What's this: Error invoking kernel findBlocksWithInteraction
SteveWillis
Hardware configuration: PC 1:
Linux Mint 17.3
PC2:
Linux Mint 18
Open air case
three gtx 1080,
Post by SteveWillis »
11:29:00:WU02:FS01:0x21:Completed 100000 out of 2500000 steps (4%)
11:29:02:WARNING:FS04:Size of positions 18938 does not match topology 18854
11:29:51:WU02:FS01:0x21:Completed 125000 out of 2500000 steps (5%)
11:30:03:WU01:FS03:0x21:Completed 360000 out of 2000000 steps (18%)
11:30:33:WU05:FS00:0x21:ERROR:exception: Error invoking kernel findBlocksWithInteractions: clEnqueueNDRangeKernel (-4)
11:30:33:WU05:FS00:0x21:Saving result file logfile_01.txt
11:30:33:WU05:FS00:0x21:Saving result file log.txt
11:30:33:WU05:FS00:0x21:Folding@home Core Shutdown: BAD_WORK_UNIT
11:30:41:WU02:FS01:0x21:Completed 150000 out of 2500000 steps (6%)
11:30:54:WU00:FS04:0x21:Completed 1020000 out of 2000000 steps (51%)
11:31:15:WARNING:FS02:Size of positions 18952 does not match topology 18869
11:31:31:WU02:FS01:0x21:Completed 175000 out of 2500000 steps (7%)
11:31:42:WARNING:FS03:Size of positions 18941 does not match topology 18858
11:32:06:WU01:FS03:0x21:Completed 380000 out of 2000000 steps (19%)
11:32:20:WU02:FS01:0x21:Completed 200000 out of 2500000 steps (8%)
11:32:35:WARNING:WU05:FS00:FahCore returned: BAD_WORK_UNIT (114 = 0x72)
11:32:35:WU05:FS00:Sending unit results: id:05 state:SEND error:FAULTY project:11406 run:3 clone:0 gen:373 core:0x21 unit:0x000001f48ca304f256805dec44df8313
11:32:35:WU05:FS00:Uploading 3.15KiB to 140.163.4.242
11:32:35:WU05:FS00:Connecting to 140.163.4.242:8080
11:32:36:WU05:FS00:Upload complete
Re: What's this: Error invoking kernel findBlocksWithInterac
I see two returned WUs, one with an error and one that was completed successfully.
Neither use the name "Steve Willis." The one with the error was added to the stats database on 2017-02-27 04:06:14 PST which does make some sense. If that happens to be yours, it probably means that your GPU is marginally unstable.
SteveWillis
Linux Mint 17.3
PC2:
Linux Mint 18
Open air case
three gtx 1080,
Yes, I changed my folding name but never created a new account here to match. See my sig.
_r2w_ben
Post by _r2w_ben »
What NVidia driver version are you using?
SteveWillis
Linux Mint 17.3
PC2:
Linux Mint 18
Open air case
three gtx 1080,
370.28
And I did reduce the amount of overclock just in case that was a factor.
SteveWillis
Linux Mint 17.3
PC2:
Linux Mint 18
Open air case
three gtx 1080,
It seems to me that it's a bug, or at least an oversight that, for example,
and
10:31:55:WU05:FS01:0x21:Bad State detected... attempting to resume from last good checkpoint. Is your system overclocked?
don't display when you check the "Warnings and Errors" box of the Log tab.
Post your log for that WU plus the first couple of pages.
Did it resume work and proceed past the point of the error or did it fail again at the same point?
SteveWillis
Linux Mint 17.3
PC2:
Linux Mint 18
Open air case
three gtx 1080,
All instances, and there were many, of the first example continued on successfully but it would have been useful if they had shown up as a warning when checking the warnings and errors box. It prompted me to reduce the overclock on those GPUs but I just accidentally came across them when looking for something else.
When I became aware I reduced the overclock on all of the GPUs getting it. I haven't gotten any since. Typically I only look at the log with the warnings and errors box checked. Too tedious to search through the complete log on a routine basis.
The second example resulted in a Bad Work Unit which did show up with Warnings and Errors checked
I'm not getting any of these now but just think they should show up on the log tab with warnings and errors checked. Especially since there isn't a search function available for the complete log. I have to go to the log.txt file and do a search which is fairly inconvenient.
1185
Presumably the message: 11:32:35:WARNING:WU05:FS00:FahCore returned: BAD_WORK_UNIT (114 = 0x72) does show with the Warnings & Errors filter applied if that WU is dumped.
