Windows 10 1607 Anniversary Edition
paulprochnow
Post by paulprochnow »
I moved to Win 10 1607 Anniversary Edition. It is a nice OS. Yesterday I totally believe F A H crashed my Tower HARD. It took hours of coaxing and wheedling the tower to get it up and running a couple of times and then I realized F A H is NO LONGER compatible with WIndows 10.
I limped it to the desk top and it froze AFTER I uninstalled F A H. I had to pull the plug to reboot again EXCEPT it took hours to get Win 10 back [ it had never been a problem ] after even a few more hours the tower commenced as normal.
I did remove old Shadow Copies after I started running F A H Anniversary 1607 Version when the BIG FREEZE occurred.. How could F A H somehow rely on an old Shadow Copy [? ? ?], so much so it Froze the tower.?
I HAD BEEN RUNNING F A H successfully for a few months on this rig - Old WIndows 10 1591[?] version.
Lenovo X58 S20ThinkStation MoBo, Xeon X5650, 6GB Samsung RAM, Adata AS330 SSD, XFX R7 300 graphics card<------------ Homade rig, 2016 SSD less than a year old & 2016 VGA card.
Will it ever be safe to run F A H on Win 10 Anniversary 1607? This is offered to Windows 10 Users as a innocent simple UPGRADE. NONE of my other PCs have been inflicted by the tragedy as they do not run F A H.
As time will march on I think the creew needs to investigate and smooth the problem out. Probably not a big fix, I do not know, but the disabling FREEZE happens.
P.P. 24sept2016
bollix47
Re: Windows 10 1607 Anniversary Edition
Post by bollix47 »
This is not likely to be a problem related directly to F@H.
The first possible solution that I would try might be to download and install the latest GPU drivers from AMD.
Unfortunately Microsoft appears to be determined to limit your ability to use the drivers you want to use and this version of Windows 10 does install GPU drivers which may not be compatible with F@H ... i.e. they might be missing OPENCL.
There are hundreds, if not thousands, of search returns on the internet complaining about this update so Microsoft describing it as "a innocent simple UPGRADE" is naive and in a lot of cases inaccurate.
Post by foldy »
This sounds to me like a harddisk problem. When there are bad sectors on disk or similar then on access to these sectors Windows will hang or crash or does not startup in time. I recommend to chkdsk your harddisk by opening a cmd shell and call "chkdsk /F".
https://www.tekrevue.com/tip/fix-hard-d ... indows-10/
No problems folding on Windows 10 Anniversary edition.
*********************** Log Started 2016-09-28T02:42:40Z ***********************
02:42:40:************************* Folding@home Client *************************
02:42:40:      Website: http://folding.stanford.edu/
02:42:40:    Copyright: (c) 2009-2016 Stanford University
02:42:40:       Author: Joseph Coffland <joseph@cauldrondevelopment.com>
02:42:40:         Args:
02:42:40:       Config: <none>
02:42:40:******************************** Build ********************************
02:42:40:      Version: 7.4.15
02:42:40:         Date: Aug 17 2016
02:42:40:         Time: 04:33:41
02:42:40:   Repository: Git
02:42:40:     Revision: 4f3e0e25571a9f691719f0c273739294bde517dd
02:42:40:       Branch: master
02:42:40:     Compiler: GNU 5.3.1 20160205
02:42:40:      Options: -std=gnu++98 -I/mingw64/include -O3 -funroll-loops -ffast-math
02:42:40:               -mfpmath=sse -fno-unsafe-math-optimizations -msse2
02:42:40:     Platform: linux2 4.6.0-1-amd64
02:42:40:         Bits: 64
02:42:40:         Mode: Release
02:42:40:******************************* System ********************************
02:42:40:          CPU: Intel(R) Core(TM)2 CPU T5600 @ 1.83GHz
02:42:40:       CPU ID: GenuineIntel Family 6 Model 15 Stepping 6
02:42:40:         CPUs: 2
02:42:40:       Memory: 2.00GiB
02:42:40:  Free Memory: 370.01MiB
02:42:40:      Threads: WINDOWS_THREADS
02:42:40:   OS Version: 6.2
02:42:40:  Has Battery: true
02:42:40:   On Battery: false
02:42:40:   UTC Offset: -7
02:42:40:          PID: 5524
02:42:40:          CWD: C:\Users\7im\AppData\Roaming\FAHClient
02:42:40:           OS: Windows 10 Pro
02:42:40:      OS Arch: AMD64
02:42:40:         GPUs: 0
02:42:40:         CUDA: Not detected
02:42:40:       OpenCL: Not detected
02:42:40:Win32 Service: false
02:42:40:***********************************************************************
02:42:40:<config>
02:42:40:  <!-- Folding Slots -->
02:42:40:</config>
02:42:40:Connecting to assign-GPU.stanford.edu:80
02:42:41:Updated GPUs.txt
02:42:41:Read GPUs.txt
02:42:41:Trying to access database...
02:42:41:Successfully acquired database lock
02:42:41:Enabled folding slot 00: PAUSED cpu:0 (not configured)
02:42:44:12:127.0.0.1:New Web connection
02:43:42:Set client configured
02:43:42:WU00:FS00:Connecting to 171.67.108.45:8080
02:43:43:WU00:FS00:Connecting to 171.67.108.45:8080
02:43:43:WU00:FS00:Assigned to work server 171.67.108.158
02:43:43:WU00:FS00:Requesting new work unit for slot 00: READY cpu:0 from 171.67.108.158
02:43:43:WU00:FS00:Connecting to 171.67.108.158:8080
02:43:44:WU00:FS00:Downloading 807.41KiB
02:43:44:WU00:FS00:Download complete
02:43:45:WU00:FS00:Received Unit: id:00 state:DOWNLOAD error:NO_ERROR project:9037 run:456 clone:14 gen:22 core:0xa4 unit:0x0000001bab436c9e56982b337297182a
02:43:45:WU00:FS00:Downloading core from http://web.stanford.edu/~pande/Win32/AMD64/Core_a4.fah
02:43:45:WU00:FS00:Connecting to web.stanford.edu:80
02:43:45:WU00:FS00:FahCore a4: Downloading 2.89MiB
02:43:48:WU00:FS00:FahCore a4: Download complete
02:43:48:WU00:FS00:Valid core signature
02:43:48:WU00:FS00:Unpacked 9.59MiB to cores/web.stanford.edu/~pande/Win32/AMD64/Core_a4.fah/FahCore_a4.exe
02:43:48:WU00:FS00:Starting
02:43:48:WARNING:WU00:FS00:Changed SMP threads from 1 to 0 this can cause some work units to fail
02:43:48:WU00:FS00:Running FahCore: "C:\Program Files\FAHClient/FAHCoreWrapper.exe" C:\Users\7im\AppData\Roaming\FAHClient\cores/web.stanford.edu/~pande/Win32/AMD64/Core_a4.fah/FahCore_a4.exe -dir 00 -suffix 01 -version 704 -lifeline 5524 -checkpoint 15
02:43:48:WU00:FS00:Started FahCore on PID 680
02:43:49:WU00:FS00:Core PID:4876
02:43:49:WU00:FS00:FahCore 0xa4 started
02:43:50:WU00:FS00:0xa4:
02:43:50:WU00:FS00:0xa4:*------------------------------*
02:43:50:WU00:FS00:0xa4:Folding@Home Gromacs GB Core
02:43:50:WU00:FS00:0xa4:Version 2.27 (Dec. 15, 2010)
02:43:50:WU00:FS00:0xa4:Preparing to commence simulation
02:43:50:WU00:FS00:0xa4:- Looking at optimizations...
02:43:50:WU00:FS00:0xa4:- Created dyn
02:43:50:WU00:FS00:0xa4:- Files status OK
02:43:53:WU00:FS00:0xa4:- Expanded 826280 -> 1403472 (decompressed 169.8 percent)
02:43:53:WU00:FS00:0xa4:Called DecompressByteArray: compressed_data_size=826280 data_size=1403472, decompressed_data_size=1403472 diff=0
02:43:53:WU00:FS00:0xa4:- Digital signature verified
02:43:53:WU00:FS00:0xa4:Project: 9037 (Run 456, Clone 14, Gen 22)
02:43:53:WU00:FS00:0xa4:Assembly optimizations on if available.
02:43:53:WU00:FS00:0xa4:Entering M.D.
02:43:58:WU00:FS00:0xa4:Mapping NT from 1 to 1
02:43:59:WU00:FS00:0xa4:Completed 0 out of 250000 steps  (0%)
02:46:45:Saving configuration to config.xml
02:46:45:<config>
02:46:45:  <!-- User Information -->
02:46:45:  <passkey v='********************************'/>
02:46:45:  <team v='14'/>
02:46:45:  <user v='7im'/>
02:46:45:
02:46:45:  <!-- Folding Slots -->
02:46:45:  <slot id='0' type='CPU'/>
02:46:45:</config>
02:48:47:Saving configuration to config.xml
02:48:47:<config>
02:48:47:  <!-- Slot Control -->
02:48:47:  <power v='full'/>
02:48:47:
02:48:47:  <!-- User Information -->
02:48:47:  <passkey v='********************************'/>
02:48:47:  <team v='14'/>
02:48:47:  <user v='7im'/>
02:48:47:
02:48:47:  <!-- Folding Slots -->
02:48:47:  <slot id='0' type='CPU'/>
02:48:47:</config>
03:01:25:WU00:FS00:0xa4:Completed 2500 out of 250000 steps  (1%)
schmiddi
Post by schmiddi »
Well, I have problems with the GPU, after that "update" installed.
select all*********************** Log Started 2016-09-30T19:44:26Z ***********************
19:44:26:************************* Folding@home Client *************************
19:44:26:      Website: http://folding.stanford.edu/
19:44:26:    Copyright: (c) 2009-2016 Stanford University
19:44:26:       Author: Joseph Coffland <joseph@cauldrondevelopment.com>
19:44:26:         Args:
19:44:26:       Config: C:\Users\schmiddi\AppData\Roaming\FAHClient\config.xml
19:44:26:******************************** Build ********************************
19:44:26:      Version: 7.4.15
19:44:26:         Date: Aug 17 2016
19:44:26:         Time: 04:33:41
19:44:26:   Repository: Git
19:44:26:     Revision: 4f3e0e25571a9f691719f0c273739294bde517dd
19:44:26:       Branch: master
19:44:26:     Compiler: GNU 5.3.1 20160205
19:44:26:      Options: -std=gnu++98 -I/mingw64/include -O3 -funroll-loops -ffast-math
19:44:26:               -mfpmath=sse -fno-unsafe-math-optimizations -msse2
19:44:26:     Platform: linux2 4.6.0-1-amd64
19:44:26:         Bits: 64
19:44:26:         Mode: Release
19:44:26:******************************* System ********************************
19:44:26:          CPU: Intel(R) Core(TM) i7-4770K CPU @ 3.50GHz
19:44:26:       CPU ID: GenuineIntel Family 6 Model 60 Stepping 3
19:44:26:         CPUs: 8
19:44:26:       Memory: 7.93GiB
19:44:26:  Free Memory: 5.90GiB
19:44:26:      Threads: WINDOWS_THREADS
19:44:26:   OS Version: 6.2
19:44:26:  Has Battery: false
19:44:26:   On Battery: false
19:44:26:   UTC Offset: 2
19:44:26:          PID: 9160
19:44:26:          CWD: C:\Users\schmiddi\AppData\Roaming\FAHClient
19:44:26:           OS: Windows 10 Home
19:44:26:      OS Arch: AMD64
19:44:26:         GPUs: 1
19:44:26:        GPU 0: Bus:1 Slot:0 NVIDIA:3 GK110 [GeForce GTX 780]
19:44:26:CUDA Device 0: Platform:0 Device:0 Bus:1 Slot:0 Compute:3.5 Driver:8.0
19:44:26:       OpenCL: Not detected
19:44:26:Win32 Service: false
19:44:26:***********************************************************************
19:44:26:<config>
19:44:26:  <!-- Network -->
19:44:26:  <proxy v=':8080'/>
19:44:26:
19:44:26:  <!-- Slot Control -->
19:44:26:  <power v='FULL'/>
19:44:26:
19:44:26:  <!-- User Information -->
19:44:26:  <passkey v='********************************'/>
19:44:26:  <team v='47958'/>
19:44:26:  <user v='schmiddi'/>
19:44:26:
19:44:26:  <!-- Folding Slots -->
19:44:26:  <slot id='0' type='CPU'/>
19:44:26:  <slot id='1' type='GPU'/>
19:44:26:</config>
19:44:26:Trying to access database...
19:44:26:Successfully acquired database lock
19:44:26:Enabled folding slot 00: READY cpu:7
19:44:26:Enabled folding slot 01: READY gpu:0:GK110 [GeForce GTX 780]
19:44:26:WU01:FS01:Starting
19:44:26:ERROR:WU01:FS01:Failed to start core: OpenCL device matching slot 1 not found
19:44:26:WU00:FS00:Starting
FAH requires OpenCL support when using a GPU. Microsoft often does not include that support -- as evidenced by the statement "19:44:26: OpenCL: Not detected"
Installing the drivers directly from NVidia (or ATI) solves this problem.
I'm not sure which driver version is included with 1607, but I'd choose to install the same version from NV. I recently had a problem installing the later version recommended by NV and I solved it by going back to the one that MS had tested on that version of Windows.
schmiddi
Post by schmiddi »
Problem solved.
For anyone who has experienced the same:
I manually downgraded to 372.70 and then let the Nvidia Experience upgrade again to the most recent driver version.
This is a Windows 10 issue, force installing non working (for fah) GPU drivers, seemingly with every monthly update.
So much so, there is a whole forum section dedicated to this issue.
viewforum.php?f=101
