GPU folding fails -- Bad platformId size.
BigApplePi
Post by BigApplePi »
Hello. I'm using a GTX 980 with Windows 7. The work unit fails. "01 Failed gpu:0:GM200 [GeForce GTX 980 Ti]"
It had been working for months and last week failed. I reinstalled Version 7.4.4 to get rid of it but the work unit fails again. Device Manager says the 980 is okay. Is this error me or folding? I am not technically inclined. Would seeing the log help?
*********************** Log Started 2017-02-10T11:36:29Z ***********************
11:36:29:************************* Folding@home Client *************************
11:36:29:      Website: http://folding.stanford.edu/
11:36:29:    Copyright: (c) 2009-2014 Stanford University
11:36:29:       Author: Joseph Coffland <joseph@cauldrondevelopment.com>
11:36:29:         Args: --open-web-control
11:36:29:       Config: <none>
11:36:29:******************************** Build ********************************
11:36:29:      Version: 7.4.4
11:36:29:         Date: Mar 4 2014
11:36:29:         Time: 20:26:54
11:36:29:      SVN Rev: 4130
11:36:29:       Branch: fah/trunk/client
11:36:29:     Compiler: Intel(R) C++ MSVC 1500 mode 1200
11:36:29:      Options: /TP /nologo /EHa /Qdiag-disable:4297,4103,1786,279 /Ox -arch:SSE
11:36:29:               /QaxSSE2,SSE3,SSSE3,SSE4.1,SSE4.2 /Qopenmp /Qrestrict /MT /Qmkl
11:36:29:     Platform: win32 XP
11:36:29:         Bits: 32
11:36:29:         Mode: Release
11:36:29:******************************* System ********************************
11:36:29:          CPU: Intel(R) Core(TM) i7 CPU 920 @ 2.67GHz
11:36:29:       CPU ID: GenuineIntel Family 6 Model 26 Stepping 4
11:36:29:         CPUs: 8
11:36:29:       Memory: 3.99GiB
11:36:29:  Free Memory: 2.34GiB
11:36:29:      Threads: WINDOWS_THREADS
11:36:29:   OS Version: 6.1
11:36:29:  Has Battery: false
11:36:29:   On Battery: false
11:36:29:   UTC Offset: -5
11:36:29:          PID: 4408
11:36:29:          CWD: C:/Users/Bob/AppData/Roaming/FAHClient
11:36:29:           OS: Windows 7 Professional
11:36:29:      OS Arch: AMD64
11:36:29:         GPUs: 0
11:36:29:         CUDA: Not detected
11:36:29:Win32 Service: false
11:36:29:***********************************************************************
11:36:29:<config>
11:36:29:  <!-- Folding Slots -->
11:36:29:</config>
11:36:29:Connecting to assign-GPU.stanford.edu:80
11:36:29:Updated GPUs.txt
11:36:29:Read GPUs.txt
11:36:29:Trying to access database...
11:36:30:Successfully acquired database lock
11:36:30:Enabled folding slot 00: PAUSED cpu:6 (not configured)
11:36:30:Enabled folding slot 01: PAUSED gpu:0:GM200 [GeForce GTX 980 Ti] (not configured)
11:36:33:14:127.0.0.1:New Web connection
11:36:40:Set client configured
11:36:41:WU00:FS00:Connecting to 171.67.108.45:8080
11:36:41:WU01:FS01:Connecting to 171.67.108.45:8080
11:36:42:WU00:FS00:Connecting to 171.67.108.45:8080
11:36:42:WU01:FS01:Connecting to 171.67.108.45:80
11:36:42:WU00:FS00:Assigned to work server 155.247.166.220
11:36:42:WU00:FS00:Requesting new work unit for slot 00: READY cpu:6 from 155.247.166.220
11:36:42:WU00:FS00:Connecting to 155.247.166.220:8080
11:36:42:WU01:FS01:Assigned to work server 140.163.4.242
11:36:42:WU01:FS01:Requesting new work unit for slot 01: READY gpu:0:GM200 [GeForce GTX 980 Ti] from 140.163.4.242
11:36:42:WU01:FS01:Connecting to 140.163.4.242:8080
11:36:43:WU01:FS01:Downloading 4.22MiB
11:36:43:WU00:FS00:Downloading 335.95KiB
11:36:43:WU01:FS01:Download complete
11:36:43:WU01:FS01:Received Unit: id:01 state:DOWNLOAD error:NO_ERROR project:11403 run:1 clone:0 gen:409 core:0x21 unit:0x000002318ca304f255ed4f25ac32e9de
11:36:43:WU00:FS00:Download complete
11:36:43:WU01:FS01:Downloading core from http://fahwebx.stanford.edu/cores/Win32/AMD64/NVIDIA/Fermi/Core_21.fah
11:36:43:WU01:FS01:Connecting to fahwebx.stanford.edu:80
11:36:43:WU00:FS00:Received Unit: id:00 state:DOWNLOAD error:NO_ERROR project:8658 run:336 clone:0 gen:3 core:0xa4 unit:0x000000030002894c57fe6507134c3513
11:36:44:WU00:FS00:Downloading core from http://fahwebx.stanford.edu/cores/Win32/AMD64/Core_a4.fah
11:36:44:WU00:FS00:Connecting to fahwebx.stanford.edu:80
11:36:44:WU01:FS01:FahCore 21: Downloading 3.47MiB
11:36:45:WU00:FS00:FahCore a4: Downloading 2.89MiB
11:36:45:WU01:FS01:FahCore 21: Download complete
11:36:45:WU01:FS01:Valid core signature
11:36:46:WU01:FS01:Unpacked 11.80MiB to cores/fahwebx.stanford.edu/cores/Win32/AMD64/NVIDIA/Fermi/Core_21.fah/FahCore_21.exe
11:36:46:WU01:FS01:Starting
11:36:46:WU01:FS01:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:/Users/Bob/AppData/Roaming/FAHClient/cores/fahwebx.stanford.edu/cores/Win32/AMD64/NVIDIA/Fermi/Core_21.fah/FahCore_21.exe -dir 01 -suffix 01 -version 704 -lifeline 4408 -checkpoint 15 -gpu 0 -gpu-vendor nvidia
11:36:46:WU01:FS01:Started FahCore on PID 2504
11:36:46:WU00:FS00:FahCore a4: Download complete
11:36:46:WU01:FS01:Core PID:3264
11:36:46:WU01:FS01:FahCore 0x21 started
11:36:47:WU01:FS01:0x21:*********************** Log Started 2017-02-10T11:36:47Z ***********************
11:36:47:WU01:FS01:0x21:Project: 11403 (Run 1, Clone 0, Gen 409)
11:36:47:WU01:FS01:0x21:Unit: 0x000002318ca304f255ed4f25ac32e9de
11:36:47:WU01:FS01:0x21:CPU: 0x00000000000000000000000000000000
11:36:47:WU01:FS01:0x21:Machine: 1
11:36:47:WU01:FS01:0x21:Reading tar file core.xml
11:36:47:WU01:FS01:0x21:Reading tar file system.xml
11:36:47:WU01:FS01:0x21:Reading tar file integrator.xml
11:36:47:WU01:FS01:0x21:Reading tar file state.xml
11:36:47:WU00:FS00:Valid core signature
11:36:47:WU00:FS00:Unpacked 9.59MiB to cores/fahwebx.stanford.edu/cores/Win32/AMD64/Core_a4.fah/FahCore_a4.exe
11:36:48:WU00:FS00:Starting
11:36:48:WU00:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:/Users/Bob/AppData/Roaming/FAHClient/cores/fahwebx.stanford.edu/cores/Win32/AMD64/Core_a4.fah/FahCore_a4.exe -dir 00 -suffix 01 -version 704 -lifeline 4408 -checkpoint 15 -np 6
11:36:48:WU00:FS00:Started FahCore on PID 4700
11:36:48:WU00:FS00:Core PID:2608
11:36:48:WU00:FS00:FahCore 0xa4 started
11:36:48:WU01:FS01:0x21:Digital signatures verified
11:36:48:WU01:FS01:0x21:Folding@home GPU Core21 Folding@home Core
11:36:48:WU01:FS01:0x21:Version 0.0.18
11:36:48:WU01:FS01:0x21:ERROR:126: Bad platformId size.
11:36:48:WU01:FS01:0x21:Saving result file logfile_01.txt
11:36:48:WU01:FS01:0x21:Saving result file log.txt
11:36:48:WU01:FS01:0x21:Folding@home Core Shutdown: BAD_WORK_UNIT
11:36:48:WARNING:WU01:FS01:FahCore returned: BAD_WORK_UNIT (114 = 0x72)
11:36:48:WU01:FS01:Sending unit results: id:01 state:SEND error:FAULTY project:11403 run:1 clone:0 gen:409 core:0x21 unit:0x000002318ca304f255ed4f25ac32e9de
11:36:48:WU01:FS01:Uploading 1.87KiB to 140.163.4.242
11:36:48:WU01:FS01:Connecting to 140.163.4.242:8080
11:36:49:WU00:FS00:0xa4:
11:36:49:WU00:FS00:0xa4:*------------------------------*
11:36:49:WU00:FS00:0xa4:Folding@Home Gromacs GB Core
11:36:49:WU00:FS00:0xa4:Version 2.27 (Dec. 15, 2010)
11:36:49:WU00:FS00:0xa4:Preparing to commence simulation
11:36:49:WU00:FS00:0xa4:- Looking at optimizations...
11:36:49:WU00:FS00:0xa4:- Created dyn
11:36:49:WU00:FS00:0xa4:- Files status OK
11:36:49:WU00:FS00:0xa4:- Expanded 343504 -> 549472 (decompressed 159.9 percent)
11:36:49:WU00:FS00:0xa4:Called DecompressByteArray: compressed_data_size=343504 data_size=549472, decompressed_data_size=549472 diff=0
11:36:49:WU00:FS00:0xa4:- Digital signature verified
11:36:49:WU00:FS00:0xa4:Project: 8658 (Run 336, Clone 0, Gen 3)
11:36:49:WU00:FS00:0xa4:Assembly optimizations on if available.
11:36:49:WU00:FS00:0xa4:Entering M.D.
11:36:49:WU02:FS01:Connecting to 171.67.108.45:80
11:36:49:WU01:FS01:Upload complete
11:36:49:WU01:FS01:Server responded WORK_ACK (400)
11:36:49:WU01:FS01:Cleaning up
11:36:50:WU02:FS01:Assigned to work server 171.64.65.84
11:36:50:WU02:FS01:Requesting new work unit for slot 01: READY gpu:0:GM200 [GeForce GTX 980 Ti] from 171.64.65.84
11:36:50:WU02:FS01:Connecting to 171.64.65.84:8080
11:36:51:WU02:FS01:Downloading 3.36MiB
11:36:53:WU02:FS01:Download complete
11:36:53:WU02:FS01:Received Unit: id:02 state:DOWNLOAD error:NO_ERROR project:9192 run:0 clone:12 gen:193 core:0x21 unit:0x0000013aab40415457cb2d062301e0a9
11:36:53:WU02:FS01:Starting
11:36:53:WU02:FS01:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:/Users/Bob/AppData/Roaming/FAHClient/cores/fahwebx.stanford.edu/cores/Win32/AMD64/NVIDIA/Fermi/Core_21.fah/FahCore_21.exe -dir 02 -suffix 01 -version 704 -lifeline 4408 -checkpoint 15 -gpu 0 -gpu-vendor nvidia
11:36:53:WU02:FS01:Started FahCore on PID 4348
11:36:53:WU02:FS01:Core PID:2136
11:36:53:WU02:FS01:FahCore 0x21 started
11:36:54:WU02:FS01:0x21:*********************** Log Started 2017-02-10T11:36:53Z ***********************
11:36:54:WU02:FS01:0x21:Project: 9192 (Run 0, Clone 12, Gen 193)
11:36:54:WU02:FS01:0x21:Unit: 0x0000013aab40415457cb2d062301e0a9
11:36:54:WU02:FS01:0x21:CPU: 0x00000000000000000000000000000000
11:36:54:WU02:FS01:0x21:Machine: 1
11:36:54:WU02:FS01:0x21:Reading tar file core.xml
11:36:54:WU02:FS01:0x21:Reading tar file system.xml
11:36:54:WU02:FS01:0x21:Reading tar file integrator.xml
11:36:54:WU02:FS01:0x21:Reading tar file state.xml
11:36:54:WU02:FS01:0x21:Digital signatures verified
11:36:54:WU02:FS01:0x21:Folding@home GPU Core21 Folding@home Core
11:36:54:WU02:FS01:0x21:Version 0.0.18
11:36:54:WU02:FS01:0x21:ERROR:126: Bad platformId size.
11:36:54:WU02:FS01:0x21:Saving result file logfile_01.txt
11:36:54:WU02:FS01:0x21:Saving result file log.txt
11:36:54:WU02:FS01:0x21:Folding@home Core Shutdown: BAD_WORK_UNIT
11:36:54:WU00:FS00:0xa4:Mapping NT from 6 to 6
11:36:54:WARNING:WU02:FS01:FahCore returned: BAD_WORK_UNIT (114 = 0x72)
11:36:54:WU02:FS01:Sending unit results: id:02 state:SEND error:FAULTY project:9192 run:0 clone:12 gen:193 core:0x21 unit:0x0000013aab40415457cb2d062301e0a9
11:36:54:WU02:FS01:Uploading 1.87KiB to 171.64.65.84
11:36:54:WU02:FS01:Connecting to 171.64.65.84:8080
11:36:55:WU00:FS00:0xa4:Completed 0 out of 2500000 steps  (0%)
11:36:55:WU02:FS01:Upload complete
11:36:55:WU02:FS01:Server responded WORK_ACK (400)
11:36:55:WU02:FS01:Cleaning up
11:36:55:WU01:FS01:Connecting to 171.67.108.45:80
11:36:55:WU01:FS01:Assigned to work server 140.163.4.243
11:36:55:WU01:FS01:Requesting new work unit for slot 01: READY gpu:0:GM200 [GeForce GTX 980 Ti] from 140.163.4.243
11:36:55:WU01:FS01:Connecting to 140.163.4.243:8080
11:36:56:WU01:FS01:Downloading 2.67MiB
11:36:56:WU01:FS01:Download complete
11:36:56:WU01:FS01:Received Unit: id:01 state:DOWNLOAD error:NO_ERROR project:11707 run:85 clone:29 gen:34 core:0x21 unit:0x0000002f8ca304f358702f813be5a08e
11:36:56:WU01:FS01:Starting
11:36:56:WU01:FS01:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:/Users/Bob/AppData/Roaming/FAHClient/cores/fahwebx.stanford.edu/cores/Win32/AMD64/NVIDIA/Fermi/Core_21.fah/FahCore_21.exe -dir 01 -suffix 01 -version 704 -lifeline 4408 -checkpoint 15 -gpu 0 -gpu-vendor nvidia
11:36:56:WU01:FS01:Started FahCore on PID 1516
11:36:56:WU01:FS01:Core PID:3432
11:36:56:WU01:FS01:FahCore 0x21 started
11:36:57:WU01:FS01:0x21:*********************** Log Started 2017-02-10T11:36:56Z ***********************
11:36:57:WU01:FS01:0x21:Project: 11707 (Run 85, Clone 29, Gen 34)
11:36:57:WU01:FS01:0x21:Unit: 0x0000002f8ca304f358702f813be5a08e
11:36:57:WU01:FS01:0x21:CPU: 0x00000000000000000000000000000000
11:36:57:WU01:FS01:0x21:Machine: 1
11:36:57:WU01:FS01:0x21:Reading tar file core.xml
11:36:57:WU01:FS01:0x21:Reading tar file system.xml
11:36:57:WU01:FS01:0x21:Reading tar file integrator.xml
11:36:57:WU01:FS01:0x21:Reading tar file state.xml
11:36:57:WU01:FS01:0x21:Digital signatures verified
11:36:57:WU01:FS01:0x21:Folding@home GPU Core21 Folding@home Core
11:36:57:WU01:FS01:0x21:Version 0.0.18
11:36:57:WU01:FS01:0x21:ERROR:126: Bad platformId size.
11:36:57:WU01:FS01:0x21:Saving result file logfile_01.txt
11:36:57:WU01:FS01:0x21:Saving result file log.txt
11:36:57:WU01:FS01:0x21:Folding@home Core Shutdown: BAD_WORK_UNIT
11:36:58:WARNING:WU01:FS01:FahCore returned: BAD_WORK_UNIT (114 = 0x72)
11:36:58:WU01:FS01:Sending unit results: id:01 state:SEND error:FAULTY project:11707 run:85 clone:29 gen:34 core:0x21 unit:0x0000002f8ca304f358702f813be5a08e
11:36:58:WU01:FS01:Uploading 1.86KiB to 140.163.4.243
11:36:58:WU01:FS01:Connecting to 140.163.4.243:8080
11:36:58:WU01:FS01:Upload complete
11:36:58:WU01:FS01:Server responded WORK_ACK (400)
11:36:58:WU01:FS01:Cleaning up
11:36:58:WU02:FS01:Connecting to 171.67.108.45:80
11:36:59:WU02:FS01:Assigned to work server 171.67.108.101
11:36:59:WU02:FS01:Requesting new work unit for slot 01: READY gpu:0:GM200 [GeForce GTX 980 Ti] from 171.67.108.101
11:36:59:WU02:FS01:Connecting to 171.67.108.101:8080
11:36:59:ERROR:WU02:FS01:Exception: Server did not assign work unit
11:36:59:WU02:FS01:Connecting to 171.67.108.45:80
11:37:00:WU02:FS01:Assigned to work server 140.163.4.244
11:37:00:WU02:FS01:Requesting new work unit for slot 01: READY gpu:0:GM200 [GeForce GTX 980 Ti] from 140.163.4.244
11:37:00:WU02:FS01:Connecting to 140.163.4.244:8080
11:37:00:WU02:FS01:Downloading 2.54MiB
11:37:00:WU02:FS01:Download complete
11:37:00:WU02:FS01:Received Unit: id:02 state:DOWNLOAD error:NO_ERROR project:10490 run:379 clone:0 gen:570 core:0x18 unit:0x000002a68ca304f45537e9161f9bd355
11:37:00:WU02:FS01:Downloading core from http://fahwebx.stanford.edu/cores/Win32/AMD64/NVIDIA/Fermi/Core_18.fah
11:37:00:WU02:FS01:Connecting to fahwebx.stanford.edu:80
11:37:01:WU02:FS01:FahCore 18: Downloading 2.54MiB
11:37:02:WU02:FS01:FahCore 18: Download complete
11:37:02:WU02:FS01:Valid core signature
11:37:02:WU02:FS01:Unpacked 8.47MiB to cores/fahwebx.stanford.edu/cores/Win32/AMD64/NVIDIA/Fermi/Core_18.fah/FahCore_18.exe
11:37:02:WU02:FS01:Starting
11:37:02:WU02:FS01:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:/Users/Bob/AppData/Roaming/FAHClient/cores/fahwebx.stanford.edu/cores/Win32/AMD64/NVIDIA/Fermi/Core_18.fah/FahCore_18.exe -dir 02 -suffix 01 -version 704 -lifeline 4408 -checkpoint 15 -gpu 0 -gpu-vendor nvidia
11:37:02:WU02:FS01:Started FahCore on PID 520
11:37:03:WU02:FS01:Core PID:4168
11:37:03:WU02:FS01:FahCore 0x18 started
11:37:04:WU02:FS01:0x18:*********************** Log Started 2017-02-10T11:37:03Z ***********************
11:37:04:WU02:FS01:0x18:Project: 10490 (Run 379, Clone 0, Gen 570)
11:37:04:WU02:FS01:0x18:Unit: 0x000002a68ca304f45537e9161f9bd355
11:37:04:WU02:FS01:0x18:CPU: 0x00000000000000000000000000000000
11:37:04:WU02:FS01:0x18:Machine: 1
11:37:04:WU02:FS01:0x18:Reading tar file core.xml
11:37:04:WU02:FS01:0x18:Reading tar file system.xml
11:37:04:WU02:FS01:0x18:Reading tar file integrator.xml
11:37:04:WU02:FS01:0x18:Reading tar file state.xml
11:37:05:WU02:FS01:0x18:Digital signatures verified
11:37:05:WU02:FS01:0x18:Folding@home GPU core18
11:37:05:WU02:FS01:0x18:Version 0.0.4
11:37:05:WU02:FS01:0x18:ERROR:exception: Bad platformId size.
11:37:05:WU02:FS01:0x18:Saving result file logfile_01.txt
11:37:05:WU02:FS01:0x18:Saving result file log.txt
11:37:05:WU02:FS01:0x18:Folding@home Core Shutdown: BAD_WORK_UNIT
11:37:05:WARNING:WU02:FS01:FahCore returned: BAD_WORK_UNIT (114 = 0x72)
11:37:05:WU02:FS01:Sending unit results: id:02 state:SEND error:FAULTY project:10490 run:379 clone:0 gen:570 core:0x18 unit:0x000002a68ca304f45537e9161f9bd355
11:37:05:WU02:FS01:Uploading 1.84KiB to 140.163.4.244
11:37:05:WU02:FS01:Connecting to 140.163.4.244:8080
11:37:05:WU02:FS01:Upload complete
11:37:05:WU01:FS01:Connecting to 171.67.108.45:80
11:37:06:WU02:FS01:Server responded WORK_ACK (400)
11:37:06:WU02:FS01:Cleaning up
11:37:06:WU01:FS01:Assigned to work server 171.67.108.157
11:37:06:WU01:FS01:Requesting new work unit for slot 01: READY gpu:0:GM200 [GeForce GTX 980 Ti] from 171.67.108.157
11:37:06:WU01:FS01:Connecting to 171.67.108.157:8080
11:37:07:WU01:FS01:Downloading 5.19MiB
11:37:08:WU01:FS01:Download complete
11:37:08:WU01:FS01:Received Unit: id:01 state:DOWNLOAD error:NO_ERROR project:9415 run:309 clone:0 gen:21 core:0x21 unit:0x00000018ab436c9d585e06cb1ec8197a
11:37:08:WU01:FS01:Starting
11:37:08:WU01:FS01:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:/Users/Bob/AppData/Roaming/FAHClient/cores/fahwebx.stanford.edu/cores/Win32/AMD64/NVIDIA/Fermi/Core_21.fah/FahCore_21.exe -dir 01 -suffix 01 -version 704 -lifeline 4408 -checkpoint 15 -gpu 0 -gpu-vendor nvidia
11:37:08:WU01:FS01:Started FahCore on PID 2084
11:37:08:WU01:FS01:Core PID:1636
11:37:08:WU01:FS01:FahCore 0x21 started
11:37:09:WARNING:WU01:FS01:FahCore returned: BAD_WORK_UNIT (114 = 0x72)
11:37:09:WU01:FS01:Sending unit results: id:01 state:SEND error:FAULTY project:9415 run:309 clone:0 gen:21 core:0x21 unit:0x00000018ab436c9d585e06cb1ec8197a
11:37:09:WU01:FS01:Uploading 5.50KiB to 171.67.108.157
11:37:09:WU01:FS01:Connecting to 171.67.108.157:8080
11:37:09:WU02:FS01:Connecting to 171.67.108.45:80
11:37:09:WU01:FS01:Upload complete
11:37:09:WU01:FS01:Server responded WORK_ACK (400)
11:37:10:WU01:FS01:Cleaning up
11:37:10:WU02:FS01:Assigned to work server 171.67.108.157
11:37:10:WU02:FS01:Requesting new work unit for slot 01: READY gpu:0:GM200 [GeForce GTX 980 Ti] from 171.67.108.157
11:37:10:WU02:FS01:Connecting to 171.67.108.157:8080
11:37:10:WU02:FS01:Downloading 8.85MiB
11:37:12:WU02:FS01:Download complete
11:37:12:WU02:FS01:Received Unit: id:02 state:DOWNLOAD error:NO_ERROR project:9431 run:490 clone:0 gen:42 core:0x21 unit:0x00000032ab436c9d586fdd3709c28fc6
11:37:12:WU02:FS01:Starting
11:37:12:WU02:FS01:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:/Users/Bob/AppData/Roaming/FAHClient/cores/fahwebx.stanford.edu/cores/Win32/AMD64/NVIDIA/Fermi/Core_21.fah/FahCore_21.exe -dir 02 -suffix 01 -version 704 -lifeline 4408 -checkpoint 15 -gpu 0 -gpu-vendor nvidia
11:37:12:WU02:FS01:Started FahCore on PID 2540
11:37:12:WU02:FS01:Core PID:4716
11:37:12:WU02:FS01:FahCore 0x21 started
11:37:13:WARNING:WU02:FS01:FahCore returned: BAD_WORK_UNIT (114 = 0x72)
11:37:13:WU02:FS01:Sending unit results: id:02 state:SEND error:FAULTY project:9431 run:490 clone:0 gen:42 core:0x21 unit:0x00000032ab436c9d586fdd3709c28fc6
11:37:13:WU02:FS01:Uploading 5.50KiB to 171.67.108.157
11:37:13:WU02:FS01:Connecting to 171.67.108.157:8080
11:37:13:WU01:FS01:Connecting to 171.67.108.45:80
11:37:13:WU02:FS01:Upload complete
11:37:13:WU02:FS01:Server responded WORK_ACK (400)
11:37:14:WU02:FS01:Cleaning up
11:37:14:WU01:FS01:Assigned to work server 140.163.4.243
11:37:14:WU01:FS01:Requesting new work unit for slot 01: READY gpu:0:GM200 [GeForce GTX 980 Ti] from 140.163.4.243
11:37:14:WU01:FS01:Connecting to 140.163.4.243:8080
11:37:14:WU01:FS01:Downloading 5.11MiB
11:37:15:WU01:FS01:Download complete
11:37:15:WU01:FS01:Received Unit: id:01 state:DOWNLOAD error:NO_ERROR project:11703 run:0 clone:536 gen:88 core:0x21 unit:0x0000007b8ca304f357a8bc8f8e4def7f
11:37:15:WU01:FS01:Starting
11:37:15:WU01:FS01:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:/Users/Bob/AppData/Roaming/FAHClient/cores/fahwebx.stanford.edu/cores/Win32/AMD64/NVIDIA/Fermi/Core_21.fah/FahCore_21.exe -dir 01 -suffix 01 -version 704 -lifeline 4408 -checkpoint 15 -gpu 0 -gpu-vendor nvidia
11:37:15:WU01:FS01:Started FahCore on PID 4320
11:37:15:WU01:FS01:Core PID:4172
11:37:15:WU01:FS01:FahCore 0x21 started
11:37:16:WU01:FS01:0x21:*********************** Log Started 2017-02-10T11:37:15Z ***********************
11:37:16:WU01:FS01:0x21:Project: 11703 (Run 0, Clone 536, Gen 88)
11:37:16:WU01:FS01:0x21:Unit: 0x0000007b8ca304f357a8bc8f8e4def7f
11:37:16:WU01:FS01:0x21:CPU: 0x00000000000000000000000000000000
11:37:16:WU01:FS01:0x21:Machine: 1
11:37:16:WU01:FS01:0x21:Reading tar file core.xml
11:37:16:WU01:FS01:0x21:Reading tar file system.xml
11:37:16:WU01:FS01:0x21:Reading tar file integrator.xml
11:37:16:WU01:FS01:0x21:Reading tar file state.xml
11:37:17:WU01:FS01:0x21:Digital signatures verified
11:37:17:WU01:FS01:0x21:Folding@home GPU Core21 Folding@home Core
11:37:17:WU01:FS01:0x21:Version 0.0.18
11:37:17:WU01:FS01:0x21:ERROR:126: Bad platformId size.
11:37:17:WU01:FS01:0x21:Saving result file logfile_01.txt
11:37:17:WU01:FS01:0x21:Saving result file log.txt
11:37:17:WU01:FS01:0x21:Folding@home Core Shutdown: BAD_WORK_UNIT
11:37:17:WARNING:WU01:FS01:FahCore returned: BAD_WORK_UNIT (114 = 0x72)
11:37:17:WU01:FS01:Sending unit results: id:01 state:SEND error:FAULTY project:11703 run:0 clone:536 gen:88 core:0x21 unit:0x0000007b8ca304f357a8bc8f8e4def7f
11:37:17:WU01:FS01:Uploading 1.87KiB to 140.163.4.243
11:37:17:WU01:FS01:Connecting to 140.163.4.243:8080
11:37:18:WU01:FS01:Upload complete
11:37:18:WU01:FS01:Server responded WORK_ACK (400)
11:37:18:WU01:FS01:Cleaning up
11:37:18:WU02:FS01:Connecting to 171.67.108.45:80
11:37:18:WU02:FS01:Assigned to work server 171.64.65.84
11:37:18:WU02:FS01:Requesting new work unit for slot 01: READY gpu:0:GM200 [GeForce GTX 980 Ti] from 171.64.65.84
11:37:18:WU02:FS01:Connecting to 171.64.65.84:8080
11:37:19:WU02:FS01:Downloading 3.18MiB
11:37:25:WU02:FS01:Download 43.22%
11:37:27:WU02:FS01:Download complete
11:37:27:WU02:FS01:Received Unit: id:02 state:DOWNLOAD error:NO_ERROR project:9193 run:1 clone:36 gen:209 core:0x21 unit:0x0000012eab40415457cb2dd5d573aaa3
11:37:27:WU02:FS01:Starting
11:37:27:WU02:FS01:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:/Users/Bob/AppData/Roaming/FAHClient/cores/fahwebx.stanford.edu/cores/Win32/AMD64/NVIDIA/Fermi/Core_21.fah/FahCore_21.exe -dir 02 -suffix 01 -version 704 -lifeline 4408 -checkpoint 15 -gpu 0 -gpu-vendor nvidia
11:37:27:WU02:FS01:Started FahCore on PID 3544
11:37:27:WU02:FS01:Core PID:4892
11:37:27:WU02:FS01:FahCore 0x21 started
11:37:28:WU02:FS01:0x21:*********************** Log Started 2017-02-10T11:37:27Z ***********************
11:37:28:WU02:FS01:0x21:Project: 9193 (Run 1, Clone 36, Gen 209)
11:37:28:WU02:FS01:0x21:Unit: 0x0000012eab40415457cb2dd5d573aaa3
11:37:28:WU02:FS01:0x21:CPU: 0x00000000000000000000000000000000
11:37:28:WU02:FS01:0x21:Machine: 1
11:37:28:WU02:FS01:0x21:Reading tar file core.xml
11:37:28:WU02:FS01:0x21:Reading tar file system.xml
11:37:28:WU02:FS01:0x21:Reading tar file integrator.xml
11:37:28:WU02:FS01:0x21:Reading tar file state.xml
11:37:29:WU02:FS01:0x21:Digital signatures verified
11:37:29:WU02:FS01:0x21:Folding@home GPU Core21 Folding@home Core
11:37:29:WU02:FS01:0x21:Version 0.0.18
11:37:29:WU02:FS01:0x21:ERROR:126: Bad platformId size.
11:37:29:WU02:FS01:0x21:Saving result file logfile_01.txt
11:37:29:WU02:FS01:0x21:Saving result file log.txt
11:37:29:WU02:FS01:0x21:Folding@home Core Shutdown: BAD_WORK_UNIT
11:37:29:WARNING:WU02:FS01:FahCore returned: BAD_WORK_UNIT (114 = 0x72)
11:37:29:WU02:FS01:Sending unit results: id:02 state:SEND error:FAULTY project:9193 run:1 clone:36 gen:209 core:0x21 unit:0x0000012eab40415457cb2dd5d573aaa3
11:37:29:WU02:FS01:Uploading 1.86KiB to 171.64.65.84
11:37:29:WU02:FS01:Connecting to 171.64.65.84:8080
11:37:29:WU02:FS01:Upload complete
11:37:29:WU02:FS01:Server responded WORK_ACK (400)
11:37:29:WU02:FS01:Cleaning up
11:37:29:WU01:FS01:Connecting to 171.67.108.45:80
11:37:30:WU01:FS01:Assigned to work server 171.64.65.92
11:37:30:WU01:FS01:Requesting new work unit for slot 01: READY gpu:0:GM200 [GeForce GTX 980 Ti] from 171.64.65.92
11:37:30:WU01:FS01:Connecting to 171.64.65.92:8080
11:37:30:WU01:FS01:Downloading 2.52MiB
11:37:31:Saving configuration to config.xml
11:37:31:<config>
11:37:31:  <!-- Folding Slots -->
11:37:31:  <slot id='0' type='CPU'/>
11:37:31:  <slot id='1' type='GPU'/>
11:37:31:</config>
11:37:32:WU01:FS01:Download complete
11:37:32:WU01:FS01:Received Unit: id:01 state:DOWNLOAD error:NO_ERROR project:9195 run:0 clone:93 gen:373 core:0x21 unit:0x00000248ab40415c57cb2ec2a1bf3725
11:37:33:WU01:FS01:Starting
11:37:33:WU01:FS01:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:/Users/Bob/AppData/Roaming/FAHClient/cores/fahwebx.stanford.edu/cores/Win32/AMD64/NVIDIA/Fermi/Core_21.fah/FahCore_21.exe -dir 01 -suffix 01 -version 704 -lifeline 4408 -checkpoint 15 -gpu 0 -gpu-vendor nvidia
11:37:33:WU01:FS01:Started FahCore on PID 2148
11:37:33:WU01:FS01:Core PID:4544
11:37:33:WU01:FS01:FahCore 0x21 started
11:37:33:WU01:FS01:0x21:*********************** Log Started 2017-02-10T11:37:33Z ***********************
11:37:33:WU01:FS01:0x21:Project: 9195 (Run 0, Clone 93, Gen 373)
11:37:33:WU01:FS01:0x21:Unit: 0x00000248ab40415c57cb2ec2a1bf3725
11:37:33:WU01:FS01:0x21:CPU: 0x00000000000000000000000000000000
11:37:33:WU01:FS01:0x21:Machine: 1
11:37:33:WU01:FS01:0x21:Reading tar file core.xml
11:37:33:WU01:FS01:0x21:Reading tar file system.xml
11:37:33:WU01:FS01:0x21:Reading tar file integrator.xml
11:37:33:WU01:FS01:0x21:Reading tar file state.xml
11:37:34:WU01:FS01:0x21:Digital signatures verified
11:37:34:WU01:FS01:0x21:Folding@home GPU Core21 Folding@home Core
11:37:34:WU01:FS01:0x21:Version 0.0.18
11:37:34:WU01:FS01:0x21:ERROR:126: Bad platformId size.
11:37:34:WU01:FS01:0x21:Saving result file logfile_01.txt
11:37:34:WU01:FS01:0x21:Saving result file log.txt
11:37:34:WU01:FS01:0x21:Folding@home Core Shutdown: BAD_WORK_UNIT
11:37:34:WARNING:WU01:FS01:FahCore returned: BAD_WORK_UNIT (114 = 0x72)
11:37:34:WU01:FS01:Sending unit results: id:01 state:SEND error:FAULTY project:9195 run:0 clone:93 gen:373 core:0x21 unit:0x00000248ab40415c57cb2ec2a1bf3725
11:37:34:WU01:FS01:Uploading 1.87KiB to 171.64.65.92
11:37:34:WU01:FS01:Connecting to 171.64.65.92:8080
11:37:34:WU01:FS01:Upload complete
11:37:34:WU01:FS01:Server responded WORK_ACK (400)
11:37:34:WU01:FS01:Cleaning up
11:37:34:WU02:FS01:Connecting to 171.67.108.45:80
11:37:35:WU02:FS01:Assigned to work server 140.163.4.242
11:37:35:WU02:FS01:Requesting new work unit for slot 01: READY gpu:0:GM200 [GeForce GTX 980 Ti] from 140.163.4.242
11:37:35:WU02:FS01:Connecting to 140.163.4.242:8080
11:37:35:WU02:FS01:Downloading 4.05MiB
11:37:36:WU02:FS01:Download complete
11:37:36:WU02:FS01:Received Unit: id:02 state:DOWNLOAD error:NO_ERROR project:11401 run:29 clone:19 gen:15 core:0x21 unit:0x0000001f8ca304f255de8f514953c085
11:37:36:WU02:FS01:Starting
11:37:36:WU02:FS01:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:/Users/Bob/AppData/Roaming/FAHClient/cores/fahwebx.stanford.edu/cores/Win32/AMD64/NVIDIA/Fermi/Core_21.fah/FahCore_21.exe -dir 02 -suffix 01 -version 704 -lifeline 4408 -checkpoint 15 -gpu 0 -gpu-vendor nvidia
11:37:36:WU02:FS01:Started FahCore on PID 5040
11:37:36:WU02:FS01:Core PID:4012
11:37:36:WU02:FS01:FahCore 0x21 started
11:37:36:WU02:FS01:0x21:*********************** Log Started 2017-02-10T11:37:36Z ***********************
11:37:36:WU02:FS01:0x21:Project: 11401 (Run 29, Clone 19, Gen 15)
11:37:36:WU02:FS01:0x21:Unit: 0x0000001f8ca304f255de8f514953c085
11:37:36:WU02:FS01:0x21:CPU: 0x00000000000000000000000000000000
11:37:36:WU02:FS01:0x21:Machine: 1
11:37:36:WU02:FS01:0x21:Reading tar file core.xml
11:37:36:WU02:FS01:0x21:Reading tar file system.xml
11:37:37:WU02:FS01:0x21:Reading tar file integrator.xml
11:37:37:WU02:FS01:0x21:Reading tar file state.xml
11:37:38:WU02:FS01:0x21:Digital signatures verified
11:37:38:WU02:FS01:0x21:Folding@home GPU Core21 Folding@home Core
11:37:38:WU02:FS01:0x21:Version 0.0.18
11:37:38:WU02:FS01:0x21:ERROR:126: Bad platformId size.
11:37:38:WU02:FS01:0x21:Saving result file logfile_01.txt
11:37:38:WU02:FS01:0x21:Saving result file log.txt
11:37:38:WU02:FS01:0x21:Folding@home Core Shutdown: BAD_WORK_UNIT
11:37:38:WARNING:WU02:FS01:FahCore returned: BAD_WORK_UNIT (114 = 0x72)
11:37:38:WU02:FS01:Sending unit results: id:02 state:SEND error:FAULTY project:11401 run:29 clone:19 gen:15 core:0x21 unit:0x0000001f8ca304f255de8f514953c085
11:37:38:WU02:FS01:Uploading 1.87KiB to 140.163.4.242
11:37:38:WU02:FS01:Connecting to 140.163.4.242:8080
11:37:38:WU02:FS01:Upload complete
11:37:38:WU02:FS01:Server responded WORK_ACK (400)
11:37:38:WU02:FS01:Cleaning up
11:40:53:WU00:FS00:0xa4:Completed 25000 out of 2500000 steps  (1%)
11:45:16:WU00:FS00:0xa4:Completed 50000 out of 2500000 steps  (2%)
11:45:39:Saving configuration to config.xml
11:45:39:<config>
11:45:39:  <!-- User Information -->
11:45:39:  <passkey v='********************************'/>
11:45:39:  <team v='328'/>
11:45:39:  <user v='BigApplePi'/>
11:45:39:
11:45:39:  <!-- Folding Slots -->
11:45:39:  <slot id='0' type='CPU'/>
11:45:39:  <slot id='1' type='GPU'/>
11:45:39:</config>
11:46:15:50:127.0.0.1:New Web connection
11:49:45:WU00:FS00:0xa4:Completed 75000 out of 2500000 steps  (3%)
11:54:11:WU00:FS00:0xa4:Completed 100000 out of 2500000 steps  (4%)
11:58:36:WU00:FS00:0xa4:Completed 125000 out of 2500000 steps  (5%)
12:03:01:WU00:FS00:0xa4:Completed 150000 out of 2500000 steps  (6%)
12:07:29:WU00:FS00:0xa4:Completed 175000 out of 2500000 steps  (7%)
12:11:57:WU00:FS00:0xa4:Completed 200000 out of 2500000 steps  (8%)
12:16:28:WU00:FS00:0xa4:Completed 225000 out of 2500000 steps  (9%)
12:21:04:WU00:FS00:0xa4:Completed 250000 out of 2500000 steps  (10%)
12:25:36:WU00:FS00:0xa4:Completed 275000 out of 2500000 steps  (11%)
12:30:10:WU00:FS00:0xa4:Completed 300000 out of 2500000 steps  (12%)
12:34:44:WU00:FS00:0xa4:Completed 325000 out of 2500000 steps  (13%)
12:39:17:WU00:FS00:0xa4:Completed 350000 out of 2500000 steps  (14%)
12:43:49:WU00:FS00:0xa4:Completed 375000 out of 2500000 steps  (15%)
12:48:20:WU00:FS00:0xa4:Completed 400000 out of 2500000 steps  (16%)
12:52:52:WU00:FS00:0xa4:Completed 425000 out of 2500000 steps  (17%)
12:57:21:WU00:FS00:0xa4:Completed 450000 out of 2500000 steps  (18%)
13:01:49:WU00:FS00:0xa4:Completed 475000 out of 2500000 steps  (19%)
13:06:18:WU00:FS00:0xa4:Completed 500000 out of 2500000 steps  (20%)
13:10:48:WU00:FS00:0xa4:Completed 525000 out of 2500000 steps  (21%)
13:15:18:WU00:FS00:0xa4:Completed 550000 out of 2500000 steps  (22%)
13:19:48:WU00:FS00:0xa4:Completed 575000 out of 2500000 steps  (23%)
13:24:19:WU00:FS00:0xa4:Completed 600000 out of 2500000 steps  (24%)
13:28:50:WU00:FS00:0xa4:Completed 625000 out of 2500000 steps  (25%)
13:33:24:WU00:FS00:0xa4:Completed 650000 out of 2500000 steps  (26%)
13:38:03:WU00:FS00:0xa4:Completed 675000 out of 2500000 steps  (27%)
13:42:42:WU00:FS00:0xa4:Completed 700000 out of 2500000 steps  (28%)
13:47:13:WU00:FS00:0xa4:Completed 725000 out of 2500000 steps  (29%)
13:51:46:WU00:FS00:0xa4:Completed 750000 out of 2500000 steps  (30%)
13:56:21:WU00:FS00:0xa4:Completed 775000 out of 2500000 steps  (31%)
14:00:56:WU00:FS00:0xa4:Completed 800000 out of 2500000 steps  (32%)
14:05:30:WU00:FS00:0xa4:Completed 825000 out of 2500000 steps  (33%)
14:10:07:WU00:FS00:0xa4:Completed 850000 out of 2500000 steps  (34%)
14:14:42:WU00:FS00:0xa4:Completed 875000 out of 2500000 steps  (35%)
14:19:16:WU00:FS00:0xa4:Completed 900000 out of 2500000 steps  (36%)
14:23:51:WU00:FS00:0xa4:Completed 925000 out of 2500000 steps  (37%)
14:28:27:WU00:FS00:0xa4:Completed 950000 out of 2500000 steps  (38%)
14:33:06:WU00:FS00:0xa4:Completed 975000 out of 2500000 steps  (39%)
14:37:42:WU00:FS00:0xa4:Completed 1000000 out of 2500000 steps  (40%)
14:42:19:WU00:FS00:0xa4:Completed 1025000 out of 2500000 steps  (41%)
14:47:02:WU00:FS00:0xa4:Completed 1050000 out of 2500000 steps  (42%)
14:51:44:WU00:FS00:0xa4:Completed 1075000 out of 2500000 steps  (43%)
14:56:25:WU00:FS00:0xa4:Completed 1100000 out of 2500000 steps  (44%)
15:01:10:WU00:FS00:0xa4:Completed 1125000 ou
Mod edit: added Code tags to log listing
Re: GPU folding fails -- clEnqueueReadBuffer
The error you are getting is:
which is not the error being talked about in this topic. Earlier in the log is this message:
This usually indicates an incomplete installation of the nVidia video driver software, were they recently updated through Windows Update? If so, you will need to download and install the drivers from nVidia so that the necessary OpenCL support is present. The drivers MS supplies as part of Windows Update often do not include that support or break a previous installation of OpenCL.
