Dual GTX 1080's
Hamltnblue
Dual GTX 1080's
Hello
Has anyone here tried running dual GTX 1080's?
If so what PPD does it get?
Also do you run SLI or just run two individual boards?
Thanks
Thanks
Nathan_P
Not currently folding
Re: Dual GTX 1080's
Hi
Running dual 1080's is not a problem - its high end due to the cost of the cards but has been done frequently. you just need plenty of cooling and a decent power supply.
You need to run it as 2 individual cards. PPD is around 800k per cards.
rwh202
3x GTX 1080 Ti
3x GTX 1060
Re: Dual GTX 1080's
Yep, 4 dual 1080 rigs here and that's correct.Nathan_P wrote:Hi
However, power and cooling aren't too onerous - a decent 650 W PSU is probably the minimum and a mid tower case with a couple of quiet intakes and exhaust fans work well enough for me.
Hamltnblue
Re: Dual GTX 1080's
Thanks
I've been running a 7770k with a 1080 on an 860watt PS.
With the 10890ti out now the 1080 cards have come down 100+ dollars.
Contemplating adding another card.
Nathan_P
Re: Dual GTX 1080's
You're not the only one, i'm just debating whether to go 1070/1080 or 1080TiHamltnblue wrote:Thanks
Re: Dual GTX 1080's
@Nathan_P: You have limited number of GPU slots and PPD/price/watt scales good with these GPUs.Nathan_P wrote:You're not the only one, i'm just debating whether to go 1070/1080 or 1080Ti
If you have the money isn't going for the fastest GPU the best option?
Nathan_P
Re: Dual GTX 1080's
It is, but sometimes its the initial hardware outlay that's the issue, not the running costs.foldy wrote:@Nathan_P: You have limited number of GPU slots and PPD/price/watt scales good with these GPUs.Nathan_P wrote:You're not the only one, i'm just debating whether to go 1070/1080 or 1080Ti
PCIe x16 slots are not a problem, I have 13 available for folding
Re: Dual GTX 1080's
@Hamltnblue: If you also want to game with dual gtx 1080 then you can leave SLI activated. But it is still 2 individual slots in FAH.
boristsybin
- Hardware configuration: 4x1080Ti + 2x1050Ti
Re: Dual GTX 1080's
1080ti is the king of money/ppd for now
dual 1080ti system (as any dual-gpu) is easy to build with nonexpensive "mainstream" psu+cpu+board platform with no ppd lost
Nathan_P
Re: Dual GTX 1080's
You will need a decent PSU, even if its only 700-750watts, so that's £80-£90 before you start, a decent mobo with 2 PCIe 3.0 x16 slots running at x8 as a minimum, the bill soon starts adding upboristsybin wrote:1080ti is the king of money/ppd for now
dual 1080ti system (as any dual-gpu) is easy to build with nonexpensive psu+cpu+board platform with no ppd lost
boristsybin
Re: Dual GTX 1080's
anyway, single "dual-1080ti system" is cheaper, simplier and smaller than two "dual-1070" or single "quarple-1070" or single "triple-1080" while producing similar ppdNathan_P wrote:You will need a decent PSU, even if its only 700-750watts, so that's £80-£90 before you start, a decent mobo with 2 PCIe 3.0 x16 slots running at x8 as a minimum, the bill soon starts adding up
same for comparison of "single-1080ti system" with "dual-1070 system"
Hamltnblue
Re: Dual GTX 1080's
Thanksfoldy wrote:@Hamltnblue: If you also want to game with dual gtx 1080 then you can leave SLI activated. But it is still 2 individual slots in FAH.
SteveWillis
- Hardware configuration: PC 1:
Linux Mint 17.3
PC2:
Linux Mint 18
Open air case
three gtx 1080,
Re: Dual GTX 1080's
I'm running three 1080s, a 960 and a 750ti on my folding rig. 1000 watt psu and have about 100 watts headroom.
ComputerGenie
Re: Dual GTX 1080's
What MB are you using for that setup?SteveWillis wrote:I'm running three 1080s, a 960 and a 750ti on my folding rig. 1000 watt psu and have about 100 watts headroom.
SteveWillis
Linux Mint 17.3
PC2:
Linux Mint 18
Open air case
three gtx 1080,
Re: Dual GTX 1080's
ASUS Crosshair V Formula-Z AM3+ AMD 990FX SATA 6Gb/s USB 3.0 ATX AMD Motherboard
Not sure of my PPD on that rig. That rig and another two 1080s gives me just under 4M daily
