Blocking a Server and its Projects
Is their a way to Block the below projects or the Server they are hosed from?
I do not want to run them is why.
vspe4.stanford.edu [171.67.108.104]
9205 171.67.108.104 p9205 116371 7.00 10.00 34820 100 OPENMM_21 Description jadeshi 0.75
9206 171.67.108.104 p9206 116371 7.00 10.00 34820 100 OPENMM_21 Description jadeshi 0.75
9207 171.67.108.104 p9207 118900 7.00 10.00 34820 100 OPENMM_21 Description jadeshi 0.75
9208 171.67.108.104 p9208 118900 7.00 10.00 34820 100 OPENMM_21 Description jadeshi 0.75
9209 171.67.108.104 p9209 118900 7.00 10.00 34820 100 OPENMM_21 Description jadeshi 0.75
9210 171.67.108.104 p9210 118900 7.00 10.00 34820 100 OPENMM_21 Description jadeshi 0.75
9211 171.67.108.104 p9211 118900 7.00 10.00 34820 100 OPENMM_21 Description jadeshi 0.75
9212 171.67.108.104 p9212 118900 7.00 10.00 34820 100 OPENMM_21 Description jadeshi 0.75
9213 171.67.108.104 p9213 118900 7.00 10.00 34820 100 OPENMM_21 Description jadeshi 0.75
Thank you.
Thank you.
ComputerGenie
Re: Blocking a Server and its Projects
Why don't you want to run them?
No, you can't block or choose the project you get ...
I don't want to fold is not a valid reason ... there is probably a reason (or a problem) with them that makes you think that you don't want them and it would be better to solve this issue ...
This is a likely reason, some of these really suck for ppd. viewtopic.php?f=19&t=29288 The guy in charge was contacted a month ago and nothing has been said about it since.
Nathan_P
Not currently folding
Having just trawled my hfm logs, they run just fine on a 980ti or anything less, ppd does however tail off on a 1070 or greater. However since 9205 & 06 give me above normal PPD on my 980ti and 1070 send them all to me
On a serious note, PPD does vary across projects, it all evens out in the end
SteveWillis
- Hardware configuration: PC 1:
Linux Mint 17.3
PC2:
Linux Mint 18
Open air case
three gtx 1080,
I haven't gotten any of those in quite a while and I'm sooo glad. My PPD is up 400K without them.Rel25917 wrote:This is a likely reason, some of these really suck for ppd. viewtopic.php?f=19&t=29288 The guy in charge was contacted a month ago and nothing has been said about it since.
Because they run for 8-10 hours and stay at 99% for 2 or 3 more hours.ComputerGenie wrote:Why don't you want to run them?
The last one that completed on my GTX 1080 took 15 hours.
They are Poorly made and with NVIDIA having bad driver and driver it is costing me a lot money to only have failed WU over and over on my GTX 1080.
At least on my GTX 980 they do complete after 9 or so hours.
This why for the most part.
I have tried that before and found it best not to ask for that kind of help here on the Support Forum.toTOW wrote:No, you can't block or choose the project you get ...
All the other Threads about 92xx Projects have been forgotten about and have gone unanswered.
That is why I only asked if they could be blocked and that was all.
ComputerGenie
If it's taking 6 more hours with a 1080 than a 980, seems like a setup/card issue and not a project issue (to me, anyway).
Not Really, As One is an Apple and the outher one is a BananaComputerGenie wrote: If it's taking 6 more hours with a 1080 than a 980, seems like a setup/card issue and not a project issue (to me, anyway).
And you're complaining about the Carrot not being big enough ...
