Project: 8662 (Run 6, Clone 9, Gen 15)
davidcoton
Post by davidcoton »
First 3% OK (20 min per %), then runs s-l-o-w (90 min per %)
Pause and restart does not fix it
(There may be a system problem -- svchost is using a full CPU -- how do I tell what it is doing?)
Windows Vista on AMD Athlon II X4 640 3GHz 4GB
GPU apparently running normally
12:43:20:WU02:FS00:0xa4:Project: 8662 (Run 6, Clone 9, Gen 15)
12:43:20:WU02:FS00:0xa4:Assembly optimizations on if available.
12:43:20:WU02:FS00:0xa4:Entering M.D.
12:43:26:WU02:FS00:0xa4:Mapping NT from 3 to 3
12:43:26:WU02:FS00:0xa4:Completed 0 out of 2500000 steps  (0%)
13:04:17:WU02:FS00:0xa4:Completed 25000 out of 2500000 steps  (1%)
13:25:20:WU02:FS00:0xa4:Completed 50000 out of 2500000 steps  (2%)
13:49:37:WU02:FS00:0xa4:Completed 75000 out of 2500000 steps  (3%)
******************************* Date: 2016-10-14 *******************************
15:50:38:WU02:FS00:0xa4:Completed 100000 out of 2500000 steps  (4%)
18:33:02:WU02:FS00:0xa4:Completed 125000 out of 2500000 steps  (5%)
18:42:54:FS00:Paused
yunhui
Scientist
Re: Project: 8662 (Run 6, Clone 9, Gen 15)
Post by yunhui »
Hi davidcoton,
This is Yunhui. I prepared this project and during beta test period no one reported any error about this project. Could you please specify any error or warning information you got except running slowly? Thank you!
Yunhui
yunhui wrote:Could you please specify any error or warning information you got except running slowly? Thank you!
Yunhui
About the only thing you can do is recheck your benchmarking and see if current WUs are still close to the target for points-per-day
davidcoton
There were no error messages. Just highly erratic frame times.
Anything from about 20min to about 140min.
Here's the log (showing just times) after a pause/fold cycle -- I notice it's now at 99% , so only about an hour to go. :D
20:44:22:WU02:FS00:0xa4:Completed 150000 out of 2500000 steps  (6%)
23:17:03:WU02:FS00:0xa4:Completed 175000 out of 2500000 steps  (7%)
01:03:10:WU02:FS00:0xa4:Completed 200000 out of 2500000 steps  (8%)
02:21:32:WU02:FS00:0xa4:Completed 225000 out of 2500000 steps  (9%)
04:15:33:WU02:FS00:0xa4:Completed 250000 out of 2500000 steps  (10%)
05:49:06:WU02:FS00:0xa4:Completed 275000 out of 2500000 steps  (11%)
06:40:28:WU02:FS00:0xa4:Completed 300000 out of 2500000 steps  (12%)
07:34:08:WU02:FS00:0xa4:Completed 325000 out of 2500000 steps  (13%)
09:31:45:WU02:FS00:0xa4:Completed 350000 out of 2500000 steps  (14%)
12:55:00:WU02:FS00:0xa4:Completed 375000 out of 2500000 steps  (15%)
15:16:24:WU02:FS00:0xa4:Completed 400000 out of 2500000 steps  (16%)
17:34:59:WU02:FS00:0xa4:Completed 425000 out of 2500000 steps  (17%)
18:53:36:WU02:FS00:0xa4:Completed 450000 out of 2500000 steps  (18%)
20:40:31:WU02:FS00:0xa4:Completed 475000 out of 2500000 steps  (19%)
23:33:27:WU02:FS00:0xa4:Completed 500000 out of 2500000 steps  (20%)
00:20:01:WU02:FS00:0xa4:Completed 525000 out of 2500000 steps  (21%)
01:20:52:WU02:FS00:0xa4:Completed 550000 out of 2500000 steps  (22%)
02:44:07:WU02:FS00:0xa4:Completed 575000 out of 2500000 steps  (23%)
04:02:51:WU02:FS00:0xa4:Completed 600000 out of 2500000 steps  (24%)
05:04:05:WU02:FS00:0xa4:Completed 625000 out of 2500000 steps  (25%)
06:14:25:WU02:FS00:0xa4:Completed 650000 out of 2500000 steps  (26%)
07:42:50:WU02:FS00:0xa4:Completed 675000 out of 2500000 steps  (27%)
08:23:03:WU02:FS00:0xa4:Completed 700000 out of 2500000 steps  (28%)
08:45:46:WU02:FS00:0xa4:Completed 725000 out of 2500000 steps  (29%)
09:08:19:WU02:FS00:0xa4:Completed 750000 out of 2500000 steps  (30%)
09:30:54:WU02:FS00:0xa4:Completed 775000 out of 2500000 steps  (31%)
09:52:13:WU02:FS00:0xa4:Completed 800000 out of 2500000 steps  (32%)
10:12:49:WU02:FS00:0xa4:Completed 825000 out of 2500000 steps  (33%)
10:34:02:WU02:FS00:0xa4:Completed 850000 out of 2500000 steps  (34%)
10:56:50:WU02:FS00:0xa4:Completed 875000 out of 2500000 steps  (35%)
11:20:24:WU02:FS00:0xa4:Completed 900000 out of 2500000 steps  (36%)
11:48:24:WU02:FS00:0xa4:Completed 925000 out of 2500000 steps  (37%)
12:09:19:WU02:FS00:0xa4:Completed 950000 out of 2500000 steps  (38%)
12:50:55:WU02:FS00:0xa4:Completed 975000 out of 2500000 steps  (39%)
13:14:25:WU02:FS00:0xa4:Completed 1000000 out of 2500000 steps  (40%)
13:46:30:WU02:FS00:0xa4:Completed 1025000 out of 2500000 steps  (41%)
14:10:40:WU02:FS00:0xa4:Completed 1050000 out of 2500000 steps  (42%)
14:33:26:WU02:FS00:0xa4:Completed 1075000 out of 2500000 steps  (43%)
14:54:55:WU02:FS00:0xa4:Completed 1100000 out of 2500000 steps  (44%)
15:15:35:WU02:FS00:0xa4:Completed 1125000 out of 2500000 steps  (45%)
15:38:55:WU02:FS00:0xa4:Completed 1150000 out of 2500000 steps  (46%)
16:01:54:WU02:FS00:0xa4:Completed 1175000 out of 2500000 steps  (47%)
16:24:36:WU02:FS00:0xa4:Completed 1200000 out of 2500000 steps  (48%)
16:47:28:WU02:FS00:0xa4:Completed 1225000 out of 2500000 steps  (49%)
17:09:49:WU02:FS00:0xa4:Completed 1250000 out of 2500000 steps  (50%)
17:32:05:WU02:FS00:0xa4:Completed 1275000 out of 2500000 steps  (51%)
17:53:36:WU02:FS00:0xa4:Completed 1300000 out of 2500000 steps  (52%)
18:16:29:WU02:FS00:0xa4:Completed 1325000 out of 2500000 steps  (53%)
18:39:50:WU02:FS00:0xa4:Completed 1350000 out of 2500000 steps  (54%)
19:02:43:WU02:FS00:0xa4:Completed 1375000 out of 2500000 steps  (55%)
19:24:42:WU02:FS00:0xa4:Completed 1400000 out of 2500000 steps  (56%)
19:46:28:WU02:FS00:0xa4:Completed 1425000 out of 2500000 steps  (57%)
20:11:01:WU02:FS00:0xa4:Completed 1450000 out of 2500000 steps  (58%)
20:34:49:WU02:FS00:0xa4:Completed 1475000 out of 2500000 steps  (59%)
20:59:45:WU02:FS00:0xa4:Completed 1500000 out of 2500000 steps  (60%)
21:23:40:WU02:FS00:0xa4:Completed 1525000 out of 2500000 steps  (61%)
21:45:10:WU02:FS00:0xa4:Completed 1550000 out of 2500000 steps  (62%)
22:07:29:WU02:FS00:0xa4:Completed 1575000 out of 2500000 steps  (63%)
22:30:13:WU02:FS00:0xa4:Completed 1600000 out of 2500000 steps  (64%)
22:52:58:WU02:FS00:0xa4:Completed 1625000 out of 2500000 steps  (65%)
23:15:46:WU02:FS00:0xa4:Completed 1650000 out of 2500000 steps  (66%)
23:37:09:WU02:FS00:0xa4:Completed 1675000 out of 2500000 steps  (67%)
23:59:25:WU02:FS00:0xa4:Completed 1700000 out of 2500000 steps  (68%)
00:20:45:WU02:FS00:0xa4:Completed 1725000 out of 2500000 steps  (69%)
00:42:31:WU02:FS00:0xa4:Completed 1750000 out of 2500000 steps  (70%)
01:07:00:WU02:FS00:0xa4:Completed 1775000 out of 2500000 steps  (71%)
01:29:45:WU02:FS00:0xa4:Completed 1800000 out of 2500000 steps  (72%)
01:52:23:WU02:FS00:0xa4:Completed 1825000 out of 2500000 steps  (73%)
02:17:10:WU02:FS00:0xa4:Completed 1850000 out of 2500000 steps  (74%)
02:40:27:WU02:FS00:0xa4:Completed 1875000 out of 2500000 steps  (75%)
03:01:16:WU02:FS00:0xa4:Completed 1900000 out of 2500000 steps  (76%)
03:22:00:WU02:FS00:0xa4:Completed 1925000 out of 2500000 steps  (77%)
03:53:17:WU02:FS00:0xa4:Completed 1950000 out of 2500000 steps  (78%)
06:21:55:WU02:FS00:0xa4:Completed 1975000 out of 2500000 steps  (79%)
10:56:55:WU02:FS00:0xa4:Completed 2000000 out of 2500000 steps  (80%)
13:02:11:WU02:FS00:0xa4:Completed 2025000 out of 2500000 steps  (81%)
15:18:24:WU02:FS00:0xa4:Completed 2050000 out of 2500000 steps  (82%)
16:48:07:WU02:FS00:0xa4:Completed 2075000 out of 2500000 steps  (83%)
17:52:31:WU02:FS00:0xa4:Completed 2100000 out of 2500000 steps  (84%)
22:02:06:WU02:FS00:0xa4:Completed 2125000 out of 2500000 steps  (85%)
23:25:04:WU02:FS00:0xa4:Completed 2150000 out of 2500000 steps  (86%)
01:25:20:WU02:FS00:0xa4:Completed 2175000 out of 2500000 steps  (87%)
04:35:36:WU02:FS00:0xa4:Completed 2200000 out of 2500000 steps  (88%)
06:04:14:WU02:FS00:0xa4:Completed 2225000 out of 2500000 steps  (89%)
07:47:33:WU02:FS00:0xa4:Completed 2250000 out of 2500000 steps  (90%)
08:29:30:WU02:FS00:0xa4:Completed 2275000 out of 2500000 steps  (91%)
10:14:15:WU02:FS00:0xa4:Completed 2300000 out of 2500000 steps  (92%)
11:08:04:WU02:FS00:0xa4:Completed 2325000 out of 2500000 steps  (93%)
12:35:09:WU02:FS00:0xa4:Completed 2350000 out of 2500000 steps  (94%)
14:25:08:WU02:FS00:0xa4:Completed 2375000 out of 2500000 steps  (95%)
14:55:44:WU02:FS00:0xa4:Completed 2400000 out of 2500000 steps  (96%)
15:54:17:WU02:FS00:0xa4:Completed 2425000 out of 2500000 steps  (97%)
16:52:56:WU02:FS00:0xa4:Completed 2450000 out of 2500000 steps  (98%)
18:24:16:WU02:FS00:0xa4:Completed 2475000 out of 2500000 steps  (99%)
How many of your CPU threads are free of contention by other applications? (hint: Show the top of your log for this system)
davidcoton
Hmm, same system is now showing similar behaviour on a WU from a different project (9033). I will try a reboot sometime, but for reasons not this week.
Running CPU:4 plus GPU on a four processor AMD, not a dedicated rig, but I haven't noticed this behaviour before. I think some process had gone rogue (svchost high CPU) but that doesn't appear to be so now -- CoreA4 is getting 66% to 75% as it should, but frame time is also normal just now.
