Hi folks
I was displaying my FAH stats on my website and decided to enhance the code a little and release it.
The plugin makes it easy to show your folding contributions on a WordPress website. Check it out at the official WordPress plugin repository at https://wordpress.org/plugins/phoenix-f ... ome-stats/. You simply enter your F@H username or team ID and it outputs a HTML table which retrieves data from the Folding API. The features are not earth shattering but since over a quarter of *all* websites are WordPress sites, I thought someone else might find it useful and released it.
You can see an example of it in action at https://www.phoenixwebdev.com.au/displa ... ss-plugin/. I've set the data to retrieve no more often than every 3 hours, so it shouldn't break any servers.
I'm keen to hear any feedback and suggestions for features.
Just published a WordPress plugin to display FAH stats
James_Jones
Re: Just published a WordPress plugin to display FAH stats
I edited your post to allow links. It'll be easier to show your work.
Thanks for your contribution
