Second GPU not visible to/used by F@H
silentrift63
Post by silentrift63 »
I've recently started folding, and all is well. But I decided to-reinstall my old video card in an open PCI slot in order to fold more. However it is a different brand than my current GPU.
F@H doesn't even seem to recognize there is a second GPU available, and I'm not sure how to have both be utilized (or ideally, have the NVIDIA be always-on, and the AMD be on-idle only)
My currently operating GPU is: AMD Radeon RX 480 GDDR5 8GB
The second GPU I want to use is: NVIDIA GeForce GTX 660
I'm not sure if there's any information you need, thank you in advance for your assistance.
Re: Second GPU not visible to/used by F@H
First question: Windows, Linux, or MacOS?
(Posting the top part of your log generally helps.)
I presume the GPU that was recognized has a monitor attached. Try restarting your system with the monitor attached to the new GPU. What happens?
silentrift63
Sorry I didn't include it! I'm running windows 7
I have two monitors, and as you requested I unplugged one from the first GPU and into the second. Both monitors are still working, and Dxdiag recognized that each monitor is operating off a different GPU; but it still seems that only the Radeon GPU is folding.
My log is as follows:
*********************** Log Started 2017-02-21T02:04:11Z ***********************
02:04:11:************************* Folding@home Client *************************
02:04:11:      Website: http://folding.stanford.edu/
02:04:11:    Copyright: (c) 2009-2014 Stanford University
02:04:11:       Author: Joseph Coffland <joseph@cauldrondevelopment.com>
02:04:11:         Args:
02:04:11:       Config: D:/Program Files/Folding At Home/config.xml
02:04:11:******************************** Build ********************************
02:04:11:      Version: 7.4.4
02:04:11:         Date: Mar 4 2014
02:04:11:         Time: 20:26:54
02:04:11:      SVN Rev: 4130
02:04:11:       Branch: fah/trunk/client
02:04:11:     Compiler: Intel(R) C++ MSVC 1500 mode 1200
02:04:11:      Options: /TP /nologo /EHa /Qdiag-disable:4297,4103,1786,279 /Ox -arch:SSE
02:04:11:               /QaxSSE2,SSE3,SSSE3,SSE4.1,SSE4.2 /Qopenmp /Qrestrict /MT /Qmkl
02:04:11:     Platform: win32 XP
02:04:11:         Bits: 32
02:04:11:         Mode: Release
02:04:11:******************************* System ********************************
02:04:11:          CPU: Intel(R) Core(TM) i5-4670K CPU @ 3.40GHz
02:04:11:       CPU ID: GenuineIntel Family 6 Model 60 Stepping 3
02:04:11:         CPUs: 4
02:04:11:       Memory: 15.93GiB
02:04:11:  Free Memory: 14.30GiB
02:04:11:      Threads: WINDOWS_THREADS
02:04:11:   OS Version: 6.1
02:04:11:  Has Battery: false
02:04:11:   On Battery: false
02:04:11:   UTC Offset: -5
02:04:11:          PID: 2776
02:04:11:          CWD: D:/Program Files/Folding At Home
02:04:11:           OS: Windows 7 Home Premium
02:04:11:      OS Arch: AMD64
02:04:11:         GPUs: 2
02:04:11:        GPU 0: ATI:5 Ellesmere XT [Radeon RX 470/480]
02:04:11:        GPU 1: NVIDIA:3 GK106 [GeForce GTX 660]
02:04:11:         CUDA: 3.0
02:04:11:  CUDA Driver: 7000
02:04:11:Win32 Service: false
02:04:11:***********************************************************************
02:04:11:<config>
02:04:11:  <!-- Slot Control -->
02:04:11:  <power v='FULL'/>
02:04:11:
02:04:11:  <!-- User Information -->
02:04:11:  <passkey v='********************************'/>
02:04:11:  <team v='182116'/>
02:04:11:  <user v='Steve_Eisen'/>
02:04:11:
02:04:11:  <!-- Folding Slots -->
02:04:11:  <slot id='0' type='CPU'>
02:04:11:    <idle v='true'/>
02:04:11:  </slot>
02:04:11:  <slot id='1' type='GPU'>
02:04:11:  </slot>
02:04:11:</config>
02:04:11:Trying to access database...
02:04:13:Successfully acquired database lock
02:04:13:Enabled folding slot 00: PAUSED cpu:3 (waiting for idle)
02:04:13:Enabled folding slot 01: PAUSED gpu:0:Ellesmere XT [Radeon RX 470/480] (waiting for idle)
02:04:52:WU00:FS00:Starting
02:04:52:WARNING:WU00:FS00:Changed SMP threads from 2 to 3 this can cause some work units to fail
02:04:52:WU00:FS00:Running FahCore: "D:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" "D:/Program Files/Folding At Home/cores/fahwebx.stanford.edu/cores/Win32/AMD64/Core_a4.fah/FahCore_a4.exe" -dir 00 -suffix 01 -version 704 -lifeline 2776 -checkpoint 15 -np 3
02:04:52:WU00:FS00:Started FahCore on PID 6096
02:04:52:WU00:FS00:Core PID:5328
02:04:52:WU00:FS00:FahCore 0xa4 started
02:04:52:WU01:FS01:Starting
02:04:53:WU01:FS01:Running FahCore: "D:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" "D:/Program Files/Folding At Home/cores/fahwebx.stanford.edu/cores/Win32/AMD64/ATI/R600/Core_21.fah/FahCore_21.exe" -dir 01 -suffix 01 -version 704 -lifeline 2776 -checkpoint 15 -gpu 0 -gpu-vendor ati
02:04:53:WU01:FS01:Started FahCore on PID 5352
02:04:53:WU00:FS00:0xa4:
02:04:53:WU00:FS00:0xa4:*------------------------------*
02:04:53:WU00:FS00:0xa4:Folding@Home Gromacs GB Core
02:04:53:WU00:FS00:0xa4:Version 2.27 (Dec. 15, 2010)
02:04:53:WU00:FS00:0xa4:Preparing to commence simulation
02:04:53:WU00:FS00:0xa4:- Looking at optimizations...
02:04:53:WU00:FS00:0xa4:- Files status OK
02:04:53:WU00:FS00:0xa4:- Expanded 378633 -> 597116 (decompressed 157.7 percent)
02:04:53:WU00:FS00:0xa4:Called DecompressByteArray: compressed_data_size=378633 data_size=597116, decompressed_data_size=597116 diff=0
02:04:53:WU00:FS00:0xa4:- Digital signature verified
02:04:53:WU00:FS00:0xa4:Project: 8659 (Run 373, Clone 0, Gen 19)
02:04:53:WU00:FS00:0xa4:Assembly optimizations on if available.
02:04:53:WU00:FS00:0xa4:Entering M.D.
02:04:53:WU01:FS01:Core PID:5376
02:04:53:WU01:FS01:FahCore 0x21 started
02:04:57:WU01:FS01:0x21:*********************** Log Started 2017-02-21T02:04:57Z ***********************
02:04:57:WU01:FS01:0x21:Project: 9181 (Run 24, Clone 9, Gen 301)
02:04:57:WU01:FS01:0x21:Unit: 0x000001c2ab436c9f57bdce06889305fb
02:04:57:WU01:FS01:0x21:CPU: 0x00000000000000000000000000000000
02:04:57:WU01:FS01:0x21:Machine: 1
02:04:57:WU01:FS01:0x21:Digital signatures verified
02:04:57:WU01:FS01:0x21:Folding@home GPU Core21 Folding@home Core
02:04:57:WU01:FS01:0x21:Version 0.0.18
02:04:57:WU01:FS01:0x21:  Found a checkpoint file
02:04:59:WU00:FS00:0xa4:Using Gromacs checkpoints
02:04:59:WU00:FS00:0xa4:Mapping NT from 3 to 3
02:05:01:WU00:FS00:0xa4:Resuming from checkpoint
02:05:02:WU00:FS00:0xa4:Verified 00/wudata_01.log
02:05:02:WU00:FS00:0xa4:Verified 00/wudata_01.trr
02:05:02:WU00:FS00:0xa4:Verified 00/wudata_01.xtc
02:05:02:WU00:FS00:0xa4:Verified 00/wudata_01.edr
02:05:02:WU00:FS00:0xa4:Completed 227440 out of 2500000 steps  (9%)
02:05:09:WU01:FS01:0x21:Completed 1200000 out of 2500000 steps (48%)
02:05:09:WU01:FS01:0x21:Temperature control disabled. Requirements: single Nvidia GPU, tmax must be < 110 and twait >= 900
02:05:09:16:127.0.0.1:New Web connection
02:05:14:Removing old file 'configs/config-20170216-142200.xml'
02:05:14:Saving configuration to config.xml
02:05:14:<config>
02:05:14:  <!-- Slot Control -->
02:05:14:  <power v='FULL'/>
02:05:14:
02:05:14:  <!-- User Information -->
02:05:14:  <passkey v='********************************'/>
02:05:14:  <team v='182116'/>
02:05:14:  <user v='Steve_Eisen'/>
02:05:14:
02:05:14:  <!-- Folding Slots -->
02:05:14:  <slot id='0' type='CPU'/>
02:05:14:  <slot id='1' type='GPU'/>
02:05:14:</config>
Mod edit: added Code tags to log file
I'd go to http://www.geforce.com/drivers and manually install their recommended drivers -- assuming you haven't already done so. If necessary, you can do the same from http://support.amd.com/en-us/download but it sounds like Windows Update has already taken care of that.
For a long time, folding with GPUs from two different companies has been considered "impossible" and then it moved to "difficult" and I'm not sure of the latest adjective. You're running the released client V7.4.4 and there have been a few enhancements between it an the latest beta (currently V7.4.16) so if you still have trouble, you can upgrade to the beta client. I have not found anything broken in the beta client that wasn't also broken in the released version but there are sill some more improvements that need to be completed before it can be called "released."
