13:43:34:WU00:FS01:0x21:Completed 5000000 out of 5000000 steps (100%)
13:43:35:WU01:FS01:Connecting to 171.67.108.45:80
13:43:35:WU01:FS01:Assigned to work server 171.67.108.155
13:43:35:WU01:FS01:Requesting new work unit for slot 01: RUNNING gpu:0:GP104 [GeForce GTX 1070] from 171.67.108.155
13:43:35:WU01:FS01:Connecting to 171.67.108.155:8080
13:43:37:WU01:FS01:Downloading 748.49KiB
13:43:37:WU01:FS01:Download complete
13:43:37:WU01:FS01:Received Unit: id:01 state:DOWNLOAD error:NO_ERROR project:9657 run:1 clone:87 gen:59 core:0x18 unit:0x00000046ab436c9b56de69ba30ac958f
13:43:39:WU00:FS01:0x21:Saving result file logfile_01.txt
13:43:39:WU00:FS01:0x21:Saving result file checkpointState.xml
13:43:41:WU00:FS01:0x21:Saving result file checkpt.crc
13:43:41:WU00:FS01:0x21:Saving result file log.txt
13:43:41:WU00:FS01:0x21:Saving result file positions.xtc
13:43:43:WU00:FS01:0x21:Folding@home Core Shutdown: FINISHED_UNIT
13:43:44:WU00:FS01:FahCore returned: FINISHED_UNIT (100 = 0x64)
13:43:44:WU00:FS01:Sending unit results: id:00 state:SEND error:NO_ERROR project:11406 run:1 clone:26 gen:233 core:0x21 unit:0x0000012a8ca304f25686b1af9e33aa06
13:43:44:WU00:FS01:Uploading 14.00MiB to 140.163.4.242
13:43:44:WU00:FS01:Connecting to 140.163.4.242:8080
13:43:44:WU01:FS01:Starting
13:43:44:WU01:FS01:Running FahCore: /usr/bin/FAHCoreWrapper /var/lib/fahclient/cores/web.stanford.edu/~pande/Linux/AMD64/NVIDIA/Fermi/Core_18.fah/FahCore_18 -dir 01 -suffix 01 -version 704 -lifeline 1156 -checkpoint 8 -gpu 0 -gpu-vendor nvidia
13:43:44:WU01:FS01:Started FahCore on PID 6645
13:43:44:WU01:FS01:Core PID:6649
13:43:44:WU01:FS01:FahCore 0x18 started
13:43:44:WU01:FS01:0x18:*********************** Log Started 2016-10-28T13:43:44Z ***********************
13:43:44:WU01:FS01:0x18:Project: 9657 (Run 1, Clone 87, Gen 59)
13:43:44:WU01:FS01:0x18:Unit: 0x00000046ab436c9b56de69ba30ac958f
13:43:44:WU01:FS01:0x18:CPU: 0x00000000000000000000000000000000
13:43:44:WU01:FS01:0x18:Machine: 1
13:43:44:WU01:FS01:0x18:Reading tar file core.xml
13:43:44:WU01:FS01:0x18:Reading tar file integrator.xml
13:43:44:WU01:FS01:0x18:Reading tar file state.xml
13:43:44:WU01:FS01:0x18:Reading tar file system.xml
13:43:44:WU01:FS01:0x18:Digital signatures verified
13:43:44:WU01:FS01:0x18:Folding@home GPU core18
13:43:44:WU01:FS01:0x18:Version 0.0.4
13:43:50:WU00:FS01:Upload 13.39%
13:43:52:WU01:FS01:0x18:Completed 0 out of 2000000 steps (0%)
13:43:52:WU01:FS01:0x18:Temperature control disabled. Requirements: single Nvidia GPU, tmax must be < 110 and twait >= 900
13:43:57:WU00:FS01:Upload 24.10%
13:44:03:WU00:FS01:Upload 33.03%
13:44:06:WU01:FS01:0x18:Completed 20000 out of 2000000 steps (1%)
13:44:09:WU00:FS01:Upload 44.64%
13:44:19:WU01:FS01:0x18:Completed 40000 out of 2000000 steps (2%)
13:44:33:WU01:FS01:0x18:Completed 60000 out of 2000000 steps (3%)
13:44:46:WU01:FS01:0x18:Completed 80000 out of 2000000 steps (4%)
13:44:59:WU01:FS01:0x18:Completed 100000 out of 2000000 steps (5%)
13:45:14:WU01:FS01:0x18:Completed 120000 out of 2000000 steps (6%)
13:45:27:WU01:FS01:0x18:Completed 140000 out of 2000000 steps (7%)
13:45:41:WU01:FS01:0x18:Completed 160000 out of 2000000 steps (8%)
13:45:54:WU01:FS01:0x18:Completed 180000 out of 2000000 steps (9%)
13:46:07:WU01:FS01:0x18:Completed 200000 out of 2000000 steps (10%)
13:46:22:WU01:FS01:0x18:Completed 220000 out of 2000000 steps (11%)
13:46:35:WU01:FS01:0x18:Completed 240000 out of 2000000 steps (12%)
13:46:48:WU01:FS01:0x18:Completed 260000 out of 2000000 steps (13%)
13:46:58:WU00:FS01:Upload 51.33%
13:46:58:WARNING:WU00:FS01:Exception: Failed to send results to work server: Transfer failed
13:46:58:WU00:FS01:Trying to send results to collection server
13:46:58:WU00:FS01:Uploading 14.00MiB to 128.252.203.2
13:46:58:WU00:FS01:Connecting to 128.252.203.2:8080
13:47:02:WU01:FS01:0x18:Completed 280000 out of 2000000 steps (14%)
13:47:04:WU00:FS01:Upload 11.61%
13:47:12:WU00:FS01:Upload 24.10%
13:47:15:WU01:FS01:0x18:Completed 300000 out of 2000000 steps (15%)
13:47:18:WU00:FS01:Upload 32.14%
13:47:24:WU00:FS01:Upload 40.17%
13:47:29:WU01:FS01:0x18:Completed 320000 out of 2000000 steps (16%)
13:47:31:WU00:FS01:Upload 51.33%
13:47:38:WU00:FS01:Upload 59.37%
13:47:43:WU01:FS01:0x18:Completed 340000 out of 2000000 steps (17%)
13:47:44:WU00:FS01:Upload 67.40%
13:47:52:WU00:FS01:Upload 75.89%
13:47:56:WU01:FS01:0x18:Completed 360000 out of 2000000 steps (18%)
13:47:59:WU00:FS01:Upload 81.24%
13:48:06:WU00:FS01:Upload 86.60%
13:48:09:WU01:FS01:0x18:Completed 380000 out of 2000000 steps (19%)
13:48:15:WU00:FS01:Upload 97.76%
13:48:22:WU01:FS01:0x18:Completed 400000 out of 2000000 steps (20%)
13:48:29:WU00:FS01:Upload complete
13:48:29:WU00:FS01:Server responded WORK_ACK (400)
13:48:29:WU00:FS01:Final credit estimate, 136827.00 points
13:48:29:WU00:FS01:Cleaning up
13:48:37:WU01:FS01:0x18:Completed 420000 out of 2000000 steps (21%)
13:48:51:WU01:FS01:0x18:Completed 440000 out of 2000000 steps (22%)
13:49:04:WU01:FS01:0x18:Completed 460000 out of 2000000 steps (23%)I'm sure this could be a hiccup in the Internet, but I wanted to make sure that this Collection Server wasn't under the weather or running short of resources. If it helps, I'm on AT&T U-verse ASDL (20 Mbps down, 2 Mbps up)
Edit: It appears the subnet this node is on had some issues back in February: viewtopic.php?f=18&t=28596
Edit: I just concentrated on the "Warnings and Errors" on this node's log and see the following:
08:20:37:WARNING:WU01:FS00:Failed to get assignment from '<myRouterIPv4>:8080': Failed to connect to <myRouterIPv4>:8080: Connection refused
08:20:38:WARNING:WU01:FS00:Failed to get assignment from '<myRouterIPv4>:80': 10001: Server responded: HTTP_INTERNAL_SERVER_ERROR
08:20:38:ERROR:WU01:FS00:Exception: Could not get an assignment
08:59:50:WARNING:WU02:FS02:Failed to get assignment from '171.67.108.45:80': 10001: Server responded: HTTP_INTERNAL_SERVER_ERROR
******************************* Date: 2016-10-28 *******************************
12:01:56:WARNING:WU03:FS00:Detected clock skew (1 mins 39 secs), adjusting time estimates
