getting the most out of CPU
i run in safe mode, set checkpoint timer to 30 minutes to get the most out of cpu. anyone else doing anything to get the most? ideas, thoughts.
ChristianVirtual
Re: getting the most out of CPU
can you quantify the gain against the pain ? Have you done some comparison ?
i see no pain in booting in safemode. the gain is significant due to not having background services and processes being reduced to bare minimum. i only noticed with my eyes that work units take some hours longer to complete in normal mode.ChristianVirtual wrote:can you quantify the gain against the pain ? Have you done some comparison ?
ComputerGenie
You do know that you can turn stuff off, right?FAMAS wrote:...the gain is significant due to not having background services and processes being reduced to bare minimum..ChristianVirtual wrote:can you quantify the gain against the pain ? Have you done some comparison ?
manual override of around 150 services and 3 background processes that can be done with 1 reboot. i chose the reboot option.ComputerGenie wrote:You do know that you can turn stuff off, right?FAMAS wrote:...the gain is significant due to not having background services and processes being reduced to bare minimum..ChristianVirtual wrote:can you quantify the gain against the pain ? Have you done some comparison ?
