Why GPU Failed
petsosay
Why GPU Failed
Post by petsosay »
log file:
15:44:56:WARNING:WU02:FS01:Fatal error, dumping
15:51:30:WARNING:WU00:FS00:FahCore returned: MISSING_WORK_FILES (116 = 0x74)
15:51:30:WARNING:WU00:FS00:Fatal error, dumping
15:51:30:WARNING:WU00:FS00:Missing original Unit data, cannot send dump report
15:51:33:WARNING:WU01:FS01:FahCore returned: FILE_IO_ERROR (117 = 0x75)
15:51:33:WARNING:WU01:FS01:Fatal error, dumping
15:51:41:WARNING:WU02:FS01:FahCore returned: FILE_IO_ERROR (117 = 0x75)
15:51:41:WARNING:WU02:FS01:Fatal error, dumping
15:51:48:WARNING:WU01:FS01:FahCore returned: FILE_IO_ERROR (117 = 0x75)
15:51:48:WARNING:WU01:FS01:Fatal error, dumping
15:51:56:WARNING:WU02:FS01:FahCore returned: FILE_IO_ERROR (117 = 0x75)
15:51:56:WARNING:WU02:FS01:Fatal error, dumping
15:52:04:WARNING:WU01:FS01:FahCore returned: FILE_IO_ERROR (117 = 0x75)
15:52:04:WARNING:WU01:FS01:Fatal error, dumping
15:52:11:WARNING:WU02:FS01:FahCore returned: FILE_IO_ERROR (117 = 0x75)
15:52:11:WARNING:WU02:FS01:Fatal error, dumping
15:52:19:WARNING:WU01:FS01:FahCore returned: FILE_IO_ERROR (117 = 0x75)
15:52:19:WARNING:WU01:FS01:Fatal error, dumping
15:52:27:WARNING:WU02:FS01:FahCore returned: FILE_IO_ERROR (117 = 0x75)
15:52:27:WARNING:WU02:FS01:Fatal error, dumping
15:52:36:WARNING:WU01:FS01:FahCore returned: FILE_IO_ERROR (117 = 0x75)
15:52:36:WARNING:WU01:FS01:Fatal error, dumping
15:52:44:WARNING:WU02:FS01:FahCore returned: FILE_IO_ERROR (117 = 0x75)
15:52:44:WARNING:WU02:FS01:Fatal error, dumping
pls help me :e(
Reason: removed invalid link to image
Re: Why GPU Failed
Too little information here to tell what happened. Please post the beginning section of the log file that shows the system information and folding configuration. We would also need to see more of what happened just before the section shown. Use the Code tags available from the Full Editor for submitting posts to enclose the sections of log file posted.
Re: Why GPU Failed
The most common cause of MISSING_WORK_FILES (116 = 0x74) is that you tried to discard a WU that, for some reason, you didn't want to run. Is that what happened?
The second most common cause is that your antivirus software scanned FAH's work files and found a string of data that happened to look the same as some virus pattern if it happened to be in an executable file. FAH's work files are data, not executable files, and you probably should configure your virus scans to avoid looking at FAH's work files.
As has already been said, please give us a big enough copy of FAH's log that we can confirm what happened.
Re: Why GPU Failed
By the way, regarding the message Missing original Unit data, cannot send dump report, when a WU is not going to be completed for any reason, the FAH servers can only reassign that same WU to someone else if [a] it receives a dump report or the WU expires. Completing EVERY WU is important to science and the additional delay of waiting for it to expire is costly, too.
noprob
Hardware configuration: borgs
Re: Why GPU Failed
Post by noprob »
seems to be my problem at the moment.
please advise.
03:47:12:WU00:FS00:Starting
03:47:12:WU00:FS00:Running FahCore: C:\FAHClient/FAHCoreWrapper.exe C:/Users/noprob/AppData/Roaming/FAHClient/cores/web.stanford.edu/~pande/Win32/AMD64/Core_a4.fah/FahCore_a4.exe -dir 00 -suffix 01 -version 704 -lifeline 2852 -checkpoint 15
03:47:12:WU00:FS00:Started FahCore on PID 1868
03:47:12:WU00:FS00:Core PID:2320
03:47:12:WU00:FS00:FahCore 0xa4 started
03:47:12:WU01:FS01:Connecting to 171.67.108.45:80
03:47:13:WU00:FS00:0xa4:
03:47:13:WU00:FS00:0xa4:*------------------------------*
03:47:13:WU00:FS00:0xa4:Folding@Home Gromacs GB Core
03:47:13:WU00:FS00:0xa4:Version 2.27 (Dec. 15, 2010)
03:47:13:WU00:FS00:0xa4:Preparing to commence simulation
03:47:13:WU00:FS00:0xa4:- Looking at optimizations...
03:47:13:WU00:FS00:0xa4:- Files status OK
03:47:13:WU00:FS00:0xa4:- Expanded 825493 -> 1403132 (decompressed 169.9 percent)
03:47:13:WU00:FS00:0xa4:Called DecompressByteArray: compressed_data_size=825493 data_size=1403132, decompressed_data_size=1403132 diff=0
03:47:13:WU00:FS00:0xa4:- Digital signature verified
03:47:13:WU00:FS00:0xa4:Project: 9036 (Run 22, Clone 1, Gen 176)
03:47:13:WU00:FS00:0xa4:Assembly optimizations on if available.
03:47:13:WU00:FS00:0xa4:Entering M.D.
03:47:13:WU01:FS01:Assigned to work server 171.67.108.158
03:47:13:WU01:FS01:Requesting new work unit for slot 01: READY gpu:0:GT200b [GeForce GTX 275] from 171.67.108.158
03:47:13:WU01:FS01:Connecting to 171.67.108.158:8080
03:47:15:WU01:FS01:Downloading 807.03KiB
03:47:18:WU00:FS00:0xa4:Using Gromacs checkpoints
03:47:18:WU00:FS00:0xa4:Mapping NT from 1 to 1
03:47:19:WU00:FS00:0xa4:Resuming from checkpoint
03:47:19:WU00:FS00:0xa4:Verified 00/wudata_01.log
03:47:19:WU00:FS00:0xa4:Verified 00/wudata_01.trr
03:47:19:WU00:FS00:0xa4:Verified 00/wudata_01.xtc
03:47:19:WU00:FS00:0xa4:Verified 00/wudata_01.edr
03:47:19:WU00:FS00:0xa4:Completed 167115 out of 250000 steps  (66%)
03:47:22:WU01:FS01:Download 23.79%
03:47:29:WU01:FS01:Download 47.58%
03:47:35:WU01:FS01:Download 87.23%
03:47:36:WU01:FS01:Download complete
03:47:36:WU01:FS01:Received Unit: id:01 state:DOWNLOAD error:NO_ERROR project:9037 run:438 clone:0 gen:629 core:0xa4 unit:0x000002b2ab436c9e56982b3b5e021c71
03:47:36:WU01:FS01:Starting
03:47:36:WU01:FS01:Running FahCore: C:\FAHClient/FAHCoreWrapper.exe C:/Users/noprob/AppData/Roaming/FAHClient/cores/web.stanford.edu/~pande/Win32/AMD64/Core_a4.fah/FahCore_a4.exe -dir 01 -suffix 01 -version 704 -lifeline 2852 -checkpoint 15 -gpu 0
03:47:36:WU01:FS01:Started FahCore on PID 1884
03:47:36:WU01:FS01:Core PID:628
03:47:36:WU01:FS01:FahCore 0xa4 started
03:47:37:WARNING:WU01:FS01:FahCore returned: FILE_IO_ERROR (117 = 0x75)
03:47:37:WARNING:WU01:FS01:Fatal error, dumping
03:47:37:WU01:FS01:Sending unit results: id:01 state:SEND error:DUMPED project:9037 run:438 clone:0 gen:629 core:0xa4 unit:0x000002b2ab436c9e56982b3b5e021c71
03:47:37:WU01:FS01:Connecting to 171.67.108.158:8080
03:47:37:WU02:FS01:Connecting to 171.67.108.45:80
03:47:37:WU01:FS01:Server responded WORK_ACK (400)
03:47:37:WU01:FS01:Cleaning up
03:47:38:WU02:FS01:Assigned to work server 171.67.108.158
03:47:38:WU02:FS01:Requesting new work unit for slot 01: READY gpu:0:GT200b [GeForce GTX 275] from 171.67.108.158
03:47:38:WU02:FS01:Connecting to 171.67.108.158:8080
03:47:39:WU02:FS01:Downloading 807.25KiB
03:47:45:WU02:FS01:Download 39.64%
03:47:51:WU02:FS01:Download 63.43%
03:47:56:Removing old file 'configs/config-20161208-063645.xml'
03:47:56:Saving configuration to config.xml
03:47:56:<config>
03:47:56:  <!-- Network -->
03:47:56:  <proxy v=':8080'/>
03:47:56:
03:47:56:  <!-- Slot Control -->
03:47:56:  <power v='full'/>
03:47:56:
03:47:56:  <!-- User Information -->
03:47:56:  <passkey v='********************************'/>
03:47:56:  <team v='12072'/>
03:47:56:  <user v='noprob'/>
03:47:56:
03:47:56:  <!-- Folding Slots -->
03:47:56:  <slot id='1' type='GPU'>
03:47:56:    <gpu-index v='0'/>
03:47:56:  </slot>
03:47:56:  <slot id='0' type='CPU'/>
03:47:56:</config>
03:47:57:WU02:FS01:Download 87.21%
03:47:59:WU02:FS01:Download complete
03:47:59:WU02:FS01:Received Unit: id:02 state:DOWNLOAD error:NO_ERROR project:9038 run:500 clone:2 gen:632 core:0xa4 unit:0x000002b5ab436c9e56982992c4d160ec
03:47:59:WU02:FS01:Starting
03:47:59:WU02:FS01:Running FahCore: C:\FAHClient/FAHCoreWrapper.exe C:/Users/noprob/AppData/Roaming/FAHClient/cores/web.stanford.edu/~pande/Win32/AMD64/Core_a4.fah/FahCore_a4.exe -dir 02 -suffix 01 -version 704 -lifeline 2852 -checkpoint 15 -gpu 0
03:47:59:WU02:FS01:Started FahCore on PID 1556
03:47:59:WU02:FS01:Core PID:3044
03:47:59:WU02:FS01:FahCore 0xa4 started
03:48:00:WARNING:WU02:FS01:FahCore returned: FILE_IO_ERROR (117 = 0x75)
03:48:00:WARNING:WU02:FS01:Fatal error, dumping
03:48:00:WU02:FS01:Sending unit results: id:02 state:SEND error:DUMPED project:9038 run:500 clone:2 gen:632 core:0xa4 unit:0x000002b5ab436c9e56982992c4d160ec
03:48:00:WU02:FS01:Connecting to 171.67.108.158:8080
03:48:00:WU01:FS01:Connecting to 171.67.108.45:80
03:48:01:WU02:FS01:Server responded WORK_ACK (400)
03:48:01:WU02:FS01:Cleaning up
03:48:01:WU01:FS01:Assigned to work server 171.67.108.158
03:48:01:WU01:FS01:Requesting new work unit for slot 01: READY gpu:0:GT200b [GeForce GTX 275] from 171.67.108.158
03:48:01:WU01:FS01:Connecting to 171.67.108.158:8080
03:48:03:WU01:FS01:Downloading 806.40KiB
03:48:09:WU01:FS01:Download 39.68%
03:48:16:WU01:FS01:Download 87.30%
03:48:18:WU01:FS01:Download complete
03:48:18:WU01:FS01:Received Unit: id:01 state:DOWNLOAD error:NO_ERROR project:9039 run:632 clone:0 gen:413 core:0xa4 unit:0x000001dfab436c9e569827ce22c48961
03:48:18:WU01:FS01:Starting
03:48:18:WU01:FS01:Running FahCore: C:\FAHClient/FAHCoreWrapper.exe C:/Users/noprob/AppData/Roaming/FAHClient/cores/web.stanford.edu/~pande/Win32/AMD64/Core_a4.fah/FahCore_a4.exe -dir 01 -suffix 01 -version 704 -lifeline 2852 -checkpoint 15 -gpu 0
03:48:18:WU01:FS01:Started FahCore on PID 1880
03:48:18:WU01:FS01:Core PID:2720
03:48:18:WU01:FS01:FahCore 0xa4 started
03:48:19:WARNING:WU01:FS01:FahCore returned: FILE_IO_ERROR (117 = 0x75)
03:48:19:WARNING:WU01:FS01:Fatal error, dumping
03:48:19:WU01:FS01:Sending unit results: id:01 state:SEND error:DUMPED project:9039 run:632 clone:0 gen:413 core:0xa4 unit:0x000001dfab436c9e569827ce22c48961
03:48:19:WU01:FS01:Connecting to 171.67.108.158:8080
03:48:19:WU02:FS01:Connecting to 171.67.108.45:80
03:48:20:WU01:FS01:Server responded WORK_ACK (400)
03:48:20:WU01:FS01:Cleaning up
03:48:20:WU02:FS01:Assigned to work server 171.67.108.158
03:48:20:WU02:FS01:Requesting new work unit for slot 01: READY gpu:0:GT200b [GeForce GTX 275] from 171.67.108.158
03:48:20:WU02:FS01:Connecting to 171.67.108.158:8080
03:48:21:WU02:FS01:Downloading 807.17KiB
03:48:28:WU02:FS01:Download 39.64%
03:48:35:WU02:FS01:Download 71.36%
03:48:40:WU02:FS01:Download complete
03:48:40:WU02:FS01:Received Unit: id:02 state:DOWNLOAD error:NO_ERROR project:9038 run:474 clone:0 gen:653 core:0xa4 unit:0x000002c6ab436c9e5698299dc87d7537
03:48:40:WU02:FS01:Starting
03:48:40:WU02:FS01:Running FahCore: C:\FAHClient/FAHCoreWrapper.exe C:/Users/noprob/AppData/Roaming/FAHClient/cores/web.stanford.edu/~pande/Win32/AMD64/Core_a4.fah/FahCore_a4.exe -dir 02 -suffix 01 -version 704 -lifeline 2852 -checkpoint 15 -gpu 0
03:48:40:WU02:FS01:Started FahCore on PID 1380
03:48:40:WU02:FS01:Core PID:2988
03:48:40:WU02:FS01:FahCore 0xa4 started
03:48:41:WARNING:WU02:FS01:FahCore returned: FILE_IO_ERROR (117 = 0x75)
03:48:41:WARNING:WU02:FS01:Fatal error, dumping
03:48:41:WU02:FS01:Sending unit results: id:02 state:SEND error:DUMPED project:9038 run:474 clone:0 gen:653 core:0xa4 unit:0x000002c6ab436c9e5698299dc87d7537
03:48:41:WU02:FS01:Connecting to 171.67.108.158:8080
03:48:41:WU01:FS01:Connecting to 171.67.108.45:80
03:48:42:WU01:FS01:Assigned to work server 171.67.108.158
03:48:42:WU01:FS01:Requesting new work unit for slot 01: READY gpu:0:GT200b [GeForce GTX 275] from 171.67.108.158
03:48:42:WU02:FS01:Server responded WORK_ACK (400)
03:48:42:WU01:FS01:Connecting to 171.67.108.158:8080
03:48:42:WU02:FS01:Cleaning up
03:48:43:WU00:FS00:0xa4:Completed 167500 out of 250000 steps  (67%)
03:48:43:WU01:FS01:Downloading 806.52KiB
03:48:49:WU01:FS01:Download 39.68%
03:48:55:WU01:FS01:Download 79.35%
03:48:59:WU01:FS01:Download complete
03:48:59:WU01:FS01:Received Unit: id:01 state:DOWNLOAD error:NO_ERROR project:9039 run:614 clone:0 gen:483 core:0xa4 unit:0x0000021fab436c9e569827d5802b5216
03:48:59:WU01:FS01:Starting
03:48:59:WU01:FS01:Running FahCore: C:\FAHClient/FAHCoreWrapper.exe C:/Users/noprob/AppData/Roaming/FAHClient/cores/web.stanford.edu/~pande/Win32/AMD64/Core_a4.fah/FahCore_a4.exe -dir 01 -suffix 01 -version 704 -lifeline 2852 -checkpoint 15 -gpu 0
03:48:59:WU01:FS01:Started FahCore on PID 2260
03:48:59:WU01:FS01:Core PID:1344
03:48:59:WU01:FS01:FahCore 0xa4 started
03:49:00:WARNING:WU01:FS01:FahCore returned: FILE_IO_ERROR (117 = 0x75)
03:49:00:WARNING:WU01:FS01:Fatal error, dumping
03:49:00:WU01:FS01:Sending unit results: id:01 state:SEND error:DUMPED project:9039 run:614 clone:0 gen:483 core:0xa4 unit:0x0000021fab436c9e569827d5802b5216
03:49:00:WU01:FS01:Connecting to 171.67.108.158:8080
03:49:01:WU02:FS01:Connecting to 171.67.108.45:80
03:49:01:WU01:FS01:Server responded WORK_ACK (400)
03:49:01:WU01:FS01:Cleaning up
03:49:02:WU02:FS01:Assigned to work server 171.67.108.158
03:49:02:WU02:FS01:Requesting new work unit for slot 01: READY gpu:0:GT200b [GeForce GTX 275] from 171.67.108.158
03:49:02:WU02:FS01:Connecting to 171.67.108.158:8080
03:49:03:WU02:FS01:Downloading 806.87KiB
Re: Why GPU Failed
noprob wrote:seems to be my problem at the moment.
please advise.
What's missing is the first 100 lines of the log showing your system configuration. Please post that per the instructions in the signature of my previous post.
I Notice you're running the 32-bit version of Windows. Right now there's a lot of attention on what can and cannot be run on 32-bit OSs and what requires 64-bit.I have no firm reason to believe this is the problem ... just mentioning a possiblity.
noprob
Re: Why GPU Failed
Post by noprob »
my apologies and this rig is 64 bit but my other computer is 32 bit same issue.
I'll call this computer #1 x64
here is the missing lines you requested and thank you for your prompt reply.
*********************** Log Started 2016-12-16T03:46:55Z ***********************
03:46:55:************************* Folding@home Client *************************
03:46:55:      Website: http://folding.stanford.edu/
03:46:55:    Copyright: (c) 2009-2014 Stanford University
03:46:55:       Author: Joseph Coffland <joseph@cauldrondevelopment.com>
03:46:55:         Args: --open-web-control
03:46:55:       Config: C:/Users/noprob/AppData/Roaming/FAHClient/config.xml
03:46:55:******************************** Build ********************************
03:46:55:      Version: 7.4.4
03:46:55:         Date: Mar 4 2014
03:46:55:         Time: 20:26:54
03:46:55:      SVN Rev: 4130
03:46:55:       Branch: fah/trunk/client
03:46:55:     Compiler: Intel(R) C++ MSVC 1500 mode 1200
03:46:55:      Options: /TP /nologo /EHa /Qdiag-disable:4297,4103,1786,279 /Ox -arch:SSE
03:46:55:               /QaxSSE2,SSE3,SSSE3,SSE4.1,SSE4.2 /Qopenmp /Qrestrict /MT /Qmkl
03:46:55:     Platform: win32 XP
03:46:55:         Bits: 32
03:46:55:         Mode: Release
03:46:55:******************************* System ********************************
03:46:55:          CPU: AMD Phenom(tm) II X2 555 Processor
03:46:55:       CPU ID: AuthenticAMD Family 16 Model 4 Stepping 3
03:46:55:         CPUs: 2
03:46:55:       Memory: 4.00GiB
03:46:55:  Free Memory: 3.18GiB
03:46:55:      Threads: WINDOWS_THREADS
03:46:55:   OS Version: 6.1
03:46:55:  Has Battery: false
03:46:55:   On Battery: false
03:46:55:   UTC Offset: -5
03:46:55:          PID: 2852
03:46:55:          CWD: C:/Users/noprob/AppData/Roaming/FAHClient
03:46:55:           OS: Windows 7 Professional
03:46:55:      OS Arch: AMD64
03:46:55:         GPUs: 1
03:46:55:        GPU 0: UNSUPPORTED: GT200b [GeForce GTX 275]
03:46:55:         CUDA: 1.3
03:46:55:  CUDA Driver: 4000
03:46:55:Win32 Service: false
03:46:55:***********************************************************************
03:46:55:<config>
03:46:55:  <!-- Network -->
03:46:55:  <proxy v=':8080'/>
03:46:55:
03:46:55:  <!-- Slot Control -->
03:46:55:  <power v='full'/>
03:46:55:
03:46:55:  <!-- User Information -->
03:46:55:  <passkey v='********************************'/>
03:46:55:  <team v='12072'/>
03:46:55:  <user v='noprob'/>
03:46:55:
03:46:55:  <!-- Folding Slots -->
03:46:55:  <slot id='1' type='GPU'>
03:46:55:    <gpu-index v='0'/>
03:46:55:    <paused v='true'/>
03:46:55:  </slot>
03:46:55:  <slot id='0' type='CPU'>
03:46:55:  </slot>
03:46:55:</config>
03:46:55:Trying to access database...
03:46:55:Successfully acquired database lock
03:46:55:Enabled folding slot 01: PAUSED gpu:0:GT200b [GeForce GTX 275] (by user)
03:46:55:Enabled folding slot 00: PAUSED cpu:1 (by user)
03:47:00:8:127.0.0.1:New Web connection
03:47:12:FS01:Unpaused
03:47:12:FS00:Unpaused
computer #2 x86
23:44:04:WU00:FS00:0xa7:*********************** Log Started 2016-12-13T23:44:04Z ***********************
23:44:04:WU00:FS00:0xa7:************************** Gromacs Folding@home Core ***************************
23:44:04:WU00:FS00:0xa7:       Type: 0xa7
23:44:04:WU00:FS00:0xa7:       Core: Gromacs
23:44:04:WU00:FS00:0xa7:    Website: http://folding.stanford.edu/
23:44:04:WU00:FS00:0xa7:  Copyright: (c) 2009-2016 Stanford University
23:44:04:WU00:FS00:0xa7:     Author: Joseph Coffland <joseph@cauldrondevelopment.com>
23:44:04:WU00:FS00:0xa7:       Args: -dir 00 -suffix 01 -version 704 -lifeline 2840 -checkpoint 15 -np 3
23:44:04:WU00:FS00:0xa7:     Config: <none>
23:44:04:WU00:FS00:0xa7:************************************ Build *************************************
23:44:04:WU00:FS00:0xa7:    Version: 0.0.11
23:44:04:WU00:FS00:0xa7:       Date: Sep 20 2016
23:44:04:WU00:FS00:0xa7:       Time: 08:11:09
23:44:04:WU00:FS00:0xa7: Repository: Git
23:44:04:WU00:FS00:0xa7:   Revision: 957bd90e68d95ddcf1594dc15ff6c64cc4555146
23:44:04:WU00:FS00:0xa7:     Branch: master
23:44:04:WU00:FS00:0xa7:   Compiler: GNU 5.4.0 20160609
23:44:04:WU00:FS00:0xa7:    Options: -std=gnu++98 -O3 -funroll-loops -ffast-math -mfpmath=sse
23:44:04:WU00:FS00:0xa7:             -fno-unsafe-math-optimizations -msse2 -I/mingw32/include
23:44:04:WU00:FS00:0xa7:   Platform: linux2 4.6.0-1-amd64
23:44:04:WU00:FS00:0xa7:       Bits: 32
23:44:04:WU00:FS00:0xa7:       Mode: Release
23:44:04:WU00:FS00:0xa7:       SIMD: sse2
23:44:04:WU00:FS00:0xa7:************************************ System ************************************
23:44:04:WU00:FS00:0xa7:        CPU: Intel(R) Core(TM) i3-2100 CPU @ 3.10GHz
23:44:04:WU00:FS00:0xa7:     CPU ID: GenuineIntel Family 6 Model 42 Stepping 7
23:44:04:WU00:FS00:0xa7:       CPUs: 4
23:44:04:WU00:FS00:0xa7:     Memory: 2.99GiB
23:44:04:WU00:FS00:0xa7:Free Memory: 2.26GiB
23:44:04:WU00:FS00:0xa7:    Threads: WINDOWS_THREADS
23:44:04:WU00:FS00:0xa7: OS Version: 6.1
23:44:04:WU00:FS00:0xa7:Has Battery: false
23:44:04:WU00:FS00:0xa7: On Battery: false
23:44:04:WU00:FS00:0xa7: UTC Offset: -5
23:44:04:WU00:FS00:0xa7:        PID: 312
23:44:04:WU00:FS00:0xa7:        CWD: C:\Users\Administrator\AppData\Roaming\FAHClient\work
23:44:04:WU00:FS00:0xa7:         OS: Windows 7 Professional Service Pack 1
23:44:04:WU00:FS00:0xa7:    OS Arch: X86
23:44:04:WU00:FS00:0xa7:********************************************************************************
23:44:04:WU00:FS00:0xa7:Project: 11920 (Run 64, Clone 6, Gen 186)
23:44:04:WU00:FS00:0xa7:Unit: 0x000000dfab4041295809d200de37168a
23:44:04:WU00:FS00:0xa7:Reading tar file core.xml
23:44:04:WU00:FS00:0xa7:Reading tar file frame186.tpr
23:44:04:WU00:FS00:0xa7:Digital signatures verified
23:44:04:WU00:FS00:0xa7:Calling: mdrun -s frame186.tpr -o frame186.trr -cpt 15 -nt 3
23:44:06:WU00:FS00:0xa7:Steps: first=14880000 total=80000
23:44:10:WU00:FS00:0xa7:Completed 1 out of 80000 steps (0%)
23:47:48:WU00:FS00:0xa7:Completed 800 out of 80000 steps (1%)
23:47:58:WU01:FS01:0xa7:Completed 66400 out of 80000 steps (83%)
23:51:28:WU00:FS00:0xa7:Completed 1600 out of 80000 steps (2%)
23:55:08:WU00:FS00:0xa7:Completed 2400 out of 80000 steps (3%)
23:58:46:WU00:FS00:0xa7:Completed 3200 out of 80000 steps (4%)
23:58:50:WU01:FS01:0xa7:Completed 67200 out of 80000 steps (84%)
00:02:28:WU00:FS00:0xa7:Completed 4000 out of 80000 steps (5%)
00:06:10:WU00:FS00:0xa7:Completed 4800 out of 80000 steps (6%)
00:09:35:WU01:FS01:0xa7:Completed 68000 out of 80000 steps (85%)
00:09:53:WU00:FS00:0xa7:Completed 5600 out of 80000 steps (7%)
00:13:33:WU00:FS00:0xa7:Completed 6400 out of 80000 steps (8%)
00:17:15:WU00:FS00:0xa7:Completed 7200 out of 80000 steps (9%)
00:20:24:WU01:FS01:0xa7:Completed 68800 out of 80000 steps (86%)
00:20:55:WU00:FS00:0xa7:Completed 8000 out of 80000 steps (10%)
00:24:35:WU00:FS00:0xa7:Completed 8800 out of 80000 steps (11%)
00:28:14:WU00:FS00:0xa7:Completed 9600 out of 80000 steps (12%)
00:31:13:WU01:FS01:0xa7:Completed 69600 out of 80000 steps (87%)
00:31:55:WU00:FS00:0xa7:Completed 10400 out of 80000 steps (13%)
00:35:33:WU00:FS00:0xa7:Completed 11200 out of 80000 steps (14%)
00:39:11:WU00:FS00:0xa7:Completed 12000 out of 80000 steps (15%)
00:42:10:WU01:FS01:0xa7:Completed 70400 out of 80000 steps (88%)
00:42:48:WU00:FS00:0xa7:Completed 12800 out of 80000 steps (16%)
00:46:28:WU00:FS00:0xa7:Completed 13600 out of 80000 steps (17%)
00:50:09:WU00:FS00:0xa7:Completed 14400 out of 80000 steps (18%)
00:52:59:WU01:FS01:0xa7:Completed 71200 out of 80000 steps (89%)
00:53:49:WU00:FS00:0xa7:Completed 15200 out of 80000 steps (19%)
00:57:28:WU00:FS00:0xa7:Completed 16000 out of 80000 steps (20%)
01:01:08:WU00:FS00:0xa7:Completed 16800 out of 80000 steps (21%)
01:03:54:WU01:FS01:0xa7:Completed 72000 out of 80000 steps (90%)
01:04:49:WU00:FS00:0xa7:Completed 17600 out of 80000 steps (22%)
01:08:26:WU00:FS00:0xa7:Completed 18400 out of 80000 steps (23%)
01:12:04:WU00:FS00:0xa7:Completed 19200 out of 80000 steps (24%)
01:14:52:WU01:FS01:0xa7:Completed 72800 out of 80000 steps (91%)
01:15:48:WU00:FS00:0xa7:Completed 20000 out of 80000 steps (25%)
01:19:28:WU00:FS00:0xa7:Completed 20800 out of 80000 steps (26%)
01:23:08:WU00:FS00:0xa7:Completed 21600 out of 80000 steps (27%)
01:25:36:WU01:FS01:0xa7:Completed 73600 out of 80000 steps (92%)
01:26:48:WU00:FS00:0xa7:Completed 22400 out of 80000 steps (28%)
01:30:32:WU00:FS00:0xa7:Completed 23200 out of 80000 steps (29%)
01:34:12:WU00:FS00:0xa7:Completed 24000 out of 80000 steps (30%)
01:36:19:WU01:FS01:0xa7:Completed 74400 out of 80000 steps (93%)
01:37:53:WU00:FS00:0xa7:Completed 24800 out of 80000 steps (31%)
01:41:33:WU00:FS00:0xa7:Completed 25600 out of 80000 steps (32%)
01:45:14:WU00:FS00:0xa7:Completed 26400 out of 80000 steps (33%)
01:47:09:WU01:FS01:0xa7:Completed 75200 out of 80000 steps (94%)
01:48:54:WU00:FS00:0xa7:Completed 27200 out of 80000 steps (34%)
01:52:35:WU00:FS00:0xa7:Completed 28000 out of 80000 steps (35%)
01:56:14:WU00:FS00:0xa7:Completed 28800 out of 80000 steps (36%)
01:57:59:WU01:FS01:0xa7:Completed 76000 out of 80000 steps (95%)
01:59:56:WU00:FS00:0xa7:Completed 29600 out of 80000 steps (37%)
02:03:33:WU00:FS00:0xa7:Completed 30400 out of 80000 steps (38%)
02:07:09:WU00:FS00:0xa7:Completed 31200 out of 80000 steps (39%)
02:08:58:WU01:FS01:0xa7:Completed 76800 out of 80000 steps (96%)
02:10:47:WU00:FS00:0xa7:Completed 32000 out of 80000 steps (40%)
02:14:25:WU00:FS00:0xa7:Completed 32800 out of 80000 steps (41%)
02:18:00:WU00:FS00:0xa7:Completed 33600 out of 80000 steps (42%)
02:20:03:WU01:FS01:0xa7:Completed 77600 out of 80000 steps (97%)
02:21:35:WU00:FS00:0xa7:Completed 34400 out of 80000 steps (43%)
02:25:10:WU00:FS00:0xa7:Completed 35200 out of 80000 steps (44%)
02:28:49:WU00:FS00:0xa7:Completed 36000 out of 80000 steps (45%)
02:31:00:WU01:FS01:0xa7:Completed 78400 out of 80000 steps (98%)
02:32:33:WU00:FS00:0xa7:Completed 36800 out of 80000 steps (46%)
02:36:14:WU00:FS00:0xa7:Completed 37600 out of 80000 steps (47%)
02:39:55:WU00:FS00:0xa7:Completed 38400 out of 80000 steps (48%)
02:41:46:WU01:FS01:0xa7:Completed 79200 out of 80000 steps (99%)
02:41:48:WU02:FS01:Connecting to 171.67.108.45:80
02:41:49:WU02:FS01:Assigned to work server 171.67.108.158
02:41:49:WU02:FS01:Requesting new work unit for slot 01: RUNNING gpu:0:GT200b [GeForce GTX 285] from 171.67.108.158
02:41:49:WU02:FS01:Connecting to 171.67.108.158:8080
02:41:51:WU02:FS01:Downloading 806.98KiB
02:41:58:WU02:FS01:Download 47.58%
02:42:11:WU02:FS01:Download 71.38%
02:42:19:WU02:FS01:Download 79.31%
02:42:26:WU02:FS01:Download 95.17%
02:42:27:WU02:FS01:Download complete
02:42:28:WU02:FS01:Received Unit: id:02 state:DOWNLOAD error:NO_ERROR project:9035 run:837 clone:0 gen:448 core:0xa4 unit:0x000001e6ab436c9e56982dace7fc8d0e
02:43:32:WU00:FS00:0xa7:Completed 39200 out of 80000 steps (49%)
02:47:09:WU00:FS00:0xa7:Completed 40000 out of 80000 steps (50%)
02:50:44:WU00:FS00:0xa7:Completed 40800 out of 80000 steps (51%)
02:52:50:WU01:FS01:0xa7:Completed 80000 out of 80000 steps (100%)
02:52:59:WU01:FS01:0xa7:Saving result file ..\logfile_01.txt
02:52:59:WU01:FS01:0xa7:Saving result file frame163.trr
02:52:59:WU01:FS01:0xa7:Saving result file md.log
02:52:59:WU01:FS01:0xa7:Saving result file science.log
02:52:59:WU01:FS01:0xa7:Folding@home Core Shutdown: FINISHED_UNIT
02:52:59:WU01:FS01:FahCore returned: FINISHED_UNIT (100 = 0x64)
02:52:59:WU01:FS01:Sending unit results: id:01 state:SEND error:NO_ERROR project:11920 run:760 clone:1 gen:163 core:0xa7 unit:0x000000cdab4041295809c6aa72c4c575
02:52:59:WU01:FS01:Uploading 3.97MiB to 171.64.65.41
02:52:59:WU02:FS01:Starting
02:52:59:WU02:FS01:Running FahCore: "C:\Program Files\FAHClient/FAHCoreWrapper.exe" C:/Users/Administrator/AppData/Roaming/FAHClient/cores/web.stanford.edu/~pande/Win32/x86/Core_a4.fah/FahCore_a4.exe -dir 02 -suffix 01 -version 704 -lifeline 3572 -checkpoint 15 -gpu 0
02:52:59:WU01:FS01:Connecting to 171.64.65.41:8080
02:52:59:WU02:FS01:Started FahCore on PID 3776
02:52:59:Started thread 17 on PID 3572
02:52:59:WU02:FS01:Core PID:3936
02:52:59:WU02:FS01:FahCore 0xa4 started
02:53:00:WU02:FS01:0xa4:
02:53:00:WU02:FS01:0xa4:*------------------------------*
02:53:00:WU02:FS01:0xa4:Folding@Home Gromacs GB Core
02:53:00:WU02:FS01:0xa4:Version 2.27 (Dec. 15, 2010)
02:53:00:WU02:FS01:0xa4:Preparing to commence simulation
02:53:00:WU02:FS01:0xa4:- Looking at optimizations...
02:53:00:WU02:FS01:0xa4:- Created dyn
02:53:00:WU02:FS01:0xa4:- Files status OK
02:53:00:WU02:FS01:0xa4:- Expanded 825840 -> 1402156 (decompressed 169.7 percent)
02:53:00:WU02:FS01:0xa4:Called DecompressByteArray: compressed_data_size=825840 data_size=1402156, decompressed_data_size=1402156 diff=0
02:53:00:WU02:FS01:0xa4:- Error: Bad work unit. Digital signatures don't match
02:53:00:WU02:FS01:0xa4:Error: Could not open work file
02:53:00:WU02:FS01:0xa4:Folding@home Core Shutdown: FILE_IO_ERROR
02:53:00:WARNING:WU02:FS01:FahCore returned: FILE_IO_ERROR (117 = 0x75)
02:53:00:WARNING:WU02:FS01:Fatal error, dumping
02:53:00:WU02:FS01:Sending unit results: id:02 state:SEND error:DUMPED project:9035 run:837 clone:0 gen:448 core:0xa4 unit:0x000001e6ab436c9e56982dace7fc8d0e
02:53:00:WU02:FS01:Connecting to 171.67.108.158:8080
02:53:01:WU03:FS01:Connecting to 171.67.108.45:80
02:53:01:WU02:FS01:Server responded WORK_ACK (400)
02:53:02:WU02:FS01:Cleaning up
02:53:03:WU03:FS01:Assigned to work server 171.67.108.158
02:53:03:WU03:FS01:Requesting new work unit for slot 01: READY gpu:0:GT200b [GeForce GTX 285] from 171.67.108.158
02:53:03:WU03:FS01:Connecting to 171.67.108.158:8080
02:53:05:WU03:FS01:Downloading 806.37KiB
02:53:06:WU01:FS01:Upload 6.30%
02:53:11:WU03:FS01:Download 23.81%
02:53:13:WU01:FS01:Upload 14.16%
02:53:17:WU03:FS01:Download 47.62%
02:53:20:WU01:FS01:Upload 22.03%
02:53:24:WU03:FS01:Download 79.37%
02:53:26:WU01:FS01:Upload 28.33%
02:53:28:WU03:FS01:Download complete
02:53:29:WU03:FS01:Received Unit: id:03 state:DOWNLOAD error:NO_ERROR project:9031 run:494 clone:0 gen:629 core:0xa4 unit:0x000002b3ab436c9e5698346abbc02df5
02:53:29:WU03:FS01:Starting
02:53:29:WU03:FS01:Running FahCore: "C:\Program Files\FAHClient/FAHCoreWrapper.exe" C:/Users/Administrator/AppData/Roaming/FAHClient/cores/web.stanford.edu/~pande/Win32/x86/Core_a4.fah/FahCore_a4.exe -dir 03 -suffix 01 -version 704 -lifeline 3572 -checkpoint 15 -gpu 0
02:53:29:WU03:FS01:Started FahCore on PID 3156
02:53:29:Started thread 18 on PID 3572
02:53:29:WU03:FS01:Core PID:2940
02:53:29:WU03:FS01:FahCore 0xa4 started
02:53:29:WARNING:WU03:FS01:FahCore returned: FILE_IO_ERROR (117 = 0x75)
02:53:29:WARNING:WU03:FS01:Fatal error, dumping
02:53:29:WU03:FS01:Sending unit results: id:03 state:SEND error:DUMPED project:9031 run:494 clone:0 gen:629 core:0xa4 unit:0x000002b3ab436c9e5698346abbc02df5
02:53:29:WU03:FS01:Connecting to 171.67.108.158:8080
02:53:30:WU02:FS01:Connecting to 171.67.108.45:80
02:53:31:WU03:FS01:Server responded WORK_ACK (400)
02:53:31:WU03:FS01:Cleaning up
02:53:31:WU02:FS01:Assigned to work server 171.67.108.158
02:53:31:WU02:FS01:Requesting new work unit for slot 01: READY gpu:0:GT200b [GeForce GTX 285] from 171.67.108.158
02:53:31:WU02:FS01:Connecting to 171.67.108.158:8080
02:53:33:WU01:FS01:Upload 36.20%
02:53:33:WU02:FS01:Downloading 806.58KiB
02:53:40:WU01:FS01:Upload 44.07%
02:53:40:WU02:FS01:Download 23.80%
02:53:47:WU02:FS01:Download 55.54%
02:53:47:WU01:FS01:Upload 51.94%
02:53:52:WU02:FS01:Download complete
02:53:52:WU02:FS01:Received Unit: id:02 state:DOWNLOAD error:NO_ERROR project:9034 run:452 clone:2 gen:581 core:0xa4 unit:0x00000287ab436c9e56982fdec64a0fe2
02:53:52:WU02:FS01:Starting
02:53:52:WU02:FS01:Running FahCore: "C:\Program Files\FAHClient/FAHCoreWrapper.exe" C:/Users/Administrator/AppData/Roaming/FAHClient/cores/web.stanford.edu/~pande/Win32/x86/Core_a4.fah/FahCore_a4.exe -dir 02 -suffix 01 -version 704 -lifeline 3572 -checkpoint 15 -gpu 0
02:53:52:WU02:FS01:Started FahCore on PID 2656
02:53:52:Started thread 19 on PID 3572
02:53:52:WU02:FS01:Core PID:3860
02:53:52:WU02:FS01:FahCore 0xa4 started
02:53:52:WARNING:WU02:FS01:FahCore returned: FILE_IO_ERROR (117 = 0x75)
02:53:52:WARNING:WU02:FS01:Fatal error, dumping
the end result is both computers have a gpu failed slot and no longer working,my question is what do I do to correct this issue?
I am using an older driver version 275.33,I was lead to believe an nvidia driver above version 177 would suffice,I may be wrong in that belief.
after considering your previous reply it would seem to me to ditch the non x64 and most probably update nvidia drivers to what working version?
Thank you
Re: Why GPU Failed
I'm afraid that your failed GPU is because the [GeForce GTX 275] is unsupported. See about 35 lines from the top:
Was the compination of 1 CPU slot and 1 GPU slot created automatically when you installed FAH or did you add it manually?
NVidia GPUs older than the Fermi series (G80 through the 200 series) are no longer supportable no matter what drivers you use.
On a system which somehow is trying to fold on an unsupportable GPU, you'd be better off deleting that slot so that your CPU slot can share the two CPUs Even with both CPU working on the same assignment, a more viable approach would be to upgrade the GPU (there are many affordable GPUs). It would outproduce the CPU slot by a significant margin -- or you may choose to continue to fold with 1 CPU while the other is in use by your upgraded GPU.
noprob
Re: Why GPU Failed
Post by noprob »
yes I did install manually.
I see that was a wrong move and thank you bruce for bringing this to my attention.
I haven't folded in over 3 years,seems a lot has changed.
so a EVGA NVIDIA GeForce GTX 470 (012-P3-1470-TR) 1.2GB GDDR5 PCIe for cheap will work?
Re: Why GPU Failed
Post by foldy »
The gtx 470 will work but gets only 30k PPD.
For 100 dollar you could get a Nvidia gtx 1050 or Amd rx 460 which get 130k PPD.
How much money can you spend on a new GPU?
Re: Why GPU Failed
While the GTX 1050 or 1050 Ti are expected to have great price and performance for a modern GPU, they're still on the list of poorly supported GPUs. The continuing saga of problems with the 375/376.xx drivers is very likely going to be resolved in the very near future, but as of today, it has not been fixed. (Personally, I've been holding off on getting one of them.)
noprob
Re: Why GPU Failed
Post by noprob »
foldy wrote:The gtx 470 will work but gets only 30k PPD.
30k PPD x2 will do me fine@$36.00 each x2=$72 (purchased already)
though I do need to invest in another 500W OCZ@$50, new at newegg on sale at this time,I think 5 more days on sale.(purchased after posting)
doing this all on the cheap as funds are limited.
thanks for the heads up though on the $100 GPU.
on a side note the nvidia driver 373.06-desktop-win8-win7-64bit-international-whql works well on windows 7 Pro x64
Re: Why GPU Failed
Post by foldy »
We also have a latest hotfix driver from nvidia now :-)
viewtopic.php?f=80&t=29497
