I'm having issue with the WU in object
Multiple EUEs: long 1-4 interactions followed by ERROR 0x7b
The strange thing is that the first EUE is at 56%, the following three EUEs at 22%
Now the client is crunching a different WU
Config: HP XW4600 with E6850, 3gb ram, Quadro FX1700, WXP-SP3
No OC
Log (I do not know how to create the box with the sliding bar
--- Opening Log file [June 3 15:59:27]
# SMP Client ##################################################################
Folding@Home Client Version 5.91beta6
http://folding.stanford.edu
Launch directory: C:\Programmi\Folding@HomeSMP
Executable: C:\Programmi\Folding@HomeSMP\fah.exe
[15:59:27] - Ask before connecting: No
[15:59:27] - User name: MT_Bender (Team 116735)
[15:59:27] - User ID: 44D708B87EDACBB9
[15:59:27] - Machine ID: 6
[15:59:27]
[15:59:27] Loaded queue successfully.
[15:59:27]
[15:59:27] + Processing work unit
[15:59:27] Core required: FahCore_a1.exe
[15:59:27] Core found.
[15:59:27] Working on Unit 00 [June 3 15:59:27]
[15:59:27] + Working ...
[15:59:28]
[15:59:28] *------------------------------*
[15:59:28] Folding@Home Gromacs SMP Core
[15:59:28] Version 1.74 (March 10, 2007)
[15:59:28]
[15:59:28] Preparing to commence simulation
[15:59:28] - Ensuring status. Please wait.
[15:59:45] - Looking at optimizations...
[15:59:45] - Working with standard loops on this execution.
[15:59:45] - Previous termination of core was improper.
[15:59:45] - Going to use standard loops.
[15:59:45] - Files status OK
[15:59:45] - Expanded 608442 -> 3255645 (decompressed 535.0 percent)
[15:59:46]
[15:59:46] Project: 3062 (Run 4, Clone 28, Gen 69)
[15:59:46]
[15:59:46] Entering M.D.
[15:59:53] Calling FAH init
[15:59:54] Read topology
[15:59:54] (Starting from checkpoint)
[15:59:54] Read checkpoint
[15:59:55] 00000 steps (8 percent)
[15:59:55] Extra SSE boost OK.
[15:59:55] es
[15:59:55] Completed 400000 out of 5000000 steps (8 percent)
[16:15:05] Writing local files
[04:05:53] Writing local files
[04:05:53] Completed 2800000 out of 5000000 steps (56 percent)
[04:11:51] Warning: long 1-4 interactions
[04:11:51] Gromacs cannot continue further.
[04:11:51] Going to send back what have done.
[04:11:51] logfile size: 87144
[04:11:51] - Writing 87680 bytes of core data to disk...
[04:11:52] ... Done.
[04:11:52] - Failed to delete work/wudata_00.chk
[04:11:52] - Failed to delete work/wudata_00.sas
[04:11:52] - Failed to delete work/wudata_00.goe
[04:11:52] Warning: check for stray files
[04:11:52]
[04:11:52] Folding@home Core Shutdown: EARLY_UNIT_END
[04:11:52]
[04:11:54] CoreStatus = 7B (123)
[04:11:54] Client-core communications error: ERROR 0x7b
[04:11:54] Deleting current work unit & continuing...
[04:13:58] - Preparing to get new work unit...
[04:13:58] + Attempting to get work packet
[04:13:58] - Connecting to assignment server
[04:13:59] - Successful: assigned to (171.64.65.63).
[04:13:59] + News From Folding@Home: Welcome to Folding@Home
[04:13:59] Loaded queue successfully.
[04:14:05] + Closed connections
[04:14:10]
[04:14:10] + Processing work unit
[04:14:10] Core required: FahCore_a1.exe
[04:14:10] Core found.
[04:14:10] Working on Unit 01 [June 4 04:14:10]
[04:14:10] + Working ...
[04:14:11]
[04:14:11] *------------------------------*
[04:14:11] Folding@Home Gromacs SMP Core
[04:14:11] Version 1.74 (March 10, 2007)
[04:14:11]
[04:14:11] Preparing to commence simulation
[04:14:11] - Ensuring status. Please wait.
[04:14:11] - Starting from initial work packet
[04:14:11]
[04:14:11] Project: 3062 (Run 4, Clone 28, Gen 69)
[04:14:11]
[04:14:11] Assembly optimizations on if available.
[04:14:11] Entering M.D.
[04:14:28] ial work packet
[04:14:28]
[04:14:28] Project: 3062 (Run 4, Clone 28, Gen 69)
[04:14:28]
[04:14:28] Entering M.D.
[04:14:34] Rejecting checkpoint
[04:14:35] ProteinWriting local files
[04:14:35] Extra SSE boost OK.
[04:14:35]
[04:14:35] Writing local files
[04:14:35] Completed 0 out of 5000000 steps (0 percent)
[04:29:34] Writing local files
[04:29:34] Completed 50000 out of 5000000 steps (1 percent)
[10:01:29] Writing local files
[10:01:29] Completed 1100000 out of 5000000 steps (22 percent)
[10:14:07] Warning: long 1-4 interactions
[10:14:07] Gromacs cannot continue further.
[10:14:07] Going to send back what have done.
[10:14:07] logfile size: 37255
[10:14:07] - Writing 37791 bytes of core data to disk...
[10:14:07] ... Done.
[10:14:07] - Failed to delete work/wudata_01.xtc
[10:14:07] - Failed to delete work/wudata_01.dyn
[10:14:07] - Failed to delete work/wudata_01.bed
[10:14:07] Warning: check for stray files
[10:14:07]
[10:14:07] Folding@home Core Shutdown: EARLY_UNIT_END
[10:14:07]
[10:14:10] CoreStatus = 7B (123)
[10:14:10] Client-core communications error: ERROR 0x7b
[10:14:10] Deleting current work unit & continuing...
[10:16:14] - Preparing to get new work unit...
[10:16:14] + Attempting to get work packet
[10:16:14] - Connecting to assignment server
[10:16:15] - Successful: assigned to (171.64.65.63).
[10:16:15] + News From Folding@Home: Welcome to Folding@Home
[10:16:15] Loaded queue successfully.
[10:16:25] + Closed connections
[10:16:30]
[10:16:30] + Processing work unit
[10:16:30] Core required: FahCore_a1.exe
[10:16:30] Core found.
[10:16:30] Working on Unit 02 [June 4 10:16:30]
[10:16:30] + Working ...
[10:16:31]
[10:16:31] *------------------------------*
[10:16:31] Folding@Home Gromacs SMP Core
[10:16:31] Version 1.74 (March 10, 2007)
[10:16:31]
[10:16:31] Preparing to commence simulation
[10:16:31] - Ensuring status. Please wait.
[10:16:31] - Starting from initial work packet
[10:16:31]
[10:16:31] Project: 3062 (Run 4, Clone 28, Gen 69)
[10:16:31]
[10:16:31] Assembly optimizations on if available.
[10:16:31] Entering M.D.
[10:16:48] ial work packet
[10:16:48]
[10:16:48] Project: 3062 (Run 4, Clone 28, Gen 69)
[10:16:48]
[10:16:48] Entering M.D.
[10:16:48] l work packet
[10:16:48]
[10:16:48] ProEntering M.D.
[10:16:48] n 4, Clone 28, Gen 69)
[10:16:48]
[10:16:55] cal files
[10:16:55] Extra SSE boost OK.
[10:16:55] p3062_lambda5_99sb
[10:16:55] Writing local files
[10:16:55] Completed 0 out of 5000000 steps (0 percent)
[10:32:07] Writing local files
[15:50:59] Writing local files
[15:50:59] Completed 1100000 out of 5000000 steps (22 percent)
[16:03:39] Warning: long 1-4 interactions
[16:03:39] Gromacs cannot continue further.
[16:03:39] Going to send back what have done.
[16:03:39] logfile size: 37255
[16:03:39] - Writing 37791 bytes of core data to disk...
[16:03:39] ... Done.
[16:03:39] - Failed to delete work/wudata_02.xtc
[16:03:39] Warning: check for stray files
[16:05:39]
[16:05:39] Folding@home Core Shutdown: EARLY_UNIT_END
[16:05:39]
[16:05:42] CoreStatus = 7B (123)
[16:05:42] Client-core communications error: ERROR 0x7b
[16:05:42] - Attempting to download new core...
[16:05:42] + Downloading new core: FahCore_a1.exe
[16:05:57] Could not download 'www.stanford.edu'
[16:05:57] + Error: Could not download core
[16:05:57] + Core download error (#2), waiting before retry...
[16:06:11] + Downloading new core: FahCore_a1.exe
[16:06:26] Could not download 'www.stanford.edu'
[16:06:26] + Error: Could not download core
[16:06:26] + Core download error (#3), waiting before retry...
[16:06:39] + Downloading new core: FahCore_a1.exe
[16:06:53] Could not download 'www.stanford.edu'
[16:06:53] + Error: Could not download core
[16:06:53] + Core download error (#4), waiting before retry...
[16:07:17] + Downloading new core: FahCore_a1.exe
[16:07:32] Could not download 'www.stanford.edu'
[16:07:32] + Error: Could not download core
[16:07:32] + Core download error (#5), waiting before retry...
[16:08:23] + Downloading new core: FahCore_a1.exe
[16:08:37] Could not download 'www.stanford.edu'
[16:08:37] + Error: Could not download core
[16:08:37] + Core download error (#6), waiting before retry...
[16:10:09] + Downloading new core: FahCore_a1.exe
[16:10:24] Could not download 'www.stanford.edu'
[16:10:24] + Error: Could not download core
[16:10:24] + Core download error (#7), waiting before retry...
[16:13:11] + Downloading new core: FahCore_a1.exe
[16:13:26] Could not download 'www.stanford.edu'
[16:13:26] + Error: Could not download core
[16:13:26] + Core download error (#8), waiting before retry...
[16:18:53] + Downloading new core: FahCore_a1.exe
[16:19:07] Could not download 'www.stanford.edu'
[16:19:07] + Error: Could not download core
[16:19:07] + Core download error (#9), waiting before retry...
[16:29:59] + Downloading new core: FahCore_a1.exe
[16:30:14] Could not download 'www.stanford.edu'
[16:30:14] + Error: Could not download core
[16:30:14] + Core download error (#10), waiting before retry...
[16:51:37] + Downloading new core: FahCore_a1.exe
[16:51:51] Could not download 'www.stanford.edu'
[16:51:51] + Error: Could not download core
[16:51:51] + Core download error (#11), waiting before retry...
[17:34:41] + Downloading new core: FahCore_a1.exe
[17:34:42] + 10240 bytes downloaded
[17:34:49] + 789667 bytes downloaded
[17:34:49] Verifying core Core_a1.fah...
[17:34:49] Signature is VALID
[17:34:49]
[17:34:49] Trying to unzip core FahCore_a1.exe
[17:34:50] Decompressed FahCore_a1.exe (2035712 bytes) successfully
[17:34:50] + Core successfully engaged
[17:34:50] Deleting current work unit & continuing...
[17:36:54] - Preparing to get new work unit...
[17:36:54] + Attempting to get work packet
[17:36:54] - Connecting to assignment server
[17:36:55] - Successful: assigned to (171.64.65.63).
[17:36:55] + News From Folding@Home: Welcome to Folding@Home
[17:36:55] Loaded queue successfully.
[17:37:01] + Closed connections
[17:37:06]
[17:37:06] + Processing work unit
[17:37:06] Core required: FahCore_a1.exe
[17:37:06] Core found.
[17:37:06] Working on Unit 03 [June 4 17:37:06]
[17:37:06] + Working ...
[17:37:06]
[17:37:06] *------------------------------*
[17:37:06] Folding@Home Gromacs SMP Core
[17:37:06] Version 1.74 (March 10, 2007)
[17:37:06]
[17:37:06] Preparing to commence simulation
[17:37:06] - Ensuring status. Please wait.
[17:37:07] - Starting from initial work packet
[17:37:07]
[17:37:07] Project: 3062 (Run 4, Clone 28, Gen 69)
[17:37:07]
[17:37:07] Assembly optimizations on if available.
[17:37:07] Entering M.D.
[17:37:24] 0 percent)
[17:37:24] - Starting from initial work packet
[17:37:24]
[17:37:24] Project: 3062 (Run 4, Clone 28, Gen 69)
[17:37:24]
[17:37:24] Entering M.D.
[17:37:30] Rejecting checkpoint
[17:37:30] a SSE boost OK.
[17:37:30] ambda5_99sbExtra SSE boost OK.
[17:37:30]
[17:37:30] Extra SSE boost OK.
[17:37:30] Writing local files
[17:37:30] Completed 0 out of 5000000 steps (0 percent)
[17:52:32] Writing local files
[23:07:39] Writing local files
[23:07:39] Completed 1100000 out of 5000000 steps (22 percent)
[23:19:44] Warning: long 1-4 interactions
[23:19:44] Gromacs cannot continue further.
[23:19:44] Going to send back what have done.
[23:19:44] logfile size: 37255
[23:19:44] - Writing 37791 bytes of core data to disk...
[23:19:44] ... Done.
[23:19:44] - Failed to delete work/wudata_03.xtc
[23:19:44] No C.P. to delete.
[23:19:44] - Failed to delete work/wudata_03.dyn
[23:19:44] - Failed to delete work/wudata_03.chk
[23:19:44] Warning: check for stray files
[23:21:44]
[23:21:44] Folding@home Core Shutdown: EARLY_UNIT_END
[23:21:44]
[23:21:48] CoreStatus = 7B (123)
[23:21:48] Client-core communications error: ERROR 0x7b
[23:21:48] Deleting current work unit & continuing...
[23:23:52] - Preparing to get new work unit...
[23:23:52] + Attempting to get work packet
[23:23:52] - Connecting to assignment server
[23:23:53] - Successful: assigned to (171.64.65.63).
[23:23:53] + News From Folding@Home: Welcome to Folding@Home
[23:23:53] Loaded queue successfully.
[23:23:54] - Error: Attempt #1 to get work failed, and no other work to do.
Waiting before retry.
[23:24:13] + Attempting to get work packet
[23:24:13] - Connecting to assignment server
[23:24:14] - Successful: assigned to (171.64.65.63).
[23:24:14] + News From Folding@Home: Welcome to Folding@Home
[23:24:14] Loaded queue successfully.
[23:24:21] + Closed connections
[23:24:26]
[23:24:26] + Processing work unit
[23:24:26] Core required: FahCore_a1.exe
[23:24:26] Core found.
[23:24:26] Working on Unit 04 [June 4 23:24:26]
[23:24:26] + Working ...
[23:24:26]
[23:24:26] *------------------------------*
[23:24:26] Folding@Home Gromacs SMP Core
[23:24:26] Version 1.74 (March 10, 2007)
[23:24:26]
[23:24:26] Preparing to commence simulation
[23:24:26] - Ensuring status. Please wait.
[23:24:26] - Starting from initial work packet
[23:24:26]
[23:24:26] Project: 3062 (Run 4, Clone 139, Gen 25)
[23:24:26]
[23:24:26] Assembly optimizations on if available.
[23:24:26] Entering M.D.
[23:24:43] percent)
[23:24:43] - Starting from initial work packet
[23:24:43]
[23:24:43] Project: 3062 (Run 4, Clone 139, Gen 25)
[23:24:43]
[23:24:43] Entering M.D.
[23:24:49] Rejecting checkpoint
[23:24:50] a SSE boost OK.
[23:24:50] ambda5_99sb
[23:24:50] Writing local files
[23:24:50] Extra SSE boost OK.
[23:24:50] Completed 0 out of 5000000 steps (0 percent)
