sorry for my bad english, im from Germany and i hope you can help me.
I have an Server with one 780Ti and Windows Server 2012. The Problem is, i become fails "bad state detected" and then driver crashed and i must restart the system.
I try to do install any Nvidia drivers with DDU. I have underclocked the GPU to -100MHz.
The Temperature of the GPU was maximum 68°C.
I hope you can help me by the problem
*********************** Log Started 2016-09-14T11:52:27Z ***********************
11:52:27:************************* Folding@home Client *************************
11:52:27: Website: http://folding.stanford.edu/
11:52:27: Copyright: (c) 2009-2014 Stanford University
11:52:27: Author: Joseph Coffland <joseph@cauldrondevelopment.com>
11:52:27: Args:
11:52:27: Config: C:/Users/Adm-Netz/AppData/Roaming/FAHClient/config.xml
11:52:27:******************************** Build ********************************
11:52:27: Version: 7.4.4
11:52:27: Date: Mar 4 2014
11:52:27: Time: 20:26:54
11:52:27: SVN Rev: 4130
11:52:27: Branch: fah/trunk/client
11:52:27: Compiler: Intel(R) C++ MSVC 1500 mode 1200
11:52:27: Options: /TP /nologo /EHa /Qdiag-disable:4297,4103,1786,279 /Ox -arch:SSE
11:52:27: /QaxSSE2,SSE3,SSSE3,SSE4.1,SSE4.2 /Qopenmp /Qrestrict /MT /Qmkl
11:52:27: Platform: win32 XP
11:52:27: Bits: 32
11:52:27: Mode: Release
11:52:27:******************************* System ********************************
11:52:27: CPU: Intel(R) Xeon(R) CPU E3-1241 v3 @ 3.50GHz
11:52:27: CPU ID: GenuineIntel Family 6 Model 60 Stepping 3
11:52:27: CPUs: 8
11:52:27: Memory: 15.96GiB
11:52:27: Free Memory: 14.08GiB
11:52:27: Threads: WINDOWS_THREADS
11:52:27: OS Version: 6.2
11:52:27: Has Battery: false
11:52:27: On Battery: false
11:52:27: UTC Offset: 2
11:52:27: PID: 6636
11:52:27: CWD: C:/Users/Adm-Netz/AppData/Roaming/FAHClient
11:52:27: OS: Windows Server 2012 R2 Essentials
11:52:27: OS Arch: AMD64
11:52:27: GPUs: 1
11:52:27: GPU 0: NVIDIA:3 GK110 [GeForce GTX 780 Ti]
11:52:27: CUDA: Not detected
11:52:27:Win32 Service: false
11:52:27:***********************************************************************
11:52:27:<config>
11:52:27: <!-- Folding Core -->
11:52:27: <checkpoint v='3'/>
11:52:27: <core-priority v='low'/>
11:52:27:
11:52:27: <!-- HTTP Server -->
11:52:27: <allow v='0.0.0.0/0'/>
11:52:27:
11:52:27: <!-- Network -->
11:52:27: <proxy v=':8080'/>
11:52:27:
11:52:27: <!-- Remote Command Server -->
11:52:27: <password v='******'/>
11:52:27:
11:52:27: <!-- Slot Control -->
11:52:27: <power v='full'/>
11:52:27:
11:52:27: <!-- User Information -->
11:52:27: <passkey v='********************************'/>
11:52:27: <team v='70335'/>
11:52:27: <user v='Fopasa-70335'/>
11:52:27:
11:52:27: <!-- Folding Slots -->
11:52:27: <slot id='1' type='GPU'>
11:52:27: <pause-on-start v='true'/>
11:52:27: <paused v='true'/>
11:52:27: </slot>
11:52:27:</config>
11:52:27:Trying to access database...
11:52:28:Successfully acquired database lock
11:52:28:Enabled folding slot 01: PAUSED gpu:0:GK110 [GeForce GTX 780 Ti] (by user)
12:28:35:FS01:Unpaused
12:28:35:WU01:FS01:Starting
12:28:35:WU01:FS01:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:/Users/Adm-Netz/AppData/Roaming/FAHClient/cores/web.stanford.edu/~pande/Win32/AMD64/NVIDIA/Fermi/Core_21.fah/FahCore_21.exe -dir 01 -suffix 01 -version 704 -lifeline 6636 -checkpoint 3 -gpu 0 -gpu-vendor nvidia
12:28:35:WU01:FS01:Started FahCore on PID 5016
12:28:35:WU01:FS01:Core PID:5136
12:28:35:WU01:FS01:FahCore 0x21 started
12:28:37:WU01:FS01:0x21:*********************** Log Started 2016-09-14T12:28:37Z ***********************
12:28:37:WU01:FS01:0x21:Project: 10496 (Run 50, Clone 13, Gen 4)
12:28:37:WU01:FS01:0x21:Unit: 0x000000088ca304f556bba9b79bbd7858
12:28:37:WU01:FS01:0x21:CPU: 0x00000000000000000000000000000000
12:28:37:WU01:FS01:0x21:Machine: 1
12:28:37:WU01:FS01:0x21:Digital signatures verified
12:28:37:WU01:FS01:0x21:Folding@home GPU Core21 Folding@home Core
12:28:37:WU01:FS01:0x21:Version 0.0.17
12:29:04:Removing old file 'configs/config-20160914-043823.xml'
12:29:04:Saving configuration to config.xml
12:29:04:<config>
12:29:04: <!-- Folding Core -->
12:29:04: <checkpoint v='3'/>
12:29:04: <core-priority v='low'/>
12:29:04:
12:29:04: <!-- HTTP Server -->
12:29:04: <allow v='0.0.0.0/0'/>
12:29:04:
12:29:04: <!-- Network -->
12:29:04: <proxy v=':8080'/>
12:29:04:
12:29:04: <!-- Remote Command Server -->
12:29:04: <password v='******'/>
12:29:04:
12:29:04: <!-- Slot Control -->
12:29:04: <power v='full'/>
12:29:04:
12:29:04: <!-- User Information -->
12:29:04: <passkey v='********************************'/>
12:29:04: <team v='70335'/>
12:29:04: <user v='Fopasa-70335'/>
12:29:04:
12:29:04: <!-- Folding Slots -->
12:29:04: <slot id='1' type='GPU'>
12:29:04: <pause-on-start v='true'/>
12:29:04: </slot>
12:29:04:</config>
12:29:04:WU01:FS01:0x21:Completed 0 out of 2000000 steps (0%)
12:29:04:WU01:FS01:0x21:Temperature control disabled. Requirements: single Nvidia GPU, tmax must be < 110 and twait >= 900
12:32:30:WU01:FS01:0x21:Completed 20000 out of 2000000 steps (1%)
12:36:21:WU01:FS01:0x21:Bad State detected... attempting to resume from last good checkpoint. Is your system overclocked?
12:43:09:WU01:FS01:0x21:Completed 40000 out of 2000000 steps (2%)
12:46:33:WU01:FS01:0x21:Completed 60000 out of 2000000 steps (3%)
12:49:59:WU01:FS01:0x21:Completed 80000 out of 2000000 steps (4%)
12:53:41:WU01:FS01:0x21:Completed 100000 out of 2000000 steps (5%)
12:57:24:WU01:FS01:0x21:Completed 120000 out of 2000000 steps (6%)
13:01:12:WU01:FS01:0x21:Completed 140000 out of 2000000 steps (7%)
13:04:55:WU01:FS01:0x21:Completed 160000 out of 2000000 steps (8%)
13:08:38:WU01:FS01:0x21:Completed 180000 out of 2000000 steps (9%)
13:12:21:WU01:FS01:0x21:Completed 200000 out of 2000000 steps (10%)
13:16:03:WU01:FS01:0x21:Completed 220000 out of 2000000 steps (11%)
13:19:46:WU01:FS01:0x21:Completed 240000 out of 2000000 steps (12%)
13:23:35:WU01:FS01:0x21:Completed 260000 out of 2000000 steps (13%)
13:27:17:WU01:FS01:0x21:Completed 280000 out of 2000000 steps (14%)
13:30:58:WU01:FS01:0x21:Completed 300000 out of 2000000 steps (15%)
13:34:39:WU01:FS01:0x21:Completed 320000 out of 2000000 steps (16%)
13:38:20:WU01:FS01:0x21:Completed 340000 out of 2000000 steps (17%)
13:42:00:WU01:FS01:0x21:Completed 360000 out of 2000000 steps (18%)
13:45:46:WU01:FS01:0x21:Completed 380000 out of 2000000 steps (19%)
13:49:27:WU01:FS01:0x21:Completed 400000 out of 2000000 steps (20%)
13:53:08:WU01:FS01:0x21:Completed 420000 out of 2000000 steps (21%)
13:56:49:WU01:FS01:0x21:Completed 440000 out of 2000000 steps (22%)
14:00:30:WU01:FS01:0x21:Completed 460000 out of 2000000 steps (23%)
14:04:11:WU01:FS01:0x21:Completed 480000 out of 2000000 steps (24%)
14:07:52:WU01:FS01:0x21:Completed 500000 out of 2000000 steps (25%)
14:11:39:WU01:FS01:0x21:Completed 520000 out of 2000000 steps (26%)
14:15:21:WU01:FS01:0x21:Completed 540000 out of 2000000 steps (27%)
14:19:03:WU01:FS01:0x21:Completed 560000 out of 2000000 steps (28%)
14:22:45:WU01:FS01:0x21:Completed 580000 out of 2000000 steps (29%)
14:26:27:WU01:FS01:0x21:Completed 600000 out of 2000000 steps (30%)
14:30:09:WU01:FS01:0x21:Completed 620000 out of 2000000 steps (31%)
14:33:58:WU01:FS01:0x21:Completed 640000 out of 2000000 steps (32%)
14:37:41:WU01:FS01:0x21:Completed 660000 out of 2000000 steps (33%)
14:38:59:FS01:Finishing
14:41:23:WU01:FS01:0x21:Completed 680000 out of 2000000 steps (34%)
14:45:06:WU01:FS01:0x21:Completed 700000 out of 2000000 steps (35%)
14:47:00:WU01:FS01:0x21:ERROR:exception: Error downloading array energyBuffer: clEnqueueReadBuffer (-5)
14:47:00:WU01:FS01:0x21:Saving result file logfile_01.txt
14:47:00:WU01:FS01:0x21:Saving result file badstate-0.xml
14:47:05:WU01:FS01:0x21:Saving result file log.txt
14:47:05:WU01:FS01:0x21:Folding@home Core Shutdown: BAD_WORK_UNIT
14:47:07:WARNING:WU01:FS01:FahCore returned: BAD_WORK_UNIT (114 = 0x72)
14:47:07:WU01:FS01:Sending unit results: id:01 state:SEND error:FAULTY project:10496 run:50 clone:13 gen:4 core:0x21 unit:0x000000088ca304f556bba9b79bbd7858
14:47:07:WU01:FS01:Uploading 10.17KiB to 140.163.4.245
14:47:07:WU01:FS01:Connecting to 140.163.4.245:8080
14:47:07:WU01:FS01:Upload complete
14:47:07:WU01:FS01:Server responded WORK_ACK (400)
14:47:07:WU01:FS01:Cleaning up
