11920, server didn't like result
ChristianVirtual
Post by ChristianVirtual »
On my CentOS i7-6700
11:05:33:WU01:FS00:0xa7:Completed 80000 out of 80000 steps (100%)
11:05:34:WU01:FS00:0xa7:Saving result file ../logfile_01.txt
11:05:34:WU01:FS00:0xa7:Saving result file frame164.trr
11:05:34:WU01:FS00:0xa7:Saving result file md.log
11:05:34:WU01:FS00:0xa7:Saving result file science.log
11:05:34:WU01:FS00:0xa7:Folding@home Core Shutdown: FINISHED_UNIT
11:05:34:WU00:FS00:Connecting to 171.67.108.45:8080
11:05:35:WU01:FS00:FahCore returned: FINISHED_UNIT (100 = 0x64)
11:05:35:WU01:FS00:Sending unit results: id:01 state:SEND error:NO_ERROR project:11920 run:249 clone:5 gen:164 core:0xa7 unit:0x000000dcab4041295809cefa89e697d6
11:05:35:WU01:FS00:Uploading 3.96MiB to 171.64.65.41
11:05:35:WU01:FS00:Connecting to 171.64.65.41:8080
11:05:35:WARNING:WU01:FS00:WorkServer connection failed on port 8080 trying 80
11:05:35:WARNING:WU01:FS00:Exception: Failed to send results to work server: Failed to connect to 171.64.65.41:80: Connection refused
11:05:35:WU01:FS00:Trying to send results to collection server
11:05:35:WU01:FS00:Uploading 3.96MiB to 171.67.108.46
11:05:35:WU01:FS00:Connecting to 171.67.108.46:8080
11:05:36:WU01:FS00:Upload complete
11:05:36:WU01:FS00:Server responded WORK_QUIT (404)
11:05:36:WARNING:WU01:FS00:Server did not like results, dumping
That was the last one, others before worked well. Wonder if server need attention ?
Re: 11920, server didn't like result
Project 11920, Run 249, Clone 5, Gen 164 -- No data back from query (WU not receive yet)
You might check the log for the earlier attempts to upload. There are several possible causes of the rejected WU. One is that the WU is actually corrupt. Another is in the software that's designed to prevent a person from submitting the same result twice and getting double credit. Depending on the reason why the primary server (171.64.65.41 in your case) failed to connect the WU may or may not be acceptable to the Collection Server.
ChristianVirtual
As shown in the first line of the snapshot (completed 100%) that upload was the first attempt and failed direct. My guts tells me something wrong on the server.
