SEND error:FAULTY project:11402
SteveWillis
Hardware configuration: PC 1:
Linux Mint 17.3
PC2:
Linux Mint 18
Open air case
three gtx 1080,
Post by SteveWillis »
16:44:37:WU04:FS04:0x21:Project: 11402 (Run 7, Clone 36, Gen 189)
16:44:37:WU04:FS04:0x21:Unit: 0x0000011d8ca304f255ed4e9bf7a86bb3
16:44:37:WU04:FS04:0x21:CPU: 0x00000000000000000000000000000000
16:44:37:WU04:FS04:0x21:Machine: 4
16:44:37:WU04:FS04:0x21:Reading tar file core.xml
16:44:37:WU04:FS04:0x21:Reading tar file system.xml
16:44:37:WU04:FS04:0x21:Reading tar file integrator.xml
16:44:37:WU04:FS04:0x21:Reading tar file state.xml
16:44:37:WU04:FS04:0x21:Digital signatures verified
16:44:37:WU04:FS04:0x21:Folding@home GPU Core21 Folding@home Core
16:44:37:WU04:FS04:0x21:Version 0.0.18
16:44:43:WU04:FS04:0x21:ERROR:exception: Invoked getForces() on a State which does not contain forces.
16:44:43:WU04:FS04:0x21:Saving result file logfile_01.txt
16:44:43:WU04:FS04:0x21:Saving result file log.txt
16:44:43:WU04:FS04:0x21:Folding@home Core Shutdown: BAD_WORK_UNIT
16:44:43:WARNING:WU04:FS04:FahCore returned: BAD_WORK_UNIT (114 = 0x72)
16:44:43:WU04:FS04:Sending unit results: id:04 state:SEND error:FAULTY project:11402 run:7 clone:36 gen:189 core:0x21 unit:0x0000011d8ca304f255ed4e9bf7a86bb3
16:44:43:WU02:FS04:Upload 78.37%
16:44:43:WU04:FS04:Uploading 2.37KiB to 140.163.4.242
16:44:43:WU04:FS04:Connecting to 140.163.4.242:8080
Re: SEND error:FAULTY project:11402
Thanks for the report, I marked the WU as a bad one since it failed on many donor machines ...
