[P13201, 40, 0, 172] Probably an anomaly, but...
v00d00
Hardware configuration: FX8320e (6 cores enabled) @ stock,
- 16GB DDR3,
- Zotac GTX 1050Ti @ Stock.
- Gigabyte GTX 970 @ Stock
Debian 9.
Ran Seti@Home prior to that.
Post by v00d00 »
Just pulled this out of my log.
If someone else completed it then im happy, and will put it down to the above.
Rig is relatively stock everything. FX8320e @ 4 cores @ stock, 16GB DDR3, GTX 970 @ stock, running 18 hours per day (ish).
23:54:25:WU00:FS01:0x21:*********************** Log Started 2016-09-16T23:54:25Z ***********************
23:54:25:WU00:FS01:0x21:Project: 13201 (Run 40, Clone 0, Gen 172)
23:54:25:WU00:FS01:0x21:Unit: 0x00000069ab436c66577fedfe2e5878e5
23:54:25:WU00:FS01:0x21:CPU: 0x00000000000000000000000000000000
23:54:25:WU00:FS01:0x21:Machine: 1
23:54:25:WU00:FS01:0x21:Reading tar file core.xml
23:54:25:WU00:FS01:0x21:Reading tar file integrator.xml
23:54:25:WU00:FS01:0x21:Reading tar file state.xml
23:54:26:WU00:FS01:0x21:Reading tar file system.xml
23:54:27:WU00:FS01:0x21:Digital signatures verified
23:54:27:WU00:FS01:0x21:Folding@home GPU Core21 Folding@home Core
23:54:27:WU00:FS01:0x21:Version 0.0.17
23:54:30:WU01:FS01:Upload 10.98%
23:54:36:WU01:FS01:Upload 22.54%
23:54:42:WU01:FS01:Upload 33.52%
23:54:48:WU01:FS01:Upload 43.93%
23:54:54:WU01:FS01:Upload 55.49%
23:55:00:WU01:FS01:Upload 65.31%
23:55:06:WU01:FS01:Upload 75.72%
23:55:12:WU01:FS01:Upload 87.85%
23:55:19:WU01:FS01:Upload 99.41%
23:55:30:WU01:FS01:Upload complete
23:55:30:WU01:FS01:Server responded WORK_ACK (400)
23:55:30:WU01:FS01:Final credit estimate, 76023.00 points
23:55:30:WU01:FS01:Cleaning up
23:55:39:WU00:FS01:0x21:Completed 0 out of 2000000 steps (0%)
23:55:39:WU00:FS01:0x21:Temperature control disabled. Requirements: single Nvidia GPU, tmax must be < 110 and twait >= 900
23:58:56:WU00:FS01:0x21:Completed 20000 out of 2000000 steps (1%)
00:02:10:WU00:FS01:0x21:Completed 40000 out of 2000000 steps (2%)
00:05:23:WU00:FS01:0x21:Completed 60000 out of 2000000 steps (3%)
00:08:37:WU00:FS01:0x21:Completed 80000 out of 2000000 steps (4%)
00:11:50:WU00:FS01:0x21:Completed 100000 out of 2000000 steps (5%)
00:15:03:WU00:FS01:0x21:Completed 120000 out of 2000000 steps (6%)
00:18:15:WU00:FS01:0x21:Completed 140000 out of 2000000 steps (7%)
00:21:28:WU00:FS01:0x21:Completed 160000 out of 2000000 steps (8%)
00:24:41:WU00:FS01:0x21:Completed 180000 out of 2000000 steps (9%)
00:27:54:WU00:FS01:0x21:Completed 200000 out of 2000000 steps (10%)
00:28:03:WU00:FS01:0x21:Bad State detected... attempting to resume from last good checkpoint. Is your system overclocked?
00:31:16:WU00:FS01:0x21:Completed 20000 out of 2000000 steps (1%)
00:34:29:WU00:FS01:0x21:Completed 40000 out of 2000000 steps (2%)
00:37:42:WU00:FS01:0x21:Completed 60000 out of 2000000 steps (3%)
00:40:56:WU00:FS01:0x21:Completed 80000 out of 2000000 steps (4%)
00:44:10:WU00:FS01:0x21:Completed 100000 out of 2000000 steps (5%)
00:47:24:WU00:FS01:0x21:Completed 120000 out of 2000000 steps (6%)
00:50:37:WU00:FS01:0x21:Completed 140000 out of 2000000 steps (7%)
00:53:51:WU00:FS01:0x21:Completed 160000 out of 2000000 steps (8%)
00:57:04:WU00:FS01:0x21:Completed 180000 out of 2000000 steps (9%)
01:00:18:WU00:FS01:0x21:Completed 200000 out of 2000000 steps (10%)
01:00:26:WU00:FS01:0x21:Bad State detected... attempting to resume from last good checkpoint. Is your system overclocked?
01:03:39:WU00:FS01:0x21:Completed 20000 out of 2000000 steps (1%)
01:06:53:WU00:FS01:0x21:Completed 40000 out of 2000000 steps (2%)
01:10:07:WU00:FS01:0x21:Completed 60000 out of 2000000 steps (3%)
01:13:21:WU00:FS01:0x21:Completed 80000 out of 2000000 steps (4%)
01:16:35:WU00:FS01:0x21:Completed 100000 out of 2000000 steps (5%)
01:19:49:WU00:FS01:0x21:Completed 120000 out of 2000000 steps (6%)
01:23:03:WU00:FS01:0x21:Completed 140000 out of 2000000 steps (7%)
01:26:17:WU00:FS01:0x21:Completed 160000 out of 2000000 steps (8%)
01:29:30:WU00:FS01:0x21:Completed 180000 out of 2000000 steps (9%)
01:32:44:WU00:FS01:0x21:Completed 200000 out of 2000000 steps (10%)
01:32:52:WU00:FS01:0x21:Bad State detected... attempting to resume from last good checkpoint. Is your system overclocked?
01:32:52:WU00:FS01:0x21:ERROR:Max Retries Reached
01:32:52:WU00:FS01:0x21:Saving result file logfile_01.txt
01:32:52:WU00:FS01:0x21:Saving result file badstate-0.xml
01:32:54:WU00:FS01:0x21:Saving result file badstate-1.xml
01:32:57:WU00:FS01:0x21:Saving result file badstate-2.xml
01:32:59:WU00:FS01:0x21:Saving result file log.txt
01:32:59:WU00:FS01:0x21:Folding@home Core Shutdown: BAD_WORK_UNIT
01:32:59:WARNING:WU00:FS01:FahCore returned: BAD_WORK_UNIT (114 = 0x72)
01:32:59:WU00:FS01:Sending unit results: id:00 state:SEND error:FAULTY project:13201 run:40 clone:0 gen:172 core:0x21 unit:0x00000069ab436c66577fedfe2e5878e5
The client appears to have dumped it, and it has now moved on to something else (P11707) which is running happily.
Sorry i dont check in often, but RL took over a while back. Still fold on the side though. ;)
Re: [P13201, 40, 0, 172] Probably an anomaly, but...
Too early to say for certain of this is a bad WU, but there are two reports failure on this WU in the database so far. WU's get tried a few times before being marked bad in the system. Both yours and the other report show partial credit for completing some steps, but no successful completion.
As a followup, the third system this WU was assigned to was able to fold it successfully:
Hi ****** (team ******),
Your WU (P13201 R40 C0 G172) was added to the stats database on 2016-09-17 04:08:10 for 13541 points of credit.
v00d00
- 16GB DDR3,
Debian 9.
Post by v00d00 »
Thats fine.
Im glad someone managed to get it done.
I have had no other failures since that unit, so I guess it just didnt like my setup, for whatever reason. ;)
I get the occasional WU like that, I blame it on cosmic rays...
