Client only folds on "Full"
I did try to search this forum and Google for ideas on how to solve this - but I could not find anything.
I have a server (retired) with a couple of older xeon cpus and I installed the latest client. Problem is that I would like to have it fold at lower than 100% cpu but whenever I lower it to Medium or Light it stops folding.
What am I doing wrong?
Re: Client only folds on "Full"
The first 100 lines or so of your log would sure help answer questions like: What OS are you using, what version of F@H is running, are you doing CPU folding or GPU folding or both, etc.
I am unsure why you would ever choose anything but full on a server, but if you can show us what your PC setup looks like via the system portion of the log, we can try to make it do what you want.
Oh, and I would like it to run on lower cpu due to it heating up and the fan-noise is unbearable.
I have not run Linux myself, let's hope an expert at that posts soon. I am not sure I saw which distribution you are using.
Its not Linux. Its Win 2012 Datacenter....
Looking at the log, you have 24 cores available at Full. Running at Medium will only reduce that by one to 23, a large enough prime to cause issues. No projects have WU's that will process at that setting. The Light setting should work, that should use half the available cores, or 12 which is usually usable. But the section of log you posted did not included anything related to that setting.
You did not post the first 100 lines of your log, that shows some important system and configuration information. You can include that in a post here, just enclose the log posting in Code tags available from the Full Editor for posting.
You can also manually set a core count using FAHControl. Valid counts are multiples of 2, 3 and/or 5.
Yeah, theres two xeons with 12 cores each. Running at Light changes the Folding slot and work queue status from "Running" to "Ready" and its not folding.
Ideally I would like FAH to "consume" about 50% cpu...
Im not sure which log to post...heres the one in user\appdata\roaming\fahclient
Log file opened on Wed Apr 12 23:15:23 2017
Host: unknown pid: 11780 nodeid: 0 nnodes: 1
The Gromacs distribution was built Unknown date by
Anonymous@unknown [CMAKE] (Windows-5.2 x86)
:-) G R O M A C S (-:
Groningen Machine for Chemical Simulation
:-) VERSION 4.5.3 (-:
Written by Emile Apol, Rossen Apostolov, Herman J.C. Berendsen,
Aldert van Buuren, Pär Bjelkmar, Rudi van Drunen, Anton Feenstra,
Gerrit Groenhof, Peter Kasson, Per Larsson, Pieter Meulenhoff,
Teemu Murtola, Szilard Pall, Sander Pronk, Roland Schulz,
Michael Shirts, Alfons Sijbers, Peter Tieleman,
Berk Hess, David van der Spoel, and Erik Lindahl.
Copyright (c) 1991-2000, University of Groningen, The Netherlands.
Copyright (c) 2001-2010, The GROMACS development team at
Uppsala University & The Royal Institute of Technology, Sweden.
check out http://www.gromacs.org for more information.
:-) Gromacs (-:
++++ PLEASE READ AND CITE THE FOLLOWING REFERENCE ++++
B. Hess and C. Kutzner and D. van der Spoel and E. Lindahl
GROMACS 4: Algorithms for highly efficient, load-balanced, and scalable
molecular simulation
J. Chem. Theory Comput. 4 (2008) pp. 435-447
-------- -------- --- Thank You --- -------- --------
D. van der Spoel, E. Lindahl, B. Hess, G. Groenhof, A. E. Mark and H. J. C.
Berendsen
GROMACS: Fast, Flexible and Free
J. Comp. Chem. 26 (2005) pp. 1701-1719
E. Lindahl and B. Hess and D. van der Spoel
GROMACS 3.0: A package for molecular simulation and trajectory analysis
J. Mol. Mod. 7 (2001) pp. 306-317
H. J. C. Berendsen, D. van der Spoel and R. van Drunen
GROMACS: A message-passing parallel molecular dynamics implementation
Comp. Phys. Comm. 91 (1995) pp. 43-56
Input Parameters:
integrator = sd
nsteps = 1250000
init_step = 40000000
ns_type = Grid
nstlist = 10
ndelta = 2
nstcomm = 10
comm_mode = Linear
nstlog = 50000
nstxout = 500000
nstvout = 500000
nstfout = 0
nstcalcenergy = 10
nstenergy = 50000
nstxtcout = 50000
init_t = 0
delta_t = 0.002
xtcprec = 1000
nkx = 72
nky = 72
nkz = 72
pme_order = 4
ewald_rtol = 1e-005
ewald_geometry = 0
epsilon_surface = 0
optimize_fft = FALSE
ePBC = xyz
bPeriodicMols = FALSE
bContinuation = TRUE
bShakeSOR = FALSE
etc = No
nsttcouple = -1
epc = No
epctype = Isotropic
nstpcouple = -1
tau_p = 1
ref_p (3x3):
ref_p[ 0]={0.00000e+000, 0.00000e+000, 0.00000e+000}
ref_p[ 1]={0.00000e+000, 0.00000e+000, 0.00000e+000}
ref_p[ 2]={0.00000e+000, 0.00000e+000, 0.00000e+000}
compress (3x3):
compress[ 0]={0.00000e+000, 0.00000e+000, 0.00000e+000}
compress[ 1]={0.00000e+000, 0.00000e+000, 0.00000e+000}
compress[ 2]={0.00000e+000, 0.00000e+000, 0.00000e+000}
refcoord_scaling = No
posres_com (3):
posres_com[0]=0.00000e+000
posres_com[1]=0.00000e+000
posres_com[2]=0.00000e+000
posres_comB (3):
posres_comB[0]=0.00000e+000
posres_comB[1]=0.00000e+000
posres_comB[2]=0.00000e+000
andersen_seed = 815131
rlist = 0.9
rlistlong = 0.9
rtpi = 0.05
coulombtype = PME
rcoulomb_switch = 0
rcoulomb = 0.9
vdwtype = Cut-off
rvdw_switch = 0
rvdw = 0.9
epsilon_r = 1
epsilon_rf = 1
tabext = 1
implicit_solvent = No
gb_algorithm = Still
gb_epsilon_solvent = 80
nstgbradii = 1
rgbradii = 1
gb_saltconc = 0
gb_obc_alpha = 1
gb_obc_beta = 0.8
gb_obc_gamma = 4.85
gb_dielectric_offset = 0.009
sa_algorithm = Ace-approximation
sa_surface_tension = 2.05016
DispCorr = No
free_energy = no
init_lambda = 0
delta_lambda = 0
n_foreign_lambda = 0
sc_alpha = 0
sc_power = 0
sc_sigma = 0.3
sc_sigma_min = 0.3
nstdhdl = 10
separate_dhdl_file = yes
dhdl_derivatives = yes
dh_hist_size = 0
dh_hist_spacing = 0.1
nwall = 0
wall_type = 9-3
wall_atomtype[0] = -1
wall_atomtype[1] = -1
wall_density[0] = 0
wall_density[1] = 0
wall_ewald_zfac = 3
pull = no
disre = No
disre_weighting = Conservative
disre_mixed = FALSE
dr_fc = 1000
dr_tau = 0
nstdisreout = 100
orires_fc = 0
orires_tau = 0
nstorireout = 100
dihre-fc = 1000
em_stepsize = 0.01
em_tol = 10
niter = 20
fc_stepsize = 0
nstcgsteep = 1000
nbfgscorr = 10
ConstAlg = Lincs
shake_tol = 0.0001
lincs_order = 4
lincs_warnangle = 30
lincs_iter = 1
bd_fric = 0
ld_seed = 19017
cos_accel = 0
deform (3x3):
deform[ 0]={0.00000e+000, 0.00000e+000, 0.00000e+000}
deform[ 1]={0.00000e+000, 0.00000e+000, 0.00000e+000}
deform[ 2]={0.00000e+000, 0.00000e+000, 0.00000e+000}
userint1 = 0
userint2 = 0
userint3 = 0
userint4 = 0
userreal1 = 0
userreal2 = 0
userreal3 = 0
userreal4 = 0
grpopts:
nrdf: 4672 102948
ref_t: 300 300
tau_t: 1 1
anneal: No No
ann_npoints: 0 0
acc: 0 0 0
nfreeze: N N N
energygrp_flags[ 0]: 0 0
energygrp_flags[ 1]: 0 0
efield-x:
n = 0
efield-xt:
n = 0
efield-y:
n = 0
efield-yt:
n = 0
efield-z:
n = 0
efield-zt:
n = 0
bQMMM = FALSE
QMconstraints = 0
QMMMscheme = 0
scalefactor = 1
qm_opts:
ngQM = 0
Initializing Domain Decomposition on 24 nodes
Dynamic load balancing: auto
Will sort the charge groups at every domain (re)decomposition
Initial maximum inter charge-group distances:
two-body bonded interactions: 0.443 nm, LJ-14, atoms 1277 1833
multi-body bonded interactions: 0.443 nm, Proper Dih., atoms 1277 1833
Minimum cell size due to bonded interactions: 0.487 nm
Maximum distance for 5 constraints, at 120 deg. angles, all-trans: 0.218 nm
Estimated maximum distance required for P-LINCS: 0.218 nm
Using 0 separate PME nodes
Scaling the initial minimum size with 1/0.8 (option -dds) = 1.25
Optimizing the DD grid for 24 cells with a minimum initial size of 0.608 nm
The maximum allowed number of cells is: X 13 Y 13 Z 13
Domain decomposition grid 6 x 4 x 1, separate PME nodes 0
PME domain decomposition: 6 x 4 x 1
Domain decomposition nodeid 0, coordinates 0 0 0
Table routines are used for coulomb: TRUE
Table routines are used for vdw: FALSE
Will do PME sum in reciprocal space.
U. Essman, L. Perela, M. L. Berkowitz, T. Darden, H. Lee and L. G. Pedersen
A smooth particle mesh Ewald method
J. Chem. Phys. 103 (1995) pp. 8577-8592
Will do ordinary reciprocal space Ewald sum.
Using a Gaussian width (1/beta) of 0.288146 nm for Ewald
Cut-off's: NS: 0.9 Coulomb: 0.9 LJ: 0.9
System total charge: 0.000
Generated table with 950 data points for Ewald.
Tabscale = 500 points/nm
Generated table with 950 data points for LJ6.
Generated table with 950 data points for LJ12.
Generated table with 950 data points for 1-4 COUL.
Generated table with 950 data points for 1-4 LJ6.
Generated table with 950 data points for 1-4 LJ12.
Enabling SPC-like water optimization for 17156 molecules.
Configuring nonbonded kernels...
Configuring standard C nonbonded kernels...
Testing ia32 SSE2 support... present.
Initializing Parallel LINear Constraint Solver
B. Hess
P-LINCS: A Parallel Linear Constraint Solver for molecular simulation
J. Chem. Theory Comput. 4 (2008) pp. 116-122
The number of constraints is 965
There are inter charge-group constraints,
will communicate selected coordinates each lincs iteration
S. Miyamoto and P. A. Kollman
SETTLE: An Analytical Version of the SHAKE and RATTLE Algorithms for Rigid
Water Models
J. Comp. Chem. 13 (1992) pp. 952-962
Linking all bonded interactions to atoms
There are 10305 inter charge-group exclusions,
will use an extra communication step for exclusion forces for PME
The initial number of communication pulses is: X 1 Y 1
The initial domain decomposition cell size is: X 1.35 nm Y 2.03 nm
The maximum allowed distance for charge groups involved in interactions is:
non-bonded interactions 0.900 nm
two-body bonded interactions (-rdd) 0.900 nm
multi-body bonded interactions (-rdd) 0.900 nm
atoms separated by up to 5 constraints (-rcon) 1.355 nm
When dynamic load balancing gets turned on, these settings will change to:
The maximum number of communication pulses is: X 1 Y 1
The minimum size for domain decomposition cells is 0.900 nm
The requested allowed shrink of DD cells (option -dds) is: 0.80
The allowed shrink of domain decomposition cells is: X 0.66 Y 0.44
atoms separated by up to 5 constraints (-rcon) 0.900 nm
Making 2D domain decomposition grid 6 x 4 x 1, home cell index 0 0 0
Center of mass motion removal mode is Linear
We have the following groups for center of mass motion removal:
0: Protein
1: Water_and_ions
There are: 53353 Atoms
Charge group distribution at step 40000000: 728 745 722 754 744 861 753 727 738 1165 890 793 793 1135 829 759 721 762 735 722 750 720 744 751
Grid: 4 x 5 x 12 cells
Initial temperature: 298.97 K
Started mdrun on node 0 Wed Apr 12 23:15:23 2017
Step Time Lambda
40000000 80000.00000 0.00000
Energies (kJ/mol)
Bond Angle Proper Dih. Improper Dih. LJ-14
1.28119e+003 4.02459e+003 4.49070e+003 2.28062e+002 1.91744e+003
Coulomb-14 LJ (SR) Coulomb (SR) Coul. recip. Potential
2.38264e+004 1.00875e+005 -7.10225e+005 -1.22494e+005 -6.96076e+005
Kinetic En. Total Energy Temperature Pressure (bar) Constr. rmsd
1.33746e+005 -5.62330e+005 2.98938e+002 2.05035e+002 3.07665e-006
Constr.2 rmsd
3.12002e-006
DD step 40000009 load imb.: force 50.5%
At step 40000010 the performance loss due to force load imbalance is 8.8 %
NOTE: Turning on dynamic load balancing
Writing checkpoint, step 40048620 at Wed Apr 12 23:30:23 2017
DD step 40049999 vol min/aver 0.595 load imb.: force 5.0%
Step Time Lambda
40050000 80100.00000 0.00000
Energies (kJ/mol)
1.35913e+003 3.84521e+003 4.38751e+003 2.42907e+002 1.85150e+003
2.39067e+004 1.03557e+005 -7.14380e+005 -1.22531e+005 -6.97760e+005
1.34205e+005 -5.63555e+005 2.99965e+002 4.02504e+002 3.11898e-006
Constr.2 rmsd
3.09024e-006
Writing checkpoint, step 40097150 at Wed Apr 12 23:45:23 2017
DD step 40099999 vol min/aver 0.595 load imb.: force 2.2%
Step Time Lambda
40100000 80200.00000 0.00000
Energies (kJ/mol)
1.33347e+003 3.84378e+003 4.36568e+003 2.72384e+002 1.79030e+003
2.38537e+004 1.03678e+005 -7.13988e+005 -1.22295e+005 -6.97145e+005
1.34244e+005 -5.62901e+005 3.00052e+002 3.80798e+002 3.27268e-006
Constr.2 rmsd
3.23589e-006
That is the working log for the core, the one for the client should also be there. Directions for locating the client's log file is located in the Welcome Topic, with directions for each OS. Or you can use the Refresh button on the FAHControl log display and scroll back to the beginning.
One possibility is that the Light setting has folding set to "On Idle", that would be waiting for user input to cease for a period of time before starting.
The log you posted does not include your system configuration, just the config file and the start of the log. It would be easier if we could see that, too. For example, I don't know what version of FAHClient you have installed.
Anyway, the slider actually provides very few choices and with a system like yours, you would have a lot more choices if you used the Advanced Control application (FAHControl).
Assuming you have 24 cpu cores and you want to use 50% of them, open FAHControl and select Configure + Slots + ...
You probably have just one slot listed on that page called CPU. Select it + Edit and at the top, there's a number of CPU threads. Set it to 12 + OK + SAVE
Thank you very much for your help. I did refresh and below is the logs first 100 lines or so.
The tip from bruce though; "FAHControl and select Configure + Slots + ...
You probably have just one slot listed on that page called CPU. Select it + Edit and at the top, there's a number of CPU threads. Set it to 12 + OK + SAVE"
seems to work perfectly
Server now uses 50% cpu (approx) and its WAY less noisy
Thanks!!!
PPD around 3000...isnt that a bit low though for this amount of cpu power?
Thanks again guys!
Thanks!!!
Thanks again guys!
*********************** Log Started 2017-04-11T21:23:16Z ***********************
21:23:16:************************* Folding@home Client *************************
21:23:16: Website: http://folding.stanford.edu/
21:23:16: Copyright: (c) 2009-2014 Stanford University
21:23:16: Author: Joseph Coffland <joseph@cauldrondevelopment.com>
21:23:16: Args:
21:23:16: Config: <none>
21:23:16:******************************** Build ********************************
21:23:16: Version: 7.4.4
21:23:16: Date: Mar 4 2014
21:23:16: Time: 20:26:54
21:23:16: SVN Rev: 4130
21:23:16: Branch: fah/trunk/client
21:23:16: Compiler: Intel(R) C++ MSVC 1500 mode 1200
21:23:16: Options: /TP /nologo /EHa /Qdiag-disable:4297,4103,1786,279 /Ox -arch:SSE
21:23:16: /QaxSSE2,SSE3,SSSE3,SSE4.1,SSE4.2 /Qopenmp /Qrestrict /MT /Qmkl
21:23:16: Platform: win32 XP
21:23:16: Bits: 32
21:23:16: Mode: Release
21:23:16:******************************* System ********************************
21:23:16: CPU: Intel(R) Xeon(R) CPU X5650 @ 2.67GHz
21:23:16: CPU ID: GenuineIntel Family 6 Model 44 Stepping 2
21:23:16: CPUs: 24
21:23:16: Memory: 99.99GiB
21:23:16: Free Memory: 76.23GiB
21:23:16: Threads: WINDOWS_THREADS
21:23:16: OS Version: 6.2
21:23:16: Has Battery: false
21:23:16: On Battery: false
21:23:16: UTC Offset: 2
21:23:16: PID: 17596
21:23:16: CWD: C:/Windows/system32
21:23:16: OS: Windows Server 2012 R2 Datacenter
21:23:16: OS Arch: AMD64
21:23:16: GPUs: 1
21:23:16: GPU 0: UNSUPPORTED: [ES1000]
21:23:16: CUDA: Not detected
21:23:16:Win32 Service: true
21:23:16:***********************************************************************
21:23:16:<config>
21:23:16: <!-- Folding Slots -->
21:23:16:</config>
21:23:16:Connecting to assign-GPU.stanford.edu:80
21:23:16:Updated GPUs.txt
21:23:16:Read GPUs.txt
21:23:16:Trying to access database...
21:23:16:Successfully acquired database lock
21:23:16:Enabled folding slot 00: PAUSED cpu:23 (not configured)
21:23:19:16:127.0.0.1:New Web connection
21:23:34:Set client configured
21:23:35:WU00:FS00:Connecting to 171.67.108.45:8080
21:23:36:WARNING:WU00:FS00:Failed to get assignment from '171.67.108.45:8080': Empty work server assignment
21:23:36:WU00:FS00:Connecting to 171.64.65.35:80
21:23:36:WARNING:WU00:FS00:Failed to get assignment from '171.64.65.35:80': Empty work server assignment
21:23:36:ERROR:WU00:FS00:Exception: Could not get an assignment
21:23:36:WU00:FS00:Connecting to 171.67.108.45:8080
21:23:37:WARNING:WU00:FS00:Failed to get assignment from '171.67.108.45:8080': Empty work server assignment
21:23:37:WU00:FS00:Connecting to 171.64.65.35:80
21:23:37:WARNING:WU00:FS00:Failed to get assignment from '171.64.65.35:80': Empty work server assignment
21:23:37:ERROR:WU00:FS00:Exception: Could not get an assignment
21:24:17:Saving configuration to config.xml
21:24:17:<config>
21:24:17: <!-- User Information -->
21:24:17: <team v='69264'/>
21:24:17: <user v='ENDSKF006'/>
21:24:17:
21:24:17: <!-- Folding Slots -->
21:24:17: <slot id='0' type='CPU'/>
21:24:17:</config>
21:24:36:WU00:FS00:Connecting to 171.67.108.45:8080
21:24:37:WARNING:WU00:FS00:Failed to get assignment from '171.67.108.45:8080': Empty work server assignment
21:24:37:WU00:FS00:Connecting to 171.64.65.35:80
21:24:37:WARNING:WU00:FS00:Failed to get assignment from '171.64.65.35:80': Empty work server assignment
21:24:37:ERROR:WU00:FS00:Exception: Could not get an assignment
21:26:14:WU00:FS00:Connecting to 171.67.108.45:8080
21:26:14:WARNING:WU00:FS00:Failed to get assignment from '171.67.108.45:8080': Empty work server assignment
21:26:14:WU00:FS00:Connecting to 171.64.65.35:80
21:26:15:WARNING:WU00:FS00:Failed to get assignment from '171.64.65.35:80': Empty work server assignment
21:26:15:ERROR:WU00:FS00:Exception: Could not get an assignment
21:27:59:WU00:FS00:Connecting to 171.67.108.45:8080
21:27:59:WU00:FS00:Assigned to work server 128.252.203.4
21:27:59:WU00:FS00:Requesting new work unit for slot 00: READY cpu:24 from 128.252.203.4
21:27:59:WU00:FS00:Connecting to 128.252.203.4:8080
21:27:59:WU00:FS00:Downloading 1.98MiB
21:28:02:WU00:FS00:Download complete
21:28:02:WU00:FS00:Received Unit: id:00 state:DOWNLOAD error:NO_ERROR project:13803 run:0 clone:733 gen:17 core:0xa7 unit:0x0000001480fccb0458b9a2637b824e0f
21:28:02:WU00:FS00:Downloading core from http://fahwebx.stanford.edu/cores/Win32/AMD64/Core_a7.fah
21:28:02:WU00:FS00:Connecting to fahwebx.stanford.edu:80
21:28:03:WU00:FS00:FahCore a7: Downloading 6.64MiB
21:28:09:WU00:FS00:FahCore a7: 53.63%
21:28:15:WU00:FS00:FahCore a7: 96.91%
21:28:15:WU00:FS00:FahCore a7: Download complete
21:28:15:WU00:FS00:Valid core signature
21:28:15:WU00:FS00:Unpacked 11.29MiB to cores/fahwebx.stanford.edu/cores/Win32/AMD64/Core_a7.fah/FahCore_a7.exe
21:28:15:WU00:FS00:Unpacked 72.16KiB to cores/fahwebx.stanford.edu/cores/Win32/AMD64/Core_a7.fah/libbz2-1.dll
21:28:15:WU00:FS00:Unpacked 2.17MiB to cores/fahwebx.stanford.edu/cores/Win32/AMD64/Core_a7.fah/libeay32.dll
21:28:15:WU00:FS00:Unpacked 154.79KiB to cores/fahwebx.stanford.edu/cores/Win32/AMD64/Core_a7.fah/libexpat-1.dll
21:28:15:WU00:FS00:Unpacked 2.11MiB to cores/fahwebx.stanford.edu/cores/Win32/AMD64/Core_a7.fah/libfftw3f-3.dll
21:28:15:WU00:FS00:Unpacked 406.90KiB to cores/fahwebx.stanford.edu/cores/Win32/AMD64/Core_a7.fah/ssleay32.dll
21:28:15:WU00:FS00:Unpacked 88.13KiB to cores/fahwebx.stanford.edu/cores/Win32/AMD64/Core_a7.fah/zlib1.dll
21:28:15:WU00:FS00:Unpacked 81.28KiB to cores/fahwebx.stanford.edu/cores/Win32/AMD64/Core_a7.fah/libgcc_s_seh-1.dll
21:28:15:WU00:FS00:Unpacked 55.64KiB to cores/fahwebx.stanford.edu/cores/Win32/AMD64/Core_a7.fah/libwinpthread-1.dll
21:28:15:WU00:FS00:Unpacked 1.35MiB to cores/fahwebx.stanford.edu/cores/Win32/AMD64/Core_a7.fah/libstdc++-6.dll
21:28:15:WU00:FS00:Starting
21:28:15:WU00:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:/Users/domene_admin/AppData/Roaming/FAHClient/cores/fahwebx.stanford.edu/cores/Win32/AMD64/Core_a7.fah/FahCore_a7.exe -dir 00 -suffix 01 -version 704 -lifeline 17596 -checkpoint 15 -np 24 -service
21:28:15:WU00:FS00:Started FahCore on PID 9088
21:28:15:WU00:FS00:Core PID:21228
21:28:15:WU00:FS00:FahCore 0xa7 started
The config that you posted on-line doesn't look like the same one posted above. Nevertheless, neither one seems to have a passkey. You will earn significantly more points after you get a new passkey, enter it into FAHControl + Identity ... and then complete 10* more WUs.h3ctic wrote:PPD around 3000...isnt that a bit low though for this amount of cpu power?
I expect that you'll be able to get a pretty good supply of WUs that work with 12 threads but if you start experimenting with slightly higher/lower numbers of CPUs, you'll really need to upgrade the FAHClient installation to v7.4.16-beta.
Im not sure what this means: "The config that you posted on-line doesn't look like the same one posted above." ?
I didnt get a passkey. I didnt think this mattered at all. I will get a passkey and leave it running and hopefully the PPD will pick up. Thanks again!
The image at pastebin looks like this:
and the one pasted above shows
You may have more than one directory containing FAH Data.
The first one looks right except for recent changes.
16:41:19:<config>
16:41:19: <!-- Folding Slot Configuration -->
16:41:19: <cause v='CANCER'/>
16:41:19:
16:41:19: <!-- Network -->
16:41:19: <proxy v=':8080'/>
16:41:19:
16:41:19: <!-- Slot Control -->
16:41:19: <pause-on-battery v='false'/>
16:41:19:
16:41:19: <!-- User Information -->
16:41:19: <team v='69264'/>
16:41:19: <user v='ENDSKF006'/>
16:41:19:
16:41:19: <!-- Folding Slots -->
16:41:19: <slot id='0' type='CPU'/>
16:41:19:</config>Code: Select all
21:23:16:<config>
21:23:16:</config>The first one looks right except for recent changes.
I really dont know about those config differences, I just copy/pasted..
Anyways; PPD estimated now is approx 25000. Is this normal/low/high given the specs?
Thanks again for your help, everything seems just fine now!
