Nvidia Titan Xp
TitanXp
NividiaTitan Xp
Post by TitanXp »
Is this card supported because I can not get it to work.
DMMD
Nvidia Titan Xp
Post by DMMD »
Please to add
log:
*********************** Log Started 2017-04-11T23:39:31Z ***********************
23:39:31:************************* Folding@home Client *************************
23:39:31:      Website: http://folding.stanford.edu/
23:39:31:    Copyright: (c) 2009-2014 Stanford University
23:39:31:       Author: Joseph Coffland <joseph@cauldrondevelopment.com>
23:39:31:         Args: --open-web-control
23:39:31:       Config: C:/Users/David/AppData/Roaming/FAHClient/config.xml
23:39:31:******************************** Build ********************************
23:39:31:      Version: 7.4.4
23:39:31:         Date: Mar 4 2014
23:39:31:         Time: 20:26:54
23:39:31:      SVN Rev: 4130
23:39:31:       Branch: fah/trunk/client
23:39:31:     Compiler: Intel(R) C++ MSVC 1500 mode 1200
23:39:31:      Options: /TP /nologo /EHa /Qdiag-disable:4297,4103,1786,279 /Ox -arch:SSE
23:39:31:               /QaxSSE2,SSE3,SSSE3,SSE4.1,SSE4.2 /Qopenmp /Qrestrict /MT /Qmkl
23:39:31:     Platform: win32 XP
23:39:31:         Bits: 32
23:39:31:         Mode: Release
23:39:31:******************************* System ********************************
23:39:31:          CPU: Intel(R) Core(TM) i7-6950X CPU @ 3.00GHz
23:39:31:       CPU ID: GenuineIntel Family 6 Model 79 Stepping 1
23:39:31:         CPUs: 20
23:39:31:       Memory: 31.91GiB
23:39:31:  Free Memory: 29.42GiB
23:39:31:      Threads: WINDOWS_THREADS
23:39:31:   OS Version: 6.2
23:39:31:  Has Battery: false
23:39:31:   On Battery: false
23:39:31:   UTC Offset: -6
23:39:31:          PID: 1660
23:39:31:          CWD: C:/Users/David/AppData/Roaming/FAHClient
23:39:31:           OS: Windows 10 Pro
23:39:31:      OS Arch: AMD64
23:39:31:         GPUs: 0
23:39:31:         CUDA: 6.1
23:39:31:  CUDA Driver: 8000
23:39:31:Win32 Service: false
23:39:31:***********************************************************************
23:39:31:<config>
23:39:31:  <!-- Network -->
23:39:31:  <proxy v=':8080'/>
23:39:31:
23:39:31:  <!-- Slot Control -->
23:39:31:  <power v='full'/>
23:39:31:
23:39:31:  <!-- User Information -->
23:39:31:  <passkey v='********************************'/>
23:39:31:  <team v='111065'/>
23:39:31:  <user v='DMMD'/>
23:39:31:
23:39:31:  <!-- Folding Slots -->
23:39:31:  <slot id='1' type='GPU'/>
23:39:31:  <slot id='2' type='GPU'/>
23:39:31:</config>
23:39:31:Connecting to assign-GPU.stanford.edu:80
23:39:31:Updated GPUs.txt
23:39:31:Read GPUs.txt
23:39:31:Trying to access database...
23:39:31:Successfully acquired database lock
23:39:31:ERROR:Exception: No available GPUs
23:39:31:ERROR:No valid folding configuration
23:39:31:ERROR:WU00:FS01:Exception: Option 'gpu-index' has no default and is not set.
23:39:31:ERROR:WU01:FS02:Exception: Option 'gpu-index' has no default and is not set.
23:39:32:ERROR:WU00:FS01:Exception: Option 'gpu-index' has no default and is not set.
23:39:32:ERROR:WU01:FS02:Exception: Option 'gpu-index' has no default and is not set.
23:39:35:12:127.0.0.1:New Web connection
23:39:37:WARNING:23:127.0.0.1:500 HTTP INTERNAL SERVER ERROR /api/updates?_=1491953975396&sid=f7c73f091a82315f80ec83fd6136ef81: Option 'gpu-index' has no default and is not set.
23:39:37:ERROR:HTTP_INTERNAL_SERVER_ERROR: Option 'gpu-index' has no default and is not set.
23:39:40:WARNING:25:127.0.0.1:500 HTTP INTERNAL SERVER ERROR /api/updates?_=1491953975397&sid=f7c73f091a82315f80ec83fd6136ef81: Option 'gpu-index' has no default and is not set.
23:39:40:ERROR:HTTP_INTERNAL_SERVER_ERROR: Option 'gpu-index' has no default and is not set.
23:40:32:ERROR:WU00:FS01:Exception: Option 'gpu-index' has no default and is not set.
23:40:32:ERROR:WU01:FS02:Exception: Option 'gpu-index' has no default and is not set.
Mod edit: added Code tags to log
TitanXp
Re: Nvidia Titan Xp
Post by TitanXp »
0x1b02 needs to be added. I also get access is denied for my CPU since upgrading to 7.4.4.
DMMD
Re: Nvidia Titan Xp
Post by DMMD »
Additional:
Microsoft Windows [Version 10.0.15063]
(c) 2017 Microsoft Corporation. All rights reserved.
C:\Users\David>cd /usr/bin
The system cannot find the path specified.
C:\Users\David>FAHClient --lspci
0x8086:0x6f00:Intel Corporation:Intel(R) Xeon(R) E7 v4/Xeon(R) E5 v4/Xeon(R) E3 v4/Xeon(R) D DMI2 - 6F00
0x8086:0x6f98:Intel Corporation:Intel(R) Xeon(R) E7 v4/Xeon(R) E5 v4/Xeon(R) E3 v4/Xeon(R) D Power Control Unit - 6F98
0x8086:0x6faa:Intel Corporation:Intel(R) Xeon(R) E7 v4/Xeon(R) E5 v4/Xeon(R) E3 v4/Xeon(R) D Memory Controller 0 - Channel Target Address Decoder - 6FAA
0x8086:0x8d62:Intel Corporation:Standard SATA AHCI Controller
0x8086:0x6fac:Intel Corporation:Intel(R) Xeon(R) E7 v4/Xeon(R) E5 v4/Xeon(R) E3 v4/Xeon(R) D Memory Controller 0 - Channel Target Address Decoder - 6FAC
0x8086:0x6f08:Intel Corporation:Intel(R) Xeon(R) E7 v4/Xeon(R) E5 v4/Xeon(R) E3 v4/Xeon(R) D PCI Express Root Port 3 - 6F08
0x1b21:0x0612:ASMedia Technology Inc.:Standard SATA AHCI Controller
0x8086:0x8d16:Intel Corporation:Intel(R) C610 series/X99 chipset PCI Express Root Port #4 - 8D16
0x8086:0x6fbe:Intel Corporation:Intel(R) Xeon(R) E7 v4/Xeon(R) E5 v4/Xeon(R) E3 v4/Xeon(R) D DDRIO Channel 0/1 Interface - 6FBE
0x8086:0x6f76:Intel Corporation:Intel(R) Xeon(R) E7 v4/Xeon(R) E5 v4/Xeon(R) E3 v4/Xeon(R) D R3 QPI Link Debug - 6F76
0x8086:0x6f29:Intel Corporation:Intel(R) Xeon(R) E7 v4/Xeon(R) E5 v4/Xeon(R) E3 v4/Xeon(R) D IIO Hot Plug - 6F29
0x8086:0x6fb0:Intel Corporation:Intel(R) Xeon(R) E7 v4/Xeon(R) E5 v4/Xeon(R) E3 v4/Xeon(R) D Memory Controller 0 - Channel 0 Thermal Control - 6FB0
0x8086:0x6f71:Intel Corporation:Intel(R) Xeon(R) E7 v4/Xeon(R) E5 v4/Xeon(R) E3 v4/Xeon(R) D Memory Controller 0 - Target Address/Thermal/RAS - 6F71
0x8086:0x6f6e:Intel Corporation:Intel(R) Xeon(R) E7 v4/Xeon(R) E5 v4/Xeon(R) E3 v4/Xeon(R) D DDRIO Channel 2/3 Broadcast - 6F6E
0x8086:0x6fb2:Intel Corporation:Intel(R) Xeon(R) E7 v4/Xeon(R) E5 v4/Xeon(R) E3 v4/Xeon(R) D Memory Controller 0 - Channel 0 Error - 6FB2
0x8086:0x6fb4:Intel Corporation:Intel(R) Xeon(R) E7 v4/Xeon(R) E5 v4/Xeon(R) E3 v4/Xeon(R) D Memory Controller 0 - Channel 2 Thermal Control - 6FB4
0x8086:0x6f2a:Intel Corporation:Intel(R) Xeon(R) E7 v4/Xeon(R) E5 v4/Xeon(R) E3 v4/Xeon(R) D IIO RAS/Control Status/Global Errors - 6F2A
0x8086:0x6fb6:Intel Corporation:Intel(R) Xeon(R) E7 v4/Xeon(R) E5 v4/Xeon(R) E3 v4/Xeon(R) D Memory Controller 0 - Channel 2 Error - 6FB6
0x8086:0x6f1e:Intel Corporation:Intel(R) Xeon(R) E7 v4/Xeon(R) E5 v4/Xeon(R) E3 v4/Xeon(R) D Ubox - 6F1E
0x8086:0x8d7c:Intel Corporation:Intel(R) C610 series/X99 chipset SPSR - 8D7C
0x8086:0x6fe0:Intel Corporation:Intel(R) Xeon(R) E7 v4/Xeon(R) E5 v4/Xeon(R) E3 v4/Xeon(R) D Caching Agent - 6FE0
0x8086:0x8d31:Intel Corporation:USB xHCI Compliant Host Controller
0x8086:0x6fe2:Intel Corporation:Intel(R) Xeon(R) E7 v4/Xeon(R) E5 v4/Xeon(R) E3 v4/Xeon(R) D Caching Agent - 6FE2
0x8086:0x6ffd:Intel Corporation:Intel(R) Xeon(R) E7 v4/Xeon(R) E5 v4/Xeon(R) E3 v4/Xeon(R) D Caching Agent - 6FFD
0x8086:0x6fe4:Intel Corporation:Intel(R) Xeon(R) E7 v4/Xeon(R) E5 v4/Xeon(R) E3 v4/Xeon(R) D Caching Agent - 6FE4
0x8086:0x6fbb:Intel Corporation:Intel(R) Xeon(R) E7 v4/Xeon(R) E5 v4/Xeon(R) E3 v4/Xeon(R) D DDRIO Channel 2/3 Interface - 6FBB
0x8086:0x6fe6:Intel Corporation:Intel(R) Xeon(R) E7 v4/Xeon(R) E5 v4/Xeon(R) E3 v4/Xeon(R) D Caching Agent - 6FE6
0x8086:0x6fe8:Intel Corporation:Intel(R) Xeon(R) E7 v4/Xeon(R) E5 v4/Xeon(R) E3 v4/Xeon(R) D Caching Agent - 6FE8
0x10de:0x10ef:NVIDIA Corporation:High Definition Audio Controller
0x8086:0x8d3a:Intel Corporation:Intel(R) Management Engine Interface
0x8086:0x8d1c:Intel Corporation:Intel(R) C610 series/X99 chipset PCI Express Root Port #7 - 8D1C
0x8086:0x6f02:Intel Corporation:Intel(R) Xeon(R) E7 v4/Xeon(R) E5 v4/Xeon(R) E3 v4/Xeon(R) D PCI Express Root Port 1 - 6F02
0x8086:0x8d10:Intel Corporation:Intel(R) C610 series/X99 chipset PCI Express Root Port #1 - 8D10
0x8086:0x6faf:Intel Corporation:Intel(R) Xeon(R) E7 v4/Xeon(R) E5 v4/Xeon(R) E3 v4/Xeon(R) D DDRIO Global Broadcast - 6FAF
0x8086:0x8d18:Intel Corporation:Intel(R) C610 series/X99 chipset PCI Express Root Port #5 - 8D18
0x8086:0x8d47:Intel Corporation:Intel(R) C610 series/X99 chipset LPC Controller - 8D47
0x8086:0x15a1:Intel Corporation:Intel(R) Ethernet Connection (2) I218-V
0x8086:0x8d22:Intel Corporation:Intel(R) C610 series/X99 chipset SMBus Controller - 8D22
0x8086:0x6ff9:Intel Corporation:Intel(R) Xeon(R) E7 v4/Xeon(R) E5 v4/Xeon(R) E3 v4/Xeon(R) D Caching Agent - 6FF9
0x10de:0x1b02:NVIDIA Corporation:NVIDIA TITAN Xp
0x8086:0x6f8a:Intel Corporation:Intel(R) Xeon(R) E7 v4/Xeon(R) E5 v4/Xeon(R) E3 v4/Xeon(R) D Power Control Unit - 6F8A
0x8086:0x6fa0:Intel Corporation:Intel(R) Xeon(R) E7 v4/Xeon(R) E5 v4/Xeon(R) E3 v4/Xeon(R) D Home Agent 0 - 6FA0
0x8086:0x6f37:Intel Corporation:Intel(R) Xeon(R) E7 v4/Xeon(R) E5 v4/Xeon(R) E3 v4/Xeon(R) D R3 QPI Link 0/1 - 6F37
0x8086:0x6fbd:Intel Corporation:Intel(R) Xeon(R) E7 v4/Xeon(R) E5 v4/Xeon(R) E3 v4/Xeon(R) D DDRIO Channel 0/1 Interface - 6FBD
0x8086:0x6f28:Intel Corporation:Intel(R) Xeon(R) E7 v4/Xeon(R) E5 v4/Xeon(R) E3 v4/Xeon(R) D Address Map/VTd_Misc/System Management - 6F28
0x8086:0x6fa8:Intel Corporation:Intel(R) Xeon(R) E7 v4/Xeon(R) E5 v4/Xeon(R) E3 v4/Xeon(R) D Memory Controller 0 - Target Address/Thermal/RAS - 6FA8
0x144d:0xa802:Samsung Electronics Co Ltd:Standard NVM Express Controller
0x8086:0x6fb9:Intel Corporation:Intel(R) Xeon(R) E7 v4/Xeon(R) E5 v4/Xeon(R) E3 v4/Xeon(R) D DDRIO Channel 2/3 Interface - 6FB9
0x8086:0x6f04:Intel Corporation:Intel(R) Xeon(R) E7 v4/Xeon(R) E5 v4/Xeon(R) E3 v4/Xeon(R) D PCI Express Root Port 2 - 6F04
0x8086:0x6f99:Intel Corporation:Intel(R) Xeon(R) E7 v4/Xeon(R) E5 v4/Xeon(R) E3 v4/Xeon(R) D Power Control Unit - 6F99
0x8086:0x6fab:Intel Corporation:Intel(R) Xeon(R) E7 v4/Xeon(R) E5 v4/Xeon(R) E3 v4/Xeon(R) D Memory Controller 0 - Channel Target Address Decoder - 6FAB
0x8086:0x6ffc:Intel Corporation:Intel(R) Xeon(R) E7 v4/Xeon(R) E5 v4/Xeon(R) E3 v4/Xeon(R) D Caching Agent - 6FFC
0x8086:0x6fad:Intel Corporation:Intel(R) Xeon(R) E7 v4/Xeon(R) E5 v4/Xeon(R) E3 v4/Xeon(R) D Memory Controller 0 - Channel Target Address Decoder - 6FAD
0x8086:0x8d02:Intel Corporation:Standard SATA AHCI Controller
0x8086:0x6fba:Intel Corporation:Intel(R) Xeon(R) E7 v4/Xeon(R) E5 v4/Xeon(R) E3 v4/Xeon(R) D DDRIO Channel 2/3 Interface - 6FBA
0x8086:0x6f9a:Intel Corporation:Intel(R) Xeon(R) E7 v4/Xeon(R) E5 v4/Xeon(R) E3 v4/Xeon(R) D Power Control Unit - 6F9A
0x8086:0x6f9c:Intel Corporation:Intel(R) Xeon(R) E7 v4/Xeon(R) E5 v4/Xeon(R) E3 v4/Xeon(R) D Power Control Unit - 6F9C
0x8086:0x6fb1:Intel Corporation:Intel(R) Xeon(R) E7 v4/Xeon(R) E5 v4/Xeon(R) E3 v4/Xeon(R) D Memory Controller 0 - Channel 1 Thermal Control - 6FB1
0x8086:0x6fb3:Intel Corporation:Intel(R) Xeon(R) E7 v4/Xeon(R) E5 v4/Xeon(R) E3 v4/Xeon(R) D Memory Controller 0 - Channel 1 Error - 6FB3
0x1b21:0x1142:ASMedia Technology Inc.:USB xHCI Compliant Host Controller
0x8086:0x6fb5:Intel Corporation:Intel(R) Xeon(R) E7 v4/Xeon(R) E5 v4/Xeon(R) E3 v4/Xeon(R) D Memory Controller 0 - Channel 3 Thermal Control - 6FB5
0x8086:0x6f1d:Intel Corporation:Intel(R) Xeon(R) E7 v4/Xeon(R) E5 v4/Xeon(R) E3 v4/Xeon(R) D R2PCIe Agent - 6F1D
0x8086:0x6fb7:Intel Corporation:Intel(R) Xeon(R) E7 v4/Xeon(R) E5 v4/Xeon(R) E3 v4/Xeon(R) D Memory Controller 0 - Channel 3 Error - 6FB7
0x8086:0x6f1f:Intel Corporation:Intel(R) Xeon(R) E7 v4/Xeon(R) E5 v4/Xeon(R) E3 v4/Xeon(R) D Ubox - 6F1F
0x8086:0x6fe1:Intel Corporation:Intel(R) Xeon(R) E7 v4/Xeon(R) E5 v4/Xeon(R) E3 v4/Xeon(R) D Caching Agent - 6FE1
0x8086:0x6fae:Intel Corporation:Intel(R) Xeon(R) E7 v4/Xeon(R) E5 v4/Xeon(R) E3 v4/Xeon(R) D DDRIO Channel 0/1 Broadcast - 6FAE
0x8086:0x6fd0:Intel Corporation:Intel(R) Xeon(R) E7 v4/Xeon(R) E5 v4/Xeon(R) E3 v4/Xeon(R) D Memory Controller 1 - Channel 0 Thermal Control - 6FD0
0x8086:0x6fe3:Intel Corporation:Intel(R) Xeon(R) E7 v4/Xeon(R) E5 v4/Xeon(R) E3 v4/Xeon(R) D Caching Agent - 6FE3
0x8086:0x6fe5:Intel Corporation:Intel(R) Xeon(R) E7 v4/Xeon(R) E5 v4/Xeon(R) E3 v4/Xeon(R) D Caching Agent - 6FE5
0x8086:0x6fe7:Intel Corporation:Intel(R) Xeon(R) E7 v4/Xeon(R) E5 v4/Xeon(R) E3 v4/Xeon(R) D Caching Agent - 6FE7
0x8086:0x6fbf:Intel Corporation:Intel(R) Xeon(R) E7 v4/Xeon(R) E5 v4/Xeon(R) E3 v4/Xeon(R) D DDRIO Channel 0/1 Interface - 6FBF
0x8086:0x6fe9:Intel Corporation:Intel(R) Xeon(R) E7 v4/Xeon(R) E5 v4/Xeon(R) E3 v4/Xeon(R) D Caching Agent - 6FE9
0x8086:0x8d2d:Intel Corporation:Intel(R) C610 series/X99 chipset USB Enhanced Host Controller #2 - 8D2D
0x8086:0x6f7d:Intel Corporation:Intel(R) Xeon(R) E7 v4/Xeon(R) E5 v4/Xeon(R) E3 v4/Xeon(R) D Ubox - 6F7D
0x8086:0x6f6f:Intel Corporation:Intel(R) Xeon(R) E7 v4/Xeon(R) E5 v4/Xeon(R) E3 v4/Xeon(R) D DDRIO Global Broadcast - 6F6F
0x8086:0x6f88:Intel Corporation:Intel(R) Xeon(R) E7 v4/Xeon(R) E5 v4/Xeon(R) E3 v4/Xeon(R) D Power Control Unit - 6F88
0x8086:0x6fc0:Intel Corporation:Intel(R) Xeon(R) E7 v4/Xeon(R) E5 v4/Xeon(R) E3 v4/Xeon(R) D Power Control Unit - 6FC0
0x8086:0x6ffe:Intel Corporation:Intel(R) Xeon(R) E7 v4/Xeon(R) E5 v4/Xeon(R) E3 v4/Xeon(R) D Caching Agent - 6FFE
0x8086:0x6f2c:Intel Corporation:Intel(R) Xeon(R) E7 v4/Xeon(R) E5 v4/Xeon(R) E3 v4/Xeon(R) D I/O APIC - 6F2C
0x8086:0x6f81:Intel Corporation:Intel(R) Xeon(R) E7 v4/Xeon(R) E5 v4/Xeon(R) E3 v4/Xeon(R) D R3 QPI Link 0/1 - 6F81
0x8086:0x6fbc:Intel Corporation:Intel(R) Xeon(R) E7 v4/Xeon(R) E5 v4/Xeon(R) E3 v4/Xeon(R) D DDRIO Channel 0/1 Interface - 6FBC
0x14e4:0x43a0:Broadcom Corporation:Broadcom 802.11ac Network Adapter
0x8086:0x6ff8:Intel Corporation:Intel(R) Xeon(R) E7 v4/Xeon(R) E5 v4/Xeon(R) E3 v4/Xeon(R) D Caching Agent - 6FF8
0x8086:0x6fb8:Intel Corporation:Intel(R) Xeon(R) E7 v4/Xeon(R) E5 v4/Xeon(R) E3 v4/Xeon(R) D DDRIO Channel 2/3 Interface - 6FB8
0x8086:0x6f30:Intel Corporation:Intel(R) Xeon(R) E7 v4/Xeon(R) E5 v4/Xeon(R) E3 v4/Xeon(R) D Home Agent 0 - 6F30
0x8086:0x6f03:Intel Corporation:Intel(R) Xeon(R) E7 v4/Xeon(R) E5 v4/Xeon(R) E3 v4/Xeon(R) D PCI Express Root Port 1 - 6F03
0x8086:0x8d26:Intel Corporation:Intel(R) C610 series/X99 chipset USB Enhanced Host Controller #1 - 8D26
0x8086:0x6f34:Intel Corporation:Intel(R) Xeon(R) E7 v4/Xeon(R) E5 v4/Xeon(R) E3 v4/Xeon(R) D R2PCIe Agent - 6F34
0x8086:0x6f36:Intel Corporation:Intel(R) Xeon(R) E7 v4/Xeon(R) E5 v4/Xeon(R) E3 v4/Xeon(R) D R3 QPI Link 0/1 - 6F36
0x8086:0x6f68:Intel Corporation:Intel(R) Xeon(R) E7 v4/Xeon(R) E5 v4/Xeon(R) E3 v4/Xeon(R) D Target Address/Thermal/RAS - 6F68
0x8086:0x8d20:Intel Corporation:High Definition Audio Controller
Added Code tags
TitanXp
Re: Nvidia Titan Xp
Post by TitanXp »
00:08:49:INFO(1):Read GPUs.txt
00:08:52:************************* Folding@home Client *************************
00:08:52:      Website: http://folding.stanford.edu/
00:08:52:    Copyright: (c) 2009-2014 Stanford University
00:08:52:       Author: Joseph Coffland <joseph@cauldrondevelopment.com>
00:08:52:         Args:
00:08:52:       Config: C:/Program Files (x86)/FAHClient/config.xml
00:08:52:******************************** Build ********************************
00:08:52:      Version: 7.4.4
00:08:52:         Date: Mar 4 2014
00:08:52:         Time: 20:26:54
00:08:52:      SVN Rev: 4130
00:08:52:       Branch: fah/trunk/client
00:08:52:     Compiler: Intel(R) C++ MSVC 1500 mode 1200
00:08:52:      Options: /TP /nologo /EHa /Qdiag-disable:4297,4103,1786,279 /Ox -arch:SSE
00:08:52:               /QaxSSE2,SSE3,SSSE3,SSE4.1,SSE4.2 /Qopenmp /Qrestrict /MT /Qmkl
00:08:52:     Platform: win32 XP
00:08:52:         Bits: 32
00:08:52:         Mode: Release
00:08:52:******************************* System ********************************
00:08:52:          CPU: Intel(R) Core(TM) i7-5960X CPU @ 3.00GHz
00:08:52:       CPU ID: GenuineIntel Family 6 Model 63 Stepping 2
00:08:52:         CPUs: 16
00:08:52:       Memory: 31.92GiB
00:08:52:  Free Memory: 29.82GiB
00:08:52:      Threads: WINDOWS_THREADS
00:08:52:   OS Version: 6.2
00:08:52:  Has Battery: false
00:08:52:   On Battery: false
00:08:52:   UTC Offset: -5
00:08:52:          PID: 2296
00:08:52:          CWD: C:/Program Files (x86)/FAHClient
00:08:52:           OS: Windows 10 Pro
00:08:52:      OS Arch: AMD64
00:08:52:         GPUs: 0
00:08:52:         CUDA: 6.1
00:08:52:  CUDA Driver: 8000
00:08:52:Win32 Service: false
00:08:52:***********************************************************************
00:08:52:<config>
00:08:52:  <service-description v='Folding@home Client'/>
00:08:52:  <service-restart v='true'/>
00:08:52:  <service-restart-delay v='5000'/>
00:08:52:
00:08:52:  <!-- Client Control -->
00:08:52:  <client-threads v='6'/>
00:08:52:  <cycle-rate v='4'/>
00:08:52:  <cycles v='-1'/>
00:08:52:  <data-directory v='.'/>
00:08:52:  <disable-sleep-when-active v='true'/>
00:08:52:  <exec-directory v='C:\Program Files (x86)\FAHClient'/>
00:08:52:  <exit-when-done v='false'/>
00:08:52:  <fold-anon v='false'/>
00:08:52:  <open-web-control v='false'/>
00:08:52:
00:08:52:  <!-- Configuration -->
00:08:52:  <config-rotate v='true'/>
00:08:52:  <config-rotate-dir v='configs'/>
00:08:52:  <config-rotate-max v='16'/>
00:08:52:
00:08:52:  <!-- Debugging -->
00:08:52:  <assignment-servers>
00:08:52:    assign3.stanford.edu:8080 assign4.stanford.edu:80
00:08:52:  </assignment-servers>
00:08:52:  <auth-as v='true'/>
00:08:52:  <capture-directory v='capture'/>
00:08:52:  <capture-on-error v='false'/>
00:08:52:  <capture-packets v='false'/>
00:08:52:  <capture-requests v='false'/>
00:08:52:  <capture-responses v='false'/>
00:08:52:  <capture-sockets v='false'/>
00:08:52:  <core-exec v='FahCore_$type'/>
00:08:52:  <core-wrapper-exec v='FAHCoreWrapper'/>
00:08:52:  <debug-sockets v='false'/>
00:08:52:  <exception-locations v='true'/>
00:08:52:  <gpu-assignment-servers>
00:08:52:    assign-GPU.stanford.edu:80 assign-GPU2.stanford.edu:80
00:08:52:  </gpu-assignment-servers>
00:08:52:  <stack-traces v='false'/>
00:08:52:
00:08:52:  <!-- Error Handling -->
00:08:52:  <max-slot-errors v='10'/>
00:08:52:  <max-unit-errors v='5'/>
00:08:52:
00:08:52:  <!-- Folding Core -->
00:08:52:  <checkpoint v='15'/>
00:08:52:  <core-dir v='cores'/>
00:08:52:  <core-priority v='idle'/>
00:08:52:  <cpu-affinity v='false'/>
00:08:52:  <cpu-usage v='100'/>
00:08:52:  <gpu-usage v='100'/>
00:08:52:  <no-assembly v='false'/>
00:08:52:
00:08:52:  <!-- Folding Slot Configuration -->
00:08:52:  <cause v='ANY'/>
00:08:52:  <client-subtype v='STDCLI'/>
00:08:52:  <client-type v='normal'/>
00:08:52:  <cpu-species v='X86_PENTIUM_II'/>
00:08:52:  <cpu-type v='AMD64'/>
00:08:52:  <cpus v='-1'/>
00:08:52:  <gpu v='true'/>
00:08:52:  <max-packet-size v='normal'/>
00:08:52:  <os-species v='UNKNOWN'/>
00:08:52:  <os-type v='WIN32'/>
00:08:52:  <project-key v='0'/>
00:08:52:  <smp v='true'/>
00:08:52:
00:08:52:  <!-- GUI -->
00:08:52:  <gui-enabled v='true'/>
00:08:52:
00:08:52:  <!-- HTTP Server -->
00:08:52:  <allow v='127.0.0.1'/>
00:08:52:  <connection-timeout v='60'/>
00:08:52:  <deny v='0/0'/>
00:08:52:  <http-addresses v='0:7396'/>
00:08:52:  <https-addresses v=''/>
00:08:52:  <max-connect-time v='900'/>
00:08:52:  <max-connections v='800'/>
00:08:52:  <max-request-length v='52428800'/>
00:08:52:  <min-connect-time v='300'/>
00:08:52:  <threads v='16'/>
00:08:52:
00:08:52:  <!-- Logging -->
00:08:52:  <log v='log.txt'/>
00:08:52:  <log-color v='false'/>
00:08:52:  <log-crlf v='true'/>
00:08:52:  <log-date v='false'/>
00:08:52:  <log-date-periodically v='21600'/>
00:08:52:  <log-debug v='true'/>
00:08:52:  <log-domain v='false'/>
00:08:52:  <log-header v='true'/>
00:08:52:  <log-level v='true'/>
00:08:52:  <log-no-info-header v='true'/>
00:08:52:  <log-redirect v='false'/>
00:08:52:  <log-rotate v='true'/>
00:08:52:  <log-rotate-dir v='logs'/>
00:08:52:  <log-rotate-max v='16'/>
00:08:52:  <log-short-level v='false'/>
00:08:52:  <log-simple-domains v='true'/>
00:08:52:  <log-thread-id v='false'/>
00:08:52:  <log-thread-prefix v='true'/>
00:08:52:  <log-time v='true'/>
00:08:52:  <log-to-screen v='true'/>
00:08:52:  <log-truncate v='false'/>
00:08:52:  <verbosity v='5'/>
00:08:52:
00:08:52:  <!-- Network -->
00:08:52:  <proxy v=':8080'/>
00:08:52:  <proxy-enable v='false'/>
00:08:52:  <proxy-pass v=''/>
00:08:52:  <proxy-user v=''/>
00:08:52:
00:08:52:  <!-- Process Control -->
00:08:52:  <child v='false'/>
00:08:52:  <daemon v='false'/>
00:08:52:  <pid v='false'/>
00:08:52:  <pid-file v='Folding@home Client.pid'/>
00:08:52:  <respawn v='false'/>
00:08:52:  <service v='false'/>
00:08:52:
00:08:52:  <!-- Remote Command Server -->
00:08:52:  <command-address v='0.0.0.0'/>
00:08:52:  <command-allow-no-pass v='127.0.0.1'/>
00:08:52:  <command-deny-no-pass v='0/0'/>
00:08:52:  <command-enable v='true'/>
00:08:52:  <command-port v='36330'/>
00:08:52:
00:08:52:  <!-- Slot Control -->
00:08:52:  <idle v='false'/>
00:08:52:  <max-shutdown-wait v='60'/>
00:08:52:  <pause-on-battery v='false'/>
00:08:52:  <pause-on-start v='false'/>
00:08:52:  <paused v='false'/>
00:08:52:  <power v='FULL'/>
00:08:52:
00:08:52:  <!-- User Information -->
00:08:52:  <machine-id v='0'/>
00:08:52:  <passkey v='********************************'/>
00:08:52:  <team v='33'/>
00:08:52:  <user v='Sparky'/>
00:08:52:
00:08:52:  <!-- Web Server -->
00:08:52:  <web-allow v='127.0.0.1'/>
00:08:52:  <web-deny v='0/0'/>
00:08:52:  <web-enable v='true'/>
00:08:52:
00:08:52:  <!-- Web Server Sessions -->
00:08:52:  <session-cookie v='sid'/>
00:08:52:  <session-lifetime v='86400'/>
00:08:52:  <session-timeout v='3600'/>
00:08:52:
00:08:52:  <!-- Work Unit Control -->
00:08:52:  <dump-after-deadline v='true'/>
00:08:52:  <max-queue v='16'/>
00:08:52:  <max-units v='0'/>
00:08:52:  <next-unit-percentage v='99'/>
00:08:52:  <stall-detection-enabled v='false'/>
00:08:52:  <stall-percent v='5'/>
00:08:52:  <stall-timeout v='1800'/>
00:08:52:
00:08:52:  <!-- Folding Slots -->
00:08:52:  <slot id='0' type='CPU'/>
00:08:52:</config>
00:08:53:Trying to access database...
00:08:53:Successfully acquired database lock
00:08:53:Enabled folding slot 00: READY cpu:16
00:08:53:Started thread 5 on PID 2296
00:08:53:Started thread 8 on PID 2296
00:08:53:Started thread 4 on PID 2296
00:08:53:Started thread 7 on PID 2296
00:08:53:Started thread 6 on PID 2296
00:08:53:Started thread 9 on PID 2296
00:08:53:WU00:FS00:Downloading core from http://fahwebx.stanford.edu/cores/Win32/AMD64/Core_a4.fah
00:08:53:WU00:FS00:Connecting to fahwebx.stanford.edu:80
00:08:54:WU00:FS00:FahCore a4: Downloading 2.89MiB
00:08:55:WU00:FS00:FahCore a4: Download complete
00:08:56:WU00:FS00:Valid core signature
00:08:56:ERROR:WU00:FS00:Exception: Failed to open 'cores/fahwebx.stanford.edu/cores/Win32/AMD64/Core_a4.fah/FahCore_a4.exe': Failed to open 'cores/fahwebx.stanford.edu/cores/Win32/AMD64/Core_a4.fah/FahCore_a4.exe': Access is denied.
00:08:56:ERROR:WU00:FS00:: Access is denied.
00:09:53:WU00:FS00:Downloading core from http://fahwebx.stanford.edu/cores/Win32/AMD64/Core_a4.fah
00:09:53:WU00:FS00:Connecting to fahwebx.stanford.edu:80
00:09:53:WU00:FS00:FahCore a4: Downloading 2.89MiB
00:09:55:WU00:FS00:FahCore a4: Download complete
00:09:55:WU00:FS00:Valid core signature
00:09:55:ERROR:WU00:FS00:Exception: Failed to open 'cores/fahwebx.stanford.edu/cores/Win32/AMD64/Core_a4.fah/FahCore_a4.exe': Failed to open 'cores/fahwebx.stanford.edu/cores/Win32/AMD64/Core_a4.fah/FahCore_a4.exe': Access is denied.
00:09:55:ERROR:WU00:FS00:: Access is denied.
Mod edit: added Code tags to log - j
Re: Nvidia Titan Xp
DMMD wrote:Additional:
Don't try to use instructions for Linux if you're running Windows.
TitanXp wrote:Is this card supported because I can not get it to work.
Not yet, but very soon.
DO NOT start FAHClient by clicking on the program found in the Windows "Program files" directory. Microsoft prohibits FAH from putting data files there and Access should be denied there. Use the shortcut that was created during installation. If necessary, reinstall FAH with the "Just for me" setting.
And please reset verbosity to the default value before posting again.
TitanXp
Re: Nvidia Titan Xp
Post by TitanXp »
When I use the desktop shortcut the Firefox opens and times out. I also ran it with addons disabled and same thing. It also timed out in IE11 and Edge so I edit the shortcut to not open the browser which I had been doing for years since I never had the web control work. Nothing happens when I double click it.
I installed it Just for me.
edit
I reinstalled it for a 3rd time and got it to work as before. It looks like I needed to remove the open-web-control true and add open-web-control false before I edited the shortcut otherwise nothing opened.
Now I wait for the GPU support.
Re: Nvidia Titan Xp
TitanXp
Re: Nvidia Titan Xp
Post by TitanXp »
Thank you sir it works great now.
