[LInux Mint] Can't install FAHcontrol
FAH provides a V7 client installer for Debian / Mint / Ubuntu / RedHat / CentOS / Fedora. Installation on other distros may or may not be easy but if you can offer help to others, they would appreciate it.
mrizzone
Post by mrizzone »
I received this error message:
Suggestions?
Both Phyton and Linux Mint are the latest version.
Thanks!
Matías
Hardware configuration: Mac Pro 2.8 quad 12 GB smp4
MacBook Pro 2.9 i7 8 GB smp2
Re: [LInux Mint] Can't install FAHcontrol
Mint is a distro listed in the installation Guide and is listed under the Downloads for the software under Debian, Mint and Ubuntu, so is not an unsupported version of Linux. A forum search will show a number of postings on this issue, the current FAHControl depends on an older version of Python than is installed by default with the latest Mint version. There are some workarounds posted on installing the older Python version.
iMac 2.8 i7 12 GB smp8, Mac Pro 2.8 quad 12 GB smp6
MacBook Pro 2.9 i7 8 GB smp3
mrizzone
Post by mrizzone »
Thanks!
mrizzone
Post by mrizzone »
Is possible to configure the client without FAHcontrol? Thanks.
mrizzone wrote:Is possible to configure the client without FAHcontrol? Thanks.
Yes, but not recommended.
Did you find this solution while searching the forum? viewtopic.php?p=287334#p287334
awannabeee
Post by awannabeee »
Is there any follow up to a solution?
SteveWillis
Hardware configuration: PC 1:
Linux Mint 17.3
PC2:
Linux Mint 18
Open air case
three gtx 1080,
Post by SteveWillis »
What worked for me on linux mint 18 was:
#fah folding at home python fix
wget http://launchpadlibrarian.net/109052632 ... 15_all.deb
sudo dpkg -i python-support_1.0.15_all.deb
You's think that a later version of Python would work, but the python development team has not been particulary supportive of such releases. Moreover, those who create the Linux install packages only ship the latest and you have to search for the kind of .deb that Steve Willis found for you. (I've see the same problem on other distros)
