stuck on waiting for idle
SteveWillis
Hardware configuration: PC 1:
Linux Mint 17.3
PC2:
Linux Mint 18
Open air case
three gtx 1080,
Post by SteveWillis »
Not sure where to put this
Linux mint 17.3
client 7.4.4 since the beta wouldn't install on this version of linux
I was watching a video so set the folding slot for my main GPU to on idle by right clicking on that slot
When I finished with the video the slot refused to change back to regular folding no matter what I tried to do.
Figured I'd delete and recreate the slot but that didn't work either.
Rebooted the pc and now there is an extra work queue stuck on ready status
Not sure what I need to do
It's always something, isn't it?
FWIW
*********************** Log Started 2017-03-23T02:28:43Z ***********************
02:28:43:************************* Folding@home Client *************************
02:28:43:    Website: http://folding.stanford.edu/
02:28:43:  Copyright: (c) 2009-2014 Stanford University
02:28:43:     Author: Joseph Coffland <joseph@cauldrondevelopment.com>
02:28:43:       Args: --child --lifeline 1777 /etc/fahclient/config.xml --run-as
02:28:43:             fahclient --pid-file=/var/run/fahclient.pid --daemon
02:28:43:     Config: /etc/fahclient/config.xml
02:28:43:******************************** Build ********************************
02:28:43:    Version: 7.4.4
02:28:43:       Date: Mar 4 2014
02:28:43:       Time: 12:02:38
02:28:43:    SVN Rev: 4130
02:28:43:     Branch: fah/trunk/client
02:28:43:   Compiler: GNU 4.4.7
02:28:43:    Options: -std=gnu++98 -O3 -funroll-loops -mfpmath=sse -ffast-math
02:28:43:             -fno-unsafe-math-optimizations -msse2
02:28:43:   Platform: linux2 3.2.0-1-amd64
02:28:43:       Bits: 64
02:28:43:       Mode: Release
02:28:43:******************************* System ********************************
02:28:43:        CPU: AMD FX(tm)-8320 Eight-Core Processor
02:28:43:     CPU ID: AuthenticAMD Family 21 Model 2 Stepping 0
02:28:43:       CPUs: 8
02:28:43:     Memory: 31.32GiB
02:28:43:Free Memory: 30.71GiB
02:28:43:    Threads: POSIX_THREADS
02:28:43: OS Version: 3.19
02:28:43:Has Battery: false
02:28:43: On Battery: false
02:28:43: UTC Offset: -5
02:28:43:        PID: 1779
02:28:43:        CWD: /var/lib/fahclient
02:28:43:         OS: Linux 3.19.0-32-generic x86_64
02:28:43:    OS Arch: AMD64
02:28:43:       GPUs: 4
02:28:43:      GPU 0: NVIDIA:5 GP104 [GeForce GTX 1080]
02:28:43:      GPU 1: UNSUPPORTED: NV3 [PCI]
02:28:43:      GPU 2: NVIDIA:5 GP104 [GeForce GTX 1080]
02:28:43:      GPU 3: UNSUPPORTED: NV3 [PCI]
02:28:43:       CUDA: 6.1
02:28:43:CUDA Driver: 8000
02:28:43:***********************************************************************
02:28:43:<config>
02:28:43:  <!-- Client Control -->
02:28:43:  <fold-anon v='true'/>
02:28:43:
02:28:43:  <!-- Folding Core -->
02:28:43:  <checkpoint v='30'/>
02:28:43:
02:28:43:  <!-- Folding Slot Configuration -->
02:28:43:  <cause v='ALZHEIMERS'/>
02:28:43:
02:28:43:  <!-- Network -->
02:28:43:  <proxy v=':8080'/>
02:28:43:
02:28:43:  <!-- Slot Control -->
02:28:43:  <power v='full'/>
02:28:43:
02:28:43:  <!-- User Information -->
02:28:43:  <passkey v='********************************'/>
02:28:43:  <team v='224497'/>
02:28:43:  <user v='DarthMouse_ALL_1GD5nCZbh7gNo1SESPLT24xEd2Jsu4rTP9'/>
02:28:43:
02:28:43:  <!-- Work Unit Control -->
02:28:43:  <next-unit-percentage v='100'/>
02:28:43:
02:28:43:  <!-- Folding Slots -->
02:28:43:  <slot id='1' type='GPU'>
02:28:43:    <idle v='true'/>
02:28:43:  </slot>
02:28:43:  <slot id='0' type='GPU'/>
02:28:43:</config>
02:28:43:Switching to user fahclient
02:28:43:Trying to access database...
02:28:43:Successfully acquired database lock
02:28:43:Enabled folding slot 01: PAUSED gpu:0:GP104 [GeForce GTX 1080] (waiting for idle)
02:28:43:Enabled folding slot 00: READY gpu:2:GP104 [GeForce GTX 1080]
02:28:43:WU01:FS00:Starting
02:28:43:WU01:FS00:Running FahCore: /usr/bin/FAHCoreWrapper /var/lib/fahclient/cores/fahwebx.stanford.edu/cores/Linux/AMD64/NVIDIA/Fermi/Core_21.fah/FahCore_21 -dir 01 -suffix 01 -version 704 -lifeline 1779 -checkpoint 30 -gpu 1 -gpu-vendor nvidia
02:28:43:WU01:FS00:Started FahCore on PID 1799
02:28:43:WU01:FS00:Core PID:1803
02:28:43:WU01:FS00:FahCore 0x21 started
02:28:45:WU01:FS00:0x21:*********************** Log Started 2017-03-23T02:28:45Z ***********************
02:28:45:WU01:FS00:0x21:Project: 11429 (Run 1, Clone 15, Gen 78)
02:28:45:WU01:FS00:0x21:Unit: 0x0000005c8ca304f1575841d5a9a2d1f3
02:28:45:WU01:FS00:0x21:CPU: 0x00000000000000000000000000000000
02:28:45:WU01:FS00:0x21:Machine: 0
02:28:45:WU01:FS00:0x21:Digital signatures verified
02:28:45:WU01:FS00:0x21:Folding@home GPU Core21 Folding@home Core
02:28:45:WU01:FS00:0x21:Version 0.0.18
02:28:45:WU01:FS00:0x21:  Found a checkpoint file
02:29:20:WU01:FS00:0x21:Completed 2500000 out of 5000000 steps (50%)
02:29:20:WU01:FS00:0x21:Temperature control disabled. Requirements: single Nvidia GPU, tmax must be < 110 and twait >= 900
02:30:55:FS01:Finishing
02:31:01:WU01:FS00:0x21:Completed 2550000 out of 5000000 steps (51%)
02:31:40:FS00:Shutting core down
02:31:40:WU01:FS00:0x21:Caught signal SIGINT(2) on PID 1803
02:31:40:WU01:FS00:0x21:Exiting, please wait. . .
02:31:40:WU01:FS00:0x21:Folding@home Core Shutdown: INTERRUPTED
02:31:40:WU01:FS00:FahCore returned: INTERRUPTED (102 = 0x66)
02:31:46:Removing old file 'configs/config-20170126-013202.xml'
02:31:46:Saving configuration to /etc/fahclient/config.xml
02:31:46:<config>
02:31:46:  <!-- Client Control -->
02:31:46:  <fold-anon v='true'/>
02:31:46:
02:31:46:  <!-- Folding Core -->
02:31:46:  <checkpoint v='30'/>
02:31:46:
02:31:46:  <!-- Folding Slot Configuration -->
02:31:46:  <cause v='ALZHEIMERS'/>
02:31:46:
02:31:46:  <!-- Network -->
02:31:46:  <proxy v=':8080'/>
02:31:46:
02:31:46:  <!-- Slot Control -->
02:31:46:  <power v='light'/>
02:31:46:
02:31:46:  <!-- User Information -->
02:31:46:  <passkey v='********************************'/>
02:31:46:  <team v='224497'/>
02:31:46:  <user v='DarthMouse_ALL_1GD5nCZbh7gNo1SESPLT24xEd2Jsu4rTP9'/>
02:31:46:
02:31:46:  <!-- Work Unit Control -->
02:31:46:  <next-unit-percentage v='100'/>
02:31:46:
02:31:46:  <!-- Folding Slots -->
02:31:46:  <slot id='1' type='GPU'>
02:31:46:    <idle v='true'/>
02:31:46:  </slot>
02:31:46:  <slot id='0' type='GPU'/>
02:31:46:</config>
02:31:47:WU01:FS00:Starting
02:31:47:WU01:FS00:Running FahCore: /usr/bin/FAHCoreWrapper /var/lib/fahclient/cores/fahwebx.stanford.edu/cores/Linux/AMD64/NVIDIA/Fermi/Core_21.fah/FahCore_21 -dir 01 -suffix 01 -version 704 -lifeline 1779 -checkpoint 30 -gpu 1 -gpu-vendor nvidia
02:31:47:WU01:FS00:Started FahCore on PID 3517
02:31:47:WU01:FS00:Core PID:3521
02:31:47:WU01:FS00:FahCore 0x21 started
02:31:47:WU01:FS00:0x21:*********************** Log Started 2017-03-23T02:31:47Z ***********************
02:31:47:WU01:FS00:0x21:Project: 11429 (Run 1, Clone 15, Gen 78)
02:31:47:WU01:FS00:0x21:Unit: 0x0000005c8ca304f1575841d5a9a2d1f3
02:31:47:WU01:FS00:0x21:CPU: 0x00000000000000000000000000000000
02:31:47:WU01:FS00:0x21:Machine: 0
02:31:47:WU01:FS00:0x21:Digital signatures verified
02:31:47:WU01:FS00:0x21:Folding@home GPU Core21 Folding@home Core
02:31:47:WU01:FS00:0x21:Version 0.0.18
02:31:47:WU01:FS00:0x21:  Found a checkpoint file
02:31:53:WU01:FS00:0x21:Completed 2500000 out of 5000000 steps (50%)
02:31:53:WU01:FS00:0x21:Temperature control disabled. Requirements: single Nvidia GPU, tmax must be < 110 and twait >= 900
02:32:34:Removing old file 'configs/config-20170126-023334.xml'
02:32:34:Saving configuration to /etc/fahclient/config.xml
02:32:34:<config>
02:32:34:  <!-- Client Control -->
02:32:34:  <fold-anon v='true'/>
02:32:34:
02:32:34:  <!-- Folding Core -->
02:32:34:  <checkpoint v='30'/>
02:32:34:
02:32:34:  <!-- Folding Slot Configuration -->
02:32:34:  <cause v='ALZHEIMERS'/>
02:32:34:
02:32:34:  <!-- Network -->
02:32:34:  <proxy v=':8080'/>
02:32:34:
02:32:34:  <!-- Slot Control -->
02:32:34:  <power v='full'/>
02:32:34:
02:32:34:  <!-- User Information -->
02:32:34:  <passkey v='********************************'/>
02:32:34:  <team v='224497'/>
02:32:34:  <user v='DarthMouse_ALL_1GD5nCZbh7gNo1SESPLT24xEd2Jsu4rTP9'/>
02:32:34:
02:32:34:  <!-- Work Unit Control -->
02:32:34:  <next-unit-percentage v='100'/>
02:32:34:
02:32:34:  <!-- Folding Slots -->
02:32:34:  <slot id='0' type='GPU'/>
02:32:34:</config>
02:32:34:WARNING:WU00:Slot ID 1 no longer exists, migrating to FS00
02:32:47:Removing old file 'configs/config-20170126-023358.xml'
02:32:47:Saving configuration to /etc/fahclient/config.xml
02:32:47:<config>
02:32:47:  <!-- Client Control -->
02:32:47:  <fold-anon v='true'/>
02:32:47:
02:32:47:  <!-- Folding Core -->
02:32:47:  <checkpoint v='30'/>
02:32:47:
02:32:47:  <!-- Folding Slot Configuration -->
02:32:47:  <cause v='ALZHEIMERS'/>
02:32:47:
02:32:47:  <!-- Network -->
02:32:47:  <proxy v=':8080'/>
02:32:47:
02:32:47:  <!-- Slot Control -->
02:32:47:  <power v='full'/>
02:32:47:
02:32:47:  <!-- User Information -->
02:32:47:  <passkey v='********************************'/>
02:32:47:  <team v='224497'/>
02:32:47:  <user v='DarthMouse_ALL_1GD5nCZbh7gNo1SESPLT24xEd2Jsu4rTP9'/>
02:32:47:
02:32:47:  <!-- Work Unit Control -->
02:32:47:  <next-unit-percentage v='100'/>
02:32:47:
02:32:47:  <!-- Folding Slots -->
02:32:47:  <slot id='0' type='GPU'/>
02:32:47:</config>
02:33:05:Adding folding slot 01: READY gpu:0:GP104 [GeForce GTX 1080]
02:33:05:Removing old file 'configs/config-20170126-023435.xml'
02:33:05:Saving configuration to /etc/fahclient/config.xml
02:33:05:<config>
02:33:05:  <!-- Client Control -->
02:33:05:  <fold-anon v='true'/>
02:33:05:
02:33:05:  <!-- Folding Core -->
02:33:05:  <checkpoint v='30'/>
02:33:05:
02:33:05:  <!-- Folding Slot Configuration -->
02:33:05:  <cause v='ALZHEIMERS'/>
02:33:05:
02:33:05:  <!-- Network -->
02:33:05:  <proxy v=':8080'/>
02:33:05:
02:33:05:  <!-- Slot Control -->
02:33:05:  <power v='full'/>
02:33:05:
02:33:05:  <!-- User Information -->
02:33:05:  <passkey v='********************************'/>
02:33:05:  <team v='224497'/>
02:33:05:  <user v='DarthMouse_ALL_1GD5nCZbh7gNo1SESPLT24xEd2Jsu4rTP9'/>
02:33:05:
02:33:05:  <!-- Work Unit Control -->
02:33:05:  <next-unit-percentage v='100'/>
02:33:05:
02:33:05:  <!-- Folding Slots -->
02:33:05:  <slot id='0' type='GPU'/>
02:33:05:  <slot id='1' type='GPU'/>
02:33:05:</config>
02:33:05:WU02:FS01:Connecting to 171.67.108.45:80
02:33:06:WU02:FS01:Assigned to work server 140.163.4.242
02:33:06:WU02:FS01:Requesting new work unit for slot 01: READY gpu:0:GP104 [GeForce GTX 1080] from 140.163.4.242
02:33:06:WU02:FS01:Connecting to 140.163.4.242:8080
02:33:06:WU02:FS01:Downloading 4.14MiB
02:33:07:WU02:FS01:Download complete
02:33:07:WU02:FS01:Received Unit: id:02 state:DOWNLOAD error:NO_ERROR project:11402 run:10 clone:35 gen:150 core:0x21 unit:0x000000c58ca304f255ed4ebd76915787
02:33:07:WU02:FS01:Starting
02:33:07:WU02:FS01:Running FahCore: /usr/bin/FAHCoreWrapper /var/lib/fahclient/cores/fahwebx.stanford.edu/cores/Linux/AMD64/NVIDIA/Fermi/Core_21.fah/FahCore_21 -dir 02 -suffix 01 -version 704 -lifeline 1779 -checkpoint 30 -gpu 0 -gpu-vendor nvidia
02:33:07:WU02:FS01:Started FahCore on PID 3541
02:33:07:WU02:FS01:Core PID:3545
02:33:07:WU02:FS01:FahCore 0x21 started
02:33:07:WU02:FS01:0x21:*********************** Log Started 2017-03-23T02:33:07Z ***********************
02:33:07:WU02:FS01:0x21:Project: 11402 (Run 10, Clone 35, Gen 150)
02:33:07:WU02:FS01:0x21:Unit: 0x000000c58ca304f255ed4ebd76915787
02:33:07:WU02:FS01:0x21:CPU: 0x00000000000000000000000000000000
02:33:07:WU02:FS01:0x21:Machine: 1
02:33:07:WU02:FS01:0x21:Reading tar file core.xml
02:33:07:WU02:FS01:0x21:Reading tar file system.xml
02:33:07:WU02:FS01:0x21:Reading tar file integrator.xml
02:33:07:WU02:FS01:0x21:Reading tar file state.xml
02:33:08:WU02:FS01:0x21:Digital signatures verified
02:33:08:WU02:FS01:0x21:Folding@home GPU Core21 Folding@home Core
02:33:08:WU02:FS01:0x21:Version 0.0.18
02:33:16:WU02:FS01:0x21:Completed 0 out of 5000000 steps (0%)
02:33:16:WU02:FS01:0x21:Temperature control disabled. Requirements: single Nvidia GPU, tmax must be < 110 and twait >= 900
02:33:35:WU01:FS00:0x21:Completed 2550000 out of 5000000 steps (51%)
02:33:48:Removing old file 'configs/config-20170126-222010.xml'
02:33:48:Saving configuration to /etc/fahclient/config.xml
02:33:48:<config>
02:33:48:  <!-- Client Control -->
02:33:48:  <fold-anon v='true'/>
02:33:48:
02:33:48:  <!-- Folding Core -->
02:33:48:  <checkpoint v='30'/>
02:33:48:
02:33:48:  <!-- Folding Slot Configuration -->
02:33:48:  <cause v='ALZHEIMERS'/>
02:33:48:
02:33:48:  <!-- Network -->
02:33:48:  <proxy v=':8080'/>
02:33:48:
02:33:48:  <!-- Slot Control -->
02:33:48:  <power v='full'/>
02:33:48:
02:33:48:  <!-- User Information -->
02:33:48:  <passkey v='********************************'/>
02:33:48:  <team v='224497'/>
02:33:48:  <user v='DarthMouse_ALL_1GD5nCZbh7gNo1SESPLT24xEd2Jsu4rTP9'/>
02:33:48:
02:33:48:  <!-- Work Unit Control -->
02:33:48:  <next-unit-percentage v='100'/>
02:33:48:
02:33:48:  <!-- Folding Slots -->
02:33:48:  <slot id='0' type='GPU'/>
02:33:48:  <slot id='1' type='GPU'/>
02:33:48:</config>
02:35:16:WU02:FS01:0x21:Completed 50000 out of 5000000 steps (1%)
02:35:16:WU01:FS00:0x21:Completed 2600000 out of 5000000 steps (52%)
02:37:00:WU01:FS00:0x21:Completed 2650000 out of 5000000 steps (53%)
02:37:17:WU02:FS01:0x21:Completed 100000 out of 5000000 steps (2%)
02:38:42:WU01:FS00:0x21:Completed 2700000 out of 5000000 steps (54%)
02:39:21:WU02:FS01:0x21:Completed 150000 out of 5000000 steps (3%)
02:40:24:WU01:FS00:0x21:Completed 2750000 out of 5000000 steps (55%)
02:41:23:WU02:FS01:0x21:Completed 200000 out of 5000000 steps (4%)
02:42:08:WU01:FS00:0x21:Completed 2800000 out of 5000000 steps (56%)
02:43:26:WU02:FS01:0x21:Completed 250000 out of 5000000 steps (5%)
02:43:50:WU01:FS00:0x21:Completed 2850000 out of 5000000 steps (57%)
02:45:31:WU02:FS01:0x21:Completed 300000 out of 5000000 steps (6%)
02:45:34:WU01:FS00:0x21:Completed 2900000 out of 5000000 steps (58%)
02:47:15:WU01:FS00:0x21:Completed 2950000 out of 5000000 steps (59%)
02:47:34:WU02:FS01:0x21:Completed 350000 out of 5000000 steps (7%)
02:48:57:WU01:FS00:0x21:Completed 3000000 out of 5000000 steps (60%)
02:49:39:WU02:FS01:0x21:Completed 400000 out of 5000000 steps (8%)
02:50:41:WU01:FS00:0x21:Completed 3050000 out of 5000000 steps (61%)
02:51:41:WU02:FS01:0x21:Completed 450000 out of 5000000 steps (9%)
02:52:23:WU01:FS00:0x21:Completed 3100000 out of 5000000 steps (62%)
02:53:45:WU02:FS01:0x21:Completed 500000 out of 5000000 steps (10%)
02:54:07:WU01:FS00:0x21:Completed 3150000 out of 5000000 steps (63%)
02:55:49:WU01:FS00:0x21:Completed 3200000 out of 5000000 steps (64%)
02:55:49:WU02:FS01:0x21:Completed 550000 out of 5000000 steps (11%)
02:57:31:WU01:FS00:0x21:Completed 3250000 out of 5000000 steps (65%)
Re: stuck on waiting for idle
In the FAHControl client, go to Configure + Slots + (select 1GPU) + EDIT + (select the line that says "idle true") + remove.
Back out with OK and save. The slot will now run whether your computer is idle or not.
SteveWillis
Linux Mint 17.3
PC2:
Linux Mint 18
Open air case
three gtx 1080,
Thanks Bruce
the fundamental question is whether you want the idle setting or not. It's purpose is to (A) pause that slot when your system is active and (B) resume folding on that slot when your keyboard/mouse is not being used. That's good for video games because of B. You'll always see "waiting for idle" because you have to use your mouse to see that setting. Manually setting pause/fold works too, but you have to remember to do it every time.
SteveWillis
Linux Mint 17.3
PC2:
Linux Mint 18
Open air case
three gtx 1080,
I tried using it when I wanted to watch a video without it glitching up. I used idle instead of pause because almost without fail I forget to take it off pause when I'm finished. I do have a script set up to pause the GPUs for an hour then fold again and I guess I'll just have to use that.
