Bad work units on AMD GPU slot
Nilushan
Post by Nilushan »
I have the folding@home client installed on my computer and have been folding on the CPU slot without problems. I wanted to fold on the GPU and added a GPU slot from FAHControl. Since adding and starting the GPU slot, I keep on getting bad work units. What happens is the WU downloads, folding starts and core shuts down immediately, and then the WU is returned.
I am using a HIS 5750 GPU with the open source driver
Log containing system details
*********************** Log Started 2016-08-28T19:40:27Z ***********************
19:40:28:************************* Folding@home Client *************************
19:40:28:    Website: http://folding.stanford.edu/
19:40:28:  Copyright: (c) 2009-2014 Stanford University
19:40:28:     Author: Joseph Coffland <joseph@cauldrondevelopment.com>
19:40:28:       Args: --config /opt/fah/config.xml --exec-directory=/opt/fah
19:40:28:             --data-directory=/opt/fah
19:40:28:     Config: /opt/fah/config.xml
19:40:28:******************************** Build ********************************
19:40:28:    Version: 7.4.4
19:40:28:       Date: Mar 4 2014
19:40:28:       Time: 12:02:38
19:40:28:    SVN Rev: 4130
19:40:28:     Branch: fah/trunk/client
19:40:28:   Compiler: GNU 4.4.7
19:40:28:    Options: -std=gnu++98 -O3 -funroll-loops -mfpmath=sse -ffast-math
19:40:28:             -fno-unsafe-math-optimizations -msse2
19:40:28:   Platform: linux2 3.2.0-1-amd64
19:40:28:       Bits: 64
19:40:28:       Mode: Release
19:40:28:******************************* System ********************************
19:40:28:        CPU: Intel(R) Core(TM)2 Quad CPU Q6600 @ 2.40GHz
19:40:28:     CPU ID: GenuineIntel Family 6 Model 15 Stepping 11
19:40:28:       CPUs: 4
19:40:28:     Memory: 3.86GiB
19:40:28:Free Memory: 1.61GiB
19:40:28:    Threads: POSIX_THREADS
19:40:28: OS Version: 4.7
19:40:28:Has Battery: false
19:40:28: On Battery: false
19:40:28: UTC Offset: 5
19:40:28:        PID: 2495
19:40:28:        CWD: /opt/fah
19:40:28:         OS: Linux 4.7.2-1-ARCH x86_64
19:40:28:    OS Arch: AMD64
19:40:28:       GPUs: 1
19:40:28:      GPU 0: ATI:4 Juniper [Radeon HD 5700/6750]
19:40:28:       CUDA: Not detected
19:40:28:***********************************************************************
19:40:28:<config>
19:40:28:  <!-- Folding Slot Configuration -->
19:40:28:  <cause v='ALZHEIMERS'/>
19:40:28:
19:40:28:  <!-- Network -->
19:40:28:  <proxy v=':8080'/>
19:40:28:
19:40:28:  <!-- Slot Control -->
19:40:28:  <power v='MEDIUM'/>
19:40:28:
19:40:28:  <!-- User Information -->
19:40:28:  <passkey v='********************************'/>
19:40:28:  <team v='111065'/>
19:40:28:  <user v='nilushan'/>
19:40:28:
19:40:28:  <!-- Folding Slots -->
19:40:28:  <slot id='0' type='CPU'>
19:40:28:    <paused v='true'/>
19:40:28:  </slot>
19:40:28:  <slot id='1' type='GPU'>
19:40:28:  </slot>
19:40:28:</config>
19:40:28:Trying to access database...
19:40:28:Successfully acquired database lock
19:40:28:Enabled folding slot 00: PAUSED cpu:2 (by user)
19:40:28:Enabled folding slot 01: PAUSED gpu:0:Juniper [Radeon HD 5700/6750] (by user)
log for the GPU slot
*********************** Log Started 2016-08-28T19:09:02Z ***********************
19:12:19:WU01:FS01:Connecting to 171.67.108.45:80
19:12:20:WU01:FS01:Assigned to work server 140.163.4.244
19:12:20:WU01:FS01:Requesting new work unit for slot 01: READY gpu:0:Juniper [Radeon HD 5700/6750] from 140.163.4.244
19:12:20:WU01:FS01:Connecting to 140.163.4.244:8080
19:12:22:WU01:FS01:Downloading 2.77MiB
19:12:28:WU01:FS01:Download 9.01%
19:12:34:WU01:FS01:Download 24.78%
19:12:40:WU01:FS01:Download 49.57%
19:12:46:WU01:FS01:Download 72.10%
19:12:52:WU01:FS01:Download 92.38%
19:12:54:WU01:FS01:Download complete
19:12:54:WU01:FS01:Received Unit: id:01 state:DOWNLOAD error:NO_ERROR project:13500 run:1 clone:894 gen:1 core:0x21 unit:0x000000018ca304f457a359789519d821
19:12:54:WU01:FS01:Starting
19:12:54:WU01:FS01:Running FahCore: /opt/fah/FAHCoreWrapper /opt/fah/cores/web.stanford.edu/~pande/Linux/AMD64/ATI/R600/Core_21.fah/FahCore_21 -dir 01 -suffix 01 -version 704 -lifeline 15615 -checkpoint 15 -gpu 0 -gpu-vendor ati
19:12:54:WU01:FS01:Started FahCore on PID 17997
19:12:54:WU01:FS01:Core PID:18001
19:12:54:WU01:FS01:FahCore 0x21 started
19:12:55:WU01:FS01:0x21:*********************** Log Started 2016-08-28T19:12:55Z ***********************
19:12:55:WU01:FS01:0x21:Project: 13500 (Run 1, Clone 894, Gen 1)
19:12:55:WU01:FS01:0x21:Unit: 0x000000018ca304f457a359789519d821
19:12:55:WU01:FS01:0x21:CPU: 0x00000000000000000000000000000000
19:12:55:WU01:FS01:0x21:Machine: 1
19:12:55:WU01:FS01:0x21:Reading tar file core.xml
19:12:55:WU01:FS01:0x21:Reading tar file system.xml
19:12:55:WU01:FS01:0x21:Reading tar file integrator.xml
19:12:55:WU01:FS01:0x21:Reading tar file state.xml
19:12:56:WU01:FS01:0x21:Digital signatures verified
19:12:56:WU01:FS01:0x21:Folding@home GPU Core21 Folding@home Core
19:12:56:WU01:FS01:0x21:Version 0.0.17
19:12:56:WU01:FS01:0x21:ERROR:Bad platformId size.
19:12:56:WU01:FS01:0x21:Saving result file logfile_01.txt
19:12:56:WU01:FS01:0x21:Saving result file log.txt
19:12:56:WU01:FS01:0x21:Folding@home Core Shutdown: BAD_WORK_UNIT
19:12:56:WARNING:WU01:FS01:FahCore returned: BAD_WORK_UNIT (114 = 0x72)
19:12:56:WU01:FS01:Sending unit results: id:01 state:SEND error:FAULTY project:13500 run:1 clone:894 gen:1 core:0x21 unit:0x000000018ca304f457a359789519d821
19:12:56:WU01:FS01:Uploading 2.18KiB to 140.163.4.244
19:12:56:WU01:FS01:Connecting to 140.163.4.244:8080
19:12:57:WU01:FS01:Upload complete
19:13:02:WU02:FS01:Connecting to 171.67.108.45:80
19:13:03:WU01:FS01:Server responded WORK_ACK (400)
19:13:03:WU01:FS01:Cleaning up
19:13:04:WU02:FS01:Assigned to work server 171.67.108.105
19:13:04:WU02:FS01:Requesting new work unit for slot 01: READY gpu:0:Juniper [Radeon HD 5700/6750] from 171.67.108.105
19:13:04:WU02:FS01:Connecting to 171.67.108.105:8080
19:13:08:WU02:FS01:Downloading 20.91MiB
19:13:14:WU02:FS01:Download 1.20%
19:13:20:WU02:FS01:Download 3.59%
19:13:26:WU02:FS01:Download 5.98%
19:13:33:WU02:FS01:Download 7.77%
19:13:40:WU02:FS01:Download 8.67%
19:13:46:WU02:FS01:Download 11.06%
19:13:52:WU02:FS01:Download 12.26%
19:13:58:WU02:FS01:Download 12.85%
19:14:04:WU02:FS01:Download 14.65%
19:14:10:WU02:FS01:Download 16.14%
19:14:16:WU02:FS01:Download 19.13%
19:14:22:WU02:FS01:Download 21.22%
19:14:37:WU02:FS01:Download 22.72%
19:14:44:WU02:FS01:Download 23.91%
19:14:50:WU02:FS01:Download 26.60%
19:14:56:WU02:FS01:Download 28.99%
19:15:02:WU02:FS01:Download 30.79%
19:15:08:WU02:FS01:Download 32.28%
19:15:14:WU02:FS01:Download 34.08%
19:15:20:WU02:FS01:Download 35.27%
19:15:26:WU02:FS01:Download 37.66%
19:15:32:WU02:FS01:Download 39.16%
19:15:39:WU02:FS01:Download 40.65%
19:15:45:WU02:FS01:Download 42.15%
19:15:51:WU02:FS01:Download 43.64%
19:15:58:WU02:FS01:Download 44.54%
19:16:04:WU02:FS01:Download 47.23%
19:16:10:WU02:FS01:Download 49.92%
19:16:16:WU02:FS01:Download 51.71%
19:16:22:WU02:FS01:Download 54.10%
19:16:29:WU02:FS01:Download 56.19%
19:16:35:WU02:FS01:Download 57.69%
19:16:41:WU02:FS01:Download 60.08%
19:16:47:WU02:FS01:Download 61.87%
19:16:53:WU02:FS01:Download 63.67%
19:16:59:WU02:FS01:Download 65.76%
19:17:05:WU02:FS01:Download 69.05%
19:17:11:WU02:FS01:Download 72.33%
19:17:17:WU02:FS01:Download 75.03%
19:17:24:WU02:FS01:Download 76.82%
19:17:31:WU02:FS01:Download 77.72%
19:17:37:WU02:FS01:Download 79.21%
19:17:43:WU02:FS01:Download 80.41%
19:17:50:WU02:FS01:Download 81.60%
19:17:56:WU02:FS01:Download 83.10%
19:18:04:WU02:FS01:Download 84.89%
19:18:10:WU02:FS01:Download 86.68%
19:18:16:WU02:FS01:Download 89.37%
19:18:22:WU02:FS01:Download 93.56%
19:18:28:WU02:FS01:Download 95.95%
19:18:34:WU02:FS01:Download 97.74%
19:18:38:WU02:FS01:Download complete
19:18:38:WU02:FS01:Received Unit: id:02 state:DOWNLOAD error:NO_ERROR project:9177 run:23 clone:7 gen:0 core:0x21 unit:0x00000000ab436c6957b24c292aa944a7
19:18:38:WU02:FS01:Starting
19:18:38:WU02:FS01:Running FahCore: /opt/fah/FAHCoreWrapper /opt/fah/cores/web.stanford.edu/~pande/Linux/AMD64/ATI/R600/Core_21.fah/FahCore_21 -dir 02 -suffix 01 -version 704 -lifeline 15615 -checkpoint 15 -gpu 0 -gpu-vendor ati
19:18:38:WU02:FS01:Started FahCore on PID 21437
19:18:38:WU02:FS01:Core PID:21441
19:18:38:WU02:FS01:FahCore 0x21 started
19:18:38:WARNING:WU02:FS01:FahCore returned: BAD_WORK_UNIT (114 = 0x72)
19:18:38:WU02:FS01:Sending unit results: id:02 state:SEND error:FAULTY project:9177 run:23 clone:7 gen:0 core:0x21 unit:0x00000000ab436c6957b24c292aa944a7
19:18:38:WU02:FS01:Uploading 6.00KiB to 171.67.108.105
19:18:38:WU02:FS01:Connecting to 171.67.108.105:8080
19:18:39:WU01:FS01:Connecting to 171.67.108.45:80
19:18:40:WU02:FS01:Upload complete
19:18:40:WU02:FS01:Server responded WORK_ACK (400)
19:18:40:WU02:FS01:Cleaning up
19:18:41:WU01:FS01:Assigned to work server 171.64.65.98
19:18:41:WU01:FS01:Requesting new work unit for slot 01: READY gpu:0:Juniper [Radeon HD 5700/6750] from 171.64.65.98
19:18:41:WU01:FS01:Connecting to 171.64.65.98:8080
19:18:42:WU01:FS01:Downloading 15.70MiB
19:18:49:WU01:FS01:Download 1.99%
19:18:57:WU01:FS01:Download 3.58%
19:19:05:WU01:FS01:Download 4.78%
19:19:11:WU01:FS01:Download 5.57%
19:19:19:WU01:FS01:Download 6.77%
19:19:26:WU01:FS01:Download 7.96%
19:19:33:WU01:FS01:Download 8.76%
19:19:39:WU01:FS01:Download 9.16%
19:19:45:WU01:FS01:Download 9.95%
19:19:52:WU01:FS01:Download 10.75%
19:20:00:WU01:FS01:Download 11.94%
19:20:08:WU01:FS01:Download 13.14%
19:20:17:WU01:FS01:Download 13.93%
19:20:25:WU01:FS01:Download 15.13%
19:20:31:WU01:FS01:Download 15.92%
19:20:38:WU01:FS01:Download 17.52%
19:20:45:WU01:FS01:Download 19.11%
19:20:51:WU01:FS01:Download 20.30%
19:20:57:WU01:FS01:Download 21.90%
19:21:04:WU01:FS01:Download 23.09%
19:21:11:WU01:FS01:Download 24.28%
19:21:18:WU01:FS01:Download 25.48%
19:21:24:WU01:FS01:Download 26.67%
19:21:30:WU01:FS01:Download 28.27%
19:21:37:WU01:FS01:Download 29.46%
19:21:46:WU01:FS01:Download 30.65%
19:21:52:WU01:FS01:Download 31.45%
19:21:59:WU01:FS01:Download 32.25%
19:22:10:WU01:FS01:Download 33.44%
19:22:17:WU01:FS01:Download 34.24%
19:22:23:WU01:FS01:Download 35.03%
19:22:30:WU01:FS01:Download 36.63%
19:22:38:WU01:FS01:Download 37.82%
19:22:47:WU01:FS01:Download 39.01%
19:22:54:WU01:FS01:Download 40.21%
19:23:00:WU01:FS01:Download 41.80%
19:23:06:WU01:FS01:Download 43.39%
19:23:12:WU01:FS01:Download 44.19%
19:23:19:WU01:FS01:Download 44.99%
19:23:26:WU01:FS01:Download 45.78%
19:23:33:WU01:FS01:Download 46.18%
19:23:39:WU01:FS01:Download 46.98%
19:23:46:WU01:FS01:Download 47.77%
19:23:54:WU01:FS01:Download 48.57%
19:24:01:WU01:FS01:Download 49.76%
19:24:08:WU01:FS01:Download 50.96%
19:24:15:WU01:FS01:Download 52.15%
19:24:21:WU01:FS01:Download 52.95%
19:24:28:WU01:FS01:Download 54.14%
19:24:35:WU01:FS01:Download 55.34%
19:24:43:WU01:FS01:Download 56.53%
19:24:49:WU01:FS01:Download 57.33%
19:24:55:WU01:FS01:Download 58.12%
19:25:02:WU01:FS01:Download 59.32%
19:25:09:WU01:FS01:Download 60.51%
19:25:16:WU01:FS01:Download 61.71%
19:25:23:WU01:FS01:Download 62.90%
19:25:30:WU01:FS01:Download 64.10%
19:25:37:WU01:FS01:Download 65.29%
19:25:43:WU01:FS01:Download 66.48%
19:25:51:WU01:FS01:Download 67.28%
19:25:58:WU01:FS01:Download 68.47%
19:26:06:WU01:FS01:Download 69.67%
19:26:13:WU01:FS01:Download 70.86%
19:26:20:WU01:FS01:Download 72.85%
19:26:26:WU01:FS01:Download 74.45%
19:26:32:WU01:FS01:Download 76.04%
19:26:40:WU01:FS01:Download 77.23%
19:26:47:WU01:FS01:Download 78.03%
19:26:53:WU01:FS01:Download 78.83%
19:26:59:WU01:FS01:Download 79.62%
19:27:06:WU01:FS01:Download 80.82%
19:27:12:WU01:FS01:Download 82.01%
19:27:18:WU01:FS01:Download 82.81%
19:27:26:WU01:FS01:Download 83.60%
19:27:33:WU01:FS01:Download 84.40%
19:27:40:WU01:FS01:Download 85.20%
19:27:46:WU01:FS01:Download 85.99%
19:27:55:WU01:FS01:Download 86.79%
19:28:04:WU01:FS01:Download 87.98%
19:28:10:WU01:FS01:Download 89.18%
19:28:18:WU01:FS01:Download 90.37%
19:28:24:WU01:FS01:Download 91.17%
19:28:31:WU01:FS01:Download 91.96%
19:28:38:WU01:FS01:Download 93.56%
19:28:45:WU01:FS01:Download 95.55%
19:28:54:WU01:FS01:Download 96.74%
19:29:01:WU01:FS01:Download 97.93%
19:29:07:WU01:FS01:Download 99.53%
19:29:11:WU01:FS01:Download complete
19:29:11:WU01:FS01:Received Unit: id:01 state:DOWNLOAD error:NO_ERROR project:9704 run:16 clone:2 gen:346 core:0x21 unit:0x000001cdab404162553ebe191b9ce190
19:29:11:WU01:FS01:Starting
19:29:11:WU01:FS01:Running FahCore: /opt/fah/FAHCoreWrapper /opt/fah/cores/web.stanford.edu/~pande/Linux/AMD64/ATI/R600/Core_21.fah/FahCore_21 -dir 01 -suffix 01 -version 704 -lifeline 15615 -checkpoint 15 -gpu 0 -gpu-vendor ati
19:29:11:WU01:FS01:Started FahCore on PID 27804
19:29:11:WU01:FS01:Core PID:27808
19:29:11:WU01:FS01:FahCore 0x21 started
19:29:12:WU01:FS01:0x21:*********************** Log Started 2016-08-28T19:29:11Z ***********************
19:29:12:WU01:FS01:0x21:Project: 9704 (Run 16, Clone 2, Gen 346)
19:29:12:WU01:FS01:0x21:Unit: 0x000001cdab404162553ebe191b9ce190
19:29:12:WU01:FS01:0x21:CPU: 0x00000000000000000000000000000000
19:29:12:WU01:FS01:0x21:Machine: 1
19:29:12:WU01:FS01:0x21:Reading tar file core.xml
19:29:12:WU01:FS01:0x21:Reading tar file system.xml
19:29:14:WU01:FS01:0x21:Reading tar file integrator.xml
19:29:14:WU01:FS01:0x21:Reading tar file state.xml
19:29:17:WU01:FS01:0x21:Digital signatures verified
19:29:17:WU01:FS01:0x21:Folding@home GPU Core21 Folding@home Core
19:29:17:WU01:FS01:0x21:Version 0.0.17
19:29:17:WU01:FS01:0x21:ERROR:Bad platformId size.
19:29:17:WU01:FS01:0x21:Saving result file logfile_01.txt
19:29:17:WU01:FS01:0x21:Saving result file log.txt
19:29:17:WU01:FS01:0x21:Folding@home Core Shutdown: BAD_WORK_UNIT
19:29:18:WARNING:WU01:FS01:FahCore returned: BAD_WORK_UNIT (114 = 0x72)
19:29:18:WU01:FS01:Sending unit results: id:01 state:SEND error:FAULTY project:9704 run:16 clone:2 gen:346 core:0x21 unit:0x000001cdab404162553ebe191b9ce190
19:29:18:WU01:FS01:Uploading 2.17KiB to 171.64.65.98
19:29:18:WU01:FS01:Connecting to 171.64.65.98:8080
19:29:19:WU01:FS01:Upload complete
19:29:24:WU02:FS01:Connecting to 171.67.108.45:80
19:29:25:WU01:FS01:Server responded WORK_ACK (400)
19:29:25:WU01:FS01:Cleaning up
19:29:26:WU02:FS01:Assigned to work server 171.67.108.101
19:29:26:WU02:FS01:Requesting new work unit for slot 01: READY gpu:0:Juniper [Radeon HD 5700/6750] from 171.67.108.101
19:29:26:WU02:FS01:Connecting to 171.67.108.101:8080
19:29:35:WU02:FS01:Downloading 8.72MiB
19:29:41:WU02:FS01:Download 3.58%
19:29:48:WU02:FS01:Download 6.45%
19:29:54:WU02:FS01:Download 13.61%
19:30:00:WU02:FS01:Download 21.49%
19:30:06:WU02:FS01:Download 27.94%
19:30:12:WU02:FS01:Download 32.95%
19:30:18:WU02:FS01:Download 41.55%
19:30:24:WU02:FS01:Download 49.43%
19:30:30:WU02:FS01:Download 57.31%
19:30:36:WU02:FS01:Download 63.76%
19:30:42:WU02:FS01:Download 66.62%
19:30:48:WU02:FS01:Download 68.77%
19:30:54:WU02:FS01:Download 72.35%
19:31:00:WU02:FS01:Download 76.65%
19:31:06:WU02:FS01:Download 80.23%
19:31:12:WU02:FS01:Download 83.10%
19:31:18:WU02:FS01:Download 88.11%
19:31:24:WU02:FS01:Download 95.99%
19:31:29:WU02:FS01:Download complete
19:31:29:WU02:FS01:Received Unit: id:02 state:DOWNLOAD error:NO_ERROR project:13110 run:39 clone:0 gen:240 core:0x21 unit:0x00000088ab436c65577170b55a971fdf
19:31:29:WU02:FS01:Starting
19:31:29:WU02:FS01:Running FahCore: /opt/fah/FAHCoreWrapper /opt/fah/cores/web.stanford.edu/~pande/Linux/AMD64/ATI/R600/Core_21.fah/FahCore_21 -dir 02 -suffix 01 -version 704 -lifeline 15615 -checkpoint 15 -gpu 0 -gpu-vendor ati
19:31:29:WU02:FS01:Started FahCore on PID 29196
19:31:29:WU02:FS01:Core PID:29200
19:31:29:WU02:FS01:FahCore 0x21 started
19:31:29:WU02:FS01:0x21:*********************** Log Started 2016-08-28T19:31:29Z ***********************
19:31:29:WU02:FS01:0x21:Project: 13110 (Run 39, Clone 0, Gen 240)
19:31:29:WU02:FS01:0x21:Unit: 0x00000088ab436c65577170b55a971fdf
19:31:29:WU02:FS01:0x21:CPU: 0x00000000000000000000000000000000
19:31:29:WU02:FS01:0x21:Machine: 1
19:31:29:WU02:FS01:0x21:Reading tar file core.xml
19:31:29:WU02:FS01:0x21:Reading tar file integrator.xml
19:31:29:WU02:FS01:0x21:Reading tar file state.xml
19:31:31:WU02:FS01:0x21:Reading tar file system.xml
19:31:32:WU02:FS01:0x21:Digital signatures verified
19:31:32:WU02:FS01:0x21:Folding@home GPU Core21 Folding@home Core
19:31:32:WU02:FS01:0x21:Version 0.0.17
19:31:32:WU02:FS01:0x21:ERROR:Bad platformId size.
19:31:32:WU02:FS01:0x21:Saving result file logfile_01.txt
19:31:32:WU02:FS01:0x21:Saving result file log.txt
19:31:32:WU02:FS01:0x21:Folding@home Core Shutdown: BAD_WORK_UNIT
19:31:32:WARNING:WU02:FS01:FahCore returned: BAD_WORK_UNIT (114 = 0x72)
19:31:32:WU02:FS01:Sending unit results: id:02 state:SEND error:FAULTY project:13110 run:39 clone:0 gen:240 core:0x21 unit:0x00000088ab436c65577170b55a971fdf
19:31:32:WU02:FS01:Uploading 2.19KiB to 171.67.108.101
19:31:32:WU02:FS01:Connecting to 171.67.108.101:8080
19:31:33:WU01:FS01:Connecting to 171.67.108.45:80
19:31:33:WU02:FS01:Upload complete
19:31:33:WU02:FS01:Server responded WORK_ACK (400)
19:31:33:WU02:FS01:Cleaning up
19:31:34:WU01:FS01:Assigned to work server 171.67.108.104
19:31:34:WU01:FS01:Requesting new work unit for slot 01: READY gpu:0:Juniper [Radeon HD 5700/6750] from 171.67.108.104
19:31:34:WU01:FS01:Connecting to 171.67.108.104:8080
19:31:36:WU01:FS01:Downloading 78.64MiB
19:31:42:WU01:FS01:Download 0.56%
19:31:48:WU01:FS01:Download 1.03%
19:31:54:WU01:FS01:Download 1.51%
19:32:00:WU01:FS01:Download 2.23%
19:32:06:WU01:FS01:Download 2.62%
19:32:12:WU01:FS01:Download 3.18%
19:32:19:WU01:FS01:Download 3.74%
19:32:25:WU01:FS01:Download 4.29%
19:32:31:WU01:FS01:Download 4.85%
19:32:37:WU01:FS01:Download 5.40%
19:32:43:WU01:FS01:Download 5.80%
19:32:49:WU01:FS01:Download 6.20%
19:32:57:WU01:FS01:Download 6.60%
19:33:04:WU01:FS01:Download 6.91%
19:33:10:WU01:FS01:Download 7.47%
19:33:19:WU01:FS01:Download 7.95%
19:33:25:WU01:FS01:Download 8.98%
19:33:31:WU01:FS01:Download 9.78%
19:33:37:WU01:FS01:Download 10.41%
19:33:43:WU01:FS01:Download 10.97%
19:33:49:WU01:FS01:Download 11.76%
19:33:55:WU01:FS01:Download 12.64%
19:34:01:WU01:FS01:Download 13.43%
19:34:07:WU01:FS01:Download 13.91%
19:34:13:WU01:FS01:Download 14.31%
19:34:19:WU01:FS01:Download 14.70%
19:34:25:WU01:FS01:Download 15.50%
19:34:32:WU01:FS01:Download 16.13%
19:34:38:WU01:FS01:Download 16.93%
19:34:44:WU01:FS01:Download 17.72%
19:34:50:WU01:FS01:Download 18.36%
19:34:57:WU01:FS01:Download 18.76%
19:35:04:WU01:FS01:Download 19.07%
19:35:10:WU01:FS01:Download 19.55%
19:35:16:WU01:FS01:Download 20.03%
19:35:20:FS01:Paused
19:35:22:WU01:FS01:Download 20.35%
19:35:29:WU01:FS01:Download 20.66%
19:35:35:WU01:FS01:Download 20.98%
19:35:41:WU01:FS01:Download 21.78%
What could be causing this and how can I correct it?
ChristianVirtual
Re: Bad work units on GPU slot
Post by ChristianVirtual »
I assume for AMD cards the same is valid as for nVidia cards: use originally driver. They bring all you need.
Give it a try, it should help.
I looked up the results for the three WUs you reported.
Project: 13500 (Run 1, Clone 894, Gen 1) -- reassigned once (so far) producing a second error by someone with an ATI GPU.
Project:9177 run:23 clone:7 gen:0 -- not yet completed by a re-assignee.
Project:13110 run:39 clone:0 gen:240 -- reassigned and successfully completed by someone with a nV GPU
Core_21 works best if the GPU has at least a minimal ability to do double precision floating point. Juniper is reported to have that capability. I can't think of another reason why there should be a difference between the one successful completion by a nV GPU and a failure by an AMD GPU.
Somebody from Development will need to ascertain what kind of problem you've encountered and whether it is related to the differences between ATI and nV GPUs.
I'm not sure if the open source driver driver contains all the necessary code. Which driver revision is it? Have you tried downloading the latest version for that GPU from the AMD website? That often solves problems like that.
aprildh31
Post by aprildh31 »
I'm having the same problem with an AMD A8-7600 APU (ATI Radeon R7 video card built into CPU):
04:01:56:WU02:FS01:0x21:*********************** Log Started 2016-09-11T04:01:56Z ***********************
04:01:56:WU02:FS01:0x21:Project: 9704 (Run 65, Clone 12, Gen 115)
04:01:56:WU02:FS01:0x21:Unit: 0x0000009cab404162553ec5de7693e4eb
04:01:56:WU02:FS01:0x21:CPU: 0x00000000000000000000000000000000
04:01:56:WU02:FS01:0x21:Machine: 1
04:01:56:WU02:FS01:0x21:Reading tar file core.xml
04:01:56:WU02:FS01:0x21:Reading tar file system.xml
04:01:59:WU02:FS01:0x21:Reading tar file integrator.xml
04:01:59:WU02:FS01:0x21:Reading tar file state.xml
04:02:01:WU02:FS01:0x21:Digital signatures verified
04:02:01:WU02:FS01:0x21:Folding@home GPU Core21 Folding@home Core
04:02:01:WU02:FS01:0x21:Version 0.0.17
04:02:01:WU02:FS01:0x21:ERROR:Bad platformId size.
04:02:01:WU02:FS01:0x21:Saving result file logfile_01.txt
04:02:01:WU02:FS01:0x21:Saving result file log.txt
04:02:01:WU02:FS01:0x21:Folding@home Core Shutdown: BAD_WORK_UNIT
04:02:01:WARNING:WU02:FS01:FahCore returned: BAD_WORK_UNIT (114 = 0x72)
04:02:01:WU02:FS01:Sending unit results: id:02 state:SEND error:FAULTY project:9704 run:65 clone:12 gen:115 core:0x21 unit:0x0000009cab404162553ec5de7693e4eb
I'm running Ubuntu 16.04 with the open-source radeon driver:
xserver-xorg-video-ati                1:7.7.0-1
xserver-xorg-video-radeon             1:7.7.0-1
libgl1-mesa-glx:amd64                 11.2.0-1ubuntu2.2
mesa-opencl-icd:amd64                 11.2.0-1ubuntu2.2
ocl-icd-libopencl1:amd64              2.2.8-1
The old closed-source Catalyst drivers are no longer supported on new Linux kernels, and will not run in Ubuntu 16.04 or later.
The new hybrid open/closed-source AMDGPU drivers don't work with any of the current AMD APUs (which all have 2nd-gen GCN graphics; the AMDGPU driver has only "experimental" support for 2nd-gen GCN, but I haven't been able to get the driver to even load).
So, the only option here is to use the open-source radeon driver.
The opencl test program from here works fine: https://wiki.tiker.net/OpenCLHowTo
Reason: Edited the URL to be a link.
Please try the Fah opencl tester called Fahbench.
aprildh31
Post by aprildh31 »
FAHBench installed and recognizing APU:
$ ./FAHBench-cmd -v
FAHBench version 2.2.5
OpenMM version 6.2-core21-0.0.17
$ ./FAHBench-cmd -d
Device                    Type        Dev Plat  Platform version             Device version
AMD KAVERI (DRM 2.43.0, LLVM 3.8.0) OpenCL        0    0  OpenCL 1.1 MESA 11.2.0       OpenCL 1.1 MESA 11.2.0
FAHBench run using CPU:
$ ./FAHBench-cmd --device-id=0 --platform=CPU --precision=single --workunit=dhfr --nan-check=0 --run-length=60
FAHBench Simulation
Plugin directory: "/home/april/foldingathome/FAHBench-2.2.5-Linux/lib/plugins"
Work unit: dhfr
WU Name: Dihydrofolate reductase
WU Description: A common system for benchmarking molecular dynamics
System XML: /home/april/foldingathome/FAHBench-2.2.5-Linux/share/fahbench/workunits/dhfr/system.xml
Integrator XML: /home/april/foldingathome/FAHBench-2.2.5-Linux/share/fahbench/workunits/dhfr/integrator.xml
State XML: /home/april/foldingathome/FAHBench-2.2.5-Linux/share/fahbench/workunits/dhfr/state.xml
Step chunk: 40
Device ID 0; Platform CPU
Run length: 60s
Loading plugins from plugin directory
Number of registered plugins: 3
Deserializing input files: system
Deserializing input files: state
Deserializing input files: integrator
Creating context (may take several minutes)
Checking accuracy against reference code
Creating reference context (may take several minutes)
Comparing forces and energy
Starting Benchmark
Benchmarking finished
Final score:    2.5321
Scaled score:   2.5321 (23558 atoms)
FAHBench run using OpenCL:
$ ./FAHBench-cmd --device-id=0 --platform-id=0 --platform=OpenCL --precision=single --workunit=dhfr --nan-check=0 --run-length=60
FAHBench Simulation
Work unit: dhfr
Step chunk: 40
Device ID 0; Platform OpenCL; Platform ID 0
Run length: 60s
Something went wrong:
Error compiling kernel: input.cl:124:50: warning: implicit declaration of function 'native_rsqrt' is invalid in C99
input.cl:124:67: warning: implicit declaration of function 'native_recip' is invalid in C99
unsupported call to function native_rsqrt in determineNativeAccuracy
Any help interpreting the error message at the end? Does FAH require OpenCL >1.1?
Here's output from clinfo in case it might provide some clues:
  Platform Name                                   Clover
  Platform Vendor                                 Mesa
  Platform Version                                OpenCL 1.1 MESA 11.2.0
  Platform Extensions                             cl_khr_icd
  Platform Extensions function suffix             MESA
  Device Name                                     AMD KAVERI (DRM 2.43.0, LLVM 3.8.0)
  Device Vendor                                   AMD
  Device Version                                  OpenCL 1.1 MESA 11.2.0
  Driver Version                                  11.2.0
  Device OpenCL C Version                         OpenCL C 1.1
  Max compute units                               6
  Max clock frequency                             720MHz
  Max work item sizes                             256x256x256
  Preferred work group size multiple              64
    char                                                16 / 16
    short                                                8 / 8
    int                                                  4 / 4
    long                                                 2 / 2
    half                                                 0 / 0        (n/a)
    float                                                4 / 4
    double                                               2 / 2        (cl_khr_fp64)
  Half-precision Floating-point support           (n/a)
    Denormals                                     No
    Round to zero                                 No
    Round to infinity                             No
    IEEE754-2008 fused multiply-add               No
    Correctly-rounded divide and sqrt operations  No
  Address bits                                    32, Little-Endian
  Global memory size                              1073741824 (1024MiB)
  Max memory allocation                           268435456 (256MiB)
  Unified memory for Host and Device              Yes
  Alignment of base address                       1024 bits (128 bytes)
  Global Memory cache type                        None
  Image support                                   No
  Local memory size                               32768 (32KiB)
  Max constant buffer size                        268435456 (256MiB)
  Max number of constant args                     16
  Queue properties
  Profiling timer resolution                      0ns
  Execution capabilities
  Device Extensions                               cl_khr_global_int32_base_atomics cl_khr_global_int32_extended_atomics cl_khr_local_int32_base_atomics cl_khr_local_int32_extended_atomics cl_khr_byte_addressable_store cl_khr_fp64
NULL platform behavior
  clGetPlatformInfo(NULL, CL_PLATFORM_NAME, ...)  Clover
  clGetDeviceIDs(NULL, CL_DEVICE_TYPE_ALL, ...)   Success [MESA]
  clCreateContext(NULL, ...) [default]            Success [MESA]
  clCreateContextFromType(NULL, CL_DEVICE_TYPE_GPU)  Success (1)
  clCreateContextFromType(NULL, CL_DEVICE_TYPE_CUSTOM)  No devices found in platform
  clCreateContextFromType(NULL, CL_DEVICE_TYPE_ALL)  Success (1)
ICD loader properties
  ICD loader Name                                 OpenCL ICD Loader
  ICD loader Vendor                               OCL Icd free software
  ICD loader Version                              2.2.8
  ICD loader Profile                              OpenCL 1.2
	NOTE:	your OpenCL library declares to support OpenCL 1.2,
		but it seems to support up to OpenCL 2.1 too.
jwinterm
Post by jwinterm »
I am having the same issue on Ubuntu 16.04 using the radeon driver for a 7950 and 270(x?) GPU, Hawaii and Tahiti. They say, ready, switch to running, then back to ready, and failed after a few attempts. Looking at output from FAHclient this seems to be the issue:
15:42:52:WU03:FS02:0x21:Folding@home GPU Core21 Folding@home Core
15:42:52:WU03:FS02:0x21:Version 0.0.17
15:42:52:WU03:FS02:0x21:ERROR:Bad platformId size.
15:42:52:WU03:FS02:0x21:Saving result file logfile_01.txt
15:42:52:WU03:FS02:0x21:Saving result file log.txt
15:42:52:WU03:FS02:0x21:Folding@home Core Shutdown: BAD_WORK_UNIT
15:42:52:WARNING:WU03:FS02:FahCore returned: BAD_WORK_UNIT (114 = 0x72)
15:42:52:WU03:FS02:Sending unit results: id:03 state:SEND error:FAULTY project:9192 run:0 clone:81 gen:85 core:0x21 unit:0x00000062ab40415457cb2d2b9c23f4ef
That was after setting Core21, I had previously tried with it set to -1 but I think it was still using 21.
jwinterm wrote:That was after setting Core21, I had previously tried with it set to -1 but I think it was still using 21.
I don't understand.
You cannot select which FahCore_xx is going to be used. Each project download will select the FAHCore software will be used (-17/-18/-21 for the GPU, _a4/-a7 for the CPU)
The number of CPU cores can be allocated up to the number present on your hardware --- and the -1 setting means the software should pick a desirable value (although FAHClient V7.4.4 doesn't do a very good job if you have 8 CPUs and one GPU.)
The ERROR:Bad platformId size. indicates a problem with your GPU drivers. You didn't include the top 100 lines of your log, but if you're running Windows 10, Microsoft has probably removed driver components that are essential to FAH. Reinstall the driver from AMD.com (or NVidia.com).
jwinterm
Post by jwinterm »
bruce wrote: ...
I said in my post Ubuntu 16.04 using the open source radeon driver. My GPUs (or at least one of them) isn't supported by the new AMD GPU PRO driver for Ubuntu, so I'm stuck with Radeon; they're actually Curacao and Tahiti chipsets, not Hawaii as I said in original post. Is there any way to use or plans to support the Radeon open source driver for Ubuntu?
Integrated GPUs (which are built into the CPU's chipset) do not perform well, even if you do manage to configure the right drivers (and that can be a challenge). Discrete GPUs (on an add-in board) generally have many more shaders and complete FAH results much faster. While the iGPU is fine to power a display, I don't think anybody would consider it for gaming or for folding.
In the past, I've configured a couple of AMD iGPUs, and while they may be able to complete FAH assignments, they rarely do so within the required deadlines so I end up removing the GPU slot and putting all the CPU resources toward CPU folding.
FAH really has two choices: They can officially drop support for low-performance GPUs or they can develop a family of projects that makes use of them and give them longer deadlines and commensurately lower points. I've been talking to them about adopting either of those approaches and it's not clear what they might do.
I think that's the main reason that they've never supported Intel's iGPUs ... adequate to power a screen, but not powerful enough for serious folding.
Fah doesn't support any drivers. The drivers either work for Fah or they do not work for Fah. Donors have recently confirmed the open source radeon driver doesn't work for Fah. Only the OEM Radeon driver works for folding.
Feel free to contact the providers of the open source drivers to request they support Fah.
  Device Vendor                                   AMD
  Max compute units                               6
    char                                                16 / 16
    short                                                8 / 8
    int                                                  4 / 4
    long                                                 2 / 2
    half                                                 0 / 0        (n/a)
    float                                                4 / 4
    Denormals                                     No
    Round to zero                                 No
  Image support                                   No
  Queue properties
I don't know where your OpenCL drivers come from, but it's not a supported OpenCL Platform : get your GPU drivers from your GPU vendor (AMD).
Just a note that FAH is not the only application where the AMDGPU-PRO driver isn't working for OpenCL. Also an interesting article in general in regards to performance.
NVIDIA GTX 680 To GTX 1080 Blender OpenCL Benchmarks
