new guy: Adding A Graphics Card To GPUs.txt File
MEGIDDO
Post by MEGIDDO »
I don't know if this is going to fix my issue or not, but it looked like a good place to start. I installed a GTX 1070 yesterday, and now the work unit (if I can get it to work at all) fails, and will not recover to start again. so I'm following these instructions:
"1) Navigate to C:\Program Files (x86)\FAHClient or C:\Program Files\FAHClient
2) Open a Command Prompt window
3) Type fahclient --lspci and hit Enter
4) Copy the output
5) Create a New Topic here and post those details along with a copy of the log file
6) Once it has been confirmed to be a valid entry, the GPUs.txt file will be updated on the Server
7) After the GPUs.txt file has been updated on the Server, locate the GPUs.txt file, delete it and restart the Client
8) The Client will automatically download the latest copy of GPUs.txt file and your GPU should be supported"
CMD prompt info:
0x1b21:0x1187:ASMedia Technology Inc.:PCI Express Upstream Switch Port
0x8086:0xa131:Intel Corporation:Intel(R) 100 Series/C230 Series Chipset Family Thermal subsystem - A131
0x8086:0x1901:Intel Corporation:Intel(R) Xeon(R) E3 - 1200/1500 v5/6th Gen Intel(R) Core(TM) PCIe Controller (x16) - 1901
0x8086:0x1909:Intel Corporation:Intel(R) Xeon(R) E3 - 1200/1500 v5/6th Gen Intel(R) Core(TM) PCIe Controller (x4) - 1909
0x8086:0xa13a:Intel Corporation:Intel(R) Management Engine Interface
0x1102:0x0012:Creative Labs:SB Recon3D PCIe Audio Controller
0x1b21:0x1242:ASMedia Technology Inc.:USB xHCI Compliant Host Controller
0x8086:0xa111:Intel Corporation:Intel(R) 100 Series/C230 Series Chipset Family PCI Express Root Port #2 - A111
0x10de:0x10f0:NVIDIA Corporation:NV3 [PCI]
0x8086:0x0953:Intel Corporation:Standard NVM Express Controller
0x1b21:0x0612:ASMedia Technology Inc.:Standard SATA AHCI Controller
0x8086:0xa121:Intel Corporation:Intel(R) 100 Series/C230 Series Chipset Family PMC - A121
0x8086:0xa123:Intel Corporation:Intel(R) 100 Series/C230 Series Chipset Family SMBus - A123
0x8086:0x191f:Intel Corporation:Intel(R) Xeon(R) E3 - 1200/1500 v5/6th Gen Intel(R) Core(TM) Host Bridge/DRAM Registers - 191F
0x8086:0xa102:Intel Corporation:Intel(R) 100 Series/C230 Chipset Family SATA AHCI Controller
0x10de:0x1b81:NVIDIA Corporation:NVIDIA GeForce GTX 1070
0x8086:0xa145:Intel Corporation:Intel(R) 100 Series/C230 Series Chipset Family LPC Controller - A145
0x8086:0xa110:Intel Corporation:Intel(R) 100 Series/C230 Series Chipset Family PCI Express Root Port #1 - A110
0x8086:0xa112:Intel Corporation:Intel(R) 100 Series/C230 Series Chipset Family PCI Express Root Port #3 - A112
0x8086:0x1539:Intel Corporation:Intel(R) I211 Gigabit Network Connection
0x8086:0xa12f:Intel Corporation:USB xHCI Compliant Host Controller
0x8086:0x15b8:Intel Corporation:Intel(R) Ethernet Connection (2) I219-V
Log file paste here::: The log file is way too big to post, I hit the character limit for post's. Is there a particular part of the log file that I can post to get this taken care of.
Please help, and thank you in advance.
MEGIDDO
Re: new guy: Adding A Graphics Card To GPUs.txt File
Post by MEGIDDO »
log file pt.1
*********************** Log Started 2016-10-27T03:24:43Z ***********************
03:25:17:WU01:FS01:Connecting to 171.67.108.45:8080
03:25:18:WU01:FS01:Connecting to 171.67.108.45:80
03:25:18:WU01:FS01:Assigned to work server 171.67.108.101
03:25:18:WU01:FS01:Requesting new work unit for slot 01: READY gpu:1:GP104 [GeForce GTX 1070] from 171.67.108.101
03:25:18:WU01:FS01:Connecting to 171.67.108.101:8080
03:25:27:WU01:FS01:Downloading 8.74MiB
03:25:33:WU01:FS01:Download 33.60%
03:25:39:WU01:FS01:Download 62.20%
03:25:45:WU01:FS01:Download 87.22%
03:25:47:WU01:FS01:Download complete
03:25:47:WU01:FS01:Received Unit: id:01 state:DOWNLOAD error:NO_ERROR project:13114 run:89 clone:0 gen:480 core:0x21 unit:0x00000120ab436c655771bc26db54d34d
03:25:47:WU01:FS01:Downloading core from http://web.stanford.edu/~pande/Win32/AMD64/NVIDIA/Fermi/Core_21.fah
03:25:47:WU01:FS01:Connecting to web.stanford.edu:80
03:25:48:WU01:FS01:FahCore 21: Downloading 3.47MiB
03:25:54:WU01:FS01:FahCore 21: 53.99%
03:26:00:WU01:FS01:FahCore 21: 100.00%
03:26:00:WU01:FS01:FahCore 21: Download complete
03:26:00:WU01:FS01:Valid core signature
03:26:00:WU01:FS01:Unpacked 11.81MiB to cores/web.stanford.edu/~pande/Win32/AMD64/NVIDIA/Fermi/Core_21.fah/FahCore_21.exe
03:26:00:WU01:FS01:Starting
03:26:00:WU01:FS01:Running FahCore: "d:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" d:/Users/Lythronax/AppData/Roaming/FAHClient/cores/web.stanford.edu/~pande/Win32/AMD64/NVIDIA/Fermi/Core_21.fah/FahCore_21.exe -dir 01 -suffix 01 -version 704 -lifeline 6204 -checkpoint 15 -gpu 0 -gpu-vendor nvidia
03:26:00:WU01:FS01:Started FahCore on PID 3268
03:26:00:WU01:FS01:Core PID:3700
03:26:00:WU01:FS01:FahCore 0x21 started
03:26:01:WU01:FS01:0x21:*********************** Log Started 2016-10-27T03:26:00Z ***********************
03:26:01:WU01:FS01:0x21:Project: 13114 (Run 89, Clone 0, Gen 480)
03:26:01:WU01:FS01:0x21:Unit: 0x00000120ab436c655771bc26db54d34d
03:26:01:WU01:FS01:0x21:CPU: 0x00000000000000000000000000000000
03:26:01:WU01:FS01:0x21:Machine: 1
03:26:01:WU01:FS01:0x21:Reading tar file core.xml
03:26:01:WU01:FS01:0x21:Reading tar file integrator.xml
03:26:01:WU01:FS01:0x21:Reading tar file state.xml
03:26:02:WU01:FS01:0x21:Reading tar file system.xml
03:26:03:WU01:FS01:0x21:Digital signatures verified
03:26:03:WU01:FS01:0x21:Folding@home GPU Core21 Folding@home Core
03:26:03:WU01:FS01:0x21:Version 0.0.17
03:26:27:WU01:FS01:0x21:ERROR:exception: Error downloading array interactionCount: clEnqueueReadBuffer (-5)
03:26:27:WU01:FS01:0x21:Saving result file logfile_01.txt
03:26:27:WU01:FS01:0x21:Saving result file log.txt
03:26:27:WU01:FS01:0x21:Folding@home Core Shutdown: BAD_WORK_UNIT
03:26:29:WARNING:WU01:FS01:FahCore returned: BAD_WORK_UNIT (114 = 0x72)
03:26:29:WU01:FS01:Sending unit results: id:01 state:SEND error:FAULTY project:13114 run:89 clone:0 gen:480 core:0x21 unit:0x00000120ab436c655771bc26db54d34d
03:26:29:WU01:FS01:Uploading 2.34KiB to 171.67.108.101
03:26:29:WU01:FS01:Connecting to 171.67.108.101:8080
03:26:29:WU01:FS01:Upload complete
03:26:29:WU01:FS01:Server responded WORK_ACK (400)
03:26:29:WU01:FS01:Cleaning up
03:26:29:WU02:FS01:Connecting to 171.67.108.45:80
03:26:30:WU02:FS01:Assigned to work server 171.67.108.159
03:26:30:WU02:FS01:Requesting new work unit for slot 01: READY gpu:1:GP104 [GeForce GTX 1070] from 171.67.108.159
03:26:30:WU02:FS01:Connecting to 171.67.108.159:8080
03:26:30:WU02:FS01:Downloading 22.04MiB
03:26:36:WU02:FS01:Download 16.45%
03:26:42:WU02:FS01:Download 29.50%
03:26:48:WU02:FS01:Download 36.87%
03:26:54:WU02:FS01:Download 38.57%
03:27:00:WU02:FS01:Download 41.69%
03:27:07:WU02:FS01:Download 43.96%
03:27:13:WU02:FS01:Download 44.53%
03:27:19:WU02:FS01:Download 45.09%
03:27:25:WU02:FS01:Download 47.08%
03:27:31:WU02:FS01:Download 57.86%
03:27:37:WU02:FS01:Download 72.04%
03:27:43:WU02:FS01:Download 79.13%
03:27:49:WU02:FS01:Download 88.49%
03:27:53:WU02:FS01:Download complete
03:27:53:WU02:FS01:Received Unit: id:02 state:DOWNLOAD error:NO_ERROR project:9181 run:7 clone:4 gen:77 core:0x21 unit:0x00000060ab436c9f57bdce0684ecd3ee
03:27:53:WU02:FS01:Starting
03:27:53:WU02:FS01:Running FahCore: "d:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" d:/Users/Lythronax/AppData/Roaming/FAHClient/cores/web.stanford.edu/~pande/Win32/AMD64/NVIDIA/Fermi/Core_21.fah/FahCore_21.exe -dir 02 -suffix 01 -version 704 -lifeline 6204 -checkpoint 15 -gpu 0 -gpu-vendor nvidia
03:27:53:WU02:FS01:Started FahCore on PID 6256
03:27:53:WU02:FS01:Core PID:3184
03:27:53:WU02:FS01:FahCore 0x21 started
03:27:55:WU02:FS01:0x21:*********************** Log Started 2016-10-27T03:27:54Z ***********************
03:27:55:WU02:FS01:0x21:Project: 9181 (Run 7, Clone 4, Gen 77)
03:27:55:WU02:FS01:0x21:Unit: 0x00000060ab436c9f57bdce0684ecd3ee
03:27:55:WU02:FS01:0x21:CPU: 0x00000000000000000000000000000000
03:27:55:WU02:FS01:0x21:Machine: 1
03:27:55:WU02:FS01:0x21:Reading tar file core.xml
03:27:55:WU02:FS01:0x21:Reading tar file integrator.xml
03:27:55:WU02:FS01:0x21:Reading tar file state.xml
03:27:55:WU02:FS01:0x21:Reading tar file system.xml
03:27:55:WU02:FS01:0x21:Digital signatures verified
03:27:55:WU02:FS01:0x21:Folding@home GPU Core21 Folding@home Core
03:27:55:WU02:FS01:0x21:Version 0.0.17
03:28:01:WU02:FS01:0x21:ERROR:exception: Error downloading array interactionCount: clEnqueueReadBuffer (-5)
03:28:01:WU02:FS01:0x21:Saving result file logfile_01.txt
03:28:01:WU02:FS01:0x21:Saving result file log.txt
03:28:01:WU02:FS01:0x21:Folding@home Core Shutdown: BAD_WORK_UNIT
03:28:03:WARNING:WU02:FS01:FahCore returned: BAD_WORK_UNIT (114 = 0x72)
03:28:03:WU02:FS01:Sending unit results: id:02 state:SEND error:FAULTY project:9181 run:7 clone:4 gen:77 core:0x21 unit:0x00000060ab436c9f57bdce0684ecd3ee
03:28:03:WU02:FS01:Uploading 7.00KiB to 171.67.108.159
03:28:03:WU02:FS01:Connecting to 171.67.108.159:8080
03:28:04:WU02:FS01:Upload complete
03:28:04:WU02:FS01:Server responded WORK_ACK (400)
03:28:04:WU02:FS01:Cleaning up
03:28:04:WU01:FS01:Connecting to 171.67.108.45:80
03:28:04:WU01:FS01:Assigned to work server 171.67.108.155
03:28:04:WU01:FS01:Requesting new work unit for slot 01: READY gpu:1:GP104 [GeForce GTX 1070] from 171.67.108.155
03:28:04:WU01:FS01:Connecting to 171.67.108.155:8080
03:28:06:WU01:FS01:Downloading 903.45KiB
03:28:08:WU01:FS01:Download complete
03:28:08:WU01:FS01:Received Unit: id:01 state:DOWNLOAD error:NO_ERROR project:9660 run:0 clone:65 gen:177 core:0x18 unit:0x000000c8ab436c9b56de69ba28349dfe
03:28:08:WU01:FS01:Downloading core from http://web.stanford.edu/~pande/Win32/AMD64/NVIDIA/Fermi/Core_18.fah
03:28:08:WU01:FS01:Connecting to web.stanford.edu:80
03:28:09:WU01:FS01:FahCore 18: Downloading 2.54MiB
03:28:15:WU01:FS01:FahCore 18: 88.69%
03:28:15:WU01:FS01:FahCore 18: Download complete
03:28:15:WU01:FS01:Valid core signature
03:28:15:WU01:FS01:Unpacked 8.47MiB to cores/web.stanford.edu/~pande/Win32/AMD64/NVIDIA/Fermi/Core_18.fah/FahCore_18.exe
03:28:15:WU01:FS01:Starting
03:28:15:WU01:FS01:Running FahCore: "d:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" d:/Users/Lythronax/AppData/Roaming/FAHClient/cores/web.stanford.edu/~pande/Win32/AMD64/NVIDIA/Fermi/Core_18.fah/FahCore_18.exe -dir 01 -suffix 01 -version 704 -lifeline 6204 -checkpoint 15 -gpu 0 -gpu-vendor nvidia
03:28:15:WU01:FS01:Started FahCore on PID 6476
03:28:15:WU01:FS01:Core PID:2316
03:28:15:WU01:FS01:FahCore 0x18 started
03:28:17:WU01:FS01:0x18:*********************** Log Started 2016-10-27T03:28:16Z ***********************
03:28:17:WU01:FS01:0x18:Project: 9660 (Run 0, Clone 65, Gen 177)
03:28:17:WU01:FS01:0x18:Unit: 0x000000c8ab436c9b56de69ba28349dfe
03:28:17:WU01:FS01:0x18:CPU: 0x00000000000000000000000000000000
03:28:17:WU01:FS01:0x18:Machine: 1
03:28:17:WU01:FS01:0x18:Reading tar file core.xml
03:28:17:WU01:FS01:0x18:Reading tar file integrator.xml
03:28:17:WU01:FS01:0x18:Reading tar file state.xml
03:28:17:WU01:FS01:0x18:Reading tar file system.xml
03:28:17:WU01:FS01:0x18:Digital signatures verified
03:28:17:WU01:FS01:0x18:Folding@home GPU core18
03:28:17:WU01:FS01:0x18:Version 0.0.4
03:28:23:WU01:FS01:0x18:Completed 0 out of 2000000 steps (0%)
03:28:23:WU01:FS01:0x18:Temperature control disabled. Requirements: single Nvidia GPU, tmax must be < 110 and twait >= 900
03:28:29:FS01:Paused
03:28:30:FS01:Shutting core down
03:28:30:WU01:FS01:0x18:WARNING:Console control signal 1 on PID 2316
03:28:30:WU01:FS01:0x18:Exiting, please wait. . .
03:28:30:WU01:FS01:FahCore returned: INTERRUPTED (102 = 0x66)
03:29:06:FS01:Unpaused
03:29:06:WU01:FS01:Starting
03:29:06:WU01:FS01:Running FahCore: "d:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" d:/Users/Lythronax/AppData/Roaming/FAHClient/cores/web.stanford.edu/~pande/Win32/AMD64/NVIDIA/Fermi/Core_18.fah/FahCore_18.exe -dir 01 -suffix 01 -version 704 -lifeline 6204 -checkpoint 15 -gpu 0 -gpu-vendor nvidia
03:29:06:WU01:FS01:Started FahCore on PID 1848
03:29:06:WU01:FS01:Core PID:8388
03:29:06:WU01:FS01:FahCore 0x18 started
03:29:07:WU01:FS01:0x18:*********************** Log Started 2016-10-27T03:29:07Z ***********************
03:29:07:WU01:FS01:0x18:Project: 9660 (Run 0, Clone 65, Gen 177)
03:29:07:WU01:FS01:0x18:Unit: 0x000000c8ab436c9b56de69ba28349dfe
03:29:07:WU01:FS01:0x18:CPU: 0x00000000000000000000000000000000
03:29:07:WU01:FS01:0x18:Machine: 1
03:29:07:WU01:FS01:0x18:Digital signatures verified
03:29:07:WU01:FS01:0x18:Folding@home GPU core18
03:29:07:WU01:FS01:0x18:Version 0.0.4
03:29:11:WU01:FS01:0x18:Completed 0 out of 2000000 steps (0%)
03:29:11:WU01:FS01:0x18:Temperature control disabled. Requirements: single Nvidia GPU, tmax must be < 110 and twait >= 900
03:29:31:WU01:FS01:0x18:Completed 20000 out of 2000000 steps (1%)
03:30:23:WU01:FS01:0x18:Completed 40000 out of 2000000 steps (2%)
03:32:03:WU01:FS01:0x18:Completed 60000 out of 2000000 steps (3%)
03:33:45:WU01:FS01:0x18:Completed 80000 out of 2000000 steps (4%)
03:35:26:WU01:FS01:0x18:Completed 100000 out of 2000000 steps (5%)
03:35:27:WU01:FS01:0x18:Bad State detected... attempting to resume from last good checkpoint
03:35:46:WU01:FS01:0x18:Completed 20000 out of 2000000 steps (1%)
03:36:05:WU01:FS01:0x18:Completed 40000 out of 2000000 steps (2%)
03:36:24:WU01:FS01:0x18:Completed 60000 out of 2000000 steps (3%)
03:36:43:WU01:FS01:0x18:Completed 80000 out of 2000000 steps (4%)
03:37:02:WU01:FS01:0x18:Completed 100000 out of 2000000 steps (5%)
03:37:23:WU01:FS01:0x18:Completed 120000 out of 2000000 steps (6%)
03:37:42:WU01:FS01:0x18:Completed 140000 out of 2000000 steps (7%)
03:38:01:WU01:FS01:0x18:Completed 160000 out of 2000000 steps (8%)
03:38:20:WU01:FS01:0x18:Completed 180000 out of 2000000 steps (9%)
03:38:40:WU01:FS01:0x18:Completed 200000 out of 2000000 steps (10%)
03:39:01:WU01:FS01:0x18:Completed 220000 out of 2000000 steps (11%)
03:39:20:WU01:FS01:0x18:Completed 240000 out of 2000000 steps (12%)
03:39:39:WU01:FS01:0x18:Completed 260000 out of 2000000 steps (13%)
03:39:58:WU01:FS01:0x18:Completed 280000 out of 2000000 steps (14%)
03:40:18:WU01:FS01:0x18:Completed 300000 out of 2000000 steps (15%)
03:40:39:WU01:FS01:0x18:Completed 320000 out of 2000000 steps (16%)
03:40:59:WU01:FS01:0x18:Completed 340000 out of 2000000 steps (17%)
03:41:18:WU01:FS01:0x18:Completed 360000 out of 2000000 steps (18%)
03:41:38:WU01:FS01:0x18:Completed 380000 out of 2000000 steps (19%)
03:41:57:WU01:FS01:0x18:Completed 400000 out of 2000000 steps (20%)
03:42:18:WU01:FS01:0x18:Completed 420000 out of 2000000 steps (21%)
03:42:38:WU01:FS01:0x18:Completed 440000 out of 2000000 steps (22%)
03:42:57:WU01:FS01:0x18:Completed 460000 out of 2000000 steps (23%)
03:43:16:WU01:FS01:0x18:Completed 480000 out of 2000000 steps (24%)
03:43:36:WU01:FS01:0x18:Completed 500000 out of 2000000 steps (25%)
03:43:57:WU01:FS01:0x18:Completed 520000 out of 2000000 steps (26%)
03:44:16:WU01:FS01:0x18:Completed 540000 out of 2000000 steps (27%)
03:44:36:WU01:FS01:0x18:Completed 560000 out of 2000000 steps (28%)
03:44:55:WU01:FS01:0x18:Completed 580000 out of 2000000 steps (29%)
03:45:14:WU01:FS01:0x18:Completed 600000 out of 2000000 steps (30%)
03:45:36:WU01:FS01:0x18:Completed 620000 out of 2000000 steps (31%)
03:45:55:WU01:FS01:0x18:Completed 640000 out of 2000000 steps (32%)
03:46:15:WU01:FS01:0x18:Completed 660000 out of 2000000 steps (33%)
03:46:34:WU01:FS01:0x18:Completed 680000 out of 2000000 steps (34%)
03:46:53:WU01:FS01:0x18:Completed 700000 out of 2000000 steps (35%)
03:47:14:WU01:FS01:0x18:Completed 720000 out of 2000000 steps (36%)
03:47:33:WU01:FS01:0x18:Completed 740000 out of 2000000 steps (37%)
03:47:52:WU01:FS01:0x18:Completed 760000 out of 2000000 steps (38%)
03:48:11:WU01:FS01:0x18:Completed 780000 out of 2000000 steps (39%)
03:48:30:WU01:FS01:0x18:Completed 800000 out of 2000000 steps (40%)
03:48:52:WU01:FS01:0x18:Completed 820000 out of 2000000 steps (41%)
03:49:11:WU01:FS01:0x18:Completed 840000 out of 2000000 steps (42%)
03:49:30:WU01:FS01:0x18:Completed 860000 out of 2000000 steps (43%)
03:49:49:WU01:FS01:0x18:Completed 880000 out of 2000000 steps (44%)
03:50:08:WU01:FS01:0x18:Completed 900000 out of 2000000 steps (45%)
03:50:29:WU01:FS01:0x18:Completed 920000 out of 2000000 steps (46%)
03:50:48:WU01:FS01:0x18:Completed 940000 out of 2000000 steps (47%)
03:51:08:WU01:FS01:0x18:Completed 960000 out of 2000000 steps (48%)
03:51:27:WU01:FS01:0x18:Completed 980000 out of 2000000 steps (49%)
03:51:46:WU01:FS01:0x18:Completed 1000000 out of 2000000 steps (50%)
03:52:08:WU01:FS01:0x18:Completed 1020000 out of 2000000 steps (51%)
03:52:27:WU01:FS01:0x18:Completed 1040000 out of 2000000 steps (52%)
03:52:46:WU01:FS01:0x18:Completed 1060000 out of 2000000 steps (53%)
03:53:05:WU01:FS01:0x18:Completed 1080000 out of 2000000 steps (54%)
03:53:25:WU01:FS01:0x18:Completed 1100000 out of 2000000 steps (55%)
03:53:46:WU01:FS01:0x18:Completed 1120000 out of 2000000 steps (56%)
03:54:05:WU01:FS01:0x18:Completed 1140000 out of 2000000 steps (57%)
03:54:24:WU01:FS01:0x18:Completed 1160000 out of 2000000 steps (58%)
03:54:44:WU01:FS01:0x18:Completed 1180000 out of 2000000 steps (59%)
03:55:03:WU01:FS01:0x18:Completed 1200000 out of 2000000 steps (60%)
03:55:24:WU01:FS01:0x18:Completed 1220000 out of 2000000 steps (61%)
03:55:43:WU01:FS01:0x18:Completed 1240000 out of 2000000 steps (62%)
03:56:03:WU01:FS01:0x18:Completed 1260000 out of 2000000 steps (63%)
03:56:22:WU01:FS01:0x18:Completed 1280000 out of 2000000 steps (64%)
03:56:41:WU01:FS01:0x18:Completed 1300000 out of 2000000 steps (65%)
03:57:03:WU01:FS01:0x18:Completed 1320000 out of 2000000 steps (66%)
03:57:22:WU01:FS01:0x18:Completed 1340000 out of 2000000 steps (67%)
03:57:41:WU01:FS01:0x18:Completed 1360000 out of 2000000 steps (68%)
03:58:00:WU01:FS01:0x18:Completed 1380000 out of 2000000 steps (69%)
03:58:20:WU01:FS01:0x18:Completed 1400000 out of 2000000 steps (70%)
03:58:41:WU01:FS01:0x18:Completed 1420000 out of 2000000 steps (71%)
03:59:00:WU01:FS01:0x18:Completed 1440000 out of 2000000 steps (72%)
03:59:19:WU01:FS01:0x18:Completed 1460000 out of 2000000 steps (73%)
03:59:38:WU01:FS01:0x18:Completed 1480000 out of 2000000 steps (74%)
03:59:58:WU01:FS01:0x18:Completed 1500000 out of 2000000 steps (75%)
04:00:19:WU01:FS01:0x18:Completed 1520000 out of 2000000 steps (76%)
04:00:38:WU01:FS01:0x18:Completed 1540000 out of 2000000 steps (77%)
04:00:58:WU01:FS01:0x18:Completed 1560000 out of 2000000 steps (78%)
04:01:17:WU01:FS01:0x18:Completed 1580000 out of 2000000 steps (79%)
04:01:36:WU01:FS01:0x18:Completed 1600000 out of 2000000 steps (80%)
04:01:58:WU01:FS01:0x18:Completed 1620000 out of 2000000 steps (81%)
04:02:18:WU01:FS01:0x18:Completed 1640000 out of 2000000 steps (82%)
04:02:37:WU01:FS01:0x18:Completed 1660000 out of 2000000 steps (83%)
04:02:57:WU01:FS01:0x18:Completed 1680000 out of 2000000 steps (84%)
04:03:16:WU01:FS01:0x18:Completed 1700000 out of 2000000 steps (85%)
04:03:38:WU01:FS01:0x18:Completed 1720000 out of 2000000 steps (86%)
04:03:57:WU01:FS01:0x18:Completed 1740000 out of 2000000 steps (87%)
04:04:16:WU01:FS01:0x18:Completed 1760000 out of 2000000 steps (88%)
04:04:36:WU01:FS01:0x18:Completed 1780000 out of 2000000 steps (89%)
04:04:55:WU01:FS01:0x18:Completed 1800000 out of 2000000 steps (90%)
04:05:16:WU01:FS01:0x18:Completed 1820000 out of 2000000 steps (91%)
04:05:35:WU01:FS01:0x18:Completed 1840000 out of 2000000 steps (92%)
04:05:54:WU01:FS01:0x18:Completed 1860000 out of 2000000 steps (93%)
04:06:14:WU01:FS01:0x18:Completed 1880000 out of 2000000 steps (94%)
04:06:33:WU01:FS01:0x18:Completed 1900000 out of 2000000 steps (95%)
04:06:54:WU01:FS01:0x18:Completed 1920000 out of 2000000 steps (96%)
04:07:13:WU01:FS01:0x18:Completed 1940000 out of 2000000 steps (97%)
04:07:32:WU01:FS01:0x18:Completed 1960000 out of 2000000 steps (98%)
04:07:52:WU01:FS01:0x18:Completed 1980000 out of 2000000 steps (99%)
04:08:11:WU01:FS01:0x18:Completed 2000000 out of 2000000 steps (100%)
04:08:12:WU02:FS01:Connecting to 171.67.108.45:80
04:08:12:WU02:FS01:Assigned to work server 140.163.4.242
04:08:12:WU02:FS01:Requesting new work unit for slot 01: RUNNING gpu:1:GP104 [GeForce GTX 1070] from 140.163.4.242
04:08:12:WU02:FS01:Connecting to 140.163.4.242:8080
04:08:13:WU01:FS01:0x18:Saving result file logfile_01.txt
04:08:13:WU01:FS01:0x18:Saving result file checkpointState.xml
04:08:13:WU01:FS01:0x18:Saving result file checkpt.crc
04:08:13:WU01:FS01:0x18:Saving result file log.txt
04:08:13:WU01:FS01:0x18:Saving result file positions.xtc
04:08:13:WU01:FS01:0x18:Folding@home Core Shutdown: FINISHED_UNIT
04:08:14:WU01:FS01:FahCore returned: FINISHED_UNIT (100 = 0x64)
04:08:14:WU01:FS01:Sending unit results: id:01 state:SEND error:NO_ERROR project:9660 run:0 clone:65 gen:177 core:0x18 unit:0x000000c8ab436c9b56de69ba28349dfe
04:08:14:WU01:FS01:Uploading 1.75MiB to 171.67.108.155
04:08:14:WU01:FS01:Connecting to 171.67.108.155:8080
04:08:16:WU02:FS01:Downloading 4.05MiB
04:08:20:WU01:FS01:Upload 53.68%
04:08:21:WU02:FS01:Download complete
04:08:21:WU02:FS01:Received Unit: id:02 state:DOWNLOAD error:NO_ERROR project:11401 run:86 clone:28 gen:17 core:0x21 unit:0x0000001d8ca304f257c5cdb3de5e0d78
04:08:21:WU02:FS01:Starting
04:08:21:WU02:FS01:Running FahCore: "d:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" d:/Users/Lythronax/AppData/Roaming/FAHClient/cores/web.stanford.edu/~pande/Win32/AMD64/NVIDIA/Fermi/Core_21.fah/FahCore_21.exe -dir 02 -suffix 01 -version 704 -lifeline 6204 -checkpoint 15 -gpu 0 -gpu-vendor nvidia
04:08:21:WU02:FS01:Started FahCore on PID 7960
04:08:21:WU02:FS01:Core PID:4060
04:08:21:WU02:FS01:FahCore 0x21 started
04:08:22:WU02:FS01:0x21:*********************** Log Started 2016-10-27T04:08:21Z ***********************
04:08:22:WU02:FS01:0x21:Project: 11401 (Run 86, Clone 28, Gen 17)
04:08:22:WU02:FS01:0x21:Unit: 0x0000001d8ca304f257c5cdb3de5e0d78
04:08:22:WU02:FS01:0x21:CPU: 0x00000000000000000000000000000000
04:08:22:WU02:FS01:0x21:Machine: 1
04:08:22:WU02:FS01:0x21:Reading tar file core.xml
04:08:22:WU02:FS01:0x21:Reading tar file system.xml
04:08:22:WU02:FS01:0x21:Reading tar file integrator.xml
04:08:22:WU02:FS01:0x21:Reading tar file state.xml
04:08:22:WU02:FS01:0x21:Digital signatures verified
04:08:22:WU02:FS01:0x21:Folding@home GPU Core21 Folding@home Core
04:08:22:WU02:FS01:0x21:Version 0.0.17
04:08:24:WU01:FS01:Upload complete
04:08:25:WU01:FS01:Server responded WORK_ACK (400)
04:08:25:WU01:FS01:Final credit estimate, 11512.00 points
04:08:25:WU01:FS01:Cleaning up
04:08:26:WU02:FS01:0x21:ERROR:exception: Error downloading array interactionCount: clEnqueueReadBuffer (-5)
04:08:26:WU02:FS01:0x21:Saving result file logfile_01.txt
04:08:26:WU02:FS01:0x21:Saving result file log.txt
04:08:26:WU02:FS01:0x21:Folding@home Core Shutdown: BAD_WORK_UNIT
04:08:29:WARNING:WU02:FS01:FahCore returned: BAD_WORK_UNIT (114 = 0x72)
04:08:29:WU02:FS01:Sending unit results: id:02 state:SEND error:FAULTY project:11401 run:86 clone:28 gen:17 core:0x21 unit:0x0000001d8ca304f257c5cdb3de5e0d78
04:08:29:WU02:FS01:Uploading 2.41KiB to 140.163.4.242
04:08:29:WU02:FS01:Connecting to 140.163.4.242:8080
04:08:29:WU02:FS01:Upload complete
04:08:29:WU02:FS01:Server responded WORK_ACK (400)
04:08:29:WU02:FS01:Cleaning up
04:08:29:WU01:FS01:Connecting to 171.67.108.45:80
04:08:29:WU01:FS01:Assigned to work server 171.64.65.92
04:08:29:WU01:FS01:Requesting new work unit for slot 01: READY gpu:1:GP104 [GeForce GTX 1070] from 171.64.65.92
04:08:29:WU01:FS01:Connecting to 171.64.65.92:8080
04:08:30:WU01:FS01:Downloading 3.05MiB
04:08:36:WU01:FS01:Download 34.80%
04:08:42:WU01:FS01:Download 73.69%
04:08:45:WU01:FS01:Download complete
04:08:45:WU01:FS01:Received Unit: id:01 state:DOWNLOAD error:NO_ERROR project:9197 run:1 clone:82 gen:102 core:0x21 unit:0x00000086ab40415c57cb3fc6defbcb10
04:08:45:WU01:FS01:Starting
04:08:45:WU01:FS01:Running FahCore: "d:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" d:/Users/Lythronax/AppData/Roaming/FAHClient/cores/web.stanford.edu/~pande/Win32/AMD64/NVIDIA/Fermi/Core_21.fah/FahCore_21.exe -dir 01 -suffix 01 -version 704 -lifeline 6204 -checkpoint 15 -gpu 0 -gpu-vendor nvidia
04:08:45:WU01:FS01:Started FahCore on PID 1156
04:08:45:WU01:FS01:Core PID:8620
04:08:45:WU01:FS01:FahCore 0x21 started
04:08:46:WU01:FS01:0x21:*********************** Log Started 2016-10-27T04:08:46Z ***********************
04:08:46:WU01:FS01:0x21:Project: 9197 (Run 1, Clone 82, Gen 102)
04:08:46:WU01:FS01:0x21:Unit: 0x00000086ab40415c57cb3fc6defbcb10
04:08:46:WU01:FS01:0x21:CPU: 0x00000000000000000000000000000000
04:08:46:WU01:FS01:0x21:Machine: 1
04:08:46:WU01:FS01:0x21:Reading tar file core.xml
04:08:46:WU01:FS01:0x21:Reading tar file system.xml
04:08:46:WU01:FS01:0x21:Reading tar file integrator.xml
04:08:46:WU01:FS01:0x21:Reading tar file state.xml
04:08:47:WU01:FS01:0x21:Digital signatures verified
04:08:47:WU01:FS01:0x21:Folding@home GPU Core21 Folding@home Core
04:08:47:WU01:FS01:0x21:Version 0.0.17
04:08:51:WU01:FS01:0x21:ERROR:exception: Error downloading array interactionCount: clEnqueueReadBuffer (-5)
04:08:51:WU01:FS01:0x21:Saving result file logfile_01.txt
04:08:51:WU01:FS01:0x21:Saving result file log.txt
04:08:51:WU01:FS01:0x21:Folding@home Core Shutdown: BAD_WORK_UNIT
04:08:53:WARNING:WU01:FS01:FahCore returned: BAD_WORK_UNIT (114 = 0x72)
04:08:53:WU01:FS01:Sending unit results: id:01 state:SEND error:FAULTY project:9197 run:1 clone:82 gen:102 core:0x21 unit:0x00000086ab40415c57cb3fc6defbcb10
04:08:53:WU01:FS01:Uploading 2.38KiB to 171.64.65.92
04:08:53:WU01:FS01:Connecting to 171.64.65.92:8080
04:08:53:WU02:FS01:Connecting to 171.67.108.45:80
04:08:54:WU01:FS01:Upload complete
04:08:54:WU01:FS01:Server responded WORK_ACK (400)
04:08:54:WU01:FS01:Cleaning up
04:08:54:WU02:FS01:Assigned to work server 140.163.4.245
04:08:54:WU02:FS01:Requesting new work unit for slot 01: READY gpu:1:GP104 [GeForce GTX 1070] from 140.163.4.245
04:08:54:WU02:FS01:Connecting to 140.163.4.245:8080
04:08:54:WU02:FS01:Downloading 14.50MiB
04:09:00:WU02:FS01:Download 16.80%
04:09:06:WU02:FS01:Download 33.18%
04:09:12:WU02:FS01:Download 53.00%
04:09:18:WU02:FS01:Download 87.04%
04:09:20:WU02:FS01:Download complete
04:09:20:WU02:FS01:Received Unit: id:02 state:DOWNLOAD error:NO_ERROR project:10496 run:62 clone:15 gen:7 core:0x21 unit:0x0000000b8ca304f556bbaa8fc8fce092
04:09:20:WU02:FS01:Starting
04:09:20:WU02:FS01:Running FahCore: "d:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" d:/Users/Lythronax/AppData/Roaming/FAHClient/cores/web.stanford.edu/~pande/Win32/AMD64/NVIDIA/Fermi/Core_21.fah/FahCore_21.exe -dir 02 -suffix 01 -version 704 -lifeline 6204 -checkpoint 15 -gpu 0 -gpu-vendor nvidia
04:09:20:WU02:FS01:Started FahCore on PID 188
04:09:20:WU02:FS01:Core PID:7084
04:09:20:WU02:FS01:FahCore 0x21 started
04:09:21:WU02:FS01:0x21:*********************** Log Started 2016-10-27T04:09:21Z ***********************
04:09:21:WU02:FS01:0x21:Project: 10496 (Run 62, Clone 15, Gen 7)
04:09:21:WU02:FS01:0x21:Unit: 0x0000000b8ca304f556bbaa8fc8fce092
04:09:21:WU02:FS01:0x21:CPU: 0x00000000000000000000000000000000
04:09:21:WU02:FS01:0x21:Machine: 1
04:09:21:WU02:FS01:0x21:Reading tar file core.xml
04:09:21:WU02:FS01:0x21:Reading tar file system.xml
04:09:22:WU02:FS01:0x21:Reading tar file integrator.xml
04:09:22:WU02:FS01:0x21:Reading tar file state.xml
04:09:24:WU02:FS01:0x21:Digital signatures verified
04:09:24:WU02:FS01:0x21:Folding@home GPU Core21 Folding@home Core
04:09:24:WU02:FS01:0x21:Version 0.0.17
04:09:40:WU02:FS01:0x21:ERROR:exception: Error downloading array interactionCount: clEnqueueReadBuffer (-5)
04:09:40:WU02:FS01:0x21:Saving result file logfile_01.txt
04:09:40:WU02:FS01:0x21:Saving result file log.txt
04:09:40:WU02:FS01:0x21:Folding@home Core Shutdown: BAD_WORK_UNIT
04:09:43:WARNING:WU02:FS01:FahCore returned: BAD_WORK_UNIT (114 = 0x72)
04:09:43:WU02:FS01:Sending unit results: id:02 state:SEND error:FAULTY project:10496 run:62 clone:15 gen:7 core:0x21 unit:0x0000000b8ca304f556bbaa8fc8fce092
04:09:43:WU02:FS01:Uploading 2.36KiB to 140.163.4.245
04:09:43:WU02:FS01:Connecting to 140.163.4.245:8080
04:09:43:WU02:FS01:Upload complete
04:09:43:WU02:FS01:Server responded WORK_ACK (400)
04:09:43:WU02:FS01:Cleaning up
04:09:43:WU01:FS01:Connecting to 171.67.108.45:80
04:09:44:WU01:FS01:Assigned to work server 171.64.65.92
04:09:44:WU01:FS01:Requesting new work unit for slot 01: READY gpu:1:GP104 [GeForce GTX 1070] from 171.64.65.92
04:09:44:WU01:FS01:Connecting to 171.64.65.92:8080
04:09:44:WU01:FS01:Downloading 2.79MiB
04:09:50:WU01:FS01:Download 56.05%
04:09:55:WU01:FS01:Download complete
04:09:55:WU01:FS01:Received Unit: id:01 state:DOWNLOAD error:NO_ERROR project:9197 run:2 clone:21 gen:46 core:0x21 unit:0x0000003dab40415c57cb3fd471fc250a
04:09:55:WU01:FS01:Starting
04:09:55:WU01:FS01:Running FahCore: "d:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" d:/Users/Lythronax/AppData/Roaming/FAHClient/cores/web.stanford.edu/~pande/Win32/AMD64/NVIDIA/Fermi/Core_21.fah/FahCore_21.exe -dir 01 -suffix 01 -version 704 -lifeline 6204 -checkpoint 15 -gpu 0 -gpu-vendor nvidia
04:09:55:WU01:FS01:Started FahCore on PID 4040
04:09:55:WU01:FS01:Core PID:4824
04:09:55:WU01:FS01:FahCore 0x21 started
04:09:56:WU01:FS01:0x21:*********************** Log Started 2016-10-27T04:09:56Z ***********************
04:09:56:WU01:FS01:0x21:Project: 9197 (Run 2, Clone 21, Gen 46)
04:09:56:WU01:FS01:0x21:Unit: 0x0000003dab40415c57cb3fd471fc250a
04:09:56:WU01:FS01:0x21:CPU: 0x00000000000000000000000000000000
04:09:56:WU01:FS01:0x21:Machine: 1
04:09:56:WU01:FS01:0x21:Reading tar file core.xml
04:09:56:WU01:FS01:0x21:Reading tar file system.xml
04:09:56:WU01:FS01:0x21:Reading tar file integrator.xml
04:09:56:WU01:FS01:0x21:Reading tar file state.xml
04:09:57:WU01:FS01:0x21:Digital signatures verified
04:09:57:WU01:FS01:0x21:Folding@home GPU Core21 Folding@home Core
04:09:57:WU01:FS01:0x21:Version 0.0.17
04:10:01:WU01:FS01:0x21:ERROR:exception: Error downloading array interactionCount: clEnqueueReadBuffer (-5)
04:10:01:WU01:FS01:0x21:Saving result file logfile_01.txt
04:10:01:WU01:FS01:0x21:Saving result file log.txt
04:10:01:WU01:FS01:0x21:Folding@home Core Shutdown: BAD_WORK_UNIT
04:10:03:WARNING:WU01:FS01:FahCore returned: BAD_WORK_UNIT (114 = 0x72)
04:10:03:WU01:FS01:Sending unit results: id:01 state:SEND error:FAULTY project:9197 run:2 clone:21 gen:46 core:0x21 unit:0x0000003dab40415c57cb3fd471fc250a
04:10:03:WU01:FS01:Uploading 2.38KiB to 171.64.65.92
04:10:03:WU01:FS01:Connecting to 171.64.65.92:8080
04:10:03:WU01:FS01:Upload complete
04:10:03:WU01:FS01:Server responded WORK_ACK (400)
04:10:03:WU01:FS01:Cleaning up
04:10:03:WU02:FS01:Connecting to 171.67.108.45:80
04:10:04:WU02:FS01:Assigned to work server 171.67.108.155
04:10:04:WU02:FS01:Requesting new work unit for slot 01: READY gpu:1:GP104 [GeForce GTX 1070] from 171.67.108.155
04:10:04:WU02:FS01:Connecting to 171.67.108.155:8080
04:10:05:WU02:FS01:Downloading 747.18KiB
04:10:08:WU02:FS01:Download complete
04:10:08:WU02:FS01:Received Unit: id:02 state:DOWNLOAD error:NO_ERROR project:9657 run:0 clone:81 gen:50 core:0x18 unit:0x00000038ab436c9b56de69b97c37a007
04:10:08:WU02:FS01:Starting
04:10:08:WU02:FS01:Running FahCore: "d:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" d:/Users/Lythronax/AppData/Roaming/FAHClient/cores/web.stanford.edu/~pande/Win32/AMD64/NVIDIA/Fermi/Core_18.fah/FahCore_18.exe -dir 02 -suffix 01 -version 704 -lifeline 6204 -checkpoint 15 -gpu 0 -gpu-vendor nvidia
04:10:08:WU02:FS01:Started FahCore on PID 5560
04:10:08:WU02:FS01:Core PID:6816
04:10:08:WU02:FS01:FahCore 0x18 started
04:10:09:WU02:FS01:0x18:*********************** Log Started 2016-10-27T04:10:08Z ***********************
04:10:09:WU02:FS01:0x18:Project: 9657 (Run 0, Clone 81, Gen 50)
04:10:09:WU02:FS01:0x18:Unit: 0x00000038ab436c9b56de69b97c37a007
04:10:09:WU02:FS01:0x18:CPU: 0x00000000000000000000000000000000
04:10:09:WU02:FS01:0x18:Machine: 1
04:10:09:WU02:FS01:0x18:Reading tar file core.xml
04:10:09:WU02:FS01:0x18:Reading tar file integrator.xml
04:10:09:WU02:FS01:0x18:Reading tar file state.xml
04:10:09:WU02:FS01:0x18:Reading tar file system.xml
04:10:09:WU02:FS01:0x18:Digital signatures verified
04:10:09:WU02:FS01:0x18:Folding@home GPU core18
04:10:09:WU02:FS01:0x18:Version 0.0.4
04:10:11:WU02:FS01:0x18:Completed 0 out of 2000000 steps (0%)
04:10:11:WU02:FS01:0x18:Temperature control disabled. Requirements: single Nvidia GPU, tmax must be < 110 and twait >= 900
04:10:27:WU02:FS01:0x18:Completed 20000 out of 2000000 steps (1%)
04:10:41:WU02:FS01:0x18:Completed 40000 out of 2000000 steps (2%)
04:10:56:WU02:FS01:0x18:Completed 60000 out of 2000000 steps (3%)
04:11:10:WU02:FS01:0x18:Completed 80000 out of 2000000 steps (4%)
04:11:25:WU02:FS01:0x18:Completed 100000 out of 2000000 steps (5%)
04:11:40:WU02:FS01:0x18:Completed 120000 out of 2000000 steps (6%)
04:11:55:WU02:FS01:0x18:Completed 140000 out of 2000000 steps (7%)
04:12:10:WU02:FS01:0x18:Completed 160000 out of 2000000 steps (8%)
04:12:25:WU02:FS01:0x18:Completed 180000 out of 2000000 steps (9%)
04:12:40:WU02:FS01:0x18:Completed 200000 out of 2000000 steps (10%)
04:12:56:WU02:FS01:0x18:Completed 220000 out of 2000000 steps (11%)
04:13:10:WU02:FS01:0x18:Completed 240000 out of 2000000 steps (12%)
04:13:24:WU02:FS01:0x18:Completed 260000 out of 2000000 steps (13%)
04:13:39:WU02:FS01:0x18:Completed 280000 out of 2000000 steps (14%)
04:13:53:WU02:FS01:0x18:Completed 300000 out of 2000000 steps (15%)
04:14:09:WU02:FS01:0x18:Completed 320000 out of 2000000 steps (16%)
04:14:24:WU02:FS01:0x18:Completed 340000 out of 2000000 steps (17%)
04:14:38:WU02:FS01:0x18:Completed 360000 out of 2000000 steps (18%)
04:14:53:WU02:FS01:0x18:Completed 380000 out of 2000000 steps (19%)
04:15:07:WU02:FS01:0x18:Completed 400000 out of 2000000 steps (20%)
04:15:23:WU02:FS01:0x18:Completed 420000 out of 2000000 steps (21%)
04:15:37:WU02:FS01:0x18:Completed 440000 out of 2000000 steps (22%)
04:15:52:WU02:FS01:0x18:Completed 460000 out of 2000000 steps (23%)
04:16:06:WU02:FS01:0x18:Completed 480000 out of 2000000 steps (24%)
04:16:21:WU02:FS01:0x18:Completed 500000 out of 2000000 steps (25%)
04:16:36:WU02:FS01:0x18:Completed 520000 out of 2000000 steps (26%)
04:16:51:WU02:FS01:0x18:Completed 540000 out of 2000000 steps (27%)
04:17:05:WU02:FS01:0x18:Completed 560000 out of 2000000 steps (28%)
04:17:20:WU02:FS01:0x18:Completed 580000 out of 2000000 steps (29%)
04:17:34:WU02:FS01:0x18:Completed 600000 out of 2000000 steps (30%)
04:17:50:WU02:FS01:0x18:Completed 620000 out of 2000000 steps (31%)
04:18:04:WU02:FS01:0x18:Completed 640000 out of 2000000 steps (32%)
04:18:19:WU02:FS01:0x18:Completed 660000 out of 2000000 steps (33%)
04:18:33:WU02:FS01:0x18:Completed 680000 out of 2000000 steps (34%)
04:18:48:WU02:FS01:0x18:Completed 700000 out of 2000000 steps (35%)
04:19:04:WU02:FS01:0x18:Completed 720000 out of 2000000 steps (36%)
04:19:18:WU02:FS01:0x18:Completed 740000 out of 2000000 steps (37%)
04:19:33:WU02:FS01:0x18:Completed 760000 out of 2000000 steps (38%)
04:19:47:WU02:FS01:0x18:Completed 780000 out of 2000000 steps (39%)
04:20:01:WU02:FS01:0x18:Completed 800000 out of 2000000 steps (40%)
04:20:17:WU02:FS01:0x18:Completed 820000 out of 2000000 steps (41%)
04:20:32:WU02:FS01:0x18:Completed 840000 out of 2000000 steps (42%)
04:20:46:WU02:FS01:0x18:Completed 860000 out of 2000000 steps (43%)
04:21:01:WU02:FS01:0x18:Completed 880000 out of 2000000 steps (44%)
04:21:16:WU02:FS01:0x18:Completed 900000 out of 2000000 steps (45%)
04:21:32:WU02:FS01:0x18:Completed 920000 out of 2000000 steps (46%)
04:21:46:WU02:FS01:0x18:Completed 940000 out of 2000000 steps (47%)
04:22:01:WU02:FS01:0x18:Completed 960000 out of 2000000 steps (48%)
04:22:16:WU02:FS01:0x18:Completed 980000 out of 2000000 steps (49%)
04:22:31:WU02:FS01:0x18:Completed 1000000 out of 2000000 steps (50%)
04:22:47:WU02:FS01:0x18:Completed 1020000 out of 2000000 steps (51%)
04:23:02:WU02:FS01:0x18:Completed 1040000 out of 2000000 steps (52%)
04:23:16:WU02:FS01:0x18:Completed 1060000 out of 2000000 steps (53%)
04:23:30:WU02:FS01:0x18:Completed 1080000 out of 2000000 steps (54%)
04:23:45:WU02:FS01:0x18:Completed 1100000 out of 2000000 steps (55%)
04:24:00:WU02:FS01:0x18:Completed 1120000 out of 2000000 steps (56%)
04:24:15:WU02:FS01:0x18:Completed 1140000 out of 2000000 steps (57%)
04:24:29:WU02:FS01:0x18:Completed 1160000 out of 2000000 steps (58%)
04:24:44:WU02:FS01:0x18:Completed 1180000 out of 2000000 steps (59%)
04:24:58:WU02:FS01:0x18:Completed 1200000 out of 2000000 steps (60%)
04:25:14:WU02:FS01:0x18:Completed 1220000 out of 2000000 steps (61%)
04:25:28:WU02:FS01:0x18:Completed 1240000 out of 2000000 steps (62%)
04:25:42:WU02:FS01:0x18:Completed 1260000 out of 2000000 steps (63%)
04:25:57:WU02:FS01:0x18:Completed 1280000 out of 2000000 steps (64%)
04:26:11:WU02:FS01:0x18:Completed 1300000 out of 2000000 steps (65%)
04:26:27:WU02:FS01:0x18:Completed 1320000 out of 2000000 steps (66%)
04:26:41:WU02:FS01:0x18:Completed 1340000 out of 2000000 steps (67%)
04:26:56:WU02:FS01:0x18:Completed 1360000 out of 2000000 steps (68%)
04:27:10:WU02:FS01:0x18:Completed 1380000 out of 2000000 steps (69%)
04:27:25:WU02:FS01:0x18:Completed 1400000 out of 2000000 steps (70%)
04:27:40:WU02:FS01:0x18:Completed 1420000 out of 2000000 steps (71%)
04:27:55:WU02:FS01:0x18:Completed 1440000 out of 2000000 steps (72%)
04:28:09:WU02:FS01:0x18:Completed 1460000 out of 2000000 steps (73%)
04:28:23:WU02:FS01:0x18:Completed 1480000 out of 2000000 steps (74%)
04:28:38:WU02:FS01:0x18:Completed 1500000 out of 2000000 steps (75%)
04:28:53:WU02:FS01:0x18:Completed 1520000 out of 2000000 steps (76%)
04:29:08:WU02:FS01:0x18:Completed 1540000 out of 2000000 steps (77%)
04:29:22:WU02:FS01:0x18:Completed 1560000 out of 2000000 steps (78%)
04:29:37:WU02:FS01:0x18:Completed 1580000 out of 2000000 steps (79%)
04:29:51:WU02:FS01:0x18:Completed 1600000 out of 2000000 steps (80%)
04:30:07:WU02:FS01:0x18:Completed 1620000 out of 2000000 steps (81%)
04:30:21:WU02:FS01:0x18:Completed 1640000 out of 2000000 steps (82%)
04:30:35:WU02:FS01:0x18:Completed 1660000 out of 2000000 steps (83%)
04:30:50:WU02:FS01:0x18:Completed 1680000 out of 2000000 steps (84%)
04:31:04:WU02:FS01:0x18:Completed 1700000 out of 2000000 steps (85%)
04:31:20:WU02:FS01:0x18:Completed 1720000 out of 2000000 steps (86%)
04:31:34:WU02:FS01:0x18:Completed 1740000 out of 2000000 steps (87%)
04:31:48:WU02:FS01:0x18:Completed 1760000 out of 2000000 steps (88%)
04:32:03:WU02:FS01:0x18:Completed 1780000 out of 2000000 steps (89%)
04:32:17:WU02:FS01:0x18:Completed 1800000 out of 2000000 steps (90%)
04:32:33:WU02:FS01:0x18:Completed 1820000 out of 2000000 steps (91%)
04:32:47:WU02:FS01:0x18:Completed 1840000 out of 2000000 steps (92%)
04:33:02:WU02:FS01:0x18:Completed 1860000 out of 2000000 steps (93%)
04:33:16:WU02:FS01:0x18:Completed 1880000 out of 2000000 steps (94%)
04:33:30:WU02:FS01:0x18:Completed 1900000 out of 2000000 steps (95%)
04:33:46:WU02:FS01:0x18:Completed 1920000 out of 2000000 steps (96%)
04:34:01:WU02:FS01:0x18:Completed 1940000 out of 2000000 steps (97%)
04:34:15:WU02:FS01:0x18:Completed 1960000 out of 2000000 steps (98%)
04:34:30:WU02:FS01:0x18:Completed 1980000 out of 2000000 steps (99%)
04:34:44:WU02:FS01:0x18:Completed 2000000 out of 2000000 steps (100%)
04:34:45:WU01:FS01:Connecting to 171.67.108.45:80
04:34:45:WU02:FS01:0x18:Saving result file logfile_01.txt
04:34:45:WU02:FS01:0x18:Saving result file checkpointState.xml
04:34:45:WU01:FS01:Assigned to work server 171.67.108.105
04:34:45:WU01:FS01:Requesting new work unit for slot 01: RUNNING gpu:1:GP104 [GeForce GTX 1070] from 171.67.108.105
04:34:45:WU01:FS01:Connecting to 171.67.108.105:8080
04:34:45:WU02:FS01:0x18:Saving result file checkpt.crc
04:34:45:WU02:FS01:0x18:Saving result file log.txt
04:34:45:WU02:FS01:0x18:Saving result file positions.xtc
04:34:46:WU02:FS01:0x18:Folding@home Core Shutdown: FINISHED_UNIT
04:34:46:WU02:FS01:FahCore returned: FINISHED_UNIT (100 = 0x64)
04:34:46:WU02:FS01:Sending unit results: id:02 state:SEND error:NO_ERROR project:9657 run:0 clone:81 gen:50 core:0x18 unit:0x00000038ab436c9b56de69b97c37a007
04:34:46:WU02:FS01:Uploading 1.44MiB to 171.67.108.155
04:34:46:WU01:FS01:Downloading 22.62MiB
04:34:46:WU02:FS01:Connecting to 171.67.108.155:8080
04:34:52:WU01:FS01:Download 24.59%
04:34:52:WU02:FS01:Upload 77.91%
04:34:54:WU02:FS01:Upload complete
04:34:54:WU02:FS01:Server responded WORK_ACK (400)
04:34:54:WU02:FS01:Final credit estimate, 9037.00 points
04:34:54:WU02:FS01:Cleaning up
04:34:58:WU01:FS01:Download 41.73%
04:35:04:WU01:FS01:Download 58.59%
04:35:10:WU01:FS01:Download 72.95%
04:35:16:WU01:FS01:Download 91.47%
04:35:17:WU01:FS01:Download complete
04:35:17:WU01:FS01:Received Unit: id:01 state:DOWNLOAD error:NO_ERROR project:9177 run:21 clone:11 gen:51 core:0x21 unit:0x00000048ab436c6957b24c29db8b0edf
04:35:17:WU01:FS01:Starting
04:35:17:WU01:FS01:Running FahCore: "d:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" d:/Users/Lythronax/AppData/Roaming/FAHClient/cores/web.stanford.edu/~pande/Win32/AMD64/NVIDIA/Fermi/Core_21.fah/FahCore_21.exe -dir 01 -suffix 01 -version 704 -lifeline 6204 -checkpoint 15 -gpu 0 -gpu-vendor nvidia
04:35:17:WU01:FS01:Started FahCore on PID 4692
04:35:17:WU01:FS01:Core PID:5384
04:35:17:WU01:FS01:FahCore 0x21 started
04:35:18:WU01:FS01:0x21:*********************** Log Started 2016-10-27T04:35:18Z ***********************
04:35:18:WU01:FS01:0x21:Project: 9177 (Run 21, Clone 11, Gen 51)
04:35:18:WU01:FS01:0x21:Unit: 0x00000048ab436c6957b24c29db8b0edf
04:35:18:WU01:FS01:0x21:CPU: 0x00000000000000000000000000000000
04:35:18:WU01:FS01:0x21:Machine: 1
04:35:18:WU01:FS01:0x21:Reading tar file core.xml
04:35:18:WU01:FS01:0x21:Reading tar file integrator.xml
04:35:18:WU01:FS01:0x21:Reading tar file state.xml
04:35:18:WU01:FS01:0x21:Reading tar file system.xml
04:35:18:WU01:FS01:0x21:Digital signatures verified
04:35:18:WU01:FS01:0x21:Folding@home GPU Core21 Folding@home Core
04:35:18:WU01:FS01:0x21:Version 0.0.17
04:35:23:WU01:FS01:0x21:ERROR:exception: Error downloading array interactionCount: clEnqueueReadBuffer (-5)
04:35:23:WU01:FS01:0x21:Saving result file logfile_01.txt
04:35:23:WU01:FS01:0x21:Saving result file log.txt
04:35:23:WU01:FS01:0x21:Folding@home Core Shutdown: BAD_WORK_UNIT
04:35:25:WARNING:WU01:FS01:FahCore returned: BAD_WORK_UNIT (114 = 0x72)
04:35:25:WU01:FS01:Sending unit results: id:01 state:SEND error:FAULTY project:9177 run:21 clone:11 gen:51 core:0x21 unit:0x00000048ab436c6957b24c29db8b0edf
04:35:25:WU01:FS01:Uploading 7.00KiB to 171.67.108.105
04:35:25:WU01:FS01:Connecting to 171.67.108.105:8080
04:35:26:WU01:FS01:Upload complete
04:35:26:WU01:FS01:Server responded WORK_ACK (400)
04:35:26:WU01:FS01:Cleaning up
04:35:26:WU01:FS01:Connecting to 171.67.108.45:80
04:35:26:WU01:FS01:Assigned to work server 171.67.108.105
04:35:26:WU01:FS01:Requesting new work unit for slot 01: READY gpu:1:GP104 [GeForce GTX 1070] from 171.67.108.105
04:35:26:WU01:FS01:Connecting to 171.67.108.105:8080
04:35:27:WU01:FS01:Downloading 20.04MiB
04:35:33:WU01:FS01:Download 28.39%
04:35:39:WU01:FS01:Download 56.46%
04:35:45:WU01:FS01:Download 79.54%
04:35:51:WU01:FS01:Download 97.64%
04:35:51:WU01:FS01:Download complete
04:35:51:WU01:FS01:Received Unit: id:01 state:DOWNLOAD error:NO_ERROR project:9176 run:13 clone:7 gen:67 core:0x21 unit:0x0000005fab436c6957b24c284f7c7fa1
04:35:51:WU01:FS01:Starting
04:35:51:WU01:FS01:Running FahCore: "d:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" d:/Users/Lythronax/AppData/Roaming/FAHClient/cores/web.stanford.edu/~pande/Win32/AMD64/NVIDIA/Fermi/Core_21.fah/FahCore_21.exe -dir 01 -suffix 01 -version 704 -lifeline 6204 -checkpoint 15 -gpu 0 -gpu-vendor nvidia
04:35:51:WU01:FS01:Started FahCore on PID 7356
04:35:51:WU01:FS01:Core PID:4280
04:35:51:WU01:FS01:FahCore 0x21 started
04:35:52:WU01:FS01:0x21:*********************** Log Started 2016-10-27T04:35:52Z ***********************
04:35:52:WU01:FS01:0x21:Project: 9176 (Run 13, Clone 7, Gen 67)
04:35:52:WU01:FS01:0x21:Unit: 0x0000005fab436c6957b24c284f7c7fa1
04:35:52:WU01:FS01:0x21:CPU: 0x00000000000000000000000000000000
04:35:52:WU01:FS01:0x21:Machine: 1
04:35:52:WU01:FS01:0x21:Reading tar file core.xml
04:35:52:WU01:FS01:0x21:Reading tar file integrator.xml
04:35:52:WU01:FS01:0x21:Reading tar file state.xml
04:35:52:WU01:FS01:0x21:Reading tar file system.xml
04:35:52:WU01:FS01:0x21:Digital signatures verified
04:35:52:WU01:FS01:0x21:Folding@home GPU Core21 Folding@home Core
04:35:52:WU01:FS01:0x21:Version 0.0.17
04:35:57:WU01:FS01:0x21:ERROR:exception: Error downloading array interactionCount: clEnqueueReadBuffer (-5)
04:35:57:WU01:FS01:0x21:Saving result file logfile_01.txt
04:35:57:WU01:FS01:0x21:Saving result file log.txt
04:35:57:WU01:FS01:0x21:Folding@home Core Shutdown: BAD_WORK_UNIT
04:35:59:WARNING:WU01:FS01:FahCore returned: BAD_WORK_UNIT (114 = 0x72)
04:35:59:WU01:FS01:Sending unit results: id:01 state:SEND error:FAULTY project:9176 run:13 clone:7 gen:67 core:0x21 unit:0x0000005fab436c6957b24c284f7c7fa1
04:35:59:WU01:FS01:Uploading 7.00KiB to 171.67.108.105
04:35:59:WU01:FS01:Connecting to 171.67.108.105:8080
04:36:00:WU01:FS01:Upload complete
04:36:00:WU02:FS01:Connecting to 171.67.108.45:80
04:36:00:WU01:FS01:Server responded WORK_ACK (400)
04:36:00:WU01:FS01:Cleaning up
04:36:00:WU02:FS01:Assigned to work server 140.163.4.243
04:36:00:WU02:FS01:Requesting new work unit for slot 01: READY gpu:1:GP104 [GeForce GTX 1070] from 140.163.4.243
04:36:00:WU02:FS01:Connecting to 140.163.4.243:8080
04:36:01:WU02:FS01:Downloading 2.67MiB
04:36:03:WU02:FS01:Download complete
04:36:04:WU02:FS01:Received Unit: id:02 state:DOWNLOAD error:NO_ERROR project:11709 run:3 clone:235 gen:7 core:0x21 unit:0x0000000e8ca304f357f594f2b9cdd979
04:36:04:WU02:FS01:Starting
04:36:04:WU02:FS01:Running FahCore: "d:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" d:/Users/Lythronax/AppData/Roaming/FAHClient/cores/web.stanford.edu/~pande/Win32/AMD64/NVIDIA/Fermi/Core_21.fah/FahCore_21.exe -dir 02 -suffix 01 -version 704 -lifeline 6204 -checkpoint 15 -gpu 0 -gpu-vendor nvidia
04:36:04:WU02:FS01:Started FahCore on PID 5688
04:36:04:WU02:FS01:Core PID:6528
04:36:04:WU02:FS01:FahCore 0x21 started
04:36:04:WU02:FS01:0x21:*********************** Log Started 2016-10-27T04:36:04Z ***********************
04:36:04:WU02:FS01:0x21:Project: 11709 (Run 3, Clone 235, Gen 7)
04:36:04:WU02:FS01:0x21:Unit: 0x0000000e8ca304f357f594f2b9cdd979
04:36:04:WU02:FS01:0x21:CPU: 0x00000000000000000000000000000000
04:36:04:WU02:FS01:0x21:Machine: 1
04:36:04:WU02:FS01:0x21:Reading tar file core.xml
04:36:04:WU02:FS01:0x21:Reading tar file system.xml
04:36:04:WU02:FS01:0x21:Reading tar file integrator.xml
04:36:04:WU02:FS01:0x21:Reading tar file state.xml
04:36:05:WU02:FS01:0x21:Digital signatures verified
04:36:05:WU02:FS01:0x21:Folding@home GPU Core21 Folding@home Core
04:36:05:WU02:FS01:0x21:Version 0.0.17
04:36:09:WU02:FS01:0x21:ERROR:exception: Error downloading array interactionCount: clEnqueueReadBuffer (-5)
04:36:09:WU02:FS01:0x21:Saving result file logfile_01.txt
04:36:09:WU02:FS01:0x21:Saving result file log.txt
04:36:09:WU02:FS01:0x21:Folding@home Core Shutdown: BAD_WORK_UNIT
04:36:10:WARNING:WU02:FS01:FahCore returned: BAD_WORK_UNIT (114 = 0x72)
04:36:10:WU02:FS01:Sending unit results: id:02 state:SEND error:FAULTY project:11709 run:3 clone:235 gen:7 core:0x21 unit:0x0000000e8ca304f357f594f2b9cdd979
04:36:10:WU02:FS01:Uploading 2.41KiB to 140.163.4.243
04:36:10:WU02:FS01:Connecting to 140.163.4.243:8080
04:36:10:WU02:FS01:Upload complete
04:36:10:WU02:FS01:Server responded WORK_ACK (400)
04:36:10:WU02:FS01:Cleaning up
04:36:10:WU01:FS01:Connecting to 171.67.108.45:80
04:36:11:WU01:FS01:Assigned to work server 140.163.4.244
04:36:11:WU01:FS01:Requesting new work unit for slot 01: READY gpu:1:GP104 [GeForce GTX 1070] from 140.163.4.244
04:36:11:WU01:FS01:Connecting to 140.163.4.244:8080
04:36:11:WU01:FS01:Downloading 2.77MiB
04:36:14:WU01:FS01:Download complete
04:36:14:WU01:FS01:Received Unit: id:01 state:DOWNLOAD error:NO_ERROR project:13500 run:1 clone:856 gen:28 core:0x21 unit:0x000000288ca304f457a35972758d46f8
04:36:14:WU01:FS01:Starting
04:36:14:WU01:FS01:Running FahCore: "d:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" d:/Users/Lythronax/AppData/Roaming/FAHClient/cores/web.stanford.edu/~pande/Win32/AMD64/NVIDIA/Fermi/Core_21.fah/FahCore_21.exe -dir 01 -suffix 01 -version 704 -lifeline 6204 -checkpoint 15 -gpu 0 -gpu-vendor nvidia
04:36:14:WU01:FS01:Started FahCore on PID 4268
04:36:14:WU01:FS01:Core PID:6152
04:36:14:WU01:FS01:FahCore 0x21 started
04:36:14:WU01:FS01:0x21:*********************** Log Started 2016-10-27T04:36:14Z ***********************
04:36:14:WU01:FS01:0x21:Project: 13500 (Run 1, Clone 856, Gen 28)
04:36:14:WU01:FS01:0x21:Unit: 0x000000288ca304f457a35972758d46f8
04:36:14:WU01:FS01:0x21:CPU: 0x00000000000000000000000000000000
04:36:14:WU01:FS01:0x21:Machine: 1
04:36:14:WU01:FS01:0x21:Reading tar file core.xml
04:36:14:WU01:FS01:0x21:Reading tar file system.xml
04:36:14:WU01:FS01:0x21:Reading tar file integrator.xml
04:36:14:WU01:FS01:0x21:Reading tar file state.xml
04:36:15:WU01:FS01:0x21:Digital signatures verified
04:36:15:WU01:FS01:0x21:Folding@home GPU Core21 Folding@home Core
04:36:15:WU01:FS01:0x21:Version 0.0.17
04:36:17:WU01:FS01:0x21:ERROR:exception: Error downloading array interactionCount: clEnqueueReadBuffer (-5)
04:36:17:WU01:FS01:0x21:Saving result file logfile_01.txt
04:36:17:WU01:FS01:0x21:Saving result file log.txt
04:36:17:WU01:FS01:0x21:Folding@home Core Shutdown: BAD_WORK_UNIT
04:36:20:WARNING:WU01:FS01:FahCore returned: BAD_WORK_UNIT (114 = 0x72)
04:36:20:WU01:FS01:Sending unit results: id:01 state:SEND error:FAULTY project:13500 run:1 clone:856 gen:28 core:0x21 unit:0x000000288ca304f457a35972758d46f8
04:36:20:WU01:FS01:Uploading 2.40KiB to 140.163.4.244
04:36:20:WU01:FS01:Connecting to 140.163.4.244:8080
04:36:20:WU01:FS01:Upload complete
04:36:20:WU01:FS01:Server responded WORK_ACK (400)
04:36:20:WU01:FS01:Cleaning up
04:36:20:WU02:FS01:Connecting to 171.67.108.45:80
04:36:21:WU02:FS01:Assigned to work server 171.64.65.84
04:36:21:WU02:FS01:Requesting new work unit for slot 01: READY gpu:1:GP104 [GeForce GTX 1070] from 171.64.65.84
04:36:21:WU02:FS01:Connecting to 171.64.65.84:8080
04:36:21:WU02:FS01:Downloading 2.52MiB
04:36:27:WU02:FS01:Download 49.52%
04:36:33:WU02:FS01:Download 94.08%
04:36:34:WU02:FS01:Download complete
04:36:34:WU02:FS01:Received Unit: id:02 state:DOWNLOAD error:NO_ERROR project:9189 run:1 clone:13 gen:72 core:0x21 unit:0x00000067ab40415457cb2bbc91ea2f27
04:36:34:WU02:FS01:Starting
04:36:34:WU02:FS01:Running FahCore: "d:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" d:/Users/Lythronax/AppData/Roaming/FAHClient/cores/web.stanford.edu/~pande/Win32/AMD64/NVIDIA/Fermi/Core_21.fah/FahCore_21.exe -dir 02 -suffix 01 -version 704 -lifeline 6204 -checkpoint 15 -gpu 0 -gpu-vendor nvidia
04:36:34:WU02:FS01:Started FahCore on PID 2620
04:36:34:WU02:FS01:Core PID:8672
04:36:34:WU02:FS01:FahCore 0x21 started
04:36:35:WU02:FS01:0x21:*********************** Log Started 2016-10-27T04:36:34Z ***********************
04:36:35:WU02:FS01:0x21:Project: 9189 (Run 1, Clone 13, Gen 72)
04:36:35:WU02:FS01:0x21:Unit: 0x00000067ab40415457cb2bbc91ea2f27
04:36:35:WU02:FS01:0x21:CPU: 0x00000000000000000000000000000000
04:36:35:WU02:FS01:0x21:Machine: 1
04:36:35:WU02:FS01:0x21:Reading tar file core.xml
04:36:35:WU02:FS01:0x21:Reading tar file system.xml
04:36:35:WU02:FS01:0x21:Reading tar file integrator.xml
04:36:35:WU02:FS01:0x21:Reading tar file state.xml
04:36:35:WU02:FS01:0x21:Digital signatures verified
04:36:35:WU02:FS01:0x21:Folding@home GPU Core21 Folding@home Core
04:36:35:WU02:FS01:0x21:Version 0.0.17
04:36:39:WU02:FS01:0x21:ERROR:exception: Error downloading array interactionCount: clEnqueueReadBuffer (-5)
04:36:39:WU02:FS01:0x21:Saving result file logfile_01.txt
04:36:39:WU02:FS01:0x21:Saving result file log.txt
04:36:39:WU02:FS01:0x21:Folding@home Core Shutdown: BAD_WORK_UNIT
04:36:42:WARNING:WU02:FS01:FahCore returned: BAD_WORK_UNIT (114 = 0x72)
04:36:42:WU02:FS01:Sending unit results: id:02 state:SEND error:FAULTY project:9189 run:1 clone:13 gen:72 core:0x21 unit:0x00000067ab40415457cb2bbc91ea2f27
04:36:42:WU02:FS01:Uploading 2.40KiB to 171.64.65.84
04:36:42:WU02:FS01:Connecting to 171.64.65.84:8080
04:36:42:WU02:FS01:Upload complete
04:36:42:WU02:FS01:Server responded WORK_ACK (400)
04:36:42:WU02:FS01:Cleaning up
04:36:42:WU01:FS01:Connecting to 171.67.108.45:80
04:36:42:WU01:FS01:Assigned to work server 171.67.108.159
04:36:42:WU01:FS01:Requesting new work unit for slot 01: READY gpu:1:GP104 [GeForce GTX 1070] from 171.67.108.159
04:36:42:WU01:FS01:Connecting to 171.67.108.159:8080
04:36:43:WU01:FS01:Downloading 22.46MiB
04:36:49:WU01:FS01:Download 27.82%
04:36:55:WU01:FS01:Download 45.63%
04:37:01:WU01:FS01:Download 63.99%
04:37:07:WU01:FS01:Download 86.52%
04:37:11:WU01:FS01:Download complete
04:37:11:WU01:FS01:Received Unit: id:01 state:DOWNLOAD error:NO_ERROR project:9180 run:5 clone:2 gen:91 core:0x21 unit:0x00000077ab436c9f57bdce05e66f8410
04:37:11:WU01:FS01:Starting
04:37:11:WU01:FS01:Running FahCore: "d:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" d:/Users/Lythronax/AppData/Roaming/FAHClient/cores/web.stanford.edu/~pande/Win32/AMD64/NVIDIA/Fermi/Core_21.fah/FahCore_21.exe -dir 01 -suffix 01 -version 704 -lifeline 6204 -checkpoint 15 -gpu 0 -gpu-vendor nvidia
04:37:11:WU01:FS01:Started FahCore on PID 7428
04:37:11:WU01:FS01:Core PID:4080
04:37:11:WU01:FS01:FahCore 0x21 started
04:37:12:WU01:FS01:0x21:*********************** Log Started 2016-10-27T04:37:11Z ***********************
04:37:12:WU01:FS01:0x21:Project: 9180 (Run 5, Clone 2, Gen 91)
04:37:12:WU01:FS01:0x21:Unit: 0x00000077ab436c9f57bdce05e66f8410
04:37:12:WU01:FS01:0x21:CPU: 0x00000000000000000000000000000000
04:37:12:WU01:FS01:0x21:Machine: 1
04:37:12:WU01:FS01:0x21:Reading tar file core.xml
04:37:12:WU01:FS01:0x21:Reading tar file integrator.xml
04:37:12:WU01:FS01:0x21:Reading tar file state.xml
04:37:12:WU01:FS01:0x21:Reading tar file system.xml
04:37:12:WU01:FS01:0x21:Digital signatures verified
04:37:12:WU01:FS01:0x21:Folding@home GPU Core21 Folding@home Core
04:37:12:WU01:FS01:0x21:Version 0.0.17
04:37:16:WU01:FS01:0x21:ERROR:exception: Error downloading array interactionCount: clEnqueueReadBuffer (-5)
04:37:16:WU01:FS01:0x21:Saving result file logfile_01.txt
04:37:16:WU01:FS01:0x21:Saving result file log.txt
04:37:16:WU01:FS01:0x21:Folding@home Core Shutdown: BAD_WORK_UNIT
04:37:19:WARNING:WU01:FS01:FahCore returned: BAD_WORK_UNIT (114 = 0x72)
04:37:19:WU01:FS01:Sending unit results: id:01 state:SEND error:FAULTY project:9180 run:5 clone:2 gen:91 core:0x21 unit:0x00000077ab436c9f57bdce05e66f8410
04:37:19:WU01:FS01:Uploading 7.00KiB to 171.67.108.159
04:37:19:WU01:FS01:Connecting to 171.67.108.159:8080
04:37:19:WU01:FS01:Upload complete
04:37:19:WU01:FS01:Server responded WORK_ACK (400)
04:37:19:WU01:FS01:Cleaning up
04:37:19:WU02:FS01:Connecting to 171.67.108.45:80
04:37:20:WU02:FS01:Assigned to work server 171.67.108.155
04:37:20:WU02:FS01:Requesting new work unit for slot 01: READY gpu:1:GP104 [GeForce GTX 1070] from 171.67.108.155
04:37:20:WU02:FS01:Connecting to 171.67.108.155:8080
04:37:21:WU02:FS01:Downloading 747.14KiB
04:37:23:WU02:FS01:Download complete
04:37:23:WU02:FS01:Received Unit: id:02 state:DOWNLOAD error:NO_ERROR project:9657 run:0 clone:81 gen:51 core:0x18 unit:0x00000039ab436c9b56de69b97c37a007
04:37:23:WU02:FS01:Starting
04:37:23:WU02:FS01:Running FahCore: "d:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" d:/Users/Lythronax/AppData/Roaming/FAHClient/cores/web.stanford.edu/~pande/Win32/AMD64/NVIDIA/Fermi/Core_18.fah/FahCore_18.exe -dir 02 -suffix 01 -version 704 -lifeline 6204 -checkpoint 15 -gpu 0 -gpu-vendor nvidia
04:37:23:WU02:FS01:Started FahCore on PID 6736
04:37:23:WU02:FS01:Core PID:6692
04:37:23:WU02:FS01:FahCore 0x18 started
MEGIDDO
Post by MEGIDDO »
Log continued, Part 2:
04:37:24:WU02:FS01:0x18:*********************** Log Started 2016-10-27T04:37:24Z ***********************
04:37:24:WU02:FS01:0x18:Project: 9657 (Run 0, Clone 81, Gen 51)
04:37:24:WU02:FS01:0x18:Unit: 0x00000039ab436c9b56de69b97c37a007
04:37:24:WU02:FS01:0x18:CPU: 0x00000000000000000000000000000000
04:37:24:WU02:FS01:0x18:Machine: 1
04:37:24:WU02:FS01:0x18:Reading tar file core.xml
04:37:24:WU02:FS01:0x18:Reading tar file integrator.xml
04:37:24:WU02:FS01:0x18:Reading tar file state.xml
04:37:24:WU02:FS01:0x18:Reading tar file system.xml
04:37:24:WU02:FS01:0x18:Digital signatures verified
04:37:24:WU02:FS01:0x18:Folding@home GPU core18
04:37:24:WU02:FS01:0x18:Version 0.0.4
04:37:27:WU02:FS01:0x18:Completed 0 out of 2000000 steps (0%)
04:37:27:WU02:FS01:0x18:Temperature control disabled. Requirements: single Nvidia GPU, tmax must be < 110 and twait >= 900
04:37:42:WU02:FS01:0x18:Completed 20000 out of 2000000 steps (1%)
04:37:56:WU02:FS01:0x18:Completed 40000 out of 2000000 steps (2%)
04:38:11:WU02:FS01:0x18:Completed 60000 out of 2000000 steps (3%)
04:38:25:WU02:FS01:0x18:Completed 80000 out of 2000000 steps (4%)
04:38:39:WU02:FS01:0x18:Completed 100000 out of 2000000 steps (5%)
04:38:55:WU02:FS01:0x18:Completed 120000 out of 2000000 steps (6%)
04:39:09:WU02:FS01:0x18:Completed 140000 out of 2000000 steps (7%)
04:39:23:WU02:FS01:0x18:Completed 160000 out of 2000000 steps (8%)
04:39:38:WU02:FS01:0x18:Completed 180000 out of 2000000 steps (9%)
04:39:52:WU02:FS01:0x18:Completed 200000 out of 2000000 steps (10%)
04:40:08:WU02:FS01:0x18:Completed 220000 out of 2000000 steps (11%)
04:40:22:WU02:FS01:0x18:Completed 240000 out of 2000000 steps (12%)
04:40:37:WU02:FS01:0x18:Completed 260000 out of 2000000 steps (13%)
04:40:51:WU02:FS01:0x18:Completed 280000 out of 2000000 steps (14%)
04:41:06:WU02:FS01:0x18:Completed 300000 out of 2000000 steps (15%)
04:41:21:WU02:FS01:0x18:Completed 320000 out of 2000000 steps (16%)
04:41:36:WU02:FS01:0x18:Completed 340000 out of 2000000 steps (17%)
04:41:50:WU02:FS01:0x18:Completed 360000 out of 2000000 steps (18%)
04:42:04:WU02:FS01:0x18:Completed 380000 out of 2000000 steps (19%)
04:42:19:WU02:FS01:0x18:Completed 400000 out of 2000000 steps (20%)
04:42:34:WU02:FS01:0x18:Completed 420000 out of 2000000 steps (21%)
04:42:49:WU02:FS01:0x18:Completed 440000 out of 2000000 steps (22%)
04:43:03:WU02:FS01:0x18:Completed 460000 out of 2000000 steps (23%)
04:43:18:WU02:FS01:0x18:Completed 480000 out of 2000000 steps (24%)
04:43:32:WU02:FS01:0x18:Completed 500000 out of 2000000 steps (25%)
04:43:47:WU02:FS01:0x18:Completed 520000 out of 2000000 steps (26%)
04:44:02:WU02:FS01:0x18:Completed 540000 out of 2000000 steps (27%)
04:44:16:WU02:FS01:0x18:Completed 560000 out of 2000000 steps (28%)
04:44:31:WU02:FS01:0x18:Completed 580000 out of 2000000 steps (29%)
04:44:45:WU02:FS01:0x18:Completed 600000 out of 2000000 steps (30%)
04:45:01:WU02:FS01:0x18:Completed 620000 out of 2000000 steps (31%)
04:45:15:WU02:FS01:0x18:Completed 640000 out of 2000000 steps (32%)
04:45:29:WU02:FS01:0x18:Completed 660000 out of 2000000 steps (33%)
04:45:44:WU02:FS01:0x18:Completed 680000 out of 2000000 steps (34%)
04:45:58:WU02:FS01:0x18:Completed 700000 out of 2000000 steps (35%)
04:46:14:WU02:FS01:0x18:Completed 720000 out of 2000000 steps (36%)
04:46:28:WU02:FS01:0x18:Completed 740000 out of 2000000 steps (37%)
04:46:42:WU02:FS01:0x18:Completed 760000 out of 2000000 steps (38%)
04:46:57:WU02:FS01:0x18:Completed 780000 out of 2000000 steps (39%)
04:47:11:WU02:FS01:0x18:Completed 800000 out of 2000000 steps (40%)
04:47:27:WU02:FS01:0x18:Completed 820000 out of 2000000 steps (41%)
04:47:41:WU02:FS01:0x18:Completed 840000 out of 2000000 steps (42%)
04:47:56:WU02:FS01:0x18:Completed 860000 out of 2000000 steps (43%)
04:48:10:WU02:FS01:0x18:Completed 880000 out of 2000000 steps (44%)
04:48:25:WU02:FS01:0x18:Completed 900000 out of 2000000 steps (45%)
04:48:40:WU02:FS01:0x18:Completed 920000 out of 2000000 steps (46%)
04:48:55:WU02:FS01:0x18:Completed 940000 out of 2000000 steps (47%)
04:49:09:WU02:FS01:0x18:Completed 960000 out of 2000000 steps (48%)
04:49:23:WU02:FS01:0x18:Completed 980000 out of 2000000 steps (49%)
04:49:38:WU02:FS01:0x18:Completed 1000000 out of 2000000 steps (50%)
04:49:53:WU02:FS01:0x18:Completed 1020000 out of 2000000 steps (51%)
04:50:08:WU02:FS01:0x18:Completed 1040000 out of 2000000 steps (52%)
04:50:22:WU02:FS01:0x18:Completed 1060000 out of 2000000 steps (53%)
04:50:36:WU02:FS01:0x18:Completed 1080000 out of 2000000 steps (54%)
04:50:51:WU02:FS01:0x18:Completed 1100000 out of 2000000 steps (55%)
04:51:06:WU02:FS01:0x18:Completed 1120000 out of 2000000 steps (56%)
04:51:21:WU02:FS01:0x18:Completed 1140000 out of 2000000 steps (57%)
04:51:35:WU02:FS01:0x18:Completed 1160000 out of 2000000 steps (58%)
04:51:50:WU02:FS01:0x18:Completed 1180000 out of 2000000 steps (59%)
04:52:04:WU02:FS01:0x18:Completed 1200000 out of 2000000 steps (60%)
04:52:20:WU02:FS01:0x18:Completed 1220000 out of 2000000 steps (61%)
04:52:34:WU02:FS01:0x18:Completed 1240000 out of 2000000 steps (62%)
04:52:48:WU02:FS01:0x18:Completed 1260000 out of 2000000 steps (63%)
04:53:03:WU02:FS01:0x18:Completed 1280000 out of 2000000 steps (64%)
04:53:17:WU02:FS01:0x18:Completed 1300000 out of 2000000 steps (65%)
04:53:33:WU02:FS01:0x18:Completed 1320000 out of 2000000 steps (66%)
04:53:47:WU02:FS01:0x18:Completed 1340000 out of 2000000 steps (67%)
04:54:02:WU02:FS01:0x18:Completed 1360000 out of 2000000 steps (68%)
04:54:16:WU02:FS01:0x18:Completed 1380000 out of 2000000 steps (69%)
04:54:30:WU02:FS01:0x18:Completed 1400000 out of 2000000 steps (70%)
04:54:46:WU02:FS01:0x18:Completed 1420000 out of 2000000 steps (71%)
04:55:00:WU02:FS01:0x18:Completed 1440000 out of 2000000 steps (72%)
04:55:15:WU02:FS01:0x18:Completed 1460000 out of 2000000 steps (73%)
04:55:29:WU02:FS01:0x18:Completed 1480000 out of 2000000 steps (74%)
04:55:44:WU02:FS01:0x18:Completed 1500000 out of 2000000 steps (75%)
04:55:59:WU02:FS01:0x18:Completed 1520000 out of 2000000 steps (76%)
04:56:14:WU02:FS01:0x18:Completed 1540000 out of 2000000 steps (77%)
04:56:28:WU02:FS01:0x18:Completed 1560000 out of 2000000 steps (78%)
04:56:42:WU02:FS01:0x18:Completed 1580000 out of 2000000 steps (79%)
04:56:57:WU02:FS01:0x18:Completed 1600000 out of 2000000 steps (80%)
04:57:13:WU02:FS01:0x18:Completed 1620000 out of 2000000 steps (81%)
04:57:27:WU02:FS01:0x18:Completed 1640000 out of 2000000 steps (82%)
04:57:41:WU02:FS01:0x18:Completed 1660000 out of 2000000 steps (83%)
04:57:56:WU02:FS01:0x18:Completed 1680000 out of 2000000 steps (84%)
04:58:10:WU02:FS01:0x18:Completed 1700000 out of 2000000 steps (85%)
04:58:26:WU02:FS01:0x18:Completed 1720000 out of 2000000 steps (86%)
04:58:40:WU02:FS01:0x18:Completed 1740000 out of 2000000 steps (87%)
04:58:54:WU02:FS01:0x18:Completed 1760000 out of 2000000 steps (88%)
04:59:09:WU02:FS01:0x18:Completed 1780000 out of 2000000 steps (89%)
04:59:23:WU02:FS01:0x18:Completed 1800000 out of 2000000 steps (90%)
04:59:39:WU02:FS01:0x18:Completed 1820000 out of 2000000 steps (91%)
04:59:53:WU02:FS01:0x18:Completed 1840000 out of 2000000 steps (92%)
05:00:08:WU02:FS01:0x18:Completed 1860000 out of 2000000 steps (93%)
05:00:22:WU02:FS01:0x18:Completed 1880000 out of 2000000 steps (94%)
05:00:36:WU02:FS01:0x18:Completed 1900000 out of 2000000 steps (95%)
05:00:52:WU02:FS01:0x18:Completed 1920000 out of 2000000 steps (96%)
05:01:06:WU02:FS01:0x18:Completed 1940000 out of 2000000 steps (97%)
05:01:21:WU02:FS01:0x18:Completed 1960000 out of 2000000 steps (98%)
05:01:35:WU02:FS01:0x18:Completed 1980000 out of 2000000 steps (99%)
05:01:50:WU02:FS01:0x18:Completed 2000000 out of 2000000 steps (100%)
05:01:50:WU01:FS01:Connecting to 171.67.108.45:80
05:01:50:WU01:FS01:Assigned to work server 171.67.108.105
05:01:50:WU01:FS01:Requesting new work unit for slot 01: RUNNING gpu:1:GP104 [GeForce GTX 1070] from 171.67.108.105
05:01:50:WU01:FS01:Connecting to 171.67.108.105:8080
05:01:51:WU01:FS01:Downloading 21.10MiB
05:01:51:WU02:FS01:0x18:Saving result file logfile_01.txt
05:01:51:WU02:FS01:0x18:Saving result file checkpointState.xml
05:01:51:WU02:FS01:0x18:Saving result file checkpt.crc
05:01:51:WU02:FS01:0x18:Saving result file log.txt
05:01:51:WU02:FS01:0x18:Saving result file positions.xtc
05:01:51:WU02:FS01:0x18:Folding@home Core Shutdown: FINISHED_UNIT
05:01:52:WU02:FS01:FahCore returned: FINISHED_UNIT (100 = 0x64)
05:01:52:WU02:FS01:Sending unit results: id:02 state:SEND error:NO_ERROR project:9657 run:0 clone:81 gen:51 core:0x18 unit:0x00000039ab436c9b56de69b97c37a007
05:01:52:WU02:FS01:Uploading 1.44MiB to 171.67.108.155
05:01:52:WU02:FS01:Connecting to 171.67.108.155:8080
05:01:57:WU01:FS01:Download 4.44%
05:01:58:WU02:FS01:Upload 47.61%
05:02:03:WU01:FS01:Download 27.26%
05:02:04:WU02:FS01:Upload 95.22%
05:02:06:WU02:FS01:Upload complete
05:02:06:WU02:FS01:Server responded WORK_ACK (400)
05:02:06:WU02:FS01:Final credit estimate, 9049.00 points
05:02:06:WU02:FS01:Cleaning up
05:02:09:WU01:FS01:Download 45.33%
05:02:15:WU01:FS01:Download 65.77%
05:02:21:WU01:FS01:Download 79.10%
05:02:27:WU01:FS01:Download 91.84%
05:02:29:WU01:FS01:Download complete
05:02:29:WU01:FS01:Received Unit: id:01 state:DOWNLOAD error:NO_ERROR project:9176 run:5 clone:4 gen:63 core:0x21 unit:0x00000052ab436c6957b24c28d59f1173
05:02:29:WU01:FS01:Starting
05:02:29:WU01:FS01:Running FahCore: "d:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" d:/Users/Lythronax/AppData/Roaming/FAHClient/cores/web.stanford.edu/~pande/Win32/AMD64/NVIDIA/Fermi/Core_21.fah/FahCore_21.exe -dir 01 -suffix 01 -version 704 -lifeline 6204 -checkpoint 15 -gpu 0 -gpu-vendor nvidia
05:02:29:WU01:FS01:Started FahCore on PID 5876
05:02:29:WU01:FS01:Core PID:6656
05:02:29:WU01:FS01:FahCore 0x21 started
05:02:30:WU01:FS01:0x21:*********************** Log Started 2016-10-27T05:02:29Z ***********************
05:02:30:WU01:FS01:0x21:Project: 9176 (Run 5, Clone 4, Gen 63)
05:02:30:WU01:FS01:0x21:Unit: 0x00000052ab436c6957b24c28d59f1173
05:02:30:WU01:FS01:0x21:CPU: 0x00000000000000000000000000000000
05:02:30:WU01:FS01:0x21:Machine: 1
05:02:30:WU01:FS01:0x21:Reading tar file core.xml
05:02:30:WU01:FS01:0x21:Reading tar file integrator.xml
05:02:30:WU01:FS01:0x21:Reading tar file state.xml
05:02:30:WU01:FS01:0x21:Reading tar file system.xml
05:02:30:WU01:FS01:0x21:Digital signatures verified
05:02:30:WU01:FS01:0x21:Folding@home GPU Core21 Folding@home Core
05:02:30:WU01:FS01:0x21:Version 0.0.17
05:02:36:WU01:FS01:0x21:ERROR:exception: Error downloading array interactionCount: clEnqueueReadBuffer (-5)
05:02:36:WU01:FS01:0x21:Saving result file logfile_01.txt
05:02:36:WU01:FS01:0x21:Saving result file log.txt
05:02:36:WU01:FS01:0x21:Folding@home Core Shutdown: BAD_WORK_UNIT
05:02:37:WARNING:WU01:FS01:FahCore returned: BAD_WORK_UNIT (114 = 0x72)
05:02:37:WU01:FS01:Sending unit results: id:01 state:SEND error:FAULTY project:9176 run:5 clone:4 gen:63 core:0x21 unit:0x00000052ab436c6957b24c28d59f1173
05:02:37:WU01:FS01:Uploading 7.00KiB to 171.67.108.105
05:02:37:WU01:FS01:Connecting to 171.67.108.105:8080
05:02:37:WU01:FS01:Upload complete
05:02:37:WU01:FS01:Server responded WORK_ACK (400)
05:02:37:WU01:FS01:Cleaning up
05:02:37:WU02:FS01:Connecting to 171.67.108.45:80
05:02:38:WU02:FS01:Assigned to work server 171.67.108.155
05:02:38:WU02:FS01:Requesting new work unit for slot 01: READY gpu:1:GP104 [GeForce GTX 1070] from 171.67.108.155
05:02:38:WU02:FS01:Connecting to 171.67.108.155:8080
05:02:39:WU02:FS01:Downloading 747.04KiB
05:02:41:WU02:FS01:Download complete
05:02:41:WU02:FS01:Received Unit: id:02 state:DOWNLOAD error:NO_ERROR project:9657 run:0 clone:81 gen:52 core:0x18 unit:0x0000003aab436c9b56de69b97c37a007
05:02:41:WU02:FS01:Starting
05:02:41:WU02:FS01:Running FahCore: "d:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" d:/Users/Lythronax/AppData/Roaming/FAHClient/cores/web.stanford.edu/~pande/Win32/AMD64/NVIDIA/Fermi/Core_18.fah/FahCore_18.exe -dir 02 -suffix 01 -version 704 -lifeline 6204 -checkpoint 15 -gpu 0 -gpu-vendor nvidia
05:02:41:WU02:FS01:Started FahCore on PID 6976
05:02:41:WU02:FS01:Core PID:9144
05:02:41:WU02:FS01:FahCore 0x18 started
05:02:42:WU02:FS01:0x18:*********************** Log Started 2016-10-27T05:02:42Z ***********************
05:02:42:WU02:FS01:0x18:Project: 9657 (Run 0, Clone 81, Gen 52)
05:02:42:WU02:FS01:0x18:Unit: 0x0000003aab436c9b56de69b97c37a007
05:02:42:WU02:FS01:0x18:CPU: 0x00000000000000000000000000000000
05:02:42:WU02:FS01:0x18:Machine: 1
05:02:42:WU02:FS01:0x18:Reading tar file core.xml
05:02:42:WU02:FS01:0x18:Reading tar file integrator.xml
05:02:42:WU02:FS01:0x18:Reading tar file state.xml
05:02:42:WU02:FS01:0x18:Reading tar file system.xml
05:02:42:WU02:FS01:0x18:Digital signatures verified
05:02:42:WU02:FS01:0x18:Folding@home GPU core18
05:02:42:WU02:FS01:0x18:Version 0.0.4
05:02:45:WU02:FS01:0x18:Completed 0 out of 2000000 steps (0%)
05:02:45:WU02:FS01:0x18:Temperature control disabled. Requirements: single Nvidia GPU, tmax must be < 110 and twait >= 900
05:03:00:WU02:FS01:0x18:Completed 20000 out of 2000000 steps (1%)
05:03:15:WU02:FS01:0x18:Completed 40000 out of 2000000 steps (2%)
05:03:29:WU02:FS01:0x18:Completed 60000 out of 2000000 steps (3%)
05:03:43:WU02:FS01:0x18:Completed 80000 out of 2000000 steps (4%)
05:03:58:WU02:FS01:0x18:Completed 100000 out of 2000000 steps (5%)
05:04:13:WU02:FS01:0x18:Completed 120000 out of 2000000 steps (6%)
05:04:28:WU02:FS01:0x18:Completed 140000 out of 2000000 steps (7%)
05:04:42:WU02:FS01:0x18:Completed 160000 out of 2000000 steps (8%)
05:04:57:WU02:FS01:0x18:Completed 180000 out of 2000000 steps (9%)
05:05:11:WU02:FS01:0x18:Completed 200000 out of 2000000 steps (10%)
05:05:27:WU02:FS01:0x18:Completed 220000 out of 2000000 steps (11%)
05:05:41:WU02:FS01:0x18:Completed 240000 out of 2000000 steps (12%)
05:05:55:WU02:FS01:0x18:Completed 260000 out of 2000000 steps (13%)
05:06:10:WU02:FS01:0x18:Completed 280000 out of 2000000 steps (14%)
05:06:24:WU02:FS01:0x18:Completed 300000 out of 2000000 steps (15%)
05:06:40:WU02:FS01:0x18:Completed 320000 out of 2000000 steps (16%)
05:06:54:WU02:FS01:0x18:Completed 340000 out of 2000000 steps (17%)
05:07:08:WU02:FS01:0x18:Completed 360000 out of 2000000 steps (18%)
05:07:23:WU02:FS01:0x18:Completed 380000 out of 2000000 steps (19%)
05:07:37:WU02:FS01:0x18:Completed 400000 out of 2000000 steps (20%)
05:07:53:WU02:FS01:0x18:Completed 420000 out of 2000000 steps (21%)
05:08:07:WU02:FS01:0x18:Completed 440000 out of 2000000 steps (22%)
05:08:22:WU02:FS01:0x18:Completed 460000 out of 2000000 steps (23%)
05:08:36:WU02:FS01:0x18:Completed 480000 out of 2000000 steps (24%)
05:08:50:WU02:FS01:0x18:Completed 500000 out of 2000000 steps (25%)
05:09:06:WU02:FS01:0x18:Completed 520000 out of 2000000 steps (26%)
05:09:20:WU02:FS01:0x18:Completed 540000 out of 2000000 steps (27%)
05:09:35:WU02:FS01:0x18:Completed 560000 out of 2000000 steps (28%)
05:09:49:WU02:FS01:0x18:Completed 580000 out of 2000000 steps (29%)
05:10:03:WU02:FS01:0x18:Completed 600000 out of 2000000 steps (30%)
05:10:19:WU02:FS01:0x18:Completed 620000 out of 2000000 steps (31%)
05:10:33:WU02:FS01:0x18:Completed 640000 out of 2000000 steps (32%)
05:10:48:WU02:FS01:0x18:Completed 660000 out of 2000000 steps (33%)
05:11:02:WU02:FS01:0x18:Completed 680000 out of 2000000 steps (34%)
05:11:17:WU02:FS01:0x18:Completed 700000 out of 2000000 steps (35%)
05:11:32:WU02:FS01:0x18:Completed 720000 out of 2000000 steps (36%)
05:11:47:WU02:FS01:0x18:Completed 740000 out of 2000000 steps (37%)
05:12:01:WU02:FS01:0x18:Completed 760000 out of 2000000 steps (38%)
05:12:16:WU02:FS01:0x18:Completed 780000 out of 2000000 steps (39%)
05:12:30:WU02:FS01:0x18:Completed 800000 out of 2000000 steps (40%)
05:12:46:WU02:FS01:0x18:Completed 820000 out of 2000000 steps (41%)
05:13:00:WU02:FS01:0x18:Completed 840000 out of 2000000 steps (42%)
05:13:15:WU02:FS01:0x18:Completed 860000 out of 2000000 steps (43%)
05:13:29:WU02:FS01:0x18:Completed 880000 out of 2000000 steps (44%)
05:13:43:WU02:FS01:0x18:Completed 900000 out of 2000000 steps (45%)
05:13:59:WU02:FS01:0x18:Completed 920000 out of 2000000 steps (46%)
05:14:13:WU02:FS01:0x18:Completed 940000 out of 2000000 steps (47%)
05:14:28:WU02:FS01:0x18:Completed 960000 out of 2000000 steps (48%)
05:14:42:WU02:FS01:0x18:Completed 980000 out of 2000000 steps (49%)
05:14:57:WU02:FS01:0x18:Completed 1000000 out of 2000000 steps (50%)
05:15:12:WU02:FS01:0x18:Completed 1020000 out of 2000000 steps (51%)
05:15:27:WU02:FS01:0x18:Completed 1040000 out of 2000000 steps (52%)
05:15:41:WU02:FS01:0x18:Completed 1060000 out of 2000000 steps (53%)
05:15:56:WU02:FS01:0x18:Completed 1080000 out of 2000000 steps (54%)
05:16:10:WU02:FS01:0x18:Completed 1100000 out of 2000000 steps (55%)
05:16:26:WU02:FS01:0x18:Completed 1120000 out of 2000000 steps (56%)
05:16:40:WU02:FS01:0x18:Completed 1140000 out of 2000000 steps (57%)
05:16:55:WU02:FS01:0x18:Completed 1160000 out of 2000000 steps (58%)
05:17:09:WU02:FS01:0x18:Completed 1180000 out of 2000000 steps (59%)
05:17:23:WU02:FS01:0x18:Completed 1200000 out of 2000000 steps (60%)
05:17:39:WU02:FS01:0x18:Completed 1220000 out of 2000000 steps (61%)
05:17:53:WU02:FS01:0x18:Completed 1240000 out of 2000000 steps (62%)
05:18:08:WU02:FS01:0x18:Completed 1260000 out of 2000000 steps (63%)
05:18:22:WU02:FS01:0x18:Completed 1280000 out of 2000000 steps (64%)
05:18:36:WU02:FS01:0x18:Completed 1300000 out of 2000000 steps (65%)
05:18:52:WU02:FS01:0x18:Completed 1320000 out of 2000000 steps (66%)
05:19:06:WU02:FS01:0x18:Completed 1340000 out of 2000000 steps (67%)
05:19:21:WU02:FS01:0x18:Completed 1360000 out of 2000000 steps (68%)
05:19:35:WU02:FS01:0x18:Completed 1380000 out of 2000000 steps (69%)
05:19:49:WU02:FS01:0x18:Completed 1400000 out of 2000000 steps (70%)
05:20:05:WU02:FS01:0x18:Completed 1420000 out of 2000000 steps (71%)
05:20:19:WU02:FS01:0x18:Completed 1440000 out of 2000000 steps (72%)
05:20:34:WU02:FS01:0x18:Completed 1460000 out of 2000000 steps (73%)
05:20:48:WU02:FS01:0x18:Completed 1480000 out of 2000000 steps (74%)
05:21:03:WU02:FS01:0x18:Completed 1500000 out of 2000000 steps (75%)
05:21:18:WU02:FS01:0x18:Completed 1520000 out of 2000000 steps (76%)
05:21:33:WU02:FS01:0x18:Completed 1540000 out of 2000000 steps (77%)
05:21:47:WU02:FS01:0x18:Completed 1560000 out of 2000000 steps (78%)
05:22:01:WU02:FS01:0x18:Completed 1580000 out of 2000000 steps (79%)
05:22:16:WU02:FS01:0x18:Completed 1600000 out of 2000000 steps (80%)
05:22:31:WU02:FS01:0x18:Completed 1620000 out of 2000000 steps (81%)
05:22:46:WU02:FS01:0x18:Completed 1640000 out of 2000000 steps (82%)
05:23:00:WU02:FS01:0x18:Completed 1660000 out of 2000000 steps (83%)
05:23:15:WU02:FS01:0x18:Completed 1680000 out of 2000000 steps (84%)
05:23:29:WU02:FS01:0x18:Completed 1700000 out of 2000000 steps (85%)
05:23:45:WU02:FS01:0x18:Completed 1720000 out of 2000000 steps (86%)
05:23:59:WU02:FS01:0x18:Completed 1740000 out of 2000000 steps (87%)
05:24:13:WU02:FS01:0x18:Completed 1760000 out of 2000000 steps (88%)
05:24:28:WU02:FS01:0x18:Completed 1780000 out of 2000000 steps (89%)
05:24:43:WU02:FS01:0x18:Completed 1800000 out of 2000000 steps (90%)
05:24:59:WU02:FS01:0x18:Completed 1820000 out of 2000000 steps (91%)
05:25:13:WU02:FS01:0x18:Completed 1840000 out of 2000000 steps (92%)
05:25:28:WU02:FS01:0x18:Completed 1860000 out of 2000000 steps (93%)
05:25:43:WU02:FS01:0x18:Completed 1880000 out of 2000000 steps (94%)
05:25:58:WU02:FS01:0x18:Completed 1900000 out of 2000000 steps (95%)
05:26:14:WU02:FS01:0x18:Completed 1920000 out of 2000000 steps (96%)
05:26:29:WU02:FS01:0x18:Completed 1940000 out of 2000000 steps (97%)
05:26:43:WU02:FS01:0x18:Completed 1960000 out of 2000000 steps (98%)
05:26:58:WU02:FS01:0x18:Completed 1980000 out of 2000000 steps (99%)
05:27:12:WU02:FS01:0x18:Completed 2000000 out of 2000000 steps (100%)
05:27:13:WU01:FS01:Connecting to 171.67.108.45:80
05:27:13:WU01:FS01:Assigned to work server 140.163.4.244
05:27:13:WU01:FS01:Requesting new work unit for slot 01: RUNNING gpu:1:GP104 [GeForce GTX 1070] from 140.163.4.244
05:27:13:WU01:FS01:Connecting to 140.163.4.244:8080
05:27:13:WU02:FS01:0x18:Saving result file logfile_01.txt
05:27:13:WU02:FS01:0x18:Saving result file checkpointState.xml
05:27:13:WU02:FS01:0x18:Saving result file checkpt.crc
05:27:13:WU02:FS01:0x18:Saving result file log.txt
05:27:13:WU02:FS01:0x18:Saving result file positions.xtc
05:27:14:WU01:FS01:Downloading 2.77MiB
05:27:14:WU02:FS01:0x18:Folding@home Core Shutdown: FINISHED_UNIT
05:27:14:WU02:FS01:FahCore returned: FINISHED_UNIT (100 = 0x64)
05:27:14:WU02:FS01:Sending unit results: id:02 state:SEND error:NO_ERROR project:9657 run:0 clone:81 gen:52 core:0x18 unit:0x0000003aab436c9b56de69b97c37a007
05:27:14:WU02:FS01:Uploading 1.44MiB to 171.67.108.155
05:27:14:WU02:FS01:Connecting to 171.67.108.155:8080
05:27:16:WU01:FS01:Download complete
05:27:16:WU01:FS01:Received Unit: id:01 state:DOWNLOAD error:NO_ERROR project:13500 run:2 clone:51 gen:21 core:0x21 unit:0x000000208ca304f457a3598fd88c1d06
05:27:17:WU01:FS01:Starting
05:27:17:WU01:FS01:Running FahCore: "d:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" d:/Users/Lythronax/AppData/Roaming/FAHClient/cores/web.stanford.edu/~pande/Win32/AMD64/NVIDIA/Fermi/Core_21.fah/FahCore_21.exe -dir 01 -suffix 01 -version 704 -lifeline 6204 -checkpoint 15 -gpu 0 -gpu-vendor nvidia
05:27:17:WU01:FS01:Started FahCore on PID 8024
05:27:17:WU01:FS01:Core PID:2852
05:27:17:WU01:FS01:FahCore 0x21 started
05:27:18:WU01:FS01:0x21:*********************** Log Started 2016-10-27T05:27:17Z ***********************
05:27:18:WU01:FS01:0x21:Project: 13500 (Run 2, Clone 51, Gen 21)
05:27:18:WU01:FS01:0x21:Unit: 0x000000208ca304f457a3598fd88c1d06
05:27:18:WU01:FS01:0x21:CPU: 0x00000000000000000000000000000000
05:27:18:WU01:FS01:0x21:Machine: 1
05:27:18:WU01:FS01:0x21:Reading tar file core.xml
05:27:18:WU01:FS01:0x21:Reading tar file system.xml
05:27:18:WU01:FS01:0x21:Reading tar file integrator.xml
05:27:18:WU01:FS01:0x21:Reading tar file state.xml
05:27:18:WU01:FS01:0x21:Digital signatures verified
05:27:18:WU01:FS01:0x21:Folding@home GPU Core21 Folding@home Core
05:27:18:WU01:FS01:0x21:Version 0.0.17
05:27:20:WU02:FS01:Upload 82.25%
05:27:21:WU01:FS01:0x21:ERROR:exception: Error downloading array interactionCount: clEnqueueReadBuffer (-5)
05:27:21:WU01:FS01:0x21:Saving result file logfile_01.txt
05:27:21:WU01:FS01:0x21:Saving result file log.txt
05:27:21:WU01:FS01:0x21:Folding@home Core Shutdown: BAD_WORK_UNIT
05:27:22:WU02:FS01:Upload complete
05:27:22:WU02:FS01:Server responded WORK_ACK (400)
05:27:22:WU02:FS01:Final credit estimate, 9058.00 points
05:27:22:WU02:FS01:Cleaning up
05:27:23:WARNING:WU01:FS01:FahCore returned: BAD_WORK_UNIT (114 = 0x72)
05:27:23:WU01:FS01:Sending unit results: id:01 state:SEND error:FAULTY project:13500 run:2 clone:51 gen:21 core:0x21 unit:0x000000208ca304f457a3598fd88c1d06
05:27:23:WU01:FS01:Uploading 2.41KiB to 140.163.4.244
05:27:23:WU01:FS01:Connecting to 140.163.4.244:8080
05:27:23:WU01:FS01:Upload complete
05:27:23:WU01:FS01:Server responded WORK_ACK (400)
05:27:23:WU01:FS01:Cleaning up
05:27:23:WU02:FS01:Connecting to 171.67.108.45:80
05:27:23:WU02:FS01:Assigned to work server 171.64.65.84
05:27:23:WU02:FS01:Requesting new work unit for slot 01: READY gpu:1:GP104 [GeForce GTX 1070] from 171.64.65.84
05:27:24:WU02:FS01:Connecting to 171.64.65.84:8080
05:27:24:WU02:FS01:Downloading 3.36MiB
05:27:30:WU02:FS01:Download 66.87%
05:27:32:WU02:FS01:Download complete
05:27:33:WU02:FS01:Received Unit: id:02 state:DOWNLOAD error:NO_ERROR project:9193 run:0 clone:75 gen:79 core:0x21 unit:0x00000061ab40415457cb2db79e61c510
05:27:33:WU02:FS01:Starting
05:27:33:WU02:FS01:Running FahCore: "d:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" d:/Users/Lythronax/AppData/Roaming/FAHClient/cores/web.stanford.edu/~pande/Win32/AMD64/NVIDIA/Fermi/Core_21.fah/FahCore_21.exe -dir 02 -suffix 01 -version 704 -lifeline 6204 -checkpoint 15 -gpu 0 -gpu-vendor nvidia
05:27:33:WU02:FS01:Started FahCore on PID 3148
05:27:33:WU02:FS01:Core PID:2580
05:27:33:WU02:FS01:FahCore 0x21 started
05:27:33:WU02:FS01:0x21:*********************** Log Started 2016-10-27T05:27:33Z ***********************
05:27:33:WU02:FS01:0x21:Project: 9193 (Run 0, Clone 75, Gen 79)
05:27:33:WU02:FS01:0x21:Unit: 0x00000061ab40415457cb2db79e61c510
05:27:33:WU02:FS01:0x21:CPU: 0x00000000000000000000000000000000
05:27:33:WU02:FS01:0x21:Machine: 1
05:27:33:WU02:FS01:0x21:Reading tar file core.xml
05:27:33:WU02:FS01:0x21:Reading tar file system.xml
05:27:34:WU02:FS01:0x21:Reading tar file integrator.xml
05:27:34:WU02:FS01:0x21:Reading tar file state.xml
05:27:34:WU02:FS01:0x21:Digital signatures verified
05:27:34:WU02:FS01:0x21:Folding@home GPU Core21 Folding@home Core
05:27:34:WU02:FS01:0x21:Version 0.0.17
05:27:39:WU02:FS01:0x21:ERROR:exception: Error downloading array interactionCount: clEnqueueReadBuffer (-5)
05:27:39:WU02:FS01:0x21:Saving result file logfile_01.txt
05:27:39:WU02:FS01:0x21:Saving result file log.txt
05:27:39:WU02:FS01:0x21:Folding@home Core Shutdown: BAD_WORK_UNIT
05:27:41:WARNING:WU02:FS01:FahCore returned: BAD_WORK_UNIT (114 = 0x72)
05:27:41:WU02:FS01:Sending unit results: id:02 state:SEND error:FAULTY project:9193 run:0 clone:75 gen:79 core:0x21 unit:0x00000061ab40415457cb2db79e61c510
05:27:41:WU02:FS01:Uploading 2.41KiB to 171.64.65.84
05:27:41:WU02:FS01:Connecting to 171.64.65.84:8080
05:27:41:WU02:FS01:Upload complete
05:27:41:WU02:FS01:Server responded WORK_ACK (400)
05:27:41:WU02:FS01:Cleaning up
05:27:41:WU01:FS01:Connecting to 171.67.108.45:80
05:27:42:WU01:FS01:Assigned to work server 171.67.108.104
05:27:42:WU01:FS01:Requesting new work unit for slot 01: READY gpu:1:GP104 [GeForce GTX 1070] from 171.67.108.104
05:27:42:WU01:FS01:Connecting to 171.67.108.104:8080
05:27:43:WU01:FS01:Downloading 80.24MiB
05:27:49:WU01:FS01:Download 3.50%
05:27:55:WU01:FS01:Download 9.27%
05:28:01:WU01:FS01:Download 14.49%
05:28:07:WU01:FS01:Download 19.94%
05:28:13:WU01:FS01:Download 27.49%
05:28:19:WU01:FS01:Download 32.64%
05:28:25:WU01:FS01:Download 37.78%
05:28:31:WU01:FS01:Download 42.06%
05:28:37:WU01:FS01:Download 46.42%
05:28:43:WU01:FS01:Download 53.59%
05:28:49:WU01:FS01:Download 60.83%
05:28:55:WU01:FS01:Download 66.36%
05:29:01:WU01:FS01:Download 72.05%
05:29:07:WU01:FS01:Download 78.12%
05:29:13:WU01:FS01:Download 84.51%
05:29:19:WU01:FS01:Download 89.34%
05:29:25:WU01:FS01:Download 93.47%
05:29:31:WU01:FS01:Download 97.20%
05:29:34:WU01:FS01:Download complete
05:29:34:WU01:FS01:Received Unit: id:01 state:DOWNLOAD error:NO_ERROR project:9211 run:6 clone:27 gen:7 core:0x21 unit:0x00000012ab436c685796c0f389ae7848
05:29:34:WU01:FS01:Starting
05:29:34:WU01:FS01:Running FahCore: "d:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" d:/Users/Lythronax/AppData/Roaming/FAHClient/cores/web.stanford.edu/~pande/Win32/AMD64/NVIDIA/Fermi/Core_21.fah/FahCore_21.exe -dir 01 -suffix 01 -version 704 -lifeline 6204 -checkpoint 15 -gpu 0 -gpu-vendor nvidia
05:29:34:WU01:FS01:Started FahCore on PID 7876
05:29:34:WU01:FS01:Core PID:6816
05:29:34:WU01:FS01:FahCore 0x21 started
05:29:35:WU01:FS01:0x21:*********************** Log Started 2016-10-27T05:29:34Z ***********************
05:29:35:WU01:FS01:0x21:Project: 9211 (Run 6, Clone 27, Gen 7)
05:29:35:WU01:FS01:0x21:Unit: 0x00000012ab436c685796c0f389ae7848
05:29:35:WU01:FS01:0x21:CPU: 0x00000000000000000000000000000000
05:29:35:WU01:FS01:0x21:Machine: 1
05:29:35:WU01:FS01:0x21:Reading tar file core.xml
05:29:35:WU01:FS01:0x21:Reading tar file integrator.xml
05:29:35:WU01:FS01:0x21:Reading tar file state.xml
05:29:35:WU01:FS01:0x21:Reading tar file system.xml
05:29:36:WU01:FS01:0x21:Digital signatures verified
05:29:36:WU01:FS01:0x21:Folding@home GPU Core21 Folding@home Core
05:29:36:WU01:FS01:0x21:Version 0.0.17
05:29:55:WU01:FS01:0x21:ERROR:exception: Error downloading array interactionCount: clEnqueueReadBuffer (-5)
05:29:55:WU01:FS01:0x21:Saving result file logfile_01.txt
05:29:55:WU01:FS01:0x21:Saving result file log.txt
05:29:55:WU01:FS01:0x21:Folding@home Core Shutdown: BAD_WORK_UNIT
05:29:58:WARNING:WU01:FS01:FahCore returned: BAD_WORK_UNIT (114 = 0x72)
05:29:58:WU01:FS01:Sending unit results: id:01 state:SEND error:FAULTY project:9211 run:6 clone:27 gen:7 core:0x21 unit:0x00000012ab436c685796c0f389ae7848
05:29:58:WU01:FS01:Uploading 7.00KiB to 171.67.108.104
05:29:58:WU01:FS01:Connecting to 171.67.108.104:8080
05:29:58:WU01:FS01:Upload complete
05:29:58:WU01:FS01:Server responded WORK_ACK (400)
05:29:58:WU01:FS01:Cleaning up
05:29:58:WU02:FS01:Connecting to 171.67.108.45:80
05:29:58:WU02:FS01:Assigned to work server 171.67.108.104
05:29:58:WU02:FS01:Requesting new work unit for slot 01: READY gpu:1:GP104 [GeForce GTX 1070] from 171.67.108.104
05:29:58:WU02:FS01:Connecting to 171.67.108.104:8080
05:29:59:WU02:FS01:Downloading 80.24MiB
05:30:05:WU02:FS01:Download 2.65%
05:30:11:WU02:FS01:Download 5.76%
05:30:17:WU02:FS01:Download 9.81%
05:30:23:WU02:FS01:Download 13.63%
05:30:29:WU02:FS01:Download 19.47%
05:30:35:WU02:FS01:Download 23.83%
05:30:41:WU02:FS01:Download 27.57%
05:30:47:WU02:FS01:Download 32.25%
05:30:53:WU02:FS01:Download 36.45%
05:30:59:WU02:FS01:Download 41.13%
05:31:05:WU02:FS01:Download 46.03%
05:31:11:WU02:FS01:Download 50.71%
05:31:17:WU02:FS01:Download 56.16%
05:31:23:WU02:FS01:Download 61.22%
05:31:29:WU02:FS01:Download 66.83%
05:31:35:WU02:FS01:Download 74.07%
05:31:41:WU02:FS01:Download 78.75%
05:31:47:WU02:FS01:Download 82.25%
05:31:53:WU02:FS01:Download 87.00%
05:31:59:WU02:FS01:Download 91.68%
05:32:05:WU02:FS01:Download 96.89%
05:32:08:WU02:FS01:Download complete
05:32:08:WU02:FS01:Received Unit: id:02 state:DOWNLOAD error:NO_ERROR project:9209 run:55 clone:19 gen:4 core:0x21 unit:0x00000012ab436c685796c0e96acfcd82
05:32:08:WU02:FS01:Starting
05:32:08:WU02:FS01:Running FahCore: "d:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" d:/Users/Lythronax/AppData/Roaming/FAHClient/cores/web.stanford.edu/~pande/Win32/AMD64/NVIDIA/Fermi/Core_21.fah/FahCore_21.exe -dir 02 -suffix 01 -version 704 -lifeline 6204 -checkpoint 15 -gpu 0 -gpu-vendor nvidia
05:32:08:WU02:FS01:Started FahCore on PID 8128
05:32:08:WU02:FS01:Core PID:2552
05:32:08:WU02:FS01:FahCore 0x21 started
05:32:09:WU02:FS01:0x21:*********************** Log Started 2016-10-27T05:32:09Z ***********************
05:32:09:WU02:FS01:0x21:Project: 9209 (Run 55, Clone 19, Gen 4)
05:32:09:WU02:FS01:0x21:Unit: 0x00000012ab436c685796c0e96acfcd82
05:32:09:WU02:FS01:0x21:CPU: 0x00000000000000000000000000000000
05:32:09:WU02:FS01:0x21:Machine: 1
05:32:09:WU02:FS01:0x21:Reading tar file core.xml
05:32:09:WU02:FS01:0x21:Reading tar file integrator.xml
05:32:09:WU02:FS01:0x21:Reading tar file state.xml
05:32:09:WU02:FS01:0x21:Reading tar file system.xml
05:32:10:WU02:FS01:0x21:Digital signatures verified
05:32:10:WU02:FS01:0x21:Folding@home GPU Core21 Folding@home Core
05:32:10:WU02:FS01:0x21:Version 0.0.17
05:32:28:WU02:FS01:0x21:ERROR:exception: Error downloading array interactionCount: clEnqueueReadBuffer (-5)
05:32:28:WU02:FS01:0x21:Saving result file logfile_01.txt
05:32:28:WU02:FS01:0x21:Saving result file log.txt
05:32:28:WU02:FS01:0x21:Folding@home Core Shutdown: BAD_WORK_UNIT
05:32:31:WARNING:WU02:FS01:FahCore returned: BAD_WORK_UNIT (114 = 0x72)
05:32:31:WU02:FS01:Sending unit results: id:02 state:SEND error:FAULTY project:9209 run:55 clone:19 gen:4 core:0x21 unit:0x00000012ab436c685796c0e96acfcd82
05:32:31:WU02:FS01:Uploading 7.00KiB to 171.67.108.104
05:32:31:WU02:FS01:Connecting to 171.67.108.104:8080
05:32:32:WU01:FS01:Connecting to 171.67.108.45:80
05:32:32:WU02:FS01:Upload complete
05:32:32:WU02:FS01:Server responded WORK_ACK (400)
05:32:32:WU02:FS01:Cleaning up
05:32:32:WU01:FS01:Assigned to work server 140.163.4.245
05:32:32:WU01:FS01:Requesting new work unit for slot 01: READY gpu:1:GP104 [GeForce GTX 1070] from 140.163.4.245
05:32:32:WU01:FS01:Connecting to 140.163.4.245:8080
05:32:33:WU01:FS01:Downloading 5.13MiB
05:32:39:WU01:FS01:Download 90.23%
05:32:40:WU01:FS01:Download complete
05:32:40:WU01:FS01:Received Unit: id:01 state:DOWNLOAD error:NO_ERROR project:10495 run:19 clone:61 gen:37 core:0x21 unit:0x0000003b8ca304f556ba642dd0e14b5c
05:32:40:WU01:FS01:Starting
05:32:40:WU01:FS01:Running FahCore: "d:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" d:/Users/Lythronax/AppData/Roaming/FAHClient/cores/web.stanford.edu/~pande/Win32/AMD64/NVIDIA/Fermi/Core_21.fah/FahCore_21.exe -dir 01 -suffix 01 -version 704 -lifeline 6204 -checkpoint 15 -gpu 0 -gpu-vendor nvidia
05:32:40:WU01:FS01:Started FahCore on PID 3200
05:32:40:WU01:FS01:Core PID:5904
05:32:40:WU01:FS01:FahCore 0x21 started
05:32:40:WU01:FS01:0x21:*********************** Log Started 2016-10-27T05:32:40Z ***********************
05:32:40:WU01:FS01:0x21:Project: 10495 (Run 19, Clone 61, Gen 37)
05:32:40:WU01:FS01:0x21:Unit: 0x0000003b8ca304f556ba642dd0e14b5c
05:32:40:WU01:FS01:0x21:CPU: 0x00000000000000000000000000000000
05:32:40:WU01:FS01:0x21:Machine: 1
05:32:40:WU01:FS01:0x21:Reading tar file core.xml
05:32:40:WU01:FS01:0x21:Reading tar file system.xml
05:32:41:WU01:FS01:0x21:Reading tar file integrator.xml
05:32:41:WU01:FS01:0x21:Reading tar file state.xml
05:32:41:WU01:FS01:0x21:Digital signatures verified
05:32:41:WU01:FS01:0x21:Folding@home GPU Core21 Folding@home Core
05:32:41:WU01:FS01:0x21:Version 0.0.17
05:32:47:WU01:FS01:0x21:ERROR:exception: Error downloading array interactionCount: clEnqueueReadBuffer (-5)
05:32:47:WU01:FS01:0x21:Saving result file logfile_01.txt
05:32:47:WU01:FS01:0x21:Saving result file log.txt
05:32:47:WU01:FS01:0x21:Folding@home Core Shutdown: BAD_WORK_UNIT
05:32:50:WARNING:WU01:FS01:FahCore returned: BAD_WORK_UNIT (114 = 0x72)
05:32:50:WU01:FS01:Sending unit results: id:01 state:SEND error:FAULTY project:10495 run:19 clone:61 gen:37 core:0x21 unit:0x0000003b8ca304f556ba642dd0e14b5c
05:32:50:WU01:FS01:Uploading 2.36KiB to 140.163.4.245
05:32:50:WU01:FS01:Connecting to 140.163.4.245:8080
05:32:50:WU01:FS01:Upload complete
05:32:50:WU01:FS01:Server responded WORK_ACK (400)
05:32:50:WU01:FS01:Cleaning up
05:32:50:WU02:FS01:Connecting to 171.67.108.45:80
05:32:51:WU02:FS01:Assigned to work server 171.67.108.155
05:32:51:WU02:FS01:Requesting new work unit for slot 01: READY gpu:1:GP104 [GeForce GTX 1070] from 171.67.108.155
05:32:51:WU02:FS01:Connecting to 171.67.108.155:8080
05:32:52:WU02:FS01:Downloading 746.94KiB
05:32:54:WU02:FS01:Download complete
05:32:54:WU02:FS01:Received Unit: id:02 state:DOWNLOAD error:NO_ERROR project:9657 run:0 clone:81 gen:53 core:0x18 unit:0x0000003bab436c9b56de69b97c37a007
05:32:54:WU02:FS01:Starting
05:32:54:WU02:FS01:Running FahCore: "d:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" d:/Users/Lythronax/AppData/Roaming/FAHClient/cores/web.stanford.edu/~pande/Win32/AMD64/NVIDIA/Fermi/Core_18.fah/FahCore_18.exe -dir 02 -suffix 01 -version 704 -lifeline 6204 -checkpoint 15 -gpu 0 -gpu-vendor nvidia
05:32:54:WU02:FS01:Started FahCore on PID 7924
05:32:54:WU02:FS01:Core PID:6992
05:32:54:WU02:FS01:FahCore 0x18 started
05:32:55:WU02:FS01:0x18:*********************** Log Started 2016-10-27T05:32:55Z ***********************
05:32:55:WU02:FS01:0x18:Project: 9657 (Run 0, Clone 81, Gen 53)
05:32:55:WU02:FS01:0x18:Unit: 0x0000003bab436c9b56de69b97c37a007
05:32:55:WU02:FS01:0x18:CPU: 0x00000000000000000000000000000000
05:32:55:WU02:FS01:0x18:Machine: 1
05:32:55:WU02:FS01:0x18:Reading tar file core.xml
05:32:55:WU02:FS01:0x18:Reading tar file integrator.xml
05:32:55:WU02:FS01:0x18:Reading tar file state.xml
05:32:55:WU02:FS01:0x18:Reading tar file system.xml
05:32:55:WU02:FS01:0x18:Digital signatures verified
05:32:55:WU02:FS01:0x18:Folding@home GPU core18
05:32:55:WU02:FS01:0x18:Version 0.0.4
05:32:58:WU02:FS01:0x18:Completed 0 out of 2000000 steps (0%)
05:32:58:WU02:FS01:0x18:Temperature control disabled. Requirements: single Nvidia GPU, tmax must be < 110 and twait >= 900
05:33:13:WU02:FS01:0x18:Completed 20000 out of 2000000 steps (1%)
05:33:28:WU02:FS01:0x18:Completed 40000 out of 2000000 steps (2%)
05:33:42:WU02:FS01:0x18:Completed 60000 out of 2000000 steps (3%)
05:33:56:WU02:FS01:0x18:Completed 80000 out of 2000000 steps (4%)
05:34:11:WU02:FS01:0x18:Completed 100000 out of 2000000 steps (5%)
05:34:26:WU02:FS01:0x18:Completed 120000 out of 2000000 steps (6%)
05:34:41:WU02:FS01:0x18:Completed 140000 out of 2000000 steps (7%)
05:34:55:WU02:FS01:0x18:Completed 160000 out of 2000000 steps (8%)
05:35:09:WU02:FS01:0x18:Completed 180000 out of 2000000 steps (9%)
05:35:24:WU02:FS01:0x18:Completed 200000 out of 2000000 steps (10%)
05:35:40:WU02:FS01:0x18:Completed 220000 out of 2000000 steps (11%)
05:35:54:WU02:FS01:0x18:Completed 240000 out of 2000000 steps (12%)
05:36:08:WU02:FS01:0x18:Completed 260000 out of 2000000 steps (13%)
05:36:23:WU02:FS01:0x18:Completed 280000 out of 2000000 steps (14%)
05:36:37:WU02:FS01:0x18:Completed 300000 out of 2000000 steps (15%)
05:36:53:WU02:FS01:0x18:Completed 320000 out of 2000000 steps (16%)
05:37:07:WU02:FS01:0x18:Completed 340000 out of 2000000 steps (17%)
05:37:21:WU02:FS01:0x18:Completed 360000 out of 2000000 steps (18%)
05:37:36:WU02:FS01:0x18:Completed 380000 out of 2000000 steps (19%)
05:37:50:WU02:FS01:0x18:Completed 400000 out of 2000000 steps (20%)
05:38:05:WU02:FS01:0x18:Completed 420000 out of 2000000 steps (21%)
05:38:20:WU02:FS01:0x18:Completed 440000 out of 2000000 steps (22%)
05:38:34:WU02:FS01:0x18:Completed 460000 out of 2000000 steps (23%)
05:38:49:WU02:FS01:0x18:Completed 480000 out of 2000000 steps (24%)
05:39:03:WU02:FS01:0x18:Completed 500000 out of 2000000 steps (25%)
05:39:19:WU02:FS01:0x18:Completed 520000 out of 2000000 steps (26%)
05:39:33:WU02:FS01:0x18:Completed 540000 out of 2000000 steps (27%)
05:39:47:WU02:FS01:0x18:Completed 560000 out of 2000000 steps (28%)
05:40:02:WU02:FS01:0x18:Completed 580000 out of 2000000 steps (29%)
05:40:16:WU02:FS01:0x18:Completed 600000 out of 2000000 steps (30%)
05:40:32:WU02:FS01:0x18:Completed 620000 out of 2000000 steps (31%)
05:40:46:WU02:FS01:0x18:Completed 640000 out of 2000000 steps (32%)
05:41:01:WU02:FS01:0x18:Completed 660000 out of 2000000 steps (33%)
05:41:15:WU02:FS01:0x18:Completed 680000 out of 2000000 steps (34%)
05:41:29:WU02:FS01:0x18:Completed 700000 out of 2000000 steps (35%)
05:41:45:WU02:FS01:0x18:Completed 720000 out of 2000000 steps (36%)
05:41:59:WU02:FS01:0x18:Completed 740000 out of 2000000 steps (37%)
05:42:13:WU02:FS01:0x18:Completed 760000 out of 2000000 steps (38%)
05:42:28:WU02:FS01:0x18:Completed 780000 out of 2000000 steps (39%)
05:42:42:WU02:FS01:0x18:Completed 800000 out of 2000000 steps (40%)
05:42:58:WU02:FS01:0x18:Completed 820000 out of 2000000 steps (41%)
05:43:12:WU02:FS01:0x18:Completed 840000 out of 2000000 steps (42%)
05:43:27:WU02:FS01:0x18:Completed 860000 out of 2000000 steps (43%)
05:43:41:WU02:FS01:0x18:Completed 880000 out of 2000000 steps (44%)
05:43:55:WU02:FS01:0x18:Completed 900000 out of 2000000 steps (45%)
05:44:11:WU02:FS01:0x18:Completed 920000 out of 2000000 steps (46%)
05:44:25:WU02:FS01:0x18:Completed 940000 out of 2000000 steps (47%)
05:44:39:WU02:FS01:0x18:Completed 960000 out of 2000000 steps (48%)
05:44:54:WU02:FS01:0x18:Completed 980000 out of 2000000 steps (49%)
05:45:08:WU02:FS01:0x18:Completed 1000000 out of 2000000 steps (50%)
05:45:24:WU02:FS01:0x18:Completed 1020000 out of 2000000 steps (51%)
05:45:38:WU02:FS01:0x18:Completed 1040000 out of 2000000 steps (52%)
05:45:53:WU02:FS01:0x18:Completed 1060000 out of 2000000 steps (53%)
05:46:07:WU02:FS01:0x18:Completed 1080000 out of 2000000 steps (54%)
05:46:21:WU02:FS01:0x18:Completed 1100000 out of 2000000 steps (55%)
05:46:37:WU02:FS01:0x18:Completed 1120000 out of 2000000 steps (56%)
05:46:51:WU02:FS01:0x18:Completed 1140000 out of 2000000 steps (57%)
05:47:06:WU02:FS01:0x18:Completed 1160000 out of 2000000 steps (58%)
05:47:20:WU02:FS01:0x18:Completed 1180000 out of 2000000 steps (59%)
05:47:35:WU02:FS01:0x18:Completed 1200000 out of 2000000 steps (60%)
05:47:51:WU02:FS01:0x18:Completed 1220000 out of 2000000 steps (61%)
05:48:05:WU02:FS01:0x18:Completed 1240000 out of 2000000 steps (62%)
05:48:19:WU02:FS01:0x18:Completed 1260000 out of 2000000 steps (63%)
05:48:34:WU02:FS01:0x18:Completed 1280000 out of 2000000 steps (64%)
05:48:48:WU02:FS01:0x18:Completed 1300000 out of 2000000 steps (65%)
05:49:04:WU02:FS01:0x18:Completed 1320000 out of 2000000 steps (66%)
05:49:18:WU02:FS01:0x18:Completed 1340000 out of 2000000 steps (67%)
05:49:32:WU02:FS01:0x18:Completed 1360000 out of 2000000 steps (68%)
05:49:47:WU02:FS01:0x18:Completed 1380000 out of 2000000 steps (69%)
05:50:01:WU02:FS01:0x18:Completed 1400000 out of 2000000 steps (70%)
05:50:17:WU02:FS01:0x18:Completed 1420000 out of 2000000 steps (71%)
05:50:31:WU02:FS01:0x18:Completed 1440000 out of 2000000 steps (72%)
05:50:46:WU02:FS01:0x18:Completed 1460000 out of 2000000 steps (73%)
05:51:00:WU02:FS01:0x18:Completed 1480000 out of 2000000 steps (74%)
05:51:15:WU02:FS01:0x18:Completed 1500000 out of 2000000 steps (75%)
05:51:30:WU02:FS01:0x18:Completed 1520000 out of 2000000 steps (76%)
05:51:44:WU02:FS01:0x18:Completed 1540000 out of 2000000 steps (77%)
05:51:59:WU02:FS01:0x18:Completed 1560000 out of 2000000 steps (78%)
05:52:13:WU02:FS01:0x18:Completed 1580000 out of 2000000 steps (79%)
05:52:28:WU02:FS01:0x18:Completed 1600000 out of 2000000 steps (80%)
05:52:43:WU02:FS01:0x18:Completed 1620000 out of 2000000 steps (81%)
05:52:58:WU02:FS01:0x18:Completed 1640000 out of 2000000 steps (82%)
05:53:12:WU02:FS01:0x18:Completed 1660000 out of 2000000 steps (83%)
05:53:26:WU02:FS01:0x18:Completed 1680000 out of 2000000 steps (84%)
05:53:41:WU02:FS01:0x18:Completed 1700000 out of 2000000 steps (85%)
05:53:57:WU02:FS01:0x18:Completed 1720000 out of 2000000 steps (86%)
05:54:11:WU02:FS01:0x18:Completed 1740000 out of 2000000 steps (87%)
05:54:25:WU02:FS01:0x18:Completed 1760000 out of 2000000 steps (88%)
05:54:40:WU02:FS01:0x18:Completed 1780000 out of 2000000 steps (89%)
05:54:54:WU02:FS01:0x18:Completed 1800000 out of 2000000 steps (90%)
05:55:10:WU02:FS01:0x18:Completed 1820000 out of 2000000 steps (91%)
05:55:24:WU02:FS01:0x18:Completed 1840000 out of 2000000 steps (92%)
05:55:39:WU02:FS01:0x18:Completed 1860000 out of 2000000 steps (93%)
05:55:53:WU02:FS01:0x18:Completed 1880000 out of 2000000 steps (94%)
05:56:07:WU02:FS01:0x18:Completed 1900000 out of 2000000 steps (95%)
05:56:23:WU02:FS01:0x18:Completed 1920000 out of 2000000 steps (96%)
05:56:37:WU02:FS01:0x18:Completed 1940000 out of 2000000 steps (97%)
05:56:52:WU02:FS01:0x18:Completed 1960000 out of 2000000 steps (98%)
05:57:06:WU02:FS01:0x18:Completed 1980000 out of 2000000 steps (99%)
05:57:20:WU02:FS01:0x18:Completed 2000000 out of 2000000 steps (100%)
05:57:21:WU03:FS01:Connecting to 171.67.108.45:80
05:57:21:WU03:FS01:Assigned to work server 140.163.4.243
05:57:21:WU03:FS01:Requesting new work unit for slot 01: RUNNING gpu:1:GP104 [GeForce GTX 1070] from 140.163.4.243
05:57:21:WU03:FS01:Connecting to 140.163.4.243:8080
05:57:22:WU02:FS01:0x18:Saving result file logfile_01.txt
05:57:22:WU02:FS01:0x18:Saving result file checkpointState.xml
05:57:22:WU03:FS01:Downloading 2.67MiB
05:57:22:WU02:FS01:0x18:Saving result file checkpt.crc
05:57:22:WU02:FS01:0x18:Saving result file log.txt
05:57:22:WU02:FS01:0x18:Saving result file positions.xtc
05:57:22:WU02:FS01:0x18:Folding@home Core Shutdown: FINISHED_UNIT
05:57:22:WU02:FS01:FahCore returned: FINISHED_UNIT (100 = 0x64)
05:57:22:WU02:FS01:Sending unit results: id:02 state:SEND error:NO_ERROR project:9657 run:0 clone:81 gen:53 core:0x18 unit:0x0000003bab436c9b56de69b97c37a007
05:57:22:WU02:FS01:Uploading 1.44MiB to 171.67.108.155
05:57:22:WU02:FS01:Connecting to 171.67.108.155:8080
05:57:25:WU03:FS01:Download complete
05:57:25:WU03:FS01:Received Unit: id:03 state:DOWNLOAD error:NO_ERROR project:11707 run:71 clone:16 gen:32 core:0x21 unit:0x0000002c8ca304f357e9eb69d631dbec
05:57:25:WU03:FS01:Starting
05:57:25:WU03:FS01:Running FahCore: "d:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" d:/Users/Lythronax/AppData/Roaming/FAHClient/cores/web.stanford.edu/~pande/Win32/AMD64/NVIDIA/Fermi/Core_21.fah/FahCore_21.exe -dir 03 -suffix 01 -version 704 -lifeline 6204 -checkpoint 15 -gpu 0 -gpu-vendor nvidia
05:57:25:WU03:FS01:Started FahCore on PID 3852
05:57:25:WU03:FS01:Core PID:6848
05:57:25:WU03:FS01:FahCore 0x21 started
05:57:26:WU03:FS01:0x21:*********************** Log Started 2016-10-27T05:57:26Z ***********************
05:57:26:WU03:FS01:0x21:Project: 11707 (Run 71, Clone 16, Gen 32)
05:57:26:WU03:FS01:0x21:Unit: 0x0000002c8ca304f357e9eb69d631dbec
05:57:26:WU03:FS01:0x21:CPU: 0x00000000000000000000000000000000
05:57:26:WU03:FS01:0x21:Machine: 1
05:57:26:WU03:FS01:0x21:Reading tar file core.xml
05:57:26:WU03:FS01:0x21:Reading tar file system.xml
05:57:26:WU03:FS01:0x21:Reading tar file integrator.xml
05:57:26:WU03:FS01:0x21:Reading tar file state.xml
05:57:26:WU03:FS01:0x21:Digital signatures verified
05:57:26:WU03:FS01:0x21:Folding@home GPU Core21 Folding@home Core
05:57:26:WU03:FS01:0x21:Version 0.0.17
05:57:28:WU02:FS01:Upload 56.28%
05:57:29:WU03:FS01:0x21:ERROR:exception: Error downloading array interactionCount: clEnqueueReadBuffer (-5)
05:57:29:WU03:FS01:0x21:Saving result file logfile_01.txt
05:57:29:WU03:FS01:0x21:Saving result file log.txt
05:57:29:WU03:FS01:0x21:Folding@home Core Shutdown: BAD_WORK_UNIT
05:57:31:WARNING:WU03:FS01:FahCore returned: BAD_WORK_UNIT (114 = 0x72)
05:57:31:WU03:FS01:Sending unit results: id:03 state:SEND error:FAULTY project:11707 run:71 clone:16 gen:32 core:0x21 unit:0x0000002c8ca304f357e9eb69d631dbec
05:57:31:WU03:FS01:Uploading 2.39KiB to 140.163.4.243
05:57:31:WU03:FS01:Connecting to 140.163.4.243:8080
05:57:32:WU03:FS01:Upload complete
05:57:32:WU03:FS01:Server responded WORK_ACK (400)
05:57:32:WU03:FS01:Cleaning up
05:57:32:WU04:FS01:Connecting to 171.67.108.45:80
05:57:32:WU04:FS01:Assigned to work server 140.163.4.245
05:57:32:WU04:FS01:Requesting new work unit for slot 01: READY gpu:1:GP104 [GeForce GTX 1070] from 140.163.4.245
05:57:32:WU04:FS01:Connecting to 140.163.4.245:8080
05:57:32:WU04:FS01:Downloading 5.13MiB
05:57:34:WU02:FS01:Upload complete
05:57:34:WU02:FS01:Server responded WORK_ACK (400)
05:57:34:WU02:FS01:Final credit estimate, 9058.00 points
05:57:34:WU02:FS01:Cleaning up
05:57:38:WU04:FS01:Download 68.26%
05:57:41:WU04:FS01:Download complete
05:57:41:WU04:FS01:Received Unit: id:04 state:DOWNLOAD error:NO_ERROR project:10495 run:22 clone:66 gen:5 core:0x21 unit:0x0000000e8ca304f556ba6467d1aae3da
05:57:41:WU04:FS01:Starting
05:57:41:WU04:FS01:Running FahCore: "d:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" d:/Users/Lythronax/AppData/Roaming/FAHClient/cores/web.stanford.edu/~pande/Win32/AMD64/NVIDIA/Fermi/Core_21.fah/FahCore_21.exe -dir 04 -suffix 01 -version 704 -lifeline 6204 -checkpoint 15 -gpu 0 -gpu-vendor nvidia
05:57:41:WU04:FS01:Started FahCore on PID 5364
05:57:41:WU04:FS01:Core PID:7004
05:57:41:WU04:FS01:FahCore 0x21 started
05:57:42:WU04:FS01:0x21:*********************** Log Started 2016-10-27T05:57:41Z ***********************
05:57:42:WU04:FS01:0x21:Project: 10495 (Run 22, Clone 66, Gen 5)
05:57:42:WU04:FS01:0x21:Unit: 0x0000000e8ca304f556ba6467d1aae3da
05:57:42:WU04:FS01:0x21:CPU: 0x00000000000000000000000000000000
05:57:42:WU04:FS01:0x21:Machine: 1
05:57:42:WU04:FS01:0x21:Reading tar file core.xml
05:57:42:WU04:FS01:0x21:Reading tar file system.xml
05:57:42:WU04:FS01:0x21:Reading tar file integrator.xml
05:57:42:WU04:FS01:0x21:Reading tar file state.xml
05:57:43:WU04:FS01:0x21:Digital signatures verified
05:57:43:WU04:FS01:0x21:Folding@home GPU Core21 Folding@home Core
05:57:43:WU04:FS01:0x21:Version 0.0.17
05:57:49:WU04:FS01:0x21:ERROR:exception: Error downloading array interactionCount: clEnqueueReadBuffer (-5)
05:57:49:WU04:FS01:0x21:Saving result file logfile_01.txt
05:57:49:WU04:FS01:0x21:Saving result file log.txt
05:57:49:WU04:FS01:0x21:Folding@home Core Shutdown: BAD_WORK_UNIT
05:57:52:WARNING:WU04:FS01:FahCore returned: BAD_WORK_UNIT (114 = 0x72)
05:57:52:WU04:FS01:Sending unit results: id:04 state:SEND error:FAULTY project:10495 run:22 clone:66 gen:5 core:0x21 unit:0x0000000e8ca304f556ba6467d1aae3da
05:57:52:WU04:FS01:Uploading 2.39KiB to 140.163.4.245
05:57:52:WU04:FS01:Connecting to 140.163.4.245:8080
05:57:52:WU04:FS01:Upload complete
05:57:52:WU04:FS01:Server responded WORK_ACK (400)
05:57:52:WU04:FS01:Cleaning up
05:57:52:WU02:FS01:Connecting to 171.67.108.45:80
05:57:53:WU02:FS01:Assigned to work server 171.64.65.84
05:57:53:WU02:FS01:Requesting new work unit for slot 01: READY gpu:1:GP104 [GeForce GTX 1070] from 171.64.65.84
05:57:53:WU02:FS01:Connecting to 171.64.65.84:8080
05:57:53:WU02:FS01:Downloading 2.99MiB
05:57:59:WU02:FS01:Download 60.57%
05:58:03:WU02:FS01:Download complete
05:58:03:WU02:FS01:Received Unit: id:02 state:DOWNLOAD error:NO_ERROR project:9191 run:0 clone:41 gen:114 core:0x21 unit:0x00000090ab40415457cb2c92f43cea69
05:58:03:WU02:FS01:Starting
05:58:03:WU02:FS01:Running FahCore: "d:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" d:/Users/Lythronax/AppData/Roaming/FAHClient/cores/web.stanford.edu/~pande/Win32/AMD64/NVIDIA/Fermi/Core_21.fah/FahCore_21.exe -dir 02 -suffix 01 -version 704 -lifeline 6204 -checkpoint 15 -gpu 0 -gpu-vendor nvidia
05:58:03:WU02:FS01:Started FahCore on PID 8676
05:58:03:WU02:FS01:Core PID:6588
05:58:03:WU02:FS01:FahCore 0x21 started
05:58:04:WU02:FS01:0x21:*********************** Log Started 2016-10-27T05:58:03Z ***********************
05:58:04:WU02:FS01:0x21:Project: 9191 (Run 0, Clone 41, Gen 114)
05:58:04:WU02:FS01:0x21:Unit: 0x00000090ab40415457cb2c92f43cea69
05:58:04:WU02:FS01:0x21:CPU: 0x00000000000000000000000000000000
05:58:04:WU02:FS01:0x21:Machine: 1
05:58:04:WU02:FS01:0x21:Reading tar file core.xml
05:58:04:WU02:FS01:0x21:Reading tar file system.xml
05:58:04:WU02:FS01:0x21:Reading tar file integrator.xml
05:58:04:WU02:FS01:0x21:Reading tar file state.xml
05:58:04:WU02:FS01:0x21:Digital signatures verified
05:58:04:WU02:FS01:0x21:Folding@home GPU Core21 Folding@home Core
05:58:04:WU02:FS01:0x21:Version 0.0.17
05:58:09:WU02:FS01:0x21:ERROR:exception: Error downloading array interactionCount: clEnqueueReadBuffer (-5)
05:58:09:WU02:FS01:0x21:Saving result file logfile_01.txt
05:58:09:WU02:FS01:0x21:Saving result file log.txt
05:58:09:WU02:FS01:0x21:Folding@home Core Shutdown: BAD_WORK_UNIT
05:58:11:WARNING:WU02:FS01:FahCore returned: BAD_WORK_UNIT (114 = 0x72)
05:58:12:WU02:FS01:Sending unit results: id:02 state:SEND error:FAULTY project:9191 run:0 clone:41 gen:114 core:0x21 unit:0x00000090ab40415457cb2c92f43cea69
05:58:12:WU02:FS01:Uploading 2.39KiB to 171.64.65.84
05:58:12:WU02:FS01:Connecting to 171.64.65.84:8080
05:58:12:WU02:FS01:Upload complete
05:58:12:WU02:FS01:Server responded WORK_ACK (400)
05:58:12:WU02:FS01:Cleaning up
05:58:12:WU03:FS01:Connecting to 171.67.108.45:80
05:58:12:WU03:FS01:Assigned to work server 171.64.65.92
05:58:12:WU03:FS01:Requesting new work unit for slot 01: READY gpu:1:GP104 [GeForce GTX 1070] from 171.64.65.92
05:58:12:WU03:FS01:Connecting to 171.64.65.92:8080
05:58:13:WU03:FS01:Downloading 3.16MiB
05:58:19:WU03:FS01:Download 47.53%
05:58:24:WU03:FS01:Download complete
05:58:24:WU03:FS01:Received Unit: id:03 state:DOWNLOAD error:NO_ERROR project:9197 run:0 clone:79 gen:91 core:0x21 unit:0x00000080ab40415c57cb3f959bea9ee3
05:58:24:WU03:FS01:Starting
05:58:24:WU03:FS01:Running FahCore: "d:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" d:/Users/Lythronax/AppData/Roaming/FAHClient/cores/web.stanford.edu/~pande/Win32/AMD64/NVIDIA/Fermi/Core_21.fah/FahCore_21.exe -dir 03 -suffix 01 -version 704 -lifeline 6204 -checkpoint 15 -gpu 0 -gpu-vendor nvidia
05:58:25:WU03:FS01:Started FahCore on PID 8036
05:58:25:WU03:FS01:Core PID:2408
05:58:25:WU03:FS01:FahCore 0x21 started
05:58:25:WU03:FS01:0x21:*********************** Log Started 2016-10-27T05:58:25Z ***********************
05:58:25:WU03:FS01:0x21:Project: 9197 (Run 0, Clone 79, Gen 91)
05:58:25:WU03:FS01:0x21:Unit: 0x00000080ab40415c57cb3f959bea9ee3
05:58:25:WU03:FS01:0x21:CPU: 0x00000000000000000000000000000000
05:58:25:WU03:FS01:0x21:Machine: 1
05:58:25:WU03:FS01:0x21:Reading tar file core.xml
05:58:25:WU03:FS01:0x21:Reading tar file system.xml
05:58:25:WU03:FS01:0x21:Reading tar file integrator.xml
05:58:25:WU03:FS01:0x21:Reading tar file state.xml
05:58:26:WU03:FS01:0x21:Digital signatures verified
05:58:26:WU03:FS01:0x21:Folding@home GPU Core21 Folding@home Core
05:58:26:WU03:FS01:0x21:Version 0.0.17
05:58:30:WU03:FS01:0x21:ERROR:exception: Error downloading array interactionCount: clEnqueueReadBuffer (-5)
05:58:30:WU03:FS01:0x21:Saving result file logfile_01.txt
05:58:30:WU03:FS01:0x21:Saving result file log.txt
05:58:30:WU03:FS01:0x21:Folding@home Core Shutdown: BAD_WORK_UNIT
05:58:33:WARNING:WU03:FS01:FahCore returned: BAD_WORK_UNIT (114 = 0x72)
05:58:33:WU03:FS01:Sending unit results: id:03 state:SEND error:FAULTY project:9197 run:0 clone:79 gen:91 core:0x21 unit:0x00000080ab40415c57cb3f959bea9ee3
05:58:33:WU03:FS01:Uploading 2.40KiB to 171.64.65.92
05:58:33:WU03:FS01:Connecting to 171.64.65.92:8080
05:58:33:WU03:FS01:Upload complete
05:58:33:WU03:FS01:Server responded WORK_ACK (400)
05:58:33:WU03:FS01:Cleaning up
05:58:33:WU02:FS01:Connecting to 171.67.108.45:80
05:58:33:WU02:FS01:Assigned to work server 171.64.65.92
05:58:33:WU02:FS01:Requesting new work unit for slot 01: READY gpu:1:GP104 [GeForce GTX 1070] from 171.64.65.92
05:58:33:WU02:FS01:Connecting to 171.64.65.92:8080
05:58:34:WU02:FS01:Downloading 2.52MiB
05:58:40:WU02:FS01:Download 81.79%
05:58:41:WU02:FS01:Download complete
05:58:41:WU02:FS01:Received Unit: id:02 state:DOWNLOAD error:NO_ERROR project:9194 run:0 clone:90 gen:105 core:0x21 unit:0x0000007fab40415c57cb2e2c445aa302
05:58:42:WU02:FS01:Starting
05:58:42:WU02:FS01:Running FahCore: "d:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" d:/Users/Lythronax/AppData/Roaming/FAHClient/cores/web.stanford.edu/~pande/Win32/AMD64/NVIDIA/Fermi/Core_21.fah/FahCore_21.exe -dir 02 -suffix 01 -version 704 -lifeline 6204 -checkpoint 15 -gpu 0 -gpu-vendor nvidia
05:58:42:WU02:FS01:Started FahCore on PID 5696
05:58:42:WU02:FS01:Core PID:6080
05:58:42:WU02:FS01:FahCore 0x21 started
05:58:42:WU02:FS01:0x21:*********************** Log Started 2016-10-27T05:58:42Z ***********************
05:58:42:WU02:FS01:0x21:Project: 9194 (Run 0, Clone 90, Gen 105)
05:58:42:WU02:FS01:0x21:Unit: 0x0000007fab40415c57cb2e2c445aa302
05:58:42:WU02:FS01:0x21:CPU: 0x00000000000000000000000000000000
05:58:42:WU02:FS01:0x21:Machine: 1
05:58:42:WU02:FS01:0x21:Reading tar file core.xml
05:58:42:WU02:FS01:0x21:Reading tar file system.xml
05:58:42:WU02:FS01:0x21:Reading tar file integrator.xml
05:58:42:WU02:FS01:0x21:Reading tar file state.xml
05:58:43:WU02:FS01:0x21:Digital signatures verified
05:58:43:WU02:FS01:0x21:Folding@home GPU Core21 Folding@home Core
05:58:43:WU02:FS01:0x21:Version 0.0.17
05:58:46:WU02:FS01:0x21:ERROR:exception: Error downloading array interactionCount: clEnqueueReadBuffer (-5)
05:58:46:WU02:FS01:0x21:Saving result file logfile_01.txt
05:58:46:WU02:FS01:0x21:Saving result file log.txt
05:58:46:WU02:FS01:0x21:Folding@home Core Shutdown: BAD_WORK_UNIT
05:58:49:WARNING:WU02:FS01:FahCore returned: BAD_WORK_UNIT (114 = 0x72)
05:58:49:WU02:FS01:Sending unit results: id:02 state:SEND error:FAULTY project:9194 run:0 clone:90 gen:105 core:0x21 unit:0x0000007fab40415c57cb2e2c445aa302
05:58:49:WU02:FS01:Uploading 2.42KiB to 171.64.65.92
05:58:49:WU02:FS01:Connecting to 171.64.65.92:8080
05:58:49:WU02:FS01:Upload complete
05:58:49:WU02:FS01:Server responded WORK_ACK (400)
05:58:49:WU02:FS01:Cleaning up
05:58:49:WU03:FS01:Connecting to 171.67.108.45:80
05:58:49:WU03:FS01:Assigned to work server 171.64.65.92
05:58:49:WU03:FS01:Requesting new work unit for slot 01: READY gpu:1:GP104 [GeForce GTX 1070] from 171.64.65.92
05:58:49:WU03:FS01:Connecting to 171.64.65.92:8080
05:58:50:WU03:FS01:Downloading 3.04MiB
05:58:56:WU03:FS01:Download 39.07%
05:59:02:WU03:FS01:Download 82.26%
05:59:04:WU03:FS01:Download complete
05:59:04:WU03:FS01:Received Unit: id:03 state:DOWNLOAD error:NO_ERROR project:9194 run:2 clone:81 gen:50 core:0x21 unit:0x00000042ab40415c57cb2e950c352a92
05:59:04:WU03:FS01:Starting
05:59:04:WU03:FS01:Running FahCore: "d:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" d:/Users/Lythronax/AppData/Roaming/FAHClient/cores/web.stanford.edu/~pande/Win32/AMD64/NVIDIA/Fermi/Core_21.fah/FahCore_21.exe -dir 03 -suffix 01 -version 704 -lifeline 6204 -checkpoint 15 -gpu 0 -gpu-vendor nvidia
05:59:04:WU03:FS01:Started FahCore on PID 6448
05:59:04:WU03:FS01:Core PID:7520
05:59:04:WU03:FS01:FahCore 0x21 started
MEGIDDO
Re: new guy: Adding A Graphics Card To GPUs.txt File
Post by MEGIDDO »
Final Log entry, part 3:
05:59:05:WU03:FS01:0x21:*********************** Log Started 2016-10-27T05:59:05Z ***********************
05:59:05:WU03:FS01:0x21:Project: 9194 (Run 2, Clone 81, Gen 50)
05:59:05:WU03:FS01:0x21:Unit: 0x00000042ab40415c57cb2e950c352a92
05:59:05:WU03:FS01:0x21:CPU: 0x00000000000000000000000000000000
05:59:05:WU03:FS01:0x21:Machine: 1
05:59:05:WU03:FS01:0x21:Reading tar file core.xml
05:59:05:WU03:FS01:0x21:Reading tar file system.xml
05:59:05:WU03:FS01:0x21:Reading tar file integrator.xml
05:59:05:WU03:FS01:0x21:Reading tar file state.xml
05:59:05:WU03:FS01:0x21:Digital signatures verified
05:59:05:WU03:FS01:0x21:Folding@home GPU Core21 Folding@home Core
05:59:05:WU03:FS01:0x21:Version 0.0.17
05:59:10:WU03:FS01:0x21:ERROR:exception: Error downloading array interactionCount: clEnqueueReadBuffer (-5)
05:59:10:WU03:FS01:0x21:Saving result file logfile_01.txt
05:59:10:WU03:FS01:0x21:Saving result file log.txt
05:59:10:WU03:FS01:0x21:Folding@home Core Shutdown: BAD_WORK_UNIT
05:59:13:WARNING:WU03:FS01:FahCore returned: BAD_WORK_UNIT (114 = 0x72)
05:59:13:WU03:FS01:Sending unit results: id:03 state:SEND error:FAULTY project:9194 run:2 clone:81 gen:50 core:0x21 unit:0x00000042ab40415c57cb2e950c352a92
05:59:13:WU03:FS01:Uploading 2.39KiB to 171.64.65.92
05:59:13:WU03:FS01:Connecting to 171.64.65.92:8080
05:59:13:WU00:FS01:Connecting to 171.67.108.45:80
05:59:13:WU03:FS01:Upload complete
05:59:13:WU03:FS01:Server responded WORK_ACK (400)
05:59:13:WU03:FS01:Cleaning up
05:59:14:WU00:FS01:Assigned to work server 140.163.4.245
05:59:14:WU00:FS01:Requesting new work unit for slot 01: READY gpu:1:GP104 [GeForce GTX 1070] from 140.163.4.245
05:59:14:WU00:FS01:Connecting to 140.163.4.245:8080
05:59:14:WU00:FS01:Downloading 14.50MiB
05:59:20:WU00:FS01:Download 18.54%
05:59:26:WU00:FS01:Download 48.28%
05:59:32:WU00:FS01:Download 72.86%
05:59:37:WU00:FS01:Download complete
05:59:37:WU00:FS01:Received Unit: id:00 state:DOWNLOAD error:NO_ERROR project:10496 run:27 clone:4 gen:72 core:0x21 unit:0x000000638ca304f556bba80c125f0df6
05:59:37:WU00:FS01:Starting
05:59:37:WU00:FS01:Running FahCore: "d:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" d:/Users/Lythronax/AppData/Roaming/FAHClient/cores/web.stanford.edu/~pande/Win32/AMD64/NVIDIA/Fermi/Core_21.fah/FahCore_21.exe -dir 00 -suffix 01 -version 704 -lifeline 6204 -checkpoint 15 -gpu 0 -gpu-vendor nvidia
05:59:37:WU00:FS01:Started FahCore on PID 8576
05:59:37:WU00:FS01:Core PID:4300
05:59:37:WU00:FS01:FahCore 0x21 started
05:59:38:WU00:FS01:0x21:*********************** Log Started 2016-10-27T05:59:38Z ***********************
05:59:38:WU00:FS01:0x21:Project: 10496 (Run 27, Clone 4, Gen 72)
05:59:38:WU00:FS01:0x21:Unit: 0x000000638ca304f556bba80c125f0df6
05:59:38:WU00:FS01:0x21:CPU: 0x00000000000000000000000000000000
05:59:38:WU00:FS01:0x21:Machine: 1
05:59:38:WU00:FS01:0x21:Reading tar file core.xml
05:59:38:WU00:FS01:0x21:Reading tar file system.xml
05:59:39:WU00:FS01:0x21:Reading tar file integrator.xml
05:59:39:WU00:FS01:0x21:Reading tar file state.xml
05:59:41:WU00:FS01:0x21:Digital signatures verified
05:59:41:WU00:FS01:0x21:Folding@home GPU Core21 Folding@home Core
05:59:41:WU00:FS01:0x21:Version 0.0.17
05:59:58:WU00:FS01:0x21:ERROR:exception: Error downloading array interactionCount: clEnqueueReadBuffer (-5)
05:59:58:WU00:FS01:0x21:Saving result file logfile_01.txt
05:59:58:WU00:FS01:0x21:Saving result file log.txt
05:59:58:WU00:FS01:0x21:Folding@home Core Shutdown: BAD_WORK_UNIT
06:00:01:WARNING:WU00:FS01:FahCore returned: BAD_WORK_UNIT (114 = 0x72)
06:00:01:WU00:FS01:Sending unit results: id:00 state:SEND error:FAULTY project:10496 run:27 clone:4 gen:72 core:0x21 unit:0x000000638ca304f556bba80c125f0df6
06:00:01:WU00:FS01:Uploading 2.36KiB to 140.163.4.245
06:00:01:WU00:FS01:Connecting to 140.163.4.245:8080
06:00:01:WU00:FS01:Upload complete
06:00:01:WU00:FS01:Server responded WORK_ACK (400)
06:00:01:WU00:FS01:Cleaning up
06:00:01:WU02:FS01:Connecting to 171.67.108.45:80
06:00:02:WU02:FS01:Assigned to work server 171.64.65.84
06:00:02:WU02:FS01:Requesting new work unit for slot 01: READY gpu:1:GP104 [GeForce GTX 1070] from 171.64.65.84
06:00:02:WU02:FS01:Connecting to 171.64.65.84:8080
06:00:02:WU02:FS01:Downloading 3.36MiB
06:00:08:WU02:FS01:Download 35.33%
06:00:14:WU02:FS01:Download 94.84%
06:00:14:WU02:FS01:Download complete
06:00:14:WU02:FS01:Received Unit: id:02 state:DOWNLOAD error:NO_ERROR project:9192 run:0 clone:58 gen:57 core:0x21 unit:0x0000004dab40415457cb2d1e254237f9
06:00:14:WU02:FS01:Starting
06:00:14:WU02:FS01:Running FahCore: "d:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" d:/Users/Lythronax/AppData/Roaming/FAHClient/cores/web.stanford.edu/~pande/Win32/AMD64/NVIDIA/Fermi/Core_21.fah/FahCore_21.exe -dir 02 -suffix 01 -version 704 -lifeline 6204 -checkpoint 15 -gpu 0 -gpu-vendor nvidia
06:00:14:WU02:FS01:Started FahCore on PID 6836
06:00:14:WU02:FS01:Core PID:2620
06:00:14:WU02:FS01:FahCore 0x21 started
06:00:15:WU02:FS01:0x21:*********************** Log Started 2016-10-27T06:00:14Z ***********************
06:00:15:WU02:FS01:0x21:Project: 9192 (Run 0, Clone 58, Gen 57)
06:00:15:WU02:FS01:0x21:Unit: 0x0000004dab40415457cb2d1e254237f9
06:00:15:WU02:FS01:0x21:CPU: 0x00000000000000000000000000000000
06:00:15:WU02:FS01:0x21:Machine: 1
06:00:15:WU02:FS01:0x21:Reading tar file core.xml
06:00:15:WU02:FS01:0x21:Reading tar file system.xml
06:00:15:WU02:FS01:0x21:Reading tar file integrator.xml
06:00:15:WU02:FS01:0x21:Reading tar file state.xml
06:00:15:WU02:FS01:0x21:Digital signatures verified
06:00:15:WU02:FS01:0x21:Folding@home GPU Core21 Folding@home Core
06:00:15:WU02:FS01:0x21:Version 0.0.17
06:00:19:WU02:FS01:0x21:ERROR:exception: Error downloading array interactionCount: clEnqueueReadBuffer (-5)
06:00:19:WU02:FS01:0x21:Saving result file logfile_01.txt
06:00:19:WU02:FS01:0x21:Saving result file log.txt
06:00:19:WU02:FS01:0x21:Folding@home Core Shutdown: BAD_WORK_UNIT
06:00:22:WARNING:WU02:FS01:FahCore returned: BAD_WORK_UNIT (114 = 0x72)
06:00:22:WU02:FS01:Sending unit results: id:02 state:SEND error:FAULTY project:9192 run:0 clone:58 gen:57 core:0x21 unit:0x0000004dab40415457cb2d1e254237f9
06:00:22:WU02:FS01:Uploading 2.39KiB to 171.64.65.84
06:00:22:WU02:FS01:Connecting to 171.64.65.84:8080
06:00:22:WU02:FS01:Upload complete
06:00:22:WU02:FS01:Server responded WORK_ACK (400)
06:00:22:WU02:FS01:Cleaning up
06:00:22:WU00:FS01:Connecting to 171.67.108.45:80
06:00:22:WU00:FS01:Assigned to work server 140.163.4.245
06:00:22:WU00:FS01:Requesting new work unit for slot 01: READY gpu:1:GP104 [GeForce GTX 1070] from 140.163.4.245
06:00:22:WU00:FS01:Connecting to 140.163.4.245:8080
06:00:23:WU00:FS01:Downloading 5.13MiB
06:00:29:WU00:FS01:Download 29.24%
06:00:34:WU00:FS01:Download complete
06:00:34:WU00:FS01:Received Unit: id:00 state:DOWNLOAD error:NO_ERROR project:10495 run:22 clone:69 gen:6 core:0x21 unit:0x0000000d8ca304f556ba64687c3ae6e0
06:00:34:WU00:FS01:Starting
06:00:34:WU00:FS01:Running FahCore: "d:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" d:/Users/Lythronax/AppData/Roaming/FAHClient/cores/web.stanford.edu/~pande/Win32/AMD64/NVIDIA/Fermi/Core_21.fah/FahCore_21.exe -dir 00 -suffix 01 -version 704 -lifeline 6204 -checkpoint 15 -gpu 0 -gpu-vendor nvidia
06:00:34:WU00:FS01:Started FahCore on PID 5968
06:00:34:WU00:FS01:Core PID:1072
06:00:34:WU00:FS01:FahCore 0x21 started
06:00:35:WU00:FS01:0x21:*********************** Log Started 2016-10-27T06:00:35Z ***********************
06:00:35:WU00:FS01:0x21:Project: 10495 (Run 22, Clone 69, Gen 6)
06:00:35:WU00:FS01:0x21:Unit: 0x0000000d8ca304f556ba64687c3ae6e0
06:00:35:WU00:FS01:0x21:CPU: 0x00000000000000000000000000000000
06:00:35:WU00:FS01:0x21:Machine: 1
06:00:35:WU00:FS01:0x21:Reading tar file core.xml
06:00:35:WU00:FS01:0x21:Reading tar file system.xml
06:00:35:WU00:FS01:0x21:Reading tar file integrator.xml
06:00:35:WU00:FS01:0x21:Reading tar file state.xml
06:00:36:WU00:FS01:0x21:Digital signatures verified
06:00:36:WU00:FS01:0x21:Folding@home GPU Core21 Folding@home Core
06:00:36:WU00:FS01:0x21:Version 0.0.17
06:00:42:WU00:FS01:0x21:ERROR:exception: Error downloading array interactionCount: clEnqueueReadBuffer (-5)
06:00:42:WU00:FS01:0x21:Saving result file logfile_01.txt
06:00:42:WU00:FS01:0x21:Saving result file log.txt
06:00:42:WU00:FS01:0x21:Folding@home Core Shutdown: BAD_WORK_UNIT
06:00:44:WARNING:WU00:FS01:FahCore returned: BAD_WORK_UNIT (114 = 0x72)
06:00:44:WU00:FS01:Sending unit results: id:00 state:SEND error:FAULTY project:10495 run:22 clone:69 gen:6 core:0x21 unit:0x0000000d8ca304f556ba64687c3ae6e0
06:00:44:WU00:FS01:Uploading 2.36KiB to 140.163.4.245
06:00:44:WU00:FS01:Connecting to 140.163.4.245:8080
06:00:44:WU00:FS01:Upload complete
06:00:44:WU00:FS01:Server responded WORK_ACK (400)
06:00:44:WU00:FS01:Cleaning up
06:00:44:WU02:FS01:Connecting to 171.67.108.45:80
06:00:45:WU02:FS01:Assigned to work server 171.67.108.155
06:00:45:WU02:FS01:Requesting new work unit for slot 01: READY gpu:1:GP104 [GeForce GTX 1070] from 171.67.108.155
06:00:45:WU02:FS01:Connecting to 171.67.108.155:8080
06:00:46:WU02:FS01:Downloading 905.81KiB
06:00:48:WU02:FS01:Download complete
06:00:48:WU02:FS01:Received Unit: id:02 state:DOWNLOAD error:NO_ERROR project:9660 run:0 clone:60 gen:163 core:0x18 unit:0x000000bbab436c9b56de69ba04c29d6e
06:00:48:WU02:FS01:Starting
06:00:48:WU02:FS01:Running FahCore: "d:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" d:/Users/Lythronax/AppData/Roaming/FAHClient/cores/web.stanford.edu/~pande/Win32/AMD64/NVIDIA/Fermi/Core_18.fah/FahCore_18.exe -dir 02 -suffix 01 -version 704 -lifeline 6204 -checkpoint 15 -gpu 0 -gpu-vendor nvidia
06:00:48:WU02:FS01:Started FahCore on PID 5372
06:00:48:WU02:FS01:Core PID:5644
06:00:48:WU02:FS01:FahCore 0x18 started
06:00:49:WU02:FS01:0x18:*********************** Log Started 2016-10-27T06:00:49Z ***********************
06:00:49:WU02:FS01:0x18:Project: 9660 (Run 0, Clone 60, Gen 163)
06:00:49:WU02:FS01:0x18:Unit: 0x000000bbab436c9b56de69ba04c29d6e
06:00:49:WU02:FS01:0x18:CPU: 0x00000000000000000000000000000000
06:00:49:WU02:FS01:0x18:Machine: 1
06:00:49:WU02:FS01:0x18:Reading tar file core.xml
06:00:49:WU02:FS01:0x18:Reading tar file integrator.xml
06:00:49:WU02:FS01:0x18:Reading tar file state.xml
06:00:49:WU02:FS01:0x18:Reading tar file system.xml
06:00:49:WU02:FS01:0x18:Digital signatures verified
06:00:49:WU02:FS01:0x18:Folding@home GPU core18
06:00:49:WU02:FS01:0x18:Version 0.0.4
06:00:54:WU02:FS01:0x18:Completed 0 out of 2000000 steps (0%)
06:00:54:WU02:FS01:0x18:Temperature control disabled. Requirements: single Nvidia GPU, tmax must be < 110 and twait >= 900
06:01:15:WU02:FS01:0x18:Completed 20000 out of 2000000 steps (1%)
06:01:34:WU02:FS01:0x18:Completed 40000 out of 2000000 steps (2%)
06:01:53:WU02:FS01:0x18:Completed 60000 out of 2000000 steps (3%)
06:02:12:WU02:FS01:0x18:Completed 80000 out of 2000000 steps (4%)
06:02:31:WU02:FS01:0x18:Completed 100000 out of 2000000 steps (5%)
06:02:52:WU02:FS01:0x18:Completed 120000 out of 2000000 steps (6%)
06:03:12:WU02:FS01:0x18:Completed 140000 out of 2000000 steps (7%)
06:03:31:WU02:FS01:0x18:Completed 160000 out of 2000000 steps (8%)
06:03:50:WU02:FS01:0x18:Completed 180000 out of 2000000 steps (9%)
06:04:09:WU02:FS01:0x18:Completed 200000 out of 2000000 steps (10%)
06:04:30:WU02:FS01:0x18:Completed 220000 out of 2000000 steps (11%)
06:04:49:WU02:FS01:0x18:Completed 240000 out of 2000000 steps (12%)
06:05:08:WU02:FS01:0x18:Completed 260000 out of 2000000 steps (13%)
06:05:28:WU02:FS01:0x18:Completed 280000 out of 2000000 steps (14%)
06:05:47:WU02:FS01:0x18:Completed 300000 out of 2000000 steps (15%)
06:06:08:WU02:FS01:0x18:Completed 320000 out of 2000000 steps (16%)
06:06:27:WU02:FS01:0x18:Completed 340000 out of 2000000 steps (17%)
06:06:47:WU02:FS01:0x18:Completed 360000 out of 2000000 steps (18%)
06:07:06:WU02:FS01:0x18:Completed 380000 out of 2000000 steps (19%)
06:07:25:WU02:FS01:0x18:Completed 400000 out of 2000000 steps (20%)
06:07:46:WU02:FS01:0x18:Completed 420000 out of 2000000 steps (21%)
06:08:05:WU02:FS01:0x18:Completed 440000 out of 2000000 steps (22%)
06:08:24:WU02:FS01:0x18:Completed 460000 out of 2000000 steps (23%)
06:08:43:WU02:FS01:0x18:Completed 480000 out of 2000000 steps (24%)
06:09:02:WU02:FS01:0x18:Completed 500000 out of 2000000 steps (25%)
06:09:23:WU02:FS01:0x18:Completed 520000 out of 2000000 steps (26%)
06:09:42:WU02:FS01:0x18:Completed 540000 out of 2000000 steps (27%)
06:10:01:WU02:FS01:0x18:Completed 560000 out of 2000000 steps (28%)
06:10:21:WU02:FS01:0x18:Completed 580000 out of 2000000 steps (29%)
06:10:40:WU02:FS01:0x18:Completed 600000 out of 2000000 steps (30%)
06:11:01:WU02:FS01:0x18:Completed 620000 out of 2000000 steps (31%)
06:11:20:WU02:FS01:0x18:Completed 640000 out of 2000000 steps (32%)
06:11:39:WU02:FS01:0x18:Completed 660000 out of 2000000 steps (33%)
06:11:58:WU02:FS01:0x18:Completed 680000 out of 2000000 steps (34%)
06:12:17:WU02:FS01:0x18:Completed 700000 out of 2000000 steps (35%)
06:12:39:WU02:FS01:0x18:Completed 720000 out of 2000000 steps (36%)
06:12:58:WU02:FS01:0x18:Completed 740000 out of 2000000 steps (37%)
06:13:17:WU02:FS01:0x18:Completed 760000 out of 2000000 steps (38%)
06:13:37:WU02:FS01:0x18:Completed 780000 out of 2000000 steps (39%)
06:13:56:WU02:FS01:0x18:Completed 800000 out of 2000000 steps (40%)
06:14:17:WU02:FS01:0x18:Completed 820000 out of 2000000 steps (41%)
06:14:37:WU02:FS01:0x18:Completed 840000 out of 2000000 steps (42%)
06:14:56:WU02:FS01:0x18:Completed 860000 out of 2000000 steps (43%)
06:15:15:WU02:FS01:0x18:Completed 880000 out of 2000000 steps (44%)
06:15:34:WU02:FS01:0x18:Completed 900000 out of 2000000 steps (45%)
06:15:56:WU02:FS01:0x18:Completed 920000 out of 2000000 steps (46%)
06:16:15:WU02:FS01:0x18:Completed 940000 out of 2000000 steps (47%)
06:16:34:WU02:FS01:0x18:Completed 960000 out of 2000000 steps (48%)
06:16:54:WU02:FS01:0x18:Completed 980000 out of 2000000 steps (49%)
06:17:13:WU02:FS01:0x18:Completed 1000000 out of 2000000 steps (50%)
06:17:34:WU02:FS01:0x18:Completed 1020000 out of 2000000 steps (51%)
06:17:53:WU02:FS01:0x18:Completed 1040000 out of 2000000 steps (52%)
06:18:13:WU02:FS01:0x18:Completed 1060000 out of 2000000 steps (53%)
06:18:32:WU02:FS01:0x18:Completed 1080000 out of 2000000 steps (54%)
06:18:51:WU02:FS01:0x18:Completed 1100000 out of 2000000 steps (55%)
06:19:12:WU02:FS01:0x18:Completed 1120000 out of 2000000 steps (56%)
06:19:32:WU02:FS01:0x18:Completed 1140000 out of 2000000 steps (57%)
06:19:51:WU02:FS01:0x18:Completed 1160000 out of 2000000 steps (58%)
06:20:10:WU02:FS01:0x18:Completed 1180000 out of 2000000 steps (59%)
06:20:29:WU02:FS01:0x18:Completed 1200000 out of 2000000 steps (60%)
06:20:51:WU02:FS01:0x18:Completed 1220000 out of 2000000 steps (61%)
06:21:10:WU02:FS01:0x18:Completed 1240000 out of 2000000 steps (62%)
06:21:31:WU02:FS01:0x18:Completed 1260000 out of 2000000 steps (63%)
06:21:52:WU02:FS01:0x18:Completed 1280000 out of 2000000 steps (64%)
06:22:12:WU02:FS01:0x18:Completed 1300000 out of 2000000 steps (65%)
06:22:35:WU02:FS01:0x18:Completed 1320000 out of 2000000 steps (66%)
06:22:56:WU02:FS01:0x18:Completed 1340000 out of 2000000 steps (67%)
06:23:15:WU02:FS01:0x18:Completed 1360000 out of 2000000 steps (68%)
06:23:34:WU02:FS01:0x18:Completed 1380000 out of 2000000 steps (69%)
06:23:53:WU02:FS01:0x18:Completed 1400000 out of 2000000 steps (70%)
06:24:15:WU02:FS01:0x18:Completed 1420000 out of 2000000 steps (71%)
06:24:34:WU02:FS01:0x18:Completed 1440000 out of 2000000 steps (72%)
06:24:53:WU02:FS01:0x18:Completed 1460000 out of 2000000 steps (73%)
06:25:12:WU02:FS01:0x18:Completed 1480000 out of 2000000 steps (74%)
06:25:31:WU02:FS01:0x18:Completed 1500000 out of 2000000 steps (75%)
06:25:52:WU02:FS01:0x18:Completed 1520000 out of 2000000 steps (76%)
06:26:12:WU02:FS01:0x18:Completed 1540000 out of 2000000 steps (77%)
06:26:31:WU02:FS01:0x18:Completed 1560000 out of 2000000 steps (78%)
06:26:50:WU02:FS01:0x18:Completed 1580000 out of 2000000 steps (79%)
06:27:09:WU02:FS01:0x18:Completed 1600000 out of 2000000 steps (80%)
06:27:30:WU02:FS01:0x18:Completed 1620000 out of 2000000 steps (81%)
06:27:49:WU02:FS01:0x18:Completed 1640000 out of 2000000 steps (82%)
06:28:09:WU02:FS01:0x18:Completed 1660000 out of 2000000 steps (83%)
06:28:28:WU02:FS01:0x18:Completed 1680000 out of 2000000 steps (84%)
06:28:47:WU02:FS01:0x18:Completed 1700000 out of 2000000 steps (85%)
06:29:08:WU02:FS01:0x18:Completed 1720000 out of 2000000 steps (86%)
06:29:27:WU02:FS01:0x18:Completed 1740000 out of 2000000 steps (87%)
06:29:47:WU02:FS01:0x18:Completed 1760000 out of 2000000 steps (88%)
06:30:06:WU02:FS01:0x18:Completed 1780000 out of 2000000 steps (89%)
06:30:25:WU02:FS01:0x18:Completed 1800000 out of 2000000 steps (90%)
06:30:46:WU02:FS01:0x18:Completed 1820000 out of 2000000 steps (91%)
06:31:05:WU02:FS01:0x18:Completed 1840000 out of 2000000 steps (92%)
06:31:25:WU02:FS01:0x18:Completed 1860000 out of 2000000 steps (93%)
06:31:44:WU02:FS01:0x18:Completed 1880000 out of 2000000 steps (94%)
06:32:03:WU02:FS01:0x18:Completed 1900000 out of 2000000 steps (95%)
06:32:24:WU02:FS01:0x18:Completed 1920000 out of 2000000 steps (96%)
06:32:43:WU02:FS01:0x18:Completed 1940000 out of 2000000 steps (97%)
06:33:02:WU02:FS01:0x18:Completed 1960000 out of 2000000 steps (98%)
06:33:22:WU02:FS01:0x18:Completed 1980000 out of 2000000 steps (99%)
06:33:41:WU02:FS01:0x18:Completed 2000000 out of 2000000 steps (100%)
06:33:42:WU00:FS01:Connecting to 171.67.108.45:80
06:33:42:WU00:FS01:Assigned to work server 171.67.108.159
06:33:42:WU00:FS01:Requesting new work unit for slot 01: RUNNING gpu:1:GP104 [GeForce GTX 1070] from 171.67.108.159
06:33:42:WU00:FS01:Connecting to 171.67.108.159:8080
06:33:43:WU00:FS01:Downloading 24.45MiB
06:33:43:WU02:FS01:0x18:Saving result file logfile_01.txt
06:33:43:WU02:FS01:0x18:Saving result file checkpointState.xml
06:33:43:WU02:FS01:0x18:Saving result file checkpt.crc
06:33:43:WU02:FS01:0x18:Saving result file log.txt
06:33:43:WU02:FS01:0x18:Saving result file positions.xtc
06:33:44:WU02:FS01:0x18:Folding@home Core Shutdown: FINISHED_UNIT
06:33:44:WU02:FS01:FahCore returned: FINISHED_UNIT (100 = 0x64)
06:33:44:WU02:FS01:Sending unit results: id:02 state:SEND error:NO_ERROR project:9660 run:0 clone:60 gen:163 core:0x18 unit:0x000000bbab436c9b56de69ba04c29d6e
06:33:44:WU02:FS01:Uploading 1.75MiB to 171.67.108.155
06:33:44:WU02:FS01:Connecting to 171.67.108.155:8080
06:33:49:WU00:FS01:Download 31.19%
06:33:50:WU02:FS01:Upload 10.71%
06:33:55:WU00:FS01:Download 51.38%
06:33:57:WU02:FS01:Upload 32.14%
06:34:01:WU00:FS01:Download 63.65%
06:34:03:WU02:FS01:Upload 53.57%
06:34:07:WU00:FS01:Download 75.16%
06:34:09:WU02:FS01:Upload 82.13%
06:34:13:WU00:FS01:Download 93.82%
06:34:13:WU02:FS01:Upload complete
06:34:13:WU02:FS01:Server responded WORK_ACK (400)
06:34:13:WU02:FS01:Final credit estimate, 12638.00 points
06:34:13:WU02:FS01:Cleaning up
06:34:15:WU00:FS01:Download complete
06:34:15:WU00:FS01:Received Unit: id:00 state:DOWNLOAD error:NO_ERROR project:9179 run:10 clone:2 gen:41 core:0x21 unit:0x00000032ab436c9f57bdce04bd12a64d
06:34:15:WU00:FS01:Starting
06:34:15:WU00:FS01:Running FahCore: "d:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" d:/Users/Lythronax/AppData/Roaming/FAHClient/cores/web.stanford.edu/~pande/Win32/AMD64/NVIDIA/Fermi/Core_21.fah/FahCore_21.exe -dir 00 -suffix 01 -version 704 -lifeline 6204 -checkpoint 15 -gpu 0 -gpu-vendor nvidia
06:34:15:WU00:FS01:Started FahCore on PID 6708
06:34:15:WU00:FS01:Core PID:5688
06:34:15:WU00:FS01:FahCore 0x21 started
06:34:16:WU00:FS01:0x21:*********************** Log Started 2016-10-27T06:34:15Z ***********************
06:34:16:WU00:FS01:0x21:Project: 9179 (Run 10, Clone 2, Gen 41)
06:34:16:WU00:FS01:0x21:Unit: 0x00000032ab436c9f57bdce04bd12a64d
06:34:16:WU00:FS01:0x21:CPU: 0x00000000000000000000000000000000
06:34:16:WU00:FS01:0x21:Machine: 1
06:34:16:WU00:FS01:0x21:Reading tar file core.xml
06:34:16:WU00:FS01:0x21:Reading tar file integrator.xml
06:34:16:WU00:FS01:0x21:Reading tar file state.xml
06:34:16:WU00:FS01:0x21:Reading tar file system.xml
06:34:16:WU00:FS01:0x21:Digital signatures verified
06:34:16:WU00:FS01:0x21:Folding@home GPU Core21 Folding@home Core
06:34:16:WU00:FS01:0x21:Version 0.0.17
06:34:22:WU00:FS01:0x21:ERROR:exception: Error downloading array interactionCount: clEnqueueReadBuffer (-5)
06:34:22:WU00:FS01:0x21:Saving result file logfile_01.txt
06:34:22:WU00:FS01:0x21:Saving result file log.txt
06:34:22:WU00:FS01:0x21:Folding@home Core Shutdown: BAD_WORK_UNIT
06:34:24:WARNING:WU00:FS01:FahCore returned: BAD_WORK_UNIT (114 = 0x72)
06:34:24:WU00:FS01:Sending unit results: id:00 state:SEND error:FAULTY project:9179 run:10 clone:2 gen:41 core:0x21 unit:0x00000032ab436c9f57bdce04bd12a64d
06:34:24:WU00:FS01:Uploading 7.00KiB to 171.67.108.159
06:34:24:WU00:FS01:Connecting to 171.67.108.159:8080
06:34:24:WU00:FS01:Upload complete
06:34:24:WU00:FS01:Server responded WORK_ACK (400)
06:34:24:WU00:FS01:Cleaning up
06:34:24:WU02:FS01:Connecting to 171.67.108.45:80
06:34:25:WU02:FS01:Assigned to work server 171.64.65.92
06:34:25:WU02:FS01:Requesting new work unit for slot 01: READY gpu:1:GP104 [GeForce GTX 1070] from 171.64.65.92
06:34:25:WU02:FS01:Connecting to 171.64.65.92:8080
06:34:25:WU02:FS01:Downloading 2.52MiB
06:34:31:WU02:FS01:Download 64.46%
06:34:35:WU02:FS01:Download complete
06:34:35:WU02:FS01:Received Unit: id:02 state:DOWNLOAD error:NO_ERROR project:9195 run:0 clone:2 gen:176 core:0x21 unit:0x000000cdab40415c57cb2e9f39bcb8cf
06:34:35:WU02:FS01:Starting
06:34:35:WU02:FS01:Running FahCore: "d:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" d:/Users/Lythronax/AppData/Roaming/FAHClient/cores/web.stanford.edu/~pande/Win32/AMD64/NVIDIA/Fermi/Core_21.fah/FahCore_21.exe -dir 02 -suffix 01 -version 704 -lifeline 6204 -checkpoint 15 -gpu 0 -gpu-vendor nvidia
06:34:35:WU02:FS01:Started FahCore on PID 8684
06:34:35:WU02:FS01:Core PID:4372
06:34:35:WU02:FS01:FahCore 0x21 started
06:34:36:WU02:FS01:0x21:*********************** Log Started 2016-10-27T06:34:36Z ***********************
06:34:36:WU02:FS01:0x21:Project: 9195 (Run 0, Clone 2, Gen 176)
06:34:36:WU02:FS01:0x21:Unit: 0x000000cdab40415c57cb2e9f39bcb8cf
06:34:36:WU02:FS01:0x21:CPU: 0x00000000000000000000000000000000
06:34:36:WU02:FS01:0x21:Machine: 1
06:34:36:WU02:FS01:0x21:Reading tar file core.xml
06:34:36:WU02:FS01:0x21:Reading tar file system.xml
06:34:36:WU02:FS01:0x21:Reading tar file integrator.xml
06:34:36:WU02:FS01:0x21:Reading tar file state.xml
06:34:37:WU02:FS01:0x21:Digital signatures verified
06:34:37:WU02:FS01:0x21:Folding@home GPU Core21 Folding@home Core
06:34:37:WU02:FS01:0x21:Version 0.0.17
06:34:41:WU02:FS01:0x21:ERROR:exception: Error downloading array interactionCount: clEnqueueReadBuffer (-5)
06:34:41:WU02:FS01:0x21:Saving result file logfile_01.txt
06:34:41:WU02:FS01:0x21:Saving result file log.txt
06:34:41:WU02:FS01:0x21:Folding@home Core Shutdown: BAD_WORK_UNIT
06:34:43:WARNING:WU02:FS01:FahCore returned: BAD_WORK_UNIT (114 = 0x72)
06:34:43:WU02:FS01:Sending unit results: id:02 state:SEND error:FAULTY project:9195 run:0 clone:2 gen:176 core:0x21 unit:0x000000cdab40415c57cb2e9f39bcb8cf
06:34:43:WU02:FS01:Uploading 2.40KiB to 171.64.65.92
06:34:43:WU02:FS01:Connecting to 171.64.65.92:8080
06:34:43:WU00:FS01:Connecting to 171.67.108.45:80
06:34:43:WU02:FS01:Upload complete
06:34:43:WU02:FS01:Server responded WORK_ACK (400)
06:34:43:WU02:FS01:Cleaning up
06:34:44:WU00:FS01:Assigned to work server 171.67.108.159
06:34:44:WU00:FS01:Requesting new work unit for slot 01: READY gpu:1:GP104 [GeForce GTX 1070] from 171.67.108.159
06:34:44:WU00:FS01:Connecting to 171.67.108.159:8080
06:34:44:WU00:FS01:Downloading 22.96MiB
06:34:50:WU00:FS01:Download 11.16%
06:34:56:WU00:FS01:Download 26.41%
06:35:02:WU00:FS01:Download 46.01%
06:35:08:WU00:FS01:Download 57.99%
06:35:14:WU00:FS01:Download 71.05%
06:35:20:WU00:FS01:Download 94.74%
06:35:22:WU00:FS01:Download complete
06:35:22:WU00:FS01:Received Unit: id:00 state:DOWNLOAD error:NO_ERROR project:9179 run:36 clone:9 gen:70 core:0x21 unit:0x00000067ab436c9f57bdce05a65b3710
06:35:22:WU00:FS01:Starting
06:35:22:WU00:FS01:Running FahCore: "d:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" d:/Users/Lythronax/AppData/Roaming/FAHClient/cores/web.stanford.edu/~pande/Win32/AMD64/NVIDIA/Fermi/Core_21.fah/FahCore_21.exe -dir 00 -suffix 01 -version 704 -lifeline 6204 -checkpoint 15 -gpu 0 -gpu-vendor nvidia
06:35:22:WU00:FS01:Started FahCore on PID 6964
06:35:22:WU00:FS01:Core PID:5968
06:35:22:WU00:FS01:FahCore 0x21 started
06:35:23:WU00:FS01:0x21:*********************** Log Started 2016-10-27T06:35:22Z ***********************
06:35:23:WU00:FS01:0x21:Project: 9179 (Run 36, Clone 9, Gen 70)
06:35:23:WU00:FS01:0x21:Unit: 0x00000067ab436c9f57bdce05a65b3710
06:35:23:WU00:FS01:0x21:CPU: 0x00000000000000000000000000000000
06:35:23:WU00:FS01:0x21:Machine: 1
06:35:23:WU00:FS01:0x21:Reading tar file core.xml
06:35:23:WU00:FS01:0x21:Reading tar file integrator.xml
06:35:23:WU00:FS01:0x21:Reading tar file state.xml
06:35:23:WU00:FS01:0x21:Reading tar file system.xml
06:35:23:WU00:FS01:0x21:Digital signatures verified
06:35:23:WU00:FS01:0x21:Folding@home GPU Core21 Folding@home Core
06:35:23:WU00:FS01:0x21:Version 0.0.17
06:35:28:WU00:FS01:0x21:ERROR:exception: Error downloading array interactionCount: clEnqueueReadBuffer (-5)
06:35:28:WU00:FS01:0x21:Saving result file logfile_01.txt
06:35:28:WU00:FS01:0x21:Saving result file log.txt
06:35:28:WU00:FS01:0x21:Folding@home Core Shutdown: BAD_WORK_UNIT
06:35:31:WARNING:WU00:FS01:FahCore returned: BAD_WORK_UNIT (114 = 0x72)
06:35:31:WU00:FS01:Sending unit results: id:00 state:SEND error:FAULTY project:9179 run:36 clone:9 gen:70 core:0x21 unit:0x00000067ab436c9f57bdce05a65b3710
06:35:31:WU00:FS01:Uploading 7.00KiB to 171.67.108.159
06:35:31:WU00:FS01:Connecting to 171.67.108.159:8080
06:35:31:WU02:FS01:Connecting to 171.67.108.45:80
06:35:31:WU02:FS01:Assigned to work server 171.64.65.92
06:35:31:WU02:FS01:Requesting new work unit for slot 01: READY gpu:1:GP104 [GeForce GTX 1070] from 171.64.65.92
06:35:31:WU02:FS01:Connecting to 171.64.65.92:8080
06:35:31:WU00:FS01:Upload complete
06:35:32:WU00:FS01:Server responded WORK_ACK (400)
06:35:32:WU00:FS01:Cleaning up
06:35:32:WU02:FS01:Downloading 2.52MiB
06:35:38:WU02:FS01:Download 89.28%
06:35:38:WU02:FS01:Download complete
06:35:38:WU02:FS01:Received Unit: id:02 state:DOWNLOAD error:NO_ERROR project:9195 run:0 clone:42 gen:90 core:0x21 unit:0x0000007dab40415c57cb2eae6717c5db
06:35:38:WU02:FS01:Starting
06:35:38:WU02:FS01:Running FahCore: "d:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" d:/Users/Lythronax/AppData/Roaming/FAHClient/cores/web.stanford.edu/~pande/Win32/AMD64/NVIDIA/Fermi/Core_21.fah/FahCore_21.exe -dir 02 -suffix 01 -version 704 -lifeline 6204 -checkpoint 15 -gpu 0 -gpu-vendor nvidia
06:35:38:WU02:FS01:Started FahCore on PID 2884
06:35:38:WU02:FS01:Core PID:5680
06:35:38:WU02:FS01:FahCore 0x21 started
06:35:39:WU02:FS01:0x21:*********************** Log Started 2016-10-27T06:35:39Z ***********************
06:35:39:WU02:FS01:0x21:Project: 9195 (Run 0, Clone 42, Gen 90)
06:35:39:WU02:FS01:0x21:Unit: 0x0000007dab40415c57cb2eae6717c5db
06:35:39:WU02:FS01:0x21:CPU: 0x00000000000000000000000000000000
06:35:39:WU02:FS01:0x21:Machine: 1
06:35:39:WU02:FS01:0x21:Reading tar file core.xml
06:35:39:WU02:FS01:0x21:Reading tar file system.xml
06:35:39:WU02:FS01:0x21:Reading tar file integrator.xml
06:35:39:WU02:FS01:0x21:Reading tar file state.xml
06:35:40:WU02:FS01:0x21:Digital signatures verified
06:35:40:WU02:FS01:0x21:Folding@home GPU Core21 Folding@home Core
06:35:40:WU02:FS01:0x21:Version 0.0.17
06:35:43:WU02:FS01:0x21:ERROR:exception: Error downloading array interactionCount: clEnqueueReadBuffer (-5)
06:35:43:WU02:FS01:0x21:Saving result file logfile_01.txt
06:35:43:WU02:FS01:0x21:Saving result file log.txt
06:35:43:WU02:FS01:0x21:Folding@home Core Shutdown: BAD_WORK_UNIT
06:35:45:WARNING:WU02:FS01:FahCore returned: BAD_WORK_UNIT (114 = 0x72)
06:35:45:WU02:FS01:Sending unit results: id:02 state:SEND error:FAULTY project:9195 run:0 clone:42 gen:90 core:0x21 unit:0x0000007dab40415c57cb2eae6717c5db
06:35:45:WU02:FS01:Uploading 2.38KiB to 171.64.65.92
06:35:45:WU02:FS01:Connecting to 171.64.65.92:8080
06:35:45:WU00:FS01:Connecting to 171.67.108.45:80
06:35:46:WU02:FS01:Upload complete
06:35:46:WU00:FS01:Assigned to work server 140.163.4.242
06:35:46:WU00:FS01:Requesting new work unit for slot 01: READY gpu:1:GP104 [GeForce GTX 1070] from 140.163.4.242
06:35:46:WU02:FS01:Server responded WORK_ACK (400)
06:35:46:WU00:FS01:Connecting to 140.163.4.242:8080
06:35:46:WU02:FS01:Cleaning up
06:35:46:WU00:FS01:Downloading 3.44MiB
06:35:50:WU00:FS01:Download complete
06:35:50:WU00:FS01:Received Unit: id:00 state:DOWNLOAD error:NO_ERROR project:11400 run:94 clone:38 gen:11 core:0x21 unit:0x0000000d8ca304f257c5cb459bb4f985
06:35:50:WU00:FS01:Starting
06:35:50:WU00:FS01:Running FahCore: "d:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" d:/Users/Lythronax/AppData/Roaming/FAHClient/cores/web.stanford.edu/~pande/Win32/AMD64/NVIDIA/Fermi/Core_21.fah/FahCore_21.exe -dir 00 -suffix 01 -version 704 -lifeline 6204 -checkpoint 15 -gpu 0 -gpu-vendor nvidia
06:35:50:WU00:FS01:Started FahCore on PID 5668
06:35:50:WU00:FS01:Core PID:2084
06:35:50:WU00:FS01:FahCore 0x21 started
06:35:51:WU00:FS01:0x21:*********************** Log Started 2016-10-27T06:35:50Z ***********************
06:35:51:WU00:FS01:0x21:Project: 11400 (Run 94, Clone 38, Gen 11)
06:35:51:WU00:FS01:0x21:Unit: 0x0000000d8ca304f257c5cb459bb4f985
06:35:51:WU00:FS01:0x21:CPU: 0x00000000000000000000000000000000
06:35:51:WU00:FS01:0x21:Machine: 1
06:35:51:WU00:FS01:0x21:Reading tar file core.xml
06:35:51:WU00:FS01:0x21:Reading tar file system.xml
06:35:51:WU00:FS01:0x21:Reading tar file integrator.xml
06:35:51:WU00:FS01:0x21:Reading tar file state.xml
06:35:51:WU00:FS01:0x21:Digital signatures verified
06:35:51:WU00:FS01:0x21:Folding@home GPU Core21 Folding@home Core
06:35:51:WU00:FS01:0x21:Version 0.0.17
06:35:55:WU00:FS01:0x21:ERROR:exception: Error downloading array interactionCount: clEnqueueReadBuffer (-5)
06:35:55:WU00:FS01:0x21:Saving result file logfile_01.txt
06:35:55:WU00:FS01:0x21:Saving result file log.txt
06:35:55:WU00:FS01:0x21:Folding@home Core Shutdown: BAD_WORK_UNIT
06:35:58:WARNING:WU00:FS01:FahCore returned: BAD_WORK_UNIT (114 = 0x72)
06:35:58:WU00:FS01:Sending unit results: id:00 state:SEND error:FAULTY project:11400 run:94 clone:38 gen:11 core:0x21 unit:0x0000000d8ca304f257c5cb459bb4f985
06:35:58:WU00:FS01:Uploading 2.42KiB to 140.163.4.242
06:35:58:WU00:FS01:Connecting to 140.163.4.242:8080
06:35:58:WU00:FS01:Upload complete
06:35:58:WU00:FS01:Server responded WORK_ACK (400)
06:35:58:WU00:FS01:Cleaning up
06:35:58:WU02:FS01:Connecting to 171.67.108.45:80
06:35:58:WU02:FS01:Assigned to work server 171.67.108.105
06:35:58:WU02:FS01:Requesting new work unit for slot 01: READY gpu:1:GP104 [GeForce GTX 1070] from 171.67.108.105
06:35:58:WU02:FS01:Connecting to 171.67.108.105:8080
06:35:59:WU02:FS01:Downloading 20.50MiB
06:36:05:WU02:FS01:Download 27.13%
06:36:11:WU02:FS01:Download 42.37%
06:36:17:WU02:FS01:Download 51.21%
06:36:23:WU02:FS01:Download 67.97%
06:36:29:WU02:FS01:Download 84.13%
06:36:34:WU02:FS01:Download complete
06:36:34:WU02:FS01:Received Unit: id:02 state:DOWNLOAD error:NO_ERROR project:9176 run:29 clone:13 gen:94 core:0x21 unit:0x00000073ab436c6957b24c293ab2282b
06:36:34:WU02:FS01:Starting
06:36:34:WU02:FS01:Running FahCore: "d:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" d:/Users/Lythronax/AppData/Roaming/FAHClient/cores/web.stanford.edu/~pande/Win32/AMD64/NVIDIA/Fermi/Core_21.fah/FahCore_21.exe -dir 02 -suffix 01 -version 704 -lifeline 6204 -checkpoint 15 -gpu 0 -gpu-vendor nvidia
06:36:34:WU02:FS01:Started FahCore on PID 4392
06:36:34:WU02:FS01:Core PID:8916
06:36:34:WU02:FS01:FahCore 0x21 started
06:36:35:WU02:FS01:0x21:*********************** Log Started 2016-10-27T06:36:35Z ***********************
06:36:35:WU02:FS01:0x21:Project: 9176 (Run 29, Clone 13, Gen 94)
06:36:35:WU02:FS01:0x21:Unit: 0x00000073ab436c6957b24c293ab2282b
06:36:35:WU02:FS01:0x21:CPU: 0x00000000000000000000000000000000
06:36:35:WU02:FS01:0x21:Machine: 1
06:36:35:WU02:FS01:0x21:Reading tar file core.xml
06:36:35:WU02:FS01:0x21:Reading tar file integrator.xml
06:36:35:WU02:FS01:0x21:Reading tar file state.xml
06:36:35:WU02:FS01:0x21:Reading tar file system.xml
06:36:35:WU02:FS01:0x21:Digital signatures verified
06:36:35:WU02:FS01:0x21:Folding@home GPU Core21 Folding@home Core
06:36:35:WU02:FS01:0x21:Version 0.0.17
06:36:41:WU02:FS01:0x21:ERROR:exception: Error downloading array interactionCount: clEnqueueReadBuffer (-5)
06:36:41:WU02:FS01:0x21:Saving result file logfile_01.txt
06:36:41:WU02:FS01:0x21:Saving result file log.txt
06:36:41:WU02:FS01:0x21:Folding@home Core Shutdown: BAD_WORK_UNIT
06:36:44:WARNING:WU02:FS01:FahCore returned: BAD_WORK_UNIT (114 = 0x72)
06:36:44:WU02:FS01:Sending unit results: id:02 state:SEND error:FAULTY project:9176 run:29 clone:13 gen:94 core:0x21 unit:0x00000073ab436c6957b24c293ab2282b
06:36:44:WU02:FS01:Uploading 7.00KiB to 171.67.108.105
06:36:44:WU02:FS01:Connecting to 171.67.108.105:8080
06:36:44:WU02:FS01:Upload complete
06:36:44:WU02:FS01:Server responded WORK_ACK (400)
06:36:44:WU02:FS01:Cleaning up
06:36:44:WU00:FS01:Connecting to 171.67.108.45:80
06:36:45:WU00:FS01:Assigned to work server 140.163.4.245
06:36:45:WU00:FS01:Requesting new work unit for slot 01: READY gpu:1:GP104 [GeForce GTX 1070] from 140.163.4.245
06:36:45:WU00:FS01:Connecting to 140.163.4.245:8080
06:36:45:WU00:FS01:Downloading 5.13MiB
06:36:51:WU00:FS01:Download 75.56%
06:36:52:WU00:FS01:Download complete
06:36:52:WU00:FS01:Received Unit: id:00 state:DOWNLOAD error:NO_ERROR project:10495 run:22 clone:37 gen:19 core:0x21 unit:0x000000208ca304f556ba645d8c7bff73
06:36:52:WU00:FS01:Starting
06:36:52:WU00:FS01:Running FahCore: "d:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" d:/Users/Lythronax/AppData/Roaming/FAHClient/cores/web.stanford.edu/~pande/Win32/AMD64/NVIDIA/Fermi/Core_21.fah/FahCore_21.exe -dir 00 -suffix 01 -version 704 -lifeline 6204 -checkpoint 15 -gpu 0 -gpu-vendor nvidia
06:36:52:WU00:FS01:Started FahCore on PID 8048
06:36:52:WU00:FS01:Core PID:4464
06:36:52:WU00:FS01:FahCore 0x21 started
06:36:53:WU00:FS01:0x21:*********************** Log Started 2016-10-27T06:36:53Z ***********************
06:36:53:WU00:FS01:0x21:Project: 10495 (Run 22, Clone 37, Gen 19)
06:36:53:WU00:FS01:0x21:Unit: 0x000000208ca304f556ba645d8c7bff73
06:36:53:WU00:FS01:0x21:CPU: 0x00000000000000000000000000000000
06:36:53:WU00:FS01:0x21:Machine: 1
06:36:53:WU00:FS01:0x21:Reading tar file core.xml
06:36:53:WU00:FS01:0x21:Reading tar file system.xml
06:36:54:WU00:FS01:0x21:Reading tar file integrator.xml
06:36:54:WU00:FS01:0x21:Reading tar file state.xml
06:36:54:WU00:FS01:0x21:Digital signatures verified
06:36:54:WU00:FS01:0x21:Folding@home GPU Core21 Folding@home Core
06:36:54:WU00:FS01:0x21:Version 0.0.17
06:37:00:WU00:FS01:0x21:ERROR:exception: Error downloading array interactionCount: clEnqueueReadBuffer (-5)
06:37:00:WU00:FS01:0x21:Saving result file logfile_01.txt
06:37:00:WU00:FS01:0x21:Saving result file log.txt
06:37:00:WU00:FS01:0x21:Folding@home Core Shutdown: BAD_WORK_UNIT
06:37:02:WARNING:WU00:FS01:FahCore returned: BAD_WORK_UNIT (114 = 0x72)
06:37:02:WU00:FS01:Sending unit results: id:00 state:SEND error:FAULTY project:10495 run:22 clone:37 gen:19 core:0x21 unit:0x000000208ca304f556ba645d8c7bff73
06:37:02:WU00:FS01:Uploading 2.36KiB to 140.163.4.245
06:37:02:WU00:FS01:Connecting to 140.163.4.245:8080
06:37:03:WU00:FS01:Upload complete
06:37:03:WU00:FS01:Server responded WORK_ACK (400)
06:37:03:WU00:FS01:Cleaning up
06:37:03:WU02:FS01:Connecting to 171.67.108.45:80
06:37:03:WU02:FS01:Assigned to work server 140.163.4.242
06:37:03:WU02:FS01:Requesting new work unit for slot 01: READY gpu:1:GP104 [GeForce GTX 1070] from 140.163.4.242
06:37:03:WU02:FS01:Connecting to 140.163.4.242:8080
06:37:03:WU02:FS01:Downloading 3.44MiB
06:37:09:WU02:FS01:Download 70.88%
06:37:10:WU02:FS01:Download complete
06:37:10:WU02:FS01:Received Unit: id:02 state:DOWNLOAD error:NO_ERROR project:11400 run:92 clone:29 gen:9 core:0x21 unit:0x0000000c8ca304f257c5cb330a42a3aa
06:37:10:WU02:FS01:Starting
06:37:10:WU02:FS01:Running FahCore: "d:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" d:/Users/Lythronax/AppData/Roaming/FAHClient/cores/web.stanford.edu/~pande/Win32/AMD64/NVIDIA/Fermi/Core_21.fah/FahCore_21.exe -dir 02 -suffix 01 -version 704 -lifeline 6204 -checkpoint 15 -gpu 0 -gpu-vendor nvidia
06:37:10:WU02:FS01:Started FahCore on PID 9136
06:37:10:WU02:FS01:Core PID:7328
06:37:10:WU02:FS01:FahCore 0x21 started
06:37:11:WU02:FS01:0x21:*********************** Log Started 2016-10-27T06:37:11Z ***********************
06:37:11:WU02:FS01:0x21:Project: 11400 (Run 92, Clone 29, Gen 9)
06:37:11:WU02:FS01:0x21:Unit: 0x0000000c8ca304f257c5cb330a42a3aa
06:37:11:WU02:FS01:0x21:CPU: 0x00000000000000000000000000000000
06:37:11:WU02:FS01:0x21:Machine: 1
06:37:11:WU02:FS01:0x21:Reading tar file core.xml
06:37:11:WU02:FS01:0x21:Reading tar file system.xml
06:37:11:WU02:FS01:0x21:Reading tar file integrator.xml
06:37:11:WU02:FS01:0x21:Reading tar file state.xml
06:37:12:WU02:FS01:0x21:Digital signatures verified
06:37:12:WU02:FS01:0x21:Folding@home GPU Core21 Folding@home Core
06:37:12:WU02:FS01:0x21:Version 0.0.17
06:37:16:WU02:FS01:0x21:ERROR:exception: Error downloading array interactionCount: clEnqueueReadBuffer (-5)
06:37:16:WU02:FS01:0x21:Saving result file logfile_01.txt
06:37:16:WU02:FS01:0x21:Saving result file log.txt
06:37:16:WU02:FS01:0x21:Folding@home Core Shutdown: BAD_WORK_UNIT
06:37:18:WARNING:WU02:FS01:FahCore returned: BAD_WORK_UNIT (114 = 0x72)
06:37:18:WU02:FS01:Sending unit results: id:02 state:SEND error:FAULTY project:11400 run:92 clone:29 gen:9 core:0x21 unit:0x0000000c8ca304f257c5cb330a42a3aa
06:37:18:WU02:FS01:Uploading 2.40KiB to 140.163.4.242
06:37:18:WU02:FS01:Connecting to 140.163.4.242:8080
06:37:18:WU02:FS01:Upload complete
06:37:18:WU02:FS01:Server responded WORK_ACK (400)
06:37:18:WU02:FS01:Cleaning up
06:37:18:WU00:FS01:Connecting to 171.67.108.45:80
06:37:19:WU00:FS01:Assigned to work server 140.163.4.243
06:37:19:WU00:FS01:Requesting new work unit for slot 01: READY gpu:1:GP104 [GeForce GTX 1070] from 140.163.4.243
06:37:19:WU00:FS01:Connecting to 140.163.4.243:8080
06:37:20:WU00:FS01:Downloading 2.67MiB
06:37:24:WU00:FS01:Download complete
06:37:24:WU00:FS01:Received Unit: id:00 state:DOWNLOAD error:NO_ERROR project:11709 run:0 clone:214 gen:13 core:0x21 unit:0x000000128ca304f357ed33bb14873662
06:37:24:WU00:FS01:Starting
06:37:24:WU00:FS01:Running FahCore: "d:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" d:/Users/Lythronax/AppData/Roaming/FAHClient/cores/web.stanford.edu/~pande/Win32/AMD64/NVIDIA/Fermi/Core_21.fah/FahCore_21.exe -dir 00 -suffix 01 -version 704 -lifeline 6204 -checkpoint 15 -gpu 0 -gpu-vendor nvidia
06:37:24:WU00:FS01:Started FahCore on PID 4928
06:37:24:WU00:FS01:Core PID:6996
06:37:24:WU00:FS01:FahCore 0x21 started
06:37:25:WU00:FS01:0x21:*********************** Log Started 2016-10-27T06:37:24Z ***********************
06:37:25:WU00:FS01:0x21:Project: 11709 (Run 0, Clone 214, Gen 13)
06:37:25:WU00:FS01:0x21:Unit: 0x000000128ca304f357ed33bb14873662
06:37:25:WU00:FS01:0x21:CPU: 0x00000000000000000000000000000000
06:37:25:WU00:FS01:0x21:Machine: 1
06:37:25:WU00:FS01:0x21:Reading tar file core.xml
06:37:25:WU00:FS01:0x21:Reading tar file system.xml
06:37:25:WU00:FS01:0x21:Reading tar file integrator.xml
06:37:25:WU00:FS01:0x21:Reading tar file state.xml
06:37:25:WU00:FS01:0x21:Digital signatures verified
06:37:25:WU00:FS01:0x21:Folding@home GPU Core21 Folding@home Core
06:37:25:WU00:FS01:0x21:Version 0.0.17
06:37:28:WU00:FS01:0x21:ERROR:exception: Error downloading array interactionCount: clEnqueueReadBuffer (-5)
06:37:28:WU00:FS01:0x21:Saving result file logfile_01.txt
06:37:28:WU00:FS01:0x21:Saving result file log.txt
06:37:28:WU00:FS01:0x21:Folding@home Core Shutdown: BAD_WORK_UNIT
06:37:30:WARNING:WU00:FS01:FahCore returned: BAD_WORK_UNIT (114 = 0x72)
06:37:30:WU00:FS01:Sending unit results: id:00 state:SEND error:FAULTY project:11709 run:0 clone:214 gen:13 core:0x21 unit:0x000000128ca304f357ed33bb14873662
06:37:30:WU00:FS01:Uploading 2.41KiB to 140.163.4.243
06:37:30:WU00:FS01:Connecting to 140.163.4.243:8080
06:37:31:WU00:FS01:Upload complete
06:37:31:WU00:FS01:Server responded WORK_ACK (400)
06:37:31:WU00:FS01:Cleaning up
06:37:31:WU02:FS01:Connecting to 171.67.108.45:80
06:37:31:WU02:FS01:Assigned to work server 140.163.4.245
06:37:31:WU02:FS01:Requesting new work unit for slot 01: READY gpu:1:GP104 [GeForce GTX 1070] from 140.163.4.245
06:37:31:WU02:FS01:Connecting to 140.163.4.245:8080
06:37:32:WU02:FS01:Downloading 20.67MiB
06:37:38:WU02:FS01:Download 18.14%
06:37:44:WU02:FS01:Download 32.66%
06:37:50:WU02:FS01:Download 47.48%
06:37:56:WU02:FS01:Download 62.29%
06:38:02:WU02:FS01:Download 86.18%
06:38:07:WU02:FS01:Download complete
06:38:07:WU02:FS01:Received Unit: id:02 state:DOWNLOAD error:NO_ERROR project:10494 run:1 clone:20 gen:238 core:0x21 unit:0x0000012e8ca304f555de92a9a45966cd
06:38:07:WU02:FS01:Starting
06:38:07:WU02:FS01:Running FahCore: "d:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" d:/Users/Lythronax/AppData/Roaming/FAHClient/cores/web.stanford.edu/~pande/Win32/AMD64/NVIDIA/Fermi/Core_21.fah/FahCore_21.exe -dir 02 -suffix 01 -version 704 -lifeline 6204 -checkpoint 15 -gpu 0 -gpu-vendor nvidia
06:38:07:WU02:FS01:Started FahCore on PID 5240
06:38:07:WU02:FS01:Core PID:8332
06:38:07:WU02:FS01:FahCore 0x21 started
06:38:08:WU02:FS01:0x21:*********************** Log Started 2016-10-27T06:38:07Z ***********************
06:38:08:WU02:FS01:0x21:Project: 10494 (Run 1, Clone 20, Gen 238)
06:38:08:WU02:FS01:0x21:Unit: 0x0000012e8ca304f555de92a9a45966cd
06:38:08:WU02:FS01:0x21:CPU: 0x00000000000000000000000000000000
06:38:08:WU02:FS01:0x21:Machine: 1
06:38:08:WU02:FS01:0x21:Reading tar file core.xml
06:38:08:WU02:FS01:0x21:Reading tar file system.xml
06:38:09:WU02:FS01:0x21:Reading tar file integrator.xml
06:38:09:WU02:FS01:0x21:Reading tar file state.xml
06:38:12:WU02:FS01:0x21:Digital signatures verified
06:38:12:WU02:FS01:0x21:Folding@home GPU Core21 Folding@home Core
06:38:12:WU02:FS01:0x21:Version 0.0.17
06:38:35:WU02:FS01:0x21:ERROR:exception: Error downloading array interactionCount: clEnqueueReadBuffer (-5)
06:38:35:WU02:FS01:0x21:Saving result file logfile_01.txt
06:38:35:WU02:FS01:0x21:Saving result file log.txt
06:38:35:WU02:FS01:0x21:Folding@home Core Shutdown: BAD_WORK_UNIT
06:38:38:WARNING:WU02:FS01:FahCore returned: BAD_WORK_UNIT (114 = 0x72)
06:38:38:WU02:FS01:Sending unit results: id:02 state:SEND error:FAULTY project:10494 run:1 clone:20 gen:238 core:0x21 unit:0x0000012e8ca304f555de92a9a45966cd
06:38:38:WU02:FS01:Uploading 2.39KiB to 140.163.4.245
06:38:38:WU02:FS01:Connecting to 140.163.4.245:8080
06:38:38:WU02:FS01:Upload complete
06:38:38:WU02:FS01:Server responded WORK_ACK (400)
06:38:38:WU02:FS01:Cleaning up
******************************* Date: 2016-10-27 *******************************
MEGIDDO
Post by MEGIDDO »
GPU-Z video card name: Nvidia Geforce GTX 1070
Device ID: 10DE - 1B81
Nathan_P
Not currently folding
Post by Nathan_P »
The GTX 1070 has been in the gpus.txt file for months, the problem is with the current 375 series of drivers from NVidia - they do not work with F@H. You will need to roll back to an earlier driver in order to be able to fold.
As already stated by Nathan_P, your problem has nothing to do with adding the 1070 to the GPUs.txt file. It is plain from the logs that it is already recognized. There is an existing topic for problems with the 375 drivers.
To reiterate the basic information about posting log files that is given in the Welcome Topic available at the top of every sub-forum:
- Post the first section of the log that shows system and configuration information, about 100 lines is usually sufficient
- Post a section of the log showing the problem, we do not need to see the full log
- Enclose the log file listing in Code tags available from the Full Editor mode for posting here
In addition, post the driver version you have installed for your GPU.
Nathan_P
Post by Nathan_P »
One good thing from this post, the error message is the same as the 375 driver one - but core 18 evidently still works with 375 drivers!!??
Nathan_P wrote:- but core 18 evidently still works with 375 drivers!!??
Yes. The blog post specifies Core_21 with those drivers.
https://folding.stanford.edu/home/core- ... nd-375-63/
