Project 9039 goes to 99.99% with 14.00 seconds left
Project 9039 goes to 99.99% with 14.00 seconds left, it has been like this for hours. (Note, this happens multiple times)
Re: Project 9039 goes to 99.99% with 14.00 seconds left
Typically the indications you have described usually are the result of some kind of crash occurred. If you can post your log file, showing the actual messages connected to processing the WU involved, then we would have a better chance of figuring out what happened.
Once a WU quits making progress for any reason, the progress indicator will continue to report increasing progress even though it's not happening ... until it reaches 99.99%
As Joe said, we need to figure out why the project is crashing and whether others are having trouble with the same PRCG.
Is your CPU overclocked?
Also, @bruce my CPU is not overclockedJoe_H wrote:Welcome to the folding support forum.
*********************** Log Started 2016-12-09T06:28:58Z ***********************
06:28:58:************************* Folding@home Client *************************
06:28:58: Website: http://folding.stanford.edu/
06:28:58: Copyright: (c) 2009-2014 Stanford University
06:28:58: Author: Joseph Coffland <joseph@cauldrondevelopment.com>
06:28:58: Args: --open-web-control
06:28:58: Config: C:/Users/User100/AppData/Roaming/FAHClient/config.xml
06:28:58:******************************** Build ********************************
06:28:58: Version: 7.4.4
06:28:58: Date: Mar 4 2014
06:28:58: Time: 20:26:54
06:28:58: SVN Rev: 4130
06:28:58: Branch: fah/trunk/client
06:28:58: Compiler: Intel(R) C++ MSVC 1500 mode 1200
06:28:58: Options: /TP /nologo /EHa /Qdiag-disable:4297,4103,1786,279 /Ox -arch:SSE
06:28:58: /QaxSSE2,SSE3,SSSE3,SSE4.1,SSE4.2 /Qopenmp /Qrestrict /MT /Qmkl
06:28:58: Platform: win32 XP
06:28:58: Bits: 32
06:28:58: Mode: Release
06:28:58:******************************* System ********************************
06:28:58: CPU: Intel(R) Core(TM) i7-4600U CPU @ 2.10GHz
06:28:58: CPU ID: GenuineIntel Family 6 Model 69 Stepping 1
06:28:58: CPUs: 4
06:28:58: Memory: 7.88GiB
06:28:58: Free Memory: 3.61GiB
06:28:58: Threads: WINDOWS_THREADS
06:28:58: OS Version: 6.2
06:28:58: Has Battery: true
06:28:58: On Battery: false
06:28:58: UTC Offset: -8
06:28:58: PID: 8420
06:28:58: CWD: C:/Users/User100/AppData/Roaming/FAHClient
06:28:58: OS: Windows 10 Enterprise
06:28:58: OS Arch: AMD64
06:28:58: GPUs: 0
06:28:58: CUDA: Not detected
06:28:58:Win32 Service: false
06:28:58:***********************************************************************
06:28:58:<config>
06:28:58: <!-- Folding Core -->
06:28:58: <checkpoint v='10'/>
06:28:58: <core-priority v='low'/>
06:28:58:
06:28:58: <!-- Network -->
06:28:58: <proxy v=':8080'/>
06:28:58:
06:28:58: <!-- Slot Control -->
06:28:58: <power v='full'/>
06:28:58:
06:28:58: <!-- User Information -->
06:28:58: <passkey v='********************************'/>
06:28:58: <team v='111065'/>
06:28:58: <user v='Sem6000'/>
06:28:58:
06:28:58: <!-- Folding Slots -->
06:28:58: <slot id='0' type='CPU'>
06:28:58: <cpus v='4'/>
06:28:58: </slot>
06:28:58: <slot id='1' type='CPU'>
06:28:58: </slot>
06:28:58: <slot id='2' type='CPU'>
06:28:58: </slot>
06:28:58: <slot id='3' type='CPU'>
06:28:58: </slot>
06:28:58: <slot id='4' type='CPU'>
06:28:58: </slot>
06:28:58: <slot id='5' type='CPU'>
06:28:58: </slot>
06:28:58: <slot id='6' type='CPU'>
06:28:58: </slot>
06:28:58: <slot id='7' type='CPU'>
06:28:58: </slot>
06:28:58:</config>
06:28:58:Trying to access database...
06:28:58:Successfully acquired database lock
06:28:58:Enabled folding slot 00: READY cpu:4
06:28:58:Enabled folding slot 01: READY cpu:4
06:28:58:Enabled folding slot 02: READY cpu:4
06:28:58:Enabled folding slot 03: READY cpu:4
06:28:58:Enabled folding slot 04: READY cpu:4
06:28:58:Enabled folding slot 05: READY cpu:4
06:28:58:Enabled folding slot 06: READY cpu:4
06:28:58:Enabled folding slot 07: READY cpu:4
06:28:58:WARNING:WU01:Missing data files, dumping
06:28:58:WU07:FS02:Starting
06:28:58:WU07:FS02:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:/Users/User100/AppData/Roaming/FAHClient/cores/web.stanford.edu/~pande/Win32/AMD64/Core_a4.fah/FahCore_a4.exe -dir 07 -suffix 01 -version 704 -lifeline 8420 -checkpoint 10 -np 4
06:28:59:WU07:FS02:Started FahCore on PID 3372
06:29:00:WU07:FS02:Core PID:7796
06:29:01:WU07:FS02:FahCore 0xa4 started
06:29:01:WU04:FS04:Starting
06:29:01:WU04:FS04:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:/Users/User100/AppData/Roaming/FAHClient/cores/web.stanford.edu/~pande/Win32/AMD64/Core_a4.fah/FahCore_a4.exe -dir 04 -suffix 01 -version 704 -lifeline 8420 -checkpoint 10 -np 4
06:29:01:WU07:FS02:0xa4:
06:29:01:WU07:FS02:0xa4:*------------------------------*
06:29:01:WU07:FS02:0xa4:Folding@Home Gromacs GB Core
06:29:01:WU07:FS02:0xa4:Version 2.27 (Dec. 15, 2010)
06:29:01:WU07:FS02:0xa4:Preparing to commence simulation
06:29:01:WU07:FS02:0xa4:- Looking at optimizations...
06:29:01:WU07:FS02:0xa4:- Files status OK
06:29:01:WU07:FS02:0xa4:- Expanded 825903 -> 1402860 (decompressed 169.8 percent)
06:29:01:WU07:FS02:0xa4:Called DecompressByteArray: compressed_data_size=825903 data_size=1402860, decompressed_data_size=1402860 diff=0
06:29:01:WU07:FS02:0xa4:- Digital signature verified
06:29:01:WU07:FS02:0xa4:Project: 9038 (Run 815, Clone 2, Gen 400)
06:29:01:WU07:FS02:0xa4:Assembly optimizations on if available.
06:29:01:WU07:FS02:0xa4:Entering M.D.
06:29:02:WU04:FS04:Started FahCore on PID 10092
06:29:03:WU04:FS04:Core PID:548
06:29:03:WU04:FS04:FahCore 0xa4 started
06:29:03:WU05:FS00:Starting
06:29:03:WU05:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:/Users/User100/AppData/Roaming/FAHClient/cores/web.stanford.edu/~pande/Win32/AMD64/AVX/Core_a7.fah/FahCore_a7.exe -dir 05 -suffix 01 -version 704 -lifeline 8420 -checkpoint 10 -np 4
06:29:03:WU04:FS04:0xa4:
06:29:03:WU04:FS04:0xa4:*------------------------------*
06:29:03:WU04:FS04:0xa4:Folding@Home Gromacs GB Core
06:29:03:WU04:FS04:0xa4:Version 2.27 (Dec. 15, 2010)
06:29:03:WU04:FS04:0xa4:Preparing to commence simulation
06:29:03:WU04:FS04:0xa4:- Looking at optimizations...
06:29:03:WU04:FS04:0xa4:- Files status OK
06:29:03:WU04:FS04:0xa4:- Expanded 825893 -> 1401112 (decompressed 169.6 percent)
06:29:03:WU04:FS04:0xa4:Called DecompressByteArray: compressed_data_size=825893 data_size=1401112, decompressed_data_size=1401112 diff=0
06:29:03:WU04:FS04:0xa4:- Digital signature verified
06:29:03:WU04:FS04:0xa4:Project: 9034 (Run 386, Clone 3, Gen 342)
06:29:03:WU04:FS04:0xa4:Assembly optimizations on if available.
06:29:03:WU04:FS04:0xa4:Entering M.D.
06:29:04:WU05:FS00:Started FahCore on PID 328
06:29:05:WU05:FS00:Core PID:6876
06:29:05:WU05:FS00:FahCore 0xa7 started
06:29:06:WU06:FS07:Starting
06:29:06:WU06:FS07:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:/Users/User100/AppData/Roaming/FAHClient/cores/web.stanford.edu/~pande/Win32/AMD64/Core_a4.fah/FahCore_a4.exe -dir 06 -suffix 01 -version 704 -lifeline 8420 -checkpoint 10 -np 4
06:29:06:WU05:FS00:0xa7:*********************** Log Started 2016-12-09T06:29:06Z ***********************
06:29:06:WU05:FS00:0xa7:************************** Gromacs Folding@home Core ***************************
06:29:06:WU05:FS00:0xa7: Type: 0xa7
06:29:06:WU05:FS00:0xa7: Core: Gromacs
06:29:06:WU05:FS00:0xa7: Website: http://folding.stanford.edu/
06:29:06:WU05:FS00:0xa7: Copyright: (c) 2009-2016 Stanford University
06:29:06:WU05:FS00:0xa7: Author: Joseph Coffland <joseph@cauldrondevelopment.com>
06:29:06:WU05:FS00:0xa7: Args: -dir 05 -suffix 01 -version 704 -lifeline 328 -checkpoint 10 -np 4
06:29:06:WU05:FS00:0xa7: Config: <none>
06:29:06:WU05:FS00:0xa7:************************************ Build *************************************
06:29:06:WU05:FS00:0xa7: Version: 0.0.11
06:29:06:WU05:FS00:0xa7: Date: Sep 21 2016
06:29:06:WU05:FS00:0xa7: Time: 01:43:48
06:29:06:WU05:FS00:0xa7: Repository: Git
06:29:06:WU05:FS00:0xa7: Revision: 957bd90e68d95ddcf1594dc15ff6c64cc4555146
06:29:06:WU05:FS00:0xa7: Branch: master
06:29:06:WU05:FS00:0xa7: Compiler: GNU 4.2.1 Compatible Clang 3.9.0 (trunk 274080)
06:29:06:WU05:FS00:0xa7: Options: -std=gnu++98 -O3 -funroll-loops -ffast-math -mfpmath=sse
06:29:06:WU05:FS00:0xa7: -fno-unsafe-math-optimizations -msse2 -I/mingw64/include
06:29:06:WU05:FS00:0xa7: -Wno-inconsistent-dllimport -Wno-parentheses-equality
06:29:06:WU05:FS00:0xa7: -Wno-deprecated-register -Wno-unused-local-typedef
06:29:06:WU05:FS00:0xa7: Platform: linux2 4.6.0-1-amd64
06:29:06:WU05:FS00:0xa7: Bits: 64
06:29:06:WU05:FS00:0xa7: Mode: Release
06:29:06:WU05:FS00:0xa7: SIMD: avx_256
06:29:06:WU05:FS00:0xa7:************************************ System ************************************
06:29:06:WU05:FS00:0xa7: CPU: Intel(R) Core(TM) i7-4600U CPU @ 2.10GHz
06:29:06:WU05:FS00:0xa7: CPU ID: GenuineIntel Family 6 Model 69 Stepping 1
06:29:06:WU05:FS00:0xa7: CPUs: 4
06:29:06:WU05:FS00:0xa7: Memory: 7.88GiB
06:29:06:WU05:FS00:0xa7:Free Memory: 3.57GiB
06:29:06:WU05:FS00:0xa7: Threads: WINDOWS_THREADS
06:29:06:WU05:FS00:0xa7: OS Version: 6.2
06:29:06:WU05:FS00:0xa7:Has Battery: true
06:29:06:WU05:FS00:0xa7: On Battery: false
06:29:06:WU05:FS00:0xa7: UTC Offset: -8
06:29:06:WU05:FS00:0xa7: PID: 6876
06:29:06:WU05:FS00:0xa7: CWD: C:\Users\User100\AppData\Roaming\FAHClient\work
06:29:06:WU05:FS00:0xa7: OS: Windows 10 Enterprise
06:29:06:WU05:FS00:0xa7: OS Arch: AMD64
06:29:06:WU05:FS00:0xa7:********************************************************************************
06:29:06:WU05:FS00:0xa7:Project: 11920 (Run 234, Clone 3, Gen 149)
06:29:06:WU05:FS00:0xa7:Unit: 0x000000beab4041295809cf399694a4e5
06:29:06:WU05:FS00:0xa7:Digital signatures verified
06:29:06:WU05:FS00:0xa7:Calling: mdrun -s frame149.tpr -o frame149.trr -cpi state.cpt -cpt 10 -nt 4
06:29:07:WU07:FS02:0xa4:Mapping NT from 4 to 4
06:29:07:WU06:FS07:Started FahCore on PID 6600
06:29:07:WU05:FS00:0xa7:Steps: first=11920000 total=80000
06:29:07:WU07:FS02:0xa4:Completed 0 out of 250000 steps (0%)
06:29:08:WU06:FS07:Core PID:9592
06:29:08:WU06:FS07:FahCore 0xa4 started
06:29:08:WU01:FS06:Cleaning up
06:29:09:WU08:FS03:Starting
06:29:09:WU08:FS03:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:/Users/User100/AppData/Roaming/FAHClient/cores/web.stanford.edu/~pande/Win32/AMD64/Core_a4.fah/FahCore_a4.exe -dir 08 -suffix 01 -version 704 -lifeline 8420 -checkpoint 10 -np 4
06:29:09:WU06:FS07:0xa4:
06:29:09:WU06:FS07:0xa4:*------------------------------*
06:29:09:WU06:FS07:0xa4:Folding@Home Gromacs GB Core
06:29:09:WU06:FS07:0xa4:Version 2.27 (Dec. 15, 2010)
06:29:09:WU06:FS07:0xa4:Preparing to commence simulation
06:29:09:WU06:FS07:0xa4:- Looking at optimizations...
06:29:09:WU06:FS07:0xa4:- Files status OK
06:29:09:WU06:FS07:0xa4:- Expanded 825800 -> 1401112 (decompressed 169.6 percent)
06:29:09:WU06:FS07:0xa4:Called DecompressByteArray: compressed_data_size=825800 data_size=1401112, decompressed_data_size=1401112 diff=0
06:29:09:WU06:FS07:0xa4:- Digital signature verified
06:29:09:WU06:FS07:0xa4:Project: 9034 (Run 181, Clone 1, Gen 434)
06:29:09:WU06:FS07:0xa4:Assembly optimizations on if available.
06:29:09:WU06:FS07:0xa4:Entering M.D.
06:29:09:WU04:FS04:0xa4:Using Gromacs checkpoints
06:29:09:WU04:FS04:0xa4:Mapping NT from 4 to 4
06:29:10:WU08:FS03:Started FahCore on PID 3136
06:29:11:WU05:FS00:0xa7:Completed 42327 out of 80000 steps (52%)
06:29:11:WU08:FS03:Core PID:6468
06:29:11:WU08:FS03:FahCore 0xa4 started
06:29:11:WU02:FS05:Starting
06:29:11:WU02:FS05:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:/Users/User100/AppData/Roaming/FAHClient/cores/web.stanford.edu/~pande/Win32/AMD64/Core_a4.fah/FahCore_a4.exe -dir 02 -suffix 01 -version 704 -lifeline 8420 -checkpoint 10 -np 4
06:29:12:WU08:FS03:0xa4:
06:29:12:WU08:FS03:0xa4:*------------------------------*
06:29:12:WU08:FS03:0xa4:Folding@Home Gromacs GB Core
06:29:12:WU08:FS03:0xa4:Version 2.27 (Dec. 15, 2010)
06:29:12:WU08:FS03:0xa4:Preparing to commence simulation
06:29:12:WU08:FS03:0xa4:- Looking at optimizations...
06:29:12:WU08:FS03:0xa4:- Files status OK
06:29:12:WU02:FS05:Started FahCore on PID 6980
06:29:13:WU02:FS05:Core PID:6436
06:29:13:WU02:FS05:FahCore 0xa4 started
06:29:13:WU00:FS01:Starting
06:29:13:WU00:FS01:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:/Users/User100/AppData/Roaming/FAHClient/cores/web.stanford.edu/~pande/Win32/AMD64/Core_a4.fah/FahCore_a4.exe -dir 00 -suffix 01 -version 704 -lifeline 8420 -checkpoint 10 -np 4
06:29:14:WU02:FS05:0xa4:
06:29:14:WU02:FS05:0xa4:*------------------------------*
06:29:14:WU02:FS05:0xa4:Folding@Home Gromacs GB Core
06:29:14:WU02:FS05:0xa4:Version 2.27 (Dec. 15, 2010)
06:29:14:WU02:FS05:0xa4:Preparing to commence simulation
06:29:14:WU02:FS05:0xa4:- Looking at optimizations...
06:29:14:WU02:FS05:0xa4:- Files status OK
06:29:14:WU08:FS03:0xa4:- Expanded 825884 -> 1403132 (decompressed 169.8 percent)
06:29:14:WU08:FS03:0xa4:Called DecompressByteArray: compressed_data_size=825884 data_size=1403132, decompressed_data_size=1403132 diff=0
06:29:14:WU08:FS03:0xa4:- Digital signature verified
06:29:14:WU08:FS03:0xa4:Project: 9036 (Run 563, Clone 2, Gen 259)
06:29:14:WU08:FS03:0xa4:Assembly optimizations on if available.
06:29:14:WU08:FS03:0xa4:Entering M.D.
06:29:15:WU00:FS01:Started FahCore on PID 8668
06:29:15:WU02:FS05:0xa4:- Expanded 825025 -> 1401332 (decompressed 169.8 percent)
06:29:15:WU02:FS05:0xa4:Called DecompressByteArray: compressed_data_size=825025 data_size=1401332, decompressed_data_size=1401332 diff=0
06:29:15:WU06:FS07:0xa4:Using Gromacs checkpoints
06:29:15:WU02:FS05:0xa4:- Digital signature verified
06:29:15:WU02:FS05:0xa4:Project: 9033 (Run 82, Clone 0, Gen 473)
06:29:15:WU02:FS05:0xa4:Assembly optimizations on if available.
06:29:15:WU02:FS05:0xa4:Entering M.D.
06:29:16:WU00:FS01:Core PID:4300
06:29:16:WU00:FS01:FahCore 0xa4 started
06:29:16:WU06:FS07:0xa4:Mapping NT from 4 to 4
06:29:17:WU00:FS01:0xa4:
06:29:17:WU00:FS01:0xa4:*------------------------------*
06:29:17:WU00:FS01:0xa4:Folding@Home Gromacs GB Core
06:29:17:WU00:FS01:0xa4:Version 2.27 (Dec. 15, 2010)
06:29:17:WU00:FS01:0xa4:Preparing to commence simulation
06:29:17:WU00:FS01:0xa4:- Looking at optimizations...
06:29:17:WU00:FS01:0xa4:- Files status OK
06:29:20:WU00:FS01:0xa4:- Expanded 825862 -> 1403132 (decompressed 169.8 percent)
06:29:20:WU00:FS01:0xa4:Called DecompressByteArray: compressed_data_size=825862 data_size=1403132, decompressed_data_size=1403132 diff=0
06:29:20:WU00:FS01:0xa4:- Digital signature verified
06:29:20:WU00:FS01:0xa4:Project: 9036 (Run 481, Clone 1, Gen 314)
06:29:20:WU00:FS01:0xa4:Assembly optimizations on if available.
06:29:20:WU00:FS01:0xa4:Entering M.D.
06:29:22:WU08:FS03:0xa4:Mapping NT from 4 to 4
06:29:23:WU02:FS05:0xa4:Using Gromacs checkpoints
06:29:24:WU02:FS05:0xa4:Mapping NT from 4 to 4
06:29:25:WU05:FS00:0xa7:Completed 42400 out of 80000 steps (53%)
06:29:27:WU00:FS01:0xa4:Using Gromacs checkpoints
06:29:28:WU00:FS01:0xa4:Mapping NT from 4 to 4
06:29:31:WU01:FS06:Connecting to 171.67.108.45:8080
06:29:32:WU01:FS06:Assigned to work server 171.67.108.158
06:29:32:WU01:FS06:Requesting new work unit for slot 06: READY cpu:4 from 171.67.108.158
06:29:32:WU01:FS06:Connecting to 171.67.108.158:8080
06:29:33:WU01:FS06:Downloading 807.06KiB
06:29:33:WU01:FS06:Download complete
06:29:34:WU01:FS06:Received Unit: id:01 state:DOWNLOAD error:NO_ERROR project:9034 run:911 clone:2 gen:542 core:0xa4 unit:0x00000256ab436c9e56982f19680afa38
06:29:34:WU01:FS06:Starting
06:29:34:WU01:FS06:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:/Users/User100/AppData/Roaming/FAHClient/cores/web.stanford.edu/~pande/Win32/AMD64/Core_a4.fah/FahCore_a4.exe -dir 01 -suffix 01 -version 704 -lifeline 8420 -checkpoint 10 -np 4
06:29:35:WU01:FS06:Started FahCore on PID 3504
06:29:36:WU01:FS06:Core PID:9156
06:29:36:WU01:FS06:FahCore 0xa4 started
06:29:37:WU01:FS06:0xa4:
06:29:37:WU01:FS06:0xa4:*------------------------------*
06:29:37:WU01:FS06:0xa4:Folding@Home Gromacs GB Core
06:29:37:WU01:FS06:0xa4:Version 2.27 (Dec. 15, 2010)
06:29:37:WU01:FS06:0xa4:Preparing to commence simulation
06:29:37:WU01:FS06:0xa4:- Looking at optimizations...
06:29:37:WU01:FS06:0xa4:- Created dyn
06:29:37:WU01:FS06:0xa4:- Files status OK
06:29:38:WU01:FS06:0xa4:- Expanded 825920 -> 1401112 (decompressed 169.6 percent)
06:29:38:WU01:FS06:0xa4:Called DecompressByteArray: compressed_data_size=825920 data_size=1401112, decompressed_data_size=1401112 diff=0
06:29:38:WU01:FS06:0xa4:- Digital signature verified
06:29:38:WU01:FS06:0xa4:Project: 9034 (Run 911, Clone 2, Gen 542)
06:29:38:WU01:FS06:0xa4:Assembly optimizations on if available.
06:29:38:WU01:FS06:0xa4:Entering M.D.
06:29:44:WU01:FS06:0xa4:Mapping NT from 4 to 4
06:30:11:WU04:FS04:0xa4:Resuming from checkpoint
06:30:11:WU04:FS04:0xa4:Verified 04/wudata_01.log
06:30:11:WU04:FS04:0xa4:Verified 04/wudata_01.trr
06:30:11:WU04:FS04:0xa4:Verified 04/wudata_01.xtc
06:30:11:WU04:FS04:0xa4:Verified 04/wudata_01.edr
06:30:16:WU04:FS04:0xa4:Completed 87490 out of 250000 steps (34%)
06:30:17:WARNING:WU04:FS04:Detected clock skew (1 mins 14 secs), adjusting time estimates
06:30:41:WU04:FS04:0xa4:Completed 87500 out of 250000 steps (35%)
06:30:53:WU06:FS07:0xa4:Resuming from checkpoint
06:30:53:WU06:FS07:0xa4:Verified 06/wudata_01.log
06:30:53:WU06:FS07:0xa4:Verified 06/wudata_01.trr
06:30:53:WU06:FS07:0xa4:Verified 06/wudata_01.xtc
06:30:53:WU06:FS07:0xa4:Verified 06/wudata_01.edr
06:30:56:WU02:FS05:0xa4:Resuming from checkpoint
06:30:56:WU02:FS05:0xa4:Verified 02/wudata_01.log
06:30:56:WU02:FS05:0xa4:Verified 02/wudata_01.trr
06:30:56:WU02:FS05:0xa4:Verified 02/wudata_01.xtc
06:30:56:WU02:FS05:0xa4:Verified 02/wudata_01.edr
06:31:01:WU06:FS07:0xa4:Completed 82090 out of 250000 steps (32%)
06:31:03:WU02:FS05:0xa4:Completed 87710 out of 250000 steps (35%)
06:31:03:WARNING:WU02:FS05:Detected clock skew (1 mins 50 secs), adjusting time estimates
06:31:04:WU08:FS03:0xa4:Completed 0 out of 250000 steps (0%)
06:31:05:WARNING:WU08:FS03:Detected clock skew (1 mins 54 secs), adjusting time estimates
06:31:10:WU00:FS01:0xa4:Resuming from checkpoint
06:31:10:WU00:FS01:0xa4:Verified 00/wudata_01.log
06:31:10:WU00:FS01:0xa4:Verified 00/wudata_01.trr
06:31:10:WU00:FS01:0xa4:Verified 00/wudata_01.xtc
06:31:10:WU00:FS01:0xa4:Verified 00/wudata_01.edr
06:31:16:WU00:FS01:0xa4:Completed 197610 out of 250000 steps (79%)
06:31:17:WARNING:WU00:FS01:Detected clock skew (2 mins 01 secs), adjusting time estimates
06:32:07:WU05:FS00:0xa7:Completed 43200 out of 80000 steps (54%)
06:32:24:WU01:FS06:0xa4:Completed 0 out of 250000 steps (0%)
06:34:58:WU05:FS00:0xa7:Completed 44000 out of 80000 steps (55%)
06:37:46:WU05:FS00:0xa7:Completed 44800 out of 80000 steps (56%)
06:40:30:WU05:FS00:0xa7:Completed 45600 out of 80000 steps (57%)
06:43:13:WU05:FS00:0xa7:Completed 46400 out of 80000 steps (58%)
06:46:04:WU05:FS00:0xa7:Completed 47200 out of 80000 steps (59%)
06:48:51:WU05:FS00:0xa7:Completed 48000 out of 80000 steps (60%)
06:51:37:WU05:FS00:0xa7:Completed 48800 out of 80000 steps (61%)
06:54:21:WU05:FS00:0xa7:Completed 49600 out of 80000 steps (62%)
06:57:12:WU05:FS00:0xa7:Completed 50400 out of 80000 steps (63%)
07:00:17:WU05:FS00:0xa7:Completed 51200 out of 80000 steps (64%)
07:00:28:FS00:Shutting core down
07:00:28:FS01:Shutting core down
07:00:28:FS02:Shutting core down
07:00:28:FS03:Shutting core down
07:00:28:FS04:Shutting core down
07:00:28:FS05:Shutting core down
07:00:28:FS06:Shutting core down
07:00:28:FS07:Shutting core down
07:00:28:WU05:FS00:0xa7:WARNING:Console control signal 1 on PID 6876
07:00:28:WU05:FS00:0xa7:Exiting, please wait. . .
07:00:30:WU04:FS04:0xa4:Client no longer detected. Shutting down core
07:00:30:WU04:FS04:0xa4:Folding@home Core Shutdown: CLIENT_DIED
07:00:30:WU02:FS05:0xa4:Client no longer detected. Shutting down core
07:00:30:WU01:FS06:0xa4:Client no longer detected. Shutting down core
07:00:30:WU02:FS05:0xa4:Folding@home Core Shutdown: CLIENT_DIED
07:00:30:WU01:FS06:0xa4:Folding@home Core Shutdown: CLIENT_DIED
07:00:30:WU04:FS04:FahCore returned: INTERRUPTED (102 = 0x66)
07:00:30:WU08:FS03:FahCore returned: INTERRUPTED (102 = 0x66)
07:00:31:WU02:FS05:FahCore returned: INTERRUPTED (102 = 0x66)
07:00:31:WU01:FS06:FahCore returned: INTERRUPTED (102 = 0x66)
07:00:31:WU05:FS00:0xa7:Folding@home Core Shutdown: INTERRUPTED
07:00:31:WU05:FS00:FahCore returned: INTERRUPTED (102 = 0x66)
07:00:35:WU07:FS02:0xa4:Client no longer detected. Shutting down core
07:00:35:WU07:FS02:0xa4:Folding@home Core Shutdown: CLIENT_DIED
07:00:35:WU00:FS01:0xa4:Client no longer detected. Shutting down core
07:00:35:WU06:FS07:0xa4:Client no longer detected. Shutting down core
07:00:35:WU00:FS01:0xa4:Folding@home Core Shutdown: CLIENT_DIED
07:00:35:WU06:FS07:0xa4:Folding@home Core Shutdown: CLIENT_DIED
07:00:35:WU07:FS02:FahCore returned: INTERRUPTED (102 = 0x66)
07:00:35:WU06:FS07:FahCore returned: INTERRUPTED (102 = 0x66)
07:00:35:WU00:FS01:FahCore returned: INTERRUPTED (102 = 0x66)
07:00:49:WU07:FS02:Starting
07:00:49:WU07:FS02:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:/Users/User100/AppData/Roaming/FAHClient/cores/web.stanford.edu/~pande/Win32/AMD64/Core_a4.fah/FahCore_a4.exe -dir 07 -suffix 01 -version 704 -lifeline 8420 -checkpoint 10 -np 4
07:00:51:WU07:FS02:Started FahCore on PID 11276
07:00:52:WU07:FS02:Core PID:11300
07:00:52:WU07:FS02:FahCore 0xa4 started
07:00:52:WU04:FS04:Starting
07:00:52:WU04:FS04:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:/Users/User100/AppData/Roaming/FAHClient/cores/web.stanford.edu/~pande/Win32/AMD64/Core_a4.fah/FahCore_a4.exe -dir 04 -suffix 01 -version 704 -lifeline 8420 -checkpoint 10 -np 4
07:00:52:WU07:FS02:0xa4:
07:00:52:WU07:FS02:0xa4:*------------------------------*
07:00:52:WU07:FS02:0xa4:Folding@Home Gromacs GB Core
07:00:52:WU07:FS02:0xa4:Version 2.27 (Dec. 15, 2010)
07:00:52:WU07:FS02:0xa4:Preparing to commence simulation
07:00:52:WU07:FS02:0xa4:- Looking at optimizations...
07:00:52:WU07:FS02:0xa4:- Files status OK
07:00:52:WU07:FS02:0xa4:- Expanded 825903 -> 1402860 (decompressed 169.8 percent)
07:00:52:WU07:FS02:0xa4:Called DecompressByteArray: compressed_data_size=825903 data_size=1402860, decompressed_data_size=1402860 diff=0
07:00:52:WU07:FS02:0xa4:- Digital signature verified
07:00:52:WU07:FS02:0xa4:Project: 9038 (Run 815, Clone 2, Gen 400)
07:00:52:WU07:FS02:0xa4:Assembly optimizations on if available.
07:00:52:WU07:FS02:0xa4:Entering M.D.
07:00:53:WU04:FS04:Started FahCore on PID 3100
07:00:54:WU04:FS04:Core PID:11632
07:00:54:WU04:FS04:FahCore 0xa4 started
07:00:54:WU05:FS00:Starting
07:00:54:WU05:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:/Users/User100/AppData/Roaming/FAHClient/cores/web.stanford.edu/~pande/Win32/AMD64/AVX/Core_a7.fah/FahCore_a7.exe -dir 05 -suffix 01 -version 704 -lifeline 8420 -checkpoint 10 -np 4
07:00:55:WU04:FS04:0xa4:
07:00:55:WU04:FS04:0xa4:*------------------------------*
07:00:55:WU04:FS04:0xa4:Folding@Home Gromacs GB Core
07:00:55:WU04:FS04:0xa4:Version 2.27 (Dec. 15, 2010)
07:00:55:WU04:FS04:0xa4:Preparing to commence simulation
07:00:55:WU04:FS04:0xa4:- Looking at optimizations...
07:00:55:WU04:FS04:0xa4:- Files status OK
07:00:55:WU04:FS04:0xa4:- Expanded 825893 -> 1401112 (decompressed 169.6 percent)
07:00:55:WU04:FS04:0xa4:Called DecompressByteArray: compressed_data_size=825893 data_size=1401112, decompressed_data_size=1401112 diff=0
07:00:55:WU04:FS04:0xa4:- Digital signature verified
07:00:55:WU04:FS04:0xa4:Project: 9034 (Run 386, Clone 3, Gen 342)
07:00:55:WU04:FS04:0xa4:Assembly optimizations on if available.
07:00:55:WU04:FS04:0xa4:Entering M.D.
07:00:55:WU05:FS00:Started FahCore on PID 9536
07:00:56:WU05:FS00:Core PID:11608
07:00:56:WU05:FS00:FahCore 0xa7 started
07:00:57:WU06:FS07:Starting
07:00:57:WU06:FS07:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:/Users/User100/AppData/Roaming/FAHClient/cores/web.stanford.edu/~pande/Win32/AMD64/Core_a4.fah/FahCore_a4.exe -dir 06 -suffix 01 -version 704 -lifeline 8420 -checkpoint 10 -np 4
07:00:57:WU05:FS00:0xa7:*********************** Log Started 2016-12-09T07:00:57Z ***********************
07:00:57:WU05:FS00:0xa7:************************** Gromacs Folding@home Core ***************************
07:00:57:WU05:FS00:0xa7: Type: 0xa7
07:00:57:WU05:FS00:0xa7: Core: Gromacs
07:00:57:WU05:FS00:0xa7: Website: http://folding.stanford.edu/
07:00:57:WU05:FS00:0xa7: Copyright: (c) 2009-2016 Stanford University
07:00:57:WU05:FS00:0xa7: Author: Joseph Coffland <joseph@cauldrondevelopment.com>
07:00:57:WU05:FS00:0xa7: Args: -dir 05 -suffix 01 -version 704 -lifeline 9536 -checkpoint 10 -np 4
07:00:57:WU05:FS00:0xa7: Config: <none>
07:00:57:WU05:FS00:0xa7:************************************ Build *************************************
07:00:57:WU05:FS00:0xa7: Version: 0.0.11
07:00:57:WU05:FS00:0xa7: Date: Sep 21 2016
07:00:57:WU05:FS00:0xa7: Time: 01:43:48
07:00:57:WU05:FS00:0xa7: Repository: Git
07:00:57:WU05:FS00:0xa7: Revision: 957bd90e68d95ddcf1594dc15ff6c64cc4555146
07:00:57:WU05:FS00:0xa7: Branch: master
07:00:57:WU05:FS00:0xa7: Compiler: GNU 4.2.1 Compatible Clang 3.9.0 (trunk 274080)
07:00:57:WU05:FS00:0xa7: Options: -std=gnu++98 -O3 -funroll-loops -ffast-math -mfpmath=sse
07:00:57:WU05:FS00:0xa7: -fno-unsafe-math-optimizations -msse2 -I/mingw64/include
07:00:57:WU05:FS00:0xa7: -Wno-inconsistent-dllimport -Wno-parentheses-equality
07:00:57:WU05:FS00:0xa7: -Wno-deprecated-register -Wno-unused-local-typedef
07:00:57:WU05:FS00:0xa7: Platform: linux2 4.6.0-1-amd64
07:00:57:WU05:FS00:0xa7: Bits: 64
07:00:57:WU05:FS00:0xa7: Mode: Release
07:00:57:WU05:FS00:0xa7: SIMD: avx_256
07:00:57:WU05:FS00:0xa7:************************************ System ************************************
07:00:57:WU05:FS00:0xa7: CPU: Intel(R) Core(TM) i7-4600U CPU @ 2.10GHz
07:00:57:WU05:FS00:0xa7: CPU ID: GenuineIntel Family 6 Model 69 Stepping 1
07:00:57:WU05:FS00:0xa7: CPUs: 4
07:00:57:WU05:FS00:0xa7: Memory: 7.88GiB
07:00:57:WU05:FS00:0xa7:Free Memory: 4.22GiB
07:00:57:WU05:FS00:0xa7: Threads: WINDOWS_THREADS
07:00:57:WU05:FS00:0xa7: OS Version: 6.2
07:00:57:WU05:FS00:0xa7:Has Battery: true
07:00:57:WU05:FS00:0xa7: On Battery: false
07:00:57:WU05:FS00:0xa7: UTC Offset: -8
07:00:57:WU05:FS00:0xa7: PID: 11608
07:00:57:WU05:FS00:0xa7: CWD: C:\Users\User100\AppData\Roaming\FAHClient\work
07:00:57:WU05:FS00:0xa7: OS: Windows 10 Enterprise
07:00:57:WU05:FS00:0xa7: OS Arch: AMD64
07:00:57:WU05:FS00:0xa7:********************************************************************************
07:00:57:WU05:FS00:0xa7:Project: 11920 (Run 234, Clone 3, Gen 149)
07:00:57:WU05:FS00:0xa7:Unit: 0x000000beab4041295809cf399694a4e5
07:00:57:WU05:FS00:0xa7:Digital signatures verified
07:00:57:WU05:FS00:0xa7:Calling: mdrun -s frame149.tpr -o frame149.trr -cpi state.cpt -cpt 10 -nt 4
07:00:58:WU06:FS07:Started FahCore on PID 11536
07:00:58:WU05:FS00:0xa7:Steps: first=11920000 total=80000
07:00:58:WU07:FS02:0xa4:Using Gromacs checkpoints
07:00:58:WU07:FS02:0xa4:Mapping NT from 4 to 4
07:00:59:WU07:FS02:0xa4:Resuming from checkpoint
07:00:59:WU07:FS02:0xa4:Verified 07/wudata_01.log
07:00:59:WU07:FS02:0xa4:Verified 07/wudata_01.trr
07:00:59:WU07:FS02:0xa4:Verified 07/wudata_01.xtc
07:00:59:WU07:FS02:0xa4:Verified 07/wudata_01.edr
07:00:59:WU07:FS02:0xa4:Completed 290 out of 250000 steps (0%)
07:00:59:WU06:FS07:Core PID:10728
07:00:59:WU06:FS07:FahCore 0xa4 started
07:00:59:WU08:FS03:Starting
07:00:59:WU08:FS03:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:/Users/User100/AppData/Roaming/FAHClient/cores/web.stanford.edu/~pande/Win32/AMD64/Core_a4.fah/FahCore_a4.exe -dir 08 -suffix 01 -version 704 -lifeline 8420 -checkpoint 10 -np 4
07:01:00:WU06:FS07:0xa4:
07:01:00:WU06:FS07:0xa4:*------------------------------*
07:01:00:WU06:FS07:0xa4:Folding@Home Gromacs GB Core
07:01:00:WU06:FS07:0xa4:Version 2.27 (Dec. 15, 2010)
07:01:00:WU06:FS07:0xa4:Preparing to commence simulation
07:01:00:WU06:FS07:0xa4:- Looking at optimizations...
07:01:00:WU06:FS07:0xa4:- Files status OK
07:01:00:WU06:FS07:0xa4:- Expanded 825800 -> 1401112 (decompressed 169.6 percent)
07:01:00:WU06:FS07:0xa4:Called DecompressByteArray: compressed_data_size=825800 data_size=1401112, decompressed_data_size=1401112 diff=0
07:01:00:WU06:FS07:0xa4:- Digital signature verified
07:01:00:WU06:FS07:0xa4:Project: 9034 (Run 181, Clone 1, Gen 434)
07:01:00:WU06:FS07:0xa4:Assembly optimizations on if available.
07:01:00:WU06:FS07:0xa4:Entering M.D.
07:01:00:WU08:FS03:Started FahCore on PID 11956
07:01:01:WU04:FS04:0xa4:Using Gromacs checkpoints
07:01:01:WU04:FS04:0xa4:Mapping NT from 4 to 4
07:01:01:WU05:FS00:0xa7:Completed 51252 out of 80000 steps (64%)
07:01:02:WU08:FS03:Core PID:11948
07:01:02:WU08:FS03:FahCore 0xa4 started
07:01:02:WU02:FS05:Starting
07:01:02:WU02:FS05:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:/Users/User100/AppData/Roaming/FAHClient/cores/web.stanford.edu/~pande/Win32/AMD64/Core_a4.fah/FahCore_a4.exe -dir 02 -suffix 01 -version 704 -lifeline 8420 -checkpoint 10 -np 4
07:01:02:WU08:FS03:0xa4:
07:01:02:WU08:FS03:0xa4:*------------------------------*
07:01:02:WU08:FS03:0xa4:Folding@Home Gromacs GB Core
07:01:02:WU08:FS03:0xa4:Version 2.27 (Dec. 15, 2010)
07:01:02:WU08:FS03:0xa4:Preparing to commence simulation
07:01:02:WU08:FS03:0xa4:- Looking at optimizations...
07:01:02:WU08:FS03:0xa4:- Files status OK
07:01:02:WU08:FS03:0xa4:- Expanded 825884 -> 1403132 (decompressed 169.8 percent)
07:01:02:WU08:FS03:0xa4:Called DecompressByteArray: compressed_data_size=825884 data_size=1403132, decompressed_data_size=1403132 diff=0
07:01:02:WU08:FS03:0xa4:- Digital signature verified
07:01:02:WU08:FS03:0xa4:Project: 9036 (Run 563, Clone 2, Gen 259)
07:01:02:WU08:FS03:0xa4:Assembly optimizations on if available.
07:01:03:WU08:FS03:0xa4:Entering M.D.
07:01:03:WU02:FS05:Started FahCore on PID 8816
07:01:04:WU02:FS05:Core PID:11340
07:01:04:WU02:FS05:FahCore 0xa4 started
07:01:04:WU00:FS01:Starting
07:01:04:WU00:FS01:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:/Users/User100/AppData/Roaming/FAHClient/cores/web.stanford.edu/~pande/Win32/AMD64/Core_a4.fah/FahCore_a4.exe -dir 00 -suffix 01 -version 704 -lifeline 8420 -checkpoint 10 -np 4
07:01:04:WU02:FS05:0xa4:
07:01:04:WU02:FS05:0xa4:*------------------------------*
07:01:04:WU02:FS05:0xa4:Folding@Home Gromacs GB Core
07:01:04:WU02:FS05:0xa4:Version 2.27 (Dec. 15, 2010)
07:01:04:WU02:FS05:0xa4:Preparing to commence simulation
07:01:05:WU02:FS05:0xa4:- Looking at optimizations...
07:01:05:WU02:FS05:0xa4:- Files status OK
07:01:05:WU00:FS01:Started FahCore on PID 1232
07:01:05:WU02:FS05:0xa4:- Expanded 825025 -> 1401332 (decompressed 169.8 percent)
07:01:05:WU02:FS05:0xa4:Called DecompressByteArray: compressed_data_size=825025 data_size=1401332, decompressed_data_size=1401332 diff=0
07:01:05:WU02:FS05:0xa4:- Digital signature verified
07:01:06:WU02:FS05:0xa4:Project: 9033 (Run 82, Clone 0, Gen 473)
07:01:06:WU02:FS05:0xa4:Assembly optimizations on if available.
07:01:06:WU02:FS05:0xa4:Entering M.D.
07:01:06:WU06:FS07:0xa4:Using Gromacs checkpoints
07:01:06:WU00:FS01:Core PID:10436
07:01:06:WU00:FS01:FahCore 0xa4 started
07:01:06:WU01:FS06:Starting
07:01:06:WU01:FS06:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:/Users/User100/AppData/Roaming/FAHClient/cores/web.stanford.edu/~pande/Win32/AMD64/Core_a4.fah/FahCore_a4.exe -dir 01 -suffix 01 -version 704 -lifeline 8420 -checkpoint 10 -np 4
07:01:06:WU06:FS07:0xa4:Mapping NT from 4 to 4
07:01:07:WU00:FS01:0xa4:
07:01:07:WU00:FS01:0xa4:*------------------------------*
07:01:07:WU00:FS01:0xa4:Folding@Home Gromacs GB Core
07:01:07:WU00:FS01:0xa4:Version 2.27 (Dec. 15, 2010)
07:01:07:WU00:FS01:0xa4:Preparing to commence simulation
07:01:07:WU00:FS01:0xa4:- Looking at optimizations...
07:01:07:WU00:FS01:0xa4:- Files status OK
07:01:07:WU01:FS06:Started FahCore on PID 11876
07:01:08:WU00:FS01:0xa4:- Expanded 825862 -> 1403132 (decompressed 169.8 percent)
07:01:08:WU00:FS01:0xa4:Called DecompressByteArray: compressed_data_size=825862 data_size=1403132, decompressed_data_size=1403132 diff=0
07:01:08:WU00:FS01:0xa4:- Digital signature verified
07:01:08:WU00:FS01:0xa4:Project: 9036 (Run 481, Clone 1, Gen 314)
07:01:08:WU00:FS01:0xa4:Assembly optimizations on if available.
07:01:08:WU00:FS01:0xa4:Entering M.D.
07:01:08:WU01:FS06:Core PID:9804
07:01:08:WU01:FS06:FahCore 0xa4 started
07:01:08:WU08:FS03:0xa4:Using Gromacs checkpoints
07:01:09:WU08:FS03:0xa4:Mapping NT from 4 to 4
07:01:09:WU01:FS06:0xa4:
07:01:09:WU01:FS06:0xa4:*------------------------------*
07:01:09:WU01:FS06:0xa4:Folding@Home Gromacs GB Core
07:01:09:WU01:FS06:0xa4:Version 2.27 (Dec. 15, 2010)
07:01:09:WU01:FS06:0xa4:Preparing to commence simulation
07:01:09:WU01:FS06:0xa4:- Looking at optimizations...
07:01:09:WU01:FS06:0xa4:- Files status OK
07:01:12:WU02:FS05:0xa4:Using Gromacs checkpoints
07:01:13:WU01:FS06:0xa4:- Expanded 825920 -> 1401112 (decompressed 169.6 percent)
07:01:13:WU01:FS06:0xa4:Called DecompressByteArray: compressed_data_size=825920 data_size=1401112, decompressed_data_size=1401112 diff=0
07:01:13:WU01:FS06:0xa4:- Digital signature verified
07:01:13:WU01:FS06:0xa4:Project: 9034 (Run 911, Clone 2, Gen 542)
07:01:13:WU02:FS05:0xa4:Mapping NT from 4 to 4
07:01:14:WU01:FS06:0xa4:Assembly optimizations on if available.
07:01:14:WU01:FS06:0xa4:Entering M.D.
07:01:14:WU00:FS01:0xa4:Using Gromacs checkpoints
07:01:15:WU00:FS01:0xa4:Mapping NT from 4 to 4
07:01:20:WU01:FS06:0xa4:Using Gromacs checkpoints
07:01:20:WU01:FS06:0xa4:Mapping NT from 4 to 4
07:01:59:WU04:FS04:0xa4:Resuming from checkpoint
07:01:59:WU04:FS04:0xa4:Verified 04/wudata_01.log
07:01:59:WU04:FS04:0xa4:Verified 04/wudata_01.trr
07:01:59:WU04:FS04:0xa4:Verified 04/wudata_01.xtc
07:01:59:WU04:FS04:0xa4:Verified 04/wudata_01.edr
07:02:02:WU04:FS04:0xa4:Completed 87660 out of 250000 steps (35%)
07:02:03:WARNING:WU04:FS04:Detected clock skew (1 mins 09 secs), adjusting time estimates
07:02:24:WU06:FS07:0xa4:Resuming from checkpoint
07:02:24:WU06:FS07:0xa4:Verified 06/wudata_01.log
07:02:24:WU06:FS07:0xa4:Verified 06/wudata_01.trr
07:02:24:WU06:FS07:0xa4:Verified 06/wudata_01.xtc
07:02:24:WU06:FS07:0xa4:Verified 06/wudata_01.edr
07:02:28:WU06:FS07:0xa4:Completed 82245 out of 250000 steps (32%)
07:02:29:WARNING:WU06:FS07:Detected clock skew (1 mins 30 secs), adjusting time estimates
07:02:31:WU02:FS05:0xa4:Resuming from checkpoint
07:02:31:WU02:FS05:0xa4:Verified 02/wudata_01.log
07:02:31:WU02:FS05:0xa4:Verified 02/wudata_01.trr
07:02:31:WU02:FS05:0xa4:Verified 02/wudata_01.xtc
07:02:31:WU02:FS05:0xa4:Verified 02/wudata_01.edr
07:02:35:WU08:FS03:0xa4:Resuming from checkpoint
07:02:35:WU08:FS03:0xa4:Verified 08/wudata_01.log
07:02:35:WU08:FS03:0xa4:Verified 08/wudata_01.trr
07:02:35:WU08:FS03:0xa4:Verified 08/wudata_01.xtc
07:02:35:WU08:FS03:0xa4:Verified 08/wudata_01.edr
07:02:38:WU00:FS01:0xa4:Resuming from checkpoint
07:02:38:WU00:FS01:0xa4:Verified 00/wudata_01.log
07:02:38:WU00:FS01:0xa4:Verified 00/wudata_01.trr
07:02:38:WU00:FS01:0xa4:Verified 00/wudata_01.xtc
07:02:38:WU00:FS01:0xa4:Verified 00/wudata_01.edr
07:02:38:WU02:FS05:0xa4:Completed 87865 out of 250000 steps (35%)
07:02:39:WARNING:WU02:FS05:Detected clock skew (1 mins 35 secs), adjusting time estimates
07:02:41:WU08:FS03:0xa4:Completed 155 out of 250000 steps (0%)
07:02:42:WARNING:WU08:FS03:Detected clock skew (1 mins 40 secs), adjusting time estimates
07:02:42:WU01:FS06:0xa4:Resuming from checkpoint
07:02:42:WU01:FS06:0xa4:Verified 01/wudata_01.log
07:02:42:WU01:FS06:0xa4:Verified 01/wudata_01.trr
07:02:42:WU01:FS06:0xa4:Verified 01/wudata_01.xtc
07:02:42:WU01:FS06:0xa4:Verified 01/wudata_01.edr
07:02:45:WARNING:WU00:FS01:Detected clock skew (1 mins 39 secs), adjusting time estimates
07:02:45:WU00:FS01:0xa4:Completed 197765 out of 250000 steps (79%)
07:02:49:WU01:FS06:0xa4:Completed 155 out of 250000 steps (0%)
07:02:50:WARNING:WU01:FS06:Detected clock skew (1 mins 42 secs), adjusting time estimates
07:03:32:WU05:FS00:0xa7:Completed 52000 out of 80000 steps (65%)
07:06:17:WU05:FS00:0xa7:Completed 52800 out of 80000 steps (66%)
07:09:05:WU05:FS00:0xa7:Completed 53600 out of 80000 steps (67%)
07:11:52:WU05:FS00:0xa7:Completed 54400 out of 80000 steps (68%)
07:14:35:WU05:FS00:0xa7:Completed 55200 out of 80000 steps (69%)
07:17:19:WU05:FS00:0xa7:Completed 56000 out of 80000 steps (70%)
07:20:04:WU05:FS00:0xa7:Completed 56800 out of 80000 steps (71%)
07:22:50:WU05:FS00:0xa7:Completed 57600 out of 80000 steps (72%)
07:25:30:WU05:FS00:0xa7:Completed 58400 out of 80000 steps (73%)
07:28:13:WU05:FS00:0xa7:Completed 59200 out of 80000 steps (74%)
07:30:51:WU05:FS00:0xa7:Completed 60000 out of 80000 steps (75%)
07:33:34:WU05:FS00:0xa7:Completed 60800 out of 80000 steps (76%)
07:36:08:WU05:FS00:0xa7:Completed 61600 out of 80000 steps (77%)
07:37:00:WU06:FS07:0xa4:Completed 82500 out of 250000 steps (33%)
07:38:45:WU05:FS00:0xa7:Completed 62400 out of 80000 steps (78%)
07:41:22:WU05:FS00:0xa7:Completed 63200 out of 80000 steps (79%)
07:43:58:WU05:FS00:0xa7:Completed 64000 out of 80000 steps (80%)
07:46:35:WU05:FS00:0xa7:Completed 64800 out of 80000 steps (81%)
07:49:08:WU05:FS00:0xa7:Completed 65600 out of 80000 steps (82%)
07:51:43:WU05:FS00:0xa7:Completed 66400 out of 80000 steps (83%)
07:54:20:WU05:FS00:0xa7:Completed 67200 out of 80000 steps (84%)
07:57:00:WU05:FS00:0xa7:Completed 68000 out of 80000 steps (85%)
07:59:38:WU05:FS00:0xa7:Completed 68800 out of 80000 steps (86%)
08:02:22:WU05:FS00:0xa7:Completed 69600 out of 80000 steps (87%)
08:05:09:WU05:FS00:0xa7:Completed 70400 out of 80000 steps (88%)
08:07:47:WU05:FS00:0xa7:Completed 71200 out of 80000 steps (89%)
08:10:25:WU05:FS00:0xa7:Completed 72000 out of 80000 steps (90%)
08:13:05:WU05:FS00:0xa7:Completed 72800 out of 80000 steps (91%)
08:15:44:WU05:FS00:0xa7:Completed 73600 out of 80000 steps (92%)
08:18:17:WU05:FS00:0xa7:Completed 74400 out of 80000 steps (93%)
08:20:59:WU05:FS00:0xa7:Completed 75200 out of 80000 steps (94%)
08:23:35:WU05:FS00:0xa7:Completed 76000 out of 80000 steps (95%)
08:26:17:WU05:FS00:0xa7:Completed 76800 out of 80000 steps (96%)
08:28:53:WU05:FS00:0xa7:Completed 77600 out of 80000 steps (97%)
08:31:38:WU05:FS00:0xa7:Completed 78400 out of 80000 steps (98%)
08:34:13:WU05:FS00:0xa7:Completed 79200 out of 80000 steps (99%)
08:34:14:WU03:FS00:Connecting to 171.67.108.45:8080
08:34:14:WU03:FS00:Assigned to work server 171.64.65.41
08:34:14:WU03:FS00:Requesting new work unit for slot 00: RUNNING cpu:4 from 171.64.65.41
08:34:14:WU03:FS00:Connecting to 171.64.65.41:8080
08:34:14:WU03:FS00:Downloading 20.96MiB
08:34:18:WU03:FS00:Download complete
08:34:18:WU03:FS00:Received Unit: id:03 state:DOWNLOAD error:NO_ERROR project:11920 run:251 clone:0 gen:290 core:0xa7 unit:0x00000174ab40412957bff6f9b409156a
08:36:54:WU05:FS00:0xa7:Completed 80000 out of 80000 steps (100%)
08:37:00:WU05:FS00:0xa7:Saving result file ..\logfile_01.txt
08:37:00:WU05:FS00:0xa7:Saving result file frame149.trr
08:37:01:WU05:FS00:0xa7:Saving result file md.log
08:37:01:WU05:FS00:0xa7:Saving result file science.log
08:37:01:WU05:FS00:0xa7:Folding@home Core Shutdown: FINISHED_UNIT
08:37:01:WU05:FS00:FahCore returned: FINISHED_UNIT (100 = 0x64)
08:37:01:WU05:FS00:Sending unit results: id:05 state:SEND error:NO_ERROR project:11920 run:234 clone:3 gen:149 core:0xa7 unit:0x000000beab4041295809cf399694a4e5
08:37:01:WU05:FS00:Uploading 19.74MiB to 171.64.65.41
08:37:01:WU03:FS00:Starting
08:37:01:WU05:FS00:Connecting to 171.64.65.41:8080
08:37:01:WU03:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:/Users/User100/AppData/Roaming/FAHClient/cores/web.stanford.edu/~pande/Win32/AMD64/AVX/Core_a7.fah/FahCore_a7.exe -dir 03 -suffix 01 -version 704 -lifeline 8420 -checkpoint 10 -np 4
08:37:02:WU03:FS00:Started FahCore on PID 4840
08:37:04:WU03:FS00:Core PID:2384
08:37:04:WU03:FS00:FahCore 0xa7 started
08:37:05:WU03:FS00:0xa7:*********************** Log Started 2016-12-09T08:37:04Z ***********************
08:37:05:WU03:FS00:0xa7:************************** Gromacs Folding@home Core ***************************
08:37:05:WU03:FS00:0xa7: Type: 0xa7
08:37:05:WU03:FS00:0xa7: Core: Gromacs
08:37:05:WU03:FS00:0xa7: Website: http://folding.stanford.edu/
08:37:05:WU03:FS00:0xa7: Copyright: (c) 2009-2016 Stanford University
08:37:05:WU03:FS00:0xa7: Author: Joseph Coffland <joseph@cauldrondevelopment.com>
08:37:05:WU03:FS00:0xa7: Args: -dir 03 -suffix 01 -version 704 -lifeline 4840 -checkpoint 10 -np 4
08:37:05:WU03:FS00:0xa7: Config: <none>
08:37:05:WU03:FS00:0xa7:************************************ Build *************************************
08:37:05:WU03:FS00:0xa7: Version: 0.0.11
08:37:05:WU03:FS00:0xa7: Date: Sep 21 2016
08:37:05:WU03:FS00:0xa7: Time: 01:43:48
08:37:05:WU03:FS00:0xa7: Repository: Git
08:37:05:WU03:FS00:0xa7: Revision: 957bd90e68d95ddcf1594dc15ff6c64cc4555146
08:37:05:WU03:FS00:0xa7: Branch: master
08:37:05:WU03:FS00:0xa7: Compiler: GNU 4.2.1 Compatible Clang 3.9.0 (trunk 274080)
08:37:05:WU03:FS00:0xa7: Options: -std=gnu++98 -O3 -funroll-loops -ffast-math -mfpmath=sse
08:37:05:WU03:FS00:0xa7: -fno-unsafe-math-optimizations -msse2 -I/mingw64/include
08:37:05:WU03:FS00:0xa7: -Wno-inconsistent-dllimport -Wno-parentheses-equality
08:37:05:WU03:FS00:0xa7: -Wno-deprecated-register -Wno-unused-local-typedef
08:37:05:WU03:FS00:0xa7: Platform: linux2 4.6.0-1-amd64
08:37:05:WU03:FS00:0xa7: Bits: 64
08:37:05:WU03:FS00:0xa7: Mode: Release
08:37:05:WU03:FS00:0xa7: SIMD: avx_256
08:37:05:WU03:FS00:0xa7:************************************ System ************************************
08:37:05:WU03:FS00:0xa7: CPU: Intel(R) Core(TM) i7-4600U CPU @ 2.10GHz
08:37:05:WU03:FS00:0xa7: CPU ID: GenuineIntel Family 6 Model 69 Stepping 1
08:37:05:WU03:FS00:0xa7: CPUs: 4
08:37:05:WU03:FS00:0xa7: Memory: 7.88GiB
08:37:05:WU03:FS00:0xa7:Free Memory: 3.84GiB
08:37:05:WU03:FS00:0xa7: Threads: WINDOWS_THREADS
08:37:05:WU03:FS00:0xa7: OS Version: 6.2
08:37:05:WU03:FS00:0xa7:Has Battery: true
08:37:05:WU03:FS00:0xa7: On Battery: false
08:37:05:WU03:FS00:0xa7: UTC Offset: -8
08:37:05:WU03:FS00:0xa7: PID: 2384
08:37:05:WU03:FS00:0xa7: CWD: C:\Users\User100\AppData\Roaming\FAHClient\work
08:37:05:WU03:FS00:0xa7: OS: Windows 10 Enterprise
08:37:05:WU03:FS00:0xa7: OS Arch: AMD64
08:37:05:WU03:FS00:0xa7:********************************************************************************
08:37:05:WU03:FS00:0xa7:Project: 11920 (Run 251, Clone 0, Gen 290)
08:37:05:WU03:FS00:0xa7:Unit: 0x00000174ab40412957bff6f9b409156a
08:37:05:WU03:FS00:0xa7:Reading tar file core.xml
08:37:05:WU03:FS00:0xa7:Reading tar file frame290.tpr
08:37:05:WU03:FS00:0xa7:Digital signatures verified
08:37:05:WU03:FS00:0xa7:Calling: mdrun -s frame290.tpr -o frame290.trr -cpt 10 -nt 4
08:37:07:WU03:FS00:0xa7:Steps: first=23200000 total=80000
08:37:09:WU05:FS00:Upload 23.75%
08:37:11:WU03:FS00:0xa7:Completed 1 out of 80000 steps (0%)
08:37:15:WU05:FS00:Upload 49.40%
08:37:21:WU05:FS00:Upload 69.35%
08:37:27:WU05:FS00:Upload 88.67%
08:37:32:WU05:FS00:Upload complete
08:37:32:WU05:FS00:Server responded WORK_ACK (400)
08:37:32:WU05:FS00:Final credit estimate, 1889.00 points
08:37:32:WU05:FS00:Cleaning up
08:40:07:WU03:FS00:0xa7:Completed 800 out of 80000 steps (1%)
08:43:12:WU03:FS00:0xa7:Completed 1600 out of 80000 steps (2%)
08:46:11:WU03:FS00:0xa7:Completed 2400 out of 80000 steps (3%)
08:49:12:WU03:FS00:0xa7:Completed 3200 out of 80000 steps (4%)
Here's another log:
*********************** Log Started 2016-12-09T06:26:26Z ***********************
06:26:26:************************* Folding@home Client *************************
06:26:26: Website: http://folding.stanford.edu/
06:26:26: Copyright: (c) 2009-2014 Stanford University
06:26:26: Author: Joseph Coffland <joseph@cauldrondevelopment.com>
06:26:26: Args: --open-web-control
06:26:26: Config: C:/Users/User100/AppData/Roaming/FAHClient/config.xml
06:26:26:******************************** Build ********************************
06:26:26: Version: 7.4.4
06:26:26: Date: Mar 4 2014
06:26:26: Time: 20:26:54
06:26:26: SVN Rev: 4130
06:26:26: Branch: fah/trunk/client
06:26:26: Compiler: Intel(R) C++ MSVC 1500 mode 1200
06:26:26: Options: /TP /nologo /EHa /Qdiag-disable:4297,4103,1786,279 /Ox -arch:SSE
06:26:26: /QaxSSE2,SSE3,SSSE3,SSE4.1,SSE4.2 /Qopenmp /Qrestrict /MT /Qmkl
06:26:26: Platform: win32 XP
06:26:26: Bits: 32
06:26:26: Mode: Release
06:26:26:******************************* System ********************************
06:26:26: CPU: Intel(R) Core(TM) i7-4600U CPU @ 2.10GHz
06:26:26: CPU ID: GenuineIntel Family 6 Model 69 Stepping 1
06:26:26: CPUs: 4
06:26:26: Memory: 7.88GiB
06:26:26: Free Memory: 3.54GiB
06:26:26: Threads: WINDOWS_THREADS
06:26:26: OS Version: 6.2
06:26:26: Has Battery: true
06:26:26: On Battery: false
06:26:26: UTC Offset: -8
06:26:26: PID: 1704
06:26:26: CWD: C:/Users/User100/AppData/Roaming/FAHClient
06:26:26: OS: Windows 10 Enterprise
06:26:26: OS Arch: AMD64
06:26:26: GPUs: 0
06:26:26: CUDA: Not detected
06:26:26:Win32 Service: false
06:26:26:***********************************************************************
06:26:26:<config>
06:26:26: <!-- Folding Core -->
06:26:26: <checkpoint v='10'/>
06:26:26: <core-priority v='low'/>
06:26:26:
06:26:26: <!-- Network -->
06:26:26: <proxy v=':8080'/>
06:26:26:
06:26:26: <!-- Slot Control -->
06:26:26: <power v='full'/>
06:26:26:
06:26:26: <!-- User Information -->
06:26:26: <passkey v='********************************'/>
06:26:26: <team v='111065'/>
06:26:26: <user v='Sem6000'/>
06:26:26:
06:26:26: <!-- Folding Slots -->
06:26:26: <slot id='0' type='CPU'>
06:26:26: <cpus v='4'/>
06:26:26: </slot>
06:26:26: <slot id='1' type='CPU'>
06:26:26: </slot>
06:26:26: <slot id='2' type='CPU'>
06:26:26: </slot>
06:26:26: <slot id='3' type='CPU'>
06:26:26: </slot>
06:26:26: <slot id='4' type='CPU'>
06:26:26: </slot>
06:26:26: <slot id='5' type='CPU'>
06:26:26: </slot>
06:26:26: <slot id='6' type='CPU'>
06:26:26: </slot>
06:26:26: <slot id='7' type='CPU'>
06:26:26: </slot>
06:26:26:</config>
06:26:26:Trying to access database...
06:26:26:Successfully acquired database lock
06:26:26:Enabled folding slot 00: READY cpu:4
06:26:26:Enabled folding slot 01: READY cpu:4
06:26:26:Enabled folding slot 02: READY cpu:4
06:26:26:Enabled folding slot 03: READY cpu:4
06:26:26:Enabled folding slot 04: READY cpu:4
06:26:26:Enabled folding slot 05: READY cpu:4
06:26:26:Enabled folding slot 06: READY cpu:4
06:26:26:Enabled folding slot 07: READY cpu:4
06:26:26:WARNING:WU03:Missing data files, dumping
06:26:26:WARNING:WU09:Missing data files, dumping
06:26:26:WU07:FS02:Starting
06:26:26:WU07:FS02:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:/Users/User100/AppData/Roaming/FAHClient/cores/web.stanford.edu/~pande/Win32/AMD64/Core_a4.fah/FahCore_a4.exe -dir 07 -suffix 01 -version 704 -lifeline 1704 -checkpoint 10 -np 4
06:26:27:WU07:FS02:Started FahCore on PID 7332
06:26:28:WU07:FS02:Core PID:9844
06:26:28:WU07:FS02:FahCore 0xa4 started
06:26:28:WU02:FS05:Starting
06:26:28:WU02:FS05:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:/Users/User100/AppData/Roaming/FAHClient/cores/web.stanford.edu/~pande/Win32/AMD64/Core_a4.fah/FahCore_a4.exe -dir 02 -suffix 01 -version 704 -lifeline 1704 -checkpoint 10 -np 4
06:26:29:WU07:FS02:0xa4:
06:26:29:WU07:FS02:0xa4:*------------------------------*
06:26:29:WU07:FS02:0xa4:Folding@Home Gromacs GB Core
06:26:29:WU07:FS02:0xa4:Version 2.27 (Dec. 15, 2010)
06:26:29:WU07:FS02:0xa4:Preparing to commence simulation
06:26:29:WU07:FS02:0xa4:- Looking at optimizations...
06:26:29:WU07:FS02:0xa4:- Created dyn
06:26:29:WU07:FS02:0xa4:- Files status OK
06:26:29:WU07:FS02:0xa4:- Expanded 825903 -> 1402860 (decompressed 169.8 percent)
06:26:29:WU07:FS02:0xa4:Called DecompressByteArray: compressed_data_size=825903 data_size=1402860, decompressed_data_size=1402860 diff=0
06:26:29:WU07:FS02:0xa4:- Digital signature verified
06:26:29:WU07:FS02:0xa4:Project: 9038 (Run 815, Clone 2, Gen 400)
06:26:29:WU07:FS02:0xa4:Assembly optimizations on if available.
06:26:29:WU07:FS02:0xa4:Entering M.D.
06:26:30:WU02:FS05:Started FahCore on PID 588
06:26:31:WU02:FS05:Core PID:116
06:26:31:WU02:FS05:FahCore 0xa4 started
06:26:31:WU00:FS01:Starting
06:26:31:WU00:FS01:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:/Users/User100/AppData/Roaming/FAHClient/cores/web.stanford.edu/~pande/Win32/AMD64/Core_a4.fah/FahCore_a4.exe -dir 00 -suffix 01 -version 704 -lifeline 1704 -checkpoint 10 -np 4
06:26:31:WU02:FS05:0xa4:
06:26:31:WU02:FS05:0xa4:*------------------------------*
06:26:31:WU02:FS05:0xa4:Folding@Home Gromacs GB Core
06:26:31:WU02:FS05:0xa4:Version 2.27 (Dec. 15, 2010)
06:26:31:WU02:FS05:0xa4:Preparing to commence simulation
06:26:31:WU02:FS05:0xa4:- Looking at optimizations...
06:26:31:WU02:FS05:0xa4:- Files status OK
06:26:31:WU02:FS05:0xa4:- Expanded 825025 -> 1401332 (decompressed 169.8 percent)
06:26:31:WU02:FS05:0xa4:Called DecompressByteArray: compressed_data_size=825025 data_size=1401332, decompressed_data_size=1401332 diff=0
06:26:31:WU02:FS05:0xa4:- Digital signature verified
06:26:31:WU02:FS05:0xa4:Project: 9033 (Run 82, Clone 0, Gen 473)
06:26:31:WU02:FS05:0xa4:Assembly optimizations on if available.
06:26:31:WU02:FS05:0xa4:Entering M.D.
06:26:32:WU00:FS01:Started FahCore on PID 10168
06:26:34:WU00:FS01:Core PID:8436
06:26:34:WU00:FS01:FahCore 0xa4 started
06:26:34:WU04:FS04:Starting
06:26:34:WU04:FS04:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:/Users/User100/AppData/Roaming/FAHClient/cores/web.stanford.edu/~pande/Win32/AMD64/Core_a4.fah/FahCore_a4.exe -dir 04 -suffix 01 -version 704 -lifeline 1704 -checkpoint 10 -np 4
06:26:34:WU00:FS01:0xa4:
06:26:34:WU00:FS01:0xa4:*------------------------------*
06:26:34:WU00:FS01:0xa4:Folding@Home Gromacs GB Core
06:26:34:WU00:FS01:0xa4:Version 2.27 (Dec. 15, 2010)
06:26:34:WU00:FS01:0xa4:Preparing to commence simulation
06:26:34:WU00:FS01:0xa4:- Looking at optimizations...
06:26:34:WU00:FS01:0xa4:- Files status OK
06:26:34:WU00:FS01:0xa4:- Expanded 825862 -> 1403132 (decompressed 169.8 percent)
06:26:34:WU00:FS01:0xa4:Called DecompressByteArray: compressed_data_size=825862 data_size=1403132, decompressed_data_size=1403132 diff=0
06:26:34:WU00:FS01:0xa4:- Digital signature verified
06:26:34:WU00:FS01:0xa4:Project: 9036 (Run 481, Clone 1, Gen 314)
06:26:34:WU00:FS01:0xa4:Assembly optimizations on if available.
06:26:34:WU00:FS01:0xa4:Entering M.D.
06:26:35:WU07:FS02:0xa4:Mapping NT from 4 to 4
06:26:35:WU04:FS04:Started FahCore on PID 3372
06:26:35:WU07:FS02:0xa4:Completed 0 out of 250000 steps (0%)
06:26:36:WU04:FS04:Core PID:8676
06:26:36:WU04:FS04:FahCore 0xa4 started
06:26:36:WU05:FS00:Starting
06:26:36:WU05:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:/Users/User100/AppData/Roaming/FAHClient/cores/web.stanford.edu/~pande/Win32/AMD64/AVX/Core_a7.fah/FahCore_a7.exe -dir 05 -suffix 01 -version 704 -lifeline 1704 -checkpoint 10 -np 4
06:26:37:WU04:FS04:0xa4:
06:26:37:WU04:FS04:0xa4:*------------------------------*
06:26:37:WU04:FS04:0xa4:Folding@Home Gromacs GB Core
06:26:37:WU04:FS04:0xa4:Version 2.27 (Dec. 15, 2010)
06:26:37:WU04:FS04:0xa4:Preparing to commence simulation
06:26:37:WU04:FS04:0xa4:- Looking at optimizations...
06:26:37:WU04:FS04:0xa4:- Files status OK
06:26:37:WU04:FS04:0xa4:- Expanded 825893 -> 1401112 (decompressed 169.6 percent)
06:26:37:WU04:FS04:0xa4:Called DecompressByteArray: compressed_data_size=825893 data_size=1401112, decompressed_data_size=1401112 diff=0
06:26:37:WU04:FS04:0xa4:- Digital signature verified
06:26:37:WU04:FS04:0xa4:Project: 9034 (Run 386, Clone 3, Gen 342)
06:26:37:WU04:FS04:0xa4:Assembly optimizations on if available.
06:26:37:WU04:FS04:0xa4:Entering M.D.
06:26:37:WU02:FS05:0xa4:Using Gromacs checkpoints
06:26:37:WU05:FS00:Started FahCore on PID 9424
06:26:37:WU02:FS05:0xa4:Mapping NT from 4 to 4
06:26:38:WU02:FS05:0xa4:Resuming from checkpoint
06:26:38:WU02:FS05:0xa4:Verified 02/wudata_01.log
06:26:38:WU02:FS05:0xa4:Verified 02/wudata_01.trr
06:26:38:WU02:FS05:0xa4:Verified 02/wudata_01.xtc
06:26:38:WU02:FS05:0xa4:Verified 02/wudata_01.edr
06:26:38:WU02:FS05:0xa4:Completed 87710 out of 250000 steps (35%)
06:26:39:WU05:FS00:Core PID:8568
06:26:39:WU05:FS00:FahCore 0xa7 started
06:26:39:WU03:FS03:Cleaning up
06:26:39:WU06:FS07:Starting
06:26:39:WU06:FS07:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:/Users/User100/AppData/Roaming/FAHClient/cores/web.stanford.edu/~pande/Win32/AMD64/Core_a4.fah/FahCore_a4.exe -dir 06 -suffix 01 -version 704 -lifeline 1704 -checkpoint 10 -np 4
06:26:39:WU05:FS00:0xa7:*********************** Log Started 2016-12-09T06:26:39Z ***********************
06:26:39:WU05:FS00:0xa7:************************** Gromacs Folding@home Core ***************************
06:26:39:WU05:FS00:0xa7: Type: 0xa7
06:26:39:WU05:FS00:0xa7: Core: Gromacs
06:26:39:WU05:FS00:0xa7: Website: http://folding.stanford.edu/
06:26:39:WU05:FS00:0xa7: Copyright: (c) 2009-2016 Stanford University
06:26:39:WU05:FS00:0xa7: Author: Joseph Coffland <joseph@cauldrondevelopment.com>
06:26:39:WU05:FS00:0xa7: Args: -dir 05 -suffix 01 -version 704 -lifeline 9424 -checkpoint 10 -np 4
06:26:39:WU05:FS00:0xa7: Config: <none>
06:26:39:WU05:FS00:0xa7:************************************ Build *************************************
06:26:39:WU05:FS00:0xa7: Version: 0.0.11
06:26:39:WU05:FS00:0xa7: Date: Sep 21 2016
06:26:39:WU05:FS00:0xa7: Time: 01:43:48
06:26:39:WU05:FS00:0xa7: Repository: Git
06:26:39:WU05:FS00:0xa7: Revision: 957bd90e68d95ddcf1594dc15ff6c64cc4555146
06:26:39:WU05:FS00:0xa7: Branch: master
06:26:39:WU05:FS00:0xa7: Compiler: GNU 4.2.1 Compatible Clang 3.9.0 (trunk 274080)
06:26:39:WU05:FS00:0xa7: Options: -std=gnu++98 -O3 -funroll-loops -ffast-math -mfpmath=sse
06:26:39:WU05:FS00:0xa7: -fno-unsafe-math-optimizations -msse2 -I/mingw64/include
06:26:39:WU05:FS00:0xa7: -Wno-inconsistent-dllimport -Wno-parentheses-equality
06:26:39:WU05:FS00:0xa7: -Wno-deprecated-register -Wno-unused-local-typedef
06:26:39:WU05:FS00:0xa7: Platform: linux2 4.6.0-1-amd64
06:26:39:WU05:FS00:0xa7: Bits: 64
06:26:39:WU05:FS00:0xa7: Mode: Release
06:26:39:WU05:FS00:0xa7: SIMD: avx_256
06:26:39:WU05:FS00:0xa7:************************************ System ************************************
06:26:39:WU05:FS00:0xa7: CPU: Intel(R) Core(TM) i7-4600U CPU @ 2.10GHz
06:26:39:WU05:FS00:0xa7: CPU ID: GenuineIntel Family 6 Model 69 Stepping 1
06:26:40:WU05:FS00:0xa7: CPUs: 4
06:26:40:WU05:FS00:0xa7: Memory: 7.88GiB
06:26:40:WU05:FS00:0xa7:Free Memory: 3.40GiB
06:26:40:WU05:FS00:0xa7: Threads: WINDOWS_THREADS
06:26:40:WU05:FS00:0xa7: OS Version: 6.2
06:26:40:WU05:FS00:0xa7:Has Battery: true
06:26:40:WU05:FS00:0xa7: On Battery: false
06:26:40:WU05:FS00:0xa7: UTC Offset: -8
06:26:40:WU05:FS00:0xa7: PID: 8568
06:26:40:WU05:FS00:0xa7: CWD: C:\Users\User100\AppData\Roaming\FAHClient\work
06:26:40:WU05:FS00:0xa7: OS: Windows 10 Enterprise
06:26:40:WU05:FS00:0xa7: OS Arch: AMD64
06:26:40:WU05:FS00:0xa7:********************************************************************************
06:26:40:WU05:FS00:0xa7:Project: 11920 (Run 234, Clone 3, Gen 149)
06:26:40:WU05:FS00:0xa7:Unit: 0x000000beab4041295809cf399694a4e5
06:26:40:WU05:FS00:0xa7:Digital signatures verified
06:26:40:WU05:FS00:0xa7:Calling: mdrun -s frame149.tpr -o frame149.trr -cpi state.cpt -cpt 10 -nt 4
06:26:40:WU00:FS01:0xa4:Using Gromacs checkpoints
06:26:40:WU00:FS01:0xa4:Mapping NT from 4 to 4
06:26:41:WU06:FS07:Started FahCore on PID 4512
06:26:41:WU05:FS00:0xa7:Steps: first=11920000 total=80000
06:26:41:WU00:FS01:0xa4:Resuming from checkpoint
06:26:41:WU00:FS01:0xa4:Verified 00/wudata_01.log
06:26:41:WU00:FS01:0xa4:Verified 00/wudata_01.trr
06:26:41:WU00:FS01:0xa4:Verified 00/wudata_01.xtc
06:26:41:WU00:FS01:0xa4:Verified 00/wudata_01.edr
06:26:42:WU00:FS01:0xa4:Completed 197610 out of 250000 steps (79%)
06:26:42:WU06:FS07:Core PID:10956
06:26:42:WU06:FS07:FahCore 0xa4 started
06:26:42:WU01:FS06:Starting
06:26:42:WU01:FS06:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:/Users/User100/AppData/Roaming/FAHClient/cores/web.stanford.edu/~pande/Win32/AMD64/Core_a4.fah/FahCore_a4.exe -dir 01 -suffix 01 -version 704 -lifeline 1704 -checkpoint 10 -np 4
06:26:42:WU04:FS04:0xa4:Using Gromacs checkpoints
06:26:42:WU06:FS07:0xa4:
06:26:42:WU06:FS07:0xa4:*------------------------------*
06:26:42:WU06:FS07:0xa4:Folding@Home Gromacs GB Core
06:26:42:WU06:FS07:0xa4:Version 2.27 (Dec. 15, 2010)
06:26:42:WU06:FS07:0xa4:Preparing to commence simulation
06:26:42:WU06:FS07:0xa4:- Looking at optimizations...
06:26:42:WU06:FS07:0xa4:- Files status OK
06:26:42:WU06:FS07:0xa4:- Expanded 825800 -> 1401112 (decompressed 169.6 percent)
06:26:42:WU06:FS07:0xa4:Called DecompressByteArray: compressed_data_size=825800 data_size=1401112, decompressed_data_size=1401112 diff=0
06:26:42:WU06:FS07:0xa4:- Digital signature verified
06:26:42:WU06:FS07:0xa4:Project: 9034 (Run 181, Clone 1, Gen 434)
06:26:42:WU06:FS07:0xa4:Assembly optimizations on if available.
06:26:42:WU06:FS07:0xa4:Entering M.D.
06:26:42:WU04:FS04:0xa4:Mapping NT from 4 to 4
06:26:43:WU01:FS06:Started FahCore on PID 292
06:26:44:WU01:FS06:Core PID:200
06:26:44:WU01:FS06:FahCore 0xa4 started
06:26:44:WU08:FS03:Starting
06:26:44:WU08:FS03:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:/Users/User100/AppData/Roaming/FAHClient/cores/web.stanford.edu/~pande/Win32/AMD64/Core_a4.fah/FahCore_a4.exe -dir 08 -suffix 01 -version 704 -lifeline 1704 -checkpoint 10 -np 4
06:26:44:WU01:FS06:0xa4:
06:26:44:WU01:FS06:0xa4:*------------------------------*
06:26:44:WU01:FS06:0xa4:Folding@Home Gromacs GB Core
06:26:44:WU01:FS06:0xa4:Version 2.27 (Dec. 15, 2010)
06:26:44:WU01:FS06:0xa4:Preparing to commence simulation
06:26:44:WU01:FS06:0xa4:- Looking at optimizations...
06:26:44:WU01:FS06:0xa4:- Files status OK
06:26:44:WU01:FS06:0xa4:- Expanded 825153 -> 1398040 (decompressed 169.4 percent)
06:26:44:WU01:FS06:0xa4:Called DecompressByteArray: compressed_data_size=825153 data_size=1398040, decompressed_data_size=1398040 diff=0
06:26:44:WU01:FS06:0xa4:- Digital signature verified
06:26:44:WU01:FS06:0xa4:Project: 9039 (Run 900, Clone 1, Gen 361)
06:26:45:WU01:FS06:0xa4:Assembly optimizations on if available.
06:26:45:WU01:FS06:0xa4:Entering M.D.
06:26:45:WU05:FS00:0xa7:Completed 42017 out of 80000 steps (52%)
06:26:45:WU08:FS03:Started FahCore on PID 10488
06:26:47:WU08:FS03:Core PID:9252
06:26:47:WU08:FS03:FahCore 0xa4 started
06:26:47:WU09:FS02:Cleaning up
06:26:48:WU08:FS03:0xa4:
06:26:48:WU08:FS03:0xa4:*------------------------------*
06:26:48:WU08:FS03:0xa4:Folding@Home Gromacs GB Core
06:26:48:WU08:FS03:0xa4:Version 2.27 (Dec. 15, 2010)
06:26:48:WU08:FS03:0xa4:Preparing to commence simulation
06:26:48:WU08:FS03:0xa4:- Looking at optimizations...
06:26:48:WU08:FS03:0xa4:- Created dyn
06:26:48:WU08:FS03:0xa4:- Files status OK
06:26:51:WU06:FS07:0xa4:Using Gromacs checkpoints
06:26:53:WU01:FS06:0xa4:Using Gromacs checkpoints
06:26:54:WU06:FS07:0xa4:Mapping NT from 4 to 4
06:26:56:WU01:FS06:0xa4:Mapping NT from 4 to 4
06:27:00:WU08:FS03:0xa4:- Expanded 825884 -> 1403132 (decompressed 169.8 percent)
06:27:00:WU08:FS03:0xa4:Called DecompressByteArray: compressed_data_size=825884 data_size=1403132, decompressed_data_size=1403132 diff=0
06:27:02:WU08:FS03:0xa4:- Digital signature verified
06:27:02:WU08:FS03:0xa4:Project: 9036 (Run 563, Clone 2, Gen 259)
06:27:03:WU08:FS03:0xa4:Assembly optimizations on if available.
06:27:03:WU08:FS03:0xa4:Entering M.D.
06:27:09:WU08:FS03:0xa4:Mapping NT from 4 to 4
06:27:49:FS00:Shutting core down
06:27:49:FS01:Shutting core down
06:27:49:FS02:Shutting core down
06:27:49:FS03:Shutting core down
06:27:49:FS04:Shutting core down
06:27:49:FS05:Shutting core down
06:27:49:FS06:Shutting core down
06:27:49:FS07:Shutting core down
06:27:49:WU05:FS00:0xa7:WARNING:Console control signal 1 on PID 8568
06:27:49:WU05:FS00:0xa7:Exiting, please wait. . .
06:27:51:WU02:FS05:0xa4:Client no longer detected. Shutting down core
06:27:51:WU02:FS05:0xa4:Folding@home Core Shutdown: CLIENT_DIED
06:27:53:WU04:FS04:0xa4:Resuming from checkpoint
06:27:53:WU04:FS04:0xa4:Verified 04/wudata_01.log
06:27:53:WU04:FS04:0xa4:Verified 04/wudata_01.trr
06:27:53:WU04:FS04:0xa4:Verified 04/wudata_01.xtc
06:27:53:WU04:FS04:0xa4:Verified 04/wudata_01.edr
06:27:53:WU04:FS04:0xa4:Completed 87490 out of 250000 steps (34%)
06:27:53:WU01:FS06:0xa4:Client no longer detected. Shutting down core
06:27:53:WU01:FS06:0xa4:Folding@home Core Shutdown: CLIENT_DIED
06:27:54:WU08:FS03:0xa4:Completed 0 out of 250000 steps (0%)
06:27:55:WU04:FS04:0xa4:Completed 87500 out of 250000 steps (35%)
06:27:56:WU04:FS04:0xa4:Client no longer detected. Shutting down core
06:27:56:WU04:FS04:0xa4:Folding@home Core Shutdown: CLIENT_DIED
06:27:57:Clean exit
Re: Project 9039 goes to 99.99% with 14.00 seconds left
And here's a google drive link to get all the logs if you think you need more: https://drive.google.com/file/d/0B312za ... sp=sharing
The log says you have 4 CPUs each with 2 Cores and 4 threads. Is this correct? Why do you have then 8 cpu slots instead of 4 cpu slots (with 4 threads each)?
Maybe this work unit is bad? Project: 9039 (Run 900, Clone 1, Gen 361)
Actually what the log is showing is that you have a single i7-4600U CPU. That is a dual-core i7 with HT for 4 threads. Somewhere along the line you have misunderstood or not followed installation and setup instructions for the client, and by setting up 8 slots have greatly overcommitted your CPU. Your client should have just one CPU slot for up to 4 threads.
As for Project: 9039 (Run 900, Clone 1, Gen 361), I could not follow it enough in the logs to see what happened with it. But so far it has not had any reports in the database for completion or being turned in as failed.
To recover from this improper setup my recommendation would be to pause all but one folding slot and set that to Finish. Once it has completed its WU, delete the slot and enable one of the remaining slots to Finish its WU. Repeat until just one folding slot remains.
