Project: 13204 (Run 20, Clone 0, Gen 118)
Nicolas_orleans
Post by Nicolas_orleans »
This one appears to consistently fail at the same percentage. GTX 750 Ti @ 1306 MHz, Ubuntu 14.04, 367.44
00:42:11:WU03:FS02:0x21:Project: 13204 (Run 20, Clone 0, Gen 118)
00:42:11:WU03:FS02:0x21:Unit: 0x00000043ab436c6657894f0c62f3d847
00:42:11:WU03:FS02:0x21:CPU: 0x00000000000000000000000000000000
00:42:11:WU03:FS02:0x21:Machine: 2
00:42:11:WU03:FS02:0x21:Reading tar file core.xml
00:42:11:WU03:FS02:0x21:Reading tar file integrator.xml
00:42:11:WU03:FS02:0x21:Reading tar file state.xml
00:42:11:WU03:FS02:0x21:Reading tar file system.xml
00:42:12:WU03:FS02:0x21:Digital signatures verified
00:42:12:WU03:FS02:0x21:Folding@home GPU Core21 Folding@home Core
00:42:12:WU03:FS02:0x21:Version 0.0.17
00:43:06:WU03:FS02:0x21:Completed 0 out of 2000000 steps (0%)
00:43:06:WU03:FS02:0x21:Temperature control disabled. Requirements: single Nvidia GPU, tmax must be < 110 and twait >= 900
00:50:35:WU03:FS02:0x21:Completed 20000 out of 2000000 steps (1%)
00:58:03:WU03:FS02:0x21:Completed 40000 out of 2000000 steps (2%)
01:05:30:WU03:FS02:0x21:Completed 60000 out of 2000000 steps (3%)
01:12:58:WU03:FS02:0x21:Completed 80000 out of 2000000 steps (4%)
01:20:25:WU03:FS02:0x21:Completed 100000 out of 2000000 steps (5%)
01:27:52:WU03:FS02:0x21:Completed 120000 out of 2000000 steps (6%)
01:35:20:WU03:FS02:0x21:Completed 140000 out of 2000000 steps (7%)
01:42:47:WU03:FS02:0x21:Completed 160000 out of 2000000 steps (8%)
01:50:15:WU03:FS02:0x21:Completed 180000 out of 2000000 steps (9%)
01:57:42:WU03:FS02:0x21:Completed 200000 out of 2000000 steps (10%)
02:05:14:WU03:FS02:0x21:Completed 220000 out of 2000000 steps (11%)
02:12:41:WU03:FS02:0x21:Completed 240000 out of 2000000 steps (12%)
02:20:09:WU03:FS02:0x21:Completed 260000 out of 2000000 steps (13%)
02:27:37:WU03:FS02:0x21:Completed 280000 out of 2000000 steps (14%)
02:35:05:WU03:FS02:0x21:Completed 300000 out of 2000000 steps (15%)
02:42:32:WU03:FS02:0x21:Completed 320000 out of 2000000 steps (16%)
02:50:00:WU03:FS02:0x21:Completed 340000 out of 2000000 steps (17%)
02:57:27:WU03:FS02:0x21:Completed 360000 out of 2000000 steps (18%)
03:04:55:WU03:FS02:0x21:Completed 380000 out of 2000000 steps (19%)
03:12:23:WU03:FS02:0x21:Completed 400000 out of 2000000 steps (20%)
03:12:27:WU03:FS02:0x21:Bad State detected... attempting to resume from last good checkpoint. Is your system overclocked?
03:19:54:WU03:FS02:0x21:Completed 220000 out of 2000000 steps (11%)
03:27:22:WU03:FS02:0x21:Completed 240000 out of 2000000 steps (12%)
03:34:50:WU03:FS02:0x21:Completed 260000 out of 2000000 steps (13%)
03:42:18:WU03:FS02:0x21:Completed 280000 out of 2000000 steps (14%)
03:49:46:WU03:FS02:0x21:Completed 300000 out of 2000000 steps (15%)
******************************* Date: 2016-10-22 *******************************
03:57:13:WU03:FS02:0x21:Completed 320000 out of 2000000 steps (16%)
04:04:41:WU03:FS02:0x21:Completed 340000 out of 2000000 steps (17%)
04:12:08:WU03:FS02:0x21:Completed 360000 out of 2000000 steps (18%)
04:19:36:WU03:FS02:0x21:Completed 380000 out of 2000000 steps (19%)
04:27:03:WU03:FS02:0x21:Completed 400000 out of 2000000 steps (20%)
04:27:08:WU03:FS02:0x21:Bad State detected... attempting to resume from last good checkpoint. Is your system overclocked?
04:34:35:WU03:FS02:0x21:Completed 220000 out of 2000000 steps (11%)
04:42:03:WU03:FS02:0x21:Completed 240000 out of 2000000 steps (12%)
04:49:30:WU03:FS02:0x21:Completed 260000 out of 2000000 steps (13%)
04:56:58:WU03:FS02:0x21:Completed 280000 out of 2000000 steps (14%)
05:04:26:WU03:FS02:0x21:Completed 300000 out of 2000000 steps (15%)
05:11:53:WU03:FS02:0x21:Completed 320000 out of 2000000 steps (16%)
05:19:21:WU03:FS02:0x21:Completed 340000 out of 2000000 steps (17%)
05:26:48:WU03:FS02:0x21:Completed 360000 out of 2000000 steps (18%)
05:34:16:WU03:FS02:0x21:Completed 380000 out of 2000000 steps (19%)
05:41:44:WU03:FS02:0x21:Completed 400000 out of 2000000 steps (20%)
05:41:48:WU03:FS02:0x21:Bad State detected... attempting to resume from last good checkpoint. Is your system overclocked?
05:41:48:WU03:FS02:0x21:ERROR:Max Retries Reached
05:41:48:WU03:FS02:0x21:Saving result file logfile_01.txt
05:41:48:WU03:FS02:0x21:Saving result file badstate-0.xml
05:41:49:WU03:FS02:0x21:Saving result file badstate-1.xml
05:41:51:WU03:FS02:0x21:Saving result file badstate-2.xml
05:41:52:WU03:FS02:0x21:Saving result file log.txt
05:41:52:WU03:FS02:0x21:Folding@home Core Shutdown: BAD_WORK_UNIT
05:41:53:WARNING:WU03:FS02:FahCore returned: BAD_WORK_UNIT (114 = 0x72)
05:41:53:WU03:FS02:Sending unit results: id:03 state:SEND error:FAULTY project:13204 run:20 clone:0 gen:118 core:0x21 unit:0x00000043ab436c6657894f0c62f3d847
05:41:53:WU03:FS02:Uploading 12.78MiB to 171.67.108.102
AORUS Elite X AX B650E- Ryzen 9 9950X - Inno3D RTX 5080 - Ubuntu 25.04 - 6.14 kernel - 580.95
MSI MPG B550 - Ryzen 5 5600X - PNY RTX 4080 Super - Ubuntu 25.04 - 6.14 kernel - 580.95
Re: Project: 13204 (Run 20, Clone 0, Gen 118)
It has been completed successfully by someone else.
Hi Nicolas_orleans (team 33),
Your WU (P13204 R20 C0 G118) was added to the stats database on 2016-10-21 23:12:58 for 2708.2 points of credit
(Error with partial credit)
Donator: xxx Team: xxx
Your WU (P13204 R20 C0 G118) was added to the stats database on 2016-10-22 02:08:29 for 0 points of credit.
(probably dumped.)
Donator: yyy Team: yyy
Your WU (P13204 R20 C0 G118) was added to the stats database on 2016-10-22 05:08:26 for 76682.7 points of credit.
The 750Ti is a very reliable performer (I have two of them) at the base-clock of 1020 with the boost-clock of 1085. I suggest you reduce your 1306 setting.
Nicolas_orleans
Thanks for the information bruce
