FahCore_a7 (More than 1 OpenMP thread requested)
xXDeltaXx
Post by xXDeltaXx »
Hi, I'm currently unable to utilise my CPU due to FahCore_a7.exe failing... constantly. If I manage to get a different core for the CPU, it progresses and completes without issue.
The GPU is continuing to progress without issue, it is only the CPU with this core that has issues. I am currently 'finishing' up a GPU WU and the Windows error stating that the .exe has stopped working keeps repeating until the client eventually kicks the CPU WU and the state changes to 'Paused:Finished'.
I'm not au fait with the logs to provide a lot of detailed information, but this seems common:
17:29:06:WU03:FS00:0xa7:ERROR:Environment variable OMP_NUM_THREADS (8) and the number of threads requested on the command line (1) have different values. Either omit one, or set them both to the same value.
17:29:00:WU03:FS00:FahCore 0xa7 started
17:29:00:WU03:FS00:0xa7:*********************** Log Started 2016-10-21T17:29:00Z ***********************
17:29:00:WU03:FS00:0xa7:************************** Gromacs Folding@home Core ***************************
17:29:00:WU03:FS00:0xa7:       Type: 0xa7
17:29:00:WU03:FS00:0xa7:       Core: Gromacs
17:29:00:WU03:FS00:0xa7:    Website: http://folding.stanford.edu/
17:29:00:WU03:FS00:0xa7:  Copyright: (c) 2009-2016 Stanford University
17:29:00:WU03:FS00:0xa7:     Author: Joseph Coffland <joseph@cauldrondevelopment.com>
17:29:00:WU03:FS00:0xa7:       Args: -dir 03 -suffix 01 -version 704 -lifeline 9292 -checkpoint 15 -np 6
17:29:00:WU03:FS00:0xa7:     Config: <none>
17:29:00:WU03:FS00:0xa7:************************************ Build *************************************
17:29:00:WU03:FS00:0xa7:    Version: 0.0.11
17:29:00:WU03:FS00:0xa7:       Date: Sep 21 2016
17:29:00:WU03:FS00:0xa7:       Time: 01:43:48
17:29:00:WU03:FS00:0xa7: Repository: Git
17:29:00:WU03:FS00:0xa7:   Revision: 957bd90e68d95ddcf1594dc15ff6c64cc4555146
17:29:00:WU03:FS00:0xa7:     Branch: master
17:29:00:WU03:FS00:0xa7:   Compiler: GNU 4.2.1 Compatible Clang 3.9.0 (trunk 274080)
17:29:00:WU03:FS00:0xa7:    Options: -std=gnu++98 -O3 -funroll-loops -ffast-math -mfpmath=sse
17:29:00:WU03:FS00:0xa7:             -fno-unsafe-math-optimizations -msse2 -I/mingw64/include
17:29:00:WU03:FS00:0xa7:             -Wno-inconsistent-dllimport -Wno-parentheses-equality
17:29:00:WU03:FS00:0xa7:             -Wno-deprecated-register -Wno-unused-local-typedef
17:29:00:WU03:FS00:0xa7:   Platform: linux2 4.6.0-1-amd64
17:29:00:WU03:FS00:0xa7:       Bits: 64
17:29:00:WU03:FS00:0xa7:       Mode: Release
17:29:00:WU03:FS00:0xa7:       SIMD: avx_256
17:29:00:WU03:FS00:0xa7:************************************ System ************************************
17:29:00:WU03:FS00:0xa7:        CPU: Intel(R) Core(TM) i7-6700K CPU @ 4.00GHz
17:29:00:WU03:FS00:0xa7:     CPU ID: GenuineIntel Family 6 Model 94 Stepping 3
17:29:00:WU03:FS00:0xa7:       CPUs: 8
17:29:00:WU03:FS00:0xa7:     Memory: 31.92GiB
17:29:00:WU03:FS00:0xa7:Free Memory: 23.43GiB
17:29:00:WU03:FS00:0xa7:    Threads: WINDOWS_THREADS
17:29:00:WU03:FS00:0xa7: OS Version: 6.1
17:29:00:WU03:FS00:0xa7:Has Battery: false
17:29:00:WU03:FS00:0xa7: On Battery: false
17:29:00:WU03:FS00:0xa7: UTC Offset: 1
17:29:00:WU03:FS00:0xa7:        PID: 10716
17:29:00:WU03:FS00:0xa7:        CWD: C:\ProgramData\FAHClient\work
17:29:00:WU03:FS00:0xa7:         OS: Windows 7 Ultimate Service Pack 1
17:29:00:WU03:FS00:0xa7:    OS Arch: AMD64
17:29:00:WU03:FS00:0xa7:********************************************************************************
17:29:00:WU03:FS00:0xa7:Project: 11920 (Run 2609, Clone 1, Gen 1)
17:29:00:WU03:FS00:0xa7:Unit: 0x00000001ab4041295809a8c849960c30
17:29:00:WU03:FS00:0xa7:Reading tar file core.xml
17:29:00:WU03:FS00:0xa7:Reading tar file frame1.tpr
17:29:00:WU03:FS00:0xa7:Digital signatures verified
17:29:00:WU03:FS00:0xa7:Calling: mdrun -s frame1.tpr -o frame1.trr -cpt 15 -nt 6
17:29:01:WU03:FS00:0xa7:ERROR:
17:29:01:WU03:FS00:0xa7:ERROR:-------------------------------------------------------
17:29:01:WU03:FS00:0xa7:ERROR:Program GROMACS, VERSION 5.0.4-20160919-669094a-unknown
17:29:01:WU03:FS00:0xa7:ERROR:Source code file: /host/windows-cross-64bit-core-a7-avx-release/gromacs-core/build/gromacs/src/programs/mdrun/runner.c, line: 879
17:29:01:WU03:FS00:0xa7:ERROR:Fatal error:
17:29:01:WU03:FS00:0xa7:ERROR:More than 1 OpenMP thread requested, but Gromacs was compiled without OpenMP support
17:29:01:WU03:FS00:0xa7:ERROR:For more information and tips for troubleshooting, please check the GROMACS
17:29:01:WU03:FS00:0xa7:ERROR:website at http://www.gromacs.org/Documentation/Errors
17:29:02:FS00:Finishing
17:29:02:FS01:Finishing
17:29:06:WU03:FS00:0xa7:WARNING:Unexpected exit() call
17:29:06:WU03:FS00:0xa7:ERROR:-------------------------------------------------------
17:29:06:WU03:FS00:0xa7:ERROR:Program GROMACS, VERSION 5.0.4-20160919-669094a-unknown
17:29:06:WU03:FS00:0xa7:ERROR:Source code file: /host/windows-cross-64bit-core-a7-avx-release/gromacs-core/build/gromacs/src/gromacs/gmxlib/gmx_omp_nthreads.c, line: 211
17:29:06:WU03:FS00:0xa7:ERROR:Fatal error:
17:29:06:WU03:FS00:0xa7:ERROR:For more information and tips for troubleshooting, please check the GROMACS
17:29:06:WU03:FS00:0xa7:ERROR:website at http://www.gromacs.org/Documentation/Errors
17:29:12:WARNING:WU03:FS00:FahCore returned: FAILED_3 (255 = 0xff)
17:29:30:WU01:FS01:0x21:Completed 850000 out of 2500000 steps (34%)
17:30:00:WU03:FS00:Starting
17:30:00:WU03:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:/ProgramData/FAHClient/cores/web.stanford.edu/~pande/Win32/AMD64/AVX/Core_a7.fah/FahCore_a7.exe -dir 03 -suffix 01 -version 704 -lifeline 9964 -checkpoint 15 -np 6
17:30:00:WU03:FS00:Started FahCore on PID 10892
17:30:00:WU03:FS00:Core PID:10956
17:30:00:WU03:FS00:FahCore 0xa7 started
17:30:00:WU03:FS00:0xa7:*********************** Log Started 2016-10-21T17:30:00Z ***********************
17:30:00:WU03:FS00:0xa7:************************** Gromacs Folding@home Core ***************************
17:30:00:WU03:FS00:0xa7:       Type: 0xa7
17:30:00:WU03:FS00:0xa7:       Core: Gromacs
17:30:00:WU03:FS00:0xa7:    Website: http://folding.stanford.edu/
17:30:00:WU03:FS00:0xa7:  Copyright: (c) 2009-2016 Stanford University
17:30:00:WU03:FS00:0xa7:     Author: Joseph Coffland <joseph@cauldrondevelopment.com>
17:30:00:WU03:FS00:0xa7:       Args: -dir 03 -suffix 01 -version 704 -lifeline 10892 -checkpoint 15 -np
17:30:00:WU03:FS00:0xa7:             6
17:30:00:WU03:FS00:0xa7:     Config: <none>
17:30:00:WU03:FS00:0xa7:************************************ Build *************************************
17:30:00:WU03:FS00:0xa7:    Version: 0.0.11
17:30:00:WU03:FS00:0xa7:       Date: Sep 21 2016
17:30:00:WU03:FS00:0xa7:       Time: 01:43:48
17:30:00:WU03:FS00:0xa7: Repository: Git
17:30:00:WU03:FS00:0xa7:   Revision: 957bd90e68d95ddcf1594dc15ff6c64cc4555146
17:30:00:WU03:FS00:0xa7:     Branch: master
17:30:00:WU03:FS00:0xa7:   Compiler: GNU 4.2.1 Compatible Clang 3.9.0 (trunk 274080)
17:30:00:WU03:FS00:0xa7:    Options: -std=gnu++98 -O3 -funroll-loops -ffast-math -mfpmath=sse
17:30:00:WU03:FS00:0xa7:             -fno-unsafe-math-optimizations -msse2 -I/mingw64/include
17:30:00:WU03:FS00:0xa7:             -Wno-inconsistent-dllimport -Wno-parentheses-equality
17:30:00:WU03:FS00:0xa7:             -Wno-deprecated-register -Wno-unused-local-typedef
17:30:00:WU03:FS00:0xa7:   Platform: linux2 4.6.0-1-amd64
17:30:00:WU03:FS00:0xa7:       Bits: 64
17:30:00:WU03:FS00:0xa7:       Mode: Release
17:30:00:WU03:FS00:0xa7:       SIMD: avx_256
17:30:00:WU03:FS00:0xa7:************************************ System ************************************
17:30:00:WU03:FS00:0xa7:        CPU: Intel(R) Core(TM) i7-6700K CPU @ 4.00GHz
17:30:00:WU03:FS00:0xa7:     CPU ID: GenuineIntel Family 6 Model 94 Stepping 3
17:30:00:WU03:FS00:0xa7:       CPUs: 8
17:30:00:WU03:FS00:0xa7:     Memory: 31.92GiB
17:30:00:WU03:FS00:0xa7:Free Memory: 23.47GiB
17:30:00:WU03:FS00:0xa7:    Threads: WINDOWS_THREADS
17:30:00:WU03:FS00:0xa7: OS Version: 6.1
17:30:00:WU03:FS00:0xa7:Has Battery: false
17:30:00:WU03:FS00:0xa7: On Battery: false
17:30:00:WU03:FS00:0xa7: UTC Offset: 1
17:30:00:WU03:FS00:0xa7:        PID: 10956
17:30:00:WU03:FS00:0xa7:        CWD: C:\ProgramData\FAHClient\work
17:30:00:WU03:FS00:0xa7:         OS: Windows 7 Ultimate Service Pack 1
17:30:00:WU03:FS00:0xa7:    OS Arch: AMD64
17:30:00:WU03:FS00:0xa7:********************************************************************************
17:30:00:WU03:FS00:0xa7:Project: 11920 (Run 2609, Clone 1, Gen 1)
17:30:00:WU03:FS00:0xa7:Unit: 0x00000001ab4041295809a8c849960c30
17:30:00:WU03:FS00:0xa7:Reading tar file core.xml
17:30:00:WU03:FS00:0xa7:Reading tar file frame1.tpr
17:30:00:WU03:FS00:0xa7:Digital signatures verified
17:30:00:WU03:FS00:0xa7:Calling: mdrun -s frame1.tpr -o frame1.trr -cpt 15 -nt 6
17:30:01:WU03:FS00:0xa7:ERROR:
17:30:01:WU03:FS00:0xa7:ERROR:-------------------------------------------------------
17:30:01:WU03:FS00:0xa7:ERROR:Program GROMACS, VERSION 5.0.4-20160919-669094a-unknown
17:30:01:WU03:FS00:0xa7:ERROR:Source code file: /host/windows-cross-64bit-core-a7-avx-release/gromacs-core/build/gromacs/src/programs/mdrun/runner.c, line: 879
17:30:01:WU03:FS00:0xa7:ERROR:Fatal error:
17:30:01:WU03:FS00:0xa7:ERROR:More than 1 OpenMP thread requested, but Gromacs was compiled without OpenMP support
17:30:01:WU03:FS00:0xa7:ERROR:For more information and tips for troubleshooting, please check the GROMACS
17:30:01:WU03:FS00:0xa7:ERROR:website at http://www.gromacs.org/Documentation/Errors
17:30:06:WU03:FS00:0xa7:ERROR:
17:30:06:WU03:FS00:0xa7:WARNING:Unexpected exit() call
17:30:06:WU03:FS00:0xa7:ERROR:-------------------------------------------------------
17:30:06:WU03:FS00:0xa7:ERROR:Program GROMACS, VERSION 5.0.4-20160919-669094a-unknown
17:30:06:WU03:FS00:0xa7:ERROR:Source code file: /host/windows-cross-64bit-core-a7-avx-release/gromacs-core/build/gromacs/src/gromacs/gmxlib/gmx_omp_nthreads.c, line: 211
17:30:06:WU03:FS00:0xa7:ERROR:Fatal error:
17:30:06:WU03:FS00:0xa7:ERROR:Environment variable OMP_NUM_THREADS (8) and the number of threads requested on the command line (1) have different values. Either omit one, or set them both to the same value.
17:30:06:WU03:FS00:0xa7:ERROR:For more information and tips for troubleshooting, please check the GROMACS
17:30:06:WU03:FS00:0xa7:ERROR:website at http://www.gromacs.org/Documentation/Errors
17:30:16:WU01:FS01:0x21:Completed 875000 out of 2500000 steps (35%)
17:31:02:WU01:FS01:0x21:Completed 900000 out of 2500000 steps (36%)
17:31:49:WU01:FS01:0x21:Completed 925000 out of 2500000 steps (37%)
17:32:36:WU01:FS01:0x21:Completed 950000 out of 2500000 steps (38%)
17:33:22:WU01:FS01:0x21:Completed 975000 out of 2500000 steps (39%)
17:34:08:WU01:FS01:0x21:Completed 1000000 out of 2500000 steps (40%)
17:34:56:WU01:FS01:0x21:Completed 1025000 out of 2500000 steps (41%)
17:35:42:WU01:FS01:0x21:Completed 1050000 out of 2500000 steps (42%)
17:36:29:WU01:FS01:0x21:Completed 1075000 out of 2500000 steps (43%)
17:37:16:WU01:FS01:0x21:Completed 1100000 out of 2500000 steps (44%)
******************************* Date: 2016-10-21 *******************************
17:38:03:WU01:FS01:0x21:Completed 1125000 out of 2500000 steps (45%)
17:38:50:WU01:FS01:0x21:Completed 1150000 out of 2500000 steps (46%)
17:39:36:WU01:FS01:0x21:Completed 1175000 out of 2500000 steps (47%)
17:40:23:WU01:FS01:0x21:Completed 1200000 out of 2500000 steps (48%)
17:41:11:WU01:FS01:0x21:Completed 1225000 out of 2500000 steps (49%)
17:41:57:WU01:FS01:0x21:Completed 1250000 out of 2500000 steps (50%)
17:42:43:WU01:FS01:0x21:Completed 1275000 out of 2500000 steps (51%)
17:43:29:WU01:FS01:0x21:Completed 1300000 out of 2500000 steps (52%)
17:44:17:WU01:FS01:0x21:Completed 1325000 out of 2500000 steps (53%)
17:45:03:WU01:FS01:0x21:Completed 1350000 out of 2500000 steps (54%)
17:45:49:WU01:FS01:0x21:Completed 1375000 out of 2500000 steps (55%)
17:46:35:WU01:FS01:0x21:Completed 1400000 out of 2500000 steps (56%)
17:47:22:WU01:FS01:0x21:Completed 1425000 out of 2500000 steps (57%)
17:48:08:WU01:FS01:0x21:Completed 1450000 out of 2500000 steps (58%)
17:48:54:WU01:FS01:0x21:Completed 1475000 out of 2500000 steps (59%)
17:49:41:WU01:FS01:0x21:Completed 1500000 out of 2500000 steps (60%)
17:50:29:WU01:FS01:0x21:Completed 1525000 out of 2500000 steps (61%)
17:51:15:WU01:FS01:0x21:Completed 1550000 out of 2500000 steps (62%)
17:52:02:WU01:FS01:0x21:Completed 1575000 out of 2500000 steps (63%)
17:52:49:WU01:FS01:0x21:Completed 1600000 out of 2500000 steps (64%)
17:53:36:WU01:FS01:0x21:Completed 1625000 out of 2500000 steps (65%)
17:54:22:WU01:FS01:0x21:Completed 1650000 out of 2500000 steps (66%)
17:55:09:WU01:FS01:0x21:Completed 1675000 out of 2500000 steps (67%)
17:55:28:WARNING:WU03:FS00:FahCore returned: FAILED_3 (255 = 0xff)
17:55:28:WU03:FS00:Starting
17:55:28:WU03:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:/ProgramData/FAHClient/cores/web.stanford.edu/~pande/Win32/AMD64/AVX/Core_a7.fah/FahCore_a7.exe -dir 03 -suffix 01 -version 704 -lifeline 9964 -checkpoint 15 -np 6
17:55:28:WU03:FS00:Started FahCore on PID 1760
17:55:28:WU03:FS00:Core PID:2536
17:55:28:WU03:FS00:FahCore 0xa7 started
17:55:29:WU03:FS00:0xa7:*********************** Log Started 2016-10-21T17:55:29Z ***********************
17:55:29:WU03:FS00:0xa7:************************** Gromacs Folding@home Core ***************************
17:55:29:WU03:FS00:0xa7:       Type: 0xa7
17:55:29:WU03:FS00:0xa7:       Core: Gromacs
17:55:29:WU03:FS00:0xa7:    Website: http://folding.stanford.edu/
17:55:29:WU03:FS00:0xa7:  Copyright: (c) 2009-2016 Stanford University
17:55:29:WU03:FS00:0xa7:     Author: Joseph Coffland <joseph@cauldrondevelopment.com>
17:55:29:WU03:FS00:0xa7:       Args: -dir 03 -suffix 01 -version 704 -lifeline 1760 -checkpoint 15 -np 6
17:55:29:WU03:FS00:0xa7:     Config: <none>
17:55:29:WU03:FS00:0xa7:************************************ Build *************************************
17:55:29:WU03:FS00:0xa7:    Version: 0.0.11
17:55:29:WU03:FS00:0xa7:       Date: Sep 21 2016
17:55:29:WU03:FS00:0xa7:       Time: 01:43:48
17:55:29:WU03:FS00:0xa7: Repository: Git
17:55:29:WU03:FS00:0xa7:   Revision: 957bd90e68d95ddcf1594dc15ff6c64cc4555146
17:55:29:WU03:FS00:0xa7:     Branch: master
17:55:29:WU03:FS00:0xa7:   Compiler: GNU 4.2.1 Compatible Clang 3.9.0 (trunk 274080)
17:55:29:WU03:FS00:0xa7:    Options: -std=gnu++98 -O3 -funroll-loops -ffast-math -mfpmath=sse
17:55:29:WU03:FS00:0xa7:             -fno-unsafe-math-optimizations -msse2 -I/mingw64/include
17:55:29:WU03:FS00:0xa7:             -Wno-inconsistent-dllimport -Wno-parentheses-equality
17:55:29:WU03:FS00:0xa7:             -Wno-deprecated-register -Wno-unused-local-typedef
17:55:29:WU03:FS00:0xa7:   Platform: linux2 4.6.0-1-amd64
17:55:29:WU03:FS00:0xa7:       Bits: 64
17:55:29:WU03:FS00:0xa7:       Mode: Release
17:55:29:WU03:FS00:0xa7:       SIMD: avx_256
17:55:29:WU03:FS00:0xa7:************************************ System ************************************
17:55:29:WU03:FS00:0xa7:        CPU: Intel(R) Core(TM) i7-6700K CPU @ 4.00GHz
17:55:29:WU03:FS00:0xa7:     CPU ID: GenuineIntel Family 6 Model 94 Stepping 3
17:55:29:WU03:FS00:0xa7:       CPUs: 8
17:55:29:WU03:FS00:0xa7:     Memory: 31.92GiB
17:55:29:WU03:FS00:0xa7:Free Memory: 22.99GiB
17:55:29:WU03:FS00:0xa7:    Threads: WINDOWS_THREADS
17:55:29:WU03:FS00:0xa7: OS Version: 6.1
17:55:29:WU03:FS00:0xa7:Has Battery: false
17:55:29:WU03:FS00:0xa7: On Battery: false
17:55:29:WU03:FS00:0xa7: UTC Offset: 1
17:55:29:WU03:FS00:0xa7:        PID: 2536
17:55:29:WU03:FS00:0xa7:        CWD: C:\ProgramData\FAHClient\work
17:55:29:WU03:FS00:0xa7:         OS: Windows 7 Ultimate Service Pack 1
17:55:29:WU03:FS00:0xa7:    OS Arch: AMD64
17:55:29:WU03:FS00:0xa7:********************************************************************************
17:55:29:WU03:FS00:0xa7:Project: 11920 (Run 2609, Clone 1, Gen 1)
17:55:29:WU03:FS00:0xa7:Unit: 0x00000001ab4041295809a8c849960c30
17:55:29:WU03:FS00:0xa7:Reading tar file core.xml
17:55:29:WU03:FS00:0xa7:Reading tar file frame1.tpr
17:55:29:WU03:FS00:0xa7:Digital signatures verified
17:55:29:WU03:FS00:0xa7:Calling: mdrun -s frame1.tpr -o frame1.trr -cpt 15 -nt 6
17:55:30:WU03:FS00:0xa7:ERROR:
17:55:30:WU03:FS00:0xa7:ERROR:-------------------------------------------------------
17:55:30:WU03:FS00:0xa7:ERROR:Program GROMACS, VERSION 5.0.4-20160919-669094a-unknown
17:55:30:WU03:FS00:0xa7:ERROR:Source code file: /host/windows-cross-64bit-core-a7-avx-release/gromacs-core/build/gromacs/src/programs/mdrun/runner.c, line: 879
17:55:30:WU03:FS00:0xa7:ERROR:Fatal error:
17:55:30:WU03:FS00:0xa7:ERROR:More than 1 OpenMP thread requested, but Gromacs was compiled without OpenMP support
17:55:30:WU03:FS00:0xa7:ERROR:For more information and tips for troubleshooting, please check the GROMACS
17:55:30:WU03:FS00:0xa7:ERROR:website at http://www.gromacs.org/Documentation/Errors
17:55:35:WU03:FS00:0xa7:ERROR:
17:55:35:WU03:FS00:0xa7:WARNING:Unexpected exit() call
17:55:35:WU03:FS00:0xa7:ERROR:-------------------------------------------------------
17:55:35:WU03:FS00:0xa7:ERROR:Program GROMACS, VERSION 5.0.4-20160919-669094a-unknown
17:55:35:WU03:FS00:0xa7:ERROR:Source code file: /host/windows-cross-64bit-core-a7-avx-release/gromacs-core/build/gromacs/src/gromacs/gmxlib/gmx_omp_nthreads.c, line: 211
17:55:35:WU03:FS00:0xa7:ERROR:Fatal error:
17:55:35:WU03:FS00:0xa7:ERROR:Environment variable OMP_NUM_THREADS (8) and the number of threads requested on the command line (1) have different values. Either omit one, or set them both to the same value.
17:55:35:WU03:FS00:0xa7:ERROR:For more information and tips for troubleshooting, please check the GROMACS
17:55:35:WU03:FS00:0xa7:ERROR:website at http://www.gromacs.org/Documentation/Errors
17:55:39:WARNING:WU03:FS00:FahCore returned: FAILED_3 (255 = 0xff)
17:55:56:WU01:FS01:0x21:Completed 1700000 out of 2500000 steps (68%)
17:56:28:WU03:FS00:Starting
17:56:28:WU03:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:/ProgramData/FAHClient/cores/web.stanford.edu/~pande/Win32/AMD64/AVX/Core_a7.fah/FahCore_a7.exe -dir 03 -suffix 01 -version 704 -lifeline 9964 -checkpoint 15 -np 6
17:56:28:WU03:FS00:Started FahCore on PID 4672
17:56:29:WU03:FS00:Core PID:2908
17:56:29:WU03:FS00:FahCore 0xa7 started
17:56:29:WU03:FS00:0xa7:*********************** Log Started 2016-10-21T17:56:29Z ***********************
17:56:29:WU03:FS00:0xa7:************************** Gromacs Folding@home Core ***************************
17:56:29:WU03:FS00:0xa7:       Type: 0xa7
17:56:29:WU03:FS00:0xa7:       Core: Gromacs
17:56:29:WU03:FS00:0xa7:    Website: http://folding.stanford.edu/
17:56:29:WU03:FS00:0xa7:  Copyright: (c) 2009-2016 Stanford University
17:56:29:WU03:FS00:0xa7:     Author: Joseph Coffland <joseph@cauldrondevelopment.com>
17:56:29:WU03:FS00:0xa7:       Args: -dir 03 -suffix 01 -version 704 -lifeline 4672 -checkpoint 15 -np 6
17:56:29:WU03:FS00:0xa7:     Config: <none>
17:56:29:WU03:FS00:0xa7:************************************ Build *************************************
17:56:29:WU03:FS00:0xa7:    Version: 0.0.11
17:56:29:WU03:FS00:0xa7:       Date: Sep 21 2016
17:56:29:WU03:FS00:0xa7:       Time: 01:43:48
17:56:29:WU03:FS00:0xa7: Repository: Git
17:56:29:WU03:FS00:0xa7:   Revision: 957bd90e68d95ddcf1594dc15ff6c64cc4555146
17:56:29:WU03:FS00:0xa7:     Branch: master
17:56:29:WU03:FS00:0xa7:   Compiler: GNU 4.2.1 Compatible Clang 3.9.0 (trunk 274080)
17:56:29:WU03:FS00:0xa7:    Options: -std=gnu++98 -O3 -funroll-loops -ffast-math -mfpmath=sse
17:56:29:WU03:FS00:0xa7:             -fno-unsafe-math-optimizations -msse2 -I/mingw64/include
17:56:29:WU03:FS00:0xa7:             -Wno-inconsistent-dllimport -Wno-parentheses-equality
17:56:29:WU03:FS00:0xa7:             -Wno-deprecated-register -Wno-unused-local-typedef
17:56:29:WU03:FS00:0xa7:   Platform: linux2 4.6.0-1-amd64
17:56:29:WU03:FS00:0xa7:       Bits: 64
17:56:29:WU03:FS00:0xa7:       Mode: Release
17:56:29:WU03:FS00:0xa7:       SIMD: avx_256
17:56:29:WU03:FS00:0xa7:************************************ System ************************************
17:56:29:WU03:FS00:0xa7:        CPU: Intel(R) Core(TM) i7-6700K CPU @ 4.00GHz
17:56:29:WU03:FS00:0xa7:     CPU ID: GenuineIntel Family 6 Model 94 Stepping 3
17:56:29:WU03:FS00:0xa7:       CPUs: 8
17:56:29:WU03:FS00:0xa7:     Memory: 31.92GiB
17:56:29:WU03:FS00:0xa7:Free Memory: 23.01GiB
17:56:29:WU03:FS00:0xa7:    Threads: WINDOWS_THREADS
17:56:29:WU03:FS00:0xa7: OS Version: 6.1
17:56:29:WU03:FS00:0xa7:Has Battery: false
17:56:29:WU03:FS00:0xa7: On Battery: false
17:56:29:WU03:FS00:0xa7: UTC Offset: 1
17:56:29:WU03:FS00:0xa7:        PID: 2908
17:56:29:WU03:FS00:0xa7:        CWD: C:\ProgramData\FAHClient\work
17:56:29:WU03:FS00:0xa7:         OS: Windows 7 Ultimate Service Pack 1
17:56:29:WU03:FS00:0xa7:    OS Arch: AMD64
17:56:29:WU03:FS00:0xa7:********************************************************************************
17:56:29:WU03:FS00:0xa7:Project: 11920 (Run 2609, Clone 1, Gen 1)
17:56:29:WU03:FS00:0xa7:Unit: 0x00000001ab4041295809a8c849960c30
17:56:29:WU03:FS00:0xa7:Reading tar file core.xml
17:56:29:WU03:FS00:0xa7:Reading tar file frame1.tpr
17:56:29:WU03:FS00:0xa7:Digital signatures verified
17:56:29:WU03:FS00:0xa7:Calling: mdrun -s frame1.tpr -o frame1.trr -cpt 15 -nt 6
17:56:30:WU03:FS00:0xa7:ERROR:
17:56:30:WU03:FS00:0xa7:ERROR:-------------------------------------------------------
17:56:30:WU03:FS00:0xa7:ERROR:Program GROMACS, VERSION 5.0.4-20160919-669094a-unknown
17:56:30:WU03:FS00:0xa7:ERROR:Source code file: /host/windows-cross-64bit-core-a7-avx-release/gromacs-core/build/gromacs/src/programs/mdrun/runner.c, line: 879
17:56:30:WU03:FS00:0xa7:ERROR:Fatal error:
17:56:30:WU03:FS00:0xa7:ERROR:More than 1 OpenMP thread requested, but Gromacs was compiled without OpenMP support
17:56:30:WU03:FS00:0xa7:ERROR:For more information and tips for troubleshooting, please check the GROMACS
17:56:30:WU03:FS00:0xa7:ERROR:website at http://www.gromacs.org/Documentation/Errors
17:56:35:WU03:FS00:0xa7:ERROR:
17:56:35:WU03:FS00:0xa7:WARNING:Unexpected exit() call
17:56:35:WU03:FS00:0xa7:ERROR:-------------------------------------------------------
17:56:35:WU03:FS00:0xa7:ERROR:Program GROMACS, VERSION 5.0.4-20160919-669094a-unknown
17:56:35:WU03:FS00:0xa7:ERROR:Source code file: /host/windows-cross-64bit-core-a7-avx-release/gromacs-core/build/gromacs/src/gromacs/gmxlib/gmx_omp_nthreads.c, line: 211
17:56:35:WU03:FS00:0xa7:ERROR:Fatal error:
17:56:35:WU03:FS00:0xa7:ERROR:Environment variable OMP_NUM_THREADS (8) and the number of threads requested on the command line (1) have different values. Either omit one, or set them both to the same value.
17:56:35:WU03:FS00:0xa7:ERROR:For more information and tips for troubleshooting, please check the GROMACS
17:56:35:WU03:FS00:0xa7:ERROR:website at http://www.gromacs.org/Documentation/Errors
17:56:40:WARNING:WU03:FS00:FahCore returned: FAILED_3 (255 = 0xff)
17:56:40:WARNING:WU03:FS00:Too many errors, failing
17:56:40:WU03:FS00:Sending unit results: id:03 state:SEND error:FAILED project:11920 run:2609 clone:1 gen:1 core:0xa7 unit:0x00000001ab4041295809a8c849960c30
17:56:40:WU03:FS00:Connecting to 171.64.65.41:8080
17:56:41:WU03:FS00:Server responded WORK_ACK (400)
17:56:41:WU03:FS00:Cleaning up
17:56:44:WU01:FS01:0x21:Completed 1725000 out of 2500000 steps (69%)
17:57:30:WU01:FS01:0x21:Completed 1750000 out of 2500000 steps (70%)
In case it help identify the issue, Operating system: Windows 7, CPU: 6700K (stock), Motherboard: Hero VII, GPU: 980Ti.
Any help is appreciated. (Sorry if this turns out to the the incorrect part of the forum)
Possibly worth mentioning that I reinstalled the client and the problem returned / stayed...
jcoffland
Re: FahCore_a7
Post by jcoffland »
As a work around unset the OMP_NUM_THREADS environment variable. In the future the core will unset this.
Cauldron Development LLC
http://cauldrondevelopment.com/
scarte
Re: FahCore_a7
Post by scarte »
jcoffland wrote:As a work around unset the OMP_NUM_THREADS environment variable. In the future the core will unset this.
How do i do that?
Re: FahCore_a7
Hello scarte, welcome to the Folding Support forum.
Adding the setting depends on the OS you have. It would be easier to just google it. It's quite common.
scarte
Re: FahCore_a7
Post by scarte »
Thank you.
did not know it was a OS variable, so i was looking in the wrong places.
So for anyone else using Windows it`s, Control Panel -> Sytem -> Environment variables and it`s under Path for the FAH client
WhitehawkEQ
Re: FahCore_a7
Post by WhitehawkEQ »
Here is the log from my 4P
09:35:56:WU00:FS00:Download 61.12%
09:38:52:WU00:FS00:Download 61.41%
09:41:17:WU00:FS00:Download 61.71%
09:43:06:WU00:FS00:Download 62.01%
09:46:01:WU00:FS00:Download 62.31%
b[91m09:46:01:ERROR:WU00:FS00:Exception: Transfer failedb[0m
09:46:01:WU00:FS00:Connecting to 171.67.108.45:8080
09:46:02:WU00:FS00:Assigned to work server 171.64.65.41
09:46:02:WU00:FS00:Requesting new work unit for slot 00: READY cpu:64 from 171.64.65.41
09:46:02:WU00:FS00:Connecting to 171.64.65.41:8080
b[93m09:46:02:WARNING:WU00:FS00:WorkServer connection failed on port 8080 trying 80b[0m
b[91m09:46:02:ERROR:WU00:FS00:Exception: Failed to connect to 171.64.65.41:80: Connection refusedb[0m
09:50:15:WU00:FS00:Connecting to 171.67.108.45:8080
09:50:15:WU00:FS00:Assigned to work server 171.64.65.41
09:50:16:WU00:FS00:Requesting new work unit for slot 00: READY cpu:64 from 171.64.65.41
09:50:16:WU00:FS00:Connecting to 171.64.65.41:8080
b[91m09:51:51:ERROR:WU00:FS00:Exception: 10002: Received short response, expected 512 bytes, got 0b[0m
09:57:07:WU00:FS00:Connecting to 171.67.108.45:8080
09:57:07:WU00:FS00:Assigned to work server 171.64.65.41
09:57:07:WU00:FS00:Requesting new work unit for slot 00: READY cpu:64 from 171.64.65.41
09:57:07:WU00:FS00:Connecting to 171.64.65.41:8080
******************************* Date: 2016-11-09 *******************************
10:00:51:WU00:FS00:Downloading 20.96MiB
10:03:58:WU00:FS00:Download 0.30%
10:04:07:WU00:FS00:Download 0.60%
10:04:13:WU00:FS00:Download 11.93%
10:04:20:WU00:FS00:Download 17.59%
10:04:28:WU00:FS00:Download 20.57%
10:04:34:WU00:FS00:Download 25.04%
10:04:40:WU00:FS00:Download 28.02%
10:04:46:WU00:FS00:Download 31.60%
10:04:52:WU00:FS00:Download 32.50%
10:04:58:WU00:FS00:Download 33.69%
10:05:05:WU00:FS00:Download 35.78%
Re: FahCore_a7
Whitehawk, I do not see your issue as being in any way related to an A_7 specific issue. You just have more CPU cores than F@H is prepared to fold with.
If you made four 16 core slots of CPU folding I am sure you would get work. It is possible that two 24 core slots and a 16 (or 20) core slot would get more Points Per Day but may still be larger than available work. 16 is a sure thing.
SchwartzBros
Re: FahCore_a7
Post by SchwartzBros »
I am also having an issue with FahCore_a7 and/or project 11920. I have had no issues running a4 projects, however when an a7 project is being started I get a popup window that says "FahCore_a7.exe has stopped working..."
The work unit will be stuck there until I manually select close program, at which point it will try downloading/starting a new work unit (which is usually the same project 11920, core a7) again and fail. It will attempt to start the project several times (sometimes a dozen or more) before it chooses a different project. I have noticed this happening for about 2 months. I thought it was just an issue with the server the project was on or an update I installed for Intel HD Graphics 4600 (driver 20.19.15.4501), but I have had that driver installed since early August and the issue with projects started near the beginning of September. I do not recall ever receiving a7 projects prior to September. I have tried installing older drivers as well as the stable version of F@H 7.4.4, but the issue remains.
Due to the popup window requiring a manual selection, I have lost hundreds of hours of folding time. I fold using my office computers I would like to find a solution to this as soon as possible so that I can maximize my contribution to the cause. Below you will see that the program first attempted to start an a7 project around 2:18 and failed. I arrived at my office around 10:59 and finally was able to get the program to start an a4 project around 11:09 losing out on nearly 9 hours of folding.
Windows 10 64-bit Version 1607 (OS Build 14393.447)
Intel Corei7-4790 (stock)
Folding at Home 7.4.15 (64-bit)
Thank you in advance for any help you can provide.
00:32:36:WU01:FS00:Starting
00:32:36:WU01:FS00:Running FahCore: "C:\Program Files\FAHClient/FAHCoreWrapper.exe" C:\ProgramData\FAHClient\cores/web.stanford.edu/~pande/Win32/AMD64/Core_a4.fah/FahCore_a4.exe -dir 01 -suffix 01 -version 704 -lifeline 7800 -checkpoint 15 -np 8
00:32:36:WU01:FS00:Started FahCore on PID 10160
00:32:36:WU01:FS00:Core PID:12884
00:32:36:WU01:FS00:FahCore 0xa4 started
00:32:37:WU01:FS00:0xa4:
00:32:37:WU01:FS00:0xa4:*------------------------------*
00:32:37:WU01:FS00:0xa4:Folding@Home Gromacs GB Core
00:32:37:WU01:FS00:0xa4:Version 2.27 (Dec. 15, 2010)
00:32:37:WU01:FS00:0xa4:Preparing to commence simulation
00:32:37:WU01:FS00:0xa4:- Looking at optimizations...
00:32:37:WU01:FS00:0xa4:- Created dyn
00:32:37:WU01:FS00:0xa4:- Files status OK
00:32:37:WU01:FS00:0xa4:- Expanded 825619 -> 1401112 (decompressed 169.7 percent)
00:32:37:WU01:FS00:0xa4:Called DecompressByteArray: compressed_data_size=825619 data_size=1401112, decompressed_data_size=1401112 diff=0
00:32:37:WU01:FS00:0xa4:- Digital signature verified
00:32:37:WU01:FS00:0xa4:Project: 9034 (Run 925, Clone 2, Gen 274)
00:32:37:WU01:FS00:0xa4:Assembly optimizations on if available.
00:32:37:WU01:FS00:0xa4:Entering M.D.
00:32:39:WU00:FS00:Upload complete
00:32:39:WU00:FS00:Server responded WORK_ACK (400)
00:32:39:WU00:FS00:Final credit estimate, 1937.00 points
00:32:39:WU00:FS00:Cleaning up
00:32:42:WU01:FS00:0xa4:Mapping NT from 8 to 8
00:32:42:WU01:FS00:0xa4:Completed 0 out of 250000 steps  (0%)
00:33:46:WU01:FS00:0xa4:Completed 2500 out of 250000 steps  (1%)
00:34:50:WU01:FS00:0xa4:Completed 5000 out of 250000 steps  (2%)
00:35:55:WU01:FS00:0xa4:Completed 7500 out of 250000 steps  (3%)
00:36:58:WU01:FS00:0xa4:Completed 10000 out of 250000 steps  (4%)
00:38:01:WU01:FS00:0xa4:Completed 12500 out of 250000 steps  (5%)
00:39:05:WU01:FS00:0xa4:Completed 15000 out of 250000 steps  (6%)
00:40:08:WU01:FS00:0xa4:Completed 17500 out of 250000 steps  (7%)
00:41:12:WU01:FS00:0xa4:Completed 20000 out of 250000 steps  (8%)
00:42:16:WU01:FS00:0xa4:Completed 22500 out of 250000 steps  (9%)
00:43:20:WU01:FS00:0xa4:Completed 25000 out of 250000 steps  (10%)
00:44:23:WU01:FS00:0xa4:Completed 27500 out of 250000 steps  (11%)
00:45:27:WU01:FS00:0xa4:Completed 30000 out of 250000 steps  (12%)
00:46:31:WU01:FS00:0xa4:Completed 32500 out of 250000 steps  (13%)
00:47:35:WU01:FS00:0xa4:Completed 35000 out of 250000 steps  (14%)
00:48:39:WU01:FS00:0xa4:Completed 37500 out of 250000 steps  (15%)
00:49:43:WU01:FS00:0xa4:Completed 40000 out of 250000 steps  (16%)
00:50:46:WU01:FS00:0xa4:Completed 42500 out of 250000 steps  (17%)
00:51:49:WU01:FS00:0xa4:Completed 45000 out of 250000 steps  (18%)
00:52:53:WU01:FS00:0xa4:Completed 47500 out of 250000 steps  (19%)
00:53:57:WU01:FS00:0xa4:Completed 50000 out of 250000 steps  (20%)
00:55:01:WU01:FS00:0xa4:Completed 52500 out of 250000 steps  (21%)
00:56:06:WU01:FS00:0xa4:Completed 55000 out of 250000 steps  (22%)
00:57:10:WU01:FS00:0xa4:Completed 57500 out of 250000 steps  (23%)
00:58:14:WU01:FS00:0xa4:Completed 60000 out of 250000 steps  (24%)
00:59:19:WU01:FS00:0xa4:Completed 62500 out of 250000 steps  (25%)
01:00:23:WU01:FS00:0xa4:Completed 65000 out of 250000 steps  (26%)
01:01:26:WU01:FS00:0xa4:Completed 67500 out of 250000 steps  (27%)
01:02:30:WU01:FS00:0xa4:Completed 70000 out of 250000 steps  (28%)
01:03:33:WU01:FS00:0xa4:Completed 72500 out of 250000 steps  (29%)
01:04:37:WU01:FS00:0xa4:Completed 75000 out of 250000 steps  (30%)
01:05:41:WU01:FS00:0xa4:Completed 77500 out of 250000 steps  (31%)
01:06:45:WU01:FS00:0xa4:Completed 80000 out of 250000 steps  (32%)
01:07:48:WU01:FS00:0xa4:Completed 82500 out of 250000 steps  (33%)
01:08:52:WU01:FS00:0xa4:Completed 85000 out of 250000 steps  (34%)
01:09:56:WU01:FS00:0xa4:Completed 87500 out of 250000 steps  (35%)
01:11:00:WU01:FS00:0xa4:Completed 90000 out of 250000 steps  (36%)
01:12:03:WU01:FS00:0xa4:Completed 92500 out of 250000 steps  (37%)
01:13:06:WU01:FS00:0xa4:Completed 95000 out of 250000 steps  (38%)
01:14:09:WU01:FS00:0xa4:Completed 97500 out of 250000 steps  (39%)
01:15:12:WU01:FS00:0xa4:Completed 100000 out of 250000 steps  (40%)
01:16:16:WU01:FS00:0xa4:Completed 102500 out of 250000 steps  (41%)
01:17:19:WU01:FS00:0xa4:Completed 105000 out of 250000 steps  (42%)
01:18:22:WU01:FS00:0xa4:Completed 107500 out of 250000 steps  (43%)
01:19:25:WU01:FS00:0xa4:Completed 110000 out of 250000 steps  (44%)
01:20:28:WU01:FS00:0xa4:Completed 112500 out of 250000 steps  (45%)
01:21:31:WU01:FS00:0xa4:Completed 115000 out of 250000 steps  (46%)
01:22:34:WU01:FS00:0xa4:Completed 117500 out of 250000 steps  (47%)
01:23:37:WU01:FS00:0xa4:Completed 120000 out of 250000 steps  (48%)
01:24:39:WU01:FS00:0xa4:Completed 122500 out of 250000 steps  (49%)
01:25:43:WU01:FS00:0xa4:Completed 125000 out of 250000 steps  (50%)
01:26:47:WU01:FS00:0xa4:Completed 127500 out of 250000 steps  (51%)
01:27:51:WU01:FS00:0xa4:Completed 130000 out of 250000 steps  (52%)
01:28:54:WU01:FS00:0xa4:Completed 132500 out of 250000 steps  (53%)
01:29:58:WU01:FS00:0xa4:Completed 135000 out of 250000 steps  (54%)
01:31:02:WU01:FS00:0xa4:Completed 137500 out of 250000 steps  (55%)
01:32:05:WU01:FS00:0xa4:Completed 140000 out of 250000 steps  (56%)
01:33:09:WU01:FS00:0xa4:Completed 142500 out of 250000 steps  (57%)
01:34:13:WU01:FS00:0xa4:Completed 145000 out of 250000 steps  (58%)
01:35:16:WU01:FS00:0xa4:Completed 147500 out of 250000 steps  (59%)
01:36:20:WU01:FS00:0xa4:Completed 150000 out of 250000 steps  (60%)
01:37:24:WU01:FS00:0xa4:Completed 152500 out of 250000 steps  (61%)
01:38:28:WU01:FS00:0xa4:Completed 155000 out of 250000 steps  (62%)
01:39:31:WU01:FS00:0xa4:Completed 157500 out of 250000 steps  (63%)
01:40:35:WU01:FS00:0xa4:Completed 160000 out of 250000 steps  (64%)
01:41:40:WU01:FS00:0xa4:Completed 162500 out of 250000 steps  (65%)
01:42:44:WU01:FS00:0xa4:Completed 165000 out of 250000 steps  (66%)
01:43:47:WU01:FS00:0xa4:Completed 167500 out of 250000 steps  (67%)
01:44:51:WU01:FS00:0xa4:Completed 170000 out of 250000 steps  (68%)
01:45:55:WU01:FS00:0xa4:Completed 172500 out of 250000 steps  (69%)
01:46:58:WU01:FS00:0xa4:Completed 175000 out of 250000 steps  (70%)
01:48:01:WU01:FS00:0xa4:Completed 177500 out of 250000 steps  (71%)
01:49:04:WU01:FS00:0xa4:Completed 180000 out of 250000 steps  (72%)
01:50:07:WU01:FS00:0xa4:Completed 182500 out of 250000 steps  (73%)
01:51:10:WU01:FS00:0xa4:Completed 185000 out of 250000 steps  (74%)
01:52:14:WU01:FS00:0xa4:Completed 187500 out of 250000 steps  (75%)
01:53:18:WU01:FS00:0xa4:Completed 190000 out of 250000 steps  (76%)
01:54:22:WU01:FS00:0xa4:Completed 192500 out of 250000 steps  (77%)
01:55:26:WU01:FS00:0xa4:Completed 195000 out of 250000 steps  (78%)
01:56:30:WU01:FS00:0xa4:Completed 197500 out of 250000 steps  (79%)
01:57:33:WU01:FS00:0xa4:Completed 200000 out of 250000 steps  (80%)
01:58:36:WU01:FS00:0xa4:Completed 202500 out of 250000 steps  (81%)
01:59:39:WU01:FS00:0xa4:Completed 205000 out of 250000 steps  (82%)
02:00:43:WU01:FS00:0xa4:Completed 207500 out of 250000 steps  (83%)
02:01:46:WU01:FS00:0xa4:Completed 210000 out of 250000 steps  (84%)
02:02:49:WU01:FS00:0xa4:Completed 212500 out of 250000 steps  (85%)
02:03:52:WU01:FS00:0xa4:Completed 215000 out of 250000 steps  (86%)
02:04:54:WU01:FS00:0xa4:Completed 217500 out of 250000 steps  (87%)
02:05:57:WU01:FS00:0xa4:Completed 220000 out of 250000 steps  (88%)
02:07:00:WU01:FS00:0xa4:Completed 222500 out of 250000 steps  (89%)
02:08:04:WU01:FS00:0xa4:Completed 225000 out of 250000 steps  (90%)
02:09:07:WU01:FS00:0xa4:Completed 227500 out of 250000 steps  (91%)
02:10:10:WU01:FS00:0xa4:Completed 230000 out of 250000 steps  (92%)
02:11:13:WU01:FS00:0xa4:Completed 232500 out of 250000 steps  (93%)
02:12:16:WU01:FS00:0xa4:Completed 235000 out of 250000 steps  (94%)
02:13:19:WU01:FS00:0xa4:Completed 237500 out of 250000 steps  (95%)
02:14:22:WU01:FS00:0xa4:Completed 240000 out of 250000 steps  (96%)
02:15:25:WU01:FS00:0xa4:Completed 242500 out of 250000 steps  (97%)
02:16:29:WU01:FS00:0xa4:Completed 245000 out of 250000 steps  (98%)
02:17:32:WU01:FS00:0xa4:Completed 247500 out of 250000 steps  (99%)
02:18:35:WU01:FS00:0xa4:Completed 250000 out of 250000 steps  (100%)
02:18:35:WU01:FS00:0xa4:DynamicWrapper: Finished Work Unit: sleep=10000
02:18:36:WU00:FS00:Connecting to 171.67.108.45:8080
02:18:36:WU00:FS00:Assigned to work server 171.64.65.41
02:18:36:WU00:FS00:Requesting new work unit for slot 00: RUNNING cpu:8 from 171.64.65.41
02:18:36:WU00:FS00:Connecting to 171.64.65.41:8080
02:18:45:WU01:FS00:0xa4:
02:18:45:WU01:FS00:0xa4:Finished Work Unit:
02:18:45:WU01:FS00:0xa4:- Reading up to 811512 from "01/wudata_01.trr": Read 811512
02:18:45:WU01:FS00:0xa4:trr file hash check passed.
02:18:45:WU01:FS00:0xa4:- Reading up to 746232 from "01/wudata_01.xtc": Read 746232
02:18:45:WU01:FS00:0xa4:xtc file hash check passed.
02:18:45:WU01:FS00:0xa4:edr file hash check passed.
02:18:45:WU01:FS00:0xa4:logfile size: 22922
02:18:45:WU01:FS00:0xa4:Leaving Run
02:18:46:WU00:FS00:Downloading 5.42MiB
02:18:48:WU01:FS00:0xa4:- Writing 1583154 bytes of core data to disk...
02:18:49:WU01:FS00:0xa4:Done: 1582642 -> 1537421 (compressed to 97.1 percent)
02:18:49:WU01:FS00:0xa4:  ... Done.
02:18:49:WU01:FS00:0xa4:- Shutting down core
02:18:49:WU01:FS00:0xa4:Folding@home Core Shutdown: FINISHED_UNIT
02:18:50:WU01:FS00:FahCore returned: FINISHED_UNIT (100 = 0x64)
02:18:50:WU01:FS00:Sending unit results: id:01 state:SEND error:NO_ERROR project:9034 run:925 clone:2 gen:274 core:0xa4 unit:0x0000013eab436c9e56982f132332742b
02:18:50:WU01:FS00:Uploading 1.47MiB to 171.67.108.158
02:18:50:WU01:FS00:Connecting to 171.67.108.158:8080
02:18:52:WU01:FS00:Upload complete
02:18:52:WU00:FS00:Download 10.37%
02:18:52:WU01:FS00:Server responded WORK_ACK (400)
02:18:52:WU01:FS00:Final credit estimate, 1901.00 points
02:18:52:WU01:FS00:Cleaning up
02:18:54:WU00:FS00:Download complete
02:18:55:WU00:FS00:Received Unit: id:00 state:DOWNLOAD error:NO_ERROR project:11920 run:585 clone:4 gen:0 core:0xa7 unit:0x00000000ab4041295809c9803f34b30b
02:18:55:WU00:FS00:Starting
02:18:55:WU00:FS00:Running FahCore: "C:\Program Files\FAHClient/FAHCoreWrapper.exe" C:\ProgramData\FAHClient\cores/web.stanford.edu/~pande/Win32/AMD64/AVX/Core_a7.fah/FahCore_a7.exe -dir 00 -suffix 01 -version 704 -lifeline 7800 -checkpoint 15 -np 8
02:18:55:WU00:FS00:Started FahCore on PID 12924
02:18:55:WU00:FS00:Core PID:12952
02:18:55:WU00:FS00:FahCore 0xa7 started
02:18:56:WU00:FS00:0xa7:*********************** Log Started 2016-11-09T02:18:55Z ***********************
02:18:56:WU00:FS00:0xa7:************************** Gromacs Folding@home Core ***************************
02:18:56:WU00:FS00:0xa7:       Type: 0xa7
02:18:56:WU00:FS00:0xa7:       Core: Gromacs
02:18:56:WU00:FS00:0xa7:    Website: http://folding.stanford.edu/
02:18:56:WU00:FS00:0xa7:  Copyright: (c) 2009-2016 Stanford University
02:18:56:WU00:FS00:0xa7:     Author: Joseph Coffland <joseph@cauldrondevelopment.com>
02:18:56:WU00:FS00:0xa7:       Args: -dir 00 -suffix 01 -version 704 -lifeline 12924 -checkpoint 15 -np
02:18:56:WU00:FS00:0xa7:             8
02:18:56:WU00:FS00:0xa7:     Config: <none>
02:18:56:WU00:FS00:0xa7:************************************ Build *************************************
02:18:56:WU00:FS00:0xa7:    Version: 0.0.11
02:18:56:WU00:FS00:0xa7:       Date: Sep 21 2016
02:18:56:WU00:FS00:0xa7:       Time: 01:43:48
02:18:56:WU00:FS00:0xa7: Repository: Git
02:18:56:WU00:FS00:0xa7:   Revision: 957bd90e68d95ddcf1594dc15ff6c64cc4555146
02:18:56:WU00:FS00:0xa7:     Branch: master
02:18:56:WU00:FS00:0xa7:   Compiler: GNU 4.2.1 Compatible Clang 3.9.0 (trunk 274080)
02:18:56:WU00:FS00:0xa7:    Options: -std=gnu++98 -O3 -funroll-loops -ffast-math -mfpmath=sse
02:18:56:WU00:FS00:0xa7:             -fno-unsafe-math-optimizations -msse2 -I/mingw64/include
02:18:56:WU00:FS00:0xa7:             -Wno-inconsistent-dllimport -Wno-parentheses-equality
02:18:56:WU00:FS00:0xa7:             -Wno-deprecated-register -Wno-unused-local-typedef
02:18:56:WU00:FS00:0xa7:   Platform: linux2 4.6.0-1-amd64
02:18:56:WU00:FS00:0xa7:       Bits: 64
02:18:56:WU00:FS00:0xa7:       Mode: Release
02:18:56:WU00:FS00:0xa7:       SIMD: avx_256
02:18:56:WU00:FS00:0xa7:************************************ System ************************************
02:18:56:WU00:FS00:0xa7:        CPU: Intel(R) Core(TM) i7-4790 CPU @ 3.60GHz
02:18:56:WU00:FS00:0xa7:     CPU ID: GenuineIntel Family 6 Model 60 Stepping 3
02:18:56:WU00:FS00:0xa7:       CPUs: 8
02:18:56:WU00:FS00:0xa7:     Memory: 15.90GiB
02:18:56:WU00:FS00:0xa7:Free Memory: 11.19GiB
02:18:56:WU00:FS00:0xa7:    Threads: WINDOWS_THREADS
02:18:56:WU00:FS00:0xa7: OS Version: 6.2
02:18:56:WU00:FS00:0xa7:Has Battery: false
02:18:56:WU00:FS00:0xa7: On Battery: false
02:18:56:WU00:FS00:0xa7: UTC Offset: -5
02:18:56:WU00:FS00:0xa7:        PID: 12952
02:18:56:WU00:FS00:0xa7:        CWD: C:\ProgramData\FAHClient\work
02:18:56:WU00:FS00:0xa7:         OS: Windows 10 Home
02:18:56:WU00:FS00:0xa7:    OS Arch: AMD64
02:18:56:WU00:FS00:0xa7:********************************************************************************
02:18:56:WU00:FS00:0xa7:Project: 11920 (Run 585, Clone 4, Gen 0)
02:18:56:WU00:FS00:0xa7:Unit: 0x00000000ab4041295809c9803f34b30b
02:18:56:WU00:FS00:0xa7:Reading tar file core.xml
02:18:56:WU00:FS00:0xa7:Reading tar file frame0.tpr
02:18:56:WU00:FS00:0xa7:Digital signatures verified
02:18:56:WU00:FS00:0xa7:Calling: mdrun -s frame0.tpr -o frame0.trr -cpt 15 -nt 8
02:18:57:WU00:FS00:0xa7:ERROR:
02:18:57:WU00:FS00:0xa7:ERROR:-------------------------------------------------------
02:18:57:WU00:FS00:0xa7:ERROR:Program GROMACS, VERSION 5.0.4-20160919-669094a-unknown
02:18:57:WU00:FS00:0xa7:ERROR:Source code file: /host/windows-cross-64bit-core-a7-avx-release/gromacs-core/build/gromacs/src/programs/mdrun/runner.c, line: 879
02:18:57:WU00:FS00:0xa7:ERROR:Fatal error:
02:18:57:WU00:FS00:0xa7:ERROR:More than 1 OpenMP thread requested, but Gromacs was compiled without OpenMP support
02:18:57:WU00:FS00:0xa7:ERROR:For more information and tips for troubleshooting, please check the GROMACS
02:18:57:WU00:FS00:0xa7:ERROR:website at http://www.gromacs.org/Documentation/Errors
02:19:02:WU00:FS00:0xa7:ERROR:
02:19:02:WU00:FS00:0xa7:WARNING:Unexpected exit() call
02:19:02:WU00:FS00:0xa7:ERROR:-------------------------------------------------------
02:19:02:WU00:FS00:0xa7:ERROR:Program GROMACS, VERSION 5.0.4-20160919-669094a-unknown
02:19:02:WU00:FS00:0xa7:ERROR:Source code file: /host/windows-cross-64bit-core-a7-avx-release/gromacs-core/build/gromacs/src/gromacs/gmxlib/gmx_omp_nthreads.c, line: 211
02:19:02:WU00:FS00:0xa7:ERROR:Fatal error:
02:19:02:WU00:FS00:0xa7:ERROR:Environment variable OMP_NUM_THREADS (8) and the number of threads requested on the command line (1) have different values. Either omit one, or set them both to the same value.
02:19:02:WU00:FS00:0xa7:ERROR:For more information and tips for troubleshooting, please check the GROMACS
02:19:02:WU00:FS00:0xa7:ERROR:website at http://www.gromacs.org/Documentation/Errors
10:59:55:WARNING:WU00:FS00:FahCore returned: FAILED_3 (255 = 0xff)
10:59:55:WU00:FS00:Starting
10:59:55:WU00:FS00:Running FahCore: "C:\Program Files\FAHClient/FAHCoreWrapper.exe" C:\ProgramData\FAHClient\cores/web.stanford.edu/~pande/Win32/AMD64/AVX/Core_a7.fah/FahCore_a7.exe -dir 00 -suffix 01 -version 704 -lifeline 7800 -checkpoint 15 -np 8
10:59:55:WU00:FS00:Started FahCore on PID 12884
10:59:55:WU00:FS00:Core PID:7876
10:59:55:WU00:FS00:FahCore 0xa7 started
10:59:56:WU00:FS00:0xa7:*********************** Log Started 2016-11-09T10:59:55Z ***********************
10:59:56:WU00:FS00:0xa7:************************** Gromacs Folding@home Core ***************************
10:59:56:WU00:FS00:0xa7:       Type: 0xa7
10:59:56:WU00:FS00:0xa7:       Core: Gromacs
10:59:56:WU00:FS00:0xa7:    Website: http://folding.stanford.edu/
10:59:56:WU00:FS00:0xa7:  Copyright: (c) 2009-2016 Stanford University
10:59:56:WU00:FS00:0xa7:     Author: Joseph Coffland <joseph@cauldrondevelopment.com>
10:59:56:WU00:FS00:0xa7:       Args: -dir 00 -suffix 01 -version 704 -lifeline 12884 -checkpoint 15 -np
10:59:56:WU00:FS00:0xa7:             8
10:59:56:WU00:FS00:0xa7:     Config: <none>
10:59:56:WU00:FS00:0xa7:************************************ Build *************************************
10:59:56:WU00:FS00:0xa7:    Version: 0.0.11
10:59:56:WU00:FS00:0xa7:       Date: Sep 21 2016
10:59:56:WU00:FS00:0xa7:       Time: 01:43:48
10:59:56:WU00:FS00:0xa7: Repository: Git
10:59:56:WU00:FS00:0xa7:   Revision: 957bd90e68d95ddcf1594dc15ff6c64cc4555146
10:59:56:WU00:FS00:0xa7:     Branch: master
10:59:56:WU00:FS00:0xa7:   Compiler: GNU 4.2.1 Compatible Clang 3.9.0 (trunk 274080)
10:59:56:WU00:FS00:0xa7:    Options: -std=gnu++98 -O3 -funroll-loops -ffast-math -mfpmath=sse
10:59:56:WU00:FS00:0xa7:             -fno-unsafe-math-optimizations -msse2 -I/mingw64/include
10:59:56:WU00:FS00:0xa7:             -Wno-inconsistent-dllimport -Wno-parentheses-equality
10:59:56:WU00:FS00:0xa7:             -Wno-deprecated-register -Wno-unused-local-typedef
10:59:56:WU00:FS00:0xa7:   Platform: linux2 4.6.0-1-amd64
10:59:56:WU00:FS00:0xa7:       Bits: 64
10:59:56:WU00:FS00:0xa7:       Mode: Release
10:59:56:WU00:FS00:0xa7:       SIMD: avx_256
10:59:56:WU00:FS00:0xa7:************************************ System ************************************
10:59:56:WU00:FS00:0xa7:        CPU: Intel(R) Core(TM) i7-4790 CPU @ 3.60GHz
10:59:56:WU00:FS00:0xa7:     CPU ID: GenuineIntel Family 6 Model 60 Stepping 3
10:59:56:WU00:FS00:0xa7:       CPUs: 8
10:59:56:WU00:FS00:0xa7:     Memory: 15.90GiB
10:59:56:WU00:FS00:0xa7:Free Memory: 11.24GiB
10:59:56:WU00:FS00:0xa7:    Threads: WINDOWS_THREADS
10:59:56:WU00:FS00:0xa7: OS Version: 6.2
10:59:56:WU00:FS00:0xa7:Has Battery: false
10:59:56:WU00:FS00:0xa7: On Battery: false
10:59:56:WU00:FS00:0xa7: UTC Offset: -5
10:59:56:WU00:FS00:0xa7:        PID: 7876
10:59:56:WU00:FS00:0xa7:        CWD: C:\ProgramData\FAHClient\work
10:59:56:WU00:FS00:0xa7:         OS: Windows 10 Home
10:59:56:WU00:FS00:0xa7:    OS Arch: AMD64
10:59:56:WU00:FS00:0xa7:********************************************************************************
10:59:56:WU00:FS00:0xa7:Project: 11920 (Run 585, Clone 4, Gen 0)
10:59:56:WU00:FS00:0xa7:Unit: 0x00000000ab4041295809c9803f34b30b
10:59:56:WU00:FS00:0xa7:Reading tar file core.xml
10:59:56:WU00:FS00:0xa7:Reading tar file frame0.tpr
10:59:56:WU00:FS00:0xa7:Digital signatures verified
10:59:56:WU00:FS00:0xa7:Calling: mdrun -s frame0.tpr -o frame0.trr -cpt 15 -nt 8
10:59:57:WU00:FS00:0xa7:ERROR:
10:59:57:WU00:FS00:0xa7:ERROR:-------------------------------------------------------
10:59:57:WU00:FS00:0xa7:ERROR:Program GROMACS, VERSION 5.0.4-20160919-669094a-unknown
10:59:57:WU00:FS00:0xa7:ERROR:Source code file: /host/windows-cross-64bit-core-a7-avx-release/gromacs-core/build/gromacs/src/programs/mdrun/runner.c, line: 879
10:59:57:WU00:FS00:0xa7:ERROR:Fatal error:
10:59:57:WU00:FS00:0xa7:ERROR:More than 1 OpenMP thread requested, but Gromacs was compiled without OpenMP support
10:59:57:WU00:FS00:0xa7:ERROR:For more information and tips for troubleshooting, please check the GROMACS
10:59:57:WU00:FS00:0xa7:ERROR:website at http://www.gromacs.org/Documentation/Errors
11:00:02:WU00:FS00:0xa7:ERROR:
11:00:02:WU00:FS00:0xa7:WARNING:Unexpected exit() call
11:00:02:WU00:FS00:0xa7:ERROR:-------------------------------------------------------
11:00:02:WU00:FS00:0xa7:ERROR:Program GROMACS, VERSION 5.0.4-20160919-669094a-unknown
11:00:02:WU00:FS00:0xa7:ERROR:Source code file: /host/windows-cross-64bit-core-a7-avx-release/gromacs-core/build/gromacs/src/gromacs/gmxlib/gmx_omp_nthreads.c, line: 211
11:00:02:WU00:FS00:0xa7:ERROR:Fatal error:
11:00:02:WU00:FS00:0xa7:ERROR:Environment variable OMP_NUM_THREADS (8) and the number of threads requested on the command line (1) have different values. Either omit one, or set them both to the same value.
11:00:02:WU00:FS00:0xa7:ERROR:For more information and tips for troubleshooting, please check the GROMACS
11:00:02:WU00:FS00:0xa7:ERROR:website at http://www.gromacs.org/Documentation/Errors
11:00:04:WARNING:WU00:FS00:FahCore returned an unknown error code which probably indicates that it crashed
11:00:04:WARNING:WU00:FS00:FahCore returned: UNKNOWN_ENUM (-1073741784 = 0xc0000028)
11:00:56:WU00:FS00:Starting
11:00:56:WU00:FS00:Running FahCore: "C:\Program Files\FAHClient/FAHCoreWrapper.exe" C:\ProgramData\FAHClient\cores/web.stanford.edu/~pande/Win32/AMD64/AVX/Core_a7.fah/FahCore_a7.exe -dir 00 -suffix 01 -version 704 -lifeline 7800 -checkpoint 15 -np 8
11:00:56:WU00:FS00:Started FahCore on PID 9888
11:00:56:WU00:FS00:Core PID:7236
11:00:56:WU00:FS00:FahCore 0xa7 started
11:00:56:WU00:FS00:0xa7:*********************** Log Started 2016-11-09T11:00:56Z ***********************
11:00:56:WU00:FS00:0xa7:************************** Gromacs Folding@home Core ***************************
11:00:56:WU00:FS00:0xa7:       Type: 0xa7
11:00:56:WU00:FS00:0xa7:       Core: Gromacs
11:00:56:WU00:FS00:0xa7:    Website: http://folding.stanford.edu/
11:00:56:WU00:FS00:0xa7:  Copyright: (c) 2009-2016 Stanford University
11:00:56:WU00:FS00:0xa7:     Author: Joseph Coffland <joseph@cauldrondevelopment.com>
11:00:56:WU00:FS00:0xa7:       Args: -dir 00 -suffix 01 -version 704 -lifeline 9888 -checkpoint 15 -np 8
11:00:56:WU00:FS00:0xa7:     Config: <none>
11:00:56:WU00:FS00:0xa7:************************************ Build *************************************
11:00:56:WU00:FS00:0xa7:    Version: 0.0.11
11:00:56:WU00:FS00:0xa7:       Date: Sep 21 2016
11:00:56:WU00:FS00:0xa7:       Time: 01:43:48
11:00:56:WU00:FS00:0xa7: Repository: Git
11:00:56:WU00:FS00:0xa7:   Revision: 957bd90e68d95ddcf1594dc15ff6c64cc4555146
11:00:56:WU00:FS00:0xa7:     Branch: master
11:00:56:WU00:FS00:0xa7:   Compiler: GNU 4.2.1 Compatible Clang 3.9.0 (trunk 274080)
11:00:56:WU00:FS00:0xa7:    Options: -std=gnu++98 -O3 -funroll-loops -ffast-math -mfpmath=sse
11:00:56:WU00:FS00:0xa7:             -fno-unsafe-math-optimizations -msse2 -I/mingw64/include
11:00:56:WU00:FS00:0xa7:             -Wno-inconsistent-dllimport -Wno-parentheses-equality
11:00:56:WU00:FS00:0xa7:             -Wno-deprecated-register -Wno-unused-local-typedef
11:00:56:WU00:FS00:0xa7:   Platform: linux2 4.6.0-1-amd64
11:00:56:WU00:FS00:0xa7:       Bits: 64
11:00:56:WU00:FS00:0xa7:       Mode: Release
11:00:56:WU00:FS00:0xa7:       SIMD: avx_256
11:00:56:WU00:FS00:0xa7:************************************ System ************************************
11:00:56:WU00:FS00:0xa7:        CPU: Intel(R) Core(TM) i7-4790 CPU @ 3.60GHz
11:00:56:WU00:FS00:0xa7:     CPU ID: GenuineIntel Family 6 Model 60 Stepping 3
11:00:56:WU00:FS00:0xa7:       CPUs: 8
11:00:56:WU00:FS00:0xa7:     Memory: 15.90GiB
11:00:56:WU00:FS00:0xa7:Free Memory: 11.40GiB
11:00:56:WU00:FS00:0xa7:    Threads: WINDOWS_THREADS
11:00:56:WU00:FS00:0xa7: OS Version: 6.2
11:00:56:WU00:FS00:0xa7:Has Battery: false
11:00:56:WU00:FS00:0xa7: On Battery: false
11:00:56:WU00:FS00:0xa7: UTC Offset: -5
11:00:56:WU00:FS00:0xa7:        PID: 7236
11:00:56:WU00:FS00:0xa7:        CWD: C:\ProgramData\FAHClient\work
11:00:56:WU00:FS00:0xa7:         OS: Windows 10 Home
11:00:56:WU00:FS00:0xa7:    OS Arch: AMD64
11:00:56:WU00:FS00:0xa7:********************************************************************************
11:00:56:WU00:FS00:0xa7:Project: 11920 (Run 585, Clone 4, Gen 0)
11:00:56:WU00:FS00:0xa7:Unit: 0x00000000ab4041295809c9803f34b30b
11:00:56:WU00:FS00:0xa7:Reading tar file core.xml
11:00:56:WU00:FS00:0xa7:Reading tar file frame0.tpr
11:00:56:WU00:FS00:0xa7:Digital signatures verified
11:00:56:WU00:FS00:0xa7:Calling: mdrun -s frame0.tpr -o frame0.trr -cpt 15 -nt 8
11:00:57:WU00:FS00:0xa7:ERROR:
11:00:57:WU00:FS00:0xa7:ERROR:-------------------------------------------------------
11:00:57:WU00:FS00:0xa7:ERROR:Program GROMACS, VERSION 5.0.4-20160919-669094a-unknown
11:00:57:WU00:FS00:0xa7:ERROR:Source code file: /host/windows-cross-64bit-core-a7-avx-release/gromacs-core/build/gromacs/src/programs/mdrun/runner.c, line: 879
11:00:57:WU00:FS00:0xa7:ERROR:Fatal error:
11:00:57:WU00:FS00:0xa7:ERROR:More than 1 OpenMP thread requested, but Gromacs was compiled without OpenMP support
11:00:57:WU00:FS00:0xa7:ERROR:For more information and tips for troubleshooting, please check the GROMACS
11:00:57:WU00:FS00:0xa7:ERROR:website at http://www.gromacs.org/Documentation/Errors
11:01:02:WU00:FS00:0xa7:ERROR:
11:01:02:WU00:FS00:0xa7:WARNING:Unexpected exit() call
11:01:02:WU00:FS00:0xa7:ERROR:-------------------------------------------------------
11:01:02:WU00:FS00:0xa7:ERROR:Program GROMACS, VERSION 5.0.4-20160919-669094a-unknown
11:01:02:WU00:FS00:0xa7:ERROR:Source code file: /host/windows-cross-64bit-core-a7-avx-release/gromacs-core/build/gromacs/src/gromacs/gmxlib/gmx_omp_nthreads.c, line: 211
11:01:02:WU00:FS00:0xa7:ERROR:Fatal error:
11:01:02:WU00:FS00:0xa7:ERROR:Environment variable OMP_NUM_THREADS (8) and the number of threads requested on the command line (1) have different values. Either omit one, or set them both to the same value.
11:01:02:WU00:FS00:0xa7:ERROR:For more information and tips for troubleshooting, please check the GROMACS
11:01:02:WU00:FS00:0xa7:ERROR:website at http://www.gromacs.org/Documentation/Errors
11:01:14:WARNING:WU00:FS00:FahCore returned: FAILED_3 (255 = 0xff)
11:01:56:WU00:FS00:Starting
11:01:56:WU00:FS00:Running FahCore: "C:\Program Files\FAHClient/FAHCoreWrapper.exe" C:\ProgramData\FAHClient\cores/web.stanford.edu/~pande/Win32/AMD64/AVX/Core_a7.fah/FahCore_a7.exe -dir 00 -suffix 01 -version 704 -lifeline 7800 -checkpoint 15 -np 8
11:01:56:WU00:FS00:Started FahCore on PID 8396
11:01:56:WU00:FS00:Core PID:11840
11:01:56:WU00:FS00:FahCore 0xa7 started
11:01:56:WU00:FS00:0xa7:*********************** Log Started 2016-11-09T11:01:56Z ***********************
11:01:56:WU00:FS00:0xa7:************************** Gromacs Folding@home Core ***************************
11:01:56:WU00:FS00:0xa7:       Type: 0xa7
11:01:56:WU00:FS00:0xa7:       Core: Gromacs
11:01:56:WU00:FS00:0xa7:    Website: http://folding.stanford.edu/
11:01:56:WU00:FS00:0xa7:  Copyright: (c) 2009-2016 Stanford University
11:01:56:WU00:FS00:0xa7:     Author: Joseph Coffland <joseph@cauldrondevelopment.com>
11:01:56:WU00:FS00:0xa7:       Args: -dir 00 -suffix 01 -version 704 -lifeline 8396 -checkpoint 15 -np 8
11:01:56:WU00:FS00:0xa7:     Config: <none>
11:01:56:WU00:FS00:0xa7:************************************ Build *************************************
11:01:56:WU00:FS00:0xa7:    Version: 0.0.11
11:01:56:WU00:FS00:0xa7:       Date: Sep 21 2016
11:01:56:WU00:FS00:0xa7:       Time: 01:43:48
11:01:56:WU00:FS00:0xa7: Repository: Git
11:01:56:WU00:FS00:0xa7:   Revision: 957bd90e68d95ddcf1594dc15ff6c64cc4555146
11:01:56:WU00:FS00:0xa7:     Branch: master
11:01:56:WU00:FS00:0xa7:   Compiler: GNU 4.2.1 Compatible Clang 3.9.0 (trunk 274080)
11:01:56:WU00:FS00:0xa7:    Options: -std=gnu++98 -O3 -funroll-loops -ffast-math -mfpmath=sse
11:01:56:WU00:FS00:0xa7:             -fno-unsafe-math-optimizations -msse2 -I/mingw64/include
11:01:56:WU00:FS00:0xa7:             -Wno-inconsistent-dllimport -Wno-parentheses-equality
11:01:56:WU00:FS00:0xa7:             -Wno-deprecated-register -Wno-unused-local-typedef
11:01:56:WU00:FS00:0xa7:   Platform: linux2 4.6.0-1-amd64
11:01:56:WU00:FS00:0xa7:       Bits: 64
11:01:56:WU00:FS00:0xa7:       Mode: Release
11:01:56:WU00:FS00:0xa7:       SIMD: avx_256
11:01:56:WU00:FS00:0xa7:************************************ System ************************************
11:01:56:WU00:FS00:0xa7:        CPU: Intel(R) Core(TM) i7-4790 CPU @ 3.60GHz
11:01:56:WU00:FS00:0xa7:     CPU ID: GenuineIntel Family 6 Model 60 Stepping 3
11:01:56:WU00:FS00:0xa7:       CPUs: 8
11:01:56:WU00:FS00:0xa7:     Memory: 15.90GiB
11:01:56:WU00:FS00:0xa7:Free Memory: 11.61GiB
11:01:56:WU00:FS00:0xa7:    Threads: WINDOWS_THREADS
11:01:56:WU00:FS00:0xa7: OS Version: 6.2
11:01:56:WU00:FS00:0xa7:Has Battery: false
11:01:56:WU00:FS00:0xa7: On Battery: false
11:01:56:WU00:FS00:0xa7: UTC Offset: -5
11:01:56:WU00:FS00:0xa7:        PID: 11840
11:01:56:WU00:FS00:0xa7:        CWD: C:\ProgramData\FAHClient\work
11:01:56:WU00:FS00:0xa7:         OS: Windows 10 Home
11:01:56:WU00:FS00:0xa7:    OS Arch: AMD64
11:01:56:WU00:FS00:0xa7:********************************************************************************
11:01:56:WU00:FS00:0xa7:Project: 11920 (Run 585, Clone 4, Gen 0)
11:01:56:WU00:FS00:0xa7:Unit: 0x00000000ab4041295809c9803f34b30b
11:01:56:WU00:FS00:0xa7:Reading tar file core.xml
11:01:56:WU00:FS00:0xa7:Reading tar file frame0.tpr
11:01:56:WU00:FS00:0xa7:Digital signatures verified
11:01:56:WU00:FS00:0xa7:Calling: mdrun -s frame0.tpr -o frame0.trr -cpt 15 -nt 8
11:01:57:WU00:FS00:0xa7:ERROR:
11:01:57:WU00:FS00:0xa7:ERROR:-------------------------------------------------------
11:01:57:WU00:FS00:0xa7:ERROR:Program GROMACS, VERSION 5.0.4-20160919-669094a-unknown
11:01:57:WU00:FS00:0xa7:ERROR:Source code file: /host/windows-cross-64bit-core-a7-avx-release/gromacs-core/build/gromacs/src/programs/mdrun/runner.c, line: 879
11:01:57:WU00:FS00:0xa7:ERROR:Fatal error:
11:01:57:WU00:FS00:0xa7:ERROR:More than 1 OpenMP thread requested, but Gromacs was compiled without OpenMP support
11:01:57:WU00:FS00:0xa7:ERROR:For more information and tips for troubleshooting, please check the GROMACS
11:01:57:WU00:FS00:0xa7:ERROR:website at http://www.gromacs.org/Documentation/Errors
11:02:02:WU00:FS00:0xa7:ERROR:
11:02:02:WU00:FS00:0xa7:WARNING:Unexpected exit() call
11:02:02:WU00:FS00:0xa7:ERROR:-------------------------------------------------------
11:02:02:WU00:FS00:0xa7:ERROR:Program GROMACS, VERSION 5.0.4-20160919-669094a-unknown
11:02:02:WU00:FS00:0xa7:ERROR:Source code file: /host/windows-cross-64bit-core-a7-avx-release/gromacs-core/build/gromacs/src/gromacs/gmxlib/gmx_omp_nthreads.c, line: 211
11:02:02:WU00:FS00:0xa7:ERROR:Fatal error:
11:02:02:WU00:FS00:0xa7:ERROR:Environment variable OMP_NUM_THREADS (8) and the number of threads requested on the command line (1) have different values. Either omit one, or set them both to the same value.
11:02:02:WU00:FS00:0xa7:ERROR:For more information and tips for troubleshooting, please check the GROMACS
11:02:02:WU00:FS00:0xa7:ERROR:website at http://www.gromacs.org/Documentation/Errors
11:02:07:WARNING:WU00:FS00:FahCore returned: FAILED_3 (255 = 0xff)
11:02:56:WU00:FS00:Starting
11:02:56:WU00:FS00:Running FahCore: "C:\Program Files\FAHClient/FAHCoreWrapper.exe" C:\ProgramData\FAHClient\cores/web.stanford.edu/~pande/Win32/AMD64/AVX/Core_a7.fah/FahCore_a7.exe -dir 00 -suffix 01 -version 704 -lifeline 7800 -checkpoint 15 -np 8
11:02:56:WU00:FS00:Started FahCore on PID 1560
11:02:56:WU00:FS00:Core PID:12976
11:02:56:WU00:FS00:FahCore 0xa7 started
11:02:56:WU00:FS00:0xa7:*********************** Log Started 2016-11-09T11:02:56Z ***********************
11:02:56:WU00:FS00:0xa7:************************** Gromacs Folding@home Core ***************************
11:02:56:WU00:FS00:0xa7:       Type: 0xa7
11:02:56:WU00:FS00:0xa7:       Core: Gromacs
11:02:56:WU00:FS00:0xa7:    Website: http://folding.stanford.edu/
11:02:56:WU00:FS00:0xa7:  Copyright: (c) 2009-2016 Stanford University
11:02:56:WU00:FS00:0xa7:     Author: Joseph Coffland <joseph@cauldrondevelopment.com>
11:02:56:WU00:FS00:0xa7:       Args: -dir 00 -suffix 01 -version 704 -lifeline 1560 -checkpoint 15 -np 8
11:02:56:WU00:FS00:0xa7:     Config: <none>
11:02:56:WU00:FS00:0xa7:************************************ Build *************************************
11:02:56:WU00:FS00:0xa7:    Version: 0.0.11
11:02:56:WU00:FS00:0xa7:       Date: Sep 21 2016
11:02:56:WU00:FS00:0xa7:       Time: 01:43:48
11:02:56:WU00:FS00:0xa7: Repository: Git
11:02:56:WU00:FS00:0xa7:   Revision: 957bd90e68d95ddcf1594dc15ff6c64cc4555146
11:02:56:WU00:FS00:0xa7:     Branch: master
11:02:56:WU00:FS00:0xa7:   Compiler: GNU 4.2.1 Compatible Clang 3.9.0 (trunk 274080)
11:02:56:WU00:FS00:0xa7:    Options: -std=gnu++98 -O3 -funroll-loops -ffast-math -mfpmath=sse
11:02:56:WU00:FS00:0xa7:             -fno-unsafe-math-optimizations -msse2 -I/mingw64/include
11:02:56:WU00:FS00:0xa7:             -Wno-inconsistent-dllimport -Wno-parentheses-equality
11:02:56:WU00:FS00:0xa7:             -Wno-deprecated-register -Wno-unused-local-typedef
11:02:56:WU00:FS00:0xa7:   Platform: linux2 4.6.0-1-amd64
11:02:56:WU00:FS00:0xa7:       Bits: 64
11:02:56:WU00:FS00:0xa7:       Mode: Release
11:02:56:WU00:FS00:0xa7:       SIMD: avx_256
11:02:56:WU00:FS00:0xa7:************************************ System ************************************
11:02:56:WU00:FS00:0xa7:        CPU: Intel(R) Core(TM) i7-4790 CPU @ 3.60GHz
11:02:56:WU00:FS00:0xa7:     CPU ID: GenuineIntel Family 6 Model 60 Stepping 3
11:02:56:WU00:FS00:0xa7:       CPUs: 8
11:02:56:WU00:FS00:0xa7:     Memory: 15.90GiB
11:02:56:WU00:FS00:0xa7:Free Memory: 11.63GiB
11:02:56:WU00:FS00:0xa7:    Threads: WINDOWS_THREADS
11:02:56:WU00:FS00:0xa7: OS Version: 6.2
11:02:56:WU00:FS00:0xa7:Has Battery: false
11:02:56:WU00:FS00:0xa7: On Battery: false
11:02:56:WU00:FS00:0xa7: UTC Offset: -5
11:02:56:WU00:FS00:0xa7:        PID: 12976
11:02:56:WU00:FS00:0xa7:        CWD: C:\ProgramData\FAHClient\work
11:02:56:WU00:FS00:0xa7:         OS: Windows 10 Home
11:02:56:WU00:FS00:0xa7:    OS Arch: AMD64
11:02:56:WU00:FS00:0xa7:********************************************************************************
11:02:56:WU00:FS00:0xa7:Project: 11920 (Run 585, Clone 4, Gen 0)
11:02:56:WU00:FS00:0xa7:Unit: 0x00000000ab4041295809c9803f34b30b
11:02:56:WU00:FS00:0xa7:Reading tar file core.xml
11:02:56:WU00:FS00:0xa7:Reading tar file frame0.tpr
11:02:57:WU00:FS00:0xa7:Digital signatures verified
11:02:57:WU00:FS00:0xa7:Calling: mdrun -s frame0.tpr -o frame0.trr -cpt 15 -nt 8
11:02:57:WU00:FS00:0xa7:ERROR:
11:02:57:WU00:FS00:0xa7:ERROR:-------------------------------------------------------
11:02:57:WU00:FS00:0xa7:ERROR:Program GROMACS, VERSION 5.0.4-20160919-669094a-unknown
11:02:57:WU00:FS00:0xa7:ERROR:Source code file: /host/windows-cross-64bit-core-a7-avx-release/gromacs-core/build/gromacs/src/programs/mdrun/runner.c, line: 879
11:02:57:WU00:FS00:0xa7:ERROR:Fatal error:
11:02:57:WU00:FS00:0xa7:ERROR:More than 1 OpenMP thread requested, but Gromacs was compiled without OpenMP support
11:02:57:WU00:FS00:0xa7:ERROR:For more information and tips for troubleshooting, please check the GROMACS
11:02:57:WU00:FS00:0xa7:ERROR:website at http://www.gromacs.org/Documentation/Errors
11:03:02:WU00:FS00:0xa7:ERROR:
11:03:02:WU00:FS00:0xa7:WARNING:Unexpected exit() call
11:03:02:WU00:FS00:0xa7:ERROR:-------------------------------------------------------
11:03:02:WU00:FS00:0xa7:ERROR:Program GROMACS, VERSION 5.0.4-20160919-669094a-unknown
11:03:02:WU00:FS00:0xa7:ERROR:Source code file: /host/windows-cross-64bit-core-a7-avx-release/gromacs-core/build/gromacs/src/gromacs/gmxlib/gmx_omp_nthreads.c, line: 211
11:03:02:WU00:FS00:0xa7:ERROR:Fatal error:
11:03:02:WU00:FS00:0xa7:ERROR:Environment variable OMP_NUM_THREADS (8) and the number of threads requested on the command line (1) have different values. Either omit one, or set them both to the same value.
11:03:02:WU00:FS00:0xa7:ERROR:For more information and tips for troubleshooting, please check the GROMACS
11:03:02:WU00:FS00:0xa7:ERROR:website at http://www.gromacs.org/Documentation/Errors
11:03:07:WARNING:WU00:FS00:FahCore returned: FAILED_3 (255 = 0xff)
11:03:07:WARNING:WU00:FS00:Too many errors, failing
11:03:07:WU00:FS00:Sending unit results: id:00 state:SEND error:FAILED project:11920 run:585 clone:4 gen:0 core:0xa7 unit:0x00000000ab4041295809c9803f34b30b
11:03:07:WU00:FS00:Connecting to 171.64.65.41:8080
11:03:08:WU01:FS00:Connecting to 171.67.108.45:8080
11:03:08:WU01:FS00:Assigned to work server 171.64.65.41
11:03:08:WU01:FS00:Requesting new work unit for slot 00: READY cpu:8 from 171.64.65.41
11:03:08:WU01:FS00:Connecting to 171.64.65.41:8080
11:03:28:WARNING:WU00:FS00:WorkServer connection failed on port 8080 trying 80
11:03:28:WU00:FS00:Connecting to 171.64.65.41:80
11:03:29:WARNING:WU01:FS00:WorkServer connection failed on port 8080 trying 80
11:03:29:WU01:FS00:Connecting to 171.64.65.41:80
11:03:49:WARNING:WU00:FS00:Exception: Failed to send results to work server: Failed to connect to 171.64.65.41:80: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.
11:03:50:WU00:FS00:Sending unit results: id:00 state:SEND error:FAILED project:11920 run:585 clone:4 gen:0 core:0xa7 unit:0x00000000ab4041295809c9803f34b30b
11:03:50:WU00:FS00:Connecting to 171.64.65.41:8080
11:04:11:WARNING:WU00:FS00:WorkServer connection failed on port 8080 trying 80
11:04:11:WU00:FS00:Connecting to 171.64.65.41:80
11:04:32:WARNING:WU00:FS00:Exception: Failed to send results to work server: Failed to connect to 171.64.65.41:80: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.
11:04:42:ERROR:WU01:FS00:Exception: 10002: Received short response, expected 512 bytes, got 0
11:04:42:WU01:FS00:Connecting to 171.67.108.45:8080
11:04:42:WU01:FS00:Assigned to work server 171.67.108.158
11:04:42:WU01:FS00:Requesting new work unit for slot 00: READY cpu:8 from 171.67.108.158
11:04:42:WU01:FS00:Connecting to 171.67.108.158:8080
11:04:43:WU01:FS00:Downloading 807.13KiB
11:04:43:WU01:FS00:Download complete
11:04:43:WU01:FS00:Received Unit: id:01 state:DOWNLOAD error:NO_ERROR project:9038 run:54 clone:0 gen:230 core:0xa4 unit:0x00000111ab436c9e56982a52854169e8
11:04:43:WU01:FS00:Starting
11:04:43:WU01:FS00:Running FahCore: "C:\Program Files\FAHClient/FAHCoreWrapper.exe" C:\ProgramData\FAHClient\cores/web.stanford.edu/~pande/Win32/AMD64/Core_a4.fah/FahCore_a4.exe -dir 01 -suffix 01 -version 704 -lifeline 7800 -checkpoint 15 -np 8
11:04:43:WU01:FS00:Started FahCore on PID 3424
11:04:43:WU01:FS00:Core PID:2580
11:04:43:WU01:FS00:FahCore 0xa4 started
11:04:44:WU01:FS00:0xa4:
11:04:44:WU01:FS00:0xa4:*------------------------------*
11:04:44:WU01:FS00:0xa4:Folding@Home Gromacs GB Core
11:04:44:WU01:FS00:0xa4:Version 2.27 (Dec. 15, 2010)
11:04:44:WU01:FS00:0xa4:Preparing to commence simulation
11:04:44:WU01:FS00:0xa4:- Looking at optimizations...
11:04:44:WU01:FS00:0xa4:- Created dyn
11:04:44:WU01:FS00:0xa4:- Files status OK
11:04:44:WU01:FS00:0xa4:- Expanded 825991 -> 1402860 (decompressed 169.8 percent)
11:04:44:WU01:FS00:0xa4:Called DecompressByteArray: compressed_data_size=825991 data_size=1402860, decompressed_data_size=1402860 diff=0
11:04:44:WU01:FS00:0xa4:- Digital signature verified
11:04:44:WU01:FS00:0xa4:Project: 9038 (Run 54, Clone 0, Gen 230)
11:04:44:WU01:FS00:0xa4:Assembly optimizations on if available.
11:04:44:WU01:FS00:0xa4:Entering M.D.
11:04:50:WU01:FS00:0xa4:Mapping NT from 8 to 8
11:04:50:WU01:FS00:0xa4:Completed 0 out of 250000 steps  (0%)
11:04:50:WU00:FS00:Sending unit results: id:00 state:SEND error:FAILED project:11920 run:585 clone:4 gen:0 core:0xa7 unit:0x00000000ab4041295809c9803f34b30b
11:04:50:WU00:FS00:Connecting to 171.64.65.41:8080
11:06:14:WU01:FS00:0xa4:Completed 2500 out of 250000 steps  (1%)
11:07:37:WU01:FS00:0xa4:Completed 5000 out of 250000 steps  (2%)
11:08:49:WU01:FS00:0xa4:Completed 7500 out of 250000 steps  (3%)
11:08:52:WU00:FS00:Server responded WORK_ACK (400)
11:08:52:WU00:FS00:Cleaning up
Re: FahCore_a7
Post by foldy »
<cpus v='48'/> Is this a problem? Should it be 3 slots with 16 threads each?
Nathan_P
Not currently folding
Re: FahCore_a7
Post by Nathan_P »
For A7, its not supposed to be a problem as the only a7 project out there is designed to make use of 32/48/64 threads
Re: FahCore_a7
When there discussions of multiple problems get intermixed, they get hard to follow. I've separated out one of those topics
Subject: FahCore_a7 doesn't work on Unsupported Linux distros (CentOS)
There are still multiple topics that are hard to unravel.
Forcinghavok
Re: FahCore_a7
Post by Forcinghavok »
Just curious, I had a problem with the same core, the system would say this core stopped working and would sometimes crash the system. Was this ever solved or was a solution ever provided?
thanks,
erik
Re: FahCore_a7
Forcinghavok wrote:Just curious, I had a problem with the same core, the system would say this core stopped working and would sometimes crash the system. Was this ever solved or was a solution ever provided?
thanks,
erik
Not yet, but information is being gathered here: viewtopic.php?f=72&t=29396
Flags?.
Kougar wrote:Quick aside, do any flags give preference for the AVX WUs or are those luck of the draw? Trying to keep my PPD above the EVGA monthly minimum with the Titan out of commission
luck of the draw ... but the projects that happen to be available based on your client-type setting at the time a new WU is requested.
Duce H_K_
Hardware configuration: MoBo◘Gigabye X99 UD4-CF F24s
CPU◘2680V4 🔥Rosetta/SIDock
RAM◘64GB Hynix 2400 CL15
HDD◘ST1000DM003 Sata3 NCQ
GFX◘Zotac X-Gaming RTX3070 🔥Folding
VALID x86 fr◘5nan6w
Re: FahCore_a7
Post by Duce H_K_ »
Don't know where to post it.
Number of Frames Observed: 98
Min. Time / Frame : 00:05:55 - 7 406,5 PPD
Avg. Time / Frame : 00:06:31 - 6 407,5 PPD
My system have been through 10 minute power-off and there was a user activity on folding machine. Any way PPD for p8663 is still not what I expected. Rest of the log survived:
*********************** Log Started 2017-01-26T18:42:49Z ***********************
18:42:49:************************* Folding@home Client *************************
18:42:49:        Website: http://folding.stanford.edu/
18:42:49:      Copyright: (c) 2009-2016 Stanford University
18:42:49:         Author: Joseph Coffland <joseph@cauldrondevelopment.com>
18:42:49:           Args:
18:42:49:         Config: E:\\Docbase\\FaH-workdir\\config.xml
18:42:49:******************************** Build ********************************
18:42:49:        Version: 7.4.15
18:42:49:           Date: Aug 17 2016
18:42:49:           Time: 04:33:41
18:42:49:     Repository: Git
18:42:49:       Revision: 4f3e0e25571a9f691719f0c273739294bde517dd
18:42:49:         Branch: master
18:42:49:       Compiler: GNU 5.3.1 20160205
18:42:49:        Options: -std=gnu++98 -I/mingw64/include -O3 -funroll-loops -ffast-math
18:42:49:                 -mfpmath=sse -fno-unsafe-math-optimizations -msse2
18:42:49:       Platform: linux2 4.6.0-1-amd64
18:42:49:           Bits: 64
18:42:49:           Mode: Release
18:42:49:******************************* System ********************************
18:42:49:            CPU: AMD A8-5600K APU with Radeon(tm) HD Graphics
18:42:49:         CPU ID: AuthenticAMD Family 21 Model 16 Stepping 1
18:42:49:           CPUs: 4
18:42:49:         Memory: 3.46GiB
18:42:49:    Free Memory: 2.37GiB
18:42:49:        Threads: WINDOWS_THREADS
18:42:49:     OS Version: 6.2
18:42:49:    Has Battery: false
18:42:49:     On Battery: false
18:42:49:     UTC Offset: 4
18:42:49:            PID: 1524
18:42:49:            CWD: E:\\Docbase\\FaH-workdir
18:42:49:             OS: Windows 8.1 Single Language
18:42:49:        OS Arch: AMD64
18:42:49:           GPUs: 2
18:42:49:          GPU 0: Bus:1 Slot:0 NVIDIA:5 GP104 [GeForce GTX 1070]
18:42:49:          GPU 1: Bus:0 Slot:1 ATI:5 Trinity [Radeon HD 7560D]
18:42:49:           CUDA: Not detected
18:42:49:OpenCL Device 0: Platform:0 Device:0 Bus:NA Slot:NA Compute:1.2 Driver:1445.5
18:42:49:OpenCL Device 1: Platform:0 Device:1 Bus:NA Slot:NA Compute:1.2 Driver:1445.5
18:42:49:  Win32 Service: false
[snip]
18:42:49:
18:42:49:  <!-- Logging -->
18:42:49:  <log v='log.txt'/>
18:42:49:  <log-color v='false'/>
18:42:49:  <log-crlf v='true'/>
18:42:49:  <log-date v='false'/>
18:42:49:  <log-date-periodically v='21600'/>
18:42:49:  <log-domain v='false'/>
18:42:49:  <log-header v='true'/>
18:42:49:  <log-level v='true'/>
18:42:49:  <log-no-info-header v='true'/>
18:42:49:  <log-redirect v='false'/>
18:42:49:  <log-rotate v='true'/>
18:42:49:  <log-rotate-dir v='logs'/>
18:42:49:  <log-rotate-max v='16'/>
18:42:49:  <log-short-level v='false'/>
18:42:49:  <log-simple-domains v='true'/>
18:42:49:  <log-thread-id v='false'/>
18:42:49:  <log-thread-prefix v='true'/>
18:42:49:  <log-time v='true'/>
18:42:49:  <log-to-screen v='true'/>
18:42:49:  <log-truncate v='false'/>
18:42:49:  <verbosity v='4'/>
18:42:49:
18:42:49:  <!-- Network -->
18:42:49:  <proxy v=':8080'/>
18:42:49:  <proxy-enable v='false'/>
18:42:49:  <proxy-pass v=''/>
18:42:49:  <proxy-user v=''/>
18:42:49:
18:42:49:  <!-- Process Control -->
18:42:49:  <child v='false'/>
18:42:49:  <daemon v='false'/>
18:42:49:  <pid v='false'/>
18:42:49:  <pid-file v='Folding@home Client.pid'/>
18:42:49:  <respawn v='false'/>
18:42:49:  <service v='false'/>
18:42:49:
18:42:49:  <!-- Remote Command Server -->
18:42:49:  <command-address v='0.0.0.0'/>
18:42:49:  <command-allow-no-pass v='127.0.0.1'/>
18:42:49:  <command-deny-no-pass v=''/>
18:42:49:  <command-enable v='true'/>
18:42:49:  <command-port v='7936'/>
18:42:49:  <password v='************'/>
18:42:49:
18:42:49:  <!-- Slot Control -->
18:42:49:  <idle v='false'/>
18:42:49:  <max-shutdown-wait v='60'/>
18:42:49:  <pause-on-battery v='false'/>
18:42:49:  <pause-on-start v='true'/>
18:42:49:  <paused v='false'/>
18:42:49:  <power v='full'/>
18:42:49:  <streaming v='false'/>
18:42:49:
18:42:49:  <!-- User Information -->
18:42:49:  <machine-id v='0'/>
18:42:49:  <passkey v='********************************'/>
18:42:49:  <team v='47191'/>
18:42:49:  <user v='Duce-HK_FLDC_1Hx5GNfGWkb6JxzvMeU6pWf141a1rjf8Pf'/>
18:42:49:
18:42:49:  <!-- Web Server -->
18:42:49:  <web-allow v='127.0.0.1'/>
18:42:49:  <web-deny v='0/0'/>
18:42:49:  <web-enable v='true'/>
18:42:49:
18:42:49:  <!-- Web Server Sessions -->
18:42:49:  <session-cookie v='sid'/>
18:42:49:  <session-lifetime v='86400'/>
18:42:49:  <session-timeout v='3600'/>
18:42:49:
18:42:49:  <!-- Work Unit Control -->
18:42:49:  <dump-after-deadline v='true'/>
18:42:49:  <max-queue v='16'/>
18:42:49:  <max-units v='0'/>
18:42:49:  <next-unit-percentage v='100'/>
18:42:49:  <stall-detection-enabled v='false'/>
18:42:49:  <stall-percent v='5'/>
18:42:49:  <stall-timeout v='1800'/>
18:42:49:
18:42:49:  <!-- Folding Slots -->
18:42:49:  <slot id='1' type='GPU'/>
18:42:49:  <slot id='0' type='CPU'>
18:42:49:    <client-type v='beta'/>
18:42:49:    <cpus v='4'/>
18:42:49:  </slot>
18:42:49:</config>
18:42:49:Trying to access database...
18:42:49:Successfully acquired database lock
18:42:49:Enabled folding slot 01: PAUSED gpu:0:GP104 [GeForce GTX 1070] (by user)
18:42:49:Enabled folding slot 00: PAUSED cpu:4 (by user)
18:42:49:ERROR:No compute devices matched GPU #0 NVIDIA:5 GP104 [GeForce GTX 1070].  You may need to update your graphics drivers.
18:43:04:FS00:Unpaused
18:43:04:WU00:FS00:Starting
18:43:04:WU00:FS00:Running FahCore: C:\\NO_UAC\\FAHClient_7.4.15_x64/FAHCoreWrapper.exe E:\\Docbase\\FaH-workdir\\cores/fahwebx.stanford.edu/cores/Win32/AMD64/AVX/beta/Core_a7.fah/FahCore_a7.exe -dir 00 -suffix 01 -version 704 -lifeline 1524 -checkpoint 6 -np 4 -forceasm -twait=80
18:43:04:WU00:FS00:Started FahCore on PID 2624
18:43:05:WU00:FS00:Core PID:1516
18:43:05:WU00:FS00:FahCore 0xa7 started
18:43:06:WU00:FS00:0xa7:*********************** Log Started 2017-01-26T18:43:06Z ***********************
18:43:06:WU00:FS00:0xa7:************************** Gromacs Folding@home Core ***************************
18:43:06:WU00:FS00:0xa7:       Type: 0xa7
18:43:06:WU00:FS00:0xa7:       Core: Gromacs
18:43:06:WU00:FS00:0xa7:    Website: http://folding.stanford.edu/
18:43:06:WU00:FS00:0xa7:  Copyright: (c) 2009-2016 Stanford University
18:43:06:WU00:FS00:0xa7:     Author: Joseph Coffland <joseph@cauldrondevelopment.com>
18:43:06:WU00:FS00:0xa7:       Args: -dir 00 -suffix 01 -version 704 -lifeline 2624 -checkpoint 6 -np 4
18:43:06:WU00:FS00:0xa7:             -forceasm -twait=80
18:43:06:WU00:FS00:0xa7:     Config: <none>
18:43:06:WU00:FS00:0xa7:************************************ Build *************************************
18:43:06:WU00:FS00:0xa7:    Version: 0.0.11
18:43:06:WU00:FS00:0xa7:       Date: Sep 21 2016
18:43:06:WU00:FS00:0xa7:       Time: 01:43:48
18:43:06:WU00:FS00:0xa7: Repository: Git
18:43:06:WU00:FS00:0xa7:   Revision: 957bd90e68d95ddcf1594dc15ff6c64cc4555146
18:43:06:WU00:FS00:0xa7:     Branch: master
18:43:06:WU00:FS00:0xa7:   Compiler: GNU 4.2.1 Compatible Clang 3.9.0 (trunk 274080)
18:43:06:WU00:FS00:0xa7:    Options: -std=gnu++98 -O3 -funroll-loops -ffast-math -mfpmath=sse
18:43:06:WU00:FS00:0xa7:             -fno-unsafe-math-optimizations -msse2 -I/mingw64/include
18:43:06:WU00:FS00:0xa7:             -Wno-inconsistent-dllimport -Wno-parentheses-equality
18:43:06:WU00:FS00:0xa7:             -Wno-deprecated-register -Wno-unused-local-typedef
18:43:06:WU00:FS00:0xa7:   Platform: linux2 4.6.0-1-amd64
18:43:06:WU00:FS00:0xa7:       Bits: 64
18:43:06:WU00:FS00:0xa7:       Mode: Release
18:43:06:WU00:FS00:0xa7:       SIMD: avx_256
18:43:06:WU00:FS00:0xa7:************************************ System ************************************
18:43:06:WU00:FS00:0xa7:        CPU: AMD A8-5600K APU with Radeon(tm) HD Graphics
18:43:06:WU00:FS00:0xa7:     CPU ID: AuthenticAMD Family 21 Model 16 Stepping 1
18:43:06:WU00:FS00:0xa7:       CPUs: 4
18:43:06:WU00:FS00:0xa7:     Memory: 3.46GiB
18:43:06:WU00:FS00:0xa7:Free Memory: 2.37GiB
18:43:06:WU00:FS00:0xa7:    Threads: WINDOWS_THREADS
18:43:06:WU00:FS00:0xa7: OS Version: 6.2
18:43:06:WU00:FS00:0xa7:Has Battery: false
18:43:06:WU00:FS00:0xa7: On Battery: false
18:43:06:WU00:FS00:0xa7: UTC Offset: 4
18:43:06:WU00:FS00:0xa7:        PID: 1516
18:43:06:WU00:FS00:0xa7:        CWD: E:\\Docbase\\FaH-workdir\\work
18:43:06:WU00:FS00:0xa7:         OS: Windows 8.1 Single Language
18:43:06:WU00:FS00:0xa7:    OS Arch: AMD64
18:43:06:WU00:FS00:0xa7:********************************************************************************
18:43:06:WU00:FS00:0xa7:Project: 8663 (Run 0, Clone 15, Gen 15)
18:43:06:WU00:FS00:0xa7:Unit: 0x000000170002894b5846e8198618c797
18:43:06:WU00:FS00:0xa7:Digital signatures verified
18:43:06:WU00:FS00:0xa7:Calling: mdrun -s frame15.tpr -o frame15.trr -cpi state.cpt -cpt 6 -nt 4
18:43:07:WU00:FS00:0xa7:Steps: first=18750000 total=1250000
18:43:08:WU00:FS00:0xa7:Completed 1053381 out of 1250000 steps (84%)
18:47:48:FS00:Finishing
18:47:49:WU00:FS00:0xa7:Completed 1062500 out of 1250000 steps (85%)
18:53:47:WU00:FS00:0xa7:Completed 1075000 out of 1250000 steps (86%)
18:59:42:WU00:FS00:0xa7:Completed 1087500 out of 1250000 steps (87%)
19:05:37:WU00:FS00:0xa7:Completed 1100000 out of 1250000 steps (88%)
19:11:32:WU00:FS00:0xa7:Completed 1112500 out of 1250000 steps (89%)
19:17:27:WU00:FS00:0xa7:Completed 1125000 out of 1250000 steps (90%)
19:23:22:WU00:FS00:0xa7:Completed 1137500 out of 1250000 steps (91%)
19:29:17:WU00:FS00:0xa7:Completed 1150000 out of 1250000 steps (92%)
19:35:13:WU00:FS00:0xa7:Completed 1162500 out of 1250000 steps (93%)
19:41:10:WU00:FS00:0xa7:Completed 1175000 out of 1250000 steps (94%)
19:47:11:WU00:FS00:0xa7:Completed 1187500 out of 1250000 steps (95%)
19:53:07:WU00:FS00:0xa7:Completed 1200000 out of 1250000 steps (96%)
19:59:02:WU00:FS00:0xa7:Completed 1212500 out of 1250000 steps (97%)
20:05:09:WU00:FS00:0xa7:Completed 1225000 out of 1250000 steps (98%)
20:11:35:WU00:FS00:0xa7:Completed 1237500 out of 1250000 steps (99%)
20:17:42:WU00:FS00:0xa7:Completed 1250000 out of 1250000 steps (100%)
20:17:44:WU00:FS00:0xa7:Saving result file ..\\logfile_01.txt
20:17:44:WU00:FS00:0xa7:Saving result file frame15.trr
20:17:45:WU00:FS00:0xa7:Saving result file md.log
20:17:45:WU00:FS00:0xa7:Saving result file science.log
20:17:45:WU00:FS00:0xa7:Saving result file traj_comp.xtc
20:17:45:WU00:FS00:0xa7:Folding@home Core Shutdown: FINISHED_UNIT
20:17:45:WU00:FS00:FahCore returned: FINISHED_UNIT (100 = 0x64)
20:17:46:WU00:FS00:Sending unit results: id:00 state:SEND error:NO_ERROR project:8663 run:0 clone:15 gen:15 core:0xa7 unit:0x000000170002894b5846e8198618c797
20:17:46:WU00:FS00:Uploading 2.46MiB to 155.247.166.219
20:17:46:WU00:FS00:Connecting to 155.247.166.219:8080
20:17:48:WU00:FS00:Upload complete
20:17:49:WU00:FS00:Server responded WORK_ACK (400)
20:17:49:WU00:FS00:Final credit estimate, 2866.00 points
20:17:49:WU00:FS00:Cleaning up
