Could not connect to folding server [assign-GPU2]
vclor
Post by vclor »
Mod note: merged two posts on issue
Hi,
Just installed folding@home on my desktop. I updated the GPU.txt file, and rebooted the machine.
The problem i seem to be having is that there is no server. Is there something i can do to resolve this?
I tried with ping to the different ip's listed in the log below, there is no response.
Thanks for helping.
*********************** Log Started 2016-09-06T08:18:40Z ***********************
08:18:40:************************* Folding@home Client *************************
08:18:40:      Website: http://folding.stanford.edu/
08:18:40:    Copyright: (c) 2009-2014 Stanford University
08:18:40:       Author: Joseph Coffland <joseph@cauldrondevelopment.com>
08:18:40:         Args:
08:18:40:       Config: C:/ProgramData/FAHClient/config.xml
08:18:40:******************************** Build ********************************
08:18:40:      Version: 7.4.4
08:18:40:         Date: Mar 4 2014
08:18:40:         Time: 20:26:54
08:18:40:      SVN Rev: 4130
08:18:40:       Branch: fah/trunk/client
08:18:40:     Compiler: Intel(R) C++ MSVC 1500 mode 1200
08:18:40:      Options: /TP /nologo /EHa /Qdiag-disable:4297,4103,1786,279 /Ox -arch:SSE
08:18:40:               /QaxSSE2,SSE3,SSSE3,SSE4.1,SSE4.2 /Qopenmp /Qrestrict /MT /Qmkl
08:18:40:     Platform: win32 XP
08:18:40:         Bits: 32
08:18:40:         Mode: Release
08:18:40:******************************* System ********************************
08:18:40:          CPU: Intel(R) Core(TM) i7-4770K CPU @ 3.50GHz
08:18:40:       CPU ID: GenuineIntel Family 6 Model 60 Stepping 3
08:18:40:         CPUs: 8
08:18:40:       Memory: 15.93GiB
08:18:40:  Free Memory: 14.36GiB
08:18:40:      Threads: WINDOWS_THREADS
08:18:40:   OS Version: 6.2
08:18:40:  Has Battery: false
08:18:40:   On Battery: false
08:18:40:   UTC Offset: 2
08:18:40:          PID: 4352
08:18:40:          CWD: C:/ProgramData/FAHClient
08:18:40:           OS: Windows 8.1 Pro
08:18:40:      OS Arch: AMD64
08:18:40:         GPUs: 1
08:18:40:        GPU 0: ATI:5 Pitcairn [FirePro R5000 (FireGL V)]
08:18:40:         CUDA: Not detected
08:18:40:Win32 Service: false
08:18:40:***********************************************************************
08:18:40:<config>
08:18:40:  <!-- Slot Control -->
08:18:40:  <power v='FULL'/>
08:18:40:
08:18:40:  <!-- Folding Slots -->
08:18:40:  <slot id='0' type='CPU'/>
08:18:40:  <slot id='1' type='GPU'/>
08:18:40:</config>
08:18:40:Connecting to assign-GPU.stanford.edu:80
08:19:01:WARNING:Attempting to update GPUs.txt from assign-GPU.stanford.edu:80: Failed to connect to assign-GPU.stanford.edu:80: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.
08:19:01:Connecting to assign-GPU2.stanford.edu:80
08:19:22:WARNING:Attempting to update GPUs.txt from assign-GPU2.stanford.edu:80: Failed to connect to assign-GPU2.stanford.edu:80: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.
08:19:22:Trying to access database...
08:19:22:Successfully acquired database lock
08:19:22:Enabled folding slot 00: READY cpu:7
08:19:22:Enabled folding slot 01: READY gpu:0:Pitcairn [FirePro R5000 (FireGL V)]
08:19:23:WU00:FS00:Connecting to 171.67.108.45:8080
08:19:23:WU01:FS01:Connecting to 171.67.108.45:80
08:19:32:20:127.0.0.1:New Web connection
08:19:44:WARNING:WU01:FS01:Failed to get assignment from '171.67.108.45:80': Failed to connect to 171.67.108.45:80: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.
08:19:44:WU01:FS01:Connecting to 171.67.108.204:80
08:19:44:WARNING:WU00:FS00:Failed to get assignment from '171.67.108.45:8080': Failed to connect to 171.67.108.45:8080: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.
08:19:44:WU00:FS00:Connecting to 171.64.65.35:80
08:19:45:WARNING:WU00:FS00:Failed to get assignment from '171.64.65.35:80': Empty work server assignment
08:19:45:ERROR:WU00:FS00:Exception: Could not get an assignment
08:19:45:WU00:FS00:Connecting to 171.67.108.45:8080
08:20:05:WARNING:WU01:FS01:Failed to get assignment from '171.67.108.204:80': Failed to connect to 171.67.108.204:80: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.
08:20:05:ERROR:WU01:FS01:Exception: Could not get an assignment
08:20:05:WU01:FS01:Connecting to 171.67.108.45:80
08:20:06:WARNING:WU00:FS00:Failed to get assignment from '171.67.108.45:8080': Failed to connect to 171.67.108.45:8080: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.
08:20:06:WU00:FS00:Connecting to 171.64.65.35:80
08:20:07:WARNING:WU00:FS00:Failed to get assignment from '171.64.65.35:80': Empty work server assignment
08:20:07:ERROR:WU00:FS00:Exception: Could not get an assignment
08:20:26:WARNING:WU01:FS01:Failed to get assignment from '171.67.108.45:80': Failed to connect to 171.67.108.45:80: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.
08:20:26:WU01:FS01:Connecting to 171.67.108.204:80
08:20:45:WU00:FS00:Connecting to 171.67.108.45:8080
08:20:47:WARNING:WU01:FS01:Failed to get assignment from '171.67.108.204:80': Failed to connect to 171.67.108.204:80: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.
08:20:47:ERROR:WU01:FS01:Exception: Could not get an assignment
08:21:05:WU01:FS01:Connecting to 171.67.108.45:80
08:21:06:WARNING:WU00:FS00:Failed to get assignment from '171.67.108.45:8080': Failed to connect to 171.67.108.45:8080: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.
08:21:06:WU00:FS00:Connecting to 171.64.65.35:80
08:21:07:WARNING:WU00:FS00:Failed to get assignment from '171.64.65.35:80': Empty work server assignment
08:21:07:ERROR:WU00:FS00:Exception: Could not get an assignment
08:21:26:WARNING:WU01:FS01:Failed to get assignment from '171.67.108.45:80': Failed to connect to 171.67.108.45:80: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.
08:21:26:WU01:FS01:Connecting to 171.67.108.204:80
08:21:47:WARNING:WU01:FS01:Failed to get assignment from '171.67.108.204:80': Failed to connect to 171.67.108.204:80: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.
08:21:47:ERROR:WU01:FS01:Exception: Could not get an assignment
08:22:22:WU00:FS00:Connecting to 171.67.108.45:8080
08:22:42:WU01:FS01:Connecting to 171.67.108.45:80
08:22:43:WARNING:WU00:FS00:Failed to get assignment from '171.67.108.45:8080': Failed to connect to 171.67.108.45:8080: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.
08:22:43:WU00:FS00:Connecting to 171.64.65.35:80
08:22:44:WARNING:WU00:FS00:Failed to get assignment from '171.64.65.35:80': Empty work server assignment
08:22:44:ERROR:WU00:FS00:Exception: Could not get an assignment
08:23:04:WARNING:WU01:FS01:Failed to get assignment from '171.67.108.45:80': Failed to connect to 171.67.108.45:80: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.
08:23:04:WU01:FS01:Connecting to 171.67.108.204:80
08:23:25:WARNING:WU01:FS01:Failed to get assignment from '171.67.108.204:80': Failed to connect to 171.67.108.204:80: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.
08:23:25:ERROR:WU01:FS01:Exception: Could not get an assignment
08:23:40:Connecting to assign-GPU.stanford.edu:80
08:24:01:WARNING:Attempting to update GPUs.txt from assign-GPU.stanford.edu:80: Failed to connect to assign-GPU.stanford.edu:80: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.
08:24:01:Connecting to assign-GPU2.stanford.edu:80
08:24:22:WARNING:Attempting to update GPUs.txt from assign-GPU2.stanford.edu:80: Failed to connect to assign-GPU2.stanford.edu:80: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.
08:24:59:WU00:FS00:Connecting to 171.67.108.45:8080
08:25:20:WU01:FS01:Connecting to 171.67.108.45:80
08:25:21:WARNING:WU00:FS00:Failed to get assignment from '171.67.108.45:8080': Failed to connect to 171.67.108.45:8080: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.
08:25:21:WU00:FS00:Connecting to 171.64.65.35:80
08:25:21:WARNING:WU00:FS00:Failed to get assignment from '171.64.65.35:80': Empty work server assignment
08:25:21:ERROR:WU00:FS00:Exception: Could not get an assignment
08:25:41:WARNING:WU01:FS01:Failed to get assignment from '171.67.108.45:80': Failed to connect to 171.67.108.45:80: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.
08:25:41:WU01:FS01:Connecting to 171.67.108.204:80
08:26:02:WARNING:WU01:FS01:Failed to get assignment from '171.67.108.204:80': Failed to connect to 171.67.108.204:80: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.
08:26:02:ERROR:WU01:FS01:Exception: Could not get an assignment
08:28:40:Connecting to assign-GPU.stanford.edu:80
08:29:01:WARNING:Attempting to update GPUs.txt from assign-GPU.stanford.edu:80: Failed to connect to assign-GPU.stanford.edu:80: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.
08:29:01:Connecting to assign-GPU2.stanford.edu:80
08:29:22:WARNING:Attempting to update GPUs.txt from assign-GPU2.stanford.edu:80: Failed to connect to assign-GPU2.stanford.edu:80: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.
08:29:22:WU00:FS00:Connecting to 171.67.108.45:8080
08:29:34:WU01:FS01:Connecting to 171.67.108.45:80
08:29:43:WARNING:WU00:FS00:Failed to get assignment from '171.67.108.45:8080': Failed to connect to 171.67.108.45:8080: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.
08:29:43:WU00:FS00:Connecting to 171.64.65.35:80
08:29:44:WARNING:WU00:FS00:Failed to get assignment from '171.64.65.35:80': Empty work server assignment
08:29:44:ERROR:WU00:FS00:Exception: Could not get an assignment
08:29:55:WARNING:WU01:FS01:Failed to get assignment from '171.67.108.45:80': Failed to connect to 171.67.108.45:80: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.
08:29:55:WU01:FS01:Connecting to 171.67.108.204:80
08:30:16:WARNING:WU01:FS01:Failed to get assignment from '171.67.108.204:80': Failed to connect to 171.67.108.204:80: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.
08:30:16:ERROR:WU01:FS01:Exception: Could not get an assignment
08:33:40:Connecting to assign-GPU.stanford.edu:80
08:34:01:WARNING:Attempting to update GPUs.txt from assign-GPU.stanford.edu:80: Failed to connect to assign-GPU.stanford.edu:80: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.
08:34:01:Connecting to assign-GPU2.stanford.edu:80
08:34:22:WARNING:Attempting to update GPUs.txt from assign-GPU2.stanford.edu:80: Failed to connect to assign-GPU2.stanford.edu:80: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.
vclor
Fail to connect to
Post by vclor »
Hi,
I can not get my GPU to start folding.
It gives me an error message about the connection to assign-GPU2.stanford.edu.
The CPU is working fine after i changed the threads from 7 to 6.
Any advice?
10:34:22:WARNING:Attempting to update GPUs.txt from assign-GPU2.stanford.edu:80: Failed to connect to assign-GPU2.stanford.edu:80: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.
08:18:40:         Args:
08:18:40:         Bits: 32
08:18:40:         CPUs: 8
08:18:40:          PID: 4352
08:18:40:         GPUs: 1
08:18:40:<config>
08:18:40:
08:18:40:</config>
08:36:13:WU00:FS00:Connecting to 171.67.108.45:8080
08:36:25:WU01:FS01:Connecting to 171.67.108.45:80
08:36:34:WARNING:WU00:FS00:Failed to get assignment from '171.67.108.45:8080': Failed to connect to 171.67.108.45:8080: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.
08:36:34:WU00:FS00:Connecting to 171.64.65.35:80
08:36:35:WARNING:WU00:FS00:Failed to get assignment from '171.64.65.35:80': Empty work server assignment
08:36:35:ERROR:WU00:FS00:Exception: Could not get an assignment
08:36:46:WARNING:WU01:FS01:Failed to get assignment from '171.67.108.45:80': Failed to connect to 171.67.108.45:80: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.
08:36:46:WU01:FS01:Connecting to 171.67.108.204:80
08:37:08:WARNING:WU01:FS01:Failed to get assignment from '171.67.108.204:80': Failed to connect to 171.67.108.204:80: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.
08:37:08:ERROR:WU01:FS01:Exception: Could not get an assignment
08:38:40:Connecting to assign-GPU.stanford.edu:80
08:39:01:WARNING:Attempting to update GPUs.txt from assign-GPU.stanford.edu:80: Failed to connect to assign-GPU.stanford.edu:80: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.
08:39:01:Connecting to assign-GPU2.stanford.edu:80
08:39:22:WARNING:Attempting to update GPUs.txt from assign-GPU2.stanford.edu:80: Failed to connect to assign-GPU2.stanford.edu:80: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.
08:43:40:Connecting to assign-GPU.stanford.edu:80
08:44:01:WARNING:Attempting to update GPUs.txt from assign-GPU.stanford.edu:80: Failed to connect to assign-GPU.stanford.edu:80: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.
08:44:01:Connecting to assign-GPU2.stanford.edu:80
08:44:22:WARNING:Attempting to update GPUs.txt from assign-GPU2.stanford.edu:80: Failed to connect to assign-GPU2.stanford.edu:80: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.
08:47:19:WU00:FS00:Connecting to 171.67.108.45:8080
08:47:31:WU01:FS01:Connecting to 171.67.108.45:80
08:47:40:WARNING:WU00:FS00:Failed to get assignment from '171.67.108.45:8080': Failed to connect to 171.67.108.45:8080: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.
08:47:40:WU00:FS00:Connecting to 171.64.65.35:80
08:47:40:WARNING:WU00:FS00:Failed to get assignment from '171.64.65.35:80': Empty work server assignment
08:47:40:ERROR:WU00:FS00:Exception: Could not get an assignment
08:47:52:WARNING:WU01:FS01:Failed to get assignment from '171.67.108.45:80': Failed to connect to 171.67.108.45:80: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.
08:47:52:WU01:FS01:Connecting to 171.67.108.204:80
08:48:14:WARNING:WU01:FS01:Failed to get assignment from '171.67.108.204:80': Failed to connect to 171.67.108.204:80: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.
08:48:14:ERROR:WU01:FS01:Exception: Could not get an assignment
08:48:40:Connecting to assign-GPU.stanford.edu:80
08:49:01:WARNING:Attempting to update GPUs.txt from assign-GPU.stanford.edu:80: Failed to connect to assign-GPU.stanford.edu:80: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.
08:49:01:Connecting to assign-GPU2.stanford.edu:80
08:49:22:WARNING:Attempting to update GPUs.txt from assign-GPU2.stanford.edu:80: Failed to connect to assign-GPU2.stanford.edu:80: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.
08:53:40:Connecting to assign-GPU.stanford.edu:80
08:54:01:WARNING:Attempting to update GPUs.txt from assign-GPU.stanford.edu:80: Failed to connect to assign-GPU.stanford.edu:80: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.
08:54:01:Connecting to assign-GPU2.stanford.edu:80
08:54:22:WARNING:Attempting to update GPUs.txt from assign-GPU2.stanford.edu:80: Failed to connect to assign-GPU2.stanford.edu:80: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.
08:58:40:Connecting to assign-GPU.stanford.edu:80
08:59:01:WARNING:Attempting to update GPUs.txt from assign-GPU.stanford.edu:80: Failed to connect to assign-GPU.stanford.edu:80: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.
08:59:01:Connecting to assign-GPU2.stanford.edu:80
08:59:22:WARNING:Attempting to update GPUs.txt from assign-GPU2.stanford.edu:80: Failed to connect to assign-GPU2.stanford.edu:80: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.
09:03:40:Connecting to assign-GPU.stanford.edu:80
09:04:01:WARNING:Attempting to update GPUs.txt from assign-GPU.stanford.edu:80: Failed to connect to assign-GPU.stanford.edu:80: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.
09:04:01:Connecting to assign-GPU2.stanford.edu:80
09:04:22:WARNING:Attempting to update GPUs.txt from assign-GPU2.stanford.edu:80: Failed to connect to assign-GPU2.stanford.edu:80: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.
09:05:15:WU00:FS00:Connecting to 171.67.108.45:8080
09:05:28:WU01:FS01:Connecting to 171.67.108.45:80
09:05:36:WARNING:WU00:FS00:Failed to get assignment from '171.67.108.45:8080': Failed to connect to 171.67.108.45:8080: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.
09:05:36:WU00:FS00:Connecting to 171.64.65.35:80
09:05:37:WARNING:WU00:FS00:Failed to get assignment from '171.64.65.35:80': Empty work server assignment
09:05:37:ERROR:WU00:FS00:Exception: Could not get an assignment
09:05:49:WARNING:WU01:FS01:Failed to get assignment from '171.67.108.45:80': Failed to connect to 171.67.108.45:80: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.
09:05:49:WU01:FS01:Connecting to 171.67.108.204:80
09:06:10:WARNING:WU01:FS01:Failed to get assignment from '171.67.108.204:80': Failed to connect to 171.67.108.204:80: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.
09:06:10:ERROR:WU01:FS01:Exception: Could not get an assignment
09:08:40:Connecting to assign-GPU.stanford.edu:80
09:09:01:WARNING:Attempting to update GPUs.txt from assign-GPU.stanford.edu:80: Failed to connect to assign-GPU.stanford.edu:80: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.
09:09:01:Connecting to assign-GPU2.stanford.edu:80
09:09:22:WARNING:Attempting to update GPUs.txt from assign-GPU2.stanford.edu:80: Failed to connect to assign-GPU2.stanford.edu:80: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.
09:13:40:Connecting to assign-GPU.stanford.edu:80
09:14:01:WARNING:Attempting to update GPUs.txt from assign-GPU.stanford.edu:80: Failed to connect to assign-GPU.stanford.edu:80: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.
09:14:01:Connecting to assign-GPU2.stanford.edu:80
09:14:22:WARNING:Attempting to update GPUs.txt from assign-GPU2.stanford.edu:80: Failed to connect to assign-GPU2.stanford.edu:80: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.
09:18:40:Connecting to assign-GPU.stanford.edu:80
09:19:01:WARNING:Attempting to update GPUs.txt from assign-GPU.stanford.edu:80: Failed to connect to assign-GPU.stanford.edu:80: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.
09:19:01:Connecting to assign-GPU2.stanford.edu:80
09:19:22:WARNING:Attempting to update GPUs.txt from assign-GPU2.stanford.edu:80: Failed to connect to assign-GPU2.stanford.edu:80: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.
09:23:40:Connecting to assign-GPU.stanford.edu:80
09:24:01:WARNING:Attempting to update GPUs.txt from assign-GPU.stanford.edu:80: Failed to connect to assign-GPU.stanford.edu:80: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.
09:24:01:Connecting to assign-GPU2.stanford.edu:80
09:24:22:WARNING:Attempting to update GPUs.txt from assign-GPU2.stanford.edu:80: Failed to connect to assign-GPU2.stanford.edu:80: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.
09:28:40:Connecting to assign-GPU.stanford.edu:80
09:29:01:WARNING:Attempting to update GPUs.txt from assign-GPU.stanford.edu:80: Failed to connect to assign-GPU.stanford.edu:80: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.
09:29:01:Connecting to assign-GPU2.stanford.edu:80
09:29:22:WARNING:Attempting to update GPUs.txt from assign-GPU2.stanford.edu:80: Failed to connect to assign-GPU2.stanford.edu:80: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.
09:33:40:Connecting to assign-GPU.stanford.edu:80
09:34:01:WARNING:Attempting to update GPUs.txt from assign-GPU.stanford.edu:80: Failed to connect to assign-GPU.stanford.edu:80: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.
09:34:01:Connecting to assign-GPU2.stanford.edu:80
09:34:22:WARNING:Attempting to update GPUs.txt from assign-GPU2.stanford.edu:80: Failed to connect to assign-GPU2.stanford.edu:80: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.
09:34:22:WU00:FS00:Connecting to 171.67.108.45:8080
09:34:30:WU01:FS01:Connecting to 171.67.108.45:80
09:34:43:WARNING:WU00:FS00:Failed to get assignment from '171.67.108.45:8080': Failed to connect to 171.67.108.45:8080: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.
09:34:43:WU00:FS00:Connecting to 171.64.65.35:80
09:34:44:WARNING:WU00:FS00:Failed to get assignment from '171.64.65.35:80': Empty work server assignment
09:34:44:ERROR:WU00:FS00:Exception: Could not get an assignment
09:34:51:WARNING:WU01:FS01:Failed to get assignment from '171.67.108.45:80': Failed to connect to 171.67.108.45:80: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.
09:34:51:WU01:FS01:Connecting to 171.67.108.204:80
09:35:12:WARNING:WU01:FS01:Failed to get assignment from '171.67.108.204:80': Failed to connect to 171.67.108.204:80: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.
09:35:12:ERROR:WU01:FS01:Exception: Could not get an assignment
09:38:40:Connecting to assign-GPU.stanford.edu:80
09:39:01:WARNING:Attempting to update GPUs.txt from assign-GPU.stanford.edu:80: Failed to connect to assign-GPU.stanford.edu:80: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.
09:39:01:Connecting to assign-GPU2.stanford.edu:80
09:39:22:WARNING:Attempting to update GPUs.txt from assign-GPU2.stanford.edu:80: Failed to connect to assign-GPU2.stanford.edu:80: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.
09:43:40:Connecting to assign-GPU.stanford.edu:80
09:44:01:WARNING:Attempting to update GPUs.txt from assign-GPU.stanford.edu:80: Failed to connect to assign-GPU.stanford.edu:80: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.
09:44:01:Connecting to assign-GPU2.stanford.edu:80
09:44:22:WARNING:Attempting to update GPUs.txt from assign-GPU2.stanford.edu:80: Failed to connect to assign-GPU2.stanford.edu:80: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.
09:48:40:Connecting to assign-GPU.stanford.edu:80
09:49:01:WARNING:Attempting to update GPUs.txt from assign-GPU.stanford.edu:80: Failed to connect to assign-GPU.stanford.edu:80: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.
09:49:01:Connecting to assign-GPU2.stanford.edu:80
09:49:22:WARNING:Attempting to update GPUs.txt from assign-GPU2.stanford.edu:80: Failed to connect to assign-GPU2.stanford.edu:80: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.
09:53:40:Connecting to assign-GPU.stanford.edu:80
09:54:01:WARNING:Attempting to update GPUs.txt from assign-GPU.stanford.edu:80: Failed to connect to assign-GPU.stanford.edu:80: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.
09:54:01:Connecting to assign-GPU2.stanford.edu:80
09:54:22:WARNING:Attempting to update GPUs.txt from assign-GPU2.stanford.edu:80: Failed to connect to assign-GPU2.stanford.edu:80: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.
09:58:40:Connecting to assign-GPU.stanford.edu:80
09:59:01:WARNING:Attempting to update GPUs.txt from assign-GPU.stanford.edu:80: Failed to connect to assign-GPU.stanford.edu:80: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.
09:59:01:Connecting to assign-GPU2.stanford.edu:80
09:59:22:WARNING:Attempting to update GPUs.txt from assign-GPU2.stanford.edu:80: Failed to connect to assign-GPU2.stanford.edu:80: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.
10:03:40:Connecting to assign-GPU.stanford.edu:80
10:04:01:WARNING:Attempting to update GPUs.txt from assign-GPU.stanford.edu:80: Failed to connect to assign-GPU.stanford.edu:80: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.
10:04:01:Connecting to assign-GPU2.stanford.edu:80
10:04:22:WARNING:Attempting to update GPUs.txt from assign-GPU2.stanford.edu:80: Failed to connect to assign-GPU2.stanford.edu:80: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.
10:08:40:Connecting to assign-GPU.stanford.edu:80
10:09:01:WARNING:Attempting to update GPUs.txt from assign-GPU.stanford.edu:80: Failed to connect to assign-GPU.stanford.edu:80: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.
10:09:01:Connecting to assign-GPU2.stanford.edu:80
10:09:22:WARNING:Attempting to update GPUs.txt from assign-GPU2.stanford.edu:80: Failed to connect to assign-GPU2.stanford.edu:80: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.
10:13:40:Connecting to assign-GPU.stanford.edu:80
10:14:01:WARNING:Attempting to update GPUs.txt from assign-GPU.stanford.edu:80: Failed to connect to assign-GPU.stanford.edu:80: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.
10:14:01:Connecting to assign-GPU2.stanford.edu:80
10:14:22:WARNING:Attempting to update GPUs.txt from assign-GPU2.stanford.edu:80: Failed to connect to assign-GPU2.stanford.edu:80: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.
10:18:40:Connecting to assign-GPU.stanford.edu:80
10:19:01:WARNING:Attempting to update GPUs.txt from assign-GPU.stanford.edu:80: Failed to connect to assign-GPU.stanford.edu:80: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.
10:19:01:Connecting to assign-GPU2.stanford.edu:80
10:19:22:WARNING:Attempting to update GPUs.txt from assign-GPU2.stanford.edu:80: Failed to connect to assign-GPU2.stanford.edu:80: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.
10:20:59:Saving configuration to config.xml
10:20:59:<config>
10:20:59:  <!-- Network -->
10:20:59:  <proxy v=':8080'/>
10:20:59:
10:20:59:  <!-- Slot Control -->
10:20:59:  <power v='FULL'/>
10:20:59:
10:20:59:  <!-- Folding Slots -->
10:20:59:  <slot id='0' type='CPU'>
10:20:59:    <cpus v='4'/>
10:20:59:  </slot>
10:20:59:  <slot id='1' type='GPU'/>
10:20:59:</config>
10:21:21:WU00:FS00:Connecting to 171.67.108.45:8080
10:21:24:Saving configuration to config.xml
10:21:24:<config>
10:21:24:  <!-- Network -->
10:21:24:  <proxy v=':8080'/>
10:21:24:
10:21:24:  <!-- Slot Control -->
10:21:24:  <power v='FULL'/>
10:21:24:
10:21:24:  <!-- Folding Slots -->
10:21:24:  <slot id='0' type='CPU'>
10:21:24:    <cpus v='4'/>
10:21:24:  </slot>
10:21:24:  <slot id='1' type='GPU'/>
10:21:24:</config>
10:21:29:WU01:FS01:Connecting to 171.67.108.45:80
10:21:42:WARNING:WU00:FS00:Failed to get assignment from '171.67.108.45:8080': Failed to connect to 171.67.108.45:8080: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.
10:21:42:WU00:FS00:Connecting to 171.64.65.35:80
10:21:43:WU00:FS00:Assigned to work server 171.67.108.158
10:21:43:WU00:FS00:Requesting new work unit for slot 00: READY cpu:4 from 171.67.108.158
10:21:43:WU00:FS00:Connecting to 171.67.108.158:8080
10:21:50:WARNING:WU01:FS01:Failed to get assignment from '171.67.108.45:80': Failed to connect to 171.67.108.45:80: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.
10:21:50:WU01:FS01:Connecting to 171.67.108.204:80
10:22:04:WARNING:WU00:FS00:WorkServer connection failed on port 8080 trying 80
10:22:04:WU00:FS00:Connecting to 171.67.108.158:80
10:22:05:WU00:FS00:Downloading 807.03KiB
10:22:07:WU00:FS00:Download complete
10:22:07:WU00:FS00:Received Unit: id:00 state:DOWNLOAD error:NO_ERROR project:9037 run:315 clone:1 gen:311 core:0xa4 unit:0x0000015cab436c9e56982b7073962db7
10:22:07:WU00:FS00:Downloading core from http://web.stanford.edu/~pande/Win32/AMD64/Core_a4.fah
10:22:07:WU00:FS00:Connecting to web.stanford.edu:80
10:22:08:WU00:FS00:FahCore a4: Downloading 2.89MiB
10:22:11:WARNING:WU01:FS01:Failed to get assignment from '171.67.108.204:80': Failed to connect to 171.67.108.204:80: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.
10:22:11:ERROR:WU01:FS01:Exception: Could not get an assignment
10:22:14:WU00:FS00:FahCore a4: 64.93%
10:22:17:WU00:FS00:FahCore a4: Download complete
10:22:17:WU00:FS00:Valid core signature
10:22:17:WU00:FS00:Unpacked 9.59MiB to cores/web.stanford.edu/~pande/Win32/AMD64/Core_a4.fah/FahCore_a4.exe
10:22:17:WU00:FS00:Starting
10:22:17:WU00:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:/ProgramData/FAHClient/cores/web.stanford.edu/~pande/Win32/AMD64/Core_a4.fah/FahCore_a4.exe -dir 00 -suffix 01 -version 704 -lifeline 4352 -checkpoint 15 -np 4
10:22:17:WU00:FS00:Started FahCore on PID 5812
10:22:17:WU00:FS00:Core PID:2768
10:22:17:WU00:FS00:FahCore 0xa4 started
10:22:17:WU00:FS00:0xa4:
10:22:17:WU00:FS00:0xa4:*------------------------------*
10:22:17:WU00:FS00:0xa4:Folding@Home Gromacs GB Core
10:22:17:WU00:FS00:0xa4:Version 2.27 (Dec. 15, 2010)
10:22:17:WU00:FS00:0xa4:Preparing to commence simulation
10:22:17:WU00:FS00:0xa4:- Looking at optimizations...
10:22:17:WU00:FS00:0xa4:- Created dyn
10:22:17:WU00:FS00:0xa4:- Files status OK
10:22:17:WU00:FS00:0xa4:- Expanded 825889 -> 1403472 (decompressed 169.9 percent)
10:22:17:WU00:FS00:0xa4:Called DecompressByteArray: compressed_data_size=825889 data_size=1403472, decompressed_data_size=1403472 diff=0
10:22:17:WU00:FS00:0xa4:- Digital signature verified
10:22:17:WU00:FS00:0xa4:Project: 9037 (Run 315, Clone 1, Gen 311)
10:22:17:WU00:FS00:0xa4:Assembly optimizations on if available.
10:22:17:WU00:FS00:0xa4:Entering M.D.
10:22:23:WU00:FS00:0xa4:Mapping NT from 4 to 4
10:22:23:WU00:FS00:0xa4:Completed 0 out of 250000 steps  (0%)
10:23:40:Connecting to assign-GPU.stanford.edu:80
10:23:57:WU00:FS00:0xa4:Completed 2500 out of 250000 steps  (1%)
10:24:01:WARNING:Attempting to update GPUs.txt from assign-GPU.stanford.edu:80: Failed to connect to assign-GPU.stanford.edu:80: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.
10:24:01:Connecting to assign-GPU2.stanford.edu:80
10:24:22:WARNING:Attempting to update GPUs.txt from assign-GPU2.stanford.edu:80: Failed to connect to assign-GPU2.stanford.edu:80: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.
10:25:21:WU00:FS00:0xa4:Completed 5000 out of 250000 steps  (2%)
10:25:40:Saving configuration to config.xml
10:25:40:<config>
10:25:40:  <!-- Network -->
10:25:40:  <proxy v=':8080'/>
10:25:40:
10:25:40:  <!-- Slot Control -->
10:25:40:  <power v='FULL'/>
10:25:40:
10:25:40:  <!-- Folding Slots -->
10:25:40:  <slot id='0' type='CPU'>
10:25:40:    <cpus v='8'/>
10:25:40:  </slot>
10:25:40:  <slot id='1' type='GPU'/>
10:25:40:</config>
10:25:40:FS00:Shutting core down
10:25:47:WU00:FS00:FahCore returned: INTERRUPTED (102 = 0x66)
10:25:47:WU00:FS00:Starting
10:25:47:WARNING:WU00:FS00:Changed SMP threads from 4 to 8 this can cause some work units to fail
10:25:47:WU00:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:/ProgramData/FAHClient/cores/web.stanford.edu/~pande/Win32/AMD64/Core_a4.fah/FahCore_a4.exe -dir 00 -suffix 01 -version 704 -lifeline 4352 -checkpoint 15 -np 8
10:25:47:WU00:FS00:Started FahCore on PID 3772
10:25:47:WU00:FS00:Core PID:672
10:25:47:WU00:FS00:FahCore 0xa4 started
10:25:48:WU00:FS00:0xa4:
10:25:48:WU00:FS00:0xa4:*------------------------------*
10:25:48:WU00:FS00:0xa4:Folding@Home Gromacs GB Core
10:25:48:WU00:FS00:0xa4:Version 2.27 (Dec. 15, 2010)
10:25:48:WU00:FS00:0xa4:Preparing to commence simulation
10:25:48:WU00:FS00:0xa4:- Looking at optimizations...
10:25:48:WU00:FS00:0xa4:- Files status OK
10:25:48:WU00:FS00:0xa4:- Expanded 825889 -> 1403472 (decompressed 169.9 percent)
10:25:48:WU00:FS00:0xa4:Called DecompressByteArray: compressed_data_size=825889 data_size=1403472, decompressed_data_size=1403472 diff=0
10:25:48:WU00:FS00:0xa4:- Digital signature verified
10:25:48:WU00:FS00:0xa4:Project: 9037 (Run 315, Clone 1, Gen 311)
10:25:48:WU00:FS00:0xa4:Assembly optimizations on if available.
10:25:48:WU00:FS00:0xa4:Entering M.D.
10:25:54:WU00:FS00:0xa4:Mapping NT from 8 to 8
10:25:54:WU00:FS00:0xa4:Completed 0 out of 250000 steps  (0%)
10:26:16:Saving configuration to config.xml
10:26:16:<config>
10:26:16:  <!-- Network -->
10:26:16:  <proxy v=':8080'/>
10:26:16:
10:26:16:  <!-- Slot Control -->
10:26:16:  <power v='FULL'/>
10:26:16:
10:26:16:  <!-- Folding Slots -->
10:26:16:  <slot id='0' type='CPU'>
10:26:16:    <cpus v='6'/>
10:26:16:  </slot>
10:26:16:  <slot id='1' type='GPU'/>
10:26:16:</config>
10:26:16:FS00:Shutting core down
10:26:18:WU00:FS00:FahCore returned: INTERRUPTED (102 = 0x66)
10:26:29:Saving configuration to config.xml
10:26:29:<config>
10:26:29:  <!-- Network -->
10:26:29:  <proxy v=':8080'/>
10:26:29:
10:26:29:  <!-- Slot Control -->
10:26:29:  <power v='FULL'/>
10:26:29:
10:26:29:  <!-- Folding Slots -->
10:26:29:  <slot id='0' type='CPU'>
10:26:29:    <cpus v='6'/>
10:26:29:  </slot>
10:26:29:  <slot id='1' type='GPU'/>
10:26:29:</config>
10:26:47:WU00:FS00:Starting
10:26:47:WARNING:WU00:FS00:Changed SMP threads from 8 to 6 this can cause some work units to fail
10:26:47:WU00:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:/ProgramData/FAHClient/cores/web.stanford.edu/~pande/Win32/AMD64/Core_a4.fah/FahCore_a4.exe -dir 00 -suffix 01 -version 704 -lifeline 4352 -checkpoint 15 -np 6
10:26:47:WU00:FS00:Started FahCore on PID 5936
10:26:47:WU00:FS00:Core PID:728
10:26:47:WU00:FS00:FahCore 0xa4 started
10:26:48:WU00:FS00:0xa4:
10:26:48:WU00:FS00:0xa4:*------------------------------*
10:26:48:WU00:FS00:0xa4:Folding@Home Gromacs GB Core
10:26:48:WU00:FS00:0xa4:Version 2.27 (Dec. 15, 2010)
10:26:48:WU00:FS00:0xa4:Preparing to commence simulation
10:26:48:WU00:FS00:0xa4:- Looking at optimizations...
10:26:48:WU00:FS00:0xa4:- Files status OK
10:26:48:WU00:FS00:0xa4:- Expanded 825889 -> 1403472 (decompressed 169.9 percent)
10:26:48:WU00:FS00:0xa4:Called DecompressByteArray: compressed_data_size=825889 data_size=1403472, decompressed_data_size=1403472 diff=0
10:26:48:WU00:FS00:0xa4:- Digital signature verified
10:26:48:WU00:FS00:0xa4:Project: 9037 (Run 315, Clone 1, Gen 311)
10:26:48:WU00:FS00:0xa4:Assembly optimizations on if available.
10:26:48:WU00:FS00:0xa4:Entering M.D.
10:26:54:WU00:FS00:0xa4:Mapping NT from 6 to 6
10:26:54:WU00:FS00:0xa4:Completed 0 out of 250000 steps  (0%)
10:28:11:WU00:FS00:0xa4:Completed 2500 out of 250000 steps  (1%)
10:28:40:Connecting to assign-GPU.stanford.edu:80
10:29:01:WARNING:Attempting to update GPUs.txt from assign-GPU.stanford.edu:80: Failed to connect to assign-GPU.stanford.edu:80: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.
10:29:01:Connecting to assign-GPU2.stanford.edu:80
10:29:22:WARNING:Attempting to update GPUs.txt from assign-GPU2.stanford.edu:80: Failed to connect to assign-GPU2.stanford.edu:80: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.
10:29:29:WU00:FS00:0xa4:Completed 5000 out of 250000 steps  (2%)
10:30:46:WU00:FS00:0xa4:Completed 7500 out of 250000 steps  (3%)
10:32:04:WU00:FS00:0xa4:Completed 10000 out of 250000 steps  (4%)
10:33:21:WU00:FS00:0xa4:Completed 12500 out of 250000 steps  (5%)
10:33:40:Connecting to assign-GPU.stanford.edu:80
10:34:01:WARNING:Attempting to update GPUs.txt from assign-GPU.stanford.edu:80: Failed to connect to assign-GPU.stanford.edu:80: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.
10:34:01:Connecting to assign-GPU2.stanford.edu:80
10:34:38:WU00:FS00:0xa4:Completed 15000 out of 250000 steps  (6%)
Re: Could not connect to folding server [assign-GPU2]
1) The supply of WUs which will run successfully with 7 active CPUs has dried up. If you want to fold with your CPU, you either need to configure the client to use 6 or less or you need to try the beta client (which has a fix for that problem). I expect the beta client will be released shortly and you can permanently avoid that problem by updating to it when it's released.
2) I'm tracking down someone who can fix the problem with http://assign-gpu2.stanford.edu/. (The new client will permanently fix that problem, too.)
vclor
Post by vclor »
Thanks,
Now i got it working with both CPU and GPU. =)
