Windows Issues?
AuraNightheart
Windows Issues?
Post by AuraNightheart »
I installed the program last night and set it to work full load while I'm working. Checked back a bit later (it was making full use of 7 of my 8 CPU threads and about 90% of my GPU) and found that my CPU was at 0% progressed and my GPU was at about 6.5%. I also got multiple error messages from Windows saying the program has stopped working, and it never showed up on my taskbar, only in my task manager. Should I try reinstalling the program maybe? I have no idea what could have gone wrong at this point.
Specs: ASRock Z77 Extreme4, Intel i7-3770K, MSI GTX 1070 (Gaming Edition), and 16GB of DDR3-1333. I also have a 750W power supply from Antec however I doubt that matters as much.
The program web control doesn't show points, or work units, or ETAs...or anything really. Anything I can do that might fix this? (Keep in mind I have no access to the program either because it won't show up on my task bar to let me access the actual controls for CPU, GPU, etc.)
Re: Windows Issues?
Post by foldy »
Hi AuraNightheart, this is known problem in FahClient. You can fix it by either switching to FahClient 7.4.16 beta or editing the cpu slot options to limit it to 6 cpus.
Edit: Oh, you said 7 of 8 CPU cores are under full load? Then this is a different issue...
AuraNightheart
Re: Windows Issues?
I downloaded the new beta client and everything shows up now (points, etc.) My GPU is now folding too. However, my CPU is still at 0% and only says it will earn 622 points...is that normal? Whenever I stop folding and start folding, my CPU starts but then immediately stops again and I get an error message saying the program has stopped working. If I start and stop folding again, it continues to work for a few seconds before I get another error message and then the CPU goes to 0% and is yellow in the web control. Is there any solution for that? Maybe my CPU doesn't work right with the program?
Re: Windows Issues?
Post by foldy »
You could choose to disable the CPU folding slot and continue on the GPU only which generates the most PPD anyway.
Or else you need to post the logfile, see this link how to: viewtopic.php?f=24&t=26036
AuraNightheart
Re: Windows Issues?
Alright. Here's my log:
*********************** Log Started 2017-03-29T18:44:27Z ***********************
18:44:27:************************* Folding@home Client *************************
18:44:27:        Website: http://folding.stanford.edu/
18:44:27:      Copyright: (c) 2009-2016 Stanford University
18:44:27:         Author: Joseph Coffland <joseph@cauldrondevelopment.com>
18:44:27:           Args: --open-web-control
18:44:27:         Config: C:\Users\Aura\AppData\Roaming\FAHClient\config.xml
18:44:27:******************************** Build ********************************
18:44:27:        Version: 7.4.16
18:44:27:           Date: Jan 6 2017
18:44:27:           Time: 00:25:14
18:44:27:     Repository: Git
18:44:27:       Revision: a9e9e27dc2ee6ff01398c439677bc27f6cb74032
18:44:27:         Branch: master
18:44:27:       Compiler: Visual C++ 2008
18:44:27:        Options: /TP /nologo /EHa /wd4297 /wd4103 /Ox -arch:SSE /MT
18:44:27:       Platform: win32 10
18:44:27:           Bits: 32
18:44:27:           Mode: Release
18:44:27:******************************* System ********************************
18:44:27:            CPU: Intel(R) Core(TM) i7-3770K CPU @ 3.50GHz
18:44:27:         CPU ID: GenuineIntel Family 6 Model 58 Stepping 9
18:44:27:           CPUs: 8
18:44:27:         Memory: 15.90GiB
18:44:27:    Free Memory: 13.00GiB
18:44:27:        Threads: WINDOWS_THREADS
18:44:27:     OS Version: 6.2
18:44:27:    Has Battery: false
18:44:27:     On Battery: false
18:44:27:     UTC Offset: -5
18:44:27:            PID: 5980
18:44:27:            CWD: C:\Users\Aura\AppData\Roaming\FAHClient
18:44:27:             OS: Windows 8.1 Enterprise N
18:44:27:        OS Arch: AMD64
18:44:27:           GPUs: 1
18:44:27:          GPU 0: Bus:1 Slot:0 Func:0 NVIDIA:5 GP104 [GeForce GTX 1070]
18:44:27:  CUDA Device 0: Platform:0 Device:0 Bus:1 Slot:0 Compute:6.1 Driver:8.0
18:44:27:OpenCL Device 2: Platform:2 Device:0 Bus:1 Slot:0 Compute:1.2 Driver:378.78
18:44:27:  Win32 Service: false
18:44:27:***********************************************************************
18:44:27:<config>
18:44:27:  <!-- Folding Slot Configuration -->
18:44:27:  <cause v='CANCER'/>
18:44:27:
18:44:27:  <!-- Network -->
18:44:27:  <proxy v=':8080'/>
18:44:27:
18:44:27:  <!-- Slot Control -->
18:44:27:  <power v='FULL'/>
18:44:27:
18:44:27:  <!-- User Information -->
18:44:27:  <passkey v='********************************'/>
18:44:27:  <team v='225605'/>
18:44:27:  <user v='William_Foss'/>
18:44:27:
18:44:27:  <!-- Folding Slots -->
18:44:27:  <slot id='0' type='CPU'>
18:44:27:    <paused v='true'/>
18:44:27:  </slot>
18:44:27:  <slot id='1' type='GPU'>
18:44:27:  </slot>
18:44:27:</config>
18:44:27:Trying to access database...
18:44:27:Upgrading database schema from version 13 to 14
18:44:28:Successfully acquired database lock
18:44:28:Enabled folding slot 00: PAUSED cpu:7 (by user)
18:44:28:Enabled folding slot 01: PAUSED gpu:0:GP104 [GeForce GTX 1070] (by user)
18:44:31:16:127.0.0.1:New Web connection
18:44:45:FS00:Unpaused
18:44:45:FS01:Unpaused
18:44:45:WU01:FS01:Starting
18:44:45:WU01:FS01:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\Aura\AppData\Roaming\FAHClient\cores/fahwebx.stanford.edu/cores/Win32/AMD64/NVIDIA/Fermi/Core_21.fah/FahCore_21.exe -dir 01 -suffix 01 -version 704 -lifeline 5980 -checkpoint 15 -gpu-vendor nvidia -opencl-platform 2 -opencl-device 0 -cuda-device 0 -gpu 0
18:44:45:WU01:FS01:Started FahCore on PID 4212
18:44:45:WU01:FS01:Core PID:5400
18:44:45:WU01:FS01:FahCore 0x21 started
18:44:46:WU00:FS00:Connecting to 171.67.108.45:8080
18:44:46:WU01:FS01:0x21:*********************** Log Started 2017-03-29T18:44:45Z ***********************
18:44:46:WU01:FS01:0x21:Project: 9176 (Run 7, Clone 16, Gen 378)
18:44:46:WU01:FS01:0x21:Unit: 0x000001feab436c6957b24c285945fd48
18:44:46:WU01:FS01:0x21:CPU: 0x00000000000000000000000000000000
18:44:46:WU01:FS01:0x21:Machine: 1
18:44:46:WU01:FS01:0x21:Digital signatures verified
18:44:46:WU01:FS01:0x21:Folding@home GPU Core21 Folding@home Core
18:44:46:WU01:FS01:0x21:Version 0.0.18
18:44:46:WU01:FS01:0x21:  Found a checkpoint file
18:44:46:WU00:FS00:Assigned to work server 128.252.203.4
18:44:46:WU00:FS00:Requesting new work unit for slot 00: READY cpu:7 from 128.252.203.4
18:44:46:WU00:FS00:Connecting to 128.252.203.4:8080
18:44:46:WU00:FS00:Downloading 6.72MiB
18:44:49:WU00:FS00:Download complete
18:44:49:WU00:FS00:Received Unit: id:00 state:DOWNLOAD error:NO_ERROR project:13802 run:0 clone:97 gen:64 core:0xa7 unit:0x0000004880fccb04587e9470456e23ab
18:44:49:WU00:FS00:Starting
18:44:49:WARNING:WU00:FS00:AS lowered CPUs from 7 to 6
18:44:49:WU00:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\Aura\AppData\Roaming\FAHClient\cores/fahwebx.stanford.edu/cores/Win32/AMD64/AVX/Core_a7.fah/FahCore_a7.exe -dir 00 -suffix 01 -version 704 -lifeline 5980 -checkpoint 15 -np 6
18:44:49:WU00:FS00:Started FahCore on PID 1256
18:44:49:WU00:FS00:Core PID:3684
18:44:49:WU00:FS00:FahCore 0xa7 started
18:44:50:WU00:FS00:0xa7:*********************** Log Started 2017-03-29T18:44:49Z ***********************
18:44:50:WU00:FS00:0xa7:************************** Gromacs Folding@home Core ***************************
18:44:50:WU00:FS00:0xa7:       Type: 0xa7
18:44:50:WU00:FS00:0xa7:       Core: Gromacs
18:44:50:WU00:FS00:0xa7:    Website: http://folding.stanford.edu/
18:44:50:WU00:FS00:0xa7:  Copyright: (c) 2009-2016 Stanford University
18:44:50:WU00:FS00:0xa7:     Author: Joseph Coffland <joseph@cauldrondevelopment.com>
18:44:50:WU00:FS00:0xa7:       Args: -dir 00 -suffix 01 -version 704 -lifeline 1256 -checkpoint 15 -np 6
18:44:50:WU00:FS00:0xa7:     Config: <none>
18:44:50:WU00:FS00:0xa7:************************************ Build *************************************
18:44:50:WU00:FS00:0xa7:    Version: 0.0.11
18:44:50:WU00:FS00:0xa7:       Date: Sep 21 2016
18:44:50:WU00:FS00:0xa7:       Time: 01:43:48
18:44:50:WU00:FS00:0xa7: Repository: Git
18:44:50:WU00:FS00:0xa7:   Revision: 957bd90e68d95ddcf1594dc15ff6c64cc4555146
18:44:50:WU00:FS00:0xa7:     Branch: master
18:44:50:WU00:FS00:0xa7:   Compiler: GNU 4.2.1 Compatible Clang 3.9.0 (trunk 274080)
18:44:50:WU00:FS00:0xa7:    Options: -std=gnu++98 -O3 -funroll-loops -ffast-math -mfpmath=sse
18:44:50:WU00:FS00:0xa7:             -fno-unsafe-math-optimizations -msse2 -I/mingw64/include
18:44:50:WU00:FS00:0xa7:             -Wno-inconsistent-dllimport -Wno-parentheses-equality
18:44:50:WU00:FS00:0xa7:             -Wno-deprecated-register -Wno-unused-local-typedef
18:44:50:WU00:FS00:0xa7:   Platform: linux2 4.6.0-1-amd64
18:44:50:WU00:FS00:0xa7:       Bits: 64
18:44:50:WU00:FS00:0xa7:       Mode: Release
18:44:50:WU00:FS00:0xa7:       SIMD: avx_256
18:44:50:WU00:FS00:0xa7:************************************ System ************************************
18:44:50:WU00:FS00:0xa7:        CPU: Intel(R) Core(TM) i7-3770K CPU @ 3.50GHz
18:44:50:WU00:FS00:0xa7:     CPU ID: GenuineIntel Family 6 Model 58 Stepping 9
18:44:50:WU00:FS00:0xa7:       CPUs: 8
18:44:50:WU00:FS00:0xa7:     Memory: 15.90GiB
18:44:50:WU00:FS00:0xa7:Free Memory: 12.77GiB
18:44:50:WU00:FS00:0xa7:    Threads: WINDOWS_THREADS
18:44:50:WU00:FS00:0xa7: OS Version: 6.2
18:44:50:WU00:FS00:0xa7:Has Battery: false
18:44:50:WU00:FS00:0xa7: On Battery: false
18:44:50:WU00:FS00:0xa7: UTC Offset: -5
18:44:50:WU00:FS00:0xa7:        PID: 3684
18:44:50:WU00:FS00:0xa7:        CWD: C:\Users\Aura\AppData\Roaming\FAHClient\work
18:44:50:WU00:FS00:0xa7:         OS: Windows 8.1 Enterprise N
18:44:50:WU00:FS00:0xa7:    OS Arch: AMD64
18:44:50:WU00:FS00:0xa7:********************************************************************************
18:44:50:WU00:FS00:0xa7:Project: 13802 (Run 0, Clone 97, Gen 64)
18:44:50:WU00:FS00:0xa7:Unit: 0x0000004880fccb04587e9470456e23ab
18:44:50:WU00:FS00:0xa7:Reading tar file core.xml
18:44:50:WU00:FS00:0xa7:Reading tar file frame64.tpr
18:44:50:WU00:FS00:0xa7:Digital signatures verified
18:44:50:WU00:FS00:0xa7:Calling: mdrun -s frame64.tpr -o frame64.trr -x frame64.xtc -cpt 15 -nt 6
18:44:50:WU00:FS00:0xa7:ERROR:
18:44:50:WU00:FS00:0xa7:ERROR:-------------------------------------------------------
18:44:50:WU00:FS00:0xa7:ERROR:Program GROMACS, VERSION 5.0.4-20160919-669094a-unknown
18:44:50:WU00:FS00:0xa7:ERROR:Source code file: /host/windows-cross-64bit-core-a7-avx-release/gromacs-core/build/gromacs/src/programs/mdrun/runner.c, line: 879
18:44:50:WU00:FS00:0xa7:ERROR:Fatal error:
18:44:50:WU00:FS00:0xa7:ERROR:More than 1 OpenMP thread requested, but Gromacs was compiled without OpenMP support
18:44:50:WU00:FS00:0xa7:ERROR:For more information and tips for troubleshooting, please check the GROMACS
18:44:50:WU00:FS00:0xa7:ERROR:website at http://www.gromacs.org/Documentation/Errors
18:44:50:WU01:FS01:0x21:Completed 200000 out of 2500000 steps (8%)
18:44:50:WU01:FS01:0x21:Temperature control disabled. Requirements: single Nvidia GPU, tmax must be < 110 and twait >= 900
18:44:51:FS00:Shutting core down
18:44:51:WU00:FS00:0xa7:WARNING:Console control signal 1 on PID 3684
18:44:51:WU00:FS00:0xa7:Exiting, please wait. . .
18:44:55:WU00:FS00:0xa7:ERROR:
18:44:55:WU00:FS00:0xa7:ERROR:-------------------------------------------------------
18:44:55:WU00:FS00:0xa7:WARNING:Unexpected exit() call
18:44:55:WU00:FS00:0xa7:ERROR:Program GROMACS, VERSION 5.0.4-20160919-669094a-unknown
18:44:55:WU00:FS00:0xa7:ERROR:Source code file: /host/windows-cross-64bit-core-a7-avx-release/gromacs-core/build/gromacs/src/gromacs/gmxlib/gmx_omp_nthreads.c, line: 211
18:44:55:WU00:FS00:0xa7:ERROR:Fatal error:
18:44:55:WU00:FS00:0xa7:ERROR:Environment variable OMP_NUM_THREADS (8) and the number of threads requested on the command line (1) have different values. Either omit one, or set them both to the same value.
18:44:55:WU00:FS00:0xa7:ERROR:For more information and tips for troubleshooting, please check the GROMACS
18:44:55:WU00:FS00:0xa7:ERROR:website at http://www.gromacs.org/Documentation/Errors
18:44:58:WU00:FS00:FahCore returned: INTERRUPTED (102 = 0x66)
18:44:58:WU00:FS00:Starting
18:44:58:WARNING:WU00:FS00:Changed SMP threads from 7 to 6 this can cause some work units to fail
18:44:58:WU00:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\Aura\AppData\Roaming\FAHClient\cores/fahwebx.stanford.edu/cores/Win32/AMD64/AVX/Core_a7.fah/FahCore_a7.exe -dir 00 -suffix 01 -version 704 -lifeline 5980 -checkpoint 15 -np 6
18:44:58:WU00:FS00:Started FahCore on PID 2496
18:44:58:WU00:FS00:Core PID:5272
18:44:58:WU00:FS00:FahCore 0xa7 started
18:44:59:WU00:FS00:0xa7:*********************** Log Started 2017-03-29T18:44:58Z ***********************
18:44:59:WU00:FS00:0xa7:************************** Gromacs Folding@home Core ***************************
18:44:59:WU00:FS00:0xa7:       Type: 0xa7
18:44:59:WU00:FS00:0xa7:       Core: Gromacs
18:44:59:WU00:FS00:0xa7:    Website: http://folding.stanford.edu/
18:44:59:WU00:FS00:0xa7:  Copyright: (c) 2009-2016 Stanford University
18:44:59:WU00:FS00:0xa7:     Author: Joseph Coffland <joseph@cauldrondevelopment.com>
18:44:59:WU00:FS00:0xa7:       Args: -dir 00 -suffix 01 -version 704 -lifeline 2496 -checkpoint 15 -np 6
18:44:59:WU00:FS00:0xa7:     Config: <none>
18:44:59:WU00:FS00:0xa7:************************************ Build *************************************
18:44:59:WU00:FS00:0xa7:    Version: 0.0.11
18:44:59:WU00:FS00:0xa7:       Date: Sep 21 2016
18:44:59:WU00:FS00:0xa7:       Time: 01:43:48
18:44:59:WU00:FS00:0xa7: Repository: Git
18:44:59:WU00:FS00:0xa7:   Revision: 957bd90e68d95ddcf1594dc15ff6c64cc4555146
18:44:59:WU00:FS00:0xa7:     Branch: master
18:44:59:WU00:FS00:0xa7:   Compiler: GNU 4.2.1 Compatible Clang 3.9.0 (trunk 274080)
18:44:59:WU00:FS00:0xa7:    Options: -std=gnu++98 -O3 -funroll-loops -ffast-math -mfpmath=sse
18:44:59:WU00:FS00:0xa7:             -fno-unsafe-math-optimizations -msse2 -I/mingw64/include
18:44:59:WU00:FS00:0xa7:             -Wno-inconsistent-dllimport -Wno-parentheses-equality
18:44:59:WU00:FS00:0xa7:             -Wno-deprecated-register -Wno-unused-local-typedef
18:44:59:WU00:FS00:0xa7:   Platform: linux2 4.6.0-1-amd64
18:44:59:WU00:FS00:0xa7:       Bits: 64
18:44:59:WU00:FS00:0xa7:       Mode: Release
18:44:59:WU00:FS00:0xa7:       SIMD: avx_256
18:44:59:WU00:FS00:0xa7:************************************ System ************************************
18:44:59:WU00:FS00:0xa7:        CPU: Intel(R) Core(TM) i7-3770K CPU @ 3.50GHz
18:44:59:WU00:FS00:0xa7:     CPU ID: GenuineIntel Family 6 Model 58 Stepping 9
18:44:59:WU00:FS00:0xa7:       CPUs: 8
18:44:59:WU00:FS00:0xa7:     Memory: 15.90GiB
18:44:59:WU00:FS00:0xa7:Free Memory: 12.79GiB
18:44:59:WU00:FS00:0xa7:    Threads: WINDOWS_THREADS
18:44:59:WU00:FS00:0xa7: OS Version: 6.2
18:44:59:WU00:FS00:0xa7:Has Battery: false
18:44:59:WU00:FS00:0xa7: On Battery: false
18:44:59:WU00:FS00:0xa7: UTC Offset: -5
18:44:59:WU00:FS00:0xa7:        PID: 5272
18:44:59:WU00:FS00:0xa7:        CWD: C:\Users\Aura\AppData\Roaming\FAHClient\work
18:44:59:WU00:FS00:0xa7:         OS: Windows 8.1 Enterprise N
18:44:59:WU00:FS00:0xa7:    OS Arch: AMD64
18:44:59:WU00:FS00:0xa7:********************************************************************************
18:44:59:WU00:FS00:0xa7:Project: 13802 (Run 0, Clone 97, Gen 64)
18:44:59:WU00:FS00:0xa7:Unit: 0x0000004880fccb04587e9470456e23ab
18:44:59:WU00:FS00:0xa7:Reading tar file core.xml
18:44:59:WU00:FS00:0xa7:Reading tar file frame64.tpr
18:44:59:WU00:FS00:0xa7:Digital signatures verified
18:44:59:WU00:FS00:0xa7:Calling: mdrun -s frame64.tpr -o frame64.trr -x frame64.xtc -cpt 15 -nt 6
18:44:59:WU00:FS00:0xa7:ERROR:
18:44:59:WU00:FS00:0xa7:ERROR:-------------------------------------------------------
18:44:59:WU00:FS00:0xa7:ERROR:Program GROMACS, VERSION 5.0.4-20160919-669094a-unknown
18:44:59:WU00:FS00:0xa7:ERROR:Source code file: /host/windows-cross-64bit-core-a7-avx-release/gromacs-core/build/gromacs/src/programs/mdrun/runner.c, line: 879
18:44:59:WU00:FS00:0xa7:ERROR:Fatal error:
18:44:59:WU00:FS00:0xa7:ERROR:More than 1 OpenMP thread requested, but Gromacs was compiled without OpenMP support
18:44:59:WU00:FS00:0xa7:ERROR:For more information and tips for troubleshooting, please check the GROMACS
18:44:59:WU00:FS00:0xa7:ERROR:website at http://www.gromacs.org/Documentation/Errors
18:45:01:FS00:Shutting core down
18:45:01:WU00:FS00:0xa7:WARNING:Console control signal 1 on PID 5272
18:45:01:WU00:FS00:0xa7:Exiting, please wait. . .
18:45:03:WU00:FS00:0xa7:ERROR:
18:45:03:WU00:FS00:0xa7:WARNING:Unexpected exit() call
18:45:03:WU00:FS00:0xa7:ERROR:-------------------------------------------------------
18:45:03:WU00:FS00:0xa7:ERROR:Program GROMACS, VERSION 5.0.4-20160919-669094a-unknown
18:45:03:WU00:FS00:0xa7:ERROR:Source code file: /host/windows-cross-64bit-core-a7-avx-release/gromacs-core/build/gromacs/src/gromacs/gmxlib/gmx_omp_nthreads.c, line: 211
18:45:03:WU00:FS00:0xa7:ERROR:Fatal error:
18:45:03:WU00:FS00:0xa7:ERROR:Environment variable OMP_NUM_THREADS (8) and the number of threads requested on the command line (1) have different values. Either omit one, or set them both to the same value.
18:45:04:WU00:FS00:0xa7:ERROR:Environment variable OMP_NUM_THREADS (8) and the number of threads requested on the command line (1) have different values. Either omit one, or set them both to the same value.
18:45:04:WU00:FS00:0xa7:ERROR:For more information and tips for troubleshooting, please check the GROMACS
18:45:04:WU00:FS00:0xa7:ERROR:website at http://www.gromacs.org/Documentation/Errors
18:45:04:WU00:FS00:0xa7:ERROR:-------------------------------------------------------
18:45:10:WU00:FS00:FahCore returned: INTERRUPTED (102 = 0x66)
18:45:29:Saving configuration to config.xml
18:45:29:<config>
18:45:29:  <!-- Folding Slot Configuration -->
18:45:29:  <cause v='CANCER'/>
18:45:29:
18:45:29:  <!-- Network -->
18:45:29:  <proxy v=':8080'/>
18:45:29:
18:45:29:  <!-- Slot Control -->
18:45:29:  <power v='FULL'/>
18:45:29:
18:45:29:  <!-- User Information -->
18:45:29:  <passkey v='********************************'/>
18:45:29:  <team v='225605'/>
18:45:29:  <user v='William_Foss'/>
18:45:29:
18:45:29:  <!-- Folding Slots -->
18:45:29:  <slot id='0' type='CPU'/>
18:45:29:  <slot id='1' type='GPU'/>
18:45:29:</config>
18:45:30:FS00:Paused
18:45:30:FS01:Paused
18:45:30:FS01:Shutting core down
18:45:30:WU01:FS01:0x21:WARNING:Console control signal 1 on PID 5400
18:45:30:WU01:FS01:0x21:Exiting, please wait. . .
18:45:30:WU01:FS01:FahCore returned: INTERRUPTED (102 = 0x66)
18:45:32:FS00:Unpaused
18:45:32:FS01:Unpaused
18:45:32:WU01:FS01:Starting
18:45:32:WU01:FS01:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\Aura\AppData\Roaming\FAHClient\cores/fahwebx.stanford.edu/cores/Win32/AMD64/NVIDIA/Fermi/Core_21.fah/FahCore_21.exe -dir 01 -suffix 01 -version 704 -lifeline 5980 -checkpoint 15 -gpu-vendor nvidia -opencl-platform 2 -opencl-device 0 -cuda-device 0 -gpu 0
18:45:32:WU01:FS01:Started FahCore on PID 2776
18:45:32:WU01:FS01:Core PID:2476
18:45:32:WU01:FS01:FahCore 0x21 started
18:45:32:WU01:FS01:0x21:*********************** Log Started 2017-03-29T18:45:32Z ***********************
18:45:32:WU01:FS01:0x21:Project: 9176 (Run 7, Clone 16, Gen 378)
18:45:32:WU01:FS01:0x21:Unit: 0x000001feab436c6957b24c285945fd48
18:45:32:WU01:FS01:0x21:CPU: 0x00000000000000000000000000000000
18:45:32:WU01:FS01:0x21:Machine: 1
18:45:32:WU01:FS01:0x21:Digital signatures verified
18:45:32:WU01:FS01:0x21:Folding@home GPU Core21 Folding@home Core
18:45:32:WU01:FS01:0x21:Version 0.0.18
18:45:32:WU01:FS01:0x21:  Found a checkpoint file
18:45:37:WU01:FS01:0x21:Completed 200000 out of 2500000 steps (8%)
18:45:37:WU01:FS01:0x21:Temperature control disabled. Requirements: single Nvidia GPU, tmax must be < 110 and twait >= 900
18:45:58:WU00:FS00:Starting
18:45:58:WARNING:WU00:FS00:Changed SMP threads from 6 to 7 this can cause some work units to fail
18:45:58:WARNING:WU00:FS00:AS lowered CPUs from 7 to 6
18:45:58:WU00:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\Aura\AppData\Roaming\FAHClient\cores/fahwebx.stanford.edu/cores/Win32/AMD64/AVX/Core_a7.fah/FahCore_a7.exe -dir 00 -suffix 01 -version 704 -lifeline 5980 -checkpoint 15 -np 6
18:45:58:WU00:FS00:Started FahCore on PID 4944
18:45:58:WU00:FS00:Core PID:3004
18:45:58:WU00:FS00:FahCore 0xa7 started
18:45:59:WU00:FS00:0xa7:*********************** Log Started 2017-03-29T18:45:58Z ***********************
18:45:59:WU00:FS00:0xa7:************************** Gromacs Folding@home Core ***************************
18:45:59:WU00:FS00:0xa7:       Type: 0xa7
18:45:59:WU00:FS00:0xa7:       Core: Gromacs
18:45:59:WU00:FS00:0xa7:    Website: http://folding.stanford.edu/
18:45:59:WU00:FS00:0xa7:  Copyright: (c) 2009-2016 Stanford University
18:45:59:WU00:FS00:0xa7:     Author: Joseph Coffland <joseph@cauldrondevelopment.com>
18:45:59:WU00:FS00:0xa7:       Args: -dir 00 -suffix 01 -version 704 -lifeline 4944 -checkpoint 15 -np 6
18:45:59:WU00:FS00:0xa7:     Config: <none>
18:45:59:WU00:FS00:0xa7:************************************ Build *************************************
18:45:59:WU00:FS00:0xa7:    Version: 0.0.11
18:45:59:WU00:FS00:0xa7:       Date: Sep 21 2016
18:45:59:WU00:FS00:0xa7:       Time: 01:43:48
18:45:59:WU00:FS00:0xa7: Repository: Git
18:45:59:WU00:FS00:0xa7:   Revision: 957bd90e68d95ddcf1594dc15ff6c64cc4555146
18:45:59:WU00:FS00:0xa7:     Branch: master
18:45:59:WU00:FS00:0xa7:   Compiler: GNU 4.2.1 Compatible Clang 3.9.0 (trunk 274080)
18:45:59:WU00:FS00:0xa7:    Options: -std=gnu++98 -O3 -funroll-loops -ffast-math -mfpmath=sse
18:45:59:WU00:FS00:0xa7:             -fno-unsafe-math-optimizations -msse2 -I/mingw64/include
18:45:59:WU00:FS00:0xa7:             -Wno-inconsistent-dllimport -Wno-parentheses-equality
18:45:59:WU00:FS00:0xa7:             -Wno-deprecated-register -Wno-unused-local-typedef
18:45:59:WU00:FS00:0xa7:   Platform: linux2 4.6.0-1-amd64
18:45:59:WU00:FS00:0xa7:       Bits: 64
18:45:59:WU00:FS00:0xa7:       Mode: Release
18:45:59:WU00:FS00:0xa7:       SIMD: avx_256
18:45:59:WU00:FS00:0xa7:************************************ System ************************************
18:45:59:WU00:FS00:0xa7:        CPU: Intel(R) Core(TM) i7-3770K CPU @ 3.50GHz
18:45:59:WU00:FS00:0xa7:     CPU ID: GenuineIntel Family 6 Model 58 Stepping 9
18:45:59:WU00:FS00:0xa7:       CPUs: 8
18:45:59:WU00:FS00:0xa7:     Memory: 15.90GiB
18:45:59:WU00:FS00:0xa7:Free Memory: 12.77GiB
18:45:59:WU00:FS00:0xa7:    Threads: WINDOWS_THREADS
18:45:59:WU00:FS00:0xa7: OS Version: 6.2
18:45:59:WU00:FS00:0xa7:Has Battery: false
18:45:59:WU00:FS00:0xa7: On Battery: false
18:45:59:WU00:FS00:0xa7: UTC Offset: -5
18:45:59:WU00:FS00:0xa7:        PID: 3004
18:45:59:WU00:FS00:0xa7:        CWD: C:\Users\Aura\AppData\Roaming\FAHClient\work
18:45:59:WU00:FS00:0xa7:         OS: Windows 8.1 Enterprise N
18:45:59:WU00:FS00:0xa7:    OS Arch: AMD64
18:45:59:WU00:FS00:0xa7:********************************************************************************
18:45:59:WU00:FS00:0xa7:Project: 13802 (Run 0, Clone 97, Gen 64)
18:45:59:WU00:FS00:0xa7:Unit: 0x0000004880fccb04587e9470456e23ab
18:45:59:WU00:FS00:0xa7:Reading tar file core.xml
18:45:59:WU00:FS00:0xa7:Reading tar file frame64.tpr
18:45:59:WU00:FS00:0xa7:Digital signatures verified
18:45:59:WU00:FS00:0xa7:Calling: mdrun -s frame64.tpr -o frame64.trr -x frame64.xtc -cpt 15 -nt 6
18:45:59:WU00:FS00:0xa7:ERROR:
18:45:59:WU00:FS00:0xa7:ERROR:-------------------------------------------------------
18:45:59:WU00:FS00:0xa7:ERROR:Program GROMACS, VERSION 5.0.4-20160919-669094a-unknown
18:45:59:WU00:FS00:0xa7:ERROR:Source code file: /host/windows-cross-64bit-core-a7-avx-release/gromacs-core/build/gromacs/src/programs/mdrun/runner.c, line: 879
18:45:59:WU00:FS00:0xa7:ERROR:Fatal error:
18:45:59:WU00:FS00:0xa7:ERROR:More than 1 OpenMP thread requested, but Gromacs was compiled without OpenMP support
18:45:59:WU00:FS00:0xa7:ERROR:For more information and tips for troubleshooting, please check the GROMACS
18:45:59:WU00:FS00:0xa7:ERROR:website at http://www.gromacs.org/Documentation/Errors
18:46:04:WU00:FS00:0xa7:ERROR:
18:46:04:WU00:FS00:0xa7:WARNING:Unexpected exit() call
18:46:04:WU00:FS00:0xa7:ERROR:-------------------------------------------------------
18:46:04:WU00:FS00:0xa7:ERROR:Program GROMACS, VERSION 5.0.4-20160919-669094a-unknown
18:46:04:WU00:FS00:0xa7:ERROR:Source code file: /host/windows-cross-64bit-core-a7-avx-release/gromacs-core/build/gromacs/src/gromacs/gmxlib/gmx_omp_nthreads.c, line: 211
18:46:04:WU00:FS00:0xa7:ERROR:Fatal error:
18:46:04:WU00:FS00:0xa7:ERROR:Environment variable OMP_NUM_THREADS (8) and the number of threads requested on the command line (1) have different values. Either omit one, or set them both to the same value.
18:46:04:WU00:FS00:0xa7:ERROR:For more information and tips for troubleshooting, please check the GROMACS
18:46:04:WU00:FS00:0xa7:ERROR:website at http://www.gromacs.org/Documentation/Errors
18:46:09:WARNING:WU00:FS00:FahCore returned an unknown error code which probably indicates that it crashed
18:46:09:WARNING:WU00:FS00:FahCore returned: UNKNOWN_ENUM (-1073741784 = 0xc0000028)
18:46:46:WU01:FS01:0x21:Completed 225000 out of 2500000 steps (9%)
18:46:58:WU00:FS00:Starting
18:46:58:WARNING:WU00:FS00:AS lowered CPUs from 7 to 6
18:46:58:WU00:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\Aura\AppData\Roaming\FAHClient\cores/fahwebx.stanford.edu/cores/Win32/AMD64/AVX/Core_a7.fah/FahCore_a7.exe -dir 00 -suffix 01 -version 704 -lifeline 5980 -checkpoint 15 -np 6
18:46:58:WU00:FS00:Started FahCore on PID 5452
18:46:58:WU00:FS00:Core PID:4616
18:46:58:WU00:FS00:FahCore 0xa7 started
18:46:59:WU00:FS00:0xa7:*********************** Log Started 2017-03-29T18:46:58Z ***********************
18:46:59:WU00:FS00:0xa7:************************** Gromacs Folding@home Core ***************************
18:46:59:WU00:FS00:0xa7:       Type: 0xa7
18:46:59:WU00:FS00:0xa7:       Core: Gromacs
18:46:59:WU00:FS00:0xa7:    Website: http://folding.stanford.edu/
18:46:59:WU00:FS00:0xa7:  Copyright: (c) 2009-2016 Stanford University
18:46:59:WU00:FS00:0xa7:     Author: Joseph Coffland <joseph@cauldrondevelopment.com>
18:46:59:WU00:FS00:0xa7:       Args: -dir 00 -suffix 01 -version 704 -lifeline 5452 -checkpoint 15 -np 6
18:46:59:WU00:FS00:0xa7:     Config: <none>
18:46:59:WU00:FS00:0xa7:************************************ Build *************************************
18:46:59:WU00:FS00:0xa7:    Version: 0.0.11
18:46:59:WU00:FS00:0xa7:       Date: Sep 21 2016
18:46:59:WU00:FS00:0xa7:       Time: 01:43:48
18:46:59:WU00:FS00:0xa7: Repository: Git
18:46:59:WU00:FS00:0xa7:   Revision: 957bd90e68d95ddcf1594dc15ff6c64cc4555146
18:46:59:WU00:FS00:0xa7:     Branch: master
18:46:59:WU00:FS00:0xa7:   Compiler: GNU 4.2.1 Compatible Clang 3.9.0 (trunk 274080)
18:46:59:WU00:FS00:0xa7:    Options: -std=gnu++98 -O3 -funroll-loops -ffast-math -mfpmath=sse
18:46:59:WU00:FS00:0xa7:             -fno-unsafe-math-optimizations -msse2 -I/mingw64/include
18:46:59:WU00:FS00:0xa7:             -Wno-inconsistent-dllimport -Wno-parentheses-equality
18:46:59:WU00:FS00:0xa7:             -Wno-deprecated-register -Wno-unused-local-typedef
18:46:59:WU00:FS00:0xa7:   Platform: linux2 4.6.0-1-amd64
18:46:59:WU00:FS00:0xa7:       Bits: 64
18:46:59:WU00:FS00:0xa7:       Mode: Release
18:46:59:WU00:FS00:0xa7:       SIMD: avx_256
18:46:59:WU00:FS00:0xa7:************************************ System ************************************
18:46:59:WU00:FS00:0xa7:        CPU: Intel(R) Core(TM) i7-3770K CPU @ 3.50GHz
18:46:59:WU00:FS00:0xa7:     CPU ID: GenuineIntel Family 6 Model 58 Stepping 9
18:46:59:WU00:FS00:0xa7:       CPUs: 8
18:46:59:WU00:FS00:0xa7:     Memory: 15.90GiB
18:46:59:WU00:FS00:0xa7:Free Memory: 12.78GiB
18:46:59:WU00:FS00:0xa7:    Threads: WINDOWS_THREADS
18:46:59:WU00:FS00:0xa7: OS Version: 6.2
18:46:59:WU00:FS00:0xa7:Has Battery: false
18:46:59:WU00:FS00:0xa7: On Battery: false
18:46:59:WU00:FS00:0xa7: UTC Offset: -5
18:46:59:WU00:FS00:0xa7:        PID: 4616
18:46:59:WU00:FS00:0xa7:        CWD: C:\Users\Aura\AppData\Roaming\FAHClient\work
18:46:59:WU00:FS00:0xa7:         OS: Windows 8.1 Enterprise N
18:46:59:WU00:FS00:0xa7:    OS Arch: AMD64
18:46:59:WU00:FS00:0xa7:********************************************************************************
18:46:59:WU00:FS00:0xa7:Project: 13802 (Run 0, Clone 97, Gen 64)
18:46:59:WU00:FS00:0xa7:Unit: 0x0000004880fccb04587e9470456e23ab
18:46:59:WU00:FS00:0xa7:Reading tar file core.xml
18:46:59:WU00:FS00:0xa7:Reading tar file frame64.tpr
18:46:59:WU00:FS00:0xa7:Digital signatures verified
18:46:59:WU00:FS00:0xa7:Calling: mdrun -s frame64.tpr -o frame64.trr -x frame64.xtc -cpt 15 -nt 6
18:46:59:WU00:FS00:0xa7:ERROR:
18:46:59:WU00:FS00:0xa7:ERROR:-------------------------------------------------------
18:46:59:WU00:FS00:0xa7:ERROR:Program GROMACS, VERSION 5.0.4-20160919-669094a-unknown
18:46:59:WU00:FS00:0xa7:ERROR:Source code file: /host/windows-cross-64bit-core-a7-avx-release/gromacs-core/build/gromacs/src/programs/mdrun/runner.c, line: 879
18:46:59:WU00:FS00:0xa7:ERROR:Fatal error:
18:46:59:WU00:FS00:0xa7:ERROR:More than 1 OpenMP thread requested, but Gromacs was compiled without OpenMP support
18:46:59:WU00:FS00:0xa7:ERROR:For more information and tips for troubleshooting, please check the GROMACS
18:46:59:WU00:FS00:0xa7:ERROR:website at http://www.gromacs.org/Documentation/Errors
18:47:04:WU00:FS00:0xa7:ERROR:
18:47:04:WU00:FS00:0xa7:ERROR:-------------------------------------------------------
18:47:04:WU00:FS00:0xa7:WARNING:Unexpected exit() call
18:47:04:WU00:FS00:0xa7:ERROR:Program GROMACS, VERSION 5.0.4-20160919-669094a-unknown
18:47:04:WU00:FS00:0xa7:ERROR:Source code file: /host/windows-cross-64bit-core-a7-avx-release/gromacs-core/build/gromacs/src/gromacs/gmxlib/gmx_omp_nthreads.c, line: 211
18:47:04:WU00:FS00:0xa7:ERROR:Fatal error:
18:47:04:WU00:FS00:0xa7:ERROR:Environment variable OMP_NUM_THREADS (8) and the number of threads requested on the command line (1) have different values. Either omit one, or set them both to the same value.
18:47:04:WU00:FS00:0xa7:ERROR:For more information and tips for troubleshooting, please check the GROMACS
18:47:04:WU00:FS00:0xa7:ERROR:website at http://www.gromacs.org/Documentation/Errors
18:47:08:WARNING:WU00:FS00:FahCore returned an unknown error code which probably indicates that it crashed
18:47:08:WARNING:WU00:FS00:FahCore returned: UNKNOWN_ENUM (-1073741784 = 0xc0000028)
18:47:55:WU01:FS01:0x21:Completed 250000 out of 2500000 steps (10%)
18:47:59:WU00:FS00:Starting
18:47:59:WARNING:WU00:FS00:AS lowered CPUs from 7 to 6
18:47:59:WU00:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\Aura\AppData\Roaming\FAHClient\cores/fahwebx.stanford.edu/cores/Win32/AMD64/AVX/Core_a7.fah/FahCore_a7.exe -dir 00 -suffix 01 -version 704 -lifeline 5980 -checkpoint 15 -np 6
18:47:59:WU00:FS00:Started FahCore on PID 5924
18:47:59:WU00:FS00:Core PID:3732
18:47:59:WU00:FS00:FahCore 0xa7 started
18:47:59:WU00:FS00:0xa7:*********************** Log Started 2017-03-29T18:47:59Z ***********************
18:47:59:WU00:FS00:0xa7:************************** Gromacs Folding@home Core ***************************
18:47:59:WU00:FS00:0xa7:       Type: 0xa7
18:47:59:WU00:FS00:0xa7:       Core: Gromacs
18:47:59:WU00:FS00:0xa7:    Website: http://folding.stanford.edu/
18:47:59:WU00:FS00:0xa7:  Copyright: (c) 2009-2016 Stanford University
18:47:59:WU00:FS00:0xa7:     Author: Joseph Coffland <joseph@cauldrondevelopment.com>
18:47:59:WU00:FS00:0xa7:       Args: -dir 00 -suffix 01 -version 704 -lifeline 5924 -checkpoint 15 -np 6
18:47:59:WU00:FS00:0xa7:     Config: <none>
18:47:59:WU00:FS00:0xa7:************************************ Build *************************************
18:47:59:WU00:FS00:0xa7:    Version: 0.0.11
18:47:59:WU00:FS00:0xa7:       Date: Sep 21 2016
18:47:59:WU00:FS00:0xa7:       Time: 01:43:48
18:47:59:WU00:FS00:0xa7: Repository: Git
18:47:59:WU00:FS00:0xa7:   Revision: 957bd90e68d95ddcf1594dc15ff6c64cc4555146
18:47:59:WU00:FS00:0xa7:     Branch: master
18:47:59:WU00:FS00:0xa7:   Compiler: GNU 4.2.1 Compatible Clang 3.9.0 (trunk 274080)
18:47:59:WU00:FS00:0xa7:    Options: -std=gnu++98 -O3 -funroll-loops -ffast-math -mfpmath=sse
18:47:59:WU00:FS00:0xa7:             -fno-unsafe-math-optimizations -msse2 -I/mingw64/include
18:47:59:WU00:FS00:0xa7:             -Wno-inconsistent-dllimport -Wno-parentheses-equality
18:47:59:WU00:FS00:0xa7:             -Wno-deprecated-register -Wno-unused-local-typedef
18:47:59:WU00:FS00:0xa7:   Platform: linux2 4.6.0-1-amd64
18:47:59:WU00:FS00:0xa7:       Bits: 64
18:47:59:WU00:FS00:0xa7:       Mode: Release
18:47:59:WU00:FS00:0xa7:       SIMD: avx_256
18:47:59:WU00:FS00:0xa7:************************************ System ************************************
18:47:59:WU00:FS00:0xa7:        CPU: Intel(R) Core(TM) i7-3770K CPU @ 3.50GHz
18:47:59:WU00:FS00:0xa7:     CPU ID: GenuineIntel Family 6 Model 58 Stepping 9
18:47:59:WU00:FS00:0xa7:       CPUs: 8
18:47:59:WU00:FS00:0xa7:     Memory: 15.90GiB
18:47:59:WU00:FS00:0xa7:Free Memory: 12.77GiB
18:47:59:WU00:FS00:0xa7:    Threads: WINDOWS_THREADS
18:47:59:WU00:FS00:0xa7: OS Version: 6.2
18:47:59:WU00:FS00:0xa7:Has Battery: false
18:47:59:WU00:FS00:0xa7: On Battery: false
18:47:59:WU00:FS00:0xa7: UTC Offset: -5
18:47:59:WU00:FS00:0xa7:        PID: 3732
18:47:59:WU00:FS00:0xa7:        CWD: C:\Users\Aura\AppData\Roaming\FAHClient\work
18:47:59:WU00:FS00:0xa7:         OS: Windows 8.1 Enterprise N
18:47:59:WU00:FS00:0xa7:    OS Arch: AMD64
18:47:59:WU00:FS00:0xa7:********************************************************************************
18:47:59:WU00:FS00:0xa7:Project: 13802 (Run 0, Clone 97, Gen 64)
18:47:59:WU00:FS00:0xa7:Unit: 0x0000004880fccb04587e9470456e23ab
18:47:59:WU00:FS00:0xa7:Reading tar file core.xml
18:47:59:WU00:FS00:0xa7:Reading tar file frame64.tpr
18:47:59:WU00:FS00:0xa7:Digital signatures verified
18:47:59:WU00:FS00:0xa7:Calling: mdrun -s frame64.tpr -o frame64.trr -x frame64.xtc -cpt 15 -nt 6
18:47:59:WU00:FS00:0xa7:ERROR:
18:47:59:WU00:FS00:0xa7:ERROR:-------------------------------------------------------
18:47:59:WU00:FS00:0xa7:ERROR:Program GROMACS, VERSION 5.0.4-20160919-669094a-unknown
18:47:59:WU00:FS00:0xa7:ERROR:Source code file: /host/windows-cross-64bit-core-a7-avx-release/gromacs-core/build/gromacs/src/programs/mdrun/runner.c, line: 879
18:47:59:WU00:FS00:0xa7:ERROR:Fatal error:
18:47:59:WU00:FS00:0xa7:ERROR:More than 1 OpenMP thread requested, but Gromacs was compiled without OpenMP support
18:47:59:WU00:FS00:0xa7:ERROR:For more information and tips for troubleshooting, please check the GROMACS
18:47:59:WU00:FS00:0xa7:ERROR:website at http://www.gromacs.org/Documentation/Errors
18:48:04:WU00:FS00:0xa7:ERROR:
18:48:04:WU00:FS00:0xa7:WARNING:Unexpected exit() call
18:48:04:WU00:FS00:0xa7:ERROR:-------------------------------------------------------
18:48:04:WU00:FS00:0xa7:ERROR:Program GROMACS, VERSION 5.0.4-20160919-669094a-unknown
18:48:04:WU00:FS00:0xa7:ERROR:Source code file: /host/windows-cross-64bit-core-a7-avx-release/gromacs-core/build/gromacs/src/gromacs/gmxlib/gmx_omp_nthreads.c, line: 211
18:48:04:WU00:FS00:0xa7:ERROR:Fatal error:
18:48:04:WU00:FS00:0xa7:ERROR:Environment variable OMP_NUM_THREADS (8) and the number of threads requested on the command line (1) have different values. Either omit one, or set them both to the same value.
18:48:04:WU00:FS00:0xa7:ERROR:For more information and tips for troubleshooting, please check the GROMACS
18:48:04:WU00:FS00:0xa7:ERROR:website at http://www.gromacs.org/Documentation/Errors
18:48:28:WARNING:WU00:FS00:FahCore returned: FAILED_3 (255 = 0xff)
18:48:36:FS00:Paused
18:48:36:FS01:Paused
18:48:36:FS01:Shutting core down
18:48:36:WU01:FS01:0x21:WARNING:Console control signal 1 on PID 2476
18:48:36:WU01:FS01:0x21:Exiting, please wait. . .
18:48:36:WU01:FS01:0x21:Folding@home Core Shutdown: INTERRUPTED
18:48:36:WU01:FS01:FahCore returned: INTERRUPTED (102 = 0x66)
18:49:33:Saving configuration to config.xml
18:49:33:<config>
18:49:33:  <!-- Folding Slot Configuration -->
18:49:33:  <cause v='CANCER'/>
18:49:33:
18:49:33:  <!-- Network -->
18:49:33:  <proxy v=':8080'/>
18:49:33:
18:49:33:  <!-- Slot Control -->
18:49:33:  <power v='FULL'/>
18:49:33:
18:49:33:  <!-- User Information -->
18:49:33:  <passkey v='********************************'/>
18:49:33:  <team v='225605'/>
18:49:33:  <user v='William_Foss'/>
18:49:33:
18:49:33:  <!-- Folding Slots -->
18:49:33:  <slot id='0' type='CPU'>
18:49:33:    <paused v='true'/>
18:49:33:  </slot>
18:49:33:  <slot id='1' type='GPU'>
18:49:33:  </slot>
18:49:33:</config>
Re: Windows Issues?
Post by foldy »
Ah, this is another known issue in the current cpu core.
As a work around unset the OMP_NUM_THREADS environment variable.
Windows Control Panel -> System -> Environment variables and it`s under Path for the FAH client
Then Quit the FahClient and start it again or reboot your PC.
Sorry for the inconvenience.
AuraNightheart
Re: Windows Issues?
What do you mean exactly by "unset"? Delete it? Edit it to be a number lower than 8?
Re: Windows Issues?
Post by foldy »
Rename it to "Disabled_OMP_NUM_THREADS".
I don't know if you run other applications on your system while folding?
If any other application would be affected by this then you can undo this change again.
AuraNightheart
Re: Windows Issues?
I'll often have a few tabs on Chrome open, watching YouTube or on Reddit, but nothing intensive. I usually turn off folding when I'm gaming.
I have set it to Disabled_OMP_NUM_THREADS but unfortunately I still get the same error when I tell the program to start folding, and then my CPU goes back to yellow on the program/idle.
Re: Windows Issues?
Post by foldy »
OK, Internet Browser and Games do not need this OMP_NUM_THREADS thing :-)
Now you need to restart your PC then folding on CPU will work (I hope).
AuraNightheart
Re: Windows Issues?
Thanks! Everything seems to be working now. My CPU definitely is very slow though, only 622 points per day. Thank you for your help!
Re: Windows Issues?
Post by foldy »
You're welcome! The first PPD shown are inaccurate, give it some days to ramp up the PPD.
AuraNightheart
Re: Windows Issues?
Yeah. Occasionally I get errors saying the program has stopped running, but if I reload the page it just keeps going and is fine. My CPU is now up to 29,000 and my GPU is at 11,000 so it does take some time to adjust. (Originally it was 40,000 and 12,000, but the time was also lower so I assume it takes a bit to get correct estimates).
Thank you!
Re: Windows Issues?
Post by foldy »
Did you set a passkey yet? When setting a passkey you get bonus points after some days of folding.
http://folding.stanford.edu/home/faq/faq-passkey/
Re: Windows Issues?
AuraNightheart wrote:I'll often have a few tabs on Chrome open, watching YouTube or on Reddit, but nothing intensive. I usually turn off folding when I'm gaming.
Thought it won't make a huge difference, I recommend pausing the GPU slot(s) and leaving the CPU slot running. The game should still perform nicely. (The GPU does not share resources nicely with games.) You'll still have to remember to restart the GPU slot when you finish gaming.
A better option is to configure your GPU slot to run on "idle" It will stop whenever you're doing anything (including gaming) and restart when Windows decides your system is idle.
