Issue with AMDGPU and RX 480 on Linux
parkerlreed
Post by parkerlreed »
Arch x86_64
mesa-git 90619.8d919ba384-1
mesa-libgl-git 90619.8d919ba384-1
opencl-mesa-git 90619.8d919ba384-1
foldingathome 7.4.4-3
fahcontrol 7.4.4-3
fahviewer 7.4.4-2
Using the AMDGPU kernel module (OSS)
01:00.0 VGA compatible controller: Advanced Micro Devices, Inc. [AMD/ATI] Ellesmere [Radeon RX 470/480] (rev c7)
I have an XFX RX 480 8GB. It gets detected in Folding@Home but fails to initialize.
Apr 03 02:31:46 e55 FAHClient[459]: 06:31:46:WU02:FS01:Requesting new work unit for slot 01: READY gpu:0:Ellesmere XT [Radeon RX 470/480] from 171.67.108.160
Apr 03 02:31:46 e55 FAHClient[459]: 06:31:46:WU02:FS01:Connecting to 171.67.108.160:8080
Apr 03 02:31:49 e55 FAHClient[459]: 06:31:49:WU02:FS01:Downloading 2.02MiB
Apr 03 02:31:51 e55 FAHClient[459]: 06:31:51:WU02:FS01:Download complete
Apr 03 02:31:51 e55 FAHClient[459]: 06:31:51:WU02:FS01:Received Unit: id:02 state:DOWNLOAD error:NO_ERROR project:9839 run:1 clone:99 gen:10 core:0x21 unit:0x0000000bab436ca05890cac6dcc153b6
Apr 03 02:31:51 e55 FAHClient[459]: 06:31:51:WU02:FS01:Starting
Apr 03 02:31:51 e55 FAHClient[459]: 06:31:51:WU02:FS01:Running FahCore: /opt/fah/FAHCoreWrapper /opt/fah/cores/fahwebx.stanford.edu/cores/Linux/AMD64/ATI/R600/Core_21.fah/FahCore_21 -dir 02 -suffix 01 -version 704 -lifeline 459 -checkpoint 15 -gpu 0 -gpu-vendor ati
Apr 03 02:31:51 e55 FAHClient[459]: 06:31:51:WU02:FS01:Started FahCore on PID 2337
Apr 03 02:31:51 e55 FAHClient[459]: 06:31:51:WU02:FS01:Core PID:2341
Apr 03 02:31:51 e55 FAHClient[459]: 06:31:51:WU02:FS01:FahCore 0x21 started
Apr 03 02:31:51 e55 FAHClient[459]: 06:31:51:WU02:FS01:0x21:*********************** Log Started 2017-04-03T06:31:51Z ***********************
Apr 03 02:31:51 e55 FAHClient[459]: 06:31:51:WU02:FS01:0x21:Project: 9839 (Run 1, Clone 99, Gen 10)
Apr 03 02:31:51 e55 FAHClient[459]: 06:31:51:WU02:FS01:0x21:Unit: 0x0000000bab436ca05890cac6dcc153b6
Apr 03 02:31:51 e55 FAHClient[459]: 06:31:51:WU02:FS01:0x21:CPU: 0x00000000000000000000000000000000
Apr 03 02:31:51 e55 FAHClient[459]: 06:31:51:WU02:FS01:0x21:Machine: 1
Apr 03 02:31:51 e55 FAHClient[459]: 06:31:51:WU02:FS01:0x21:Reading tar file core.xml
Apr 03 02:31:51 e55 FAHClient[459]: 06:31:51:WU02:FS01:0x21:Reading tar file integrator.xml
Apr 03 02:31:51 e55 FAHClient[459]: 06:31:51:WU02:FS01:0x21:Reading tar file state.xml
Apr 03 02:31:51 e55 FAHClient[459]: 06:31:51:WU02:FS01:0x21:Reading tar file system.xml
Apr 03 02:31:52 e55 FAHClient[459]: 06:31:52:WU02:FS01:0x21:Digital signatures verified
Apr 03 02:31:52 e55 FAHClient[459]: 06:31:52:WU02:FS01:0x21:Folding@home GPU Core21 Folding@home Core
Apr 03 02:31:52 e55 FAHClient[459]: 06:31:52:WU02:FS01:0x21:Version 0.0.18
Apr 03 02:31:52 e55 FAHClient[459]: 06:31:52:WU02:FS01:0x21:ERROR:126: Bad platformId size.
Apr 03 02:31:52 e55 FAHClient[459]: 06:31:52:WU02:FS01:0x21:Saving result file logfile_01.txt
Apr 03 02:31:52 e55 FAHClient[459]: 06:31:52:WU02:FS01:0x21:Saving result file log.txt
Apr 03 02:31:52 e55 FAHClient[459]: 06:31:52:WU02:FS01:0x21:Folding@home Core Shutdown: BAD_WORK_UNIT
Apr 03 02:31:52 e55 FAHClient[459]: 06:31:52:WARNING:WU02:FS01:FahCore returned: BAD_WORK_UNIT (114 = 0x72)
Apr 03 02:31:52 e55 FAHClient[459]: 06:31:52:WU02:FS01:Sending unit results: id:02 state:SEND error:FAULTY project:9839 run:1 clone:99 gen:10 core:0x21 unit:0x0000000bab436ca05890cac6dcc153b6
Apr 03 02:31:52 e55 FAHClient[459]: 06:31:52:WU02:FS01:Uploading 2.15KiB to 171.67.108.160
Apr 03 02:31:52 e55 FAHClient[459]: 06:31:52:WU02:FS01:Connecting to 171.67.108.160:8080
Apr 03 02:31:52 e55 FAHClient[459]: 06:31:52:WU02:FS01:Upload complete
Apr 03 02:31:52 e55 FAHClient[459]: 06:31:52:WU02:FS01:Server responded WORK_ACK (400)
Apr 03 02:31:52 e55 FAHClient[459]: 06:31:52:WU02:FS01:Cleaning up
Every time I search for the bad platformid size I just get results about Nvidia drivers. Nothing about AMD. What could be causing this error?
Re: Issue with AMDGPU and RX 480 on Linux
Post by foldy »
I guess FAH does not like the mesa drivers. Maybe the official AMD drivers work better?
http://support.amd.com/en-us/kb-article ... Notes.aspx
Yes, for FAH, always the drivers downloaded from the AMD website ...
tictoc
Hardware configuration: AMD Threadripper 7960X
1x AMD Radeon 7900XTX
1x AMD Radeon 6900XT
1x AMD Radeon VII
AMD Threadripper 3960X
2x AMD Radeon VII
AMD Threadripper 2970WX
2x AMD Radeon VII
AMD Ryzen 7 5800X
2x NVIDIA RTX 3090
Post by tictoc »
You will at least need the OpenCL portion of the AMDGPU-PRO driver. If you are running Arch Linux, there is a package in the AUR, that is just the OpenCL bits of the Pro driver. https://aur.archlinux.org/packages/opencl-amd
With that package you can run the amdgpu kernel driver, and use the OpenCL bits of the Pro driver for GPU compute. The last time I tested my RX 480 in F@H, the Linux performance was very nearly on par with the Windows performance.
*Edit* Missed the date in the OP, but the information is still good, and as of right now performance of the RX 480 is very good in Linux. :D
