Core 21 doesn't exist. [for pre-Fermi]
qwertylex
Post by qwertylex »
There is apparently no G80 directory.
https://folding.stanford.edu/bugs/12f62673879b5dd4646d13a3787d280e7a29411a/20161108-68bbb13c.html
********************* Log Started 2016-11-09T01:40:08Z ***********************
01:40:08:************************* Folding@home Client *************************
01:40:08: Website: http://folding.stanford.edu/
01:40:08: Copyright: (c) 2009-2014 Stanford University
01:40:08: Author: Joseph Coffland <joseph@cauldrondevelopment.com>
01:40:08: Args: --config /opt/fah/config.xml --exec-directory=/opt/fah
01:40:08: --data-directory=/opt/fah
01:40:08: Config: /opt/fah/config.xml
01:40:08:******************************** Build ********************************
01:40:08: Version: 7.4.4
01:40:08: Date: Mar 4 2014
01:40:08: Time: 12:02:38
01:40:08: SVN Rev: 4130
01:40:08: Branch: fah/trunk/client
01:40:08: Compiler: GNU 4.4.7
01:40:08: Options: -std=gnu++98 -O3 -funroll-loops -mfpmath=sse -ffast-math
01:40:08: -fno-unsafe-math-optimizations -msse2
01:40:08: Platform: linux2 3.2.0-1-amd64
01:40:08: Bits: 64
01:40:08: Mode: Release
01:40:08:******************************* System ********************************
01:40:08: CPU: Intel(R) Core(TM) i7 CPU Q 740 @ 1.73GHz
01:40:08: CPU ID: GenuineIntel Family 6 Model 30 Stepping 5
01:40:08: CPUs: 4
01:40:08: Memory: 7.74GiB
01:40:08:Free Memory: 2.94GiB
01:40:08: Threads: POSIX_THREADS
01:40:08: OS Version: 4.8
01:40:08:Has Battery: true
01:40:08: On Battery: false
01:40:08: UTC Offset: -5
01:40:08: PID: 24162
01:40:08: CWD: /opt/fah
01:40:08: OS: Linux 4.8.6-1-ARCH x86_64
01:40:08: OS Arch: AMD64
01:40:08: GPUs: 1
01:40:08: GPU 0: NVIDIA:0 GT215 [Quadro FX 1800M]
01:40:08: CUDA: 1.2
01:40:08:CUDA Driver: 6050
01:40:08:***********************************************************************
01:40:08:<config>
01:40:08: <!-- Slot Control -->
01:40:08: <power v='FULL'/>
01:40:08:
01:40:08: <!-- User Information -->
01:40:08: <passkey v='********************************'/>
01:40:08: <user v='Qwertylex'/>
01:40:08:
01:40:08: <!-- Folding Slots -->
01:40:08: <slot id='0' type='CPU'/>
01:40:08: <slot id='1' type='GPU'/>
01:40:08:</config>
01:40:08:Trying to access database...
01:40:08:Successfully acquired database lock
01:40:08:Enabled folding slot 00: READY cpu:3
01:40:08:Enabled folding slot 01: READY gpu:0:GT215 [Quadro FX 1800M]
01:40:08:WU01:FS00:Starting
01:40:08:WARNING:WU01:FS00:Changed SMP threads from 4 to 3 this can cause some work units to fail
01:40:08:WU01:FS00:Running FahCore: /opt/fah/FAHCoreWrapper /opt/fah/cores/web.stanford.edu/~pande/Linux/AMD64/Core_a4.fah/FahCore_a4 -dir 01 -suffix 01 -version 704 -lifeline 24162 -checkpoint 15 -np 3
01:40:08:WU01:FS00:Started FahCore on PID 24171
01:40:08:WU01:FS00:Core PID:24175
01:40:08:WU01:FS00:FahCore 0xa4 started
01:40:08:WU00:FS01:Downloading core from http://web.stanford.edu/~pande/Linux/AMD64/NVIDIA/G80/Core_21.fah
01:40:08:WU00:FS01:Connecting to web.stanford.edu:80
01:40:08:WU01:FS00:0xa4:
01:40:08:WU01:FS00:0xa4:*------------------------------*
01:40:08:WU01:FS00:0xa4:Folding@Home Gromacs GB Core
01:40:08:WU01:FS00:0xa4:Version 2.27 (Dec. 15, 2010)
01:40:08:WU01:FS00:0xa4:Preparing to commence simulation
01:40:08:WU01:FS00:0xa4:- Looking at optimizations...
01:40:08:WU01:FS00:0xa4:- Files status OK
01:40:08:WU01:FS00:0xa4:- Expanded 825073 -> 1398040 (decompressed 169.4 percent)
01:40:08:WU01:FS00:0xa4:Called DecompressByteArray: compressed_data_size=825073 data_size=1398040, decompressed_data_size=1398040 diff=0
01:40:08:WU01:FS00:0xa4:- Digital signature verified
01:40:08:WU01:FS00:0xa4:Project: 9039 (Run 196, Clone 5, Gen 107)
01:40:08:WU01:FS00:0xa4:Assembly optimizations on if available.
01:40:08:WU01:FS00:0xa4:Entering M.D.
01:40:09:ERROR:WU00:FS01:Exception: Failed to access core package.
01:40:14:WU01:FS00:0xa4:Using Gromacs checkpoints
01:40:15:WU01:FS00:0xa4:Resuming from checkpoint
01:40:15:WU01:FS00:0xa4:Verified 01/wudata_01.log
01:40:15:WU01:FS00:0xa4:Verified 01/wudata_01.trr
01:40:15:WU01:FS00:0xa4:Verified 01/wudata_01.xtc
01:40:15:WU01:FS00:0xa4:Verified 01/wudata_01.edr
01:40:15:WU01:FS00:0xa4:Completed 52020 out of 250000 steps (20%)
01:40:51:5:127.0.0.1:New Web connection
01:41:08:WU01:FS00:0xa4:Completed 52500 out of 250000 steps (21%)
01:41:08:WU00:FS01:Downloading core from http://web.stanford.edu/~pande/Linux/AMD64/NVIDIA/G80/Core_21.fah
01:41:08:WU00:FS01:Connecting to web.stanford.edu:80
01:41:09:ERROR:WU00:FS01:Exception: Failed to access core package.
01:42:46:WU00:FS01:Downloading core from http://web.stanford.edu/~pande/Linux/AMD64/NVIDIA/G80/Core_21.fah
01:42:46:WU00:FS01:Connecting to web.stanford.edu:80
01:42:46:ERROR:WU00:FS01:Exception: Failed to access core package.
01:45:23:WU00:FS01:Downloading core from http://web.stanford.edu/~pande/Linux/AMD64/NVIDIA/G80/Core_21.fah
01:45:23:WU00:FS01:Connecting to web.stanford.edu:80
01:45:23:ERROR:WU00:FS01:Exception: Failed to access core package.
01:46:05:WU01:FS00:0xa4:Completed 55000 out of 250000 steps (22%)
Re: Core 21 doesn't exist.
Thank you for your report. Your system should not have been assigned any Core_21 WU, the Tesla based Quadro FX card is incapable of processing it. In addition, the GPU has recently been completely deprecated for folding, work on projects that did utilize pre-Fermi based GPU's ran out several months ago and it was determined that no additional processing for those projects was needed. That was announced in the F@H Blog.
I will bring this to the attention of the appropriate persons. In the meantime you can just remove the GPU slot for folding, that will dump the WU that was downloaded and should end the attempt to download a non-existent folding core. There is no GPU work available for your GPU and what was available in the past for it did not run on Linux anyways.
P.S. The Core_21 WU apparently was downloaded prior to the start of this log, could you post the project WU information so I can notify the person who manages the server which assigned it.
qwertylex
Re: Core 21 doesn't exist. [for pre-Fermi]
Post by qwertylex »
*********************** Log Started 2016-11-09T01:26:25Z ***********************
01:26:25:************************* Folding@home Client *************************
01:26:25:    Website: http://folding.stanford.edu/
01:26:25:  Copyright: (c) 2009-2014 Stanford University
01:26:25:     Author: Joseph Coffland <joseph@cauldrondevelopment.com>
01:26:25:       Args: --config /opt/fah/config.xml --exec-directory=/opt/fah
01:26:25:             --data-directory=/opt/fah
01:26:25:     Config: /opt/fah/config.xml
01:26:25:******************************** Build ********************************
01:26:25:    Version: 7.4.4
01:26:25:       Date: Mar 4 2014
01:26:25:       Time: 12:02:38
01:26:25:    SVN Rev: 4130
01:26:25:     Branch: fah/trunk/client
01:26:25:   Compiler: GNU 4.4.7
01:26:25:    Options: -std=gnu++98 -O3 -funroll-loops -mfpmath=sse -ffast-math
01:26:25:             -fno-unsafe-math-optimizations -msse2
01:26:25:   Platform: linux2 3.2.0-1-amd64
01:26:25:       Bits: 64
01:26:25:       Mode: Release
01:26:25:******************************* System ********************************
01:26:25:        CPU: Intel(R) Core(TM) i7 CPU Q 740 @ 1.73GHz
01:26:25:     CPU ID: GenuineIntel Family 6 Model 30 Stepping 5
01:26:25:       CPUs: 4
01:26:25:     Memory: 7.74GiB
01:26:25:Free Memory: 3.22GiB
01:26:25:    Threads: POSIX_THREADS
01:26:25: OS Version: 4.8
01:26:25:Has Battery: true
01:26:25: On Battery: false
01:26:25: UTC Offset: -5
01:26:25:        PID: 23540
01:26:25:        CWD: /opt/fah
01:26:25:         OS: Linux 4.8.6-1-ARCH x86_64
01:26:25:    OS Arch: AMD64
01:26:25:       GPUs: 1
01:26:25:      GPU 0: NVIDIA:0 GT215 [Quadro FX 1800M]
01:26:25:       CUDA: 1.2
01:26:25:CUDA Driver: 6050
01:26:25:***********************************************************************
01:26:25:<config>
01:26:25:  <!-- Slot Control -->
01:26:25:  <power v='FULL'/>
01:26:25:
01:26:25:  <!-- User Information -->
01:26:25:  <passkey v='********************************'/>
01:26:25:  <user v='Qwertylex'/>
01:26:25:
01:26:25:  <!-- Folding Slots -->
01:26:25:  <slot id='0' type='CPU'>
01:26:25:    <paused v='true'/>
01:26:25:  </slot>
01:26:25:  <slot id='1' type='GPU'/>
01:26:25:</config>
01:26:25:Trying to access database...
01:26:25:Successfully acquired database lock
01:26:25:Enabled folding slot 00: PAUSED cpu:3 (by user)
01:26:25:Enabled folding slot 01: READY gpu:0:GT215 [Quadro FX 1800M]
01:26:26:WU00:FS01:Connecting to 171.67.108.45:80
01:26:27:WU00:FS01:Assigned to work server 171.64.65.92
01:26:27:WU00:FS01:Requesting new work unit for slot 01: READY gpu:0:GT215 [Quadro FX 1800M] from 171.64.65.92
01:26:27:WU00:FS01:Connecting to 171.64.65.92:8080
01:26:28:WU00:FS01:Downloading 2.79MiB
01:26:29:WU00:FS01:Download complete
01:26:29:WU00:FS01:Received Unit: id:00 state:DOWNLOAD error:NO_ERROR project:9197 run:2 clone:49 gen:106 core:0x21 unit:0x00000091ab40415c57cb3fe14b9373ce
01:26:29:WU00:FS01:Downloading core from http://web.stanford.edu/~pande/Linux/AMD64/NVIDIA/G80/Core_21.fah
01:26:29:WU00:FS01:Connecting to web.stanford.edu:80
01:26:29:ERROR:WU00:FS01:Exception: Failed to access core package.
01:26:30:12:127.0.0.1:New Web connection
01:27:29:WU00:FS01:Downloading core from http://web.stanford.edu/~pande/Linux/AMD64/NVIDIA/G80/Core_21.fah
01:27:29:WU00:FS01:Connecting to web.stanford.edu:80
01:27:29:ERROR:WU00:FS01:Exception: Failed to access core package.
01:37:14:WU00:FS01:Downloading core from http://web.stanford.edu/~pande/Linux/AMD64/NVIDIA/G80/Core_21.fah
01:37:14:WU00:FS01:Connecting to web.stanford.edu:80
01:37:14:ERROR:WU00:FS01:Exception: Failed to access core package.
01:39:50:Caught signal SIGTERM(15) on PID 23540
01:39:50:Exiting, please wait. . .
01:39:52:Clean exit
