddcf1594dc15ff6c64cc4555146
20:17:44:WU00:FS00:0xa7: Branch: master
20:17:44:WU00:FS00:0xa7: Compiler: GNU 4.2.1 Compatible Clang 3.9.0 (trunk 274080)
20:17:44:WU00:FS00:0xa7: Options: -std=gnu++98 -O3 -funroll-loops -ffast-math -mfpmath=sse
20:17:44:WU00:FS00:0xa7: -fno-unsafe-math-optimizations -msse2 -I/mingw64/include
20:17:44:WU00:FS00:0xa7: -Wno-inconsistent-dllimport -Wno-parentheses-equality
20:17:44:WU00:FS00:0xa7: -Wno-deprecated-register -Wno-unused-local-typedef
20:17:44:WU00:FS00:0xa7: Platform: linux2 4.6.0-1-amd64
20:17:44:WU00:FS00:0xa7: Bits: 64
20:17:44:WU00:FS00:0xa7: Mode: Release
20:17:44:WU00:FS00:0xa7: SIMD: avx_256
20:17:44:WU00:FS00:0xa7:************************************ System ************************************
20:17:44:WU00:FS00:0xa7: CPU: Intel(R) Core(TM) i5-2500 CPU @ 3.30GHz
20:17:44:WU00:FS00:0xa7: CPU ID: GenuineIntel Family 6 Model 42 Stepping 7
20:17:44:WU00:FS00:0xa7: CPUs: 4
20:17:44:WU00:FS00:0xa7: Memory: 3.96GiB
20:17:44:WU00:FS00:0xa7:Free Memory: 2.23GiB
20:17:44:WU00:FS00:0xa7: Threads: WINDOWS_THREADS
20:17:44:WU00:FS00:0xa7: OS Version: 6.2
20:17:44:WU00:FS00:0xa7:Has Battery: false
20:17:44:WU00:FS00:0xa7: On Battery: false
20:17:44:WU00:FS00:0xa7: UTC Offset: 2
20:17:44:WU00:FS00:0xa7: PID: 1260
20:17:44:WU00:FS00:0xa7: CWD: C:\Users\*garbled*\AppData\Roaming\FAHClient\work
20:17:44:WU00:FS00:0xa7: OS: Windows 10 Enterprise
20:17:44:WU00:FS00:0xa7: OS Arch: AMD64
20:17:44:WU00:FS00:0xa7:********************************************************************************
20:17:44:WU00:FS00:0xa7:Project: 13803 (Run 0, Clone 1867, Gen 39)
20:17:44:WU00:FS00:0xa7:Unit: 0x0000002f80fccb0458b9a24af638fdd5
20:17:44:WU00:FS00:0xa7:Reading tar file core.xml
20:17:44:WU00:FS00:0xa7:Reading tar file frame39.tpr
20:17:44:WU00:FS00:0xa7:Digital signatures verified
20:17:44:WU00:FS00:0xa7:Calling: mdrun -s frame39.tpr -o frame39.trr -x frame39.xtc -cpt 15 -nt 4
20:17:44:WU00:FS00:0xa7:Steps: first=9750000 total=250000
20:17:45:WU00:FS00:0xa7:Completed 1 out of 250000 steps (0%)
20:17:45:WU01:FS00:Upload complete
20:17:45:WU01:FS00:Server responded WORK_ACK (400)
20:17:45:WU01:FS00:Final credit estimate, 2772.00 points
20:17:45:WU01:FS00:Cleaning up
20:18:56:WU00:FS00:0xa7:Completed 2500 out of 250000 steps (1%)
20:20:07:WU00:FS00:0xa7:Completed 5000 out of 250000 steps (2%)
22:15:47:WU00:FS00:0xa7:Completed 247500 out of 250000 steps (99%)
22:15:48:WU01:FS00:Connecting to 171.67.108.45:8080
22:15:49:WU01:FS00:Assigned to work server 171.67.108.158
22:15:49:WU01:FS00:Requesting new work unit for slot 00: RUNNING cpu:4 from 171.67.108.158
22:15:49:WU01:FS00:Connecting to 171.67.108.158:8080
22:15:50:WU01:FS00:Downloading 807.12KiB
22:15:51:WU01:FS00:Download complete
22:15:51:WU01:FS00:Received Unit: id:01 state:DOWNLOAD error:NO_ERROR project:9038 run:296 clone:0 gen:929 core:0xa4 unit:0x000003f6ab436c9e569829ead4dd949e
22:16:59:WU00:FS00:0xa7:Completed 250000 out of 250000 steps (100%)
22:17:00:WU00:FS00:0xa7:Saving result file ..\logfile_01.txt
22:17:00:WU00:FS00:0xa7:Saving result file frame39.trr
22:17:00:WU00:FS00:0xa7:Saving result file frame39.xtc
22:17:00:WU00:FS00:0xa7:Saving result file md.log
22:17:00:WU00:FS00:0xa7:Saving result file science.log
22:17:00:WU00:FS00:0xa7:Folding@home Core Shutdown: FINISHED_UNIT
22:17:00:WU00:FS00:FahCore returned: FINISHED_UNIT (100 = 0x64)
22:17:00:WU00:FS00:Sending unit results: id:00 state:SEND error:NO_ERROR project:13803 run:0 clone:1867 gen:39 core:0xa7 unit:0x0000002f80fccb0458b9a24af638fdd5
22:17:01:WU00:FS00:Uploading 2.42MiB to 128.252.203.4
22:17:01:WU01:FS00:Starting
22:17:01:WU00:FS00:Connecting to 128.252.203.4:8080
22:17:01:WU01:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:/Users/*garbled*/AppData/Roaming/FAHClient/cores/fahwebx.stanford.edu/cores/Win32/AMD64/Core_a4.fah/FahCore_a4.exe -dir 01 -suffix 01 -version 704 -lifeline 5852 -checkpoint 15 -np 4
22:17:01:WU01:FS00:Started FahCore on PID 2704
22:17:01:WU01:FS00:Core PID:4644
22:17:01:WU01:FS00:FahCore 0xa4 started
22:17:01:WU01:FS00:0xa4:
22:17:01:WU01:FS00:0xa4:*------------------------------*
22:17:01:WU01:FS00:0xa4:Folding@Home Gromacs GB Core
22:17:01:WU01:FS00:0xa4:Version 2.27 (Dec. 15, 2010)
22:17:01:WU01:FS00:0xa4:Preparing to commence simulation
22:17:01:WU01:FS00:0xa4:- Looking at optimizations...
22:17:01:WU01:FS00:0xa4:- Created dyn
22:17:01:WU01:FS00:0xa4:- Files status OK
22:17:01:WU01:FS00:0xa4:- Expanded 825980 -> 1402860 (decompressed 169.8 percent)
22:17:01:WU01:FS00:0xa4:Called DecompressByteArray: compressed_data_size=825980 data_size=1402860, decompressed_data_size=1402860 diff=0
22:17:01:WU01:FS00:0xa4:- Digital signature verified
22:17:01:WU01:FS00:0xa4:Project: 9038 (Run 296, Clone 0, Gen 929)
22:17:01:WU01:FS00:0xa4:Assembly optimizations on if available.
22:17:01:WU01:FS00:0xa4:Entering M.D.
22:17:02:WU00:FS00:Upload complete
22:17:02:WU00:FS00:Server responded WORK_ACK (400)
22:17:02:WU00:FS00:Final credit estimate, 2772.00 points
22:17:02:WU00:FS00:Cleaning up
22:17:07:WU01:FS00:0xa4:Mapping NT from 4 to 4
22:17:07:WU01:FS00:0xa4:Completed 0 out of 250000 steps (0%)
22:18:51:WU01:FS00:0xa4:Completed 2500 out of 250000 steps (1%)
22:20:33:WU01:FS00:0xa4:Completed 5000 out of 250000 steps (2%)
01:07:35:WU01:FS00:0xa4:Completed 247500 out of 250000 steps (99%)
01:07:36:WU00:FS00:Connecting to 171.67.108.45:8080
01:07:37:WU00:FS00:Assigned to work server 155.247.166.219
01:07:37:WU00:FS00:Requesting new work unit for slot 00: RUNNING cpu:4 from 155.247.166.219
01:07:37:WU00:FS00:Connecting to 155.247.166.219:8080
01:07:38:WU00:FS00:Downloading 854.14KiB
01:07:38:WU00:FS00:Download complete
01:07:38:WU00:FS00:Received Unit: id:00 state:DOWNLOAD error:NO_ERROR project:8634 run:0 clone:483 gen:60 core:0xa4 unit:0x0000003e0002894b5820d748cd021cc3
01:09:19:WU01:FS00:0xa4:Completed 250000 out of 250000 steps (100%)
01:09:20:WU01:FS00:0xa4:DynamicWrapper: Finished Work Unit: sleep=10000
01:09:29:WU01:FS00:0xa4:
01:09:29:WU01:FS00:0xa4:Finished Work Unit:
01:09:29:WU01:FS00:0xa4:- Reading up to 811536 from "01/wudata_01.trr": Read 811536
01:09:29:WU01:FS00:0xa4:trr file hash check passed.
01:09:29:WU01:FS00:0xa4:- Reading up to 745904 from "01/wudata_01.xtc": Read 745904
01:09:29:WU01:FS00:0xa4:xtc file hash check passed.
01:09:29:WU01:FS00:0xa4:edr file hash check passed.
01:09:29:WU01:FS00:0xa4:logfile size: 23129
01:09:29:WU01:FS00:0xa4:Leaving Run
01:09:30:WU01:FS00:0xa4:- Writing 1583057 bytes of core data to disk...
01:09:30:WU01:FS00:0xa4:Done: 1582545 -> 1537848 (compressed to 97.1 percent)
01:09:30:WU01:FS00:0xa4: ... Done.
01:09:30:WU01:FS00:0xa4:- Shutting down core
01:09:30:WU01:FS00:0xa4:Folding@home Core Shutdown: FINISHED_UNIT
01:09:31:WU01:FS00:FahCore returned: FINISHED_UNIT (100 = 0x64)
01:09:31:WU01:FS00:Sending unit results: id:01 state:SEND error:NO_ERROR project:9038 run:296 clone:0 gen:929 core:0xa4 unit:0x000003f6ab436c9e569829ead4dd949e
01:09:31:WU01:FS00:Uploading 1.47MiB to 171.67.108.158
01:09:31:WU01:FS00:Connecting to 171.67.108.158:8080
01:09:31:WU00:FS00:Starting
01:09:31:WU00:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:/Users/*garbled*/AppData/Roaming/FAHClient/cores/fahwebx.stanford.edu/cores/Win32/AMD64/Core_a4.fah/FahCore_a4.exe -dir 00 -suffix 01 -version 704 -lifeline 5852 -checkpoint 15 -np 4
01:09:31:WU00:FS00:Started FahCore on PID 1012
01:09:31:WU00:FS00:Core PID:4276
01:09:31:WU00:FS00:FahCore 0xa4 started
01:09:31:WU00:FS00:0xa4:
01:09:31:WU00:FS00:0xa4:*------------------------------*
01:09:31:WU00:FS00:0xa4:Folding@Home Gromacs GB Core
01:09:31:WU00:FS00:0xa4:Version 2.27 (Dec. 15, 2010)
01:09:31:WU00:FS00:0xa4:Preparing to commence simulation
01:09:31:WU00:FS00:0xa4:- Looking at optimizations...
01:09:31:WU00:FS00:0xa4:- Created dyn
01:09:31:WU00:FS00:0xa4:- Files status OK
01:09:31:WU00:FS00:0xa4:- Expanded 874128 -> 2032328 (decompressed 232.4 percent)
01:09:31:WU00:FS00:0xa4:Called DecompressByteArray: compressed_data_size=874128 data_size=2032328, decompressed_data_size=2032328 diff=0
01:09:31:WU00:FS00:0xa4:- Digital signature verified
01:09:31:WU00:FS00:0xa4:Project: 8634 (Run 0, Clone 483, Gen 60)
01:09:31:WU00:FS00:0xa4:Assembly optimizations on if available.
01:09:31:WU00:FS00:0xa4:Entering M.D.
01:09:33:WU01:FS00:Upload complete
01:09:33:WU01:FS00:Server responded WORK_ACK (400)
01:09:33:WU01:FS00:Final credit estimate, 1488.00 points
01:09:33:WU01:FS00:Cleaning up
01:09:37:WU00:FS00:0xa4:Mapping NT from 4 to 4
01:09:37:WU00:FS00:0xa4:Completed 0 out of 1250000 steps (0%)
01:14:15:WU00:FS00:0xa4:Completed 12500 out of 1250000 steps (1%)
01:18:51:WU00:FS00:0xa4:Completed 25000 out of 1250000 steps (2%)
08:46:38:WU00:FS00:0xa4:Completed 1237500 out of 1250000 steps (99%)
08:46:39:WU01:FS00:Connecting to 171.67.108.45:8080
08:46:40:WU01:FS00:Assigned to work server 171.67.108.158
08:46:40:WU01:FS00:Requesting new work unit for slot 00: RUNNING cpu:4 from 171.67.108.158
08:46:40:WU01:FS00:Connecting to 171.67.108.158:8080
08:46:41:WU01:FS00:Downloading 807.17KiB
08:46:44:WU01:FS00:Download complete
08:46:44:WU01:FS00:Received Unit: id:01 state:DOWNLOAD error:NO_ERROR project:9037 run:433 clone:1 gen:1109 core:0xa4 unit:0x000004a6ab436c9e56982b3d4ffab0f2
08:51:15:WU00:FS00:0xa4:Completed 1250000 out of 1250000 steps (100%)
08:51:16:WU00:FS00:0xa4:DynamicWrapper: Finished Work Unit: sleep=10000
08:51:26:WU00:FS00:0xa4:
08:51:26:WU00:FS00:0xa4:Finished Work Unit:
08:51:26:WU00:FS00:0xa4:- Reading up to 3922944 from "00/wudata_01.trr": Read 3922944
08:51:26:WU00:FS00:0xa4:trr file hash check passed.
08:51:26:WU00:FS00:0xa4:- Reading up to 149292 from "00/wudata_01.xtc": Read 149292
08:51:26:WU00:FS00:0xa4:xtc file hash check passed.
08:51:26:WU00:FS00:0xa4:edr file hash check passed.
08:51:26:WU00:FS00:0xa4:logfile size: 37545
08:51:26:WU00:FS00:0xa4:Leaving Run
08:51:29:WU00:FS00:0xa4:- Writing 4129481 bytes of core data to disk...
08:51:30:WU00:FS00:0xa4:Done: 4128969 -> 3374386 (compressed to 81.7 percent)
08:51:30:WU00:FS00:0xa4: ... Done.
08:51:30:WU00:FS00:0xa4:- Shutting down core
08:51:30:WU00:FS00:0xa4:Folding@home Core Shutdown: FINISHED_UNIT
08:51:31:WU00:FS00:FahCore returned: FINISHED_UNIT (100 = 0x64)
08:51:31:WU00:FS00:Sending unit results: id:00 state:SEND error:NO_ERROR project:8634 run:0 clone:483 gen:60 core:0xa4 unit:0x0000003e0002894b5820d748cd021cc3
08:51:31:WU00:FS00:Uploading 3.22MiB to 155.247.166.219
08:51:31:WU01:FS00:Starting
08:51:31:WU00:FS00:Connecting to 155.247.166.219:8080
08:51:31:WU01:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:/Users/*garbled*/AppData/Roaming/FAHClient/cores/fahwebx.stanford.edu/cores/Win32/AMD64/Core_a4.fah/FahCore_a4.exe -dir 01 -suffix 01 -version 704 -lifeline 5852 -checkpoint 15 -np 4
08:51:31:WU01:FS00:Started FahCore on PID 2800
08:51:31:WU01:FS00:Core PID:7128
08:51:31:WU01:FS00:FahCore 0xa4 started
08:51:32:WU01:FS00:0xa4:
08:51:32:WU01:FS00:0xa4:*------------------------------*
08:51:32:WU01:FS00:0xa4:Folding@Home Gromacs GB Core
08:51:32:WU01:FS00:0xa4:Version 2.27 (Dec. 15, 2010)
08:51:32:WU01:FS00:0xa4:Preparing to commence simulation
08:51:32:WU01:FS00:0xa4:- Looking at optimizations...
08:51:32:WU01:FS00:0xa4:- Created dyn
08:51:32:WU01:FS00:0xa4:- Files status OK
08:51:32:WU01:FS00:0xa4:- Expanded 826030 -> 1403472 (decompressed 169.9 percent)
08:51:32:WU01:FS00:0xa4:Called DecompressByteArray: compressed_data_size=826030 data_size=1403472, decompressed_data_size=1403472 diff=0
08:51:32:WU01:FS00:0xa4:- Digital signature verified
08:51:32:WU01:FS00:0xa4:Project: 9037 (Run 433, Clone 1, Gen 1109)
08:51:32:WU01:FS00:0xa4:Assembly optimizations on if available.
08:51:32:WU01:FS00:0xa4:Entering M.D.
08:51:34:WU00:FS00:Upload complete
08:51:34:WU00:FS00:Server responded WORK_ACK (400)
08:51:34:WU00:FS00:Final credit estimate, 4383.00 points
08:51:34:WU00:FS00:Cleaning up
08:51:38:WU01:FS00:0xa4:Mapping NT from 4 to 4
08:51:38:WU01:FS00:0xa4:Completed 0 out of 250000 steps (0%)
08:53:20:WU01:FS00:0xa4:Completed 2500 out of 250000 steps (1%)
08:55:03:WU01:FS00:0xa4:Completed 5000 out of 250000 steps (2%)
11:40:22:WU01:FS00:0xa4:Completed 247500 out of 250000 steps (99%)
11:40:22:WU00:FS00:Connecting to 171.67.108.45:8080
11:40:23:WU00:FS00:Assigned to work server 171.67.108.158
11:40:23:WU00:FS00:Requesting new work unit for slot 00: RUNNING cpu:4 from 171.67.108.158
11:40:23:WU00:FS00:Connecting to 171.67.108.158:8080
11:40:24:WU00:FS00:Downloading 806.85KiB
11:40:25:WU00:FS00:Download complete
11:40:25:WU00:FS00:Received Unit: id:00 state:DOWNLOAD error:NO_ERROR project:9034 run:673 clone:2 gen:898 core:0xa4 unit:0x000003d0ab436c9e56982f7fd477ada6
11:42:04:WU01:FS00:0xa4:Completed 250000 out of 250000 steps (100%)
11:42:05:WU01:FS00:0xa4:DynamicWrapper: Finished Work Unit: sleep=10000
11:42:15:WU01:FS00:0xa4:
11:42:15:WU01:FS00:0xa4:Finished Work Unit:
11:42:15:WU01:FS00:0xa4:- Reading up to 811560 from "01/wudata_01.trr": Read 811560
11:42:15:WU01:FS00:0xa4:trr file hash check passed.
11:42:15:WU01:FS00:0xa4:- Reading up to 745852 from "01/wudata_01.xtc": Read 745852
11:42:15:WU01:FS00:0xa4:xtc file hash check passed.
11:42:15:WU01:FS00:0xa4:edr file hash check passed.
11:42:15:WU01:FS00:0xa4:logfile size: 23134
11:42:15:WU01:FS00:0xa4:Leaving Run
11:42:20:WU01:FS00:0xa4:- Writing 1583034 bytes of core data to disk...
11:42:20:WU01:FS00:0xa4:Done: 1582522 -> 1537568 (compressed to 97.1 percent)
11:42:20:WU01:FS00:0xa4: ... Done.
11:42:21:WU01:FS00:0xa4:- Shutting down core
11:42:21:WU01:FS00:0xa4:Folding@home Core Shutdown: FINISHED_UNIT
11:42:21:WU01:FS00:FahCore returned: FINISHED_UNIT (100 = 0x64)
11:42:21:WU01:FS00:Sending unit results: id:01 state:SEND error:NO_ERROR project:9037 run:433 clone:1 gen:1109 core:0xa4 unit:0x000004a6ab436c9e56982b3d4ffab0f2
11:42:21:WU01:FS00:Uploading 1.47MiB to 171.67.108.158
11:42:21:WU01:FS00:Connecting to 171.67.108.158:8080
11:42:21:WU00:FS00:Starting
11:42:21:WU00:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:/Users/*garbled*/AppData/Roaming/FAHClient/cores/fahwebx.stanford.edu/cores/Win32/AMD64/Core_a4.fah/FahCore_a4.exe -dir 00 -suffix 01 -version 704 -lifeline 5852 -checkpoint 15 -np 4
11:42:21:WU00:FS00:Started FahCore on PID 3872
11:42:21:WU00:FS00:Core PID:6176
11:42:21:WU00:FS00:FahCore 0xa4 started
11:42:22:WU00:FS00:0xa4:
11:42:22:WU00:FS00:0xa4:*------------------------------*
11:42:22:WU00:FS00:0xa4:Folding@Home Gromacs GB Core
11:42:22:WU00:FS00:0xa4:Version 2.27 (Dec. 15, 2010)
11:42:22:WU00:FS00:0xa4:Preparing to commence simulation
11:42:22:WU00:FS00:0xa4:- Looking at optimizations...
11:42:22:WU00:FS00:0xa4:- Created dyn
11:42:22:WU00:FS00:0xa4:- Files status OK
11:42:22:WU00:FS00:0xa4:- Expanded 825703 -> 1401112 (decompressed 169.6 percent)
11:42:22:WU00:FS00:0xa4:Called DecompressByteArray: compressed_data_size=825703 data_size=1401112, decompressed_data_size=1401112 diff=0
11:42:22:WU00:FS00:0xa4:- Digital signature verified
11:42:22:WU00:FS00:0xa4:Project: 9034 (Run 673, Clone 2, Gen 898)
11:42:22:WU00:FS00:0xa4:Assembly optimizations on if available.
11:42:22:WU00:FS00:0xa4:Entering M.D.
11:42:23:WU01:FS00:Upload complete
11:42:23:WU01:FS00:Server responded WORK_ACK (400)
11:42:23:WU01:FS00:Final credit estimate, 1480.00 points
11:42:23:WU01:FS00:Cleaning up
11:42:27:WU00:FS00:0xa4:Mapping NT from 4 to 4
11:42:27:WU00:FS00:0xa4:Completed 0 out of 250000 steps (0%)
11:44:09:WU00:FS00:0xa4:Completed 2500 out of 250000 steps (1%)
11:45:51:WU00:FS00:0xa4:Completed 5000 out of 250000 steps (2%)
14:30:13:WU00:FS00:0xa4:Completed 247500 out of 250000 steps (99%)
14:30:13:WU01:FS00:Connecting to 171.67.108.45:8080
14:30:14:WU01:FS00:Assigned to work server 155.247.166.220
14:30:14:WU01:FS00:Requesting new work unit for slot 00: RUNNING cpu:4 from 155.247.166.220
14:30:14:WU01:FS00:Connecting to 155.247.166.220:8080
14:30:18:WU01:FS00:Downloading 812.01KiB
14:30:19:WU01:FS00:Download complete
14:30:19:WU01:FS00:Received Unit: id:01 state:DOWNLOAD error:NO_ERROR project:8629 run:0 clone:453 gen:20 core:0xa4 unit:0x000000160002894c57e53455d40eb7f2
14:31:54:WU00:FS00:0xa4:Completed 250000 out of 250000 steps (100%)
14:31:54:WU00:FS00:0xa4:DynamicWrapper: Finished Work Unit: sleep=10000
14:32:04:WU00:FS00:0xa4:
14:32:04:WU00:FS00:0xa4:Finished Work Unit:
14:32:04:WU00:FS00:0xa4:- Reading up to 811512 from "00/wudata_01.trr": Read 811512
14:32:04:WU00:FS00:0xa4:trr file hash check passed.
14:32:04:WU00:FS00:0xa4:- Reading up to 745956 from "00/wudata_01.xtc": Read 745956
14:32:04:WU00:FS00:0xa4:xtc file hash check passed.
14:32:04:WU00:FS00:0xa4:edr file hash check passed.
14:32:04:WU00:FS00:0xa4:logfile size: 23129
14:32:04:WU00:FS00:0xa4:Leaving Run
14:32:06:WU00:FS00:0xa4:- Writing 1583085 bytes of core data to disk...
14:32:06:WU00:FS00:0xa4:Done: 1582573 -> 1537697 (compressed to 97.1 percent)
14:32:06:WU00:FS00:0xa4: ... Done.
14:32:07:WU00:FS00:0xa4:- Shutting down core
14:32:07:WU00:FS00:0xa4:Folding@home Core Shutdown: FINISHED_UNIT
14:32:07:WU00:FS00:FahCore returned: FINISHED_UNIT (100 = 0x64)
14:32:07:WU00:FS00:Sending unit results: id:00 state:SEND error:NO_ERROR project:9034 run:673 clone:2 gen:898 core:0xa4 unit:0x000003d0ab436c9e56982f7fd477ada6
14:32:07:WU00:FS00:Uploading 1.47MiB to 171.67.108.158
14:32:07:WU01:FS00:Starting
14:32:07:WU00:FS00:Connecting to 171.67.108.158:8080
14:32:07:WU01:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:/Users/*garbled*/AppData/Roaming/FAHClient/cores/fahwebx.stanford.edu/cores/Win32/AMD64/Core_a4.fah/FahCore_a4.exe -dir 01 -suffix 01 -version 704 -lifeline 5852 -checkpoint 15 -np 4
14:32:07:WU01:FS00:Started FahCore on PID 7516
14:32:07:WU01:FS00:Core PID:6808
14:32:07:WU01:FS00:FahCore 0xa4 started
14:32:08:WU01:FS00:0xa4:
14:32:08:WU01:FS00:0xa4:*------------------------------*
14:32:08:WU01:FS00:0xa4:Folding@Home Gromacs GB Core
14:32:08:WU01:FS00:0xa4:Version 2.27 (Dec. 15, 2010)
14:32:08:WU01:FS00:0xa4:Preparing to commence simulation
14:32:08:WU01:FS00:0xa4:- Looking at optimizations...
14:32:08:WU01:FS00:0xa4:- Created dyn
14:32:08:WU01:FS00:0xa4:- Files status OK
14:32:08:WU01:FS00:0xa4:- Expanded 830991 -> 2144572 (decompressed 258.0 percent)
14:32:08:WU01:FS00:0xa4:Called DecompressByteArray: compressed_data_size=830991 data_size=2144572, decompressed_data_size=2144572 diff=0
14:32:08:WU01:FS00:0xa4:- Digital signature verified
14:32:08:WU01:FS00:0xa4:Project: 8629 (Run 0, Clone 453, Gen 20)
14:32:08:WU01:FS00:0xa4:Assembly optimizations on if available.
14:32:08:WU01:FS00:0xa4:Entering M.D.
14:32:09:WU00:FS00:Upload complete
14:32:09:WU00:FS00:Server responded WORK_ACK (400)
14:32:09:WU00:FS00:Final credit estimate, 1497.00 points
14:32:09:WU00:FS00:Cleaning up
14:32:14:WU01:FS00:0xa4:Mapping NT from 4 to 4
14:32:14:WU01:FS00:0xa4:Completed 0 out of 2500000 steps (0%)
14:40:55:WU01:FS00:0xa4:Completed 25000 out of 2500000 steps (1%)
14:49:40:WU01:FS00:0xa4:Completed 50000 out of 2500000 steps (2%)
04:55:21:WU01:FS00:0xa4:Completed 2475000 out of 2500000 steps (99%)
04:55:22:WU00:FS00:Connecting to 171.67.108.45:8080
04:55:23:WU00:FS00:Assigned to work server 155.247.166.219
04:55:23:WU00:FS00:Requesting new work unit for slot 00: RUNNING cpu:4 from 155.247.166.219
04:55:23:WU00:FS00:Connecting to 155.247.166.219:8080
04:55:24:WU00:FS00:Downloading 859.68KiB
04:55:24:WU00:FS00:Download complete
04:55:25:WU00:FS00:Received Unit: id:00 state:DOWNLOAD error:NO_ERROR project:8637 run:0 clone:22 gen:55 core:0xa4 unit:0x0000003e0002894b582b52f7eea452c7
05:04:04:WU01:FS00:0xa4:Completed 2500000 out of 2500000 steps (100%)
05:04:05:WU01:FS00:0xa4:DynamicWrapper: Finished Work Unit: sleep=10000
05:04:15:WU01:FS00:0xa4:
05:04:15:WU01:FS00:0xa4:Finished Work Unit:
05:04:15:WU01:FS00:0xa4:- Reading up to 5215968 from "01/wudata_01.trr": Read 5215968
05:04:15:WU01:FS00:0xa4:trr file hash check passed.
05:04:15:WU01:FS00:0xa4:- Reading up to 515688 from "01/wudata_01.xtc": Read 515688
05:04:15:WU01:FS00:0xa4:xtc file hash check passed.
05:04:15:WU01:FS00:0xa4:edr file hash check passed.
05:04:15:WU01:FS00:0xa4:logfile size: 57767
05:04:15:WU01:FS00:0xa4:Leaving Run
05:04:15:WU01:FS00:0xa4:- Writing 5827127 bytes of core data to disk...
05:04:16:WU01:FS00:0xa4:Done: 5826615 -> 4943939 (compressed to 84.8 percent)
05:04:16:WU01:FS00:0xa4: ... Done.
05:04:17:WU01:FS00:FahCore returned: FINISHED_UNIT (100 = 0x64)
05:04:17:WU01:FS00:Sending unit results: id:01 state:SEND error:NO_ERROR project:8629 run:0 clone:453 gen:20 core:0xa4 unit:0x000000160002894c57e53455d40eb7f2
05:04:17:WU01:FS00:Uploading 4.72MiB to 155.247.166.220
05:04:17:WU00:FS00:Starting
05:04:17:WU01:FS00:Connecting to 155.247.166.220:8080
05:04:17:WU00:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:/Users/*garbled*/AppData/Roaming/FAHClient/cores/fahwebx.stanford.edu/cores/Win32/AMD64/Core_a4.fah/FahCore_a4.exe -dir 00 -suffix 01 -version 704 -lifeline 5852 -checkpoint 15 -np 4
05:04:17:WU00:FS00:Started FahCore on PID 7872
05:04:17:WU00:FS00:Core PID:3924
05:04:17:WU00:FS00:FahCore 0xa4 started
05:04:18:WU00:FS00:0xa4:
05:04:18:WU00:FS00:0xa4:*------------------------------*
05:04:18:WU00:FS00:0xa4:Folding@Home Gromacs GB Core
05:04:18:WU00:FS00:0xa4:Version 2.27 (Dec. 15, 2010)
05:04:18:WU00:FS00:0xa4:Preparing to commence simulation
05:04:18:WU00:FS00:0xa4:- Looking at optimizations...
05:04:18:WU00:FS00:0xa4:- Created dyn
05:04:18:WU00:FS00:0xa4:- Files status OK
05:04:18:WU00:FS00:0xa4:- Expanded 879801 -> 2055196 (decompressed 233.5 percent)
05:04:18:WU00:FS00:0xa4:Called DecompressByteArray: compressed_data_size=879801 data_size=2055196, decompressed_data_size=2055196 diff=0
05:04:18:WU00:FS00:0xa4:- Digital signature verified
05:04:18:WU00:FS00:0xa4:Project: 8637 (Run 0, Clone 22, Gen 55)
05:04:18:WU00:FS00:0xa4:Assembly optimizations on if available.
05:04:18:WU00:FS00:0xa4:Entering M.D.
05:04:24:WU00:FS00:0xa4:Mapping NT from 4 to 4
05:04:24:WU00:FS00:0xa4:Completed 0 out of 1250000 steps (0%)
05:04:32:WU01:FS00:Upload 3.98%
05:04:55:WU01:FS00:Upload complete
05:04:55:WU01:FS00:Server responded WORK_ACK (400)
05:04:55:WU01:FS00:Final credit estimate, 8281.00 points
05:04:55:WU01:FS00:Cleaning up
05:09:01:WU00:FS00:0xa4:Completed 12500 out of 1250000 steps (1%)
05:13:39:WU00:FS00:0xa4:Completed 25000 out of 1250000 steps (2%)
12:43:33:WU00:FS00:0xa4:Completed 1237500 out of 1250000 steps (99%)
12:43:34:WU01:FS00:Connecting to 171.67.108.45:8080
12:43:35:WU01:FS00:Assigned to work server 171.67.108.101
12:43:35:WU01:FS00:Requesting new work unit for slot 00: RUNNING cpu:4 from 171.67.108.101
12:43:35:WU01:FS00:Connecting to 171.67.108.101:8080
12:43:36:WU01:FS00:Downloading 2.94MiB
12:43:38:WU01:FS00:Download complete
12:43:38:WU01:FS00:Received Unit: id:01 state:DOWNLOAD error:NO_ERROR project:13122 run:75 clone:2 gen:76 core:0xa7 unit:0x0000005cab436c655898cb3ea4b32f4d
12:48:11:WU00:FS00:0xa4:Completed 1250000 out of 1250000 steps (100%)
12:48:12:WU00:FS00:0xa4:DynamicWrapper: Finished Work Unit: sleep=10000
12:48:22:WU00:FS00:0xa4:
12:48:22:WU00:FS00:0xa4:Finished Work Unit:
12:48:22:WU00:FS00:0xa4:- Reading up to 2941128 from "00/wudata_01.trr": Read 2941128
12:48:22:WU00:FS00:0xa4:trr file hash check passed.
12:48:22:WU00:FS00:0xa4:- Reading up to 161436 from "00/wudata_01.xtc": Read 161436
12:48:22:WU00:FS00:0xa4:xtc file hash check passed.
12:48:22:WU00:FS00:0xa4:edr file hash check passed.
12:48:22:WU00:FS00:0xa4:logfile size: 37549
12:48:22:WU00:FS00:0xa4:Leaving Run
12:48:23:WU00:FS00:0xa4:- Writing 3159813 bytes of core data to disk...
12:48:24:WU00:FS00:0xa4:Done: 3159301 -> 2573274 (compressed to 81.4 percent)
12:48:24:WU00:FS00:0xa4: ... Done.
12:48:24:WU00:FS00:0xa4:- Shutting down core
12:48:24:WU00:FS00:0xa4:Folding@home Core Shutdown: FINISHED_UNIT
12:48:25:WU00:FS00:FahCore returned: FINISHED_UNIT (100 = 0x64)
12:48:25:WU00:FS00:Sending unit results: id:00 state:SEND error:NO_ERROR project:8637 run:0 clone:22 gen:55 core:0xa4 unit:0x0000003e0002894b582b52f7eea452c7
12:48:25:WU00:FS00:Uploading 2.45MiB to 155.247.166.219
