Credits not awarded
Tremac831
Credits not awarded
Post by Tremac831 »
Hello,
I ran WU 9212 I believe for quite some time. but the credits have not been awarded. below is the log from my client. would an admin be able to assist me in deducing what may have gone wrong?
Appreciate the help.
19:12:07:WU00:FS01:0x21:Saving result file logfile_01.txt
19:12:07:WU00:FS01:0x21:Saving result file checkpointState.xml
19:12:07:WU00:FS01:0x21:Saving result file checkpt.crc
19:12:07:WU00:FS01:0x21:Saving result file log.txt
19:12:07:WU00:FS01:0x21:Saving result file positions.xtc
19:12:07:WU00:FS01:0x21:Folding@home Core Shutdown: FINISHED_UNIT
19:12:07:WU00:FS01:FahCore returned: FINISHED_UNIT (100 = 0x64)
19:12:07:WU00:FS01:Sending unit results: id:00 state:SEND error:NO_ERROR project:9212 run:46 clone:28 gen:6 core:0x21 unit:0x00000014ab436c685796c10bc2f43b75
19:12:07:WU00:FS01:Uploading 37.95MiB to 171.67.108.104
19:12:07:WU00:FS01:Connecting to 171.67.108.104:8080
19:12:08:WU01:FS01:Starting
19:12:08:WU01:FS01:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:/Users/Trevor/AppData/Roaming/FAHClient/cores/web.stanford.edu/~pande/Win32/AMD64/NVIDIA/Fermi/Core_21.fah/FahCore_21.exe -dir 01 -suffix 01 -version 704 -lifeline 6988 -checkpoint 15 -gpu 0 -gpu-vendor nvidia
19:12:08:WU01:FS01:Started FahCore on PID 2548
19:12:08:Started thread 24 on PID 6988
19:12:08:WU01:FS01:Core PID:7000
19:12:08:WU01:FS01:FahCore 0x21 started
19:12:08:WU01:FS01:0x21:*********************** Log Started 2016-11-09T19:12:08Z ***********************
19:12:08:WU01:FS01:0x21:Project: 11710 (Run 1, Clone 28, Gen 8)
19:12:08:WU01:FS01:0x21:Unit: 0x0000000b8ca304e75814df363ca33664
19:12:08:WU01:FS01:0x21:CPU: 0x00000000000000000000000000000000
19:12:08:WU01:FS01:0x21:Machine: 1
19:12:08:WU01:FS01:0x21:Reading tar file core.xml
19:12:08:WU01:FS01:0x21:Reading tar file integrator.xml
19:12:08:WU01:FS01:0x21:Reading tar file state.xml
19:12:08:WU01:FS01:0x21:Reading tar file system.xml
19:12:08:WU01:FS01:0x21:Digital signatures verified
19:12:08:WU01:FS01:0x21:Folding@home GPU Core21 Folding@home Core
19:12:08:WU01:FS01:0x21:Version 0.0.17
19:12:12:WU01:FS01:0x21:Temperature control disabled. Requirements: single Nvidia GPU, tmax must be < 110 and twait >= 900
19:12:13:WU00:FS01:Upload 17.13%
19:12:19:WU00:FS01:Upload 38.37%
19:12:25:WU00:FS01:Upload 59.95%
19:12:31:WU00:FS01:Upload 81.03%
19:12:36:WU00:FS01:Upload complete
19:12:36:WU00:FS01:Server responded WORK_ACK (400)
19:12:36:WU00:FS01:Final credit estimate, 166527.00 points
19:12:36:WU00:FS01:Cleaning up
ChristianVirtual
Re: Credits not awarded
Post by ChristianVirtual »
Welcome Tremac831,
stat server is not doing well ... viewtopic.php?f=24&t=29366
Happen sometimes; but in most cases it is not a big issue as your points will be credited once the stat server is back.
Hi Tremac831 (team 54196),
Your WU (P9212 R46 C28 G6) was added to the stats database on 2016-11-09 12:08:42 for 166544 points of credit.
As I recall from looking up your stats on EOC, this WU had already shown up for you before the stats server issues, note the difference between the estimated and actual points award.
bollix47
Post by bollix47 »
kakao shows the actual update whereas EOC has it combined with a couple of other WUs:
http://www.kakaostats.net/donor-log?donor=1643370
