thanks for the tip but that doesn't work. I've paused the jobs before and never had to to that but tried just now and the jobs run but the web control still blinks and never loads, so I can't use the web control. jobs run now and you can see the progress in FAH control. But the web page is still unusable. Here's a new log:
*********************** Log Started 2017-04-20T09:49:14Z ***********************
09:49:14:************************* Folding@home Client *************************
09:49:14: Website:
http://folding.stanford.edu/
09:49:14: Copyright: (c) 2009-2014 Stanford University
09:49:14: Author: Joseph Coffland <
joseph@cauldrondevelopment.com>
09:49:14: Args:
09:49:14: Config: C:/Users/Randy/AppData/Roaming/FAHClient/config.xml
09:49:14:******************************** Build ********************************
09:49:14: Version: 7.4.4
09:49:14: Date: Mar 4 2014
09:49:14: Time: 20:26:54
09:49:14: SVN Rev: 4130
09:49:14: Branch: fah/trunk/client
09:49:14: Compiler: Intel(R) C++ MSVC 1500 mode 1200
09:49:14: Options: /TP /nologo /EHa /Qdiag-disable:4297,4103,1786,279 /Ox -arch:SSE
09:49:14: /QaxSSE2,SSE3,SSSE3,SSE4.1,SSE4.2 /Qopenmp /Qrestrict /MT /Qmkl
09:49:14: Platform: win32 XP
09:49:14: Bits: 32
09:49:14: Mode: Release
09:49:14:******************************* System ********************************
09:49:14: CPU: Intel(R) Core(TM) i7 CPU 920 @ 2.67GHz
09:49:14: CPU ID: GenuineIntel Family 6 Model 26 Stepping 5
09:49:14: CPUs: 8
09:49:14: Memory: 5.99GiB
09:49:14: Free Memory: 4.44GiB
09:49:14: Threads: WINDOWS_THREADS
09:49:14: OS Version: 6.2
09:49:14: Has Battery: false
09:49:14: On Battery: false
09:49:14: UTC Offset: -4
09:49:14: PID: 6248
09:49:14: CWD: C:/Users/Randy/AppData/Roaming/FAHClient
09:49:14: OS: Windows 10 Pro
09:49:14: OS Arch: AMD64
09:49:14: GPUs: 1
09:49:14: GPU 0: UNSUPPORTED: RV710 [Radeon HD 4350]
09:49:14: CUDA: Not detected
09:49:14:Win32 Service: false
09:49:14:***********************************************************************
09:49:14:<config>
09:49:14: <!-- Folding Slot Configuration -->
09:49:14: <cause v='ALZHEIMERS'/>
09:49:14:
09:49:14: <!-- Slot Control -->
09:49:14: <power v='light'/>
09:49:14:
09:49:14: <!-- User Information -->
09:49:14: <passkey v='********************************'/>
09:49:14: <team v='446'/>
09:49:14: <user v='RareBear'/>
09:49:14:
09:49:14: <!-- Folding Slots -->
09:49:14: <slot id='0' type='CPU'>
09:49:14: <paused v='true'/>
09:49:14: </slot>
09:49:14:</config>
09:49:14:Trying to access database...
09:49:16:Successfully acquired database lock
09:49:16:Enabled folding slot 00: PAUSED cpu:4 (by user)
10:01:00:Saving configuration to config.xml
10:01:00:<config>
10:01:00: <!-- Folding Slot Configuration -->
10:01:00: <cause v='ALZHEIMERS'/>
10:01:00:
10:01:00: <!-- Network -->
10:01:00: <proxy v=':8080'/>
10:01:00:
10:01:00: <!-- Slot Control -->
10:01:00: <power v='light'/>
10:01:00:
10:01:00: <!-- User Information -->
10:01:00: <passkey v='********************************'/>
10:01:00: <team v='446'/>
10:01:00: <user v='RareBear'/>
10:01:00:
10:01:00: <!-- Folding Slots -->
10:01:00: <slot id='0' type='CPU'>
10:01:00: <paused v='true'/>
10:01:00: </slot>
10:01:00:</config>
10:01:28:Saving configuration to config.xml
10:01:28:<config>
10:01:28: <!-- Folding Slot Configuration -->
10:01:28: <cause v='ALZHEIMERS'/>
10:01:28:
10:01:28: <!-- Network -->
10:01:28: <proxy v=':8080'/>
10:01:28:
10:01:28: <!-- Slot Control -->
10:01:28: <power v='light'/>
10:01:28:
10:01:28: <!-- User Information -->
10:01:28: <passkey v='********************************'/>
10:01:28: <team v='446'/>
10:01:28: <user v='RareBear'/>
10:01:28:
10:01:28: <!-- Folding Slots -->
10:01:28: <slot id='0' type='CPU'>
10:01:28: <paused v='true'/>
10:01:28: </slot>
10:01:28:</config>
******************************* Date: 2017-04-20 *******************************
21:27:53:FS00:Unpaused
21:27:53:WU00:FS00:Starting
21:27:53:WU00:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:/Users/Randy/AppData/Roaming/FAHClient/cores/fahwebx.stanford.edu/cores/Win32/AMD64/Core_a7.fah/FahCore_a7.exe -dir 00 -suffix 01 -version 704 -lifeline 6248 -checkpoint 15 -np 4
21:27:53:WU00:FS00:Started FahCore on PID 8228
21:27:53:WU00:FS00:Core PID:7140
21:27:53:WU00:FS00:FahCore 0xa7 started
21:27:55:WU00:FS00:0xa7:*********************** Log Started 2017-04-20T21:27:54Z ***********************
21:27:55:WU00:FS00:0xa7:************************** Gromacs Folding@home Core ***************************
21:27:55:WU00:FS00:0xa7: Type: 0xa7
21:27:55:WU00:FS00:0xa7: Core: Gromacs
21:27:55:WU00:FS00:0xa7: Website:
21:27:55:WU00:FS00:0xa7: Copyright: (c) 2009-2016 Stanford University
21:27:55:WU00:FS00:0xa7: Author: Joseph Coffland <
21:27:55:WU00:FS00:0xa7: Args: -dir 00 -suffix 01 -version 704 -lifeline 8228 -checkpoint 15 -np 4
21:27:55:WU00:FS00:0xa7: Config: <none>
21:27:55:WU00:FS00:0xa7:************************************ Build *************************************
21:27:55:WU00:FS00:0xa7: Version: 0.0.11
21:27:55:WU00:FS00:0xa7: Date: Sep 21 2016
21:27:55:WU00:FS00:0xa7: Time: 01:53:37
21:27:55:WU00:FS00:0xa7: Repository: Git
21:27:55:WU00:FS00:0xa7: Revision: 957bd90e68d95ddcf1594dc15ff6c64cc4555146
21:27:55:WU00:FS00:0xa7: Branch: master
21:27:55:WU00:FS00:0xa7: Compiler: GNU 4.2.1 Compatible Clang 3.9.0 (trunk 274080)
21:27:55:WU00:FS00:0xa7: Options: -std=gnu++98 -O3 -funroll-loops -ffast-math -mfpmath=sse
21:27:55:WU00:FS00:0xa7: -fno-unsafe-math-optimizations -msse2 -I/mingw64/include
21:27:55:WU00:FS00:0xa7: -Wno-inconsistent-dllimport -Wno-parentheses-equality
21:27:55:WU00:FS00:0xa7: -Wno-deprecated-register -Wno-unused-local-typedef
21:27:55:WU00:FS00:0xa7: Platform: linux2 4.6.0-1-amd64
21:27:55:WU00:FS00:0xa7: Bits: 64
21:27:55:WU00:FS00:0xa7: Mode: Release
21:27:55:WU00:FS00:0xa7: SIMD: sse2
21:27:55:WU00:FS00:0xa7:************************************ System ************************************
21:27:55:WU00:FS00:0xa7: CPU: Intel(R) Core(TM) i7 CPU 920 @ 2.67GHz
21:27:55:WU00:FS00:0xa7: CPU ID: GenuineIntel Family 6 Model 26 Stepping 5
21:27:55:WU00:FS00:0xa7: CPUs: 8
21:27:55:WU00:FS00:0xa7: Memory: 5.99GiB
21:27:55:WU00:FS00:0xa7:Free Memory: 3.37GiB
21:27:55:WU00:FS00:0xa7: Threads: WINDOWS_THREADS
21:27:55:WU00:FS00:0xa7: OS Version: 6.2
21:27:55:WU00:FS00:0xa7:Has Battery: false
21:27:55:WU00:FS00:0xa7: On Battery: false
21:27:55:WU00:FS00:0xa7: UTC Offset: -4
21:27:55:WU00:FS00:0xa7: PID: 7140
21:27:55:WU00:FS00:0xa7: CWD: C:\Users\Randy\AppData\Roaming\FAHClient\work
21:27:55:WU00:FS00:0xa7: OS: Windows 10 Pro
21:27:55:WU00:FS00:0xa7: OS Arch: AMD64
21:27:55:WU00:FS00:0xa7:********************************************************************************
21:27:55:WU00:FS00:0xa7:Project: 13126 (Run 76, Clone 4, Gen 61)
21:27:55:WU00:FS00:0xa7:Unit: 0x0000004aab436c655898c999be4bad71
21:27:55:WU00:FS00:0xa7:Digital signatures verified
21:27:55:WU00:FS00:0xa7:Calling: mdrun -s frame61.tpr -o frame61.trr -cpi state.cpt -cpt 15 -nt 4
21:27:56:WU00:FS00:0xa7:Steps: first=12200000 total=200000
21:27:59:WU00:FS00:0xa7:Completed 2432 out of 200000 steps (1%)
21:28:44:Saving configuration to config.xml
21:28:44:<config>
21:28:44: <!-- Folding Slot Configuration -->
21:28:44: <cause v='ALZHEIMERS'/>
21:28:44:
21:28:44: <!-- Network -->
21:28:44: <proxy v=':8080'/>
21:28:44:
21:28:44: <!-- Slot Control -->
21:28:44: <power v='light'/>
21:28:44:
21:28:44: <!-- User Information -->
21:28:44: <passkey v='********************************'/>
21:28:44: <team v='446'/>
21:28:44: <user v='RareBear'/>
21:28:44:
21:28:44: <!-- Folding Slots -->
21:28:44: <slot id='0' type='CPU'/>
21:28:44:</config>
21:29:11:FS00:Finishing
21:29:57:FS00:Paused
21:29:57:FS00:Shutting core down
21:29:57:WU00:FS00:0xa7:WARNING:Console control signal 1 on PID 7140
21:29:57:WU00:FS00:0xa7:Exiting, please wait. . .
21:29:59:WU00:FS00:0xa7:Folding@home Core Shutdown: INTERRUPTED
21:29:59:WU00:FS00:FahCore returned: INTERRUPTED (102 = 0x66)
21:30:02:FS00:Unpaused
21:30:02:WU00:FS00:Starting
21:30:02:WU00:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:/Users/Randy/AppData/Roaming/FAHClient/cores/fahwebx.stanford.edu/cores/Win32/AMD64/Core_a7.fah/FahCore_a7.exe -dir 00 -suffix 01 -version 704 -lifeline 6248 -checkpoint 15 -np 4
21:30:02:WU00:FS00:Started FahCore on PID 9724
21:30:02:WU00:FS00:Core PID:5612
21:30:02:WU00:FS00:FahCore 0xa7 started
21:30:02:WU00:FS00:0xa7:*********************** Log Started 2017-04-20T21:30:02Z ***********************
21:30:02:WU00:FS00:0xa7:************************** Gromacs Folding@home Core ***************************
21:30:02:WU00:FS00:0xa7: Type: 0xa7
21:30:02:WU00:FS00:0xa7: Core: Gromacs
21:30:02:WU00:FS00:0xa7: Website:
21:30:02:WU00:FS00:0xa7: Copyright: (c) 2009-2016 Stanford University
21:30:02:WU00:FS00:0xa7: Author: Joseph Coffland <
21:30:02:WU00:FS00:0xa7: Args: -dir 00 -suffix 01 -version 704 -lifeline 9724 -checkpoint 15 -np 4
21:30:02:WU00:FS00:0xa7: Config: <none>
21:30:02:WU00:FS00:0xa7:************************************ Build *************************************
21:30:02:WU00:FS00:0xa7: Version: 0.0.11
21:30:02:WU00:FS00:0xa7: Date: Sep 21 2016
21:30:02:WU00:FS00:0xa7: Time: 01:53:37
21:30:02:WU00:FS00:0xa7: Repository: Git
21:30:02:WU00:FS00:0xa7: Revision: 957bd90e68d95ddcf1594dc15ff6c64cc4555146
21:30:02:WU00:FS00:0xa7: Branch: master
21:30:02:WU00:FS00:0xa7: Compiler: GNU 4.2.1 Compatible Clang 3.9.0 (trunk 274080)
21:30:02:WU00:FS00:0xa7: Options: -std=gnu++98 -O3 -funroll-loops -ffast-math -mfpmath=sse
21:30:02:WU00:FS00:0xa7: -fno-unsafe-math-optimizations -msse2 -I/mingw64/include
21:30:02:WU00:FS00:0xa7: -Wno-inconsistent-dllimport -Wno-parentheses-equality
21:30:02:WU00:FS00:0xa7: -Wno-deprecated-register -Wno-unused-local-typedef
21:30:02:WU00:FS00:0xa7: Platform: linux2 4.6.0-1-amd64
21:30:02:WU00:FS00:0xa7: Bits: 64
21:30:02:WU00:FS00:0xa7: Mode: Release
21:30:02:WU00:FS00:0xa7: SIMD: sse2
21:30:02:WU00:FS00:0xa7:************************************ System ************************************
21:30:02:WU00:FS00:0xa7: CPU: Intel(R) Core(TM) i7 CPU 920 @ 2.67GHz
21:30:02:WU00:FS00:0xa7: CPU ID: GenuineIntel Family 6 Model 26 Stepping 5
21:30:02:WU00:FS00:0xa7: CPUs: 8
21:30:02:WU00:FS00:0xa7: Memory: 5.99GiB
21:30:02:WU00:FS00:0xa7:Free Memory: 3.33GiB
21:30:02:WU00:FS00:0xa7: Threads: WINDOWS_THREADS
21:30:02:WU00:FS00:0xa7: OS Version: 6.2
21:30:02:WU00:FS00:0xa7:Has Battery: false
21:30:02:WU00:FS00:0xa7: On Battery: false
21:30:02:WU00:FS00:0xa7: UTC Offset: -4
21:30:02:WU00:FS00:0xa7: PID: 5612
21:30:02:WU00:FS00:0xa7: CWD: C:\Users\Randy\AppData\Roaming\FAHClient\work
21:30:02:WU00:FS00:0xa7: OS: Windows 10 Pro
21:30:02:WU00:FS00:0xa7: OS Arch: AMD64
21:30:02:WU00:FS00:0xa7:********************************************************************************
21:30:02:WU00:FS00:0xa7:Project: 13126 (Run 76, Clone 4, Gen 61)
21:30:02:WU00:FS00:0xa7:Unit: 0x0000004aab436c655898c999be4bad71
21:30:02:WU00:FS00:0xa7:Digital signatures verified
21:30:02:WU00:FS00:0xa7:Calling: mdrun -s frame61.tpr -o frame61.trr -cpi state.cpt -cpt 15 -nt 4
21:30:03:WU00:FS00:0xa7:Steps: first=12200000 total=200000
21:30:05:WU00:FS00:0xa7:Completed 3482 out of 200000 steps (1%)
21:31:04:WU00:FS00:0xa7:Completed 4000 out of 200000 steps (2%)
