P4@2.8 plus GTX960/ATI380, will it fold?
antropofob
Greetings,
I just got an P4 2.8HT with 2GB RAM rig so I was wondering if I could put something like GTX960/ATI380 inside and fold away?
It has Enermax 380W PSU inside, so I guess it would cope with 150W GPU?
Thanks!
Thanks!
Re: P4@2.8 plus GTX960/ATI380, will it fold?
Which Operating System is on this machine?
That's in my opinion the only thing that may prevent you from folding.
antropofob
Mint XFCE.Sven wrote:Which Operating System is on this machine?
I guess Linux is the way to go?
The PSU is 350W with 26A@12V (http://www.newegg.com/Product/Product.a ... 6817103455), so with P4@2.8, and only GPU folding, do you guys think that GTX960 would be overkill consumption-wise?
Also MB has PCIe x16 slot, so no problems there I guess?
You need an adapter cable if your gtx960 has an extra power plug, 4pin molex to 6pin gpu.
The PCIe x16 slot has a gen and speed e.g. gen2 x4, if it is too low then it will slwo down the gtx 960
I have no personal experience but I feel this rig is too old and you want a little newer one.
Foxbat
- Hardware configuration: Apple Mac Pro 1,1 2x2.66 GHz Dual-Core Xeon w/10 GB RAM | EVGA GTX 960, Zotac GTX 750 Ti | Ubuntu 14.04 LTS
Dell Precision T7400 2x3.0 GHz Quad-Core Xeon w/16 GB RAM | Zotac GTX 970 | Ubuntu 14.04 LTS
Apple iMac Retina 5K 4.00 GHz Core i7 w/8 GB RAM | OS X 10.11.3 (El Capitan) - Location: Michiana, USA
I have a 2006-era Mac Pro running at 2.66 GHz and a GTX 970 card inside. It does the job, although don't expect much from a CPU slot. But the PCI-e x16 slot is Gen 1 and it still cranks out around 300K PPD on average.
Instead of the GTX 960, though, I think you'd be better off getting a new 3GB GTX 1060 card which runs closer to $200 and uses less power to do so to boot. Plus, being a Pascal chip it would probably be supported longer than the Maxwell chip.
antropofob
Thanks everybody, I am gunning for 1060 3GB model!
MARSTG
- Hardware configuration: B450 AORUS M w 3800X & WRAITH PRISM
16 GB DELTA RGB 3600 & WD SN 770 500GB
GTX 1070 GAMING X w LG OLED C1 55"
ECLIPSE P300A TG - Location: Montreal
Slot bandwidth has nothing to do with Folding. I had a gtx 470 hooked to a 120GB prieteni 1.1 and it was folding with no penalties compared to 16x port.
That may hold for a relatively low end card such as the GTX 470, but tests by others on higher end cards have shown a 10% or higher loss in throughput using a slow PCIe slot.MARSTG wrote:Slot bandwidth has nothing to do with Folding. I had a gtx 470 hooked to a 120GB prieteni 1.1 and it was folding with no penalties compared to 16x port.
MARSTG
A gtx 960 is good for 135-160k ppd and open mentioned that 16x port is available so where is the disagreement stemming from? Short answer is, it will work but only with Nvidia as AMD cards don't fold under Linux.
Nathan_P
Not currently folding
As Joe said that statement is not true, in my experiments I've seen anything from a 2% to 6% gain from PCIe 1.1 x16 to PCIe 3.0 x16. What I haven't tested yet is PCIe x4 and x1, that's where the biggest hits comeJoe_H wrote:That may hold for a relatively low end card such as the GTX 470, but tests by others on higher end cards have shown a 10% or higher loss in throughput using a slow PCIe slot.MARSTG wrote:Slot bandwidth has nothing to do with Folding. I had a gtx 470 hooked to a 120GB prieteni 1.1 and it was folding with no penalties compared to 16x port.
Also incorrect, AMD cards have been usable for folding under Linux for some time.MARSTG wrote:A gtx 960 is good for 135-160k ppd and open mentioned that 16x port is available so where is the disagreement stemming from? Short answer is, it will work but only with Nvidia as AMD cards don't fold under Linux.
MARSTG
That is good news then. BTW how much ppd is a 380 giving? Is it comparable with 280x, in the 135k range?
R9 380 makes 150k PPD
antropofob
I finally managed to put system with 1060.
I even bought a used Pentium 4 with 64-bit support running at 3Ghz. Paid 3 dollars for it
But things did not go smoothly in Linuxland so I ended up installing W7.
Its running smoothly and uses about 500MB after boot.
But it seems that something is starving my GPU because I am seeing lots of waves in GPU utilization.
Motherboard has Gen 1 x16 pcie slot and thats where my GPU is.
If you have any ideas please post them here: viewtopic.php?f=80&t=29229
Are you sure the PCIe slot is actually running at x16 or is it split with some other device?
