GTX 960
GTX 960
Hi Guys,
Well my i7 cpu, with the new evga gtx960, is up & running. I've installed FAH on it & changed identity to my passkey. I looked at 'slots' it says: '0 - cpu, 1 - GPU'. Is there anything else to do, or did the software figure out whats best.
NVIDIA has a new driver, for the 900 series, ver. 372.54, I've updated to it. Will win10, want to install it's driver at the next windows updates?
Re: GTX 960
Yes, Win10 will (eventually) want to update your driver and when it does, they'll break FAH by uninstalling OpenCL. Manually install the recommended driver from NVidia and reconfigure Win10 NOT to install drivers.
Post the top portion of your log per the instructions below.
Log Ricorocks
*********************** Log Started 2016-08-16T18:19:07Z ***********************
18:19:07:************************* Folding@home Client *************************
18:19:07: Website: http://folding.stanford.edu/
18:19:07: Copyright: (c) 2009-2014 Stanford University
18:19:07: Author: Joseph Coffland <joseph@cauldrondevelopment.com>
18:19:07: Args:
18:19:07: Config: C:/Users/rick/AppData/Roaming/FAHClient/config.xml
18:19:07:******************************** Build ********************************
18:19:07: Version: 7.4.4
18:19:07: Date: Mar 4 2014
18:19:07: Time: 20:26:54
18:19:07: SVN Rev: 4130
18:19:07: Branch: fah/trunk/client
18:19:07: Compiler: Intel(R) C++ MSVC 1500 mode 1200
18:19:07: Options: /TP /nologo /EHa /Qdiag-disable:4297,4103,1786,279 /Ox -arch:SSE
18:19:07: /QaxSSE2,SSE3,SSSE3,SSE4.1,SSE4.2 /Qopenmp /Qrestrict /MT /Qmkl
18:19:07: Platform: win32 XP
18:19:07: Bits: 32
18:19:07: Mode: Release
18:19:07:******************************* System ********************************
18:19:07: CPU: Intel(R) Core(TM) i7 CPU 950 @ 3.07GHz
18:19:07: CPU ID: GenuineIntel Family 6 Model 26 Stepping 5
18:19:07: CPUs: 8
18:19:07: Memory: 11.99GiB
18:19:07: Free Memory: 9.79GiB
18:19:07: Threads: WINDOWS_THREADS
18:19:07: OS Version: 6.2
18:19:07: Has Battery: false
18:19:07: On Battery: false
18:19:07: UTC Offset: -5
18:19:07: PID: 6056
18:19:07: CWD: C:/Users/rick/AppData/Roaming/FAHClient
18:19:07: OS: Windows 10 Pro
18:19:07: OS Arch: AMD64
18:19:07: GPUs: 1
18:19:07: GPU 0: NVIDIA:5 GM206 [GeForce GTX 960]
18:19:07: CUDA: 5.2
18:19:07: CUDA Driver: 8000
18:19:07:Win32 Service: false
18:19:07:***********************************************************************
18:19:07:<config>
18:19:07: <!-- Slot Control -->
18:19:07: <power v='FULL'/>
18:19:07:
18:19:07: <!-- User Information -->
18:19:07: <passkey v='********************************'/>
18:19:07: <user v='Ricorocks'/>
18:19:07:
18:19:07: <!-- Folding Slots -->
18:19:07: <slot id='0' type='CPU'/>
18:19:07: <slot id='1' type='GPU'/>
18:19:07:</config>
18:19:07:Trying to access database...
18:19:07:Successfully acquired database lock
18:19:07:Enabled folding slot 00: READY cpu:7
18:19:07:Enabled folding slot 01: READY gpu:0:GM206 [GeForce GTX 960]
18:19:08:WU00:FS00:Starting
18:19:08:WU00:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:/Users/rick/AppData/Roaming/FAHClient/cores/web.stanford.edu/~pande/Win32/AMD64/Core_a4.fah/FahCore_a4.exe -dir 00 -suffix 01 -version 704 -lifeline 6056 -checkpoint 15 -np 7
18:19:10:WU00:FS00:Started FahCore on PID 1048
18:19:11:WU00:FS00:Core PID:7640
18:19:11:WU00:FS00:FahCore 0xa4 started
18:19:12:WU01:FS01:Starting
18:19:12:WU01:FS01:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:/Users/rick/AppData/Roaming/FAHClient/cores/web.stanford.edu/~pande/Win32/AMD64/NVIDIA/Fermi/Core_21.fah/FahCore_21.exe -dir 01 -suffix 01 -version 704 -lifeline 6056 -checkpoint 15 -gpu 0 -gpu-vendor nvidia
18:19:12:WU01:FS01:Started FahCore on PID 7596
18:19:12:WU00:FS00:0xa4:
18:19:12:WU00:FS00:0xa4:*------------------------------*
18:19:12:WU00:FS00:0xa4:Folding@Home Gromacs GB Core
18:19:12:WU00:FS00:0xa4:Version 2.27 (Dec. 15, 2010)
18:19:12:WU00:FS00:0xa4:Preparing to commence simulation
18:19:12:WU00:FS00:0xa4:- Ensuring status. Please wait.
18:19:14:WU01:FS01:Core PID:3960
18:19:14:WU01:FS01:FahCore 0x21 started
18:19:15:WU01:FS01:0x21:*********************** Log Started 2016-08-16T18:19:15Z ***********************
18:19:15:WU01:FS01:0x21:Project: 9704 (Run 22, Clone 3, Gen 328)
18:19:15:WU01:FS01:0x21:Unit: 0x000001b3ab404162553ebf0a3348c536
18:19:15:WU01:FS01:0x21:CPU: 0x00000000000000000000000000000000
18:19:15:WU01:FS01:0x21:Machine: 1
18:19:15:WU01:FS01:0x21:Digital signatures verified
18:19:15:WU01:FS01:0x21:Folding@home GPU Core21 Folding@home Core
18:19:15:WU01:FS01:0x21:Version 0.0.17
18:19:21:WU00:FS00:0xa4:- Looking at optimizations...
18:19:21:WU00:FS00:0xa4:- Working with standard loops on this execution.
18:19:21:WU00:FS00:0xa4:- Previous termination of core was improper.
18:19:21:WU00:FS00:0xa4:- Files status OK
18:19:22:WU00:FS00:0xa4:- Expanded 825858 -> 1403132 (decompressed 169.8 percent)
18:19:22:WU00:FS00:0xa4:Called DecompressByteArray: compressed_data_size=825858 data_size=1403132, decompressed_data_size=1403132 diff=0
18:19:22:WU00:FS00:0xa4:- Digital signature verified
18:19:22:WU00:FS00:0xa4:Project: 9036 (Run 869, Clone 0, Gen 320)
18:19:23:WU00:FS00:0xa4:Entering M.D.
18:19:29:WU00:FS00:0xa4:Using Gromacs checkpoints
18:19:29:WU00:FS00:0xa4:Mapping NT from 7 to 7
18:19:29:WU00:FS00:0xa4:Resuming from checkpoint
18:19:29:WU00:FS00:0xa4:Verified 00/wudata_01.log
18:19:29:WU00:FS00:0xa4:Verified 00/wudata_01.trr
18:19:29:WU00:FS00:0xa4:Verified 00/wudata_01.xtc
18:19:29:WU00:FS00:0xa4:Verified 00/wudata_01.edr
18:19:29:WU00:FS00:0xa4:Completed 31785 out of 250000 steps (12%)
18:20:15:WU00:FS00:0xa4:Completed 32500 out of 250000 steps (13%)
18:21:54:16:127.0.0.1:New Web connection
18:22:02:WU01:FS01:0x21:Completed 0 out of 640000 steps (0%)
18:22:02:WU01:FS01:0x21:Temperature control disabled. Requirements: single Nvidia GPU, tmax must be < 110 and twait >= 900
18:22:32:WU00:FS00:0xa4:Completed 35000 out of 250000 steps (14%)
18:24:38:WU00:FS00:0xa4:Completed 37500 out of 250000 steps (15%)
18:25:19:WU01:FS01:0x21:Completed 6400 out of 640000 steps (1%)
18:26:41:WU00:FS00:0xa4:Completed 40000 out of 250000 steps (16%)
18:28:33:WU01:FS01:0x21:Completed 12800 out of 640000 steps (2%)
18:28:56:WU00:FS00:0xa4:Completed 42500 out of 250000 steps (17%)
18:31:42:WU00:FS00:0xa4:Completed 45000 out of 250000 steps (18%)
18:31:47:WU01:FS01:0x21:Completed 19200 out of 640000 steps (3%)
18:34:35:WU00:FS00:0xa4:Completed 47500 out of 250000 steps (19%)
18:35:01:WU01:FS01:0x21:Completed 25600 out of 640000 steps (4%)
18:37:21:WU00:FS00:0xa4:Completed 50000 out of 250000 steps (20%)
18:38:14:WU01:FS01:0x21:Completed 32000 out of 640000 steps (5%)
18:40:05:WU00:FS00:0xa4:Completed 52500 out of 250000 steps (21%)
18:41:28:WU01:FS01:0x21:Completed 38400 out of 640000 steps (6%)
18:42:49:WU00:FS00:0xa4:Completed 55000 out of 250000 steps (22%)
18:44:42:WU01:FS01:0x21:Completed 44800 out of 640000 steps (7%)
18:45:32:WU00:FS00:0xa4:Completed 57500 out of 250000 steps (23%)
18:47:56:WU01:FS01:0x21:Completed 51200 out of 640000 steps (8%)
18:48:13:WU00:FS00:0xa4:Completed 60000 out of 250000 steps (24%)
18:50:18:WU00:FS00:0xa4:Completed 62500 out of 250000 steps (25%)
18:51:10:WU01:FS01:0x21:Completed 57600 out of 640000 steps (9%)
18:52:22:WU00:FS00:0xa4:Completed 65000 out of 250000 steps (26%)
18:54:23:WU01:FS01:0x21:Completed 64000 out of 640000 steps (10%)
18:54:25:WU00:FS00:0xa4:Completed 67500 out of 250000 steps (27%)
18:56:27:WU00:FS00:0xa4:Completed 70000 out of 250000 steps (28%)
18:57:36:WU01:FS01:0x21:Completed 70400 out of 640000 steps (11%)
18:58:31:WU00:FS00:0xa4:Completed 72500 out of 250000 steps (29%)
19:00:34:WU00:FS00:0xa4:Completed 75000 out of 250000 steps (30%)
19:00:50:WU01:FS01:0x21:Completed 76800 out of 640000 steps (12%)
19:02:38:WU00:FS00:0xa4:Completed 77500 out of 250000 steps (31%)
19:04:14:WU01:FS01:0x21:Completed 83200 out of 640000 steps (13%)
19:04:41:WU00:FS00:0xa4:Completed 80000 out of 250000 steps (32%)
19:06:43:WU00:FS00:0xa4:Completed 82500 out of 250000 steps (33%)
19:07:28:WU01:FS01:0x21:Completed 89600 out of 640000 steps (14%)
19:08:46:WU00:FS00:0xa4:Completed 85000 out of 250000 steps (34%)
19:10:42:WU01:FS01:0x21:Completed 96000 out of 640000 steps (15%)
19:10:51:WU00:FS00:0xa4:Completed 87500 out of 250000 steps (35%)
Re: GTX 960
My guess was right.
Open Advanced Control (aka FAHControl)
Select Configure + Slots + cpu + Edit
Near the top, change the number of CPUs to 6
OK + Save.
18:19:07:Enabled folding slot 00: READY cpu:7Select Configure + Slots + cpu + Edit
OK + Save.
Re: GTX 960
I read your post as configure > slots > choose highlight cpu > edit > change to cpu to 6?
I did the above, which took me to another page, which said cpu -1, is this the value to change to six?
Re: GTX 960
Okay! Got it now at web control it says CPU-6. The little circle (near progress bar) is yellow, the GPU's circle is green & cranking. The changes were made to the machine the log came from. I'll check back in an hour or so, hopefully, CPU is green & progessing.
Thanks
Rico
NOTE: I could tell FAH was inactive on the CPU as its temp went fro 71 to 56C, also GPU temp stays at 71 - 72C, is this ok, or more cooling required? Perhaps CPU's circle was yellow, awaiting next dl The GPU was still working.
Thanks
Rico
PS3EdOlkkola
9 AMD GPU folding slots
31 Nvidia GPU folding slots
50 total folding slots
Re: GTX 960
The temperature case rating (the maximum temperature allowed at the processor Integrated Heat Spreader) for your i7-950 is 67.9 deg C. (Ref: http://ark.intel.com/products/37150/Int ... -Intel-QPI), so by that standard you could use a better cooling solution.
Re: GTX 960
Okay! All is well, I guess the cpu finished its job & the gpu was still active, once the gpu finished, new assignments were give & both are folding! GR8!
PS3EdOlkkola - I read your comments and immediately used VNC, to check on the heat situation 72 cpu, 72-73 gpu.
Before this came into service, used the air compressor, to blow out, stopped tha fans from spinning while cleaning. Any suggestions for cooling, all 4 core cpu's 71 - 73C, should I shut down now? DL Speedfan supposed to allow user settings for fan speeds, still trying to figure out how & how fast. I'll DL afterburner now
Thanks Amigo
Thanks Amigo
Re: GTX 960
Thanks Amigo
Thanks Amigo
PS3EdOlkkola
Re: GTX 960
If you're running the current CPU cooling fan at 100%, then a better solution is needed. I believe you mentioned your case is full-size, so the good news is you likely have enough room for a better cooling solution that won't cost a fortune. I've used the Coolermaster Hyper 212 cooling solution in the past and been very pleased with it. The only reason I don't use the 212 series now is because my server cases are too short for the height of the cooler. This model is compatible with the socket profile of your i7-950 (LGA 1366) and is relatively inexpensive ($44.99) for a two-fan (push-pull) cooler: http://www.newegg.com/Product/Product.a ... 000X-00037 Just check height, width and depth to make sure it fits within your case, and check to be sure if will fit over your DRAM sticks if you have high-profile memory (i.e. tall heat spreaders). Others may have a different opinion, but I'd suspend SMP (CPU) folding until you get a better cooling solution installed.
Re: GTX 960
I'm sorry to disagree but the CPU temperature 73°C is fine. If you hit 90°C then you have a problem and the PC will shutdown itself.
http://www.overclock.net/t/843863/intel ... empurature
The value for the CPU to change must be 6 (not -6)
Re: GTX 960
Good Morning Guys,
I throttled FAH to medium overnight & now it's cpu 72, gpu 71 & mb 54. So med or fast speed same. I'm not sure it it's a full tower, it's definitely larger than most desktop cases, it a "RaidMaxEnzo." The case has no vents, left un-used to mount another fan. I do not know how to push the cpu fan, previously at cpu 72, one of those GPUz reported fan usage at 34%. It seems like that would be, the fan is in "auto" & adjusting fan usage to the heat load. Would running with the cover OFF, help? CPU is set for 6.
This is what sit on to of the CPU now: http://www.newegg.com/Product/Product.a ... 6835103055. A long time ago this V8 fan, was bad, the system notified me that this fan was bad. I took it for repair, they had to remove the MB, to replace.
memory is 12 gb, 2gb x 6, ddr3 1333 triple mem module, Corsair value.
Okay, the new machine has not been on line a full 24hrs, yet & at least 8 hrs. FaH set "Medium" I began yesterday at 69,554 pts, & 105 WU's, this morning 177,053 pts & 115 WU's.
Re: GTX 960
Temperatures are all fine
If you take cover off then dust will get all over your case inside.
If you want to take a tool you can make vents at the bottom of the case and put a big fan there including a dust filter.
http://ru.gecid.com/cases/raidmax_enzo/?s=all
Re: GTX 960
Hi Foldy,
Been checking out in addition to your link, other O.C forums. This topic is like two guys arguing Ford vs Chevy. I believe the GPU temp. is "fine", if it thought it was hot, %Fan would increase, higher than the current 34%.
I also believe, that Intel set's its temp guideline (should not exceed), conservatively, or what they are comfortable with under normal usage. I've found that many think the i7 runs hot, in comparison to what, not mentioned. It would be nice to know what others here are experiencing!
Thinking out loud, on my case, the cover (plastic &metal) has two vents, the upper vent appears to be the size of a 5.5" case fan, I wonder if attaching, a fan there, blowing OUT, so as to suck hot air out, would be helpful. The only think I can think of is, bu sucking air out, by fan this may dirupt the normal air flow, inside the case, causing temps to go up. I will monitor & test, I have all the stuff already & the fan can be run via usb or AC. I McGivered a test, had to use bottom, vent, top vent to flat, some gorilla tape, & it's sucking & blowing. If this works ill try mounting the fan on the inside top, using either glue or screws.
Re: GTX 960
Wow! Approx. 1hr running McGiver mods.
without: with Mcgiver
CPU 72 68
mb 54 51
gpu 71 72 68
also maybe only one qtr. of the fan covers, the vent. I think I can mount, inside the case, top vent, & the fan would match, the vents dimensions. I'll wait to hear from you guys, before I get the hammer & nails out. just about 6% improvement cpu mb, & gpu.
CPU 72 68
mb 54 51
gpu 71 72 68
