missing credit for several wu's [Proj's 86nn & 137nn]
I have 12 wu's that have been successfully uploaded during the last 26 hours to either server 155.247.166.219 or 155.247.166.220 that have not received credit. Here is a listing of the wu's without credit:
project 8682 r 79, c 1, g 63 155.247.166.219
project 8681 r 93, c 0, g 73 155.247.166.219
project 8630 r 0, c 699, g 42 155.247.166.219
project 8637 r 3, c 115, g 40 155.247.166.219
project 8682 r 87, c 0, g 95 155.247.166.219
project 8618 r 0, c 41, g 9 155.247.166.220
project 8693 r 0, c 112, g 119 155.247.166.220
project 8632 r 5, c 79, g 47 155.247.166.219
project 8636 r 5, c 124, g 9 155.247.166.219
project 8677 r 20, c 4, g 64 155.247.166.219
project 8619 r 0, c 244, g 35 155.247.166.220
project 8674 r 70, c 5, g 50 155.247.166.219
Re: missing credit for several wu's during last 2 days
I have sent a message to persons responsible for these WS's and checking on WU's not showing up in the stats.
One item to add, if you could just copy and paste the WU description from your log files, it makes lookup much quicker. With the description reduced to the abbreviated form you posted, each number has to be entered manually to do a lookup. Forms either like this "Project: 8627 (Run 0, Clone 394, Gen 18)" or "project:8627 run:0 clone:394 gen:18" which I copied from the beginning of a WU and the message connected to sending it in respectively are much more useful.
SteveWillis
- Hardware configuration: PC 1:
Linux Mint 17.3
PC2:
Linux Mint 18
Open air case
three gtx 1080,
How did you determine this?I have 12 wu's that have been successfully uploaded during the last 26 hours to either server 155.247.166.219 or 155.247.166.220 that have not received credit. Here is a listing of the wu's without credit:
calkapokole
- Hardware configuration: Lenovo IdeaPad Y580: Chipset Intel HM76 | Socket G2 | BIOS 2.07
Display: 15.6" | 1920x1080 | LG LP156WF1-TLC1 | TN LED | glossy
CPU: Intel Core i7-3610QM | 2.3-3.3 GHz | 6 MB L3 | 22 nm | TDP 45 W
iGPU: Intel HD Graphics 4000 (GT2) | 22 nm | 16 Unified Shaders: 1100 Mhz
dGPU: NVIDIA GeForce GTX 660M (GK107) | 28 nm:
- 384 Unified Shaders: 835@1215 MHz (45.5% OC)
- 2 GB GDDR5 128 bit: 1000@1250 (5000 effective) MHz (25% OC)
RAM: Patriot | 16 GB | DDR3 1600 MHz | 11-11-11-28-1 | Dual Channel
SSD 1: Crucial MX200 | mSATA | 250 GB | Micron 16 nm 128 Gb MLC NAND
SSD 2: Crucial MX500 | 2.5" | 2 TB | Micron 256 Gb 64L 3D TLC NAND
HDD: WD Scorpio Black WD7500BPKT | 2.5" | 750 GB | 7200 RPM | 16 MB
ODD: Samsung SN-506BB | 4 MB | BD-RE XL
WiFi: Intel Centrino Wireless-N 2200
OS: Windows 10 Pro (x64) | ForceWare 425.31 WHQL
Cooler: Zalman ZM-NC2000 - Location: Poland
The same problem here as well, missing credit for two WUs uploaded to 155.247.166.219:
1) project:8630 run:0 clone:359 gen:14
2) project:8673 run:79 clone:0 gen:53
21:09:34:WU00:FS00:0xa4:Folding@home Core Shutdown: FINISHED_UNIT
21:09:34:WU00:FS00:FahCore returned: FINISHED_UNIT (100 = 0x64)
21:09:34:WU00:FS00:Sending unit results: id:00 state:SEND error:NO_ERROR project:8630 run:0 clone:359 gen:14 core:0xa4 unit:0x000000110002894b57e3ef678a1eab7a
21:09:34:WU00:FS00:Uploading 3.22MiB to 155.247.166.219
21:09:34:WU00:FS00:Connecting to 155.247.166.219:8080
21:09:38:WU00:FS00:Upload complete
21:09:38:WU00:FS00:Server responded WORK_ACK (400)
21:09:38:WU00:FS00:Final credit estimate, 4175.00 points
04:20:57:WU00:FS00:0xa7:Folding@home Core Shutdown: FINISHED_UNIT
04:20:57:WU00:FS00:FahCore returned: FINISHED_UNIT (100 = 0x64)
04:20:57:WU00:FS00:Sending unit results: id:00 state:SEND error:NO_ERROR project:8673 run:79 clone:0 gen:53 core:0xa7 unit:0x0000003c0002894b58249cce9ee7bec9
04:20:57:WU00:FS00:Uploading 4.26MiB to 155.247.166.219
04:20:57:WU00:FS00:Connecting to 155.247.166.219:8080
04:21:06:WU00:FS00:Upload complete
04:21:07:WU00:FS00:Server responded WORK_ACK (400)
04:21:07:WU00:FS00:Final credit estimate, 2988.00 points
Here is the list of the original 12 units:
Project: 8682 (Run 79, Clone 1, Gen 63)
Project: 8681 (Run 93, Clone 0, Gen 73)
Project: 8630 (Run 0, Clone 699, Gen 42)
Project: 8637 (Run 3, Clone 115, Gen 40)
Project: 8682 (Run 87, Clone 0, Gen 95)
Project: 8618 (Run 0, Clone 41, Gen 9)
Project: 8693 (Run 0, Clone 112, Gen 119)
Project: 8632 (Run 5, Clone 79, Gen 47)
Project: 8636 (Run 5, Clone 124, Gen 9)
Project: 8677 (Run 20, Clone 4, Gen 64)
Project: 8619 (Run 0, Clone 244, Gen 35)
Project: 8674 (Run 70, Clone 5, Gen 50)
Since yesterday's post, I have an additional 6 WU's that were successfully uploaded, but no credit received:
Project: 8678 (Run 65, Clone 4, Gen 59)
Project: 8677 (Run 24, Clone 1, Gen 75)
Project: 8670 (Run 46, Clone 0, Gen 87)
Project: 8647 (Run 467, Clone 0, Gen 10)
Project: 8634 (Run 0, Clone 590, Gen 33)
Project: 8677 (Run 1, Clone 3, Gen 41)
I log the details of all successful uploads to a database and compare to what Stanford is reporting.SteveWillis wrote: How did you determine this?
SteveWillis
Linux Mint 17.3
PC2:
Linux Mint 18
Open air case
three gtx 1080,
Where do you get what Stanford is reporting? All I can find is a point total.I log the details of all successful uploads to a database and compare to what Stanford is reporting.
thanks
He's talking about what the client reports:
01:27:08:WU03:FS01:Server responded WORK_ACK (400)
01:27:08:WU03:FS01:Final credit estimate, 7600.00 points
01:27:08:WU03:FS01:Cleaning up
That information is pretty accurate except for the non-bonus results returned before the passkey/name combination is qualified with the first 10 WUs.
Access to historic data is restricted to Moderator-only.
SteveWillis
Linux Mint 17.3
PC2:
Linux Mint 18
Open air case
three gtx 1080,
So if I understand correctly his conclusions are based solely on information available in the client log file.
In my own case if I execute
grep FS00 log.txt |egrep -i "Received|Sending|final"
for each folding slot and my results show a sending and credit estimate for every download then I'm good?
Sorry if I'm just being stupid.
02:40:30:WU02:FS00:Received Unit: id:02 state:DOWNLOAD error:NO_ERROR project:9178 run:28 clone:0 gen:256 core:0x21 unit:0x0000016cab436c6957b24c2a5539c9fc
02:40:32:WU00:FS00:Final credit estimate, 28221.00 points
03:46:41:WU02:FS00:Sending unit results: id:02 state:SEND error:NO_ERROR project:9178 run:28 clone:0 gen:256 core:0x21 unit:0x0000016cab436c6957b24c2a5539c9fc
03:46:44:WU01:FS00:Received Unit: id:01 state:DOWNLOAD error:NO_ERROR project:10496 run:102 clone:4 gen:35 core:0x21 unit:0x0000002c8ca304f556bbad55656d271f
03:46:49:WU02:FS00:Final credit estimate, 48365.00 points
06:45:42:WU02:FS00:Received Unit: id:02 state:DOWNLOAD error:NO_ERROR project:13500 run:0 clone:290 gen:113 core:0x21 unit:0x000000a28ca304f457a35877601a61e7
06:45:54:WU01:FS00:Sending unit results: id:01 state:SEND error:NO_ERROR project:10496 run:102 clone:4 gen:35 core:0x21 unit:0x0000002c8ca304f556bbad55656d271f
06:47:45:WU01:FS00:Final credit estimate, 94086.00 points
09:00:19:WU02:FS00:Sending unit results: id:02 state:SEND error:NO_ERROR project:13500 run:0 clone:290 gen:113 core:0x21 unit:0x000000a28ca304f457a35877601a61e7
09:00:20:WU01:FS00:Received Unit: id:01 state:DOWNLOAD error:NO_ERROR project:9180 run:6 clone:3 gen:264 core:0x21 unit:0x00000197ab436c9f57bdce05e1ff23b7
09:00:31:WU02:FS00:Final credit estimate, 84217.00 points
10:20:00:WU01:FS00:Sending unit results: id:01 state:SEND error:NO_ERROR project:9180 run:6 clone:3 gen:264 core:0x21 unit:0x00000197ab436c9f57bdce05e1ff23b7
10:20:00:WU02:FS00:Received Unit: id:02 state:DOWNLOAD error:NO_ERROR project:9415 run:291 clone:0 gen:134 core:0x21 unit:0x0000009bab436c9d585e06cbf68ef7fd
10:20:09:WU01:FS00:Final credit estimate, 52099.00 points
11:34:15:WU02:FS00:Sending unit results: id:02 state:SEND error:NO_ERROR project:9415 run:291 clone:0 gen:134 core:0x21 unit:0x0000009bab436c9d585e06cbf68ef7fd
11:34:18:WU00:FS00:Received Unit: id:00 state:DOWNLOAD error:NO_ERROR project:9194 run:1 clone:53 gen:307 core:0x21 unit:0x000001caab40415c57cb2e5d12042c94
11:34:21:WU02:FS00:Final credit estimate, 51122.00 points
12:46:19:WU00:FS00:Sending unit results: id:00 state:SEND error:NO_ERROR project:9194 run:1 clone:53 gen:307 core:0x21 unit:0x000001caab40415c57cb2e5d12042c94
12:46:20:WU01:FS00:Received Unit: id:01 state:DOWNLOAD error:NO_ERROR project:9192 run:1 clone:82 gen:275 core:0x21 unit:0x000001b0ab40415457cb2d5ba37d9b1b
12:46:29:WU00:FS00:Final credit estimate, 41578.00 points
14:03:54:WU00:FS00:Received Unit: id:00 state:DOWNLOAD error:NO_ERROR project:9175 run:15 clone:18 gen:291 core:0x21 unit:0x000001baab436c6957b24c28771e4197
14:03:55:WU01:FS00:Sending unit results: id:01 state:SEND error:NO_ERROR project:9192 run:1 clone:82 gen:275 core:0x21 unit:0x000001b0ab40415457cb2d5ba37d9b1b
14:04:05:WU01:FS00:Final credit estimate, 44771.00 points
15:19:05:WU00:FS00:Sending unit results: id:00 state:SEND error:NO_ERROR project:9175 run:15 clone:18 gen:291 core:0x21 unit:0x000001baab436c6957b24c28771e4197
15:19:06:WU02:FS00:Received Unit: id:02 state:DOWNLOAD error:NO_ERROR project:10496 run:97 clone:5 gen:41 core:0x21 unit:0x0000003a8ca304f556bbacfef6622cc7
15:19:14:WU00:FS00:Final credit estimate, 45386.00 points
18:20:34:WU01:FS00:Received Unit: id:01 state:DOWNLOAD error:NO_ERROR project:13500 run:1 clone:147 gen:114 core:0x21 unit:0x000000ab8ca304f457a358fef027cd84
18:20:47:WU02:FS00:Sending unit results: id:02 state:SEND error:NO_ERROR project:10496 run:97 clone:5 gen:41 core:0x21 unit:0x0000003a8ca304f556bbacfef6622cc7
18:21:25:WU02:FS00:Final credit estimate, 93754.00 points
20:35:08:WU02:FS00:Received Unit: id:02 state:DOWNLOAD error:NO_ERROR project:9178 run:4 clone:8 gen:376 core:0x21 unit:0x000001faab436c6957b24c2980d5fe42
20:35:08:WU01:FS00:Sending unit results: id:01 state:SEND error:NO_ERROR project:13500 run:1 clone:147 gen:114 core:0x21 unit:0x000000ab8ca304f457a358fef027cd84
20:35:20:WU01:FS00:Final credit estimate, 84233.00 points
21:52:31:WU02:FS00:Sending unit results: id:02 state:SEND error:NO_ERROR project:9178 run:4 clone:8 gen:376 core:0x21 unit:0x000001faab436c6957b24c2980d5fe42
21:52:32:WU00:FS00:Received Unit: id:00 state:DOWNLOAD error:NO_ERROR project:10496 run:147 clone:19 gen:60 core:0x21 unit:0x0000004f8ca304f556bbb08750437671
21:52:42:WU02:FS00:Final credit estimate, 44728.00 points
00:53:05:WU01:FS00:Received Unit: id:01 state:DOWNLOAD error:NO_ERROR project:13500 run:0 clone:695 gen:119 core:0x21 unit:0x000000ac8ca304f457a358b806ef67ff
00:53:19:WU00:FS00:Sending unit results: id:00 state:SEND error:NO_ERROR project:10496 run:147 clone:19 gen:60 core:0x21 unit:0x0000004f8ca304f556bbb08750437671
00:57:00:WU00:FS00:Final credit estimate, 93211.00 points
03:07:51:WU00:FS00:Received Unit: id:00 state:DOWNLOAD error:NO_ERROR project:11710 run:2 clone:29 gen:51 core:0x21 unit:0x000000408ca304e75814df41533e4f32
03:07:51:WU01:FS00:Sending unit results: id:01 state:SEND error:NO_ERROR project:13500 run:0 clone:695 gen:119 core:0x21 unit:0x000000ac8ca304f457a358b806ef67ff
03:08:33:WU01:FS00:Final credit estimate, 84020.00 points
06:28:30:WU00:FS00:Sending unit results: id:00 state:SEND error:NO_ERROR project:11710 run:2 clone:29 gen:51 core:0x21 unit:0x000000408ca304e75814df41533e4f32
06:28:31:WU01:FS00:Received Unit: id:01 state:DOWNLOAD error:NO_ERROR project:11418 run:1 clone:71 gen:22 core:0x21 unit:0x000000198ca304f158af649913644587
06:28:41:WU00:FS00:Final credit estimate, 122263.00 points
09:25:48:WU00:FS00:Received Unit: id:00 state:DOWNLOAD error:NO_ERROR project:9839 run:0 clone:9 gen:34 core:0x21 unit:0x0000002eab436ca05890cac657c8fbb3
09:25:49:WU01:FS00:Sending unit results: id:01 state:SEND error:NO_ERROR project:11418 run:1 clone:71 gen:22 core:0x21 unit:0x000000198ca304f158af649913644587
09:26:02:WU01:FS00:Final credit estimate, 98488.00 points
10:29:29:WU00:FS00:Sending unit results: id:00 state:SEND error:NO_ERROR project:9839 run:0 clone:9 gen:34 core:0x21 unit:0x0000002eab436ca05890cac657c8fbb3
10:29:30:WU01:FS00:Received Unit: id:01 state:DOWNLOAD error:NO_ERROR project:11418 run:3 clone:47 gen:97 core:0x21 unit:0x0000007a8ca304f1570697cd339e7262
10:29:32:WU00:FS00:Final credit estimate, 28232.00 points
During the last 24 hours I have an additional 10 WU's that were successfully uploaded without credit being given. Here is the list:
Project: 8649 (Run 433, Clone 0, Gen 5)
Project: 8646 (Run 371, Clone 0, Gen 17)
Project: 8681 (Run 75, Clone 3, Gen 32)
Project: 8677 (Run 49, Clone 2, Gen 23)
Project: 8681 (Run 68, Clone 4, Gen 75)
Project: 8682 (Run 46, Clone 5, Gen 31)
Project: 8675 (Run 90, Clone 1, Gen 49)
Project: 8631 (Run 0, Clone 112, Gen 10)
Project: 8635 (Run 0, Clone 30, Gen 28)
Project: 8672 (Run 34, Clone 1, Gen 44)
During the last 24 hours, 11 additional WU's were successfully uploaded, but no credit was given. Here is a list:
Project: 13700 (Run 0, Clone 162, Gen 0)
Project: 8634 (Run 0, Clone 82, Gen 41)
Project: 8642 (Run 391, Clone 0, Gen 16)
Project: 8676 (Run 70, Clone 0, Gen 34)
Project: 8693 (Run 0, Clone 64, Gen 167)
Project: 8620 (Run 0, Clone 518, Gen 30)
Project: 8641 (Run 171, Clone 0, Gen 0)
Project: 8680 (Run 50, Clone 0, Gen 52)
Project: 8673 (Run 83, Clone 3, Gen 43)
Project: 13123 (Run 72, Clone 9, Gen 15)
Project: 8620 (Run 0, Clone 442, Gen 14)
I just started folding a few days ago and have a PC chugging away at WUs and completing them every 4-6 hours but they are not updating or giving any credit. It's my understanding that they should be updating every hour. I tried to post on the newbies thread but apparently you have to have an established account to make a new post so here I am.
These say in the logs that they were successfully uploaded yesterday but I don't have any credits for them.
project:13127 run:59 clone:6 gen:58 to 171.67.108.101
project:9037 run:452 clone:0 gen:863 to 171.67.108.158
project:8676 run:81 clone:0 gen:38 to 155.247.166.219
Am I doing something wrong or is this just a bug?
Additional examples will not be needed. The persons running projects on these 2 servers is aware of the issue and that it is happening to returns from others as well. They are looking into the problem, credits should be given once the reason is identified and corrected.
In addition, you did receive credit for:
Edit: specifically that would be projects in the 8601-8699 range and 13700-13701
The problem is only affecting returns to these two specific servers.Hi goodyca (team 439),
Your WU (P13123 R72 C9 G15) was added to the stats database on 2017-03-19 02:08:23 for 6592.8 points of credit.
Nothing you are doing, just a bug with the server that handles Project 8676. You did receive credit for the other two WU's:6-o-9 wrote:I just started folding a few days ago and have a PC chugging away at WUs and completing them every 4-6 hours but they are not updating or giving any credit. It's my understanding that they should be updating every hour. I tried to post on the newbies thread but apparently you have to have an established account to make a new post so here I am.
Once you have completed 10 WU's you should start receiving the Quick Return Bonus.Hi 6-o-9 (team 225605),
Your WU (P13127 R59 C6 G58) was added to the stats database on 2017-03-18 05:06:58 for 800 points of credit.
Your WU (P9037 R452 C0 G863) was added to the stats database on 2017-03-18 09:06:29 for 207 points of credit.
