New rig troubles
BlueboyX
New rig troubles
Post by BlueboyX »
Hi,
I have been folding for quite some time under the name BlueboyX. I recently started testing a new rig that has a xeon processor and two factory overclocked GTX 1080 Ti under the screenname BlueboyX_ALL_12tANB2SnTk8367ri9zfR5rG2jnzpbbH8q. That has over 700 work units completed with the new passkey for this screenname, so I should be getting the bonus. I keep getting about 800k ppd with this card and I have seen screenshots online with people getting more like 1.2 - 1.5 million ppd with each of these cards. I have F@H set to full, but my GPU load seems to jump around a lot, from the 60's to 99%. This is using a new windows 10 pro 64 bit install.
Aorus GTX 1080 Ti
Aorus GTX 1080 Ti Xtreme (with a PCIe riser - will try removing this card completely to see if it makes a difference)
Intel Xeon E5-2683 V3
ASUS X99-E WS/USB 3.1 LGA 2011-v3 Intel X99 SATA 6Gb/s USB 3.1 USB 3.0 CEB Intel Motherboard
G.SKILL Ripjaws V Series (2x4GB) DDR4 3200
Anyone have any ideas? Or need more info?
*********************** Log Started 2017-04-08T02:46:26Z ***********************
02:46:26:************************* Folding@home Client *************************
02:46:26:      Website: http://folding.stanford.edu/
02:46:26:    Copyright: (c) 2009-2014 Stanford University
02:46:26:       Author: Joseph Coffland <joseph@cauldrondevelopment.com>
02:46:26:         Args:
02:46:26:       Config: C:/Users/Cerebro/AppData/Roaming/FAHClient/config.xml
02:46:26:******************************** Build ********************************
02:46:26:      Version: 7.4.4
02:46:26:         Date: Mar 4 2014
02:46:26:         Time: 20:26:54
02:46:26:      SVN Rev: 4130
02:46:26:       Branch: fah/trunk/client
02:46:26:     Compiler: Intel(R) C++ MSVC 1500 mode 1200
02:46:26:      Options: /TP /nologo /EHa /Qdiag-disable:4297,4103,1786,279 /Ox -arch:SSE
02:46:26:               /QaxSSE2,SSE3,SSSE3,SSE4.1,SSE4.2 /Qopenmp /Qrestrict /MT /Qmkl
02:46:26:     Platform: win32 XP
02:46:26:         Bits: 32
02:46:26:         Mode: Release
02:46:26:******************************* System ********************************
02:46:26:          CPU: Intel(R) Xeon(R) CPU E5-2683 v3 @ 2.00GHz
02:46:26:       CPU ID: GenuineIntel Family 6 Model 63 Stepping 2
02:46:26:         CPUs: 28
02:46:26:       Memory: 7.91GiB
02:46:26:  Free Memory: 6.46GiB
02:46:26:      Threads: WINDOWS_THREADS
02:46:26:   OS Version: 6.2
02:46:26:  Has Battery: false
02:46:26:   On Battery: false
02:46:26:   UTC Offset: -4
02:46:26:          PID: 808
02:46:26:          CWD: C:/Users/Cerebro/AppData/Roaming/FAHClient
02:46:26:           OS: Windows 10 Pro
02:46:26:      OS Arch: AMD64
02:46:26:         GPUs: 2
02:46:26:        GPU 0: NVIDIA:5 GP102 [GeForce GTX 1080 Ti]
02:46:26:        GPU 1: NVIDIA:5 GP102 [GeForce GTX 1080 Ti]
02:46:26:         CUDA: 6.1
02:46:26:  CUDA Driver: 8000
02:46:26:Win32 Service: false
02:46:26:***********************************************************************
02:46:26:<config>
02:46:26:  <!-- Network -->
02:46:26:  <proxy v=':8080'/>
02:46:26:
02:46:26:  <!-- Slot Control -->
02:46:26:  <power v='FULL'/>
02:46:26:
02:46:26:  <!-- User Information -->
02:46:26:  <passkey v='********************************'/>
02:46:26:  <team v='224497'/>
02:46:26:  <user v='BlueboyX_ALL_12tANB2SnTk8367ri9zfR5rG2jnzpbbH8q'/>
02:46:26:
02:46:26:  <!-- Folding Slots -->
02:46:26:  <slot id='0' type='CPU'>
02:46:26:    <cpus v='20'/>
02:46:26:  </slot>
02:46:26:  <slot id='1' type='GPU'>
02:46:26:    <gpu-index v='0'/>
02:46:26:  </slot>
02:46:26:  <slot id='2' type='GPU'/>
02:46:26:</config>
02:46:26:Trying to access database...
02:46:26:Successfully acquired database lock
02:46:26:Enabled folding slot 00: READY cpu:20
02:46:26:Enabled folding slot 01: READY gpu:0:GP102 [GeForce GTX 1080 Ti]
02:46:26:Enabled folding slot 02: READY gpu:1:GP102 [GeForce GTX 1080 Ti]
02:46:27:WU00:FS00:Connecting to 171.67.108.45:8080
02:46:27:WU01:FS01:Connecting to 171.67.108.45:80
02:46:27:WU02:FS02:Connecting to 171.67.108.45:80
02:46:27:WU00:FS00:Assigned to work server 171.67.108.101
02:46:27:WU00:FS00:Requesting new work unit for slot 00: READY cpu:20 from 171.67.108.101
02:46:27:WU01:FS01:Assigned to work server 171.64.65.84
02:46:27:WU00:FS00:Connecting to 171.67.108.101:8080
02:46:27:WU01:FS01:Requesting new work unit for slot 01: READY gpu:0:GP102 [GeForce GTX 1080 Ti] from 171.64.65.84
02:46:27:WU02:FS02:Assigned to work server 171.64.65.84
02:46:27:WU01:FS01:Connecting to 171.64.65.84:8080
02:46:27:WU02:FS02:Requesting new work unit for slot 02: READY gpu:1:GP102 [GeForce GTX 1080 Ti] from 171.64.65.84
02:46:27:WU02:FS02:Connecting to 171.64.65.84:8080
02:46:28:WU02:FS02:Downloading 2.58MiB
02:46:28:WU01:FS01:Downloading 3.36MiB
02:46:29:WU00:FS00:Downloading 2.94MiB
02:46:30:WU02:FS02:Download complete
02:46:30:WU02:FS02:Received Unit: id:02 state:DOWNLOAD error:NO_ERROR project:9189 run:0 clone:20 gen:349 core:0x21 unit:0x000001ebab40415457cb2b9cee5a38ee
02:46:30:WU02:FS02:Starting
02:46:30:WU02:FS02:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:/Users/Cerebro/AppData/Roaming/FAHClient/cores/fahwebx.stanford.edu/cores/Win32/AMD64/NVIDIA/Fermi/Core_21.fah/FahCore_21.exe -dir 02 -suffix 01 -version 704 -lifeline 808 -checkpoint 15 -gpu 1 -gpu-vendor nvidia
02:46:30:WU02:FS02:Started FahCore on PID 7436
02:46:30:WU02:FS02:Core PID:7260
02:46:30:WU02:FS02:FahCore 0x21 started
02:46:30:WU01:FS01:Download complete
02:46:30:WU00:FS00:Download complete
02:46:31:WU01:FS01:Received Unit: id:01 state:DOWNLOAD error:NO_ERROR project:9192 run:0 clone:93 gen:350 core:0x21 unit:0x000001ecab40415457cb2d2fb2c246c1
02:46:31:WU01:FS01:Starting
02:46:31:WU01:FS01:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:/Users/Cerebro/AppData/Roaming/FAHClient/cores/fahwebx.stanford.edu/cores/Win32/AMD64/NVIDIA/Fermi/Core_21.fah/FahCore_21.exe -dir 01 -suffix 01 -version 704 -lifeline 808 -checkpoint 15 -gpu 0 -gpu-vendor nvidia
02:46:31:WU01:FS01:Started FahCore on PID 7360
02:46:31:WU01:FS01:Core PID:7356
02:46:31:WU01:FS01:FahCore 0x21 started
02:46:31:WU00:FS00:Received Unit: id:00 state:DOWNLOAD error:NO_ERROR project:13127 run:80 clone:5 gen:81 core:0xa7 unit:0x00000065ab436c655898c9289c1b7441
02:46:31:WU00:FS00:Starting
02:46:31:WU00:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:/Users/Cerebro/AppData/Roaming/FAHClient/cores/fahwebx.stanford.edu/cores/Win32/AMD64/AVX/Core_a7.fah/FahCore_a7.exe -dir 00 -suffix 01 -version 704 -lifeline 808 -checkpoint 15 -np 20
02:46:31:WU00:FS00:Started FahCore on PID 7308
02:46:31:WU00:FS00:Core PID:7252
02:46:31:WU00:FS00:FahCore 0xa7 started
02:46:32:WU02:FS02:0x21:*********************** Log Started 2017-04-08T02:46:32Z ***********************
02:46:32:WU02:FS02:0x21:Project: 9189 (Run 0, Clone 20, Gen 349)
02:46:32:WU02:FS02:0x21:Unit: 0x000001ebab40415457cb2b9cee5a38ee
02:46:32:WU02:FS02:0x21:CPU: 0x00000000000000000000000000000000
02:46:32:WU02:FS02:0x21:Machine: 2
02:46:32:WU02:FS02:0x21:Reading tar file core.xml
02:46:32:WU02:FS02:0x21:Reading tar file system.xml
02:46:32:WU02:FS02:0x21:Reading tar file integrator.xml
02:46:32:WU02:FS02:0x21:Reading tar file state.xml
02:46:33:WU01:FS01:0x21:*********************** Log Started 2017-04-08T02:46:32Z ***********************
02:46:33:WU01:FS01:0x21:Project: 9192 (Run 0, Clone 93, Gen 350)
02:46:33:WU01:FS01:0x21:Unit: 0x000001ecab40415457cb2d2fb2c246c1
02:46:33:WU01:FS01:0x21:CPU: 0x00000000000000000000000000000000
02:46:33:WU01:FS01:0x21:Machine: 1
02:46:33:WU01:FS01:0x21:Reading tar file core.xml
02:46:33:WU01:FS01:0x21:Reading tar file system.xml
02:46:33:WU01:FS01:0x21:Reading tar file integrator.xml
02:46:33:WU01:FS01:0x21:Reading tar file state.xml
02:46:33:WU02:FS02:0x21:Digital signatures verified
02:46:33:WU02:FS02:0x21:Folding@home GPU Core21 Folding@home Core
02:46:33:WU02:FS02:0x21:Version 0.0.18
02:46:33:WU00:FS00:0xa7:*********************** Log Started 2017-04-08T02:46:33Z ***********************
02:46:33:WU00:FS00:0xa7:************************** Gromacs Folding@home Core ***************************
02:46:33:WU00:FS00:0xa7:       Type: 0xa7
02:46:33:WU00:FS00:0xa7:       Core: Gromacs
02:46:33:WU00:FS00:0xa7:    Website: http://folding.stanford.edu/
02:46:33:WU00:FS00:0xa7:  Copyright: (c) 2009-2016 Stanford University
02:46:33:WU00:FS00:0xa7:     Author: Joseph Coffland <joseph@cauldrondevelopment.com>
02:46:33:WU00:FS00:0xa7:       Args: -dir 00 -suffix 01 -version 704 -lifeline 7308 -checkpoint 15 -np
02:46:33:WU00:FS00:0xa7:             20
02:46:33:WU00:FS00:0xa7:     Config: <none>
02:46:33:WU00:FS00:0xa7:************************************ Build *************************************
02:46:33:WU00:FS00:0xa7:    Version: 0.0.11
02:46:33:WU00:FS00:0xa7:       Date: Sep 21 2016
02:46:33:WU00:FS00:0xa7:       Time: 01:43:48
02:46:33:WU00:FS00:0xa7: Repository: Git
02:46:33:WU00:FS00:0xa7:   Revision: 957bd90e68d95ddcf1594dc15ff6c64cc4555146
02:46:33:WU00:FS00:0xa7:     Branch: master
02:46:33:WU00:FS00:0xa7:   Compiler: GNU 4.2.1 Compatible Clang 3.9.0 (trunk 274080)
02:46:33:WU00:FS00:0xa7:    Options: -std=gnu++98 -O3 -funroll-loops -ffast-math -mfpmath=sse
02:46:33:WU00:FS00:0xa7:             -fno-unsafe-math-optimizations -msse2 -I/mingw64/include
02:46:33:WU00:FS00:0xa7:             -Wno-inconsistent-dllimport -Wno-parentheses-equality
02:46:33:WU00:FS00:0xa7:             -Wno-deprecated-register -Wno-unused-local-typedef
02:46:33:WU00:FS00:0xa7:   Platform: linux2 4.6.0-1-amd64
02:46:33:WU00:FS00:0xa7:       Bits: 64
02:46:33:WU00:FS00:0xa7:       Mode: Release
02:46:33:WU00:FS00:0xa7:       SIMD: avx_256
02:46:33:WU00:FS00:0xa7:************************************ System ************************************
02:46:33:WU00:FS00:0xa7:        CPU: Intel(R) Xeon(R) CPU E5-2683 v3 @ 2.00GHz
02:46:33:WU00:FS00:0xa7:     CPU ID: GenuineIntel Family 6 Model 63 Stepping 2
02:46:33:WU00:FS00:0xa7:       CPUs: 28
02:46:33:WU00:FS00:0xa7:     Memory: 7.91GiB
02:46:33:WU00:FS00:0xa7:Free Memory: 6.29GiB
02:46:33:WU00:FS00:0xa7:    Threads: WINDOWS_THREADS
02:46:33:WU00:FS00:0xa7: OS Version: 6.2
02:46:33:WU00:FS00:0xa7:Has Battery: false
02:46:33:WU00:FS00:0xa7: On Battery: false
02:46:33:WU00:FS00:0xa7: UTC Offset: -4
02:46:33:WU00:FS00:0xa7:        PID: 7252
02:46:33:WU00:FS00:0xa7:        CWD: C:\Users\Cerebro\AppData\Roaming\FAHClient\work
02:46:33:WU00:FS00:0xa7:         OS: Windows 10 Pro
02:46:33:WU00:FS00:0xa7:    OS Arch: AMD64
02:46:33:WU00:FS00:0xa7:********************************************************************************
02:46:33:WU00:FS00:0xa7:Project: 13127 (Run 80, Clone 5, Gen 81)
02:46:33:WU00:FS00:0xa7:Unit: 0x00000065ab436c655898c9289c1b7441
02:46:33:WU00:FS00:0xa7:Reading tar file core.xml
02:46:33:WU00:FS00:0xa7:Reading tar file frame81.tpr
02:46:33:WU00:FS00:0xa7:Digital signatures verified
02:46:33:WU00:FS00:0xa7:Calling: mdrun -s frame81.tpr -o frame81.trr -cpt 15 -nt 20
02:46:34:WU01:FS01:0x21:Digital signatures verified
02:46:34:WU01:FS01:0x21:Folding@home GPU Core21 Folding@home Core
02:46:34:WU01:FS01:0x21:Version 0.0.18
02:46:36:WU00:FS00:0xa7:Steps: first=16200000 total=200000
02:46:39:WU00:FS00:0xa7:Completed 1 out of 200000 steps (0%)
02:46:44:WU02:FS02:0x21:Completed 0 out of 2500000 steps (0%)
02:46:44:WU02:FS02:0x21:Temperature control disabled. Requirements: single Nvidia GPU, tmax must be < 110 and twait >= 900
02:46:48:WU01:FS01:0x21:Completed 0 out of 2500000 steps (0%)
02:46:48:WU01:FS01:0x21:Temperature control disabled. Requirements: single Nvidia GPU, tmax must be < 110 and twait >= 900
02:47:20:WU02:FS02:0x21:Completed 25000 out of 2500000 steps (1%)
02:47:48:WU01:FS01:0x21:Completed 25000 out of 2500000 steps (1%)
02:47:57:WU02:FS02:0x21:Completed 50000 out of 2500000 steps (2%)
02:48:03:WU00:FS00:0xa7:Completed 2000 out of 200000 steps (1%)
02:48:33:WU02:FS02:0x21:Completed 75000 out of 2500000 steps (3%)
02:48:47:WU01:FS01:0x21:Completed 50000 out of 2500000 steps (2%)
02:49:10:WU02:FS02:0x21:Completed 100000 out of 2500000 steps (4%)
02:49:27:WU00:FS00:0xa7:Completed 4000 out of 200000 steps (2%)
02:49:47:WU01:FS01:0x21:Completed 75000 out of 2500000 steps (3%)
02:49:49:WU02:FS02:0x21:Completed 125000 out of 2500000 steps (5%)
02:50:26:WU02:FS02:0x21:Completed 150000 out of 2500000 steps (6%)
02:50:47:WU01:FS01:0x21:Completed 100000 out of 2500000 steps (4%)
02:50:50:WU00:FS00:0xa7:Completed 6000 out of 200000 steps (3%)
02:51:03:WU02:FS02:0x21:Completed 175000 out of 2500000 steps (7%)
02:51:40:WU02:FS02:0x21:Completed 200000 out of 2500000 steps (8%)
02:51:52:WU01:FS01:0x21:Completed 125000 out of 2500000 steps (5%)
02:52:15:WU00:FS00:0xa7:Completed 8000 out of 200000 steps (4%)
02:52:20:WU02:FS02:0x21:Completed 225000 out of 2500000 steps (9%)
02:52:52:WU01:FS01:0x21:Completed 150000 out of 2500000 steps (6%)
02:52:57:WU02:FS02:0x21:Completed 250000 out of 2500000 steps (10%)
02:53:34:WU02:FS02:0x21:Completed 275000 out of 2500000 steps (11%)
02:53:39:WU00:FS00:0xa7:Completed 10000 out of 200000 steps (5%)
02:53:52:WU01:FS01:0x21:Completed 175000 out of 2500000 steps (7%)
02:54:11:WU02:FS02:0x21:Completed 300000 out of 2500000 steps (12%)
02:54:51:WU02:FS02:0x21:Completed 325000 out of 2500000 steps (13%)
02:54:52:WU01:FS01:0x21:Completed 200000 out of 2500000 steps (8%)
02:55:03:WU00:FS00:0xa7:Completed 12000 out of 200000 steps (6%)
02:55:27:WU02:FS02:0x21:Completed 350000 out of 2500000 steps (14%)
02:55:57:WU01:FS01:0x21:Completed 225000 out of 2500000 steps (9%)
02:56:04:WU02:FS02:0x21:Completed 375000 out of 2500000 steps (15%)
02:56:28:WU00:FS00:0xa7:Completed 14000 out of 200000 steps (7%)
02:56:41:WU02:FS02:0x21:Completed 400000 out of 2500000 steps (16%)
02:56:57:WU01:FS01:0x21:Completed 250000 out of 2500000 steps (10%)
02:57:21:WU02:FS02:0x21:Completed 425000 out of 2500000 steps (17%)
02:57:53:WU00:FS00:0xa7:Completed 16000 out of 200000 steps (8%)
02:57:57:WU01:FS01:0x21:Completed 275000 out of 2500000 steps (11%)
02:57:58:WU02:FS02:0x21:Completed 450000 out of 2500000 steps (18%)
02:58:35:WU02:FS02:0x21:Completed 475000 out of 2500000 steps (19%)
02:58:58:WU01:FS01:0x21:Completed 300000 out of 2500000 steps (12%)
02:59:12:WU02:FS02:0x21:Completed 500000 out of 2500000 steps (20%)
02:59:18:WU00:FS00:0xa7:Completed 18000 out of 200000 steps (9%)
02:59:52:WU02:FS02:0x21:Completed 525000 out of 2500000 steps (21%)
03:00:02:WU01:FS01:0x21:Completed 325000 out of 2500000 steps (13%)
03:00:29:WU02:FS02:0x21:Completed 550000 out of 2500000 steps (22%)
03:00:44:WU00:FS00:0xa7:Completed 20000 out of 200000 steps (10%)
03:01:02:WU01:FS01:0x21:Completed 350000 out of 2500000 steps (14%)
03:01:06:WU02:FS02:0x21:Completed 575000 out of 2500000 steps (23%)
03:01:42:WU02:FS02:0x21:Completed 600000 out of 2500000 steps (24%)
03:02:03:WU01:FS01:0x21:Completed 375000 out of 2500000 steps (15%)
03:02:12:WU00:FS00:0xa7:Completed 22000 out of 200000 steps (11%)
03:02:22:WU02:FS02:0x21:Completed 625000 out of 2500000 steps (25%)
03:02:59:WU02:FS02:0x21:Completed 650000 out of 2500000 steps (26%)
03:03:03:WU01:FS01:0x21:Completed 400000 out of 2500000 steps (16%)
03:03:36:WU02:FS02:0x21:Completed 675000 out of 2500000 steps (27%)
03:03:38:WU00:FS00:0xa7:Completed 24000 out of 200000 steps (12%)
03:04:08:WU01:FS01:0x21:Completed 425000 out of 2500000 steps (17%)
03:04:13:WU02:FS02:0x21:Completed 700000 out of 2500000 steps (28%)
03:04:53:WU02:FS02:0x21:Completed 725000 out of 2500000 steps (29%)
03:05:02:WU00:FS00:0xa7:Completed 26000 out of 200000 steps (13%)
03:05:09:WU01:FS01:0x21:Completed 450000 out of 2500000 steps (18%)
03:05:30:WU02:FS02:0x21:Completed 750000 out of 2500000 steps (30%)
03:06:07:WU02:FS02:0x21:Completed 775000 out of 2500000 steps (31%)
03:06:09:WU01:FS01:0x21:Completed 475000 out of 2500000 steps (19%)
03:06:29:WU00:FS00:0xa7:Completed 28000 out of 200000 steps (14%)
03:06:44:WU02:FS02:0x21:Completed 800000 out of 2500000 steps (32%)
03:07:09:WU01:FS01:0x21:Completed 500000 out of 2500000 steps (20%)
03:07:24:WU02:FS02:0x21:Completed 825000 out of 2500000 steps (33%)
03:07:54:WU00:FS00:0xa7:Completed 30000 out of 200000 steps (15%)
03:08:01:WU02:FS02:0x21:Completed 850000 out of 2500000 steps (34%)
03:08:13:WU01:FS01:0x21:Completed 525000 out of 2500000 steps (21%)
03:08:38:WU02:FS02:0x21:Completed 875000 out of 2500000 steps (35%)
03:09:14:WU01:FS01:0x21:Completed 550000 out of 2500000 steps (22%)
03:09:15:WU02:FS02:0x21:Completed 900000 out of 2500000 steps (36%)
03:09:21:WU00:FS00:0xa7:Completed 32000 out of 200000 steps (16%)
03:09:54:WU02:FS02:0x21:Completed 925000 out of 2500000 steps (37%)
03:10:14:WU01:FS01:0x21:Completed 575000 out of 2500000 steps (23%)
03:10:31:WU02:FS02:0x21:Completed 950000 out of 2500000 steps (38%)
03:10:50:WU00:FS00:0xa7:Completed 34000 out of 200000 steps (17%)
03:11:08:WU02:FS02:0x21:Completed 975000 out of 2500000 steps (39%)
03:11:14:WU01:FS01:0x21:Completed 600000 out of 2500000 steps (24%)
03:11:45:WU02:FS02:0x21:Completed 1000000 out of 2500000 steps (40%)
03:12:18:WU00:FS00:0xa7:Completed 36000 out of 200000 steps (18%)
03:12:19:WU01:FS01:0x21:Completed 625000 out of 2500000 steps (25%)
03:12:25:WU02:FS02:0x21:Completed 1025000 out of 2500000 steps (41%)
03:13:02:WU02:FS02:0x21:Completed 1050000 out of 2500000 steps (42%)
03:13:19:WU01:FS01:0x21:Completed 650000 out of 2500000 steps (26%)
03:13:38:WU02:FS02:0x21:Completed 1075000 out of 2500000 steps (43%)
03:13:48:WU00:FS00:0xa7:Completed 38000 out of 200000 steps (19%)
03:14:15:WU02:FS02:0x21:Completed 1100000 out of 2500000 steps (44%)
03:14:19:WU01:FS01:0x21:Completed 675000 out of 2500000 steps (27%)
03:14:55:WU02:FS02:0x21:Completed 1125000 out of 2500000 steps (45%)
03:15:17:WU00:FS00:0xa7:Completed 40000 out of 200000 steps (20%)
03:15:19:WU01:FS01:0x21:Completed 700000 out of 2500000 steps (28%)
03:15:31:WU02:FS02:0x21:Completed 1150000 out of 2500000 steps (46%)
03:16:08:WU02:FS02:0x21:Completed 1175000 out of 2500000 steps (47%)
03:16:23:WU01:FS01:0x21:Completed 725000 out of 2500000 steps (29%)
03:16:45:WU02:FS02:0x21:Completed 1200000 out of 2500000 steps (48%)
03:16:53:WU00:FS00:0xa7:Completed 42000 out of 200000 steps (21%)
03:17:23:WU01:FS01:0x21:Completed 750000 out of 2500000 steps (30%)
03:17:25:WU02:FS02:0x21:Completed 1225000 out of 2500000 steps (49%)
03:18:02:WU02:FS02:0x21:Completed 1250000 out of 2500000 steps (50%)
03:18:23:WU01:FS01:0x21:Completed 775000 out of 2500000 steps (31%)
03:18:24:WU00:FS00:0xa7:Completed 44000 out of 200000 steps (22%)
03:18:38:WU02:FS02:0x21:Completed 1275000 out of 2500000 steps (51%)
03:19:15:WU02:FS02:0x21:Completed 1300000 out of 2500000 steps (52%)
03:19:24:WU01:FS01:0x21:Completed 800000 out of 2500000 steps (32%)
03:19:54:WU00:FS00:0xa7:Completed 46000 out of 200000 steps (23%)
03:19:55:WU02:FS02:0x21:Completed 1325000 out of 2500000 steps (53%)
03:20:28:WU01:FS01:0x21:Completed 825000 out of 2500000 steps (33%)
03:20:32:WU02:FS02:0x21:Completed 1350000 out of 2500000 steps (54%)
03:21:09:WU02:FS02:0x21:Completed 1375000 out of 2500000 steps (55%)
03:21:28:WU00:FS00:0xa7:Completed 48000 out of 200000 steps (24%)
03:21:28:WU01:FS01:0x21:Completed 850000 out of 2500000 steps (34%)
03:21:45:WU02:FS02:0x21:Completed 1400000 out of 2500000 steps (56%)
03:22:26:WU02:FS02:0x21:Completed 1425000 out of 2500000 steps (57%)
03:22:28:WU01:FS01:0x21:Completed 875000 out of 2500000 steps (35%)
03:23:00:WU00:FS00:0xa7:Completed 50000 out of 200000 steps (25%)
03:23:02:WU02:FS02:0x21:Completed 1450000 out of 2500000 steps (58%)
03:23:28:WU01:FS01:0x21:Completed 900000 out of 2500000 steps (36%)
03:23:39:WU02:FS02:0x21:Completed 1475000 out of 2500000 steps (59%)
03:24:16:WU02:FS02:0x21:Completed 1500000 out of 2500000 steps (60%)
03:24:33:WU01:FS01:0x21:Completed 925000 out of 2500000 steps (37%)
03:24:35:WU00:FS00:0xa7:Completed 52000 out of 200000 steps (26%)
03:24:56:WU02:FS02:0x21:Completed 1525000 out of 2500000 steps (61%)
03:25:33:WU02:FS02:0x21:Completed 1550000 out of 2500000 steps (62%)
03:25:33:WU01:FS01:0x21:Completed 950000 out of 2500000 steps (38%)
03:26:09:WU00:FS00:0xa7:Completed 54000 out of 200000 steps (27%)
03:26:09:WU02:FS02:0x21:Completed 1575000 out of 2500000 steps (63%)
03:26:33:WU01:FS01:0x21:Completed 975000 out of 2500000 steps (39%)
03:26:47:WU02:FS02:0x21:Completed 1600000 out of 2500000 steps (64%)
03:27:27:WU02:FS02:0x21:Completed 1625000 out of 2500000 steps (65%)
03:27:34:WU01:FS01:0x21:Completed 1000000 out of 2500000 steps (40%)
03:27:44:WU00:FS00:0xa7:Completed 56000 out of 200000 steps (28%)
03:28:03:WU02:FS02:0x21:Completed 1650000 out of 2500000 steps (66%)
03:28:38:WU01:FS01:0x21:Completed 1025000 out of 2500000 steps (41%)
03:28:40:WU02:FS02:0x21:Completed 1675000 out of 2500000 steps (67%)
03:29:16:WU00:FS00:0xa7:Completed 58000 out of 200000 steps (29%)
03:29:17:WU02:FS02:0x21:Completed 1700000 out of 2500000 steps (68%)
03:29:39:WU01:FS01:0x21:Completed 1050000 out of 2500000 steps (42%)
03:29:57:WU02:FS02:0x21:Completed 1725000 out of 2500000 steps (69%)
03:30:34:WU02:FS02:0x21:Completed 1750000 out of 2500000 steps (70%)
03:30:39:WU01:FS01:0x21:Completed 1075000 out of 2500000 steps (43%)
03:30:48:WU00:FS00:0xa7:Completed 60000 out of 200000 steps (30%)
03:31:11:WU02:FS02:0x21:Completed 1775000 out of 2500000 steps (71%)
03:31:39:WU01:FS01:0x21:Completed 1100000 out of 2500000 steps (44%)
03:31:47:WU02:FS02:0x21:Completed 1800000 out of 2500000 steps (72%)
03:32:20:WU00:FS00:0xa7:Completed 62000 out of 200000 steps (31%)
03:32:27:WU02:FS02:0x21:Completed 1825000 out of 2500000 steps (73%)
03:32:44:WU01:FS01:0x21:Completed 1125000 out of 2500000 steps (45%)
03:33:04:WU02:FS02:0x21:Completed 1850000 out of 2500000 steps (74%)
03:33:41:WU02:FS02:0x21:Completed 1875000 out of 2500000 steps (75%)
03:33:44:WU01:FS01:0x21:Completed 1150000 out of 2500000 steps (46%)
03:33:53:WU00:FS00:0xa7:Completed 64000 out of 200000 steps (32%)
03:34:18:WU02:FS02:0x21:Completed 1900000 out of 2500000 steps (76%)
03:34:44:WU01:FS01:0x21:Completed 1175000 out of 2500000 steps (47%)
03:34:58:WU02:FS02:0x21:Completed 1925000 out of 2500000 steps (77%)
03:35:25:WU00:FS00:0xa7:Completed 66000 out of 200000 steps (33%)
03:35:34:WU02:FS02:0x21:Completed 1950000 out of 2500000 steps (78%)
03:35:44:WU01:FS01:0x21:Completed 1200000 out of 2500000 steps (48%)
03:36:11:WU02:FS02:0x21:Completed 1975000 out of 2500000 steps (79%)
03:36:48:WU02:FS02:0x21:Completed 2000000 out of 2500000 steps (80%)
03:36:49:WU01:FS01:0x21:Completed 1225000 out of 2500000 steps (49%)
03:36:58:WU00:FS00:0xa7:Completed 68000 out of 200000 steps (34%)
03:37:28:WU02:FS02:0x21:Completed 2025000 out of 2500000 steps (81%)
03:37:49:WU01:FS01:0x21:Completed 1250000 out of 2500000 steps (50%)
03:38:05:WU02:FS02:0x21:Completed 2050000 out of 2500000 steps (82%)
03:38:29:WU00:FS00:0xa7:Completed 70000 out of 200000 steps (35%)
03:38:42:WU02:FS02:0x21:Completed 2075000 out of 2500000 steps (83%)
03:38:49:WU01:FS01:0x21:Completed 1275000 out of 2500000 steps (51%)
03:39:19:WU02:FS02:0x21:Completed 2100000 out of 2500000 steps (84%)
03:39:50:WU01:FS01:0x21:Completed 1300000 out of 2500000 steps (52%)
03:39:58:WU02:FS02:0x21:Completed 2125000 out of 2500000 steps (85%)
03:40:00:WU00:FS00:0xa7:Completed 72000 out of 200000 steps (36%)
03:40:35:WU02:FS02:0x21:Completed 2150000 out of 2500000 steps (86%)
03:40:54:WU01:FS01:0x21:Completed 1325000 out of 2500000 steps (53%)
03:41:12:WU02:FS02:0x21:Completed 2175000 out of 2500000 steps (87%)
03:41:30:WU00:FS00:0xa7:Completed 74000 out of 200000 steps (37%)
03:41:49:WU02:FS02:0x21:Completed 2200000 out of 2500000 steps (88%)
03:41:54:WU01:FS01:0x21:Completed 1350000 out of 2500000 steps (54%)
03:42:29:WU02:FS02:0x21:Completed 2225000 out of 2500000 steps (89%)
03:42:55:WU01:FS01:0x21:Completed 1375000 out of 2500000 steps (55%)
03:42:58:WU00:FS00:0xa7:Completed 76000 out of 200000 steps (38%)
03:43:06:WU02:FS02:0x21:Completed 2250000 out of 2500000 steps (90%)
03:43:42:WU02:FS02:0x21:Completed 2275000 out of 2500000 steps (91%)
03:43:55:WU01:FS01:0x21:Completed 1400000 out of 2500000 steps (56%)
03:44:19:WU02:FS02:0x21:Completed 2300000 out of 2500000 steps (92%)
03:44:27:WU00:FS00:0xa7:Completed 78000 out of 200000 steps (39%)
03:44:59:WU01:FS01:0x21:Completed 1425000 out of 2500000 steps (57%)
03:44:59:WU02:FS02:0x21:Completed 2325000 out of 2500000 steps (93%)
03:45:36:WU02:FS02:0x21:Completed 2350000 out of 2500000 steps (94%)
03:45:57:WU00:FS00:0xa7:Completed 80000 out of 200000 steps (40%)
03:45:59:WU01:FS01:0x21:Completed 1450000 out of 2500000 steps (58%)
03:46:13:WU02:FS02:0x21:Completed 2375000 out of 2500000 steps (95%)
03:46:50:WU02:FS02:0x21:Completed 2400000 out of 2500000 steps (96%)
03:46:59:WU01:FS01:0x21:Completed 1475000 out of 2500000 steps (59%)
03:47:29:WU00:FS00:0xa7:Completed 82000 out of 200000 steps (41%)
03:47:29:WU02:FS02:0x21:Completed 2425000 out of 2500000 steps (97%)
03:48:00:WU01:FS01:0x21:Completed 1500000 out of 2500000 steps (60%)
03:48:06:WU02:FS02:0x21:Completed 2450000 out of 2500000 steps (98%)
03:48:43:WU02:FS02:0x21:Completed 2475000 out of 2500000 steps (99%)
03:48:44:WU03:FS02:Connecting to 171.67.108.45:80
03:48:44:WU03:FS02:Assigned to work server 171.64.65.84
03:48:44:WU03:FS02:Requesting new work unit for slot 02: RUNNING gpu:1:GP102 [GeForce GTX 1080 Ti] from 171.64.65.84
03:48:44:WU03:FS02:Connecting to 171.64.65.84:8080
03:48:45:ERROR:WU03:FS02:Exception: Server did not assign work unit
03:48:45:WU03:FS02:Connecting to 171.67.108.45:80
03:48:46:WU03:FS02:Assigned to work server 140.163.4.245
03:48:46:WU03:FS02:Requesting new work unit for slot 02: RUNNING gpu:1:GP102 [GeForce GTX 1080 Ti] from 140.163.4.245
03:48:46:WU03:FS02:Connecting to 140.163.4.245:8080
03:48:46:WU03:FS02:Downloading 14.50MiB
03:48:47:WU03:FS02:Download complete
03:48:48:WU03:FS02:Received Unit: id:03 state:DOWNLOAD error:NO_ERROR project:10496 run:47 clone:75 gen:5 core:0x21 unit:0x000000098ca304f558896373c7c94ec1
03:48:59:WU00:FS00:0xa7:Completed 84000 out of 200000 steps (42%)
03:49:04:WU01:FS01:0x21:Completed 1525000 out of 2500000 steps (61%)
03:49:20:WU02:FS02:0x21:Completed 2500000 out of 2500000 steps (100%)
03:49:23:WU02:FS02:0x21:Saving result file logfile_01.txt
03:49:23:WU02:FS02:0x21:Saving result file checkpointState.xml
03:49:25:WU02:FS02:0x21:Saving result file checkpt.crc
03:49:25:WU02:FS02:0x21:Saving result file log.txt
03:49:25:WU02:FS02:0x21:Saving result file positions.xtc
03:49:26:WU02:FS02:0x21:Folding@home Core Shutdown: FINISHED_UNIT
03:49:27:WU02:FS02:FahCore returned: FINISHED_UNIT (100 = 0x64)
03:49:27:WU02:FS02:Sending unit results: id:02 state:SEND error:NO_ERROR project:9189 run:0 clone:20 gen:349 core:0x21 unit:0x000001ebab40415457cb2b9cee5a38ee
03:49:27:WU02:FS02:Uploading 4.77MiB to 171.64.65.84
03:49:27:WU02:FS02:Connecting to 171.64.65.84:8080
03:49:27:WU03:FS02:Starting
03:49:27:WU03:FS02:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:/Users/Cerebro/AppData/Roaming/FAHClient/cores/fahwebx.stanford.edu/cores/Win32/AMD64/NVIDIA/Fermi/Core_21.fah/FahCore_21.exe -dir 03 -suffix 01 -version 704 -lifeline 808 -checkpoint 15 -gpu 1 -gpu-vendor nvidia
03:49:27:WU03:FS02:Started FahCore on PID 960
03:49:27:WU03:FS02:Core PID:9080
03:49:27:WU03:FS02:FahCore 0x21 started
03:49:33:WU02:FS02:Upload 77.33%
03:49:35:WU03:FS02:0x21:*********************** Log Started 2017-04-08T03:49:34Z ***********************
03:49:35:WU03:FS02:0x21:Project: 10496 (Run 47, Clone 75, Gen 5)
03:49:35:WU03:FS02:0x21:Unit: 0x000000098ca304f558896373c7c94ec1
03:49:35:WU03:FS02:0x21:CPU: 0x00000000000000000000000000000000
03:49:35:WU03:FS02:0x21:Machine: 2
03:49:35:WU03:FS02:0x21:Reading tar file core.xml
03:49:35:WU03:FS02:0x21:Reading tar file system.xml
03:49:38:WU02:FS02:Upload complete
03:49:38:WU02:FS02:Server responded WORK_ACK (400)
03:49:38:WU02:FS02:Final credit estimate, 43150.00 points
03:49:38:WU02:FS02:Cleaning up
03:49:39:WU03:FS02:0x21:Reading tar file integrator.xml
03:49:39:WU03:FS02:0x21:Reading tar file state.xml
03:49:45:WU03:FS02:0x21:Digital signatures verified
03:49:45:WU03:FS02:0x21:Folding@home GPU Core21 Folding@home Core
03:49:45:WU03:FS02:0x21:Version 0.0.18
03:50:04:WU01:FS01:0x21:Completed 1550000 out of 2500000 steps (62%)
03:50:28:WU00:FS00:0xa7:Completed 86000 out of 200000 steps (43%)
03:50:45:WU03:FS02:0x21:Completed 0 out of 2000000 steps (0%)
03:50:45:WU03:FS02:0x21:Temperature control disabled. Requirements: single Nvidia GPU, tmax must be < 110 and twait >= 900
03:51:04:WU01:FS01:0x21:Completed 1575000 out of 2500000 steps (63%)
03:51:55:WU00:FS00:0xa7:Completed 88000 out of 200000 steps (44%)
03:52:04:WU01:FS01:0x21:Completed 1600000 out of 2500000 steps (64%)
03:52:23:WU03:FS02:0x21:Completed 20000 out of 2000000 steps (1%)
03:53:09:WU01:FS01:0x21:Completed 1625000 out of 2500000 steps (65%)
03:53:24:WU00:FS00:0xa7:Completed 90000 out of 200000 steps (45%)
03:54:00:WU03:FS02:0x21:Completed 40000 out of 2000000 steps (2%)
03:54:09:WU01:FS01:0x21:Completed 1650000 out of 2500000 steps (66%)
03:54:52:WU00:FS00:0xa7:Completed 92000 out of 200000 steps (46%)
03:55:10:WU01:FS01:0x21:Completed 1675000 out of 2500000 steps (67%)
03:55:37:WU03:FS02:0x21:Completed 60000 out of 2000000 steps (3%)
03:56:10:WU01:FS01:0x21:Completed 1700000 out of 2500000 steps (68%)
03:56:20:WU00:FS00:0xa7:Completed 94000 out of 200000 steps (47%)
03:57:14:WU03:FS02:0x21:Completed 80000 out of 2000000 steps (4%)
03:57:15:WU01:FS01:0x21:Completed 1725000 out of 2500000 steps (69%)
03:57:49:WU00:FS00:0xa7:Completed 96000 out of 200000 steps (48%)
03:58:15:WU01:FS01:0x21:Completed 1750000 out of 2500000 steps (70%)
03:58:51:WU03:FS02:0x21:Completed 100000 out of 2000000 steps (5%)
03:59:16:WU01:FS01:0x21:Completed 1775000 out of 2500000 steps (71%)
03:59:18:WU00:FS00:0xa7:Completed 98000 out of 200000 steps (49%)
04:00:16:WU01:FS01:0x21:Completed 1800000 out of 2500000 steps (72%)
04:00:28:WU03:FS02:0x21:Completed 120000 out of 2000000 steps (6%)
04:00:47:WU00:FS00:0xa7:Completed 100000 out of 200000 steps (50%)
04:01:21:WU01:FS01:0x21:Completed 1825000 out of 2500000 steps (73%)
04:02:21:WU00:FS00:0xa7:Completed 102000 out of 200000 steps (51%)
04:02:21:WU01:FS01:0x21:Completed 1850000 out of 2500000 steps (74%)
04:02:23:WU03:FS02:0x21:Completed 140000 out of 2000000 steps (7%)
04:03:22:WU01:FS01:0x21:Completed 1875000 out of 2500000 steps (75%)
04:03:49:WU00:FS00:0xa7:Completed 104000 out of 200000 steps (52%)
04:04:00:WU03:FS02:0x21:Completed 160000 out of 2000000 steps (8%)
04:04:22:WU01:FS01:0x21:Completed 1900000 out of 2500000 steps (76%)
04:05:18:WU00:FS00:0xa7:Completed 106000 out of 200000 steps (53%)
04:05:27:WU01:FS01:0x21:Completed 1925000 out of 2500000 steps (77%)
04:05:37:WU03:FS02:0x21:Completed 180000 out of 2000000 steps (9%)
04:06:27:WU01:FS01:0x21:Completed 1950000 out of 2500000 steps (78%)
04:06:45:WU00:FS00:0xa7:Completed 108000 out of 200000 steps (54%)
04:07:14:WU03:FS02:0x21:Completed 200000 out of 2000000 steps (10%)
04:07:27:WU01:FS01:0x21:Completed 1975000 out of 2500000 steps (79%)
04:08:14:WU00:FS00:0xa7:Completed 110000 out of 200000 steps (55%)
04:08:28:WU01:FS01:0x21:Completed 2000000 out of 2500000 steps (80%)
04:08:51:WU03:FS02:0x21:Completed 220000 out of 2000000 steps (11%)
04:09:33:WU01:FS01:0x21:Completed 2025000 out of 2500000 steps (81%)
04:09:42:WU00:FS00:0xa7:Completed 112000 out of 200000 steps (56%)
04:10:28:WU03:FS02:0x21:Completed 240000 out of 2000000 steps (12%)
04:10:33:WU01:FS01:0x21:Completed 2050000 out of 2500000 steps (82%)
04:11:10:WU00:FS00:0xa7:Completed 114000 out of 200000 steps (57%)
04:11:33:WU01:FS01:0x21:Completed 2075000 out of 2500000 steps (83%)
04:12:20:WU03:FS02:0x21:Completed 260000 out of 2000000 steps (13%)
04:12:34:WU01:FS01:0x21:Completed 2100000 out of 2500000 steps (84%)
04:12:39:WU00:FS00:0xa7:Completed 116000 out of 200000 steps (58%)
04:13:38:WU01:FS01:0x21:Completed 2125000 out of 2500000 steps (85%)
04:13:58:WU03:FS02:0x21:Completed 280000 out of 2000000 steps (14%)
04:14:10:WU00:FS00:0xa7:Completed 118000 out of 200000 steps (59%)
04:14:39:WU01:FS01:0x21:Completed 2150000 out of 2500000 steps (86%)
04:15:35:WU03:FS02:0x21:Completed 300000 out of 2000000 steps (15%)
04:15:39:WU01:FS01:0x21:Completed 2175000 out of 2500000 steps (87%)
04:15:40:WU00:FS00:0xa7:Completed 120000 out of 200000 steps (60%)
04:16:39:WU01:FS01:0x21:Completed 2200000 out of 2500000 steps (88%)
04:17:12:WU00:FS00:0xa7:Completed 122000 out of 200000 steps (61%)
04:17:12:WU03:FS02:0x21:Completed 320000 out of 2000000 steps (16%)
04:17:44:WU01:FS01:0x21:Completed 2225000 out of 2500000 steps (89%)
04:18:40:WU00:FS00:0xa7:Completed 124000 out of 200000 steps (62%)
04:18:45:WU01:FS01:0x21:Completed 2250000 out of 2500000 steps (90%)
04:18:49:WU03:FS02:0x21:Completed 340000 out of 2000000 steps (17%)
04:19:45:WU01:FS01:0x21:Completed 2275000 out of 2500000 steps (91%)
04:20:08:WU00:FS00:0xa7:Completed 126000 out of 200000 steps (63%)
04:20:26:WU03:FS02:0x21:Completed 360000 out of 2000000 steps (18%)
04:20:45:WU01:FS01:0x21:Completed 2300000 out of 2500000 steps (92%)
04:21:35:WU00:FS00:0xa7:Completed 128000 out of 200000 steps (64%)
04:21:50:WU01:FS01:0x21:Completed 2325000 out of 2500000 steps (93%)
04:22:20:WU03:FS02:0x21:Completed 380000 out of 2000000 steps (19%)
04:22:51:WU01:FS01:0x21:Completed 2350000 out of 2500000 steps (94%)
04:23:04:WU00:FS00:0xa7:Completed 130000 out of 200000 steps (65%)
04:23:51:WU01:FS01:0x21:Completed 2375000 out of 2500000 steps (95%)
04:23:57:WU03:FS02:0x21:Completed 400000 out of 2000000 steps (20%)
04:24:33:WU00:FS00:0xa7:Completed 132000 out of 200000 steps (66%)
04:24:52:WU01:FS01:0x21:Completed 2400000 out of 2500000 steps (96%)
04:25:34:WU03:FS02:0x21:Completed 420000 out of 2000000 steps (21%)
04:25:56:WU01:FS01:0x21:Completed 2425000 out of 2500000 steps (97%)
04:26:00:WU00:FS00:0xa7:Completed 134000 out of 200000 steps (67%)
04:26:57:WU01:FS01:0x21:Completed 2450000 out of 2500000 steps (98%)
04:27:11:WU03:FS02:0x21:Completed 440000 out of 2000000 steps (22%)
04:27:27:WU00:FS00:0xa7:Completed 136000 out of 200000 steps (68%)
04:27:57:WU01:FS01:0x21:Completed 2475000 out of 2500000 steps (99%)
04:27:58:WU02:FS01:Connecting to 171.67.108.45:80
04:27:58:WU02:FS01:Assigned to work server 140.163.4.245
04:27:58:WU02:FS01:Requesting new work unit for slot 01: RUNNING gpu:0:GP102 [GeForce GTX 1080 Ti] from 140.163.4.245
04:27:58:WU02:FS01:Connecting to 140.163.4.245:8080
04:27:59:WU02:FS01:Downloading 14.49MiB
04:28:00:WU02:FS01:Download complete
04:28:00:WU02:FS01:Received Unit: id:02 state:DOWNLOAD error:NO_ERROR project:10496 run:61 clone:59 gen:6 core:0x21 unit:0x000000098ca304f558896724bf80c754
04:28:48:WU03:FS02:0x21:Completed 460000 out of 2000000 steps (23%)
04:28:53:WU00:FS00:0xa7:Completed 138000 out of 200000 steps (69%)
04:28:58:WU01:FS01:0x21:Completed 2500000 out of 2500000 steps (100%)
04:29:02:WU01:FS01:0x21:Saving result file logfile_01.txt
04:29:02:WU01:FS01:0x21:Saving result file checkpointState.xml
04:29:05:WU01:FS01:0x21:Saving result file checkpt.crc
04:29:05:WU01:FS01:0x21:Saving result file log.txt
04:29:05:WU01:FS01:0x21:Saving result file positions.xtc
04:29:06:WU01:FS01:0x21:Folding@home Core Shutdown: FINISHED_UNIT
04:29:07:WU01:FS01:FahCore returned: FINISHED_UNIT (100 = 0x64)
04:29:07:WU01:FS01:Sending unit results: id:01 state:SEND error:NO_ERROR project:9192 run:0 clone:93 gen:350 core:0x21 unit:0x000001ecab40415457cb2d2fb2c246c1
04:29:07:WU01:FS01:Uploading 6.29MiB to 171.64.65.84
04:29:07:WU01:FS01:Connecting to 171.64.65.84:8080
04:29:07:WU02:FS01:Starting
04:29:07:WU02:FS01:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:/Users/Cerebro/AppData/Roaming/FAHClient/cores/fahwebx.stanford.edu/cores/Win32/AMD64/NVIDIA/Fermi/Core_21.fah/FahCore_21.exe -dir 02 -suffix 01 -version 704 -lifeline 808 -checkpoint 15 -gpu 0 -gpu-vendor nvidia
04:29:07:WU02:FS01:Started FahCore on PID 1144
04:29:07:WU02:FS01:Core PID:896
04:29:07:WU02:FS01:FahCore 0x21 started
04:29:13:WU01:FS01:Upload 56.64%
04:29:14:WU02:FS01:0x21:*********************** Log Started 2017-04-08T04:29:13Z ***********************
04:29:14:WU02:FS01:0x21:Project: 10496 (Run 61, Clone 59, Gen 6)
04:29:14:WU02:FS01:0x21:Unit: 0x000000098ca304f558896724bf80c754
04:29:14:WU02:FS01:0x21:CPU: 0x00000000000000000000000000000000
04:29:14:WU02:FS01:0x21:Machine: 1
04:29:14:WU02:FS01:0x21:Reading tar file core.xml
04:29:14:WU02:FS01:0x21:Reading tar file system.xml
04:29:18:WU02:FS01:0x21:Reading tar file integrator.xml
04:29:18:WU02:FS01:0x21:Reading tar file state.xml
04:29:21:WU01:FS01:Upload complete
04:29:21:WU01:FS01:Server responded WORK_ACK (400)
04:29:21:WU01:FS01:Final credit estimate, 38933.00 points
04:29:21:WU01:FS01:Cleaning up
04:29:24:WU02:FS01:0x21:Digital signatures verified
04:29:24:WU02:FS01:0x21:Folding@home GPU Core21 Folding@home Core
04:29:24:WU02:FS01:0x21:Version 0.0.18
04:30:19:WU00:FS00:0xa7:Completed 140000 out of 200000 steps (70%)
04:30:22:WU02:FS01:0x21:Completed 0 out of 2000000 steps (0%)
04:30:23:WU02:FS01:0x21:Temperature control disabled. Requirements: single Nvidia GPU, tmax must be < 110 and twait >= 900
04:30:27:WU03:FS02:0x21:Completed 480000 out of 2000000 steps (24%)
04:31:47:WU00:FS00:0xa7:Completed 142000 out of 200000 steps (71%)
04:32:04:WU03:FS02:0x21:Completed 500000 out of 2000000 steps (25%)
04:32:10:WU02:FS01:0x21:Completed 20000 out of 2000000 steps (1%)
04:33:15:WU00:FS00:0xa7:Completed 144000 out of 200000 steps (72%)
04:33:57:WU03:FS02:0x21:Completed 520000 out of 2000000 steps (26%)
04:33:57:WU02:FS01:0x21:Completed 40000 out of 2000000 steps (2%)
04:34:42:WU00:FS00:0xa7:Completed 146000 out of 200000 steps (73%)
04:35:34:WU03:FS02:0x21:Completed 540000 out of 2000000 steps (27%)
04:35:45:WU02:FS01:0x21:Completed 60000 out of 2000000 steps (3%)
04:36:07:WU00:FS00:0xa7:Completed 148000 out of 200000 steps (74%)
04:37:12:WU03:FS02:0x21:Completed 560000 out of 2000000 steps (28%)
04:37:32:WU02:FS01:0x21:Completed 80000 out of 2000000 steps (4%)
04:37:36:WU00:FS00:0xa7:Completed 150000 out of 200000 steps (75%)
04:38:50:WU03:FS02:0x21:Completed 580000 out of 2000000 steps (29%)
04:39:04:WU00:FS00:0xa7:Completed 152000 out of 200000 steps (76%)
04:39:20:WU02:FS01:0x21:Completed 100000 out of 2000000 steps (5%)
04:40:27:WU03:FS02:0x21:Completed 600000 out of 2000000 steps (30%)
04:40:30:WU00:FS00:0xa7:Completed 154000 out of 200000 steps (77%)
04:41:07:WU02:FS01:0x21:Completed 120000 out of 2000000 steps (6%)
04:41:59:WU00:FS00:0xa7:Completed 156000 out of 200000 steps (78%)
04:42:05:WU03:FS02:0x21:Completed 620000 out of 2000000 steps (31%)
04:43:09:WU02:FS01:0x21:Completed 140000 out of 2000000 steps (7%)
04:43:27:WU00:FS00:0xa7:Completed 158000 out of 200000 steps (79%)
04:43:57:WU03:FS02:0x21:Completed 640000 out of 2000000 steps (32%)
04:44:56:WU00:FS00:0xa7:Completed 160000 out of 200000 steps (80%)
04:44:57:WU02:FS01:0x21:Completed 160000 out of 2000000 steps (8%)
04:45:35:WU03:FS02:0x21:Completed 660000 out of 2000000 steps (33%)
04:46:26:WU00:FS00:0xa7:Completed 162000 out of 200000 steps (81%)
04:46:43:WU02:FS01:0x21:Completed 180000 out of 2000000 steps (9%)
04:47:12:WU03:FS02:0x21:Completed 680000 out of 2000000 steps (34%)
04:47:56:WU00:FS00:0xa7:Completed 164000 out of 200000 steps (82%)
04:48:30:WU02:FS01:0x21:Completed 200000 out of 2000000 steps (10%)
04:48:50:WU03:FS02:0x21:Completed 700000 out of 2000000 steps (35%)
04:49:26:WU00:FS00:0xa7:Completed 166000 out of 200000 steps (83%)
04:50:17:WU02:FS01:0x21:Completed 220000 out of 2000000 steps (11%)
04:50:27:WU03:FS02:0x21:Completed 720000 out of 2000000 steps (36%)
04:50:57:WU00:FS00:0xa7:Completed 168000 out of 200000 steps (84%)
04:52:03:WU02:FS01:0x21:Completed 240000 out of 2000000 steps (12%)
04:52:04:WU03:FS02:0x21:Completed 740000 out of 2000000 steps (37%)
04:52:29:WU00:FS00:0xa7:Completed 170000 out of 200000 steps (85%)
04:53:58:WU03:FS02:0x21:Completed 760000 out of 2000000 steps (38%)
04:54:05:WU00:FS00:0xa7:Completed 172000 out of 200000 steps (86%)
04:54:06:WU02:FS01:0x21:Completed 260000 out of 2000000 steps (13%)
04:55:36:WU03:FS02:0x21:Completed 780000 out of 2000000 steps (39%)
04:55:38:WU00:FS00:0xa7:Completed 174000 out of 200000 steps (87%)
04:55:53:WU02:FS01:0x21:Completed 280000 out of 2000000 steps (14%)
04:57:12:WU00:FS00:0xa7:Completed 176000 out of 200000 steps (88%)
04:57:14:WU03:FS02:0x21:Completed 800000 out of 2000000 steps (40%)
04:57:40:WU02:FS01:0x21:Completed 300000 out of 2000000 steps (15%)
04:58:44:WU00:FS00:0xa7:Completed 178000 out of 200000 steps (89%)
04:58:51:WU03:FS02:0x21:Completed 820000 out of 2000000 steps (41%)
04:59:28:WU02:FS01:0x21:Completed 320000 out of 2000000 steps (16%)
05:00:19:WU00:FS00:0xa7:Completed 180000 out of 200000 steps (90%)
05:00:29:WU03:FS02:0x21:Completed 840000 out of 2000000 steps (42%)
05:01:16:WU02:FS01:0x21:Completed 340000 out of 2000000 steps (17%)
05:01:54:WU00:FS00:0xa7:Completed 182000 out of 200000 steps (91%)
05:02:07:WU03:FS02:0x21:Completed 860000 out of 2000000 steps (43%)
05:03:03:WU02:FS01:0x21:Completed 360000 out of 2000000 steps (18%)
05:03:26:WU00:FS00:0xa7:Completed 184000 out of 200000 steps (92%)
05:04:00:WU03:FS02:0x21:Completed 880000 out of 2000000 steps (44%)
05:04:58:WU00:FS00:0xa7:Completed 186000 out of 200000 steps (93%)
05:05:07:WU02:FS01:0x21:Completed 380000 out of 2000000 steps (19%)
05:05:38:WU03:FS02:0x21:Completed 900000 out of 2000000 steps (45%)
05:06:28:WU00:FS00:0xa7:Completed 188000 out of 200000 steps (94%)
05:06:55:WU02:FS01:0x21:Completed 400000 out of 2000000 steps (20%)
05:07:15:WU03:FS02:0x21:Completed 920000 out of 2000000 steps (46%)
05:07:59:WU00:FS00:0xa7:Completed 190000 out of 200000 steps (95%)
05:08:42:WU02:FS01:0x21:Completed 420000 out of 2000000 steps (21%)
05:08:52:WU03:FS02:0x21:Completed 940000 out of 2000000 steps (47%)
05:09:32:WU00:FS00:0xa7:Completed 192000 out of 200000 steps (96%)
05:10:29:WU02:FS01:0x21:Completed 440000 out of 2000000 steps (22%)
05:10:30:WU03:FS02:0x21:Completed 960000 out of 2000000 steps (48%)
05:10:59:WU00:FS00:0xa7:Completed 194000 out of 200000 steps (97%)
05:12:07:WU03:FS02:0x21:Completed 980000 out of 2000000 steps (49%)
05:12:16:WU02:FS01:0x21:Completed 460000 out of 2000000 steps (23%)
05:12:27:WU00:FS00:0xa7:Completed 196000 out of 200000 steps (98%)
05:13:45:WU03:FS02:0x21:Completed 1000000 out of 2000000 steps (50%)
05:13:54:WU00:FS00:0xa7:Completed 198000 out of 200000 steps (99%)
05:13:55:WU01:FS00:Connecting to 171.67.108.45:8080
05:13:55:WU01:FS00:Assigned to work server 171.67.108.101
05:13:55:WU01:FS00:Requesting new work unit for slot 00: RUNNING cpu:20 from 171.67.108.101
05:13:55:WU01:FS00:Connecting to 171.67.108.101:8080
05:13:57:WU01:FS00:Downloading 2.94MiB
05:13:57:WU01:FS00:Download complete
05:13:57:WU01:FS00:Received Unit: id:01 state:DOWNLOAD error:NO_ERROR project:13123 run:62 clone:6 gen:83 core:0xa7 unit:0x0000005eab436c655898cae0e983cbe7
05:14:04:WU02:FS01:0x21:Completed 480000 out of 2000000 steps (24%)
05:15:20:WU00:FS00:0xa7:Completed 200000 out of 200000 steps (100%)
05:15:26:WU00:FS00:0xa7:Saving result file ..\logfile_01.txt
05:15:26:WU00:FS00:0xa7:Saving result file frame81.trr
05:15:29:WU00:FS00:0xa7:Saving result file md.log
05:15:29:WU00:FS00:0xa7:Saving result file science.log
05:15:29:WU00:FS00:0xa7:Folding@home Core Shutdown: FINISHED_UNIT
05:15:29:WU00:FS00:FahCore returned: FINISHED_UNIT (100 = 0x64)
05:15:29:WU00:FS00:Sending unit results: id:00 state:SEND error:NO_ERROR project:13127 run:80 clone:5 gen:81 core:0xa7 unit:0x00000065ab436c655898c9289c1b7441
05:15:29:WU00:FS00:Uploading 15.51MiB to 171.67.108.101
05:15:29:WU00:FS00:Connecting to 171.67.108.101:8080
05:15:29:WU01:FS00:Starting
05:15:29:WU01:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:/Users/Cerebro/AppData/Roaming/FAHClient/cores/fahwebx.stanford.edu/cores/Win32/AMD64/AVX/Core_a7.fah/FahCore_a7.exe -dir 01 -suffix 01 -version 704 -lifeline 808 -checkpoint 15 -np 20
05:15:29:WU01:FS00:Started FahCore on PID 3940
05:15:30:WU01:FS00:Core PID:4420
05:15:30:WU01:FS00:FahCore 0xa7 started
BlueboyX
New rig troubles
Post by BlueboyX »
My new xeon rig with Aorus 1080 ti is getting about 800k, but I have seen other people getting 1.2-1.5 million ppd. How do I figure out what is going wrong?
02:46:26:         Args:
02:46:26:         Bits: 32
02:46:26:         CPUs: 28
02:46:26:          PID: 808
02:46:26:         GPUs: 2
02:46:26:         CUDA: 6.1
02:46:26:<config>
02:46:26:
02:46:26:
02:46:26:
02:46:26:  </slot>
02:46:26:  </slot>
02:46:26:</config>
ComputerGenie
Re: New rig troubles
Post by ComputerGenie »
BlueboyX_ALL_12tANB2SnTk8367ri9zfR5rG2jnzpbbH8q:
Day 	        Points 	WUs
04.12.17 	2,957,300 	60
04.11.17 	2,845,586 	57
04.10.17 	2,988,007 	46
04.09.17 	3,023,036 	51
04.08.17 	2,976,933 	50
04.07.17 	2,348,912 	37
Seems in line with 1.2-1.5M to me. :e?:
BlueboyX
Post by BlueboyX »
Are those the total scores for both my computers? I have another computer that gets 1.5 million ppd total across its cpu and two graphics cards. From the 8th to 12th that leaves about 1.4 million ppd for the new rig, which is running the cpu (20 of 24 xeon cores) and two 1080 TI cards. That would mean each 1080 Ti is getting less than 700k ppd.
I just tried removing the card on the riser. FAHControl is reporting an estimated PPD of 739,565 on the 1080 Ti and 60,790 on the CPU.
Or are the listed 'Estimated PPD' just totally off? I don't know how to get a nice readout like you just posted.
The estimated PPD isn't accurate until you've completed a few percent -- and it assumes your computer never sleeps and is never shut down. Aside from that, it also assumes you're using a qualified passkey.
I've listed a few WUs from your log above:
project:9189 run:0 clone:20 gen:349 earned 43150.8 points of credit. in 0.05 days
Your log, reports it as:Final credit estimate, 43150.00 points
project:9192 run:0 clone:93 gen:350 earned 38934.8 points of credit in 0.09 days
project:13127 run:80 clone:5 gen:81 earned 5696.8 points of credit in 0.13 days.
project:10496 run:47 clone:75 gen:5 earned 97305.6 points of credit in 0.13 days
project:10496 run:61 clone:59 gen:6 earned 92822.3 points of credit in 0.15 days.
Post by foldy »
BlueboyX wrote:my GPU load seems to jump around a lot, from the 60's to 99%.
The 24h average PPD listed above by ComputerGenie is for all your CPUs and GPUs under your username. Does it make a difference if you pause your CPU slot?
BlueboyX
Post by BlueboyX »
I can give that a try. I am at work so I cannot make any changes until the end of the day.
Nathan_P
Not currently folding
Post by Nathan_P »
A quick look at the log shows the gou index is only set for one card - I suspect that all WU are running on the one card. Doers GPu-z or afterburner show both cards running at load or just one?
02:46:26:<config>
02:46:26:
02:46:26:
02:46:26:
02:46:26:  </slot>
02:46:26:  </slot>
02:46:26:</config>
If just one of them is under load you will have to set the gpu and open cl index manually. mine looks like this:-
14:43:39:  <!-- User Information -->
14:43:39:  <passkey v='********************************'/>
14:43:39:  <team v='33'/>
14:43:39:  <user v='Nathan_P'/>
14:43:39:
14:43:39:  <!-- Folding Slots -->
14:43:39:  <slot id='1' type='GPU'>
14:43:39:    <cuda-index v='2'/>
14:43:39:    <gpu-index v='2'/>
14:43:39:    <opencl-index v='2'/>
14:43:39:  </slot>
14:43:39:  <slot id='0' type='GPU'>
14:43:39:    <cuda-index v='0'/>
14:43:39:    <gpu-index v='0'/>
14:43:39:    <opencl-index v='0'/>
14:43:39:  </slot>
14:43:39:</config>
BlueboyX
Post by BlueboyX »
Hmm. I see what you mean. I will have to try changing that once I get home. Thanks. :)
BlueboyX
Post by BlueboyX »
Nathan_P wrote:A quick look at the log shows the gou index is only set for one card - I suspect that all WU are running on the one card. Doers GPu-z or afterburner show both cards running at load or just one?
Hi,
When you say change it manually do you mean through a config file or through the client? I used the advanced client to change settings. I now have each GPU slot with a cuta-index and opencl-index. However, they do not show gpu-index even though I changed that entry from -1. Do I need to do something else to change that?
It looks like this:
14:43:39:  </slot>
I have also tried running with the cpu folding paused, which did not help. Changing around GPU slots did not seem to help.
There is a new bios out for each of these cards; I will try that out this weekend. Anyone have any other ideas for things to try?
Post by foldy »
You are using FAhClient 7.4.4 and you can try FahClient 7.4.16 beta, maybe that makes a difference.
Nathan_P
Post by Nathan_P »
Not that I am aware of, setting gpu-index should just be a matter of setting it in advanced control and saving the changes, you may need to restart the client for the changes to be picked up.
A new bios should not be necessary for folding
BlueboyX
Post by BlueboyX »
I am using FAHClient 7.4.4 I was not aware of there being a beta client available. I can try that before messing with the bios.
I don't think that matters. FAHClient will tell you if it finds a conflict when it configures both devices.
BlueboyX wrote:I am using FAHClient 7.4.4 I was not aware of there being a beta client available.
Yes, do try 7.4.16.
One of the bugs that I encountered with FAHClient V7.4.4 was only a problem on a system which had two GPUs of the same type in different slots (as opposed to a dual GPU in a single slot). They were in different slots and the software didn't automatically come up with a valid configuration that set different gpu-index values properly.
Your system does not seem to have my problem since it says.
For you, it's saying it already recognizes gpu:0 and gpu:1. You should not need to configure <gpu-index v='0'/>, but since you have, I'd leave it.
In my situation, when rebooting, sometimes it would work and sometimes I would get an error message saying there was a conflict. I'm going to assume you have NOT gotten such a message, but in any case, the bug I reported has been apparently fixed in v7.4.16(+).
One thing to note:
Suppose both GPUs are working on their own assignment but you want to make sure everything is working. Maybe you remove one GPU leaving the other, to confirm the hardware is working and then you plan on switching them to confirm the other one works.
After the first reboot, FAHClient will find one WU assigned to the operational GPU and a second WU that's no longer assigned to anything. In order to process both WUs it will not that the extra WU says it can be assigned to the operationa WU, so it will move that WU to the (only) GPU slot. One will start processing and the second WU will wait until the first one finishes. You can't undo that process. At such time as your system sees two GPUs again, FAH will download a new WU for it to process Three WUs assigned to two GPUs, with one simply queued for future processing. Eventually it will resolve itself, but the extra delay will reduce your PPD.
I don't know if that happened to you. but you can see it on FAHControl's Folding Slots / Work Queue panels -- and confirmed by the Selected WU panel as you select them one-by-one.
