Can't download
kbless551
Can't download
Post by kbless551 »
are the work servers borked this morning? I woke up and my cpu slot said ready and it's work queue said downloading. Been like that for hours. A snip from the log:
16:31:11:WU03:FS03:0x21:Digital signatures verified
16:31:11:WU03:FS03:0x21:Folding@home GPU Core21 Folding@home Core
16:31:11:WU03:FS03:0x21:Version 0.0.17
16:31:11:WU03:FS03:0x21: Found a checkpoint file
16:31:11:WARNING:WU01:FS01:Failed to get assignment from '171.67.108.45:8080': Empty work server assignment
16:31:11:WU01:FS01:Connecting to 171.64.65.35:80
16:31:11:WARNING:WU00:FS00:Failed to get assignment from '171.67.108.45:8080': Empty work server assignment
16:31:11:WU00:FS00:Connecting to 171.64.65.35:80
16:31:12:WARNING:WU01:FS01:Failed to get assignment from '171.64.65.35:80': Empty work server assignment
16:31:12:ERROR:WU01:FS01:Exception: Could not get an assignment
16:31:12:WARNING:WU00:FS00:Failed to get assignment from '171.64.65.35:80': Empty work server assignment
16:31:12:ERROR:WU00:FS00:Exception: Could not get an assignment
The client shows this:
Re: Can't download
Please post the log information noted in the sig of this post.
1) The "Empty work server assignment" means that there are no WUs that can be assigned to your particular hardware/software configuration so we need to know what kind of project you were seeking.
2) The "Access denied" messages indicate that something is wrong with permissions on your system or with the configuration of your installation. Is there more than one user/password in use on your OS?
3) How are you starting FAH?
MEGIDDO
Re: Can't download
Post by MEGIDDO »
I'm all of a sudden having the same issue.. just on the CPU (started this afternoon):
"*********************** Log Started 2016-10-30T01:23:25Z ***********************
01:23:25:************************* Folding@home Client *************************
01:23:25:      Website: http://folding.stanford.edu/
01:23:25:    Copyright: (c) 2009-2014 Stanford University
01:23:25:       Author: Joseph Coffland <joseph@cauldrondevelopment.com>
01:23:25:         Args:
01:23:25:       Config: d:/Users/Lythronax/AppData/Roaming/FAHClient/config.xml
01:23:25:******************************** Build ********************************
01:23:25:      Version: 7.4.4
01:23:25:         Date: Mar 4 2014
01:23:25:         Time: 20:26:54
01:23:25:      SVN Rev: 4130
01:23:25:       Branch: fah/trunk/client
01:23:25:     Compiler: Intel(R) C++ MSVC 1500 mode 1200
01:23:25:      Options: /TP /nologo /EHa /Qdiag-disable:4297,4103,1786,279 /Ox -arch:SSE
01:23:25:               /QaxSSE2,SSE3,SSSE3,SSE4.1,SSE4.2 /Qopenmp /Qrestrict /MT /Qmkl
01:23:25:     Platform: win32 XP
01:23:25:         Bits: 32
01:23:25:         Mode: Release
01:23:25:******************************* System ********************************
01:23:25:          CPU: Intel(R) Core(TM) i7-6700K CPU @ 4.00GHz
01:23:25:       CPU ID: GenuineIntel Family 6 Model 94 Stepping 3
01:23:25:         CPUs: 8
01:23:25:       Memory: 15.95GiB
01:23:25:  Free Memory: 14.07GiB
01:23:25:      Threads: WINDOWS_THREADS
01:23:25:   OS Version: 6.2
01:23:25:  Has Battery: false
01:23:25:   On Battery: false
01:23:25:   UTC Offset: -5
01:23:25:          PID: 6416
01:23:25:          CWD: d:/Users/Lythronax/AppData/Roaming/FAHClient
01:23:25:           OS: Windows 10 Pro
01:23:25:      OS Arch: AMD64
01:23:25:         GPUs: 2
01:23:25:        GPU 0: UNSUPPORTED: NV3 [PCI]
01:23:25:        GPU 1: NVIDIA:5 GP104 [GeForce GTX 1070]
01:23:25:         CUDA: 6.1
01:23:25:  CUDA Driver: 8000
01:23:25:Win32 Service: false
01:23:25:***********************************************************************
01:23:25:<config>
01:23:25:  <!-- Slot Control -->
01:23:25:  <power v='full'/>
01:23:25:
01:23:25:  <!-- User Information -->
01:23:25:  <passkey v='********************************'/>
01:23:25:  <team v='223518'/>
01:23:25:  <user v='MEGIDDO'/>
01:23:25:
01:23:25:  <!-- Folding Slots -->
01:23:25:  <slot id='0' type='CPU'/>
01:23:25:  <slot id='1' type='GPU'/>
01:23:25:</config>
01:23:25:Trying to access database...
01:23:25:Successfully acquired database lock
01:23:25:Enabled folding slot 00: READY cpu:7
01:23:25:Enabled folding slot 01: READY gpu:1:GP104 [GeForce GTX 1070]
01:23:25:WU02:FS01:Starting
01:23:25:WU02:FS01:Running FahCore: "d:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" d:/Users/Lythronax/AppData/Roaming/FAHClient/cores/web.stanford.edu/~pande/Win32/AMD64/NVIDIA/Fermi/Core_21.fah/FahCore_21.exe -dir 02 -suffix 01 -version 704 -lifeline 6416 -checkpoint 15 -gpu 0 -gpu-vendor nvidia
01:23:25:WU02:FS01:Started FahCore on PID 8400
01:23:25:WU02:FS01:Core PID:8440
01:23:25:WU02:FS01:FahCore 0x21 started
01:23:25:WU00:FS00:Connecting to 171.67.108.45:8080
01:23:26:WU02:FS01:0x21:*********************** Log Started 2016-10-30T01:23:26Z ***********************
01:23:26:WU02:FS01:0x21:Project: 11402 (Run 5, Clone 41, Gen 156)
01:23:26:WU02:FS01:0x21:Unit: 0x000000d78ca304f255ed4e845727bd11
01:23:26:WU02:FS01:0x21:CPU: 0x00000000000000000000000000000000
01:23:26:WU02:FS01:0x21:Machine: 1
01:23:26:WU02:FS01:0x21:Digital signatures verified
01:23:26:WU02:FS01:0x21:Folding@home GPU Core21 Folding@home Core
01:23:26:WU02:FS01:0x21:Version 0.0.17
01:23:26:WU02:FS01:0x21:  Found a checkpoint file
01:23:26:WARNING:WU00:FS00:Failed to get assignment from '171.67.108.45:8080': Empty work server assignment
01:23:26:WU00:FS00:Connecting to 171.64.65.35:80
01:23:27:WARNING:WU00:FS00:Failed to get assignment from '171.64.65.35:80': Empty work server assignment
01:23:27:ERROR:WU00:FS00:Exception: Could not get an assignment
01:23:28:WU00:FS00:Connecting to 171.67.108.45:8080
01:23:28:WARNING:WU00:FS00:Failed to get assignment from '171.67.108.45:8080': Empty work server assignment
etc...
etc...
I've tried re-install with data cleared. and I have started it through advanced control panel, and web control panel.
Mod edit: merged two posts and added Code tags to log listing
Re: Can't download
"01:23:25:Enabled folding slot 00: READY cpu:7"
Lately the CPU WUs have really hated prime numbers larger than 3.
Try setting CPUs to 6 and see if that helps. (It may be set to -1 now)
Re: Can't download
The other option to changing the CPU slot setting is to move the Power Slider to Medium. That uses one less than the maximum available CPU cores for folding.
CPU settings that are multiples of 2 and or 3 will work. Sometimes WU's are also available for multiples of 5. Multiples of prime numbers 7 and greater tend not to get assignments. The next release of the client software should handle negotiating assignments for CPU settings such as this for 7 better and automatically try for 6 if nothing is available for 7.
MEGIDDO
Re: Can't download
Post by MEGIDDO »
Changing it to 6 totally fixed it, man you guys are good. Thank you.
