16:37:18:WU01:FS00:Connecting to 171.67.108.45:8080
16:37:19:WU01:FS00:Assigned to work server 171.67.108.101
16:37:19:WU01:FS00:Requesting new work unit for slot 00: RUNNING cpu:4 from 171.67.108.101
16:37:19:WU01:FS00:Connecting to 171.67.108.101:8080
16:37:21:WU01:FS00:Downloading 2.95MiB
16:37:24:WU01:FS00:Download complete
16:37:25:WU01:FS00:Received Unit: id:01 state:DOWNLOAD error:NO_ERROR project:13126 run:77 clone:7 gen:23 core:0xa7 unit:0x0000001bab436c655898c998e9514d98
16:39:05:WU01:FS00:Starting
16:39:05:WU00:FS00:Connecting to 171.67.108.101:8080
16:39:05:WU01:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:\Users\david\AppData\Roaming\FAHClient\cores/fahwebx.stanford.edu/cores/Win32/AMD64/AVX/beta/Core_a7.fah/FahCore_a7.exe -dir 01 -suffix 01 -version 704 -lifeline 6472 -checkpoint 15 -np 4
16:39:06:WU01:FS00:Started FahCore on PID 6664
16:39:06:WU01:FS00:Core PID:3376
16:39:06:WU01:FS00:FahCore 0xa7 started
16:39:07:WU01:FS00:0xa7:*********************** Log Started 2017-03-04T16:39:07Z ***********************
16:39:07:WU01:FS00:0xa7:************************** Gromacs Folding@home Core ***************************
16:39:07:WU01:FS00:0xa7: Type: 0xa7
16:39:07:WU01:FS00:0xa7: Core: Gromacs
16:39:07:WU01:FS00:0xa7: Website: http://folding.stanford.edu/
16:39:07:WU01:FS00:0xa7: Copyright: (c) 2009-2016 Stanford University
16:39:07:WU01:FS00:0xa7: Author: Joseph Coffland <joseph@cauldrondevelopment.com>
16:39:07:WU01:FS00:0xa7: Args: -dir 01 -suffix 01 -version 704 -lifeline 6664 -checkpoint 15 -np 4
16:39:07:WU01:FS00:0xa7: Config: <none>
16:39:07:WU01:FS00:0xa7:************************************ Build *************************************
16:39:07:WU01:FS00:0xa7: Version: 0.0.11
16:39:07:WU01:FS00:0xa7: Date: Sep 21 2016
16:39:07:WU01:FS00:0xa7: Time: 01:43:48
16:39:07:WU01:FS00:0xa7: Repository: Git
16:39:07:WU01:FS00:0xa7: Revision: 957bd90e68d95ddcf1594dc15ff6c64cc4555146
16:39:07:WU01:FS00:0xa7: Branch: master
16:39:07:WU01:FS00:0xa7: Compiler: GNU 4.2.1 Compatible Clang 3.9.0 (trunk 274080)
16:39:07:WU01:FS00:0xa7: Options: -std=gnu++98 -O3 -funroll-loops -ffast-math -mfpmath=sse
16:39:07:WU01:FS00:0xa7: -fno-unsafe-math-optimizations -msse2 -I/mingw64/include
16:39:07:WU01:FS00:0xa7: -Wno-inconsistent-dllimport -Wno-parentheses-equality
16:39:07:WU01:FS00:0xa7: -Wno-deprecated-register -Wno-unused-local-typedef
16:39:07:WU01:FS00:0xa7: Platform: linux2 4.6.0-1-amd64
16:39:07:WU01:FS00:0xa7: Bits: 64
16:39:07:WU01:FS00:0xa7: Mode: Release
16:39:07:WU01:FS00:0xa7: SIMD: avx_256
16:39:07:WU01:FS00:0xa7:************************************ System ************************************
16:39:07:WU01:FS00:0xa7: CPU: Intel(R) Core(TM) i5-6400 CPU @ 2.70GHz
16:39:07:WU01:FS00:0xa7: CPU ID: GenuineIntel Family 6 Model 94 Stepping 3
16:39:07:WU01:FS00:0xa7: CPUs: 4
16:39:07:WU01:FS00:0xa7: Memory: 15.91GiB
16:39:07:WU01:FS00:0xa7:Free Memory: 12.70GiB
16:39:07:WU01:FS00:0xa7: Threads: WINDOWS_THREADS
16:39:07:WU01:FS00:0xa7: OS Version: 6.2
16:39:07:WU01:FS00:0xa7:Has Battery: false
16:39:07:WU01:FS00:0xa7: On Battery: false
16:39:07:WU01:FS00:0xa7: UTC Offset: 0
16:39:07:WU01:FS00:0xa7: PID: 3376
16:39:07:WU01:FS00:0xa7: CWD: C:\Users\david\AppData\Roaming\FAHClient\work
16:39:07:WU01:FS00:0xa7: OS: Windows 10 Home
16:39:07:WU01:FS00:0xa7: OS Arch: AMD64
16:39:07:WU01:FS00:0xa7:********************************************************************************
16:39:07:WU01:FS00:0xa7:Project: 13126 (Run 77, Clone 7, Gen 23)
16:39:07:WU01:FS00:0xa7:Unit: 0x0000001bab436c655898c998e9514d98
16:39:07:WU01:FS00:0xa7:Reading tar file core.xml
16:39:07:WU01:FS00:0xa7:Reading tar file frame23.tpr
16:39:07:WU01:FS00:0xa7:Digital signatures verified
16:39:07:WU01:FS00:0xa7:Calling: mdrun -s frame23.tpr -o frame23.trr -cpt 15 -nt 4
16:39:08:WU01:FS00:0xa7:Steps: first=4600000 total=200000
16:39:10:WU01:FS00:0xa7:Completed 1 out of 200000 steps (0%)
16:40:55:WU01:FS00:0xa7:Completed 2000 out of 200000 steps (1%)
16:42:39:WU01:FS00:0xa7:Completed 4000 out of 200000 steps (2%)
16:44:22:WU01:FS00:0xa7:Completed 6000 out of 200000 steps (3%)
17:51:31:WU01:FS00:0xa7:Completed 84000 out of 200000 steps (42%)
17:52:22:Removing old file 'configs/config-20170220-213437.xml'
17:52:22:Saving configuration to config.xml
17:52:22:<config>
17:52:22: <!-- HTTP Server -->
17:52:22: <allow v='127.0.0.1 192.168.1.0/24'/>
17:52:22:
17:52:22: <!-- Network -->
17:52:22: <proxy v=':8080'/>
17:52:22:
17:52:22: <!-- Remote Command Server -->
17:52:22: <password v='*******'/>
17:52:22:
17:52:22: <!-- Slot Control -->
17:52:22: <power v='FULL'/>
17:52:22:
17:52:22: <!-- User Information -->
17:52:22: <passkey v='********************************'/>
17:52:22: <user v='davidcoton'/>
17:52:22:
17:52:22: <!-- Folding Slots -->
17:52:22: <slot id='0' type='CPU'>
17:52:22: <client-type v=redacted/>
17:52:22: <cpus v='4'/>
17:52:22: <project-key v=redacted/>
17:52:22: </slot>
17:52:22: <slot id='1' type='GPU'/>
17:52:22:</config>
17:53:10:Removing old file 'configs/config-20170227-230643.xml'
17:53:10:Saving configuration to config.xml
17:53:10:<config>
17:53:10: <!-- HTTP Server -->
17:53:10: <allow v='127.0.0.1 192.168.1.0/24'/>
17:53:10:
17:53:10: <!-- Network -->
17:53:10: <proxy v=':8080'/>
17:53:10:
17:53:10: <!-- Remote Command Server -->
17:53:10: <password v='*******'/>
17:53:10:
17:53:10: <!-- Slot Control -->
17:53:10: <power v='FULL'/>
17:53:10:
17:53:10: <!-- User Information -->
17:53:10: <passkey v='********************************'/>
17:53:10: <user v='davidcoton'/>
17:53:10:
17:53:10: <!-- Folding Slots -->
17:53:10: <slot id='0' type='CPU'>
17:53:10: <client-type v=redacted/>
17:53:10: <cpus v='4'/>
17:53:10: <project-key v=redacted/>
17:53:10: </slot>
17:53:10: <slot id='1' type='GPU'/>
17:53:10:</config>
17:53:14:WU01:FS00:0xa7:Completed 86000 out of 200000 steps (43%)
17:54:57:WU01:FS00:0xa7:Completed 88000 out of 200000 steps (44%)
17:55:35:WU01:FS00:0xa7:ERROR:
17:55:35:WU01:FS00:0xa7:ERROR:-------------------------------------------------------
17:55:35:WU01:FS00:0xa7:ERROR:Program GROMACS, VERSION 5.0.4-20160919-669094a-unknown
17:55:35:WU01:FS00:0xa7:ERROR:Source code file: /host/windows-cross-64bit-core-a7-avx-release/gromacs-core/build/gromacs/src/gromacs/mdlib/pme.c, line: 754
17:55:35:WU01:FS00:0xa7:ERROR:Fatal error:
17:55:35:WU01:FS00:0xa7:ERROR:46 particles communicated to PME rank 1 are more than 2/3 times the cut-off out of the domain decomposition cell of their charge group in dimension x.
17:55:35:WU01:FS00:0xa7:ERROR:This usually means that your system is not well equilibrated.
17:55:35:WU01:FS00:0xa7:ERROR:For more information and tips for troubleshooting, please check the GROMACS
17:55:35:WU01:FS00:0xa7:ERROR:website at http://www.gromacs.org/Documentation/Errors
17:55:35:WU01:FS00:0xa7:ERROR:24 particles communicated to PME rank 2 are more than 2/3 times the cut-off out of the domain decomposition cell of their charge group in dimension x.
