No CPU use
No CPU use
Just installed the client on my new dual CPU workstation. Two GPU clients started up fine, but the CPU slot just shows 'ready'
Any ideas on why the CPU slot won't work?
Re: No CPU use
Too little information to say for sure, but the most likely reason is a default setting resulting in an CPU thread count that will not get assignments. Currently the servers will assign to counts that are multiples of 2 and/or 3 and sometimes 5. Most other multiples of primes greater than 5 are excluded. For very large core counts the number may need to be reduced, and possibly more than one CPU slot be defined to use all CPU cores available.
If you post the first 100 or so lines of your log file that shows system and client setup information using the directions in the Welcome topic, we can give more specific recommendations.
Re: No CPU use
Figured it out...I needed to define the number of threads... 2 less than the max. works now!
Re: No CPU use
We'd still like to see the (older?) log showing the failure, in case somebody else runs into the same problem.
Re: No CPU use
I got mine to work again by deleting the CPU slot and making a new one, the only issue now is that under "Full" my PC is lagging really hard currently- the text I am typing is actually experiencing a delay. This never happened before, even running at full?
Re: No CPU use
Welcome to foldingforum.org, stonedboss.
We need to see the log. See the signature block of my previous post.
Re: No CPU use
My CPU does not fold due to a down server. Not a big deal for me I will just use my GPU. It keeps trying the same server over and over hopefully it helps though.
01:45:10:WU00:FS00:Connecting to 171.67.108.45:8080
01:45:10:WARNING:WU00:FS00:Failed to get assignment from '171.67.108.45:8080': Empty work server assignment
01:45:10:WU00:FS00:Connecting to 171.64.65.35:80
01:45:11:WARNING:WU00:FS00:Failed to get assignment from '171.64.65.35:80': Empty work server assignment
01:45:11:ERROR:WU00:FS00:Exception: Could not get an assignment
Re: No CPU use
How many CPU threads are you requesting WU's for BIG_RED? Unless your system has a very large number, or just one CPU thread, then there is CPU work. The two servers shown in the very brief section of log are Assignment Servers, they are just indicating there is no match to a WS at your current CPU setting. As I wrote in my response above, currently the number of CPU threads requested needs to be a multiple of 2, 3 and/or 5. Multiples of other larger primes are not currently available, and likely will not be in the future.
Re: No CPU use
I don't have anything telling it how many threads it request in the logs I left those settings on default. The settings I have now worked last time I tried to run the client when it was cold.
Configure Expert only has pause-on-start true, open-web-control true, and client-type advanced.
System Info has CPUs 12
When I go to the Configure folding slot it has -1 which is "-1 let the client choose"
config part of log.
20:55:52:<config>
20:55:52: <!-- Folding Core -->
20:55:52: <core-priority v='low'/>
20:55:52:
20:55:52: <!-- Folding Slot Configuration -->
20:55:52: <client-type v='advanced'/>
20:55:52:
20:55:52: <!-- Network -->
20:55:52: <proxy v=':8080'/>
20:55:52:
20:55:52: <!-- Slot Control -->
20:55:52: <pause-on-battery v='false'/>
20:55:52: <pause-on-start v='true'/>
20:55:52: <power v='FULL'/>
20:55:52:
20:55:52: <!-- User Information -->
20:55:52: <passkey v='********************************'/>
20:55:52: <team v='xxxx'/>
20:55:52: <user v='xx'/>
20:55:52:
20:55:52: <!-- Folding Slots -->
20:55:52: <slot id='0' type='CPU'/>
20:55:52: <slot id='1' type='GPU'/>
20:55:52:</config>
20:56:15:Removing old file 'configs/config-20160119-223006.xml'
20:56:15:Saving configuration to config.xml
20:56:15:<config>
20:56:15: <!-- Folding Slot Configuration -->
20:56:15: <cause v='ALZHEIMERS'/>
20:56:15: <client-type v='advanced'/>
20:56:15:
20:56:15: <!-- Network -->
20:56:15: <proxy v=':8080'/>
20:56:15:
20:56:15: <!-- Slot Control -->
20:56:15: <pause-on-battery v='false'/>
20:56:15: <pause-on-start v='true'/>
20:56:15: <power v='FULL'/>
20:56:15:
20:56:15: <!-- User Information -->
20:56:15: <passkey v='********************************'/>
20:56:15: <team v='xxxx'/>
20:56:15: <user v='xxxx'/>
20:56:15:
20:56:15: <!-- Folding Slots -->
20:56:15: <slot id='0' type='CPU'/>
20:56:15: <slot id='1' type='GPU'/>
20:56:15:</config>
20:56:37:Removing old file 'configs/config-20160202-195421.xml'
20:56:37:Saving configuration to config.xml
20:56:37:<config>
20:56:37: <!-- Folding Slot Configuration -->
20:56:37: <cause v='ALZHEIMERS'/>
20:56:37: <client-type v='advanced'/>
20:56:37:
20:56:37: <!-- Network -->
20:56:37: <proxy v=':8080'/>
20:56:37:
20:56:37: <!-- Slot Control -->
20:56:37: <pause-on-battery v='false'/>
20:56:37: <pause-on-start v='true'/>
20:56:37: <power v='FULL'/>
20:56:37:
20:56:37: <!-- User Information -->
20:56:37: <passkey v='********************************'/>
20:56:37: <team v='xxxxx'/>
20:56:37: <user v='xxxxx'/>
20:56:37:
20:56:37: <!-- Folding Slots -->
20:56:37: <slot id='0' type='CPU'/>
20:56:37: <slot id='1' type='GPU'/>
20:56:37:</config>
config part of log.
20:55:52:<config>
20:55:52:
20:55:52:
20:55:52:
20:55:52:
20:55:52:
20:55:52:</config>
20:56:15:<config>
20:56:15:
20:56:15:
20:56:15:
20:56:15:
20:56:15:</config>
20:56:37:<config>
20:56:37:
20:56:37:
20:56:37:
20:56:37:
20:56:37:</config>
Re: No CPU use
Change the number of CPUs slots to 12 in Configure folding slot to 12 and it worked. Not sure if this is a change in what the defaults need to be or what but the "-1 lets the client choose" is still there.
Re: No CPU use
You didn't include the first part of the log (or the information from the System Info tab) so I have to assume your GPU slot is functional. In the V7.4.4 client, the default of -1 will assign CPU:11 which will not get assignments. Setting 12 is likely to reduce the throughput of your GPU slot which will cost more than reducing the CPU count to an acceptable falue. Manually setting it to 9 (or maybe 10) would be better.BIG_RED wrote:Change the number of CPUs slots to 12 in Configure folding slot to 12 and it worked. Not sure if this is a change in what the defaults need to be or what but the "-1 lets the client choose" is still there.
Re: No CPU use
I posted all relevant information CPU 12 in system tab and default on slot threads (which is showing that it is default by lack of <cpus v='xx'/> in the config settings I posted). I also said that I would just use the GPU so no assumptions needed. The requirements for the assignments changed before the beta was released that looks like it fixes the issue. A new user should not be expected to go into special settings to get the client to work correctly. Hopefully the Beta will be released sooner rather than latter but I understand that the beta will be released full build when it is released. I never expect a launch date to be set since the google compute days.bruce wrote:
As far as the CPU client I set it back to default if they are ok with that setting by telling it-1 is going to be the default then it is ok by me. My CPU just won't fold until a public release fixes it no big deal.
Re: No CPU use
If it were my system (and unless you choose to run the beta client), I'd set the CPU count to 9 and run the CPU client. After upgrading the client (to V7.4.15 or later), the new client is going to do something like that for everyone who uses the -1 setting.
Re: No CPU use
I just noticed that my CPU is also without assignment. It had 30 attempts, and everything regarding work server, collection sever, and job assignment consisted of nothing but zeros. Given the number of attempts, and the fact that the wait time between attempts had grown somewhere near two hours between them, I can only imagine it has been close to a day since this project of zeros started, probably sometime yesterday. I tried removing the CPU slot, then replacing it, but it came back to all zeros. Is there some way to get out of this mess?
_________________________________________________________________________________________________________
Is it the number of threads being odd, instead of even, that makes this unstable? I could switch to 12 threads if that might help.
Mod edit: added Code tags to log listing - available from the posting Full Editor
*********************** Log Started 2016-10-18T12:43:01Z ***********************
12:44:13:WARNING:WU00:FS00:FahCore returned: UNSTABLE_MACHINE (122 = 0x7a)
12:44:13:WARNING:WU00:FS00:Failed to get assignment from '171.67.108.45:8080': Empty work server assignment
12:44:14:WARNING:WU00:FS00:Failed to get assignment from '171.64.65.35:80': Empty work server assignment
12:44:14:ERROR:WU00:FS00:Exception: Could not get an assignment
12:44:14:WARNING:WU00:FS00:Failed to get assignment from '171.67.108.45:8080': Empty work server assignment
12:45:14:WARNING:WU00:FS00:Failed to get assignment from '171.67.108.45:8080': Empty work server assignment
12:45:14:WARNING:WU00:FS00:Failed to get assignment from '171.64.65.35:80': Empty work server assignment
12:45:14:ERROR:WU00:FS00:Exception: Could not get an assignment
12:46:51:WARNING:WU00:FS00:Failed to get assignment from '171.67.108.45:8080': Empty work server assignment
12:46:52:WARNING:WU00:FS00:Failed to get assignment from '171.64.65.35:80': Empty work server assignment
12:46:52:ERROR:WU00:FS00:Exception: Could not get an assignment
12:48:09:WARNING:WU00:FS00:Changed SMP threads from 12 to 13 this can cause some work units to fail
14:05:45:WARNING:WU04:FS00:Failed to get assignment from '171.67.108.45:8080': Empty work server assignment
14:05:45:WARNING:WU04:FS00:Failed to get assignment from '171.64.65.35:80': Empty work server assignment
14:05:45:ERROR:WU04:FS00:Exception: Could not get an assignment
14:05:46:WARNING:WU04:FS00:Failed to get assignment from '171.67.108.45:8080': Empty work server assignment
14:05:46:WARNING:WU04:FS00:Failed to get assignment from '171.64.65.35:80': Empty work server assignment
14:05:46:ERROR:WU04:FS00:Exception: Could not get an assignment
14:06:46:WARNING:WU04:FS00:Failed to get assignment from '171.67.108.45:8080': Empty work server assignment
14:06:46:WARNING:WU04:FS00:Failed to get assignment from '171.64.65.35:80': Empty work server assignment
14:06:46:ERROR:WU04:FS00:Exception: Could not get an assignment
14:08:23:WARNING:WU04:FS00:Failed to get assignment from '171.67.108.45:8080': Empty work server assignment
14:08:23:WARNING:WU04:FS00:Failed to get assignment from '171.64.65.35:80': Empty work server assignment
14:08:23:ERROR:WU04:FS00:Exception: Could not get an assignment
14:11:00:WARNING:WU04:FS00:Failed to get assignment from '171.67.108.45:8080': Empty work server assignment
14:11:00:WARNING:WU04:FS00:Failed to get assignment from '171.64.65.35:80': Empty work server assignment
14:11:00:ERROR:WU04:FS00:Exception: Could not get an assignment
14:15:15:WARNING:WU04:FS00:Failed to get assignment from '171.67.108.45:8080': Empty work server assignment
14:15:15:WARNING:WU04:FS00:Failed to get assignment from '171.64.65.35:80': Empty work server assignment
14:15:15:ERROR:WU04:FS00:Exception: Could not get an assignment
14:22:06:WARNING:WU04:FS00:Failed to get assignment from '171.67.108.45:8080': Empty work server assignment
14:22:06:WARNING:WU04:FS00:Failed to get assignment from '171.64.65.35:80': Empty work server assignment
14:22:06:ERROR:WU04:FS00:Exception: Could not get an assignment
14:33:11:WARNING:WU04:FS00:Failed to get assignment from '171.67.108.45:8080': Empty work server assignment
14:33:12:WARNING:WU04:FS00:Failed to get assignment from '171.64.65.35:80': Empty work server assignment
14:33:12:ERROR:WU04:FS00:Exception: Could not get an assignment
14:51:08:WARNING:WU04:FS00:Failed to get assignment from '171.67.108.45:8080': Empty work server assignment
14:51:08:WARNING:WU04:FS00:Failed to get assignment from '171.64.65.35:80': Empty work server assignment
14:51:08:ERROR:WU04:FS00:Exception: Could not get an assignment
15:20:10:WARNING:WU04:FS00:Failed to get assignment from '171.67.108.45:8080': Empty work server assignment
15:20:11:WARNING:WU04:FS00:Failed to get assignment from '171.64.65.35:80': Empty work server assignment
15:20:11:ERROR:WU04:FS00:Exception: Could not get an assignment
16:07:09:WARNING:WU04:FS00:Failed to get assignment from '171.67.108.45:8080': Empty work server assignment
16:07:10:WARNING:WU04:FS00:Failed to get assignment from '171.64.65.35:80': Empty work server assignment
16:07:10:ERROR:WU04:FS00:Exception: Could not get an assignment
17:23:10:WARNING:WU04:FS00:Failed to get assignment from '171.67.108.45:8080': Empty work server assignment
17:23:10:WARNING:WU04:FS00:Failed to get assignment from '171.64.65.35:80': Empty work server assignment
17:23:10:ERROR:WU04:FS00:Exception: Could not get an assignment
******************************* Date: 2016-10-18 *******************************
19:26:10:WARNING:WU04:FS00:Failed to get assignment from '171.67.108.45:8080': Empty work server assignment
19:26:10:WARNING:WU04:FS00:Failed to get assignment from '171.64.65.35:80': Empty work server assignment
19:26:10:ERROR:WU04:FS00:Exception: Could not get an assignment
22:45:10:WARNING:WU04:FS00:Failed to get assignment from '171.67.108.45:8080': Empty work server assignment
22:45:10:WARNING:WU04:FS00:Failed to get assignment from '171.64.65.35:80': Empty work server assignment
22:45:10:ERROR:WU04:FS00:Exception: Could not get an assignment
******************************* Date: 2016-10-19 *******************************
01:18:57:WARNING:WU04:FS00:Failed to get assignment from '171.67.108.45:8080': Empty work server assignment
01:18:58:WARNING:WU04:FS00:Failed to get assignment from '171.64.65.35:80': Empty work server assignment
01:18:58:ERROR:WU04:FS00:Exception: Could not get an assignment
01:20:35:WARNING:WU04:FS00:Failed to get assignment from '171.67.108.45:8080': Empty work server assignment
01:20:35:WARNING:WU04:FS00:Failed to get assignment from '171.64.65.35:80': Empty work server assignment
01:20:35:ERROR:WU04:FS00:Exception: Could not get an assignment
01:23:12:WARNING:WU04:FS00:Failed to get assignment from '171.67.108.45:8080': Empty work server assignment
01:23:13:WARNING:WU04:FS00:Failed to get assignment from '171.64.65.35:80': Empty work server assignment
01:23:13:ERROR:WU04:FS00:Exception: Could not get an assignment
01:27:26:WARNING:WU04:FS00:Failed to get assignment from '171.67.108.45:8080': Empty work server assignment
01:27:27:WARNING:WU04:FS00:Failed to get assignment from '171.64.65.35:80': Empty work server assignment
01:27:27:ERROR:WU04:FS00:Exception: Could not get an assignment
01:34:18:WARNING:WU04:FS00:Failed to get assignment from '171.67.108.45:8080': Empty work server assignment
01:34:18:WARNING:WU04:FS00:Failed to get assignment from '171.64.65.35:80': Empty work server assignment
01:34:18:ERROR:WU04:FS00:Exception: Could not get an assignment
01:45:23:WARNING:WU04:FS00:Failed to get assignment from '171.67.108.45:8080': Empty work server assignment
01:45:24:WARNING:WU04:FS00:Failed to get assignment from '171.64.65.35:80': Empty work server assignment
01:45:24:ERROR:WU04:FS00:Exception: Could not get an assignment
02:03:20:WARNING:WU04:FS00:Failed to get assignment from '171.67.108.45:8080': Empty work server assignment
02:03:21:WARNING:WU04:FS00:Failed to get assignment from '171.64.65.35:80': Empty work server assignment
02:03:21:ERROR:WU04:FS00:Exception: Could not get an assignment
02:32:22:WARNING:WU04:FS00:Failed to get assignment from '171.67.108.45:8080': Empty work server assignment
02:32:23:WARNING:WU04:FS00:Failed to get assignment from '171.64.65.35:80': Empty work server assignment
02:32:23:ERROR:WU04:FS00:Exception: Could not get an assignment
03:19:21:WARNING:WU04:FS00:Failed to get assignment from '171.67.108.45:8080': Empty work server assignment
03:19:22:WARNING:WU04:FS00:Failed to get assignment from '171.64.65.35:80': Empty work server assignment
03:19:22:ERROR:WU04:FS00:Exception: Could not get an assignment
04:35:23:WARNING:WU04:FS00:Failed to get assignment from '171.67.108.45:8080': Empty work server assignment
04:35:23:WARNING:WU04:FS00:Failed to get assignment from '171.64.65.35:80': Empty work server assignment
04:35:23:ERROR:WU04:FS00:Exception: Could not get an assignment
06:38:22:WARNING:WU04:FS00:Failed to get assignment from '171.67.108.45:8080': Empty work server assignment
06:38:23:WARNING:WU04:FS00:Failed to get assignment from '171.64.65.35:80': Empty work server assignment
06:38:23:ERROR:WU04:FS00:Exception: Could not get an assignment
09:57:23:WARNING:WU04:FS00:Failed to get assignment from '171.67.108.45:8080': Empty work server assignment
09:57:23:WARNING:WU04:FS00:Failed to get assignment from '171.64.65.35:80': Empty work server assignment
09:57:23:ERROR:WU04:FS00:Exception: Could not get an assignment
15:19:23:WARNING:WU04:FS00:Failed to get assignment from '171.67.108.45:8080': Empty work server assignment
15:19:23:WARNING:WU04:FS00:Failed to get assignment from '171.64.65.35:80': Empty work server assignment
15:19:23:ERROR:WU04:FS00:Exception: Could not get an assignment
21:19:23:WARNING:WU04:FS00:Failed to get assignment from '171.67.108.45:8080': Empty work server assignment
21:19:23:WARNING:WU04:FS00:Failed to get assignment from '171.64.65.35:80': Empty work server assignment
21:19:23:ERROR:WU04:FS00:Exception: Could not get an assignment
******************************* Date: 2016-10-20 *******************************
03:19:23:WARNING:WU04:FS00:Failed to get assignment from '171.67.108.45:8080': Empty work server assignment
03:19:23:WARNING:WU04:FS00:Failed to get assignment from '171.64.65.35:80': Empty work server assignment
03:19:23:ERROR:WU04:FS00:Exception: Could not get an assignment
09:19:23:WARNING:WU04:FS00:Failed to get assignment from '171.67.108.45:8080': Empty work server assignment
09:19:23:WARNING:WU04:FS00:Failed to get assignment from '171.64.65.35:80': Empty work server assignment
09:19:23:ERROR:WU04:FS00:Exception: Could not get an assignment
19:33:02:WARNING:WU04:FS00:Failed to get assignment from '171.67.108.45:8080': Empty work server assignment
19:33:02:WARNING:WU04:FS00:Failed to get assignment from '171.64.65.35:80': Empty work server assignment
19:33:02:ERROR:WU04:FS00:Exception: Could not get an assignment
19:34:02:WARNING:WU04:FS00:Failed to get assignment from '171.67.108.45:8080': Empty work server assignment
19:34:02:WARNING:WU04:FS00:Failed to get assignment from '171.64.65.35:80': Empty work server assignment
19:34:02:ERROR:WU04:FS00:Exception: Could not get an assignment
19:35:02:WARNING:WU04:FS00:Failed to get assignment from '171.67.108.45:8080': Empty work server assignment
19:35:02:WARNING:WU04:FS00:Failed to get assignment from '171.64.65.35:80': Empty work server assignment
19:35:02:ERROR:WU04:FS00:Exception: Could not get an assignment
19:36:02:WARNING:WU04:FS00:Failed to get assignment from '171.67.108.45:8080': Empty work server assignment
19:36:03:WARNING:WU04:FS00:Failed to get assignment from '171.64.65.35:80': Empty work server assignment
19:36:03:ERROR:WU04:FS00:Exception: Could not get an assignment
19:37:34:WARNING:WU01:FS00:Failed to get assignment from '171.67.108.45:8080': Empty work server assignment
19:37:34:WARNING:WU01:FS00:Failed to get assignment from '171.64.65.35:80': Empty work server assignment
19:37:34:ERROR:WU01:FS00:Exception: Could not get an assignment
19:37:35:WARNING:WU01:FS00:Failed to get assignment from '171.67.108.45:8080': Empty work server assignment
19:37:35:WARNING:WU01:FS00:Failed to get assignment from '171.64.65.35:80': Empty work server assignment
19:37:35:ERROR:WU01:FS00:Exception: Could not get an assignment
19:38:35:WARNING:WU01:FS00:Failed to get assignment from '171.67.108.45:8080': Empty work server assignment
19:38:35:WARNING:WU01:FS00:Failed to get assignment from '171.64.65.35:80': Empty work server assignment
19:38:35:ERROR:WU01:FS00:Exception: Could not get an assignment
19:40:13:WARNING:WU01:FS00:Failed to get assignment from '171.67.108.45:8080': Empty work server assignment
19:40:14:WARNING:WU01:FS00:Failed to get assignment from '171.64.65.35:80': Empty work server assignment
19:40:14:ERROR:WU01:FS00:Exception: Could not get an assignment
19:42:49:WARNING:WU01:FS00:Failed to get assignment from '171.67.108.45:8080': Empty work server assignment
19:42:50:WARNING:WU01:FS00:Failed to get assignment from '171.64.65.35:80': Empty work server assignment
19:42:50:ERROR:WU01:FS00:Exception: Could not get an assignment
19:47:04:WARNING:WU01:FS00:Failed to get assignment from '171.67.108.45:8080': Empty work server assignment
19:47:04:WARNING:WU01:FS00:Failed to get assignment from '171.64.65.35:80': Empty work server assignment
19:47:04:ERROR:WU01:FS00:Exception: Could not get an assignment
19:53:55:WARNING:WU01:FS00:Failed to get assignment from '171.67.108.45:8080': Empty work server assignment
19:53:55:WARNING:WU01:FS00:Failed to get assignment from '171.64.65.35:80': Empty work server assignment
19:53:55:ERROR:WU01:FS00:Exception: Could not get an assignment
Re: No CPU use
The issue is with CPU thread setting that are multiples of larger prime numbers. In the past that was any prime 11 or greater, and some projects also excluded multiples of 7. In the past couple years, most projects that could use multiples of 7 have finished, and some projects have been identified that have problems with multiples of 5.
If you have a GPU folding, you need to reserve a CPU core for that folding slot. Then set the CPU thread count to a multiple of 2 and/or 3. A multiple of 5 might or might not get an assignment, it depends on which projects are currently active.
